[U-Boot] [PATCH] at91: corvus_defconfig: get rid of build warnings
fix CONFIG_OF_EMBED and add CONFIG_DM_USB build warnings.
Signed-off-by: Heiko Schocher hs@denx.de --- tree builds fine on travis, see: https://travis-ci.org/hsdenx/u-boot/builds/520165307
configs/corvus_defconfig | 6 ++++-- include/configs/corvus.h | 1 + 2 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index a1af2f1342..af159ecb47 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -18,6 +18,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro,256k(env),256k(env_redundant),256k(spare),512k(dtb),6M(kernel)ro,-(rootfs) root=/dev/mtdblock7 rw rootfstype=jffs2" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " @@ -34,10 +35,11 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_MTDPARTS=y +CONFIG_DOS_PARTITION=y CONFIG_OF_CONTROL=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g45-corvus" CONFIG_ENV_IS_IN_NAND=y +CONFIG_BLK=y CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_DFU_NAND=y @@ -47,8 +49,8 @@ CONFIG_NAND_ATMEL=y CONFIG_PHYLIB=y CONFIG_ATMEL_USART=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Siemens AG" CONFIG_USB_GADGET_VENDOR_NUM=0x0908 diff --git a/include/configs/corvus.h b/include/configs/corvus.h index 749a67d4b0..e85f684e32 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -72,6 +72,7 @@ #define CONFIG_SYS_NAND_MASK_CLE (1 << 22) #define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC8 +#define CONFIG_SYS_NAND_DRIVER_ECC_LAYOUT #endif
/* Ethernet */
Applied to u-boot-atmel/master, thanks !
Eugen.Hristev@microchip.com
Heiko Schocher
