[U-Boot] [PATCH v3] arm64: Add SMC and HVC commands
This patch adds smc and hvc commands, that allow issuing Secure Monitor Calls and Hypervisor Calls conforming to the ARM SMC Calling Convention.
Add Kconfig items to allow each command can be individually enabled.
Signed-off-by: Michalis Pappas mpappas@fastmail.fm ---
cmd/Kconfig | 14 ++++++++++ cmd/Makefile | 2 ++ cmd/smccc.c | 72 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 88 insertions(+) create mode 100644 cmd/smccc.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index 136836d146..2176b98ccb 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1348,6 +1348,20 @@ config CMD_HASH saved to memory or to an environment variable. It is also possible to verify a hash against data in memory.
+config CMD_HVC + bool "Support the 'hvc' command" + depends on ARM_SMCCC + help + Allows issuing Hypervisor Calls (HVCs). Mostly useful for + development and testing. + +config CMD_SMC + bool "Support the 'smc' command" + depends on ARM_SMCCC + help + Allows issuing Secure Monitor Calls (SMCs). Mostly useful for + development and testing. + config HASH_VERIFY bool "hash -v" depends on CMD_HASH diff --git a/cmd/Makefile b/cmd/Makefile index 9a358e4801..5656a1a40a 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -61,6 +61,7 @@ obj-$(CONFIG_CMD_FS_GENERIC) += fs.o obj-$(CONFIG_CMD_FUSE) += fuse.o obj-$(CONFIG_CMD_GETTIME) += gettime.o obj-$(CONFIG_CMD_GPIO) += gpio.o +obj-$(CONFIG_CMD_HVC) += smccc.o obj-$(CONFIG_CMD_I2C) += i2c.o obj-$(CONFIG_CMD_IOTRACE) += iotrace.o obj-$(CONFIG_CMD_HASH) += hash.o @@ -113,6 +114,7 @@ obj-$(CONFIG_CMD_SHA1SUM) += sha1sum.o obj-$(CONFIG_CMD_SETEXPR) += setexpr.o obj-$(CONFIG_CMD_SPI) += spi.o obj-$(CONFIG_CMD_STRINGS) += strings.o +obj-$(CONFIG_CMD_SMC) += smccc.o obj-$(CONFIG_CMD_TERMINAL) += terminal.o obj-$(CONFIG_CMD_TIME) += time.o obj-$(CONFIG_CMD_TRACE) += trace.o diff --git a/cmd/smccc.c b/cmd/smccc.c new file mode 100644 index 0000000000..2fa7c23999 --- /dev/null +++ b/cmd/smccc.c @@ -0,0 +1,72 @@ +/* + * Copyright 2018 + * Michalis Pappas mpappas@fastmail.fm + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <asm/psci.h> +#include <common.h> +#include <command.h> +#include <linux/arm-smccc.h> +#include <linux/compiler.h> +#include <linux/psci.h> + +static int do_call(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + struct arm_smccc_res res; + + unsigned long fid; + + unsigned long a1; + unsigned long a2; + unsigned long a3; + unsigned long a4; + unsigned long a5; + unsigned long a6; + unsigned long a7; + + if (argc < 2) + return CMD_RET_USAGE; + + fid = simple_strtoul(argv[1], NULL, 16); + + a1 = argc > 2 ? simple_strtoul(argv[2], NULL, 16) : 0; + a2 = argc > 3 ? simple_strtoul(argv[3], NULL, 16) : 0; + a3 = argc > 4 ? simple_strtoul(argv[4], NULL, 16) : 0; + a4 = argc > 5 ? simple_strtoul(argv[5], NULL, 16) : 0; + a5 = argc > 6 ? simple_strtoul(argv[6], NULL, 16) : 0; + a6 = argc > 7 ? simple_strtoul(argv[7], NULL, 16) : 0; + a7 = argc > 8 ? simple_strtoul(argv[8], NULL, 16) : 0; + + if (!strcmp(argv[0], "smc")) + arm_smccc_smc(fid, a1, a2, a3, a4, a5, a6, a7, &res); + else + arm_smccc_hvc(fid, a1, a2, a3, a4, a5, a6, a7, &res); + + printf("Res: %ld %ld %ld %ld\n", res.a0, res.a1, res.a2, res.a3); + + return 0; +} + +#ifdef CONFIG_CMD_SMC +U_BOOT_CMD( + smc, 8, 2, do_call, + "Issue a Secure Monitor Call", + "<fid> [arg1 ... arg6] [id]\n" + " - fid Function ID\n" + " - arg SMC arguments, passed to X1-X6 (default to zero)\n" + " - id Secure OS ID / Session ID, passed to W7 (defaults to zero)\n" +); +#endif + +#ifdef CONFIG_CMD_HVC +U_BOOT_CMD( + hvc, 8, 2, do_call, + "Issue a Hypervisor Call", + "<fid> [arg1...arg7] [id]\n" + " - fid Function ID\n" + " - arg HVC arguments, passed to X1-X6 (default to zero)\n" + " - id Session ID, passed to W7 (defaults to zero)\n" +); +#endif + -- 2.17.0
But you need a change list
Okay, i see. The change is the replacement of the dependency of ARM64 to ARM_SMCCC in Kconfig.
If you think it's necessary to issue a v4 and document the changes properly please let me know and I'll do so.
Michalis
Yes please.
Michalis
Michalis Pappas
