[U-Boot] [PATCH] armv8: fsl-layerscape: properly configure qdma ICID
The ICIDs for the qdma device are not configured through SCFG but through some registers found in the actual device register block.
Signed-off-by: Laurentiu Tudor laurentiu.tudor@nxp.com --- arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h | 6 +++++- arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h | 1 + 2 files changed, 6 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h index a3f473fe28..f375fe7115 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h @@ -55,7 +55,11 @@ void fdt_fixup_icid(void *blob); CONFIG_SYS_FSL_ESDHC_ADDR)
#define SET_QDMA_ICID(compat, streamid) \ - SET_SCFG_ICID(compat, streamid, dma_icid,\ + SET_ICID_ENTRY(compat, streamid, (1 << 31) | (streamid), \ + QDMA_BASE_ADDR + QMAN_CQSIDR_REG, \ + QDMA_BASE_ADDR), \ + SET_ICID_ENTRY(NULL, streamid, (1 << 31) | (streamid), \ + QDMA_BASE_ADDR + QMAN_CQSIDR_REG + 4, \ QDMA_BASE_ADDR)
#define SET_EDMA_ICID(streamid) \ diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index 4d0f16f21c..b4b7c3492e 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -94,6 +94,7 @@ #define AHCI_BASE_ADDR (CONFIG_SYS_IMMR + 0x02200000)
#define QDMA_BASE_ADDR (CONFIG_SYS_IMMR + 0x07380000) +#define QMAN_CQSIDR_REG 0x20a80
#define CONFIG_SYS_PCIE1_PHYS_ADDR 0x4000000000ULL #define CONFIG_SYS_PCIE2_PHYS_ADDR 0x4800000000ULL
Applied to fsl-qoriq master, awaiting upstream. Thanks.
York
York Sun
