[PATCH] tools: relocate-rela: Fix ELF decoding on big-endian hosts
The new ELF decoding logic assumed that the target binary has the same endianness as the host, which broke building ARM64 firmware binaries on big-endian machines.
This commit fixes the ELF64 decoding to be host-endianness-neutral, and applies the same changes to the ELF32 decoding. It does not fix the microblaze-specific dynamic symbol decoding.
It also corrects the functions used for byte swapping in rela_elf64() and rela_elf32(). The result is the same, but semantically the code is converting bytes read from a foreign-endianness file to host byte order.
Fixes: 4c9e2d643460 ("tools: relocate-rela: Read rela start/end directly from ELF") Fixes: a1405d9cfedb ("tools: relocate-rela: Check that relocation works only for EM_AARCH64") Signed-off-by: Samuel Holland samuel@sholland.org ---
tools/relocate-rela.c | 125 +++++++++++++++++++++++------------------- 1 file changed, 68 insertions(+), 57 deletions(-)
diff --git a/tools/relocate-rela.c b/tools/relocate-rela.c index 090fb1acb20c..fcf3fb201f07 100644 --- a/tools/relocate-rela.c +++ b/tools/relocate-rela.c @@ -60,7 +60,9 @@ static int decode_elf64(FILE *felf, char **argv) { size_t size; Elf64_Ehdr header; - uint64_t section_header_base, section_header_size, sh_offset, sh_size; + uint64_t section_header_base, section_header_size; + uint64_t sh_addr, sh_offset, sh_size; + Elf64_Half sh_index, sh_num; Elf64_Shdr *sh_table; /* Elf symbol table */ int ret, i, machine; char *sh_str; @@ -76,7 +78,7 @@ static int decode_elf64(FILE *felf, char **argv) return 25; }
- machine = header.e_machine; + machine = le16_to_cpu(header.e_machine); debug("Machine\t%d\n", machine);
if (machine != EM_AARCH64) { @@ -84,9 +86,10 @@ static int decode_elf64(FILE *felf, char **argv) return 30; }
- text_base = header.e_entry; - section_header_base = header.e_shoff; - section_header_size = header.e_shentsize * header.e_shnum; + text_base = le64_to_cpu(header.e_entry); + section_header_base = le64_to_cpu(header.e_shoff); + section_header_size = le16_to_cpu(header.e_shentsize) * + le16_to_cpu(header.e_shnum);
sh_table = malloc(section_header_size); if (!sh_table) { @@ -114,9 +117,9 @@ static int decode_elf64(FILE *felf, char **argv) return 27; }
- sh_size = sh_table[header.e_shstrndx].sh_size; - debug("e_shstrndx\t0x%08x\n", header.e_shstrndx); - debug("sh_size\t\t0x%08lx\n", sh_size); + sh_index = le16_to_cpu(header.e_shstrndx); + sh_size = le64_to_cpu(sh_table[sh_index].sh_size); + debug("e_shstrndx %x, sh_size %lx\n", sh_index, sh_size);
sh_str = malloc(sh_size); if (!sh_str) { @@ -130,9 +133,8 @@ static int decode_elf64(FILE *felf, char **argv) * Specifies the byte offset from the beginning of the file * to the first byte in the section. */ - sh_offset = sh_table[header.e_shstrndx].sh_offset; - - debug("sh_offset\t0x%08x\n", header.e_shnum); + sh_offset = le64_to_cpu(sh_table[sh_index].sh_offset); + sh_num = le16_to_cpu(header.e_shnum);
ret = fseek(felf, sh_offset, SEEK_SET); if (ret) { @@ -153,18 +155,22 @@ static int decode_elf64(FILE *felf, char **argv) return 30; }
- for (i = 0; i < header.e_shnum; i++) { - /* fprintf(stderr, "%s\n", sh_str + sh_table[i].sh_name); Debug only */ - if (!strcmp(".rela.dyn", (sh_str + sh_table[i].sh_name))) { + for (i = 0; i < sh_num; i++) { + char *sh_name = sh_str + le32_to_cpu(sh_table[i].sh_name); + + debug("%s\n", sh_name); + + sh_addr = le64_to_cpu(sh_table[i].sh_addr); + sh_offset = le64_to_cpu(sh_table[i].sh_offset); + sh_size = le64_to_cpu(sh_table[i].sh_size); + + if (!strcmp(".rela.dyn", sh_name)) { debug("Found section\t".rela_dyn"\n"); - debug(" at addr\t0x%08x\n", - (unsigned int)sh_table[i].sh_addr); - debug(" at offset\t0x%08x\n", - (unsigned int)sh_table[i].sh_offset); - debug(" of size\t0x%08x\n", - (unsigned int)sh_table[i].sh_size); - rela_start = sh_table[i].sh_addr; - rela_end = rela_start + sh_table[i].sh_size; + debug(" at addr\t0x%08x\n", sh_addr); + debug(" at offset\t0x%08x\n", sh_offset); + debug(" of size\t0x%08x\n", sh_size); + rela_start = sh_addr; + rela_end = rela_start + sh_size; break; } } @@ -188,7 +194,9 @@ static int decode_elf32(FILE *felf, char **argv) { size_t size; Elf32_Ehdr header; - uint64_t section_header_base, section_header_size, sh_offset, sh_size; + uint64_t section_header_base, section_header_size; + uint32_t sh_addr, sh_offset, sh_size; + Elf32_Half sh_index, sh_num; Elf32_Shdr *sh_table; /* Elf symbol table */ int ret, i, machine; char *sh_str; @@ -204,7 +212,7 @@ static int decode_elf32(FILE *felf, char **argv) return 25; }
- machine = header.e_machine; + machine = le16_to_cpu(header.e_machine); debug("Machine %d\n", machine);
if (machine != EM_MICROBLAZE) { @@ -212,14 +220,10 @@ static int decode_elf32(FILE *felf, char **argv) return 30; }
- text_base = header.e_entry; - section_header_base = header.e_shoff; - - debug("Section header base %x\n", section_header_base); - - section_header_size = header.e_shentsize * header.e_shnum; - - debug("Section header size %d\n", section_header_size); + text_base = le32_to_cpu(header.e_entry); + section_header_base = le32_to_cpu(header.e_shoff); + section_header_size = le16_to_cpu(header.e_shentsize) * + le16_to_cpu(header.e_shnum);
sh_table = malloc(section_header_size); if (!sh_table) { @@ -247,8 +251,9 @@ static int decode_elf32(FILE *felf, char **argv) return 27; }
- sh_size = sh_table[header.e_shstrndx].sh_size; - debug("e_shstrndx %x, sh_size %lx\n", header.e_shstrndx, sh_size); + sh_index = le16_to_cpu(header.e_shstrndx); + sh_size = le32_to_cpu(sh_table[sh_index].sh_size); + debug("e_shstrndx %x, sh_size %lx\n", sh_index, sh_size);
sh_str = malloc(sh_size); if (!sh_str) { @@ -262,9 +267,8 @@ static int decode_elf32(FILE *felf, char **argv) * Specifies the byte offset from the beginning of the file * to the first byte in the section. */ - sh_offset = sh_table[header.e_shstrndx].sh_offset; - - debug("sh_offset %x\n", header.e_shnum); + sh_offset = le32_to_cpu(sh_table[sh_index].sh_offset); + sh_num = le16_to_cpu(header.e_shnum);
ret = fseek(felf, sh_offset, SEEK_SET); if (ret) { @@ -277,7 +281,7 @@ static int decode_elf32(FILE *felf, char **argv)
size = fread(sh_str, 1, sh_size, felf); if (size != sh_size) { - fprintf(stderr, "%s: Can't read section: %lx/%lx\n", + fprintf(stderr, "%s: Can't read section: %lx/%x\n", argv[0], size, sh_size); free(sh_str); free(sh_table); @@ -285,22 +289,29 @@ static int decode_elf32(FILE *felf, char **argv) return 30; }
- for (i = 0; i < header.e_shnum; i++) { - debug("%s\n", sh_str + sh_table[i].sh_name); - if (!strcmp(".rela.dyn", (sh_str + sh_table[i].sh_name))) { + for (i = 0; i < sh_num; i++) { + char *sh_name = sh_str + le32_to_cpu(sh_table[i].sh_name); + + debug("%s\n", sh_name); + + sh_addr = le64_to_cpu(sh_table[i].sh_addr); + sh_offset = le64_to_cpu(sh_table[i].sh_offset); + sh_size = le64_to_cpu(sh_table[i].sh_size); + + if (!strcmp(".rela.dyn", sh_name)) { debug("Found section\t".rela_dyn"\n"); - debug(" at addr\t0x%08x\n", (unsigned int)sh_table[i].sh_addr); - debug(" at offset\t0x%08x\n", (unsigned int)sh_table[i].sh_offset); - debug(" of size\t0x%08x\n", (unsigned int)sh_table[i].sh_size); - rela_start = sh_table[i].sh_addr; - rela_end = rela_start + sh_table[i].sh_size; + debug(" at addr\t0x%08x\n", sh_addr); + debug(" at offset\t0x%08x\n", sh_offset); + debug(" of size\t0x%08x\n", sh_size); + rela_start = sh_addr; + rela_end = rela_start + sh_size; } - if (!strcmp(".dynsym", (sh_str + sh_table[i].sh_name))) { + if (!strcmp(".dynsym", sh_name)) { debug("Found section\t".dynsym"\n"); - debug(" at addr\t0x%08x\n", (unsigned int)sh_table[i].sh_addr); - debug(" at offset\t0x%08x\n", (unsigned int)sh_table[i].sh_offset); - debug(" of size\t0x%08x\n", (unsigned int)sh_table[i].sh_size); - dyn_start = sh_table[i].sh_addr; + debug(" at addr\t0x%08x\n", sh_addr); + debug(" at offset\t0x%08x\n", sh_offset); + debug(" of size\t0x%08x\n", sh_size); + dyn_start = sh_addr; } }
@@ -386,9 +397,9 @@ static int rela_elf64(char **argv, FILE *f) return 4; }
- swrela.r_offset = cpu_to_le64(rela.r_offset); - swrela.r_info = cpu_to_le64(rela.r_info); - swrela.r_addend = cpu_to_le64(rela.r_addend); + swrela.r_offset = le64_to_cpu(rela.r_offset); + swrela.r_info = le64_to_cpu(rela.r_info); + swrela.r_addend = le64_to_cpu(rela.r_addend);
if (!supported_rela(&swrela)) continue; @@ -487,9 +498,9 @@ static int rela_elf32(char **argv, FILE *f) PRIu32 " r_addend:\t%" PRIx32 "\n", rela.r_offset, rela.r_info, rela.r_addend);
- swrela.r_offset = cpu_to_le32(rela.r_offset); - swrela.r_info = cpu_to_le32(rela.r_info); - swrela.r_addend = cpu_to_le32(rela.r_addend); + swrela.r_offset = le32_to_cpu(rela.r_offset); + swrela.r_info = le32_to_cpu(rela.r_info); + swrela.r_addend = le32_to_cpu(rela.r_addend);
debug("SWRela:\toffset:\t%" PRIx32 " r_info:\t%" PRIu32 " r_addend:\t%" PRIx32 "\n",
- uint64_t section_header_base, section_header_size;
- uint64_t sh_addr, sh_offset, sh_size;
- Elf64_Half sh_index, sh_num; Elf64_Shdr *sh_table; /* Elf symbol table */ int ret, i, machine; char *sh_str;
- for (i = 0; i < sh_num; i++) {
nit: We could move this below sh_name checking but that's fine.
if (!strcmp(".rela.dyn", sh_name)) { debug("Found section\t\".rela_dyn\"\n");
} }rela_end = rela_start + sh_size; break;
- uint32_t sh_addr, sh_offset, sh_size;
- Elf32_Half sh_index, sh_num; Elf32_Shdr *sh_table; /* Elf symbol table */ int ret, i, machine; char *sh_str;
free(sh_str); free(sh_table);fprintf(stderr, "%s: Can't read section: %lx/%x\n", argv[0], size, sh_size);
if (!strcmp(".dynsym", sh_name)) { debug("Found section\t\".dynsym\"\n");
} }dyn_start = sh_addr;
I have tested it on arm64 and also microblaze and it works fine.
Applied. M
Michal Simek
Samuel Holland
