[U-Boot] [PATCH 0/6] Various gdsys ppc4xx boards revised
Dirk Eibach (6): powerpc/ppc4xx: Adjust environment size on neo powerpc/ppc4xx: Make gdsys 405ep boards reset more generic powerpc/ppc4xx: Adapt gdsys 405ep boards to platform changes powerpc/ppc4xx: Support gdsys dlvision-10g hardware 1.20 powerpc/ppc4xx: Update gdsys board configurations powerpc/ppc4xx: Fix typo in gdsys_fpga.h
board/gdsys/405ep/405ep.c | 42 +++++------ board/gdsys/405ep/405ep.h | 10 +++ board/gdsys/405ep/Makefile | 1 + board/gdsys/405ep/dlvision-10g.c | 76 +++++++++++++++--- board/gdsys/405ep/io.c | 75 +++++++++++++++--- board/gdsys/405ep/iocon.c | 68 +++++++++++++---- board/gdsys/405ep/neo.c | 161 ++++++++++++++++++++++++++++++++++++++ board/gdsys/neo/Makefile | 45 ----------- board/gdsys/neo/neo.c | 102 ------------------------ boards.cfg | 2 +- include/configs/dlvision-10g.h | 9 ++- include/configs/gdppc440etx.h | 4 + include/configs/intip.h | 4 +- include/configs/io.h | 13 +++- include/configs/io64.h | 2 +- include/configs/iocon.h | 9 ++- include/configs/neo.h | 96 +++++++++++++---------- include/gdsys_fpga.h | 13 +++- 18 files changed, 468 insertions(+), 264 deletions(-) create mode 100644 board/gdsys/405ep/405ep.h create mode 100644 board/gdsys/405ep/neo.c delete mode 100644 board/gdsys/neo/Makefile delete mode 100644 board/gdsys/neo/neo.c
Environment size on neo has to be 0x20000 for compatibilty reasons.
Signed-off-by: Dirk Eibach eibach@gdsys.de Cc: Stefan Roese sr@denx.de --- Changes in v2: - add Cc - split up original patch series
include/configs/neo.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/configs/neo.h b/include/configs/neo.h index 8de5aaf..6559353 100644 --- a/include/configs/neo.h +++ b/include/configs/neo.h @@ -150,7 +150,7 @@ #ifdef CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE 0x20000 /* size of one complete sector */ #define CONFIG_ENV_ADDR ((-CONFIG_SYS_MONITOR_LEN)-CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 /* Total Size of Environment Sector */ +#define CONFIG_ENV_SIZE 0x20000 /* Total Size of Environment Sector */
/* Address and size of Redundant Environment Sector */ #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR-CONFIG_ENV_SECT_SIZE)
Patch series (1...6) applied to u-boot-ppc4xx/master.
Thanks, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
In order to add boards that have different hardware for fpga reset, any 405ep gdsys board now provides these functions:
void gd405ep_init(void); void gd405ep_set_fpga_reset(unsigned state); void gd405ep_setup_hw(void); int gd405ep_get_fpga_done(unsigned fpga);
board/gdsys/405ep/405ep.c | 42 +++++------ board/gdsys/405ep/405ep.h | 10 +++ board/gdsys/405ep/Makefile | 1 + board/gdsys/405ep/dlvision-10g.c | 36 ++++++++- board/gdsys/405ep/io.c | 34 ++++++++ board/gdsys/405ep/iocon.c | 34 ++++++++ board/gdsys/405ep/neo.c | 161 ++++++++++++++++++++++++++++++++++++++ board/gdsys/neo/Makefile | 45 ----------- board/gdsys/neo/neo.c | 102 ------------------------ boards.cfg | 2 +- include/configs/dlvision-10g.h | 3 +- include/configs/io.h | 5 +- include/configs/iocon.h | 3 +- include/configs/neo.h | 94 +++++++++++++---------- include/gdsys_fpga.h | 11 +++ 15 files changed, 366 insertions(+), 217 deletions(-) create mode 100644 board/gdsys/405ep/405ep.h create mode 100644 board/gdsys/405ep/neo.c delete mode 100644 board/gdsys/neo/Makefile delete mode 100644 board/gdsys/neo/neo.c
diff --git a/board/gdsys/405ep/405ep.c b/board/gdsys/405ep/405ep.c index 8b80533..bea671e 100644 --- a/board/gdsys/405ep/405ep.c +++ b/board/gdsys/405ep/405ep.c @@ -28,12 +28,9 @@ #include <asm/ppc4xx-gpio.h> #include <asm/global_data.h>
+#include "405ep.h" #include <gdsys_fpga.h>
-#define LATCH0_BASE (CONFIG_SYS_LATCH_BASE) -#define LATCH1_BASE (CONFIG_SYS_LATCH_BASE + 0x100) -#define LATCH2_BASE (CONFIG_SYS_LATCH_BASE + 0x200) - #define REFLECTION_TESTPATTERN 0xdede #define REFLECTION_TESTPATTERN_INV (~REFLECTION_TESTPATTERN & 0xffff)
@@ -55,7 +52,6 @@ void print_fpga_state(unsigned dev) int board_early_init_f(void) { unsigned k; - unsigned ctr;
for (k = 0; k < CONFIG_SYS_FPGA_COUNT; ++k) gd->fpga_state[k] = 0; @@ -73,26 +69,29 @@ int board_early_init_f(void) * -> ca. 15 us */ mtebc(EBC0_CFG, 0xa8400000); /* ebc always driven */ + return 0; +}
- /* - * setup io-latches for reset - */ - out_le16((void *)LATCH0_BASE, CONFIG_SYS_LATCH0_RESET); - out_le16((void *)LATCH1_BASE, CONFIG_SYS_LATCH1_RESET); +int board_early_init_r(void) +{ + unsigned k; + unsigned ctr;
- /* - * set "startup-finished"-gpios - */ - gpio_write_bit(21, 0); - gpio_write_bit(22, 1); + for (k = 0; k < CONFIG_SYS_FPGA_COUNT; ++k) + gd->fpga_state[k] = 0;
/* - * wait for fpga-done + * reset FPGA */ + gd405ep_init(); + + gd405ep_set_fpga_reset(1); + + gd405ep_setup_hw(); + for (k = 0; k < CONFIG_SYS_FPGA_COUNT; ++k) { ctr = 0; - while (!(in_le16((void *)LATCH2_BASE) - & CONFIG_SYS_FPGA_DONE(k))) { + while (!gd405ep_get_fpga_done(k)) { udelay(100000); if (ctr++ > 5) { gd->fpga_state[k] |= FPGA_STATE_DONE_FAILED; @@ -101,12 +100,9 @@ int board_early_init_f(void) } }
- /* - * setup io-latches for boot (stop reset) - */ udelay(10); - out_le16((void *)LATCH0_BASE, CONFIG_SYS_LATCH0_BOOT); - out_le16((void *)LATCH1_BASE, CONFIG_SYS_LATCH1_BOOT); + + gd405ep_set_fpga_reset(0);
for (k = 0; k < CONFIG_SYS_FPGA_COUNT; ++k) { ihs_fpga_t *fpga = (ihs_fpga_t *) CONFIG_SYS_FPGA_BASE(k); diff --git a/board/gdsys/405ep/405ep.h b/board/gdsys/405ep/405ep.h new file mode 100644 index 0000000..5647dbc --- /dev/null +++ b/board/gdsys/405ep/405ep.h @@ -0,0 +1,10 @@ +#ifndef __405EP_H_ +#define __405EP_H_ + +/* functions to be provided by board implementation */ +void gd405ep_init(void); +void gd405ep_set_fpga_reset(unsigned state); +void gd405ep_setup_hw(void); +int gd405ep_get_fpga_done(unsigned fpga); + +#endif /* __405EP_H_ */ diff --git a/board/gdsys/405ep/Makefile b/board/gdsys/405ep/Makefile index feb5cec..38e5ea4 100644 --- a/board/gdsys/405ep/Makefile +++ b/board/gdsys/405ep/Makefile @@ -25,6 +25,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).o
+COBJS-$(CONFIG_NEO) += neo.o COBJS-$(CONFIG_IO) += io.o COBJS-$(CONFIG_IOCON) += iocon.o COBJS-$(CONFIG_DLVISION_10G) += dlvision-10g.o diff --git a/board/gdsys/405ep/dlvision-10g.c b/board/gdsys/405ep/dlvision-10g.c index f55afbd..adaffb2 100644 --- a/board/gdsys/405ep/dlvision-10g.c +++ b/board/gdsys/405ep/dlvision-10g.c @@ -27,15 +27,18 @@ #include <asm/io.h> #include <asm/ppc4xx-gpio.h>
#include "../common/osd.h"
+#define LATCH0_BASE (CONFIG_SYS_LATCH_BASE) +#define LATCH1_BASE (CONFIG_SYS_LATCH_BASE + 0x100) #define LATCH2_BASE (CONFIG_SYS_LATCH_BASE + 0x200) -#define LATCH2_MC2_PRESENT_N 0x0080 - #define LATCH3_BASE (CONFIG_SYS_LATCH_BASE + 0x300)
+#define LATCH2_MC2_PRESENT_N 0x0080 + enum { UNITTYPE_VIDEO_USER = 0, UNITTYPE_MAIN_USER = 1, @@ -261,3 +264,32 @@ int last_stage_init(void)
return 0; } + +void gd405ep_init(void) +{ +} + +void gd405ep_set_fpga_reset(unsigned state) +{ + if (state) { + out_le16((void *)LATCH0_BASE, CONFIG_SYS_LATCH0_RESET); + out_le16((void *)LATCH1_BASE, CONFIG_SYS_LATCH1_RESET); + } else { + out_le16((void *)LATCH0_BASE, CONFIG_SYS_LATCH0_BOOT); + out_le16((void *)LATCH1_BASE, CONFIG_SYS_LATCH1_BOOT); + } +} + +void gd405ep_setup_hw(void) +{ + /* + * set "startup-finished"-gpios + */ + gpio_write_bit(21, 0); + gpio_write_bit(22, 1); +} + +int gd405ep_get_fpga_done(unsigned fpga) +{ + return in_le16((void *)LATCH2_BASE) & CONFIG_SYS_FPGA_DONE(fpga); +} diff --git a/board/gdsys/405ep/io.c b/board/gdsys/405ep/io.c index db1ea7f..ac4cefd 100644 --- a/board/gdsys/405ep/io.c +++ b/board/gdsys/405ep/io.c @@ -29,8 +29,13 @@
#include <miiphy.h>
+#define LATCH0_BASE (CONFIG_SYS_LATCH_BASE) +#define LATCH1_BASE (CONFIG_SYS_LATCH_BASE + 0x100) +#define LATCH2_BASE (CONFIG_SYS_LATCH_BASE + 0x200) + #define PHYREG_CONTROL 0 #define PHYREG_PAGE_ADDRESS 22 #define PHYREG_PG0_COPPER_SPECIFIC_CONTROL_1 16 @@ -175,3 +180,32 @@ int last_stage_init(void)
return 0; } + +void gd405ep_init(void) +{ +} + +void gd405ep_set_fpga_reset(unsigned state) +{ + if (state) { + out_le16((void *)LATCH0_BASE, CONFIG_SYS_LATCH0_RESET); + out_le16((void *)LATCH1_BASE, CONFIG_SYS_LATCH1_RESET); + } else { + out_le16((void *)LATCH0_BASE, CONFIG_SYS_LATCH0_BOOT); + out_le16((void *)LATCH1_BASE, CONFIG_SYS_LATCH1_BOOT); + } +} + +void gd405ep_setup_hw(void) +{ + /* + * set "startup-finished"-gpios + */ + gpio_write_bit(21, 0); + gpio_write_bit(22, 1); +} + +int gd405ep_get_fpga_done(unsigned fpga) +{ + return in_le16((void *)LATCH2_BASE) & CONFIG_SYS_FPGA_DONE(fpga); +} diff --git a/board/gdsys/405ep/iocon.c b/board/gdsys/405ep/iocon.c index ce53340..ed27791 100644 --- a/board/gdsys/405ep/iocon.c +++ b/board/gdsys/405ep/iocon.c @@ -27,10 +27,15 @@ #include <asm/io.h> #include <asm/ppc4xx-gpio.h>
+#define LATCH0_BASE (CONFIG_SYS_LATCH_BASE) +#define LATCH1_BASE (CONFIG_SYS_LATCH_BASE + 0x100) +#define LATCH2_BASE (CONFIG_SYS_LATCH_BASE + 0x200) + enum { UNITTYPE_MAIN_SERVER = 0, UNITTYPE_MAIN_USER = 1, @@ -231,3 +236,32 @@ int fpga_gpio_get(int pin) { return in_le16((void *)(CONFIG_SYS_FPGA0_BASE + 0x14)) & pin; } + +void gd405ep_init(void) +{ +} + +void gd405ep_set_fpga_reset(unsigned state) +{ + if (state) { + out_le16((void *)LATCH0_BASE, CONFIG_SYS_LATCH0_RESET); + out_le16((void *)LATCH1_BASE, CONFIG_SYS_LATCH1_RESET); + } else { + out_le16((void *)LATCH0_BASE, CONFIG_SYS_LATCH0_BOOT); + out_le16((void *)LATCH1_BASE, CONFIG_SYS_LATCH1_BOOT); + } +} + +void gd405ep_setup_hw(void) +{ + /* + * set "startup-finished"-gpios + */ + gpio_write_bit(21, 0); + gpio_write_bit(22, 1); +} + +int gd405ep_get_fpga_done(unsigned fpga) +{ + return in_le16((void *)LATCH2_BASE) & CONFIG_SYS_FPGA_DONE(fpga); +} diff --git a/board/gdsys/405ep/neo.c b/board/gdsys/405ep/neo.c new file mode 100644 index 0000000..f38edd2 --- /dev/null +++ b/board/gdsys/405ep/neo.c @@ -0,0 +1,161 @@ +/* + * (C) Copyright 2011 + * Dirk Eibach, Guntermann & Drunck GmbH, eibach@gdsys.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <asm/processor.h> +#include <asm/io.h> +#include <asm/ppc4xx-gpio.h> +#include <dtt.h> + +#include "405ep.h" +#include <gdsys_fpga.h> + +#define LATCH0_BASE (CONFIG_SYS_LATCH_BASE) +#define LATCH1_BASE (CONFIG_SYS_LATCH_BASE + 0x100) +#define LATCH2_BASE (CONFIG_SYS_LATCH_BASE + 0x200) + +enum { + UNITTYPE_CCX16 = 1, + UNITTYPE_CCIP216 = 2, +}; + +enum { + HWVER_300 = 3, +}; + +int misc_init_r(void) +{ + /* startup fans */ + dtt_init(); + + return 0; +} + +int checkboard(void) +{ + char *s = getenv("serial#"); + + puts("Board: CATCenter Neo"); + + if (s != NULL) { + puts(", serial# "); + puts(s); + } + + puts("\n"); + + return 0; +} + +static void print_fpga_info(void) +{ + ihs_fpga_t *fpga = (ihs_fpga_t *) CONFIG_SYS_FPGA_BASE(0); + u16 versions = in_le16(&fpga->versions); + u16 fpga_version = in_le16(&fpga->fpga_version); + u16 fpga_features = in_le16(&fpga->fpga_features); + int fpga_state = get_fpga_state(0); + unsigned unit_type; + unsigned hardware_version; + unsigned feature_channels; + + puts("FPGA: "); + if (fpga_state & FPGA_STATE_DONE_FAILED) { + printf(" done timed out\n"); + return; + } + + if (fpga_state & FPGA_STATE_REFLECTION_FAILED) { + printf(" refelectione test failed\n"); + return; + } + + unit_type = (versions & 0xf000) >> 12; + hardware_version = versions & 0x000f; + feature_channels = fpga_features & 0x007f; + + switch (unit_type) { + case UNITTYPE_CCX16: + printf("CCX-Switch"); + break; + + default: + printf("UnitType %d(not supported)", unit_type); + break; + } + + switch (hardware_version) { + case HWVER_300: + printf(" HW-Ver 3.00-3.12\n"); + break; + + default: + printf(" HW-Ver %d(not supported)\n", + hardware_version); + break; + } + + printf(" FPGA V %d.%02d, features:", + fpga_version / 100, fpga_version % 100); + + printf(" %d channel(s)\n", feature_channels); +} + +int last_stage_init(void) +{ + print_fpga_info(); + + return 0; +} + +void gd405ep_init(void) +{ +} + +void gd405ep_set_fpga_reset(unsigned state) +{ + if (state) { + out_le16((void *)LATCH0_BASE, CONFIG_SYS_LATCH0_RESET); + out_le16((void *)LATCH1_BASE, CONFIG_SYS_LATCH1_RESET); + } else { + out_le16((void *)LATCH0_BASE, CONFIG_SYS_LATCH0_BOOT); + out_le16((void *)LATCH1_BASE, CONFIG_SYS_LATCH1_BOOT); + } +} + +void gd405ep_setup_hw(void) +{ + /* + * set "startup-finished"-gpios + */ + gpio_write_bit(21, 0); + gpio_write_bit(22, 1); +} + +int gd405ep_get_fpga_done(unsigned fpga) +{ + /* + * Neo hardware has no FPGA-DONE GPIO + */ + return 1; +} diff --git a/board/gdsys/neo/Makefile b/board/gdsys/neo/Makefile deleted file mode 100644 index dc5b5b8..0000000 --- a/board/gdsys/neo/Makefile +++ /dev/null @@ -1,45 +0,0 @@ -# -# (C) Copyright 2007 -# Stefan Roese, DENX Software Engineering, sr@denx.de. -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o -SOBJS = - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/gdsys/neo/neo.c b/board/gdsys/neo/neo.c deleted file mode 100644 index d21d599..0000000 --- a/board/gdsys/neo/neo.c +++ /dev/null @@ -1,102 +0,0 @@ -/* - * (C) Copyright 2007-2008 - * Dirk Eibach, Guntermann & Drunck GmbH, eibach@gdsys.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <command.h> -#include <asm/processor.h> -#include <asm/io.h> - -#define HWTYPE_CCX16 1 -#define HWREV_300 3 - -int board_early_init_f(void) -{ - mtdcr(UIC0SR, 0xFFFFFFFF); /* clear all ints */ - mtdcr(UIC0ER, 0x00000000); /* disable all ints */ - mtdcr(UIC0CR, 0x00000000); /* set all to be non-critical */ - mtdcr(UIC0PR, 0xFFFFFF80); /* set int polarities */ - mtdcr(UIC0TR, 0x10000000); /* set int trigger levels */ - mtdcr(UIC0VCR, 0x00000001); /* set vect base=0,INT0 highest prio */ - mtdcr(UIC0SR, 0xFFFFFFFF); /* clear all ints */ - - /* - * EBC Configuration Register: set ready timeout to 512 ebc-clks - * -> ca. 15 us - */ - mtebc(EBC0_CFG, 0xa8400000); /* ebc always driven */ - - return 0; -} - -/* - * Check Board Identity: - */ -int checkboard(void) -{ - char buf[64]; - int i = getenv_f("serial#", buf, sizeof(buf)); - u16 val = in_le16((void *)CONFIG_FPGA_BASE + 2); - u8 unit_type; - u8 hardware_cpu_ports; - u8 hardware_con_ports; - u8 hardware_version; - - printf("Board: CATCenter Neo"); - - if (i > 0) { - puts(", serial# "); - puts(buf); - } - puts("\n "); - - unit_type = (val & 0xf000) >> 12; - hardware_cpu_ports = ((val & 0x0f00) >> 8) * 8; - hardware_con_ports = ((val & 0x00f0) >> 4) * 2; - hardware_version = val & 0x000f; - - switch (unit_type) { - case HWTYPE_CCX16: - printf("CCX16-FPGA (80 UARTs)"); - break; - - default: - printf("UnitType %d, unsupported", unit_type); - break; - } - - printf(", %d cpu ports, %d console ports,", - hardware_cpu_ports, hardware_con_ports); - - switch (hardware_version) { - case HWREV_300: - printf(" HW-Ver 3.00\n"); - break; - - default: - printf(" HW-Ver %d, unsupported\n", - hardware_version); - break; - } - - return 0; -} diff --git a/boards.cfg b/boards.cfg index 3cf75c3..24c5879 100644 --- a/boards.cfg +++ b/boards.cfg @@ -982,7 +982,7 @@ intip powerpc ppc4xx intip gdsys io powerpc ppc4xx 405ep gdsys io64 powerpc ppc4xx 405ex gdsys iocon powerpc ppc4xx 405ep gdsys -neo powerpc ppc4xx - gdsys +neo powerpc ppc4xx 405ep gdsys icon powerpc ppc4xx - mosaixtech MIP405 powerpc ppc4xx mip405 mpl MIP405T powerpc ppc4xx mip405 mpl - MIP405:MIP405T diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index 1468197..cd64e3a 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -37,7 +37,8 @@ #define CONFIG_IDENT_STRING " dlvision-10g 0.02" #include "amcc-common.h"
-#define CONFIG_BOARD_EARLY_INIT_F /* call board_early_init_f */ +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_LAST_STAGE_INIT
#define CONFIG_SYS_CLK_FREQ 33333333 /* external frequency to pll */ diff --git a/include/configs/io.h b/include/configs/io.h index 9d2a87d..fe07ca5 100644 --- a/include/configs/io.h +++ b/include/configs/io.h @@ -37,8 +37,9 @@ #define CONFIG_IDENT_STRING " io 0.04" #include "amcc-common.h"
-#define CONFIG_BOARD_EARLY_INIT_F /* call board_early_init_f */ -#define CONFIG_LAST_STAGE_INIT /* call last_stage_init */ +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_EARLY_INIT_R +#define CONFIG_LAST_STAGE_INIT
diff --git a/include/configs/iocon.h b/include/configs/iocon.h index 9fcc643..bbf79e7 100644 --- a/include/configs/iocon.h +++ b/include/configs/iocon.h @@ -37,7 +37,8 @@ #define CONFIG_IDENT_STRING " iocon 0.03" #include "amcc-common.h"
#define CONFIG_SYS_CLK_FREQ 33333333 /* external frequency to pll */ diff --git a/include/configs/neo.h b/include/configs/neo.h index 6559353..38b5bec 100644 --- a/include/configs/neo.h +++ b/include/configs/neo.h @@ -35,9 +35,13 @@ * Include common defines/options for all AMCC eval boards */ #define CONFIG_HOSTNAME neo +#define CONFIG_IDENT_STRING " neo 0.01" #include "amcc-common.h"
-#define CONFIG_BOARD_EARLY_INIT_F /* call board_early_init_f */ +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_EARLY_INIT_R +#define CONFIG_MISC_INIT_R +#define CONFIG_LAST_STAGE_INIT
@@ -149,53 +153,53 @@
#ifdef CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE 0x20000 /* size of one complete sector */ -#define CONFIG_ENV_ADDR ((-CONFIG_SYS_MONITOR_LEN)-CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_ADDR 0xFFF00000 #define CONFIG_ENV_SIZE 0x20000 /* Total Size of Environment Sector */
/* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR-CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_ADDR_REDUND 0xFFF20000 #define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) #endif
/* * PPC405 GPIO Configuration */ -#define CONFIG_SYS_4xx_GPIO_TABLE { /* GPIO Alternate1 */ \ -{ \ -/* GPIO Core 0 */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO0 PerBLast */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO1 TS1E */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO2 TS2E */ \ -{ GPIO_BASE, GPIO_IN, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO3 TS1O */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO4 TS2O */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO5 TS3 */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO6 TS4 */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO7 TS5 */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO8 TS6 */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO9 TrcClk */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO10 PerCS1 */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO11 PerCS2 */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO12 PerCS3 */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO13 PerCS4 */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO14 PerAddr03 */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO15 PerAddr04 */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO16 PerAddr05 */ \ -{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO17 IRQ0 */ \ -{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO18 IRQ1 */ \ -{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO19 IRQ2 */ \ -{ GPIO_BASE, GPIO_IN, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO20 IRQ3 */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO21 IRQ4 */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO22 IRQ5 */ \ -{ GPIO_BASE, GPIO_IN, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO23 IRQ6 */ \ -{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO24 UART0_DCD */ \ -{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO25 UART0_DSR */ \ -{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO26 UART0_RI */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO27 UART0_DTR */ \ -{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO28 UART1_Rx */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO29 UART1_Tx */ \ -{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO30 RejectPkt0 */ \ -{ GPIO_BASE, GPIO_IN, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO31 RejectPkt1 */ \ -} \ +#define CONFIG_SYS_4xx_GPIO_TABLE { \ +{ \ +/* GPIO Core 0 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO0 PerBLast */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO1 TS1E */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO2 TS2E */ \ +{ GPIO_BASE, GPIO_IN, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO3 TS1O */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO4 TS2O */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_1 }, /* GPIO5 TS3 */ \ +{ GPIO_BASE, GPIO_IN, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO6 TS4 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO7 TS5 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO8 TS6 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO9 TrcClk */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO10 PerCS1 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO11 PerCS2 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO12 PerCS3 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO13 PerCS4 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO14 PerAddr03 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO15 PerAddr04 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO16 PerAddr05 */ \ +{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO17 IRQ0 */ \ +{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO18 IRQ1 */ \ +{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO19 IRQ2 */ \ +{ GPIO_BASE, GPIO_IN, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO20 IRQ3 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO21 IRQ4 */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO22 IRQ5 */ \ +{ GPIO_BASE, GPIO_IN, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO23 IRQ6 */ \ +{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO24 UART0_DCD */ \ +{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO25 UART0_DSR */ \ +{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO26 UART0_RI */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO27 UART0_DTR */ \ +{ GPIO_BASE, GPIO_IN, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO28 UART1_Rx */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO29 UART1_Tx */ \ +{ GPIO_BASE, GPIO_OUT, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO30 RejectPkt0 */ \ +{ GPIO_BASE, GPIO_IN, GPIO_SEL, GPIO_OUT_NO_CHG }, /* GPIO31 RejectPkt1 */ \ +} \ }
/* @@ -226,12 +230,22 @@ #define CONFIG_SYS_EBC_PB1CR 0xFB85A000 /* BAS=0xFF8,BS=4MB,BU=R/W,BW=8bit */
/* Memory Bank 2 (FPGA) initialization */ -#define CONFIG_FPGA_BASE 0x7f100000 +#define CONFIG_SYS_FPGA0_BASE 0x7f100000 #define CONFIG_SYS_EBC_PB2AP 0x92015480 #define CONFIG_SYS_EBC_PB2CR 0x7f11a000 /* BAS=0x7f1,BS=1MB,BU=R/W,BW=16bit */
+#define CONFIG_SYS_FPGA_BASE(k) CONFIG_SYS_FPGA0_BASE + +#define CONFIG_SYS_FPGA_COUNT 1 + /* Memory Bank 3 (Latches) initialization */ +#define CONFIG_SYS_LATCH_BASE 0x7f200000 #define CONFIG_SYS_EBC_PB3AP 0x92015480 #define CONFIG_SYS_EBC_PB3CR 0x7f21a000 /* BAS=0x7f2,BS=1MB,BU=R/W,BW=16bit */
+#define CONFIG_SYS_LATCH0_RESET 0xffff +#define CONFIG_SYS_LATCH0_BOOT 0xffff +#define CONFIG_SYS_LATCH1_RESET 0xffbf +#define CONFIG_SYS_LATCH1_BOOT 0xffff + #endif /* __CONFIG_H */ diff --git a/include/gdsys_fpga.h b/include/gdsys_fpga.h index 949864c..555fbe2 100644 --- a/include/gdsys_fpga.h +++ b/include/gdsys_fpga.h @@ -58,6 +58,17 @@ typedef struct ihs_osd { u16 y_pos; } ihs_osd_t;
+#ifdef CONFIG_NEO +typedef struct ihs_fpga { + u16 reflection_low; /* 0x0000 */ + u16 versions; /* 0x0002 */ + u16 fpga_features; /* 0x0004 */ + u16 fpga_version; /* 0x0006 */ + u16 reserved_0[8187]; /* 0x0008 */ + u16 reflection_high; /* 0x3ffe */ +} ihs_fpga_t; +#endif + #ifdef CONFIG_IO typedef struct ihs_fpga { u16 reflection_low; /* 0x0000 */
HI Dirk,
One comment below:
<snip>
- u16 reflection_low; /* 0x0000 */
- u16 versions; /* 0x0002 */
- u16 fpga_features; /* 0x0004 */
- u16 fpga_version; /* 0x0006 */
- u16 reserved_0[8187]; /* 0x0008 */
- u16 reflection_high; /* 0x3ffe */
checkpatch complains about typedef's. Please don't add more of them. I know that you already have some in your files. It would be great if you could clean this up with an follow-up patch, to remove all your local typedef's.
Thanks, Stefan
Print fpga info at last_stage_init on gdsys 405ep boards. Use dtt_init() to startup fans.
board/gdsys/405ep/dlvision-10g.c | 28 ++++++++++++++++--------- board/gdsys/405ep/io.c | 41 +++++++++++++++++++++++++------------ board/gdsys/405ep/iocon.c | 34 ++++++++++++++++++------------- include/configs/dlvision-10g.h | 2 + include/configs/io.h | 2 + 5 files changed, 70 insertions(+), 37 deletions(-)
diff --git a/board/gdsys/405ep/dlvision-10g.c b/board/gdsys/405ep/dlvision-10g.c index adaffb2..648c2ee 100644 --- a/board/gdsys/405ep/dlvision-10g.c +++ b/board/gdsys/405ep/dlvision-10g.c @@ -26,6 +26,7 @@ #include <asm/processor.h> #include <asm/io.h> #include <asm/ppc4xx-gpio.h> +#include <dtt.h>
#include "405ep.h" #include <gdsys_fpga.h> @@ -68,6 +69,14 @@ enum { RAM_DDR2_64 = 2, };
+int misc_init_r(void) +{ + /* startup fans */ + dtt_init(); + + return 0; +} + static unsigned int get_hwver(void) { u16 latch3 = in_le16((void *)LATCH3_BASE); @@ -226,24 +235,19 @@ static void print_fpga_info(unsigned dev) */ int checkboard(void) { - char buf[64]; - int i = getenv_f("serial#", buf, sizeof(buf)); + char *s = getenv("serial#");
- printf("Board: "); + puts("Board: ");
- printf("DLVision 10G"); + puts("DLVision 10G");
- if (i > 0) { + if (s != NULL) { puts(", serial# "); - puts(buf); + puts(s); }
puts("\n");
- print_fpga_info(0); - if (get_mc2_present()) - print_fpga_info(1); - return 0; }
@@ -252,6 +256,10 @@ int last_stage_init(void) ihs_fpga_t *fpga = (ihs_fpga_t *) CONFIG_SYS_FPGA_BASE(0); u16 versions = in_le16(&fpga->versions);
+ print_fpga_info(0); + if (get_mc2_present()) + print_fpga_info(1); + if (((versions >> 4) & 0x000f) != UNITTYPE_MAIN_USER) return 0;
diff --git a/board/gdsys/405ep/io.c b/board/gdsys/405ep/io.c index ac4cefd..85b61f1 100644 --- a/board/gdsys/405ep/io.c +++ b/board/gdsys/405ep/io.c @@ -27,6 +27,7 @@ #include <asm/io.h> #include <asm/ppc4xx-gpio.h>
+#include <dtt.h> #include <miiphy.h>
#include "405ep.h" @@ -52,6 +53,14 @@ enum { HWVER_122 = 3, };
+int misc_init_r(void) +{ + /* startup fans */ + dtt_init(); + + return 0; +} + int configure_gbit_phy(unsigned char addr) { unsigned short value; @@ -92,8 +101,22 @@ err_out: */ int checkboard(void) { - char buf[64]; - int i = getenv_f("serial#", buf, sizeof(buf)); + char *s = getenv("serial#"); + + puts("Board: CATCenter Io"); + + if (s != NULL) { + puts(", serial# "); + puts(s); + } + + puts("\n"); + + return 0; +} + +static void print_fpga_info(void) +{ ihs_fpga_t *fpga = (ihs_fpga_t *) CONFIG_SYS_FPGA_BASE(0); u16 versions = in_le16(&fpga->versions); u16 fpga_version = in_le16(&fpga->fpga_version); @@ -108,15 +131,7 @@ int checkboard(void) feature_channels = fpga_features & 0x007f; feature_expansion = fpga_features & (1<<15);
- printf("Board: "); - - printf("CATCenter Io"); - - if (i > 0) { - puts(", serial# "); - puts(buf); - } - puts("\n "); + puts("FPGA: ");
switch (unit_type) { case UNITTYPE_CCD_SWITCH: @@ -157,8 +172,6 @@ int checkboard(void) printf(" %d channel(s)", feature_channels);
printf(", expansion %ssupported\n", feature_expansion ? "" : "un"); - - return 0; }
/* @@ -169,6 +182,8 @@ int last_stage_init(void) ihs_fpga_t *fpga = (ihs_fpga_t *) CONFIG_SYS_FPGA_BASE(0); unsigned int k;
+ print_fpga_info(); + miiphy_register(CONFIG_SYS_GBIT_MII_BUSNAME, bb_miiphy_read, bb_miiphy_write);
diff --git a/board/gdsys/405ep/iocon.c b/board/gdsys/405ep/iocon.c index ed27791..0ffdb38 100644 --- a/board/gdsys/405ep/iocon.c +++ b/board/gdsys/405ep/iocon.c @@ -74,8 +74,24 @@ enum { */ int checkboard(void) { - char buf[64]; - int i = getenv_f("serial#", buf, sizeof(buf)); + char *s = getenv("serial#"); + + puts("Board: "); + + puts("IoCon"); + + if (s != NULL) { + puts(", serial# "); + puts(s); + } + + puts("\n"); + + return 0; +} + +static void print_fpga_info(void) +{ ihs_fpga_t *fpga = (ihs_fpga_t *) CONFIG_SYS_FPGA_BASE(0); u16 versions = in_le16(&fpga->versions); u16 fpga_version = in_le16(&fpga->fpga_version); @@ -100,16 +116,6 @@ int checkboard(void) feature_carriers = (fpga_features & 0x000c) >> 2; feature_video_channels = fpga_features & 0x0003;
- printf("Board: "); - - printf("IoCon"); - - if (i > 0) { - puts(", serial# "); - puts(buf); - } - puts("\n "); - switch (unit_type) { case UNITTYPE_MAIN_USER: printf("Mainchannel"); @@ -210,12 +216,12 @@ int checkboard(void) printf(", %d carrier(s)", feature_carriers);
printf(", %d video channel(s)\n", feature_video_channels); - - return 0; }
int last_stage_init(void) { + print_fpga_info(); + return osd_probe(0); }
diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index cd64e3a..47f1061 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -39,6 +39,7 @@
#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_EARLY_INIT_R +#define CONFIG_MISC_INIT_R #define CONFIG_LAST_STAGE_INIT
#define CONFIG_SYS_CLK_FREQ 33333333 /* external frequency to pll */ @@ -81,6 +82,7 @@ * Commands additional to the ones defined in amcc-common.h */ #define CONFIG_CMD_CACHE +#define CONFIG_CMD_DTT #undef CONFIG_CMD_EEPROM
/* diff --git a/include/configs/io.h b/include/configs/io.h index fe07ca5..ceae3f5 100644 --- a/include/configs/io.h +++ b/include/configs/io.h @@ -39,6 +39,7 @@
#define CONFIG_SYS_CLK_FREQ 33333333 /* external frequency to pll */ @@ -77,6 +78,7 @@ * Commands additional to the ones defined in amcc-common.h */ #define CONFIG_CMD_CACHE +#define CONFIG_CMD_DTT #undef CONFIG_CMD_EEPROM
In hardware revision 1.20 one more fan controller is added to dlvision-10g.
board/gdsys/405ep/dlvision-10g.c | 12 +++++++++++- include/configs/dlvision-10g.h | 4 ++-- 2 files changed, 13 insertions(+), 3 deletions(-)
diff --git a/board/gdsys/405ep/dlvision-10g.c b/board/gdsys/405ep/dlvision-10g.c index 648c2ee..d7e0d66 100644 --- a/board/gdsys/405ep/dlvision-10g.c +++ b/board/gdsys/405ep/dlvision-10g.c @@ -50,6 +50,8 @@ enum { enum { HWVER_101 = 0, HWVER_110 = 1, + HWVER_120 = 2, + HWVER_130 = 3, };
enum { @@ -158,7 +160,15 @@ static void print_fpga_info(unsigned dev) break;
case HWVER_110: - printf(" HW-Ver 1.10\n"); + printf(" HW-Ver 1.10-1.12\n"); + break; + + case HWVER_120: + printf(" HW-Ver 1.20\n"); + break; + + case HWVER_130: + printf(" HW-Ver 1.30\n"); break;
default: diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index 47f1061..2cd2027 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -34,7 +34,7 @@ * Include common defines/options for all AMCC eval boards */ #define CONFIG_HOSTNAME dlvsion-10g -#define CONFIG_IDENT_STRING " dlvision-10g 0.02" +#define CONFIG_IDENT_STRING " dlvision-10g 0.03" #include "amcc-common.h"
#define CONFIG_BOARD_EARLY_INIT_F @@ -118,7 +118,7 @@
/* Temp sensor/hwmon/dtt */ #define CONFIG_DTT_LM63 1 /* National LM63 */ -#define CONFIG_DTT_SENSORS { 0x4c, 0x4e } /* Sensor addresses */ +#define CONFIG_DTT_SENSORS { 0x4c, 0x4e, 0x18 } /* Sensor addresses */ #define CONFIG_DTT_PWM_LOOKUPTABLE \ { { 46, 10 }, { 48, 14 }, { 50, 19 }, { 52, 23 },\ { 54, 27 }, { 56, 31 }, { 58, 36 }, { 60, 40 } }
include/configs/gdppc440etx.h | 4 ++++ include/configs/intip.h | 4 ++-- include/configs/io.h | 6 +++++- include/configs/io64.h | 2 +- include/configs/iocon.h | 6 +++++- 5 files changed, 17 insertions(+), 5 deletions(-)
diff --git a/include/configs/gdppc440etx.h b/include/configs/gdppc440etx.h index 3c59ff4..9efbb8e 100644 --- a/include/configs/gdppc440etx.h +++ b/include/configs/gdppc440etx.h @@ -50,6 +50,10 @@ #define CONFIG_BOARD_EARLY_INIT_F 1 /* call board_early_init_f*/ #define CONFIG_MISC_INIT_R 1 /* call misc_init_r() */
+#undef CONFIG_ZERO_BOOTDELAY_CHECK /* ignore keypress on bootdelay==0 */ +#define CONFIG_AUTOBOOT_KEYED /* use key strings to stop autoboot */ +#define CONFIG_AUTOBOOT_STOP_STR " " + /* * Base addresses -- Note these are effective addresses where the * actual resources get mapped (not physical addresses) diff --git a/include/configs/intip.h b/include/configs/intip.h index 92b65af..33364a8 100644 --- a/include/configs/intip.h +++ b/include/configs/intip.h @@ -37,10 +37,10 @@ #define CONFIG_460EX 1 /* Specific PPC460EX */ #ifdef CONFIG_DEVCONCENTER #define CONFIG_HOSTNAME devconcenter -#define CONFIG_IDENT_STRING " devconcenter 0.05" +#define CONFIG_IDENT_STRING " devconcenter 0.06" #else #define CONFIG_HOSTNAME intip -#define CONFIG_IDENT_STRING " intip 0.05" +#define CONFIG_IDENT_STRING " intip 0.06" #endif #define CONFIG_440 1 #define CONFIG_4xx 1 /* ... PPC4xx family */ diff --git a/include/configs/io.h b/include/configs/io.h index ceae3f5..03661cc 100644 --- a/include/configs/io.h +++ b/include/configs/io.h @@ -34,7 +34,7 @@ * Include common defines/options for all AMCC eval boards */ #define CONFIG_HOSTNAME io -#define CONFIG_IDENT_STRING " io 0.04" +#define CONFIG_IDENT_STRING " io 0.05" #include "amcc-common.h"
#define CONFIG_BOARD_EARLY_INIT_F @@ -50,6 +50,10 @@ #define PLLMR0_DEFAULT PLLMR0_266_133_66 #define PLLMR1_DEFAULT PLLMR1_266_133_66
+#undef CONFIG_ZERO_BOOTDELAY_CHECK /* ignore keypress on bootdelay==0 */ +#define CONFIG_AUTOBOOT_KEYED /* use key strings to stop autoboot */ +#define CONFIG_AUTOBOOT_STOP_STR " " + /* new uImage format support */ #define CONFIG_FIT #define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ diff --git a/include/configs/io64.h b/include/configs/io64.h index 51b2dd1..887aaef 100644 --- a/include/configs/io64.h +++ b/include/configs/io64.h @@ -53,7 +53,7 @@ * Include common defines/options for all AMCC eval boards */ #define CONFIG_HOSTNAME io64 -#define CONFIG_IDENT_STRING " io64 0.01" +#define CONFIG_IDENT_STRING " io64 0.02" #include "amcc-common.h"
#define CONFIG_BOARD_EARLY_INIT_F diff --git a/include/configs/iocon.h b/include/configs/iocon.h index bbf79e7..7f8825b 100644 --- a/include/configs/iocon.h +++ b/include/configs/iocon.h @@ -34,7 +34,7 @@ * Include common defines/options for all AMCC eval boards */ #define CONFIG_HOSTNAME iocon -#define CONFIG_IDENT_STRING " iocon 0.03" +#define CONFIG_IDENT_STRING " iocon 0.04" #include "amcc-common.h"
#define CONFIG_BOARD_EARLY_INIT_F @@ -49,6 +49,10 @@ #define PLLMR0_DEFAULT PLLMR0_266_133_66 #define PLLMR1_DEFAULT PLLMR1_266_133_66
include/gdsys_fpga.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/gdsys_fpga.h b/include/gdsys_fpga.h index 555fbe2..bfa656f 100644 --- a/include/gdsys_fpga.h +++ b/include/gdsys_fpga.h @@ -115,7 +115,7 @@ typedef struct ihs_fpga { u16 reserved_2[93]; /* 0x0044 */ u16 reflection_high; /* 0x00fe */ ihs_osd_t osd; /* 0x0100 */ - u16 reserved_3[88]; /* 0x010e */ + u16 reserved_3[889]; /* 0x010e */ u16 videomem; /* 0x0800 */ } ihs_fpga_t; #endif
Dirk Eibach
Stefan Roese
