[U-Boot-Users] viewing files on JFFS2/NAND flash
I have implemented the macros for JFFS2/NAND flash access and can do an mtd, mtdparts or ls command, like this:
I8000E> mtd device nand0 <atx-0>, # parts = 3 #: name size offset mask_flags 0: rootfs1 0x01000000 0x00000000 0 1: rootfs2 0x01000000 0x01000000 0 2: MPUapps 0x06000000 0x02000000 0 active partition: nand0,0 - (rootfs1) 0x01000000 @ 0x00000000 defaults: mtdids : nand0=atx-0 mtdparts: mtdparts=atx-0:-@1m(jffs2) I8000E> ls rescan: First time in use Scanning JFFS2 FS: done. ******The directory Entries****** ******The fragment Entries****** I8000E>
However, my problem is that I have written some files from Linux onto these three partitions and then when I reboot, I do not see the files from u-boot.
If I then do a complete boot to Linux, I can ls the files from linux and display their contents.
There must be something silly I am doing (or not doing) that precludes me from viewing the files on the JFFS2/NAND flash partitions that were written from Linux.
I wonder if you would be so kind as to offer a suggestion or two for a way to move forward.
Charles
Charles Krinke
