[U-Boot-Users] debug u-boot with BDI2000
After solving early problem with target reset (cable fault) I'm ready to do some real work! I order to debug u-boot startup and so on, do I have to enable/provide some additional options when compiling u-boot for my target?
I've read the Debugging section in dulg manual, but it doesn't mention anything like that - Just to make sure...
regards, hk
regards, hk
Just the standard ones for debugging: -g for symbolic support.
You may want to use -O0 to turn off optimization. The linux kernel won't link when compiled with -O0 because the expected inlining doesn't happen (symptom: linking gives missing symbols) -- I don't recall if u-boot has that limitation too.
gvb
You also have to be careful of processor initialization code that initializes debug control registers. Proper processor set up requires you do this, but of course the BDI2000 is also trying to use these registers to assist with the debug process. You may have to disable this debug register initialization in the code, depending upon the processor, or find some other way of working around this.
-- Dan
Hmm, I'm using intel pxa255 A0 processor here. BDI2000 came with some setup files for this processor. I'll check out that stuff, thanks for the tip.
regards, hk
This is default for U-Boot, so no change needed.
We never do this. You get used to see what the optimizer is doing - and actually this my be very important to know. We've been hunting a couple of problems (like missing "volatile" atributes) when switching from older versions of GCC to GCC-3.3 - turning off -O0 ould have made this impossible.
Dan Malek
Hinko Kocevar
Jerry Van Baren
