[PATCH 1/2] test/py: efi_secboot: apply autopep8
Python's autopep8 can automatically correct some of warnings from pylint and rewrite the code in a pretty print format. So just do it.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org Suggested-by: Heinrich Schuchardt xypron.glpk@gmx.de --- test/py/tests/test_efi_secboot/conftest.py | 162 ++++++++++-------- test/py/tests/test_efi_secboot/defs.py | 14 +- .../py/tests/test_efi_secboot/test_authvar.py | 1 + test/py/tests/test_efi_secboot/test_signed.py | 1 + .../tests/test_efi_secboot/test_unsigned.py | 37 ++-- 5 files changed, 118 insertions(+), 97 deletions(-)
diff --git a/test/py/tests/test_efi_secboot/conftest.py b/test/py/tests/test_efi_secboot/conftest.py index 5ac0389064e8..f74b4b109a7b 100644 --- a/test/py/tests/test_efi_secboot/conftest.py +++ b/test/py/tests/test_efi_secboot/conftest.py @@ -10,6 +10,8 @@ from subprocess import call, check_call, check_output, CalledProcessError from defs import *
# from test/py/conftest.py + + def tool_is_in_path(tool): for path in os.environ["PATH"].split(os.pathsep): fn = os.path.join(path, tool) @@ -20,13 +22,15 @@ def tool_is_in_path(tool): # # Fixture for UEFI secure boot test # + + @pytest.fixture(scope='session') def efi_boot_env(request, u_boot_config): """Set up a file system to be used in UEFI secure boot test.
Args: request: Pytest request object. - u_boot_config: U-boot configuration. + u_boot_config: U-boot configuration.
Return: A path to disk image to be used for testing @@ -48,20 +52,21 @@ def efi_boot_env(request, u_boot_config):
# create a disk/partition check_call('dd if=/dev/zero of=%s bs=1MiB count=%d' - % (image_path, image_size), shell=True) + % (image_path, image_size), shell=True) check_call('sgdisk %s -n 1:0:+%dMiB' - % (image_path, part_size), shell=True) + % (image_path, part_size), shell=True) # create a file system check_call('dd if=/dev/zero of=%s.tmp bs=1MiB count=%d' - % (image_path, part_size), shell=True) + % (image_path, part_size), shell=True) check_call('mkfs -t %s %s.tmp' % (fs_type, image_path), shell=True) check_call('dd if=%s.tmp of=%s bs=1MiB seek=1 count=%d conv=notrunc' - % (image_path, image_path, 1), shell=True) + % (image_path, image_path, 1), shell=True) check_call('rm %s.tmp' % image_path, shell=True) - loop_dev = check_output('sudo losetup -o 1MiB --sizelimit %dMiB --show -f %s | tr -d "\n"' - % (part_size, image_path), shell=True).decode() + loop_dev = check_output( + 'sudo losetup -o 1MiB --sizelimit %dMiB --show -f %s | tr -d "\n"' % + (part_size, image_path), shell=True).decode() check_output('sudo mount -t %s -o umask=000 %s %s' - % (fs_type, loop_dev, mnt_point), shell=True) + % (fs_type, loop_dev, mnt_point), shell=True)
# suffix # *.key: RSA private key in PEM @@ -73,75 +78,88 @@ def efi_boot_env(request, u_boot_config): # *.efi.signed: signed UEFI image
# Create signature database - ## PK - check_call('cd %s; openssl req -x509 -sha256 -newkey rsa:2048 -subj /CN=TEST_PK/ -keyout PK.key -out PK.crt -nodes -days 365' - % mnt_point, shell=True) - check_call('cd %s; %scert-to-efi-sig-list -g %s PK.crt PK.esl; %ssign-efi-sig-list -c PK.crt -k PK.key PK PK.esl PK.auth' - % (mnt_point, EFITOOLS_PATH, GUID, EFITOOLS_PATH), - shell=True) - ## PK_null for deletion - check_call('cd %s; sleep 2; touch PK_null.esl; %ssign-efi-sig-list -c PK.crt -k PK.key PK PK_null.esl PK_null.auth' - % (mnt_point, EFITOOLS_PATH), shell=True) - ## KEK - check_call('cd %s; openssl req -x509 -sha256 -newkey rsa:2048 -subj /CN=TEST_KEK/ -keyout KEK.key -out KEK.crt -nodes -days 365' - % mnt_point, shell=True) - check_call('cd %s; %scert-to-efi-sig-list -g %s KEK.crt KEK.esl; %ssign-efi-sig-list -c PK.crt -k PK.key KEK KEK.esl KEK.auth' - % (mnt_point, EFITOOLS_PATH, GUID, EFITOOLS_PATH), - shell=True) - ## db - check_call('cd %s; openssl req -x509 -sha256 -newkey rsa:2048 -subj /CN=TEST_db/ -keyout db.key -out db.crt -nodes -days 365' - % mnt_point, shell=True) - check_call('cd %s; %scert-to-efi-sig-list -g %s db.crt db.esl; %ssign-efi-sig-list -c KEK.crt -k KEK.key db db.esl db.auth' - % (mnt_point, EFITOOLS_PATH, GUID, EFITOOLS_PATH), - shell=True) - ## db1 - check_call('cd %s; openssl req -x509 -sha256 -newkey rsa:2048 -subj /CN=TEST_db1/ -keyout db1.key -out db1.crt -nodes -days 365' - % mnt_point, shell=True) - check_call('cd %s; %scert-to-efi-sig-list -g %s db1.crt db1.esl; %ssign-efi-sig-list -c KEK.crt -k KEK.key db db1.esl db1.auth' - % (mnt_point, EFITOOLS_PATH, GUID, EFITOOLS_PATH), - shell=True) - ## db1-update - check_call('cd %s; %ssign-efi-sig-list -a -c KEK.crt -k KEK.key db db1.esl db1-update.auth' - % (mnt_point, EFITOOLS_PATH), shell=True) - ## dbx (TEST_dbx certificate) - check_call('cd %s; openssl req -x509 -sha256 -newkey rsa:2048 -subj /CN=TEST_dbx/ -keyout dbx.key -out dbx.crt -nodes -days 365' - % mnt_point, shell=True) - check_call('cd %s; %scert-to-efi-sig-list -g %s dbx.crt dbx.esl; %ssign-efi-sig-list -c KEK.crt -k KEK.key dbx dbx.esl dbx.auth' - % (mnt_point, EFITOOLS_PATH, GUID, EFITOOLS_PATH), - shell=True) - ## dbx_hash (digest of TEST_db certificate) - check_call('cd %s; %scert-to-efi-hash-list -g %s -t 0 -s 256 db.crt dbx_hash.crl; %ssign-efi-sig-list -c KEK.crt -k KEK.key dbx dbx_hash.crl dbx_hash.auth' - % (mnt_point, EFITOOLS_PATH, GUID, EFITOOLS_PATH), - shell=True) - ## dbx_hash1 (digest of TEST_db1 certificate) - check_call('cd %s; %scert-to-efi-hash-list -g %s -t 0 -s 256 db1.crt dbx_hash1.crl; %ssign-efi-sig-list -c KEK.crt -k KEK.key dbx dbx_hash1.crl dbx_hash1.auth' - % (mnt_point, EFITOOLS_PATH, GUID, EFITOOLS_PATH), - shell=True) - ## dbx_db (with TEST_db certificate) - check_call('cd %s; %ssign-efi-sig-list -c KEK.crt -k KEK.key dbx db.esl dbx_db.auth' - % (mnt_point, EFITOOLS_PATH), - shell=True) + # PK + check_call( + 'cd %s; openssl req -x509 -sha256 -newkey rsa:2048 -subj /CN=TEST_PK/ -keyout PK.key -out PK.crt -nodes -days 365' % + mnt_point, + shell=True) + check_call( + 'cd %s; %scert-to-efi-sig-list -g %s PK.crt PK.esl; %ssign-efi-sig-list -c PK.crt -k PK.key PK PK.esl PK.auth' % + (mnt_point, EFITOOLS_PATH, GUID, EFITOOLS_PATH), shell=True) + # PK_null for deletion + check_call( + 'cd %s; sleep 2; touch PK_null.esl; %ssign-efi-sig-list -c PK.crt -k PK.key PK PK_null.esl PK_null.auth' % + (mnt_point, EFITOOLS_PATH), shell=True) + # KEK + check_call( + 'cd %s; openssl req -x509 -sha256 -newkey rsa:2048 -subj /CN=TEST_KEK/ -keyout KEK.key -out KEK.crt -nodes -days 365' % + mnt_point, + shell=True) + check_call( + 'cd %s; %scert-to-efi-sig-list -g %s KEK.crt KEK.esl; %ssign-efi-sig-list -c PK.crt -k PK.key KEK KEK.esl KEK.auth' % + (mnt_point, EFITOOLS_PATH, GUID, EFITOOLS_PATH), shell=True) + # db + check_call( + 'cd %s; openssl req -x509 -sha256 -newkey rsa:2048 -subj /CN=TEST_db/ -keyout db.key -out db.crt -nodes -days 365' % + mnt_point, + shell=True) + check_call( + 'cd %s; %scert-to-efi-sig-list -g %s db.crt db.esl; %ssign-efi-sig-list -c KEK.crt -k KEK.key db db.esl db.auth' % + (mnt_point, EFITOOLS_PATH, GUID, EFITOOLS_PATH), shell=True) + # db1 + check_call( + 'cd %s; openssl req -x509 -sha256 -newkey rsa:2048 -subj /CN=TEST_db1/ -keyout db1.key -out db1.crt -nodes -days 365' % + mnt_point, + shell=True) + check_call( + 'cd %s; %scert-to-efi-sig-list -g %s db1.crt db1.esl; %ssign-efi-sig-list -c KEK.crt -k KEK.key db db1.esl db1.auth' % + (mnt_point, EFITOOLS_PATH, GUID, EFITOOLS_PATH), shell=True) + # db1-update + check_call( + 'cd %s; %ssign-efi-sig-list -a -c KEK.crt -k KEK.key db db1.esl db1-update.auth' % + (mnt_point, EFITOOLS_PATH), shell=True) + # dbx (TEST_dbx certificate) + check_call( + 'cd %s; openssl req -x509 -sha256 -newkey rsa:2048 -subj /CN=TEST_dbx/ -keyout dbx.key -out dbx.crt -nodes -days 365' % + mnt_point, + shell=True) + check_call( + 'cd %s; %scert-to-efi-sig-list -g %s dbx.crt dbx.esl; %ssign-efi-sig-list -c KEK.crt -k KEK.key dbx dbx.esl dbx.auth' % + (mnt_point, EFITOOLS_PATH, GUID, EFITOOLS_PATH), shell=True) + # dbx_hash (digest of TEST_db certificate) + check_call( + 'cd %s; %scert-to-efi-hash-list -g %s -t 0 -s 256 db.crt dbx_hash.crl; %ssign-efi-sig-list -c KEK.crt -k KEK.key dbx dbx_hash.crl dbx_hash.auth' % + (mnt_point, EFITOOLS_PATH, GUID, EFITOOLS_PATH), shell=True) + # dbx_hash1 (digest of TEST_db1 certificate) + check_call( + 'cd %s; %scert-to-efi-hash-list -g %s -t 0 -s 256 db1.crt dbx_hash1.crl; %ssign-efi-sig-list -c KEK.crt -k KEK.key dbx dbx_hash1.crl dbx_hash1.auth' % + (mnt_point, EFITOOLS_PATH, GUID, EFITOOLS_PATH), shell=True) + # dbx_db (with TEST_db certificate) + check_call( + 'cd %s; %ssign-efi-sig-list -c KEK.crt -k KEK.key dbx db.esl dbx_db.auth' % + (mnt_point, EFITOOLS_PATH), shell=True)
# Copy image check_call('cp %s %s' % (HELLO_PATH, mnt_point), shell=True)
- ## Sign image + # Sign image check_call('cd %s; sbsign --key db.key --cert db.crt helloworld.efi' - % mnt_point, shell=True) - ## Sign already-signed image with another key - check_call('cd %s; sbsign --key db1.key --cert db1.crt --output helloworld.efi.signed_2sigs helloworld.efi.signed' - % mnt_point, shell=True) - ## Digest image - check_call('cd %s; %shash-to-efi-sig-list helloworld.efi db_hello.hash; %ssign-efi-sig-list -c KEK.crt -k KEK.key db db_hello.hash db_hello.auth' - % (mnt_point, EFITOOLS_PATH, EFITOOLS_PATH), - shell=True) - check_call('cd %s; %shash-to-efi-sig-list helloworld.efi.signed db_hello_signed.hash; %ssign-efi-sig-list -c KEK.crt -k KEK.key db db_hello_signed.hash db_hello_signed.auth' - % (mnt_point, EFITOOLS_PATH, EFITOOLS_PATH), - shell=True) - check_call('cd %s; %ssign-efi-sig-list -c KEK.crt -k KEK.key dbx db_hello_signed.hash dbx_hello_signed.auth' - % (mnt_point, EFITOOLS_PATH), - shell=True) - + % mnt_point, shell=True) + # Sign already-signed image with another key + check_call( + 'cd %s; sbsign --key db1.key --cert db1.crt --output helloworld.efi.signed_2sigs helloworld.efi.signed' % + mnt_point, + shell=True) + # Digest image + check_call( + 'cd %s; %shash-to-efi-sig-list helloworld.efi db_hello.hash; %ssign-efi-sig-list -c KEK.crt -k KEK.key db db_hello.hash db_hello.auth' % + (mnt_point, EFITOOLS_PATH, EFITOOLS_PATH), shell=True) + check_call( + 'cd %s; %shash-to-efi-sig-list helloworld.efi.signed db_hello_signed.hash; %ssign-efi-sig-list -c KEK.crt -k KEK.key db db_hello_signed.hash db_hello_signed.auth' % + (mnt_point, EFITOOLS_PATH, EFITOOLS_PATH), shell=True) + check_call( + 'cd %s; %ssign-efi-sig-list -c KEK.crt -k KEK.key dbx db_hello_signed.hash dbx_hello_signed.auth' % + (mnt_point, EFITOOLS_PATH), shell=True)
check_call('sudo umount %s' % loop_dev, shell=True) check_call('sudo losetup -d %s' % loop_dev, shell=True) diff --git a/test/py/tests/test_efi_secboot/defs.py b/test/py/tests/test_efi_secboot/defs.py index d6222809c547..099f453979ff 100644 --- a/test/py/tests/test_efi_secboot/defs.py +++ b/test/py/tests/test_efi_secboot/defs.py @@ -1,21 +1,21 @@ # SPDX-License-Identifier: GPL-2.0+
# Disk image name -EFI_SECBOOT_IMAGE_NAME='test_efi_secboot.img' +EFI_SECBOOT_IMAGE_NAME = 'test_efi_secboot.img'
# Size in MiB -EFI_SECBOOT_IMAGE_SIZE=16 -EFI_SECBOOT_PART_SIZE=8 +EFI_SECBOOT_IMAGE_SIZE = 16 +EFI_SECBOOT_PART_SIZE = 8
# Partition file system type -EFI_SECBOOT_FS_TYPE='vfat' +EFI_SECBOOT_FS_TYPE = 'vfat'
# Owner guid -GUID='11111111-2222-3333-4444-123456789abc' +GUID = '11111111-2222-3333-4444-123456789abc'
# v1.5.1 or earlier of efitools has a bug in sha256 calculation, and # you need build a newer version on your own. -EFITOOLS_PATH='' +EFITOOLS_PATH = ''
# Hello World application for sandbox -HELLO_PATH='' +HELLO_PATH = '' diff --git a/test/py/tests/test_efi_secboot/test_authvar.py b/test/py/tests/test_efi_secboot/test_authvar.py index 148aa3123e4f..359adba4b4b7 100644 --- a/test/py/tests/test_efi_secboot/test_authvar.py +++ b/test/py/tests/test_efi_secboot/test_authvar.py @@ -11,6 +11,7 @@ This test verifies variable authentication import pytest from defs import *
+ @pytest.mark.boardspec('sandbox') @pytest.mark.buildconfigspec('efi_secure_boot') @pytest.mark.buildconfigspec('cmd_fat') diff --git a/test/py/tests/test_efi_secboot/test_signed.py b/test/py/tests/test_efi_secboot/test_signed.py index 441f4906c865..c100832a2375 100644 --- a/test/py/tests/test_efi_secboot/test_signed.py +++ b/test/py/tests/test_efi_secboot/test_signed.py @@ -11,6 +11,7 @@ This test verifies image authentication for signed images. import pytest from defs import *
+ @pytest.mark.boardspec('sandbox') @pytest.mark.buildconfigspec('efi_secure_boot') @pytest.mark.buildconfigspec('cmd_efidebug') diff --git a/test/py/tests/test_efi_secboot/test_unsigned.py b/test/py/tests/test_efi_secboot/test_unsigned.py index c42c5ddc4774..3748b51ee7e9 100644 --- a/test/py/tests/test_efi_secboot/test_unsigned.py +++ b/test/py/tests/test_efi_secboot/test_unsigned.py @@ -11,6 +11,7 @@ This test verifies image authentication for unsigned images. import pytest from defs import *
+ @pytest.mark.boardspec('sandbox') @pytest.mark.buildconfigspec('efi_secure_boot') @pytest.mark.buildconfigspec('cmd_efidebug') @@ -28,10 +29,10 @@ class TestEfiUnsignedImage(object): # Test Case 1 output = u_boot_console.run_command_list([ 'host bind 0 %s' % disk_img, - 'fatload host 0:1 4000000 KEK.auth', - 'setenv -e -nv -bs -rt -at -i 4000000,$filesize KEK', - 'fatload host 0:1 4000000 PK.auth', - 'setenv -e -nv -bs -rt -at -i 4000000,$filesize PK']) + 'fatload host 0:1 4000000 KEK.auth', + 'setenv -e -nv -bs -rt -at -i 4000000,$filesize KEK', + 'fatload host 0:1 4000000 PK.auth', + 'setenv -e -nv -bs -rt -at -i 4000000,$filesize PK']) assert(not 'Failed to set EFI variable' in ''.join(output))
output = u_boot_console.run_command_list([ @@ -55,12 +56,12 @@ class TestEfiUnsignedImage(object): # Test Case 2 output = u_boot_console.run_command_list([ 'host bind 0 %s' % disk_img, - 'fatload host 0:1 4000000 db_hello.auth', - 'setenv -e -nv -bs -rt -at -i 4000000,$filesize db', - 'fatload host 0:1 4000000 KEK.auth', - 'setenv -e -nv -bs -rt -at -i 4000000,$filesize KEK', - 'fatload host 0:1 4000000 PK.auth', - 'setenv -e -nv -bs -rt -at -i 4000000,$filesize PK']) + 'fatload host 0:1 4000000 db_hello.auth', + 'setenv -e -nv -bs -rt -at -i 4000000,$filesize db', + 'fatload host 0:1 4000000 KEK.auth', + 'setenv -e -nv -bs -rt -at -i 4000000,$filesize KEK', + 'fatload host 0:1 4000000 PK.auth', + 'setenv -e -nv -bs -rt -at -i 4000000,$filesize PK']) assert(not 'Failed to set EFI variable' in ''.join(output))
output = u_boot_console.run_command_list([ @@ -79,12 +80,12 @@ class TestEfiUnsignedImage(object): # Test Case 3a, rejected by dbx output = u_boot_console.run_command_list([ 'host bind 0 %s' % disk_img, - 'fatload host 0:1 4000000 db_hello.auth', - 'setenv -e -nv -bs -rt -at -i 4000000,$filesize dbx', - 'fatload host 0:1 4000000 KEK.auth', - 'setenv -e -nv -bs -rt -at -i 4000000,$filesize KEK', - 'fatload host 0:1 4000000 PK.auth', - 'setenv -e -nv -bs -rt -at -i 4000000,$filesize PK']) + 'fatload host 0:1 4000000 db_hello.auth', + 'setenv -e -nv -bs -rt -at -i 4000000,$filesize dbx', + 'fatload host 0:1 4000000 KEK.auth', + 'setenv -e -nv -bs -rt -at -i 4000000,$filesize KEK', + 'fatload host 0:1 4000000 PK.auth', + 'setenv -e -nv -bs -rt -at -i 4000000,$filesize PK']) assert(not 'Failed to set EFI variable' in ''.join(output))
output = u_boot_console.run_command_list([ @@ -101,8 +102,8 @@ class TestEfiUnsignedImage(object): with u_boot_console.log.section('Test Case 3b'): # Test Case 3b, rejected by dbx even if db allows output = u_boot_console.run_command_list([ - 'fatload host 0:1 4000000 db_hello.auth', - 'setenv -e -nv -bs -rt -at -i 4000000,$filesize db']) + 'fatload host 0:1 4000000 db_hello.auth', + 'setenv -e -nv -bs -rt -at -i 4000000,$filesize db']) assert(not 'Failed to set EFI variable' in ''.join(output))
More fixes against pylint warnings that autopep8 didn't handle in the previous commit.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- test/py/tests/test_efi_secboot/conftest.py | 11 +-- .../py/tests/test_efi_secboot/test_authvar.py | 91 +++++++++---------- test/py/tests/test_efi_secboot/test_signed.py | 73 ++++++++------- .../tests/test_efi_secboot/test_unsigned.py | 29 +++--- 4 files changed, 100 insertions(+), 104 deletions(-)
diff --git a/test/py/tests/test_efi_secboot/conftest.py b/test/py/tests/test_efi_secboot/conftest.py index f74b4b109a7b..34abcd79ae00 100644 --- a/test/py/tests/test_efi_secboot/conftest.py +++ b/test/py/tests/test_efi_secboot/conftest.py @@ -4,9 +4,8 @@
import os import os.path -import pytest -import re from subprocess import call, check_call, check_output, CalledProcessError +import pytest from defs import *
# from test/py/conftest.py @@ -14,8 +13,8 @@ from defs import *
def tool_is_in_path(tool): for path in os.environ["PATH"].split(os.pathsep): - fn = os.path.join(path, tool) - if os.path.isfile(fn) and os.access(fn, os.X_OK): + full_path = os.path.join(path, tool) + if os.path.isfile(full_path) and os.access(full_path, os.X_OK): return True return False
@@ -164,8 +163,8 @@ def efi_boot_env(request, u_boot_config): check_call('sudo umount %s' % loop_dev, shell=True) check_call('sudo losetup -d %s' % loop_dev, shell=True)
- except CalledProcessError as e: - pytest.skip('Setup failed: %s' % e.cmd) + except CalledProcessError as exception: + pytest.skip('Setup failed: %s' % exception.cmd) return else: yield image_path diff --git a/test/py/tests/test_efi_secboot/test_authvar.py b/test/py/tests/test_efi_secboot/test_authvar.py index 359adba4b4b7..d0c6b9035b1b 100644 --- a/test/py/tests/test_efi_secboot/test_authvar.py +++ b/test/py/tests/test_efi_secboot/test_authvar.py @@ -9,7 +9,6 @@ This test verifies variable authentication """
import pytest -from defs import *
@pytest.mark.boardspec('sandbox') @@ -29,18 +28,18 @@ class TestEfiAuthVar(object): output = u_boot_console.run_command_list([ 'host bind 0 %s' % disk_img, 'printenv -e SecureBoot']) - assert('00000000: 00' in ''.join(output)) + assert '00000000: 00' in ''.join(output)
output = u_boot_console.run_command( 'printenv -e SetupMode') - assert('00000000: 01' in output) + assert '00000000: 01' in output
with u_boot_console.log.section('Test Case 1b'): # Test Case 1b, PK without AUTHENTICATED_WRITE_ACCESS output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 PK.auth', 'setenv -e -nv -bs -rt -i 4000000,$filesize PK']) - assert('Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' in ''.join(output)
with u_boot_console.log.section('Test Case 1c'): # Test Case 1c, install PK @@ -48,79 +47,79 @@ class TestEfiAuthVar(object): 'fatload host 0:1 4000000 PK.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize PK', 'printenv -e -n PK']) - assert('PK:' in ''.join(output)) + assert 'PK:' in ''.join(output)
output = u_boot_console.run_command( 'printenv -e SecureBoot') - assert('00000000: 01' in output) + assert '00000000: 01' in output output = u_boot_console.run_command( 'printenv -e SetupMode') - assert('00000000: 00' in output) + assert '00000000: 00' in output
with u_boot_console.log.section('Test Case 1d'): # Test Case 1d, db/dbx without KEK output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 db.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize db']) - assert('Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' in ''.join(output)
output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 db.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize dbx']) - assert('Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' in ''.join(output)
with u_boot_console.log.section('Test Case 1e'): # Test Case 1e, install KEK output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 KEK.auth', 'setenv -e -nv -bs -rt -i 4000000,$filesize KEK']) - assert('Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' in ''.join(output)
output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 KEK.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize KEK', 'printenv -e -n KEK']) - assert('KEK:' in ''.join(output)) + assert 'KEK:' in ''.join(output)
with u_boot_console.log.section('Test Case 1f'): # Test Case 1f, install db output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 db.auth', 'setenv -e -nv -bs -rt -i 4000000,$filesize db']) - assert('Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' in ''.join(output)
output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 db.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize db', 'printenv -e -n -guid d719b2cb-3d3a-4596-a3bc-dad00e67656f db']) - assert(not 'Failed to set EFI variable' in ''.join(output)) - assert('db:' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output) + assert 'db:' in ''.join(output)
with u_boot_console.log.section('Test Case 1g'): # Test Case 1g, install dbx output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 dbx.auth', 'setenv -e -nv -bs -rt -i 4000000,$filesize dbx']) - assert('Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' in ''.join(output)
output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 dbx.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize dbx', 'printenv -e -n -guid d719b2cb-3d3a-4596-a3bc-dad00e67656f dbx']) - assert(not 'Failed to set EFI variable' in ''.join(output)) - assert('dbx:' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output) + assert 'dbx:' in ''.join(output)
def test_efi_var_auth2(self, u_boot_console, efi_boot_env): """ @@ -139,20 +138,20 @@ class TestEfiAuthVar(object): 'fatload host 0:1 4000000 db.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize db', 'printenv -e -n -guid d719b2cb-3d3a-4596-a3bc-dad00e67656f db']) - assert(not 'Failed to set EFI variable' in ''.join(output)) - assert('db:' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output) + assert 'db:' in ''.join(output)
output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 db1.auth', 'setenv -e -nv -bs -rt -i 4000000,$filesize db']) - assert('Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' in ''.join(output)
with u_boot_console.log.section('Test Case 2b'): # Test Case 2b, update without correct signature output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 db.esl', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize db']) - assert('Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' in ''.join(output)
with u_boot_console.log.section('Test Case 2c'): # Test Case 2c, update with correct signature @@ -160,8 +159,8 @@ class TestEfiAuthVar(object): 'fatload host 0:1 4000000 db1.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize db', 'printenv -e -n -guid d719b2cb-3d3a-4596-a3bc-dad00e67656f db']) - assert(not 'Failed to set EFI variable' in ''.join(output)) - assert('db:' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output) + assert 'db:' in ''.join(output)
def test_efi_var_auth3(self, u_boot_console, efi_boot_env): """ @@ -180,20 +179,20 @@ class TestEfiAuthVar(object): 'fatload host 0:1 4000000 db.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize db', 'printenv -e -n -guid d719b2cb-3d3a-4596-a3bc-dad00e67656f db']) - assert(not 'Failed to set EFI variable' in ''.join(output)) - assert('db:' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output) + assert 'db:' in ''.join(output)
output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 db1.auth', 'setenv -e -nv -bs -rt -a -i 4000000,$filesize db']) - assert('Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' in ''.join(output)
with u_boot_console.log.section('Test Case 3b'): # Test Case 3b, update without correct signature output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 db.esl', 'setenv -e -nv -bs -rt -at -a -i 4000000,$filesize db']) - assert('Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' in ''.join(output)
with u_boot_console.log.section('Test Case 3c'): # Test Case 3c, update with correct signature @@ -201,8 +200,8 @@ class TestEfiAuthVar(object): 'fatload host 0:1 4000000 db1.auth', 'setenv -e -nv -bs -rt -at -a -i 4000000,$filesize db', 'printenv -e -n -guid d719b2cb-3d3a-4596-a3bc-dad00e67656f db']) - assert(not 'Failed to set EFI variable' in ''.join(output)) - assert('db:' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output) + assert 'db:' in ''.join(output)
def test_efi_var_auth4(self, u_boot_console, efi_boot_env): """ @@ -221,22 +220,22 @@ class TestEfiAuthVar(object): 'fatload host 0:1 4000000 db.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize db', 'printenv -e -n -guid d719b2cb-3d3a-4596-a3bc-dad00e67656f db']) - assert(not 'Failed to set EFI variable' in ''.join(output)) - assert('db:' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output) + assert 'db:' in ''.join(output)
output = u_boot_console.run_command_list([ 'setenv -e -nv -bs -rt db', 'printenv -e -n -guid d719b2cb-3d3a-4596-a3bc-dad00e67656f db']) - assert('Failed to set EFI variable' in ''.join(output)) - assert('db:' in ''.join(output)) + assert 'Failed to set EFI variable' in ''.join(output) + assert 'db:' in ''.join(output)
with u_boot_console.log.section('Test Case 4b'): # Test Case 4b, update without correct signature/data output = u_boot_console.run_command_list([ 'setenv -e -nv -bs -rt -at db', 'printenv -e -n -guid d719b2cb-3d3a-4596-a3bc-dad00e67656f db']) - assert('Failed to set EFI variable' in ''.join(output)) - assert('db:' in ''.join(output)) + assert 'Failed to set EFI variable' in ''.join(output) + assert 'db:' in ''.join(output)
def test_efi_var_auth5(self, u_boot_console, efi_boot_env): """ @@ -255,15 +254,15 @@ class TestEfiAuthVar(object): 'fatload host 0:1 4000000 db.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize db', 'printenv -e -n PK']) - assert(not 'Failed to set EFI variable' in ''.join(output)) - assert('PK:' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output) + assert 'PK:' in ''.join(output)
output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 PK_null.esl', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize PK', 'printenv -e -n PK']) - assert('Failed to set EFI variable' in ''.join(output)) - assert('PK:' in ''.join(output)) + assert 'Failed to set EFI variable' in ''.join(output) + assert 'PK:' in ''.join(output)
with u_boot_console.log.section('Test Case 5b'): # Test Case 5b, Uninstall PK with correct signature @@ -271,12 +270,12 @@ class TestEfiAuthVar(object): 'fatload host 0:1 4000000 PK_null.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize PK', 'printenv -e -n PK']) - assert(not 'Failed to set EFI variable' in ''.join(output)) - assert('"PK" not defined' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output) + assert '"PK" not defined' in ''.join(output)
output = u_boot_console.run_command( 'printenv -e SecureBoot') - assert('00000000: 00' in output) + assert '00000000: 00' in output output = u_boot_console.run_command( 'printenv -e SetupMode') - assert('00000000: 01' in output) + assert '00000000: 01' in output diff --git a/test/py/tests/test_efi_secboot/test_signed.py b/test/py/tests/test_efi_secboot/test_signed.py index c100832a2375..02cfa6480f26 100644 --- a/test/py/tests/test_efi_secboot/test_signed.py +++ b/test/py/tests/test_efi_secboot/test_signed.py @@ -9,7 +9,6 @@ This test verifies image authentication for signed images. """
@pytest.mark.boardspec('sandbox') @@ -32,7 +31,7 @@ class TestEfiSignedImage(object): 'efidebug boot add 1 HELLO1 host 0:1 /helloworld.efi.signed ""', 'efidebug boot next 1', 'bootefi bootmgr']) - assert('Hello, world!' in ''.join(output)) + assert 'Hello, world!' in ''.join(output)
with u_boot_console.log.section('Test Case 1b'): # Test Case 1b, run unsigned image if no PK @@ -40,7 +39,7 @@ class TestEfiSignedImage(object): 'efidebug boot add 2 HELLO2 host 0:1 /helloworld.efi ""', 'efidebug boot next 2', 'bootefi bootmgr']) - assert('Hello, world!' in ''.join(output)) + assert 'Hello, world!' in ''.join(output)
def test_efi_signed_image_auth2(self, u_boot_console, efi_boot_env): """ @@ -57,35 +56,35 @@ class TestEfiSignedImage(object): 'setenv -e -nv -bs -rt -at -i 4000000,$filesize KEK', 'fatload host 0:1 4000000 PK.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize PK']) - assert(not 'Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot add 1 HELLO1 host 0:1 /helloworld.efi.signed ""', 'efidebug boot next 1', 'efidebug test bootmgr']) - assert(''HELLO1' failed' in ''.join(output)) - assert('efi_start_image() returned: 26' in ''.join(output)) + assert ''HELLO1' failed' in ''.join(output) + assert 'efi_start_image() returned: 26' in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot add 2 HELLO2 host 0:1 /helloworld.efi ""', 'efidebug boot next 2', 'efidebug test bootmgr']) - assert(''HELLO2' failed' in ''.join(output)) - assert('efi_start_image() returned: 26' in ''.join(output)) + assert ''HELLO2' failed' in ''.join(output) + assert 'efi_start_image() returned: 26' in ''.join(output)
with u_boot_console.log.section('Test Case 2b'): # Test Case 2b, authenticated by db output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 db.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize db']) - assert(not 'Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot next 2', 'efidebug test bootmgr']) - assert(''HELLO2' failed' in ''.join(output)) - assert('efi_start_image() returned: 26' in ''.join(output)) + assert ''HELLO2' failed' in ''.join(output) + assert 'efi_start_image() returned: 26' in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot next 1', 'bootefi bootmgr']) - assert('Hello, world!' in ''.join(output)) + assert 'Hello, world!' in ''.join(output)
def test_efi_signed_image_auth3(self, u_boot_console, efi_boot_env): """ @@ -103,25 +102,25 @@ class TestEfiSignedImage(object): 'setenv -e -nv -bs -rt -at -i 4000000,$filesize KEK', 'fatload host 0:1 4000000 PK.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize PK']) - assert(not 'Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot add 1 HELLO host 0:1 /helloworld.efi.signed ""', 'efidebug boot next 1', 'efidebug test bootmgr']) - assert(''HELLO' failed' in ''.join(output)) - assert('efi_start_image() returned: 26' in ''.join(output)) + assert ''HELLO' failed' in ''.join(output) + assert 'efi_start_image() returned: 26' in ''.join(output)
with u_boot_console.log.section('Test Case 3b'): # Test Case 3b, rejected by dbx even if db allows output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 db.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize db']) - assert(not 'Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot next 1', 'efidebug test bootmgr']) - assert(''HELLO' failed' in ''.join(output)) - assert('efi_start_image() returned: 26' in ''.join(output)) + assert ''HELLO' failed' in ''.join(output) + assert 'efi_start_image() returned: 26' in ''.join(output)
def test_efi_signed_image_auth4(self, u_boot_console, efi_boot_env): """ @@ -141,13 +140,13 @@ class TestEfiSignedImage(object): 'setenv -e -nv -bs -rt -at -i 4000000,$filesize KEK', 'fatload host 0:1 4000000 PK.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize PK']) - assert(not 'Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot add 1 HELLO host 0:1 /helloworld.efi.signed ""', 'efidebug boot next 1', 'efidebug test bootmgr']) - assert(''HELLO' failed' in ''.join(output)) - assert('efi_start_image() returned: 26' in ''.join(output)) + assert ''HELLO' failed' in ''.join(output) + assert 'efi_start_image() returned: 26' in ''.join(output)
def test_efi_signed_image_auth5(self, u_boot_console, efi_boot_env): """ @@ -167,38 +166,38 @@ class TestEfiSignedImage(object): 'setenv -e -nv -bs -rt -at -i 4000000,$filesize KEK', 'fatload host 0:1 4000000 PK.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize PK']) - assert(not 'Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot add 1 HELLO host 0:1 /helloworld.efi.signed_2sigs ""', 'efidebug boot next 1', 'efidebug test bootmgr']) - assert(''HELLO' failed' in ''.join(output)) - assert('efi_start_image() returned: 26' in ''.join(output)) + assert ''HELLO' failed' in ''.join(output) + assert 'efi_start_image() returned: 26' in ''.join(output)
with u_boot_console.log.section('Test Case 5b'): # Test Case 5b, authenticated if both signatures are verified output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 db1.auth', 'setenv -e -nv -bs -rt -at -a -i 4000000,$filesize db']) - assert(not 'Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot add 1 HELLO host 0:1 /helloworld.efi.signed_2sigs ""', 'efidebug boot next 1', 'bootefi bootmgr']) - assert('Hello, world!' in ''.join(output)) + assert 'Hello, world!' in ''.join(output)
with u_boot_console.log.section('Test Case 5c'): # Test Case 5c, rejected if any of signatures is revoked output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 dbx_hash1.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize dbx']) - assert(not 'Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot add 1 HELLO host 0:1 /helloworld.efi.signed_2sigs ""', 'efidebug boot next 1', 'efidebug test bootmgr']) - assert(''HELLO' failed' in ''.join(output)) - assert('efi_start_image() returned: 26' in ''.join(output)) + assert ''HELLO' failed' in ''.join(output) + assert 'efi_start_image() returned: 26' in ''.join(output)
def test_efi_signed_image_auth6(self, u_boot_console, efi_boot_env): """ @@ -216,24 +215,24 @@ class TestEfiSignedImage(object): 'setenv -e -nv -bs -rt -at -i 4000000,$filesize KEK', 'fatload host 0:1 4000000 PK.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize PK']) - assert(not 'Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot add 1 HELLO host 0:1 /helloworld.efi.signed ""', 'efidebug boot next 1', 'bootefi bootmgr']) - assert('Hello, world!' in ''.join(output)) + assert 'Hello, world!' in ''.join(output)
with u_boot_console.log.section('Test Case 6b'): # Test Case 6b, rejected by TEST_db certificate in dbx output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 dbx_db.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize dbx']) - assert(not 'Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot next 1', 'efidebug test bootmgr']) - assert(''HELLO' failed' in ''.join(output)) - assert('efi_start_image() returned: 26' in ''.join(output)) + assert ''HELLO' failed' in ''.join(output) + assert 'efi_start_image() returned: 26' in ''.join(output)
with u_boot_console.log.section('Test Case 6c'): # Test Case 6c, rejected by image's digest in dbx @@ -242,9 +241,9 @@ class TestEfiSignedImage(object): 'setenv -e -nv -bs -rt -at -i 4000000,$filesize db', 'fatload host 0:1 4000000 dbx_hello_signed.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize dbx']) - assert(not 'Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot next 1', 'efidebug test bootmgr']) - assert(''HELLO' failed' in ''.join(output)) - assert('efi_start_image() returned: 26' in ''.join(output)) + assert ''HELLO' failed' in ''.join(output) + assert 'efi_start_image() returned: 26' in ''.join(output) diff --git a/test/py/tests/test_efi_secboot/test_unsigned.py b/test/py/tests/test_efi_secboot/test_unsigned.py index 3748b51ee7e9..c4c3f4c2023f 100644 --- a/test/py/tests/test_efi_secboot/test_unsigned.py +++ b/test/py/tests/test_efi_secboot/test_unsigned.py @@ -9,7 +9,6 @@ This test verifies image authentication for unsigned images. """
@pytest.mark.boardspec('sandbox') @@ -33,18 +32,18 @@ class TestEfiUnsignedImage(object): 'setenv -e -nv -bs -rt -at -i 4000000,$filesize KEK', 'fatload host 0:1 4000000 PK.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize PK']) - assert(not 'Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output)
output = u_boot_console.run_command_list([ 'efidebug boot add 1 HELLO host 0:1 /helloworld.efi ""', 'efidebug boot next 1', 'bootefi bootmgr']) - assert(''HELLO' failed' in ''.join(output)) + assert ''HELLO' failed' in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot next 1', 'efidebug test bootmgr']) - assert('efi_start_image() returned: 26' in ''.join(output)) - assert(not 'Hello, world!' in ''.join(output)) + assert 'efi_start_image() returned: 26' in ''.join(output) + assert 'Hello, world!' not in ''.join(output)
def test_efi_unsigned_image_auth2(self, u_boot_console, efi_boot_env): """ @@ -62,13 +61,13 @@ class TestEfiUnsignedImage(object): 'setenv -e -nv -bs -rt -at -i 4000000,$filesize KEK', 'fatload host 0:1 4000000 PK.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize PK']) - assert(not 'Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output)
output = u_boot_console.run_command_list([ 'efidebug boot add 1 HELLO host 0:1 /helloworld.efi ""', 'efidebug boot next 1', 'bootefi bootmgr']) - assert('Hello, world!' in ''.join(output)) + assert 'Hello, world!' in ''.join(output)
def test_efi_unsigned_image_auth3(self, u_boot_console, efi_boot_env): """ @@ -86,33 +85,33 @@ class TestEfiUnsignedImage(object): 'setenv -e -nv -bs -rt -at -i 4000000,$filesize KEK', 'fatload host 0:1 4000000 PK.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize PK']) - assert(not 'Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output)
with u_boot_console.log.section('Test Case 3b'): # Test Case 3b, rejected by dbx even if db allows output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 db_hello.auth', 'setenv -e -nv -bs -rt -at -i 4000000,$filesize db']) - assert(not 'Failed to set EFI variable' in ''.join(output)) + assert 'Failed to set EFI variable' not in ''.join(output)
This patch has to be rebased:
error: patch failed: test/py/tests/test_efi_secboot/conftest.py:14 error: test/py/tests/test_efi_secboot/conftest.py: patch does not apply error: patch failed: test/py/tests/test_efi_secboot/test_authvar.py:9 error: test/py/tests/test_efi_secboot/test_authvar.py: patch does not apply error: patch failed: test/py/tests/test_efi_secboot/test_signed.py:9 error: test/py/tests/test_efi_secboot/test_signed.py: patch does not apply error: patch failed: test/py/tests/test_efi_secboot/test_unsigned.py:9 error: test/py/tests/test_efi_secboot/test_unsigned.py: patch does not apply Patch failed at 0001 test/py: efi_secboot: more fixes against pylint
Best regards
Heinrich
This patch will be included in a next version (v3) of follow-up patches.
-Takahiro Akashi
Best regards
Heinrich
% (fs_type, loop_dev, mnt_point), shell=True) # suffix # *.key: RSA private key in PEM
## PK
shell=True)
## KEK
shell=True)
## db
shell=True)
## db1
shell=True)
## db1-update
shell=True)
shell=True)
shell=True)
shell=True)
# PK
check_call(
mnt_point,
shell=True)
check_call(
check_call(
# KEK
check_call(
mnt_point,
shell=True)
check_call(
# db
check_call(
mnt_point,
shell=True)
check_call(
# db1
check_call(
mnt_point,
shell=True)
check_call(
# db1-update
check_call(
check_call(
mnt_point,
shell=True)
check_call(
check_call(
check_call(
check_call(
(mnt_point, EFITOOLS_PATH), shell=True) # Copy image check_call('cp %s %s' % (HELLO_PATH, mnt_point), shell=True)
## Sign image
## Digest image
shell=True)
shell=True)
shell=True)
check_call(
mnt_point,
shell=True)
Please, use the format() method.
See a discussion here: https://realpython.com/python-string-formatting/#4-template-strings-standard...
Best regards
Heinrich
# Digest image
check_call(
check_call(
check_call(
(mnt_point, EFITOOLS_PATH), shell=True) check_call('sudo umount %s' % loop_dev, shell=True) check_call('sudo losetup -d %s' % loop_dev, shell=True)
'setenv -e -nv -bs -rt -at -i 4000000,$filesize PK']) assert(not 'Failed to set EFI variable' in ''.join(output)) output = u_boot_console.run_command_list([
'setenv -e -nv -bs -rt -at -i 4000000,$filesize db']) assert(not 'Failed to set EFI variable' in ''.join(output)) output = u_boot_console.run_command_list([
## PK
shell=True)
## KEK
shell=True)
## db
shell=True)
## db1
shell=True)
## db1-update
shell=True)
shell=True)
shell=True)
shell=True)
# PK
check_call(
mnt_point,
shell=True)
check_call(
check_call(
# KEK
check_call(
mnt_point,
shell=True)
check_call(
# db
check_call(
mnt_point,
shell=True)
check_call(
# db1
check_call(
mnt_point,
shell=True)
check_call(
# db1-update
check_call(
check_call(
mnt_point,
shell=True)
check_call(
check_call(
check_call(
check_call(
## Sign image
## Digest image
shell=True)
shell=True)
shell=True)
check_call(
mnt_point,
shell=True)
This patch will be included in a next version (v3) of follow-up patch.
This comment is not related to this patch.
In addition, even after reading the link (and discussions in python ML referred to in this article), I don't see any benefit of using .format() in this context. As test_efi_secboot has already been merged, I won't make changes.
FYI, I'd prefer to use "f-string" which was introduced in Python3.6 if readability is a problem.
-Takahiro Akashi
Best regards
Heinrich
# Digest image
check_call(
check_call(
check_call(
AKASHI Takahiro
