[U-Boot] [PATCH v3 2/5] spi: make mode visible to both dm and non-dm
Couldn't find the exact reason to define 'mode' for dm, probably it is not using in non-dm drivers but it need to visible both dm and non-dm as mode data is getting dereferred in spi flash core ie common to both.
Cc: Bin Meng bmeng.cn@gmail.com Cc: Simon Glass sjg@chromium.org Signed-off-by: Jagan Teki jteki@openedev.com --- Changes for v3: make mode as uint Changes for v2: none
include/spi.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/spi.h b/include/spi.h index b4d2723..05202d0 100644 --- a/include/spi.h +++ b/include/spi.h @@ -99,13 +99,13 @@ struct dm_spi_slave_platdata { * * @dev: SPI slave device * @max_hz: Maximum speed for this slave - * @mode: SPI mode to use for this slave (see SPI mode flags) * @speed: Current bus speed. This is 0 until the bus is first * claimed. * @bus: ID of the bus that the slave is attached to. For * driver model this is the sequence number of the SPI * bus (bus->seq) so does not need to be stored * @cs: ID of the chip select connected to the slave. + * @mode: SPI mode to use for this slave (see SPI mode flags) * @op_mode_rx: SPI RX operation mode. * @op_mode_tx: SPI TX operation mode. * @wordlen: Size of SPI word in number of bits @@ -120,11 +120,11 @@ struct spi_slave { struct udevice *dev; /* struct spi_slave is dev->parentdata */ uint max_hz; uint speed; - uint mode; #else unsigned int bus; unsigned int cs; #endif + uint mode; u8 op_mode_rx; u8 op_mode_tx; unsigned int wordlen;
Hi Jagan,
- @dev: SPI slave device
- @max_hz: Maximum speed for this slave
- @mode: SPI mode to use for this slave (see SPI mode flags)
- @speed: Current bus speed. This is 0 until the bus is first
claimed.
- @bus: ID of the bus that the slave is attached to. For
- @cs: ID of the chip select connected to the slave.
- @op_mode_rx: SPI RX operation mode.
- @op_mode_tx: SPI TX operation mode.
- @wordlen: Size of SPI word in number of bits
uint mode;
Can you please send all v3? I see you used to send just partial patch series to the mailing list, but I don't think that's good for people to test the whole series, especially for those who have not been tracking the series from the beginning.
For this case, after I applied the v3 2/5 patch, then applied the v2 3/5 patch, I got:
Applying: spi: Use mode instead of op_mode_tx error: patch failed: include/spi.h:126 error: include/spi.h: patch does not apply Patch failed at 0001 spi: Use mode instead of op_mode_tx The copy of the patch that failed is found in: ~/work/git/u-boot/.git/rebase-apply/patch When you have resolved this problem, run "git am --resolved". If you prefer to skip this patch, run "git am --skip" instead. To restore the original branch and stop patching, run "git am --abort".
Regards, Bin
Bin Meng
Jagan Teki
