[PATCH] stm32mp: fix various array bounds checks
In all these cases, the index on the LHS is immediately afterwards used to access the array appearing in the ARRAY_SIZE() on the RHS - so if that index is equal to the array size, we'll access one-past-the-end of the array.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk ---
Patch generated with '-U5' to make that access obvious from the diff context.
arch/arm/mach-stm32mp/cpu.c | 4 ++-- board/st/stm32mp1/stm32mp1.c | 2 +- drivers/ram/stm32mp1/stm32mp1_interactive.c | 2 +- 3 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-stm32mp/cpu.c b/arch/arm/mach-stm32mp/cpu.c index dc4112d5e6..e2f67fc423 100644 --- a/arch/arm/mach-stm32mp/cpu.c +++ b/arch/arm/mach-stm32mp/cpu.c @@ -188,11 +188,11 @@ static void setup_boot_mode(void)
log_debug("%s: boot_ctx=0x%x => boot_mode=%x, instance=%d forced=%x\n", __func__, boot_ctx, boot_mode, instance, forced_mode); switch (boot_mode & TAMP_BOOT_DEVICE_MASK) { case BOOT_SERIAL_UART: - if (instance > ARRAY_SIZE(serial_addr)) + if (instance >= ARRAY_SIZE(serial_addr)) break; /* serial : search associated node in devicetree */ sprintf(cmd, "serial@%x", serial_addr[instance]); if (uclass_get_device_by_name(UCLASS_SERIAL, cmd, &dev)) { /* restore console on error */ @@ -218,11 +218,11 @@ static void setup_boot_mode(void) env_set("boot_device", "usb"); env_set("boot_instance", "0"); break; case BOOT_FLASH_SD: case BOOT_FLASH_EMMC: - if (instance > ARRAY_SIZE(sdmmc_addr)) + if (instance >= ARRAY_SIZE(sdmmc_addr)) break; /* search associated sdmmc node in devicetree */ sprintf(cmd, "mmc@%x", sdmmc_addr[instance]); if (uclass_get_device_by_name(UCLASS_MMC, cmd, &dev)) { printf("mmc%d = %s not found in device tree!\n", diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index ca8f0255ae..1a1b1844c8 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -870,11 +870,11 @@ int mmc_get_boot(void) STM32_SDMMC1_BASE, STM32_SDMMC2_BASE, STM32_SDMMC3_BASE };
- if (instance > ARRAY_SIZE(sdmmc_addr)) + if (instance >= ARRAY_SIZE(sdmmc_addr)) return 0;
/* search associated sdmmc node in devicetree */ snprintf(cmd, sizeof(cmd), "mmc@%x", sdmmc_addr[instance]); if (uclass_get_device_by_name(UCLASS_MMC, cmd, &dev)) { diff --git a/drivers/ram/stm32mp1/stm32mp1_interactive.c b/drivers/ram/stm32mp1/stm32mp1_interactive.c index f0fe7e61e3..2c19847c66 100644 --- a/drivers/ram/stm32mp1/stm32mp1_interactive.c +++ b/drivers/ram/stm32mp1/stm32mp1_interactive.c @@ -389,11 +389,11 @@ bool stm32mp1_ddr_interactive(void *priv, log_debug("** step %d ** %s / %d\n", step, step_str[step], next_step);
if (next_step < 0) return false;
- if (step < 0 || step > ARRAY_SIZE(step_str)) { + if (step < 0 || step >= ARRAY_SIZE(step_str)) { printf("** step %d ** INVALID\n", step); return false; }
printf("%d:%s\n", step, step_str[step]);
Hi Rasmus
/* serial : search associated node in devicetree */ sprintf(cmd, "serial@%x", serial_addr[instance]); if (uclass_get_device_by_name(UCLASS_SERIAL, cmd, &dev)) { /* restore console on error */if (instance >= ARRAY_SIZE(serial_addr)) break;
/* search associated sdmmc node in devicetree */ sprintf(cmd, "mmc@%x", sdmmc_addr[instance]); if (uclass_get_device_by_name(UCLASS_MMC, cmd, &dev)) { printf("mmc%d = %s not found in device tree!\n",if (instance >= ARRAY_SIZE(sdmmc_addr)) break;
Good catch !
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
On 3/24/23 10:39, Patrice CHOTARD wrote:
Hi Rasmus
Good catch !
Thanks Patrice
Applied on u-boot-stm/master, thanks
Patrice
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Thanks Patrick
Patrice CHOTARD
Patrick DELAUNAY
Rasmus Villemoes
