Please pull u-boot-marvell/master
Hi Tom,
please pull these MVEBU related patches:
---------------------------------------------------------------- - Cleanup in Marvell bubt cmd (Tom & Jagan) - Add a series of MikroTik CRS3xx, 98DX3236 based switches (Luka) ----------------------------------------------------------------
Here the Azure build, without any issues:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=15&view=resul...
Thanks, Stefan
The following changes since commit 89150a9314bd432ed8cca9a03034435346fb0b16:
Merge https://gitlab.denx.de/u-boot/custodians/u-boot-sh (2020-08-05 16:06:42 -0400)
git@gitlab.denx.de:u-boot/custodians/u-boot-marvell.git
for you to fetch changes up to 96be2f072768a91eb0df3767b9c8c880dd1e4b5b:
mvebu: bubt: Drop dead code (2020-08-06 14:12:14 +0200)
---------------------------------------------------------------- Jagan Teki (1): cmd: mvebu/bubt: Drop unused SPI_FLASH_PROTECTION
Luka Kovacic (5): arm: mvebu: Add CRS305-1G-4S Bit board arm: mvebu: Add CRS326-24G-2S board arm: mvebu: Add CRS328-4C-20S-4S board arm: mvebu: crs3xx-98dx3236: Add a maintainer arm: mvebu: Update CRS305-1G-4S board flash layout
Tom Rini (1): mvebu: bubt: Drop dead code
arch/arm/dts/Makefile | 5 + arch/arm/dts/armada-xp-crs305-1g-4s-bit.dts | 43 ++++++++ arch/arm/dts/armada-xp-crs305-1g-4s.dtsi | 10 +- arch/arm/dts/armada-xp-crs326-24g-2s-bit.dts | 43 ++++++++ arch/arm/dts/armada-xp-crs326-24g-2s-u-boot.dtsi | 13 +++ arch/arm/dts/armada-xp-crs326-24g-2s.dts | 17 ++++ arch/arm/dts/armada-xp-crs326-24g-2s.dtsi | 110 +++++++++++++++++++++ arch/arm/dts/armada-xp-crs328-4c-20s-4s-bit.dts | 43 ++++++++ .../arm/dts/armada-xp-crs328-4c-20s-4s-u-boot.dtsi | 13 +++ arch/arm/dts/armada-xp-crs328-4c-20s-4s.dts | 17 ++++ arch/arm/dts/armada-xp-crs328-4c-20s-4s.dtsi | 110 +++++++++++++++++++++ board/mikrotik/crs3xx-98dx3236/MAINTAINERS | 22 +++++ cmd/mvebu/bubt.c | 22 ----- configs/crs305-1g-4s-bit_defconfig | 54 ++++++++++ configs/crs305-1g-4s_defconfig | 9 +- configs/crs326-24g-2s-bit_defconfig | 54 ++++++++++ configs/crs326-24g-2s_defconfig | 54 ++++++++++ configs/crs328-4c-20s-4s-bit_defconfig | 54 ++++++++++ configs/crs328-4c-20s-4s_defconfig | 54 ++++++++++ 19 files changed, 719 insertions(+), 28 deletions(-) create mode 100644 arch/arm/dts/armada-xp-crs305-1g-4s-bit.dts create mode 100644 arch/arm/dts/armada-xp-crs326-24g-2s-bit.dts create mode 100644 arch/arm/dts/armada-xp-crs326-24g-2s-u-boot.dtsi create mode 100644 arch/arm/dts/armada-xp-crs326-24g-2s.dts create mode 100644 arch/arm/dts/armada-xp-crs326-24g-2s.dtsi create mode 100644 arch/arm/dts/armada-xp-crs328-4c-20s-4s-bit.dts create mode 100644 arch/arm/dts/armada-xp-crs328-4c-20s-4s-u-boot.dtsi create mode 100644 arch/arm/dts/armada-xp-crs328-4c-20s-4s.dts create mode 100644 arch/arm/dts/armada-xp-crs328-4c-20s-4s.dtsi create mode 100644 configs/crs305-1g-4s-bit_defconfig create mode 100644 configs/crs326-24g-2s-bit_defconfig create mode 100644 configs/crs326-24g-2s_defconfig create mode 100644 configs/crs328-4c-20s-4s-bit_defconfig create mode 100644 configs/crs328-4c-20s-4s_defconfig
On Thu, Aug 06, 2020 at 02:28:52PM -0400, Tom Rini wrote:
On Thu, Aug 06, 2020 at 04:33:01PM +0200, Stefan Roese wrote:
Hi Tom,
Oh, can you please take a look in to the dtc warnings that are generated on Marvell platforms? Thanks!
Stefan Roese
