[PATCH v2 1/4] cmd: bind: Add unbind command with driver filter
Extend the driver core to perform lookup by both OF node and driver bound to the node. Use this to look up specific device instances to unbind from nodes in the unbind command. One example where this is needed is USB peripheral controller, which may have multiple gadget drivers bound to it. The unbind command has to select that specific gadget driver instance to unbind from the controller, not unbind the controller driver itself from the controller.
USB ethernet gadget usage looks as follows with this change. Notice the extra 'usb_ether' addition in the 'unbind' command at the end. " bind /soc/usb-otg@49000000 usb_ether setenv ethact usb_ether setenv loadaddr 0xc2000000 setenv ipaddr 10.0.0.2 setenv serverip 10.0.0.1 setenv netmask 255.255.255.0 tftpboot 0xc2000000 10.0.0.1:test.file unbind /soc/usb-otg@49000000 usb_ether "
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Kevin Hilman khilman@baylibre.com Cc: Lukasz Majewski lukma@denx.de Cc: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org --- V2: No change --- cmd/bind.c | 10 +++++----- drivers/core/device.c | 20 +++++++++++++++----- include/dm/device.h | 17 +++++++++++++++++ 3 files changed, 37 insertions(+), 10 deletions(-)
diff --git a/cmd/bind.c b/cmd/bind.c index 4d1b7885e60..3137cdf6cb5 100644 --- a/cmd/bind.c +++ b/cmd/bind.c @@ -162,7 +162,7 @@ static int bind_by_node_path(const char *path, const char *drv_name) return 0; }
-static int unbind_by_node_path(const char *path) +static int unbind_by_node_path(const char *path, const char *drv_name) { struct udevice *dev; int ret; @@ -174,7 +174,7 @@ static int unbind_by_node_path(const char *path) return -EINVAL; }
- ret = device_find_global_by_ofnode(ofnode, &dev); + ret = device_find_global_by_ofnode_driver(ofnode, drv_name, &dev);
if (!dev || ret) { printf("Cannot find a device with path %s\n", path); @@ -214,9 +214,9 @@ static int do_bind_unbind(struct cmd_tbl *cmdtp, int flag, int argc, return CMD_RET_USAGE; ret = bind_by_node_path(argv[1], argv[2]); } else if (by_node && !bind) { - if (argc != 2) + if (argc != 2 && argc != 3) return CMD_RET_USAGE; - ret = unbind_by_node_path(argv[1]); + ret = unbind_by_node_path(argv[1], argv[2]); } else if (!by_node && bind) { int index = (argc > 2) ? dectoul(argv[2], NULL) : 0;
@@ -251,7 +251,7 @@ U_BOOT_CMD( U_BOOT_CMD( unbind, 4, 0, do_bind_unbind, "Unbind a device from a driver", - "<node path>\n" + "<node path> [<driver>]\n" "unbind <class> <index>\n" "unbind <class> <index> <driver>\n" ); diff --git a/drivers/core/device.c b/drivers/core/device.c index 6e26b64fb81..52fceb69341 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -877,15 +877,17 @@ int device_get_child_by_of_offset(const struct udevice *parent, int node, }
static struct udevice *_device_find_global_by_ofnode(struct udevice *parent, - ofnode ofnode) + ofnode ofnode, + const char *drv) { struct udevice *dev, *found;
- if (ofnode_equal(dev_ofnode(parent), ofnode)) + if (ofnode_equal(dev_ofnode(parent), ofnode) && + (!drv || (drv && !strcmp(parent->driver->name, drv)))) return parent;
device_foreach_child(dev, parent) { - found = _device_find_global_by_ofnode(dev, ofnode); + found = _device_find_global_by_ofnode(dev, ofnode, drv); if (found) return found; } @@ -895,7 +897,15 @@ static struct udevice *_device_find_global_by_ofnode(struct udevice *parent,
int device_find_global_by_ofnode(ofnode ofnode, struct udevice **devp) { - *devp = _device_find_global_by_ofnode(gd->dm_root, ofnode); + *devp = _device_find_global_by_ofnode(gd->dm_root, ofnode, NULL); + + return *devp ? 0 : -ENOENT; +} + +int device_find_global_by_ofnode_driver(ofnode ofnode, const char *drv, + struct udevice **devp) +{ + *devp = _device_find_global_by_ofnode(gd->dm_root, ofnode, drv);
return *devp ? 0 : -ENOENT; } @@ -904,7 +914,7 @@ int device_get_global_by_ofnode(ofnode ofnode, struct udevice **devp) { struct udevice *dev;
- dev = _device_find_global_by_ofnode(gd->dm_root, ofnode); + dev = _device_find_global_by_ofnode(gd->dm_root, ofnode, NULL); return device_get_device_tail(dev, dev ? 0 : -ENOENT, devp); }
diff --git a/include/dm/device.h b/include/dm/device.h index b86bf90609b..5f05ae0924f 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -748,6 +748,23 @@ int device_get_child_by_of_offset(const struct udevice *parent, int of_offset,
int device_find_global_by_ofnode(ofnode node, struct udevice **devp);
+/** + * device_find_global_by_ofnode_driver() - Get a device based on ofnode and driver + * + * Locates a device by its device tree ofnode and driver currently bound to + * it, searching globally throughout the all driver model devices. + * + * The device is NOT probed + * + * @node: Device tree ofnode to find + * @drv: Driver name bound to device + * @devp: Returns pointer to device if found, otherwise this is set to NULL + * Return: 0 if OK, -ve on error + */ + +int device_find_global_by_ofnode_driver(ofnode node, const char *drv, + struct udevice **devp); + /** * device_get_global_by_ofnode() - Get a device based on ofnode *
These functions here are only ever called once since drop of non-DM networking code. Inline them. No functional change.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Kevin Hilman khilman@baylibre.com Cc: Lukasz Majewski lukma@denx.de Cc: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org --- V2: No change --- drivers/usb/gadget/ether.c | 48 +++++++------------------------------- 1 file changed, 9 insertions(+), 39 deletions(-)
diff --git a/drivers/usb/gadget/ether.c b/drivers/usb/gadget/ether.c index 85c971e4c43..88c656c4dc0 100644 --- a/drivers/usb/gadget/ether.c +++ b/drivers/usb/gadget/ether.c @@ -2273,10 +2273,11 @@ fail: }
/*-------------------------------------------------------------------------*/ -static void _usb_eth_halt(struct ether_priv *priv); +static void usb_eth_stop(struct udevice *dev);
-static int _usb_eth_init(struct ether_priv *priv) +static int usb_eth_start(struct udevice *udev) { + struct ether_priv *priv = dev_get_priv(udev); struct eth_dev *dev = &priv->ethdev; struct usb_gadget *gadget; unsigned long ts; @@ -2347,12 +2348,13 @@ static int _usb_eth_init(struct ether_priv *priv) rx_submit(dev, dev->rx_req, 0); return 0; fail: - _usb_eth_halt(priv); + usb_eth_stop(udev); return -1; }
-static int _usb_eth_send(struct ether_priv *priv, void *packet, int length) +static int usb_eth_send(struct udevice *udev, void *packet, int length) { + struct ether_priv *priv = dev_get_priv(udev); int retval; void *rndis_pkt = NULL; struct eth_dev *dev = &priv->ethdev; @@ -2419,15 +2421,9 @@ drop: return -ENOMEM; }
-static int _usb_eth_recv(struct ether_priv *priv) -{ - usb_gadget_handle_interrupts(0); - - return 0; -} - -static void _usb_eth_halt(struct ether_priv *priv) +static void usb_eth_stop(struct udevice *udev) { + struct ether_priv *priv = dev_get_priv(udev); struct eth_dev *dev = &priv->ethdev;
/* If the gadget not registered, simple return */ @@ -2459,31 +2455,12 @@ static void _usb_eth_halt(struct ether_priv *priv) usb_gadget_release(0); }
-static int usb_eth_start(struct udevice *dev) -{ - struct ether_priv *priv = dev_get_priv(dev); - - return _usb_eth_init(priv); -} - -static int usb_eth_send(struct udevice *dev, void *packet, int length) -{ - struct ether_priv *priv = dev_get_priv(dev); - - return _usb_eth_send(priv, packet, length); -} - static int usb_eth_recv(struct udevice *dev, int flags, uchar **packetp) { struct ether_priv *priv = dev_get_priv(dev); struct eth_dev *ethdev = &priv->ethdev; - int ret;
- ret = _usb_eth_recv(priv); - if (ret) { - pr_err("error packet receive\n"); - return ret; - } + usb_gadget_handle_interrupts(0);
if (packet_received) { if (ethdev->rx_req) { @@ -2509,13 +2486,6 @@ static int usb_eth_free_pkt(struct udevice *dev, uchar *packet, return rx_submit(ethdev, ethdev->rx_req, 0); }
-static void usb_eth_stop(struct udevice *dev) -{ - struct ether_priv *priv = dev_get_priv(dev); - - _usb_eth_halt(priv); -} - static int usb_eth_probe(struct udevice *dev) { struct ether_priv *priv = dev_get_priv(dev);
Move the driver probe function above the driver structure, so it can be placed alongside other related functions, like upcoming remove function. No functional change.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Kevin Hilman khilman@baylibre.com Cc: Lukasz Majewski lukma@denx.de Cc: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org --- V2: No change --- drivers/usb/gadget/ether.c | 28 ++++++++++++++-------------- 1 file changed, 14 insertions(+), 14 deletions(-)
diff --git a/drivers/usb/gadget/ether.c b/drivers/usb/gadget/ether.c index 88c656c4dc0..2040b5b5081 100644 --- a/drivers/usb/gadget/ether.c +++ b/drivers/usb/gadget/ether.c @@ -2486,20 +2486,6 @@ static int usb_eth_free_pkt(struct udevice *dev, uchar *packet, return rx_submit(ethdev, ethdev->rx_req, 0); }
-static int usb_eth_probe(struct udevice *dev) -{ - struct ether_priv *priv = dev_get_priv(dev); - struct eth_pdata *pdata = dev_get_plat(dev); - - priv->netdev = dev; - l_priv = priv; - - get_ether_addr(CONFIG_USBNET_DEV_ADDR, pdata->enetaddr); - eth_env_set_enetaddr("usbnet_devaddr", pdata->enetaddr); - - return 0; -} - static const struct eth_ops usb_eth_ops = { .start = usb_eth_start, .send = usb_eth_send, @@ -2528,6 +2514,20 @@ int usb_ether_init(void) return 0; }
+static int usb_eth_probe(struct udevice *dev) +{ + struct ether_priv *priv = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_plat(dev); + + priv->netdev = dev; + l_priv = priv; + + get_ether_addr(CONFIG_USBNET_DEV_ADDR, pdata->enetaddr); + eth_env_set_enetaddr("usbnet_devaddr", pdata->enetaddr); + + return 0; +} + U_BOOT_DRIVER(eth_usb) = { .name = "usb_ether", .id = UCLASS_ETH,
Move the ethernet gadget driver registration and removal from ethernet bind and unbind callbacks into driver DM probe and remove callbacks. This way, when the driver is bound, which is triggered deliberately using 'bind' command, the USB ethernet gadget driver is instantiated and bound to the matching UDC. In reverse, when the driver is unbound, which is again triggered deliberately using 'unbind' command, the USB ethernet gadget driver instance is removed.
Effectively, this now behaves like running either 'ums' or 'dfu' or any other commands utilizing USB gadget functionality.
This also drops use of usb_gadget_initialize()/usb_gadget_release(), which are helper functions implemented in the UDC uclass to bind and unbind UDC drivers to controllers from U-Boot command line. Those have no place in drivers.
Signed-off-by: Marek Vasut marex@denx.de --- NOTE: This must be thoroughly tested. --- Cc: Kevin Hilman khilman@baylibre.com Cc: Lukasz Majewski lukma@denx.de Cc: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org --- V2: Fix up return value handling in probe --- drivers/usb/gadget/ether.c | 87 +++++++++++++++++++------------------- 1 file changed, 43 insertions(+), 44 deletions(-)
diff --git a/drivers/usb/gadget/ether.c b/drivers/usb/gadget/ether.c index 2040b5b5081..9e1a45ad9df 100644 --- a/drivers/usb/gadget/ether.c +++ b/drivers/usb/gadget/ether.c @@ -2281,49 +2281,8 @@ static int usb_eth_start(struct udevice *udev) struct eth_dev *dev = &priv->ethdev; struct usb_gadget *gadget; unsigned long ts; - int ret; unsigned long timeout = USB_CONNECT_TIMEOUT;
- ret = usb_gadget_initialize(0); - if (ret) - return ret; - - /* Configure default mac-addresses for the USB ethernet device */ -#ifdef CONFIG_USBNET_DEV_ADDR - strlcpy(dev_addr, CONFIG_USBNET_DEV_ADDR, sizeof(dev_addr)); -#endif -#ifdef CONFIG_USBNET_HOST_ADDR - strlcpy(host_addr, CONFIG_USBNET_HOST_ADDR, sizeof(host_addr)); -#endif - /* Check if the user overruled the MAC addresses */ - if (env_get("usbnet_devaddr")) - strlcpy(dev_addr, env_get("usbnet_devaddr"), - sizeof(dev_addr)); - - if (env_get("usbnet_hostaddr")) - strlcpy(host_addr, env_get("usbnet_hostaddr"), - sizeof(host_addr)); - - if (!is_eth_addr_valid(dev_addr)) { - pr_err("Need valid 'usbnet_devaddr' to be set"); - goto fail; - } - if (!is_eth_addr_valid(host_addr)) { - pr_err("Need valid 'usbnet_hostaddr' to be set"); - goto fail; - } - - priv->eth_driver.speed = DEVSPEED; - priv->eth_driver.bind = eth_bind; - priv->eth_driver.unbind = eth_unbind; - priv->eth_driver.setup = eth_setup; - priv->eth_driver.reset = eth_disconnect; - priv->eth_driver.disconnect = eth_disconnect; - priv->eth_driver.suspend = eth_suspend; - priv->eth_driver.resume = eth_resume; - if (usb_gadget_register_driver(&priv->eth_driver) < 0) - goto fail; - dev->network_started = 0;
packet_received = 0; @@ -2450,9 +2409,6 @@ static void usb_eth_stop(struct udevice *udev) usb_gadget_handle_interrupts(0); dev->network_started = 0; } - - usb_gadget_unregister_driver(&priv->eth_driver); - usb_gadget_release(0); }
static int usb_eth_recv(struct udevice *dev, int flags, uchar **packetp) @@ -2525,6 +2481,48 @@ static int usb_eth_probe(struct udevice *dev) get_ether_addr(CONFIG_USBNET_DEV_ADDR, pdata->enetaddr); eth_env_set_enetaddr("usbnet_devaddr", pdata->enetaddr);
+ /* Configure default mac-addresses for the USB ethernet device */ +#ifdef CONFIG_USBNET_DEV_ADDR + strlcpy(dev_addr, CONFIG_USBNET_DEV_ADDR, sizeof(dev_addr)); +#endif +#ifdef CONFIG_USBNET_HOST_ADDR + strlcpy(host_addr, CONFIG_USBNET_HOST_ADDR, sizeof(host_addr)); +#endif + /* Check if the user overruled the MAC addresses */ + if (env_get("usbnet_devaddr")) + strlcpy(dev_addr, env_get("usbnet_devaddr"), + sizeof(dev_addr)); + + if (env_get("usbnet_hostaddr")) + strlcpy(host_addr, env_get("usbnet_hostaddr"), + sizeof(host_addr)); + + if (!is_eth_addr_valid(dev_addr)) { + pr_err("Need valid 'usbnet_devaddr' to be set"); + return -EINVAL; + } + if (!is_eth_addr_valid(host_addr)) { + pr_err("Need valid 'usbnet_hostaddr' to be set"); + return -EINVAL; + } + + priv->eth_driver.speed = DEVSPEED; + priv->eth_driver.bind = eth_bind; + priv->eth_driver.unbind = eth_unbind; + priv->eth_driver.setup = eth_setup; + priv->eth_driver.reset = eth_disconnect; + priv->eth_driver.disconnect = eth_disconnect; + priv->eth_driver.suspend = eth_suspend; + priv->eth_driver.resume = eth_resume; + return usb_gadget_register_driver(&priv->eth_driver); +} + +static int usb_eth_remove(struct udevice *dev) +{ + struct ether_priv *priv = dev_get_priv(dev); + + usb_gadget_unregister_driver(&priv->eth_driver); + return 0; }
@@ -2532,6 +2530,7 @@ U_BOOT_DRIVER(eth_usb) = { .name = "usb_ether", .id = UCLASS_ETH, .probe = usb_eth_probe, + .remove = usb_eth_remove, .ops = &usb_eth_ops, .priv_auto = sizeof(struct ether_priv), .plat_auto = sizeof(struct eth_pdata),
V2: No change
Can we have a test?
V2: No change
Can we have a test?
I added it into my todo queue.
Anything else or is the patch OK ?
Hi Marek,
V2: No change
Can we have a test?
That's my only comment.
V2: No change
Conceptually this seems fine to me. Simon?
Hi Marek,
marex@denx.de wrote on Mon, 17 Jul 2023 13:21:34 +0200:
I don't really get why this is needed? Yes, having proper bind and unbind methods and having them called internally is relevant, but when you have a single OTG controller, why is this needed? It basically breaks the CLI, making bisects more painful and all updates just fail.
I've tested the whole series, unfortunately is does not work on AM335x/BBBW:
* Any recovery attempted using the network will now fail in the SPL, where, AFAIK, there is no way to manually bind:
U-Boot SPL 2023.07-00806-gac80e6de9cf (Jul 23 2023 - 19:45:51 +0200) Trying to boot from USB eth Could not get PHY for eth_cpsw: addr 0 eth0: eth_cpswusing musb-hdrc, OUT ep1out IN ep1in STATUS ep2in MAC de:ad:be:ef:00:01 HOST MAC de:ad:be:ef:00:00 RNDIS ready , eth1: usb_ether
* The bind command was not available on my default configuration, making it even difficult for people unaware that this command is now required to fix their common commands.
* Any command that expects the usb_ether driver will now fail badly even after the bind call:
=> bind /ocp/usb@47400000/usb@47401000 usb_ether => fastboot usb 0 couldn't find an available UDC g_dnl_register: failed!, error: -19 exit not allowed from main input shell. => tftp 0x81000000 zImage dev_get_priv: null device data abort pc : [<9ffa04ba>] lr : [<9ff86d5f>] reloc pc : [<8083b4ba>] lr : [<80821d5f>] sp : 9df2f920 ip : 00000000 fp : 00000003 r10: 9df4cf48 r9 : 9df44ea0 r8 : 9ffec33c r7 : 00004a53 r6 : 00000000 r5 : 00000bb8 r4 : 9df4d3c0 r3 : 9ff97653 r2 : fff1102c r1 : 00000000 r0 : 00000000 Flags: nzcv IRQs off FIQs on Mode SVC_32 (T) Code: 9ffd b508 f7e6 fc4b (6801) 2000 Resetting CPU ...
Is there anything I missed?
Thanks, Miquèl
On 7/23/23 19:49, Miquel Raynal wrote:
Hi Marek,
Because you do need to bind the usb_ether driver to a controller.
I suspect you are trying to point in the direction of usb_ether_init() , right ? That is bogus and should be removed, because that is hard-coding one specific (ethernet) function to an OTG controller.
Can you elaborate on this ?
How does calling a 'bind' command breaks CLI ?
This is just utter nonsense, sorry.
- Any recovery attempted using the network will now fail in the SPL, where, AFAIK, there is no way to manually bind:
It seems the RNDIS adapter is actually ready based on the above ^ ?
- The bind command was not available on my default configuration, making it even difficult for people unaware that this command is now required to fix their common commands.
It has been required ever since, it's just that many ignored the need to move over to DM and depended on board-specific hackage to set up their USB ethernet. Now that hackage broke, time to switch to the proper way.
- Any command that expects the usb_ether driver will now fail badly even after the bind call:
You already have the ethernet function bound to the UDC and now you are trying to bind another function, fastboot, right ? This is likely the problem. Unbind the ethernet first, then use fastboot.
Please see above.
Hi Marek,
marex@denx.de wrote on Sun, 23 Jul 2023 23:45:55 +0200:
Hi Marek,
Right now it seems that binding is kind of performed in the context of a command execution (and then everything is cleaned up). I also think it is not optimal, but I would like to avoid breaking common commands like you propose. At the *very least* the error messages should be very clear about what has changed and what the user needs to do now in order to workaround it. But the best would be to avoid user interaction as much as possible. So why not load the first driver needed and expect the user the run the correct unbind/bind commands if it wants to change?
Well, hardcoding is bad, but setting a default is often useful and much more user friendly, IMHO.
I've attempted a bisect between U-Boot 2018 and 2023, it was already very painful. But if I try again in 2024 and need to cope with the new rules added in 2023 for binding drivers which were not needed until, then it becomes even more painful. So yes, it breaks the CLI. Before: => tftp xxx => fastboot xxx just worked, after you patchset these simple operations won't work anymore.
Well, I am a U-Boot user, and I expect this change to break a good amount of boot scripts after an update.
It breaks because there is something wrong elsewhere. It's not at all the fault of the board hack (if any, I have no idea, I'll trust your judgment regarding the BBB support). My series fixes a real problem in the current code. The fact that it won't be visible after your series is almost anecdotic... until it triggers again for whatever reason.
Please see above.
Sorry for disturbing you with the fastboot command. Can you advise a couple of commands to test fastboot then? I don't find the relevant driver name to use.
Here is a boot without anything else than a tftp, no change:
U-Boot SPL 2023.07-00806-gac80e6de9cf (Jul 23 2023 - 19:45:51 +0200) Trying to boot from MMC2
U-Boot 2023.07-00806-gac80e6de9cf (Jul 23 2023 - 19:45:51 +0200)
CPU : AM335X-GP rev 2.1 Model: TI AM335x BeagleBone Black DRAM: 512 MiB Core: 160 devices, 18 uclasses, devicetree: separate WDT: Started wdt@44e35000 with servicing every 1000ms (60s timeout) NAND: 0 MiB MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 Loading Environment from FAT... Unable to read "uboot.env" from mmc1:1... <ethaddr> not set. Validating first E-fuse MAC Net: Could not get PHY for ethernet@4a100000: addr 0 eth2: ethernet@4a100000using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in MAC de:ad:be:ef:00:01 HOST MAC de:ad:be:ef:00:00 RNDIS ready , eth3: usb_ether => bind /ocp/usb@47400000/usb@47401000 usb_ether => tftp 0x81000000 zImage dev_get_priv: null device data abort pc : [<9ffa04ba>] lr : [<9ff86d5f>] reloc pc : [<8083b4ba>] lr : [<80821d5f>] sp : 9df2f920 ip : 00000000 fp : 00000003 r10: 9df4cf48 r9 : 9df44ea0 r8 : 9ffec33c r7 : 0000538c r6 : 00000000 r5 : 00000bb8 r4 : 9df4d3c0 r3 : 9ff97653 r2 : fff69249 r1 : 00000000 r0 : 00000000 Flags: nzcv IRQs off FIQs on Mode SVC_32 (T) Code: 9ffd b508 f7e6 fc4b (6801) 2000 Resetting CPU ...
Thanks, Miquèl
On Sun, Jul 23, 2023 at 07:49:55PM +0200, Miquel Raynal wrote:
Hi Marek,
I think part of the issue here is how usb_ether didn't act like the rest of the gadget do, for example fastboot.
For testing, what happens if you disable CPSW? Does it both bind (as it shows here) and then use the expected device?
Yes, we'll need to make that default y if USB_ETHER.
Well, does it work if you do: bind /ocp/usb@47400000/usb@47401000 usb_ether tftp 0x81000000 zImage ?
Hi Tom,
trini@konsulko.com wrote on Mon, 24 Jul 2023 14:13:45 -0400:
Hi Marek,
It definitely is. "before it was working, now it does not anymore". That's the gut feeling many people get when the community breaks common habits. If we break something like this, we must at least be very clear on what is the new behavior.
Disabling CPSW breaks the link, I had to ensure ft_board_setup in the am335x arch folder was still available (and returned 0). But once I managed to start I did not observe any improvements.
U-Boot SPL 2023.07-00806-gac80e6de9cf-dirty (Jul 28 2023 - 14:49:48 +0200) Trying to boot from USB eth Could not get PHY for eth_cpsw: addr 0 eth0: eth_cpswusing musb-hdrc, OUT ep1out IN ep1in STATUS ep2in MAC de:ad:be:ef:00:01 HOST MAC de:ad:be:ef:00:00 RNDIS ready , eth1: usb_ether
Agreed.
No, I already tried both:
resetting ...
Thanks, Miquèl
On Fri, Jul 28, 2023 at 02:55:23PM +0200, Miquel Raynal wrote:
Hi Tom,
Hi Marek,
I'm not sure that in the end there will be a behavior change here, but the first step to figuring out if things do or don't automatically bind right in the end is to fix the MUSB problem (see below). Then we can worry if there's a real behavior change or not.
So it's just not working, is what we both observe, on this platform.
Agreed.
I had talked with Marek a bit on IRC as well and found that yes, there's some additional problem seemingly with MUSB. Perhaps you can debug what's going on here?
Miquel Raynal
