[PATCH 1/1] mmc: consider cd-gpios in Synopsys DesignWare driver
The JH7110 SoC uses a GPIO for card detect.
* In the of_to_plat function check if a cd-gpios definition exists and request the GPIO. * In the getcd function return the GPIO value in this case.
Reported-by: Conor Dooley conor.dooley@microchip.com Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- drivers/mmc/snps_dw_mmc.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/mmc/snps_dw_mmc.c b/drivers/mmc/snps_dw_mmc.c index 9bdbe5070b1..2f0133f22c9 100644 --- a/drivers/mmc/snps_dw_mmc.c +++ b/drivers/mmc/snps_dw_mmc.c @@ -12,6 +12,7 @@ #include <dwmmc.h> #include <errno.h> #include <fdtdec.h> +#include <asm/gpio.h> #include <dm/device_compat.h> #include <linux/libfdt.h> #include <linux/err.h> @@ -29,6 +30,7 @@ struct snps_dwmci_plat { struct snps_dwmci_priv_data { struct dwmci_host host; u32 f_max; + struct gpio_desc cd_gpio; };
static int snps_dwmmc_clk_setup(struct udevice *dev) @@ -106,6 +108,8 @@ static int snps_dwmmc_of_to_plat(struct udevice *dev) if (!ret && priv->f_max < CLOCK_MIN) return -EINVAL;
+ gpio_request_by_name(dev, "cd-gpios", 0, &priv->cd_gpio, GPIOD_IS_IN); + host->fifo_mode = dev_read_bool(dev, "fifo-mode"); host->name = dev->name; host->dev_index = 0; @@ -119,6 +123,9 @@ int snps_dwmmc_getcd(struct udevice *dev) struct snps_dwmci_priv_data *priv = dev_get_priv(dev); struct dwmci_host *host = &priv->host;
+ if (dm_gpio_is_valid(&priv->cd_gpio)) + return dm_gpio_get_value(&priv->cd_gpio); + return !(dwmci_readl(host, DWMCI_CDETECT) & 1); }
