[U-Boot] [PATCH] ARM: uniphier: add pin-mux settings for NAND, eMMC, SD of PH1-sLD3
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/pinctrl/pinctrl-sld3.c | 23 +++++++++++++++++++++++ 1 file changed, 23 insertions(+)
diff --git a/arch/arm/mach-uniphier/pinctrl/pinctrl-sld3.c b/arch/arm/mach-uniphier/pinctrl/pinctrl-sld3.c index 367d9f3..f85ed53 100644 --- a/arch/arm/mach-uniphier/pinctrl/pinctrl-sld3.c +++ b/arch/arm/mach-uniphier/pinctrl/pinctrl-sld3.c @@ -22,4 +22,27 @@ void ph1_sld3_pin_init(void) sg_set_pinsel(19, 0, 4, 4); /* USB3OC */ sg_set_pinsel(20, 1, 4, 4); /* USB3VBUS */ #endif + +#ifdef CONFIG_NAND_DENALI + sg_set_pinsel(38, 1, 4, 4); /* NFALE_GB, NFCLE_GB */ + sg_set_pinsel(39, 1, 4, 4); /* XNFRYBY0_GB */ + sg_set_pinsel(40, 1, 4, 4); /* XNFCE0_GB, XNFRE_GB, XNFWE_GB, XNFWP_GB */ + sg_set_pinsel(41, 1, 4, 4); /* XNFRYBY1_GB, XNFCE1_GB */ + sg_set_pinsel(58, 1, 4, 4); /* NFD[0-3]_GB */ + sg_set_pinsel(59, 1, 4, 4); /* NFD[4-7]_GB */ +#endif + +#ifdef CONFIG_MMC_UNIPHIER + /* eMMC */ + sg_set_pinsel(55, 1, 4, 4); /* XERST */ + sg_set_pinsel(56, 1, 4, 4); /* MMCDAT[0-3] */ + sg_set_pinsel(57, 1, 4, 4); /* MMCDAT[4-7] */ + sg_set_pinsel(60, 1, 4, 4); /* MMCCLK, MMCCMD */ + + /* SD card */ + sg_set_pinsel(42, 1, 4, 4); /* SD1CLK, SD1CMD, SD1DAT[0-3] */ + sg_set_pinsel(43, 1, 4, 4); /* SD1CD */ + sg_set_pinsel(44, 1, 4, 4); /* SD1WP */ + sg_set_pinsel(45, 1, 4, 4); /* SDVTCG */ +#endif }
2016-03-30 10:53 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier/master.
Masahiro Yamada
