[U-Boot] [PATCH] mx25: Make the UART port number explicit in its setup function
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/arm926ejs/mx25/generic.c | 2 +- board/karo/tx25/tx25.c | 4 ++-- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx25/generic.c b/arch/arm/cpu/arm926ejs/mx25/generic.c index c6e1146..150eb69 100644 --- a/arch/arm/cpu/arm926ejs/mx25/generic.c +++ b/arch/arm/cpu/arm926ejs/mx25/generic.c @@ -145,7 +145,7 @@ int cpu_mmc_init (bd_t * bis) }
#ifdef CONFIG_MXC_UART -void mx25_uart_init_pins (void) +void mx25_uart1_init_pins(void) { struct iomuxc_mux_ctl *muxctl; struct iomuxc_pad_ctl *padctl; diff --git a/board/karo/tx25/tx25.c b/board/karo/tx25/tx25.c index dc57d5c..269858c 100644 --- a/board/karo/tx25/tx25.c +++ b/board/karo/tx25/tx25.c @@ -141,9 +141,9 @@ void tx25_fec_init(void) int board_init() { #ifdef CONFIG_MXC_UART - extern void mx25_uart_init_pins(void); + extern void mx25_uart1_init_pins(void);
- mx25_uart_init_pins(); + mx25_uart1_init_pins(); #endif /* board id for linux */ gd->bd->bi_arch_number = MACH_TYPE_TX25;
Hi Stefano,
Ping?
Regards,
Fabio Estevam
-----Original Message----- From: Estevam Fabio-R49496 Sent: Thursday, February 17, 2011 5:50 PM To: u-boot@lists.denx.de Cc: sbabic@denx.de; Estevam Fabio-R49496 Subject: [PATCH] mx25: Make the UART port number explicit in its setup function
- mx25_uart_init_pins(); + mx25_uart1_init_pins(); #endif /* board id for linux */ gd->bd->bi_arch_number = MACH_TYPE_TX25; -- 1.6.0.4
On 03/02/2011 02:31 AM, Estevam Fabio-R49496 wrote:
Hi Stefano,
Hi Fabio,
Ping?
As I do not see any fix for the current release, I have not yet merged it into u-boot-imx and I will do it when the window is open again. I imagine your patch is an introduction for further patches, where more as one uart is used, right ? Should it belong maybe to the same patchset ?
checkpatch reports your patch is corrupted. Strange, I do not why, I have fixed myself.
Best regards, Stefano Babic
On 3/2/2011 6:15 AM, Stefano Babic wrote: ...
I was working on adding MX25PDK support and I think that that the UART reference should be explicit, as different boards can boot from different UART ports.
Thanks, I haven“t noticed this.
Regards,
Fabio Estevam
I have applied your patch to u-boot-imx, next branch. Maybe it is easier to you to use it as base for your port.
Fabio Estevam
Stefano Babic
