[U-Boot] [PATCH] arm: atmel: sam9m10g45ek: let CONFIG_SYS_NO_FLASH at proper position
In config_cmd_default.h, it will use CONFIG_SYS_NO_FLASH to decide whether include CONFIG_CMD_FLASH and CONFIG_CMD_IMLS. So, if the CONFIG_SYS_NO_FLASH defined later than include/config_cmd_default.h, These two commands will be included always.
So move CONFIG_SYS_NO_FLASH definition to proper position.
Signed-off-by: Bo Shen voice.shen@atmel.com --- include/configs/at91sam9m10g45ek.h | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 2095fe6..eb86239 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -77,6 +77,10 @@ /* * Command line configuration. */ + +/* No NOR flash */ +#define CONFIG_SYS_NO_FLASH + #include <config_cmd_default.h> #undef CONFIG_CMD_BDI #undef CONFIG_CMD_FPGA @@ -97,9 +101,6 @@ #define CONFIG_SYS_INIT_SP_ADDR \ (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - GENERATED_GBL_DATA_SIZE)
-/* No NOR flash */ -#define CONFIG_SYS_NO_FLASH - /* NAND flash */ #ifdef CONFIG_CMD_NAND #define CONFIG_NAND_ATMEL
Dear Bo Shen,
Bo Shen voice.shen@atmel.com writes:
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Andreas Bießmann
Bo Shen
