[PATCH 1/2] arm: mvebu: turris_omnia: Show MCU type in show_board_info()
Different Turris Omnia HW board revisions contains different MCU. Show type in show_board_info() to easily identify which MCU is populated.
Signed-off-by: Pali Rohár pali@kernel.org --- board/CZ.NIC/turris_omnia/turris_omnia.c | 45 ++++++++++++++++++++++++ 1 file changed, 45 insertions(+)
diff --git a/board/CZ.NIC/turris_omnia/turris_omnia.c b/board/CZ.NIC/turris_omnia/turris_omnia.c index b169abca0956..6fc2018c1cfb 100644 --- a/board/CZ.NIC/turris_omnia/turris_omnia.c +++ b/board/CZ.NIC/turris_omnia/turris_omnia.c @@ -62,13 +62,27 @@ enum mcu_commands { CMD_GET_STATUS_WORD = 0x01, CMD_GET_RESET = 0x09, CMD_WATCHDOG_STATE = 0x0b, + + /* available if STS_FEATURES_SUPPORTED bit set in status word */ + CMD_GET_FEATURES = 0x10, };
enum status_word_bits { + STS_MCU_TYPE_MASK = GENMASK(1, 0), + STS_MCU_TYPE_STM32 = 0, + STS_MCU_TYPE_GD32 = 1, + STS_MCU_TYPE_MKL = 2, + STS_MCU_TYPE_UNKN = 3, + STS_FEATURES_SUPPORTED = BIT(2), CARD_DET_STSBIT = 0x0010, MSATA_IND_STSBIT = 0x0020, };
+/* CMD_GET_FEATURES */ +enum features_e { + FEAT_PERIPH_MCU = BIT(0), +}; + /* * Those values and defines are taken from the Marvell U-Boot version * "u-boot-2013.01-2014_T3.0" @@ -371,6 +385,36 @@ static int omnia_get_ram_size_gb(void) return ram_size; }
+static const char * const omnia_get_mcu_type(void) +{ + static const char * const mcu_types[] = { + [STS_MCU_TYPE_STM32] = "STM32", + [STS_MCU_TYPE_GD32] = "GD32", + [STS_MCU_TYPE_MKL] = "MKL", + [STS_MCU_TYPE_UNKN] = "unknown", + }; + static const char * const mcu_types_with_perip_resets[] = { + [STS_MCU_TYPE_STM32] = "STM32 (with peripheral resets)", + [STS_MCU_TYPE_GD32] = "GD32 (with peripheral resets)", + [STS_MCU_TYPE_MKL] = "MKL (with peripheral resets)", + [STS_MCU_TYPE_UNKN] = "unknown (with peripheral resets)", + }; + u16 stsword, features; + int ret; + + ret = omnia_mcu_read(CMD_GET_STATUS_WORD, &stsword, sizeof(stsword)); + if (ret) + return "unknown"; + + if (stsword & STS_FEATURES_SUPPORTED) { + ret = omnia_mcu_read(CMD_GET_FEATURES, &features, sizeof(features)); + if (ret == 0 && (features & FEAT_PERIPH_MCU)) + return mcu_types_with_perip_resets[stsword & STS_MCU_TYPE_MASK]; + } + + return mcu_types[stsword & STS_MCU_TYPE_MASK]; +} + /* * Define the DDR layout / topology here in the board file. This will * be used by the DDR3 init code in the SPL U-Boot version to configure @@ -688,6 +732,7 @@ int show_board_info(void)
err = turris_atsha_otp_get_serial_number(&version_num, &serial_num); printf("Model: Turris Omnia\n"); + printf(" MCU type: %s\n", omnia_get_mcu_type()); printf(" RAM size: %i MiB\n", omnia_get_ram_size_gb() * 1024); if (err) printf(" Serial Number: unknown\n");
New Turris Omnia HW board revision requires that software controls peripheral reset signals, namely PERST# signals on mPCIe slots, ethernet phy reset and lan switch reset. Those pins are connected to MCU controlled by MCU i2c API as GPIOs. On new HW board revision those pins stay in reset after board reset and software has to release these peripherals from reset manually. MCU announce this requirement by FEAT_PERIPH_MCU bit in CMD_GET_FEATURES command.
On older HW board revisions when FEAT_PERIPH_MCU is not announced, all those reset signals are automatically released after board finish reset.
Detect FEAT_PERIPH_MCU bit in board_fix_fdt() and ft_board_setup() functions and insert into device tree blob pcie "reset-gpios" and eth phy "phy-reset-gpios" properties with corresponding MCU gpio definitions. PCIe and eth PHY drivers then automatically release resets during device initialization. Both U-Boot and Linux kernel drivers support those device tree reset properties.
Initialization of lan switch on new HW board revision is more complicated. Switch strapping pins are shared with switch RGMII pins. And strapping pins must be in specific configuration after releasing switch reset. Due to pin sharing, it is first required to switch A385 side of switch pins into GPIO mode, set strapping configuration, release switch from reset and after that switch A385 pins back to RGMII mode.
Because this complicated setup is not supported by switch DSA drivers and cannot be expressed easily in device tree, implement it manually in SPL function spl_board_init(). So in proper U-Boot and OS/kernel would be lan switch initialized and be in same configuration like it was on old HW board revisions (where reset sequence did those steps at hardware level).
Signed-off-by: Pali Rohár pali@kernel.org --- board/CZ.NIC/turris_omnia/turris_omnia.c | 226 +++++++++++++++++++++++ 1 file changed, 226 insertions(+)
diff --git a/board/CZ.NIC/turris_omnia/turris_omnia.c b/board/CZ.NIC/turris_omnia/turris_omnia.c index 6fc2018c1cfb..e262ea1aba51 100644 --- a/board/CZ.NIC/turris_omnia/turris_omnia.c +++ b/board/CZ.NIC/turris_omnia/turris_omnia.c @@ -19,9 +19,11 @@ #include <asm/arch/cpu.h> #include <asm/arch/soc.h> #include <dm/uclass.h> +#include <dt-bindings/gpio/gpio.h> #include <fdt_support.h> #include <time.h> #include <linux/bitops.h> +#include <linux/delay.h> #include <u-boot/crc.h>
#include "../drivers/ddr/marvell/a38x/ddr3_init.h" @@ -65,6 +67,9 @@ enum mcu_commands {
/* available if STS_FEATURES_SUPPORTED bit set in status word */ CMD_GET_FEATURES = 0x10, + + /* available if EXT_CMD bit set in features */ + CMD_EXT_CONTROL = 0x12, };
enum status_word_bits { @@ -81,6 +86,16 @@ enum status_word_bits { /* CMD_GET_FEATURES */ enum features_e { FEAT_PERIPH_MCU = BIT(0), + FEAT_EXT_CMDS = BIT(1), +}; + +/* CMD_EXT_CONTROL */ +enum ext_ctl_e { + EXT_CTL_nRES_LAN = BIT(1), + EXT_CTL_nRES_PHY = BIT(2), + EXT_CTL_nPERST0 = BIT(3), + EXT_CTL_nPERST1 = BIT(4), + EXT_CTL_nPERST2 = BIT(5), };
/* @@ -543,6 +558,90 @@ static void handle_reset_button(void) } }
+static void initialize_switch(void) +{ + u32 val, val04, val08, val10, val14; + u16 ctrl[2]; + int err; + + printf("Initializing LAN eth switch... "); + + /* Change RGMII pins to GPIO mode */ + + val = val04 = readl(MVEBU_MPP_BASE + 0x04); + val &= ~GENMASK(19, 16); /* MPP[12] := GPIO */ + val &= ~GENMASK(23, 20); /* MPP[13] := GPIO */ + val &= ~GENMASK(27, 24); /* MPP[14] := GPIO */ + val &= ~GENMASK(31, 28); /* MPP[15] := GPIO */ + writel(val, MVEBU_MPP_BASE + 0x04); + + val = val08 = readl(MVEBU_MPP_BASE + 0x08); + val &= ~GENMASK(3, 0); /* MPP[16] := GPIO */ + val &= ~GENMASK(23, 20); /* MPP[21] := GPIO */ + writel(val, MVEBU_MPP_BASE + 0x08); + + val = val10 = readl(MVEBU_MPP_BASE + 0x10); + val &= ~GENMASK(27, 24); /* MPP[38] := GPIO */ + val &= ~GENMASK(31, 28); /* MPP[39] := GPIO */ + writel(val, MVEBU_MPP_BASE + 0x10); + + val = val14 = readl(MVEBU_MPP_BASE + 0x14); + val &= ~GENMASK(3, 0); /* MPP[40] := GPIO */ + val &= ~GENMASK(7, 4); /* MPP[41] := GPIO */ + writel(val, MVEBU_MPP_BASE + 0x14); + + /* Set initial values for switch reset strapping pins */ + + val = readl(MVEBU_GPIO0_BASE + 0x00); + val |= BIT(12); /* GPIO[12] := 1 */ + val |= BIT(13); /* GPIO[13] := 1 */ + val |= BIT(14); /* GPIO[14] := 1 */ + val |= BIT(15); /* GPIO[15] := 1 */ + val &= ~BIT(16); /* GPIO[16] := 0 */ + val |= BIT(21); /* GPIO[21] := 1 */ + writel(val, MVEBU_GPIO0_BASE + 0x00); + + val = readl(MVEBU_GPIO1_BASE + 0x00); + val |= BIT(6); /* GPIO[38] := 1 */ + val |= BIT(7); /* GPIO[39] := 1 */ + val |= BIT(8); /* GPIO[40] := 1 */ + val &= ~BIT(9); /* GPIO[41] := 0 */ + writel(val, MVEBU_GPIO1_BASE + 0x00); + + val = readl(MVEBU_GPIO0_BASE + 0x04); + val &= ~BIT(12); /* GPIO[12] := Out Enable */ + val &= ~BIT(13); /* GPIO[13] := Out Enable */ + val &= ~BIT(14); /* GPIO[14] := Out Enable */ + val &= ~BIT(15); /* GPIO[15] := Out Enable */ + val &= ~BIT(16); /* GPIO[16] := Out Enable */ + val &= ~BIT(21); /* GPIO[21] := Out Enable */ + writel(val, MVEBU_GPIO0_BASE + 0x04); + + val = readl(MVEBU_GPIO1_BASE + 0x04); + val &= ~BIT(6); /* GPIO[38] := Out Enable */ + val &= ~BIT(7); /* GPIO[39] := Out Enable */ + val &= ~BIT(8); /* GPIO[40] := Out Enable */ + val &= ~BIT(9); /* GPIO[41] := Out Enable */ + writel(val, MVEBU_GPIO1_BASE + 0x04); + + /* Release switch reset */ + + ctrl[0] = EXT_CTL_nRES_LAN; + ctrl[1] = EXT_CTL_nRES_LAN; + err = omnia_mcu_write(CMD_EXT_CONTROL, ctrl, sizeof(ctrl)); + + mdelay(10); + + /* Change RGMII pins back to RGMII mode */ + + writel(val04, MVEBU_MPP_BASE + 0x04); + writel(val08, MVEBU_MPP_BASE + 0x08); + writel(val10, MVEBU_MPP_BASE + 0x10); + writel(val14, MVEBU_MPP_BASE + 0x14); + + puts(err ? "failed\n" : "done\n"); +} + int board_early_init_f(void) { /* Configure MPP */ @@ -572,6 +671,9 @@ int board_early_init_f(void)
void spl_board_init(void) { + u16 val; + int ret; + /* * If booting from UART, disable MCU watchdog in SPL, since uploading * U-Boot proper can take too much time and trigger it. Instead enable @@ -581,6 +683,19 @@ void spl_board_init(void) enable_a385_watchdog(10); disable_mcu_watchdog(); } + + /* + * When MCU controls peripheral resets then release LAN eth switch from + * the reset and initialize it. When MCU does not control peripheral + * resets then LAN eth switch is initialized automatically by bootstrap + * pins when A385 is released from the reset. + */ + ret = omnia_mcu_read(CMD_GET_STATUS_WORD, &val, sizeof(val)); + if (ret == 0 && (val & STS_FEATURES_SUPPORTED)) { + ret = omnia_mcu_read(CMD_GET_FEATURES, &val, sizeof(val)); + if (ret == 0 && (val & FEAT_PERIPH_MCU)) + initialize_switch(); + } }
#if IS_ENABLED(CONFIG_OF_BOARD_FIXUP) || IS_ENABLED(CONFIG_OF_BOARD_SETUP) @@ -689,11 +804,109 @@ static void fixup_wwan_port_nodes(void *blob) disable_pcie_node(blob, 2); }
+static int insert_mcu_gpio_prop(void *blob, int node, const char *prop, + unsigned int phandle, u32 bank, u32 gpio, + u32 flags) +{ + fdt32_t val[4] = { cpu_to_fdt32(phandle), cpu_to_fdt32(bank), + cpu_to_fdt32(gpio), cpu_to_fdt32(flags) }; + return fdt_setprop(blob, node, prop, &val, sizeof(val)); +} + +static int fixup_mcu_gpio_in_pcie_nodes(void *blob) +{ + unsigned int mcu_phandle; + int port, gpio; + int pcie_node; + int port_node; + int ret; + + ret = fdt_increase_size(blob, 128); + if (ret < 0) { + printf("Cannot increase FDT size!\n"); + return ret; + } + + mcu_phandle = fdt_create_phandle_by_compatible(blob, "cznic,turris-omnia-mcu"); + if (!mcu_phandle) + return -FDT_ERR_NOPHANDLES; + + fdt_for_each_node_by_compatible(pcie_node, blob, -1, "marvell,armada-370-pcie") { + if (!fdtdec_get_is_enabled(blob, pcie_node)) + continue; + + fdt_for_each_subnode(port_node, blob, pcie_node) { + if (!fdtdec_get_is_enabled(blob, port_node)) + continue; + + port = fdtdec_get_int(blob, port_node, "marvell,pcie-port", -1); + + if (port == 0) + gpio = ilog2(EXT_CTL_nPERST0); + else if (port == 1) + gpio = ilog2(EXT_CTL_nPERST1); + else if (port == 2) + gpio = ilog2(EXT_CTL_nPERST2); + else + continue; + + /* insert: reset-gpios = <&mcu 2 gpio GPIO_ACTIVE_LOW>; */ + ret = insert_mcu_gpio_prop(blob, port_node, "reset-gpios", + mcu_phandle, 2, gpio, GPIO_ACTIVE_LOW); + if (ret < 0) + return ret; + } + } + + return 0; +} + +static int fixup_mcu_gpio_in_eth_wan_node(void *blob) +{ + unsigned int mcu_phandle; + int eth_wan_node; + int ret; + + ret = fdt_increase_size(blob, 64); + if (ret < 0) { + printf("Cannot increase FDT size!\n"); + return ret; + } + + eth_wan_node = fdt_path_offset(blob, "ethernet2"); + if (eth_wan_node < 0) + return eth_wan_node; + + mcu_phandle = fdt_create_phandle_by_compatible(blob, "cznic,turris-omnia-mcu"); + if (!mcu_phandle) + return -FDT_ERR_NOPHANDLES; + + /* insert: phy-reset-gpios = <&mcu 2 gpio GPIO_ACTIVE_LOW>; */ + ret = insert_mcu_gpio_prop(blob, eth_wan_node, "phy-reset-gpios", + mcu_phandle, 2, ilog2(EXT_CTL_nRES_PHY), GPIO_ACTIVE_LOW); + if (ret < 0) + return ret; + + return 0; +} + #endif
#if IS_ENABLED(CONFIG_OF_BOARD_FIXUP) int board_fix_fdt(void *blob) { + u16 val; + int ret; + + ret = omnia_mcu_read(CMD_GET_STATUS_WORD, &val, sizeof(val)); + if (ret == 0 && (val & STS_FEATURES_SUPPORTED)) { + ret = omnia_mcu_read(CMD_GET_FEATURES, &val, sizeof(val)); + if (ret == 0 && (val & FEAT_PERIPH_MCU)) { + fixup_mcu_gpio_in_pcie_nodes(blob); + fixup_mcu_gpio_in_eth_wan_node(blob); + } + } + fixup_msata_port_nodes(blob); fixup_wwan_port_nodes(blob);
@@ -840,6 +1053,19 @@ fail:
int ft_board_setup(void *blob, struct bd_info *bd) { + int node; + + /* + * U-Boot's FDT blob contains phy-reset-gpios in ethernet2 + * node when MCU controls all peripherals resets. + * Fixup MCU GPIO nodes in PCIe and eth wan nodes in this case. + */ + node = fdt_path_offset(gd->fdt_blob, "ethernet2"); + if (node >= 0 && fdt_getprop(gd->fdt_blob, node, "phy-reset-gpios", NULL)) { + fixup_mcu_gpio_in_pcie_nodes(blob); + fixup_mcu_gpio_in_eth_wan_node(blob); + } + fixup_spi_nor_partitions(blob); fixup_msata_port_nodes(blob); fixup_wwan_port_nodes(blob);
Wow, this looks pretty complex. But I assume that you already de-stilled the "best solution", so:
Thanks, Stefan
- FEAT_EXT_CMDS = BIT(1),
- u32 val, val04, val08, val10, val14;
- u16 ctrl[2];
- int err;
- printf("Initializing LAN eth switch... ");
- /* Change RGMII pins to GPIO mode */
- val = val04 = readl(MVEBU_MPP_BASE + 0x04);
- val &= ~GENMASK(19, 16); /* MPP[12] := GPIO */
- val &= ~GENMASK(23, 20); /* MPP[13] := GPIO */
- val &= ~GENMASK(27, 24); /* MPP[14] := GPIO */
- val &= ~GENMASK(31, 28); /* MPP[15] := GPIO */
- writel(val, MVEBU_MPP_BASE + 0x04);
- val = val08 = readl(MVEBU_MPP_BASE + 0x08);
- val &= ~GENMASK(3, 0); /* MPP[16] := GPIO */
- val &= ~GENMASK(23, 20); /* MPP[21] := GPIO */
- writel(val, MVEBU_MPP_BASE + 0x08);
- val = val10 = readl(MVEBU_MPP_BASE + 0x10);
- val &= ~GENMASK(27, 24); /* MPP[38] := GPIO */
- val &= ~GENMASK(31, 28); /* MPP[39] := GPIO */
- writel(val, MVEBU_MPP_BASE + 0x10);
- val = val14 = readl(MVEBU_MPP_BASE + 0x14);
- val &= ~GENMASK(3, 0); /* MPP[40] := GPIO */
- val &= ~GENMASK(7, 4); /* MPP[41] := GPIO */
- writel(val, MVEBU_MPP_BASE + 0x14);
- /* Set initial values for switch reset strapping pins */
- val = readl(MVEBU_GPIO0_BASE + 0x00);
- val |= BIT(12); /* GPIO[12] := 1 */
- val |= BIT(13); /* GPIO[13] := 1 */
- val |= BIT(14); /* GPIO[14] := 1 */
- val |= BIT(15); /* GPIO[15] := 1 */
- val &= ~BIT(16); /* GPIO[16] := 0 */
- val |= BIT(21); /* GPIO[21] := 1 */
- writel(val, MVEBU_GPIO0_BASE + 0x00);
- val = readl(MVEBU_GPIO1_BASE + 0x00);
- val |= BIT(6); /* GPIO[38] := 1 */
- val |= BIT(7); /* GPIO[39] := 1 */
- val |= BIT(8); /* GPIO[40] := 1 */
- val &= ~BIT(9); /* GPIO[41] := 0 */
- writel(val, MVEBU_GPIO1_BASE + 0x00);
- val = readl(MVEBU_GPIO0_BASE + 0x04);
- val &= ~BIT(12); /* GPIO[12] := Out Enable */
- val &= ~BIT(13); /* GPIO[13] := Out Enable */
- val &= ~BIT(14); /* GPIO[14] := Out Enable */
- val &= ~BIT(15); /* GPIO[15] := Out Enable */
- val &= ~BIT(16); /* GPIO[16] := Out Enable */
- val &= ~BIT(21); /* GPIO[21] := Out Enable */
- writel(val, MVEBU_GPIO0_BASE + 0x04);
- val = readl(MVEBU_GPIO1_BASE + 0x04);
- val &= ~BIT(6); /* GPIO[38] := Out Enable */
- val &= ~BIT(7); /* GPIO[39] := Out Enable */
- val &= ~BIT(8); /* GPIO[40] := Out Enable */
- val &= ~BIT(9); /* GPIO[41] := Out Enable */
- writel(val, MVEBU_GPIO1_BASE + 0x04);
- /* Release switch reset */
- ctrl[0] = EXT_CTL_nRES_LAN;
- ctrl[1] = EXT_CTL_nRES_LAN;
- err = omnia_mcu_write(CMD_EXT_CONTROL, ctrl, sizeof(ctrl));
- mdelay(10);
- /* Change RGMII pins back to RGMII mode */
- writel(val04, MVEBU_MPP_BASE + 0x04);
- writel(val08, MVEBU_MPP_BASE + 0x08);
- writel(val10, MVEBU_MPP_BASE + 0x10);
- writel(val14, MVEBU_MPP_BASE + 0x14);
- puts(err ? "failed\n" : "done\n");
- int board_early_init_f(void) { /* Configure MPP */
- u16 val;
- int ret;
- If booting from UART, disable MCU watchdog in SPL, since uploading
- U-Boot proper can take too much time and trigger it. Instead enable
u32 flags)
- fdt32_t val[4] = { cpu_to_fdt32(phandle), cpu_to_fdt32(bank),
- return fdt_setprop(blob, node, prop, &val, sizeof(val));
- unsigned int mcu_phandle;
- int port, gpio;
- int pcie_node;
- int port_node;
- int ret;
- ret = fdt_increase_size(blob, 128);
- if (ret < 0) {
return ret;
- mcu_phandle = fdt_create_phandle_by_compatible(blob, "cznic,turris-omnia-mcu");
- if (!mcu_phandle)
- fdt_for_each_node_by_compatible(pcie_node, blob, -1, "marvell,armada-370-pcie") {
continue;
continue;
if (port == 0)
else if (port == 1)
else if (port == 2)
else
continue;
if (ret < 0)
return ret;
- int eth_wan_node;
- int ret;
- ret = fdt_increase_size(blob, 64);
- if (ret < 0) {
return ret;
- eth_wan_node = fdt_path_offset(blob, "ethernet2");
- if (eth_wan_node < 0)
- if (!mcu_phandle)
- /* insert: phy-reset-gpios = <&mcu 2 gpio GPIO_ACTIVE_LOW>; */
- ret = insert_mcu_gpio_prop(blob, eth_wan_node, "phy-reset-gpios",
- if (ret < 0)
return ret;
#endif
u16 val;
int ret;
- int node;
- node = fdt_path_offset(gd->fdt_blob, "ethernet2");
- if (node >= 0 && fdt_getprop(gd->fdt_blob, node, "phy-reset-gpios", NULL)) {
- fixup_spi_nor_partitions(blob); fixup_msata_port_nodes(blob); fixup_wwan_port_nodes(blob);
Viele Grüße, Stefan Roese
This SW setup is required as this is the only way how Marvell switch 88E6176 (Agate) can be configured. 88E6176 shares RGMII pins with bootstrap pins. This is how Marvell designed this switch chip. In previous board revisions 88E6176 setup was done in board reset procedure by HW. In new board revision it is not by HW anymore.
Function initialize_switch() could be written differently, e.g. by using U-Boot DM pinmux and GPIO APIs. But code would be larger (= slow UART booting) and because this function is called from SPL, it would require to adjust that DM code to fit into SPL memory and sizing limits... So easier is to touch A385 GPIO registers directly as it require relocations, DM usage and other stuff...
For other DT properties. Other option could be to include two DTS files for Omnia and via some runtime u-boot hooks choose the correct DTS file. And then there would be option question how to boot kernel correctly. So DTS patching (which is already used in this board code) seems to be easier and more robust solution and it allows to boot original kernel/DTB binaries.
Thanks, Stefan
diff --git a/board/CZ.NIC/turris_omnia/turris_omnia.c b/board/CZ.NIC/turris_omnia/turris_omnia.c index 6fc2018c1cfb..e262ea1aba51 100644 --- a/board/CZ.NIC/turris_omnia/turris_omnia.c +++ b/board/CZ.NIC/turris_omnia/turris_omnia.c @@ -19,9 +19,11 @@ #include <asm/arch/cpu.h> #include <asm/arch/soc.h> #include <dm/uclass.h> +#include <dt-bindings/gpio/gpio.h> #include <fdt_support.h> #include <time.h> #include <linux/bitops.h> +#include <linux/delay.h> #include <u-boot/crc.h> #include "../drivers/ddr/marvell/a38x/ddr3_init.h" @@ -65,6 +67,9 @@ enum mcu_commands { /* available if STS_FEATURES_SUPPORTED bit set in status word */ CMD_GET_FEATURES = 0x10,
- /* available if EXT_CMD bit set in features */
- CMD_EXT_CONTROL = 0x12, }; enum status_word_bits {
- EXT_CTL_nRES_LAN = BIT(1),
- EXT_CTL_nRES_PHY = BIT(2),
- EXT_CTL_nPERST0 = BIT(3),
- EXT_CTL_nPERST1 = BIT(4),
- EXT_CTL_nPERST2 = BIT(5), }; /*
@@ -543,6 +558,90 @@ static void handle_reset_button(void) } } +static void initialize_switch(void) +{
- u16 ctrl[2];
- int err;
- mdelay(10);
@@ -572,6 +671,9 @@ int board_early_init_f(void) void spl_board_init(void) {
- u16 val;
- int ret;
- ret = omnia_mcu_read(CMD_GET_STATUS_WORD, &val, sizeof(val));
- if (ret == 0 && (val & STS_FEATURES_SUPPORTED)) {
- } } #if IS_ENABLED(CONFIG_OF_BOARD_FIXUP) || IS_ENABLED(CONFIG_OF_BOARD_SETUP)
@@ -689,11 +804,109 @@ static void fixup_wwan_port_nodes(void *blob) disable_pcie_node(blob, 2); } +static int insert_mcu_gpio_prop(void *blob, int node, const char *prop,
u32 flags)
- int port, gpio;
- int pcie_node;
- int port_node;
- int ret;
- if (ret < 0) {
return ret;
- if (!mcu_phandle)
continue;
continue;
if (port == 0)
else if (port == 1)
else if (port == 2)
else
continue;
if (ret < 0)
return ret;
- int eth_wan_node;
- int ret;
- if (ret < 0) {
return ret;
- if (!mcu_phandle)
- if (ret < 0)
return ret;
- #endif #if IS_ENABLED(CONFIG_OF_BOARD_FIXUP) int board_fix_fdt(void *blob) {
- u16 val;
- int ret;
- fixup_msata_port_nodes(blob); fixup_wwan_port_nodes(blob);
@@ -840,6 +1053,19 @@ fail: int ft_board_setup(void *blob, struct bd_info *bd) {
- int node;
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-51 Fax: (+49)-8142-66989-80 Email: sr@denx.de
Reviewed-by: Marek Behún kabel@kernel.org
Applied to u-boot-marvell/master
Thanks, Stefan
- u16 ctrl[2];
- int err;
- mdelay(10);
- u16 val;
- int ret;
u32 flags)
- int port, gpio;
- int pcie_node;
- int port_node;
- int ret;
- if (ret < 0) {
return ret;
- if (!mcu_phandle)
continue;
continue;
if (port == 0)
else if (port == 1)
else if (port == 2)
else
continue;
if (ret < 0)
return ret;
- int eth_wan_node;
- int ret;
- if (ret < 0) {
return ret;
- if (!mcu_phandle)
- if (ret < 0)
return ret;
#endif
u16 val;
int ret;
- int node;
Thanks, Stefan
- FEAT_PERIPH_MCU = BIT(0),
- Those values and defines are taken from the Marvell U-Boot version
- "u-boot-2013.01-2014_T3.0"
- static const char * const mcu_types[] = {
- static const char * const mcu_types_with_perip_resets[] = {
- u16 stsword, features;
- int ret;
- ret = omnia_mcu_read(CMD_GET_STATUS_WORD, &stsword, sizeof(stsword));
- if (ret)
return "unknown";
- if (stsword & STS_FEATURES_SUPPORTED) {
- return mcu_types[stsword & STS_MCU_TYPE_MASK];
- Define the DDR layout / topology here in the board file. This will
- be used by the DDR3 init code in the SPL U-Boot version to configure
- printf(" MCU type: %s\n", omnia_get_mcu_type()); printf(" RAM size: %i MiB\n", omnia_get_ram_size_gb() * 1024); if (err) printf(" Serial Number: unknown\n");
Thanks, Stefan
- int ret;
- if (ret)
return "unknown";
Marek Behún
Pali Rohár
Stefan Roese
