[PATCH v4 0/3] board: toradex: add verdin am62 support
This series adds initial support for the Toradex Verdin AM62 SoM [1]. The first commit adds resp. PID4s to the ConfigBlock, the second one fixes an early clocking issue confirmed to be a weird bug in TI's scripting. And last but not least support for the Toradex Verdin AM62 is added.
[1] https://www.toradex.com/computer-on-modules/verdin-arm-family/ti-am62
Changes in v4: - Re-based on top of master with recent binman integration, mac_efuse, cpsw-phy-sel and mdio clean-up and dtsi bump from linux v6.5-rc1. - Verdin AM62 binman enablement and further clean-up after re-base. - Removed all ifdefs from DTs now with bumped Linux dtsi. - Avoid relocated U-Boot and DT reserved-memory clash. - Enable of_system_setup.
Changes in v3: - Add Verdin AM62 launch configuration SKUs as well. - Integrate our recent find of CTRL_SLEEP_MOCI# needing to be driven from A53 SPL as it may be used to control some power-rails on the carrier board. E.g. on the Yavia carrier board it is needed to power the I2C EEPROM on the carrier board. - Improve boot environment in R5 SPL vs. A53. - Integrate launch configuration SKUs to Wi-Fi handling. - Re-sync device trees from Linux kernel v6.5-rc1. - Add warning if memory is less than expected.
Changes in v2: - Add Bryan's reviewed-by tag. Thanks! - Use 1.2 GHz rather than 1.25 GHz A53 clock as on the EVM/SK. - Also add power-domain 166 as on the EVM/SK. - Get rid of main_bcdma and main_pktdma as not required in R5 SPL. - Get rid of all bootph-pre-ram in Ethernet and SDHC1 aka SD card related pinctrls as not required in any SPL. - Enable CONFIG_TI_SECURE_DEVICE by default as Non-HS devices will continue to boot due to runtime device type detection. - Disable FAT and SPI support as not required in R5 SPL. - Also enable CONFIG_SPL_MMC_HS200_SUPPORT in R5 SPL. - Enable CONFIG_LEGACY_IMAGE_FORMAT to allow sourcing unsigned script images e.g. like our current boot scripts. - Increase CONFIG_SYS_BOOTM_LEN to 64 MB to allow booting bigger compressed images as e.g. in the Toradex Easy Installer case. - Change memory configurations to operate at temperatures of up to 95 degrees celsius. - Increase CONFIG_SYS_MAXARGS from default 16 to 64. - Enable CONFIG_CMD_REMOTEPROC, CONFIG_SPL_DM_GPIO_LOOKUP_LABEL and CONFIG_SPL_I2C_EEPROM. - For R5 SPL increase CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN to 0x140000, enable CONFIG_SPL_I2C, CONFIG_DM_I2C and CONFIG_SYS_I2C_OMAP24XX and savedefconfig got rid of CONFIG_SPL_FIT_IMAGE_POST_PROCESS.
Marcel Ziswiler (3): toradex: tdx-cfg-block: add verdin am62 skus arm: mach-k3: am62: fix 2nd mux option of clkout0 board: toradex: add verdin am62 support
arch/arm/dts/Makefile | 4 +- arch/arm/dts/k3-am62-verdin-dev.dtsi | 192 ++ arch/arm/dts/k3-am62-verdin-wifi.dtsi | 39 + arch/arm/dts/k3-am62-verdin.dtsi | 1405 +++++++++++ .../dts/k3-am625-verdin-lpddr4-1600MTs.dtsi | 2190 +++++++++++++++++ arch/arm/dts/k3-am625-verdin-r5.dts | 116 + .../dts/k3-am625-verdin-wifi-dev-binman.dtsi | 570 +++++ .../dts/k3-am625-verdin-wifi-dev-u-boot.dtsi | 201 ++ arch/arm/dts/k3-am625-verdin-wifi-dev.dts | 22 + arch/arm/mach-k3/Kconfig | 1 + arch/arm/mach-k3/am62x/clk-data.c | 5 +- board/toradex/common/tdx-cfg-block.c | 7 + board/toradex/common/tdx-cfg-block.h | 10 +- board/toradex/verdin-am62/Kconfig | 82 + board/toradex/verdin-am62/MAINTAINERS | 17 + board/toradex/verdin-am62/Makefile | 6 + board/toradex/verdin-am62/board-cfg.yaml | 36 + board/toradex/verdin-am62/pm-cfg.yaml | 12 + board/toradex/verdin-am62/rm-cfg.yaml | 1088 ++++++++ board/toradex/verdin-am62/sec-cfg.yaml | 379 +++ board/toradex/verdin-am62/verdin-am62.c | 131 + configs/verdin-am62_a53_defconfig | 187 ++ configs/verdin-am62_r5_defconfig | 111 + doc/board/toradex/verdin-am62.rst | 169 ++ include/configs/verdin-am62.h | 55 + 25 files changed, 7030 insertions(+), 5 deletions(-) create mode 100644 arch/arm/dts/k3-am62-verdin-dev.dtsi create mode 100644 arch/arm/dts/k3-am62-verdin-wifi.dtsi create mode 100644 arch/arm/dts/k3-am62-verdin.dtsi create mode 100644 arch/arm/dts/k3-am625-verdin-lpddr4-1600MTs.dtsi create mode 100644 arch/arm/dts/k3-am625-verdin-r5.dts create mode 100644 arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi create mode 100644 arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi create mode 100644 arch/arm/dts/k3-am625-verdin-wifi-dev.dts create mode 100644 board/toradex/verdin-am62/Kconfig create mode 100644 board/toradex/verdin-am62/MAINTAINERS create mode 100644 board/toradex/verdin-am62/Makefile create mode 100644 board/toradex/verdin-am62/board-cfg.yaml create mode 100644 board/toradex/verdin-am62/pm-cfg.yaml create mode 100644 board/toradex/verdin-am62/rm-cfg.yaml create mode 100644 board/toradex/verdin-am62/sec-cfg.yaml create mode 100644 board/toradex/verdin-am62/verdin-am62.c create mode 100644 configs/verdin-am62_a53_defconfig create mode 100644 configs/verdin-am62_r5_defconfig create mode 100644 doc/board/toradex/verdin-am62.rst create mode 100644 include/configs/verdin-am62.h
Add initial Verdin AM62 Quad 1GB WB IT prototype and launch configuration SKUs to ConfigBlock handling.
0069: Verdin AM62 Quad 1GB WB IT 0071: Verdin AM62 Solo 512MB 0072: Verdin AM62 Solo 512MB WB IT 0073: Verdin AM62 Dual 1GB ET 0074: Verdin AM62 Dual 1GB IT 0075: Verdin AM62 Dual 1GB WB IT 0076: Verdin AM62 Quad 2GB WB IT
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Signed-off-by: Emanuele Ghidoli emanuele.ghidoli@toradex.com
(no changes since v3)
board/toradex/common/tdx-cfg-block.c | 7 +++++++ board/toradex/common/tdx-cfg-block.h | 10 ++++++++-- 2 files changed, 15 insertions(+), 2 deletions(-)
diff --git a/board/toradex/common/tdx-cfg-block.c b/board/toradex/common/tdx-cfg-block.c index e513f4a2919..8ad4907bfe4 100644 --- a/board/toradex/common/tdx-cfg-block.c +++ b/board/toradex/common/tdx-cfg-block.c @@ -139,7 +139,14 @@ const struct toradex_som toradex_modules[] = { [66] = { "Verdin iMX8M Plus Quad 8GB WB", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, [67] = { "Apalis iMX8QM 8GB WB IT", TARGET_IS_ENABLED(APALIS_IMX8) }, [68] = { "Verdin iMX8M Mini Quad 2GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, + [69] = { "Verdin AM62 Quad 1GB WB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, [70] = { "Verdin iMX8M Plus Quad 8GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, + [71] = { "Verdin AM62 Solo 512MB", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, + [72] = { "Verdin AM62 Solo 512MB WB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, + [73] = { "Verdin AM62 Dual 1GB ET", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, + [74] = { "Verdin AM62 Dual 1GB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, + [75] = { "Verdin AM62 Dual 1GB WB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, + [76] = { "Verdin AM62 Quad 2GB WB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, };
const char * const toradex_carrier_boards[] = { diff --git a/board/toradex/common/tdx-cfg-block.h b/board/toradex/common/tdx-cfg-block.h index 45fa04ca38a..5c204931a2d 100644 --- a/board/toradex/common/tdx-cfg-block.h +++ b/board/toradex/common/tdx-cfg-block.h @@ -94,8 +94,14 @@ enum { VERDIN_IMX8MPQ_8GB_WIFI_BT, APALIS_IMX8QM_8GB_WIFI_BT_IT, VERDIN_IMX8MMQ_WIFI_BT_IT_NO_CAN, - /* 69 */ - VERDIN_IMX8MPQ_8GB_WIFI_BT_IT = 70, /* 70 */ + VERDIN_AM62Q_WIFI_BT_IT, + VERDIN_IMX8MPQ_8GB_WIFI_BT_IT, /* 70 */ + VERDIN_AM62S_512MB, + VERDIN_AM62S_512MB_WIFI_BT_IT, + VERDIN_AM62D_1G_ET, + VERDIN_AM62D_1G_IT, + VERDIN_AM62D_1G_WIFI_BT_IT, /* 75 */ + VERDIN_AM62Q_2G_WIFI_BT_IT, };
enum {
Fix second mux option of clkout0 which should really be DEV_BOARD0_CLKOUT0_IN_PARENT_HSDIV4_16FFT_MAIN_2_HSDIVOUT1_CLK10 rather than twice the same according to [1].
[1] https://software-dl.ti.com/tisci/esd/latest/5_soc_doc/am62x/clocks.html#cloc...
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Reviewed-by: Bryan Brattlof bb@ti.com
(no changes since v2)
arch/arm/mach-k3/am62x/clk-data.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-k3/am62x/clk-data.c b/arch/arm/mach-k3/am62x/clk-data.c index c0881778fe7..d7bfed0e031 100644 --- a/arch/arm/mach-k3/am62x/clk-data.c +++ b/arch/arm/mach-k3/am62x/clk-data.c @@ -57,7 +57,7 @@ static const char * const sam62_pll_ctrl_wrap_mcu_0_sysclkout_clk_parents[] = {
static const char * const clkout0_ctrl_out0_parents[] = { "hsdiv4_16fft_main_2_hsdivout1_clk", - "hsdiv4_16fft_main_2_hsdivout1_clk", + "hsdiv4_16fft_main_2_hsdivout1_clk10", };
static const char * const clk_32k_rc_sel_out0_parents[] = { @@ -195,6 +195,7 @@ static const struct clk_data clk_list[] = { CLK_DIV("hsdiv4_16fft_main_1_hsdivout1_clk", "pllfracf_ssmod_16fft_main_1_foutvcop_clk", 0x681084, 0, 7, 0, 0), CLK_DIV("hsdiv4_16fft_main_1_hsdivout2_clk", "pllfracf_ssmod_16fft_main_1_foutvcop_clk", 0x681088, 0, 7, 0, 0), CLK_DIV("hsdiv4_16fft_main_2_hsdivout1_clk", "pllfracf_ssmod_16fft_main_2_foutvcop_clk", 0x682084, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_2_hsdivout1_clk10", "pllfracf_ssmod_16fft_main_2_foutvcop_clk", 0x682084, 0, 7, 0, 0), CLK_DIV("hsdiv4_16fft_main_2_hsdivout2_clk", "pllfracf_ssmod_16fft_main_2_foutvcop_clk", 0x682088, 0, 7, 0, 0), CLK_DIV("hsdiv4_16fft_mcu_0_hsdivout0_clk", "pllfracf_ssmod_16fft_mcu_0_foutvcop_clk", 0x4040080, 0, 7, 0, 0), CLK_MUX_PLLCTRL("sam62_pll_ctrl_wrap_main_0_sysclkout_clk", sam62_pll_ctrl_wrap_main_0_sysclkout_clk_parents, 2, 0x410000, 0), @@ -313,7 +314,7 @@ static const struct dev_clk soc_dev_clk_data[] = { DEV_CLK(146, 5, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), DEV_CLK(157, 20, "clkout0_ctrl_out0"), DEV_CLK(157, 21, "hsdiv4_16fft_main_2_hsdivout1_clk"), - DEV_CLK(157, 22, "hsdiv4_16fft_main_2_hsdivout1_clk"), + DEV_CLK(157, 22, "hsdiv4_16fft_main_2_hsdivout1_clk10"), DEV_CLK(157, 24, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), DEV_CLK(157, 25, "board_0_ddr0_ck0_out"), DEV_CLK(157, 40, "mshsi2c_main_0_porscl"),
This adds initial support for the Toradex Verdin AM62 Quad 1GB WB IT V1.0A module and subsequent V1.1 launch configuration SKUs. They are strapped to boot from their on-module eMMC. U-Boot supports booting from the on-module eMMC only, DFU support is disabled for now due to missing AM62x USB support.
Boot sequence is: SYSFW ---> R5 SPL (both in tiboot3.bin) ---> ATF (TF-A) ---> OP-TEE ---> A53 SPL (part of tispl.bin) ---> U-boot proper (u-boot.img)
Changes in v3: - Integrate our recent find of CTRL_SLEEP_MOCI# needing to be driven from A53 SPL as it may be used to control some power-rails on the carrier board. E.g. on the Yavia carrier board it is needed to power the I2C EEPROM on the carrier board. - Improve boot environment in R5 SPL vs. A53. - Integrate launch configuration SKUs to Wi-Fi handling. - Re-sync device trees from Linux kernel v6.5-rc1. - Add warning if memory is less than expected.
Changes in v2: - Use 1.2 GHz rather than 1.25 GHz A53 clock as on the EVM/SK. - Also add power-domain 166 as on the EVM/SK. - Get rid of main_bcdma and main_pktdma as not required in R5 SPL. - Get rid of all bootph-pre-ram in Ethernet and SDHC1 aka SD card related pinctrls as not required in any SPL. - Enable CONFIG_TI_SECURE_DEVICE by default as Non-HS devices will continue to boot due to runtime device type detection. - Disable FAT and SPI support as not required in R5 SPL. - Also enable CONFIG_SPL_MMC_HS200_SUPPORT in R5 SPL. - Enable CONFIG_LEGACY_IMAGE_FORMAT to allow sourcing unsigned script images e.g. like our current boot scripts. - Increase CONFIG_SYS_BOOTM_LEN to 64 MB to allow booting bigger compressed images as e.g. in the Toradex Easy Installer case. - Change memory configurations to operate at temperatures of up to 95 degrees celsius. - Increase CONFIG_SYS_MAXARGS from default 16 to 64. - Enable CONFIG_CMD_REMOTEPROC, CONFIG_SPL_DM_GPIO_LOOKUP_LABEL and CONFIG_SPL_I2C_EEPROM. - For R5 SPL increase CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN to 0x140000, enable CONFIG_SPL_I2C, CONFIG_DM_I2C and CONFIG_SYS_I2C_OMAP24XX and savedefconfig got rid of CONFIG_SPL_FIT_IMAGE_POST_PROCESS.
arch/arm/dts/Makefile | 4 +- arch/arm/dts/k3-am62-verdin-dev.dtsi | 192 ++ arch/arm/dts/k3-am62-verdin-wifi.dtsi | 39 + arch/arm/dts/k3-am62-verdin.dtsi | 1405 +++++++++++ .../dts/k3-am625-verdin-lpddr4-1600MTs.dtsi | 2190 +++++++++++++++++ arch/arm/dts/k3-am625-verdin-r5.dts | 116 + .../dts/k3-am625-verdin-wifi-dev-binman.dtsi | 570 +++++ .../dts/k3-am625-verdin-wifi-dev-u-boot.dtsi | 201 ++ arch/arm/dts/k3-am625-verdin-wifi-dev.dts | 22 + arch/arm/mach-k3/Kconfig | 1 + board/toradex/verdin-am62/Kconfig | 82 + board/toradex/verdin-am62/MAINTAINERS | 17 + board/toradex/verdin-am62/Makefile | 6 + board/toradex/verdin-am62/board-cfg.yaml | 36 + board/toradex/verdin-am62/pm-cfg.yaml | 12 + board/toradex/verdin-am62/rm-cfg.yaml | 1088 ++++++++ board/toradex/verdin-am62/sec-cfg.yaml | 379 +++ board/toradex/verdin-am62/verdin-am62.c | 131 + configs/verdin-am62_a53_defconfig | 187 ++ configs/verdin-am62_r5_defconfig | 111 + doc/board/toradex/verdin-am62.rst | 169 ++ include/configs/verdin-am62.h | 55 + 22 files changed, 7012 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/k3-am62-verdin-dev.dtsi create mode 100644 arch/arm/dts/k3-am62-verdin-wifi.dtsi create mode 100644 arch/arm/dts/k3-am62-verdin.dtsi create mode 100644 arch/arm/dts/k3-am625-verdin-lpddr4-1600MTs.dtsi create mode 100644 arch/arm/dts/k3-am625-verdin-r5.dts create mode 100644 arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi create mode 100644 arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi create mode 100644 arch/arm/dts/k3-am625-verdin-wifi-dev.dts create mode 100644 board/toradex/verdin-am62/Kconfig create mode 100644 board/toradex/verdin-am62/MAINTAINERS create mode 100644 board/toradex/verdin-am62/Makefile create mode 100644 board/toradex/verdin-am62/board-cfg.yaml create mode 100644 board/toradex/verdin-am62/pm-cfg.yaml create mode 100644 board/toradex/verdin-am62/rm-cfg.yaml create mode 100644 board/toradex/verdin-am62/sec-cfg.yaml create mode 100644 board/toradex/verdin-am62/verdin-am62.c create mode 100644 configs/verdin-am62_a53_defconfig create mode 100644 configs/verdin-am62_r5_defconfig create mode 100644 doc/board/toradex/verdin-am62.rst create mode 100644 include/configs/verdin-am62.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index bd5887bf750..ad34391d7d0 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1311,7 +1311,9 @@ dtb-$(CONFIG_SOC_K3_AM642) += k3-am642-evm.dtb \ k3-am642-r5-sk.dtb
dtb-$(CONFIG_SOC_K3_AM625) += k3-am625-sk.dtb \ - k3-am625-r5-sk.dtb + k3-am625-r5-sk.dtb \ + k3-am625-verdin-wifi-dev.dtb \ + k3-am625-verdin-r5.dtb
dtb-$(CONFIG_SOC_K3_AM62A7) += k3-am62a7-sk.dtb \ k3-am62a7-r5-sk.dtb diff --git a/arch/arm/dts/k3-am62-verdin-dev.dtsi b/arch/arm/dts/k3-am62-verdin-dev.dtsi new file mode 100644 index 00000000000..e5443cd3c2d --- /dev/null +++ b/arch/arm/dts/k3-am62-verdin-dev.dtsi @@ -0,0 +1,192 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright 2023 Toradex + * + * Common dtsi for Verdin AM62 SoM on Development carrier board + * + * https://www.toradex.com/computer-on-modules/verdin-arm-family/ti-am62 + * https://www.toradex.com/products/carrier-board/verdin-development-board-kit + */ + +/* Verdin ETHs */ +&cpsw3g { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_rgmii1>, <&pinctrl_rgmii2>; + status = "okay"; +}; + +/* MDIO, shared by Verdin ETH_1 (On-module PHY) and Verdin ETH_2_RGMII */ +&cpsw3g_mdio { + status = "okay"; + + cpsw3g_phy1: ethernet-phy@7 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <7>; + interrupt-parent = <&main_gpio0>; + interrupts = <38 IRQ_TYPE_EDGE_FALLING>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_eth2_rgmii_int>; + micrel,led-mode = <0>; + }; +}; + +/* Verdin ETH_1 (On-module PHY) */ +&cpsw_port1 { + status = "okay"; +}; + +/* Verdin ETH_2_RGMII */ +&cpsw_port2 { + phy-handle = <&cpsw3g_phy1>; + phy-mode = "rgmii-rxid"; + status = "okay"; +}; + +/* Verdin PWM_1, PWM_2 */ +&epwm0 { + status = "okay"; +}; + +/* Verdin PWM_3_DSI */ +&epwm1 { + status = "okay"; +}; + +&main_gpio0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ctrl_sleep_moci>, + <&pinctrl_gpio_5>, + <&pinctrl_gpio_6>, + <&pinctrl_gpio_7>, + <&pinctrl_gpio_8>; +}; + +/* Verdin I2C_1 */ +&main_i2c1 { + status = "okay"; + + /* IO Expander */ + gpio_expander_21: gpio@21 { + compatible = "nxp,pcal6416"; + reg = <0x21>; + #gpio-cells = <2>; + gpio-controller; + }; + + /* Current measurement into module VCC */ + hwmon@40 { + compatible = "ti,ina219"; + reg = <0x40>; + shunt-resistor = <10000>; + }; + + /* Temperature sensor */ + sensor@4f { + compatible = "ti,tmp75c"; + reg = <0x4f>; + }; + + /* EEPROM */ + eeprom@57 { + compatible = "st,24c02", "atmel,24c02"; + reg = <0x57>; + pagesize = <16>; + }; +}; + +/* Verdin I2C_2_DSI */ +&main_i2c2 { + status = "okay"; +}; + +/* Verdin I2C_4_CSI */ +&main_i2c3 { + status = "okay"; +}; + +/* Verdin CAN_1 */ +&main_mcan0 { + status = "okay"; +}; + +/* Verdin SPI_1 */ +&main_spi1 { + status = "okay"; +}; + +/* Verdin UART_3 */ +&main_uart0 { + status = "okay"; +}; + +/* Verdin UART_1, connector X50 through RS485 transceiver. */ +&main_uart1 { + linux,rs485-enabled-at-boot-time; + rs485-rx-during-tx; + status = "okay"; +}; + +/* Verdin I2S_1 */ +&mcasp0 { + status = "okay"; +}; + +&mcu_gpio0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_1>, + <&pinctrl_gpio_2>, + <&pinctrl_gpio_3>, + <&pinctrl_gpio_4>; +}; + +/* Verdin I2C_3_HDMI */ +&mcu_i2c0 { + status = "okay"; +}; + +/* Verdin UART_4 */ +&mcu_uart0 { + status = "okay"; +}; + +/* Verdin QSPI_1 */ +&ospi0 { + status = "okay"; +}; + +/* Verdin SD_1 */ +&sdhci1 { + ti,driver-strength-ohm = <33>; + status = "okay"; +}; + +#if 0 +/* Verdin USB_1 */ +&usbss0 { + status = "okay"; +}; + +&usb0 { + status = "okay"; +}; + +/* Verdin USB_2 */ +&usbss1 { + status = "okay"; +}; + +&usb1 { + status = "okay"; +}; +#endif + +/* Verdin CTRL_WAKE1_MICO# */ +&verdin_gpio_keys { + status = "okay"; +}; + +/* Verdin UART_2 */ +&wkup_uart0 { + /* FIXME: WKUP UART0 is used by DM firmware */ + status = "reserved"; +}; diff --git a/arch/arm/dts/k3-am62-verdin-wifi.dtsi b/arch/arm/dts/k3-am62-verdin-wifi.dtsi new file mode 100644 index 00000000000..90ddc71bcd3 --- /dev/null +++ b/arch/arm/dts/k3-am62-verdin-wifi.dtsi @@ -0,0 +1,39 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright 2023 Toradex + * + * Common dtsi for Verdin AM62 SoM WB variant + * + * https://www.toradex.com/computer-on-modules/verdin-arm-family/ti-am62 + */ + +/ { + wifi_pwrseq: wifi-pwrseq { + compatible = "mmc-pwrseq-simple"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wifi_en>; + reset-gpios = <&main_gpio0 22 GPIO_ACTIVE_LOW>; + }; +}; + +/* On-module Wi-Fi */ +&sdhci2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sdhci2>; + bus-width = <4>; + cap-power-off-card; + keep-power-in-suspend; + mmc-pwrseq = <&wifi_pwrseq>; + non-removable; + ti,fails-without-test-cd; + ti,driver-strength-ohm = <50>; + vmmc-supply = <®_3v3>; + status = "okay"; +}; + +/* On-module Bluetooth */ +&main_uart5 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart5>; + status = "okay"; +}; diff --git a/arch/arm/dts/k3-am62-verdin.dtsi b/arch/arm/dts/k3-am62-verdin.dtsi new file mode 100644 index 00000000000..9f626c86972 --- /dev/null +++ b/arch/arm/dts/k3-am62-verdin.dtsi @@ -0,0 +1,1405 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright 2023 Toradex + * + * Common dtsi for Verdin AM62 SoM + * + * https://www.toradex.com/computer-on-modules/verdin-arm-family/ti-am62 + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/net/ti-dp83867.h> + +/ { + chosen { + stdout-path = "serial2:115200n8"; + }; + + aliases { + ethernet0 = &cpsw_port1; + ethernet1 = &cpsw_port2; + i2c0 = &main_i2c0; + i2c1 = &main_i2c1; + i2c2 = &main_i2c2; + i2c3 = &mcu_i2c0; + i2c4 = &main_i2c3; + mmc0 = &sdhci0; + mmc1 = &sdhci1; + mmc2 = &sdhci2; + rtc0 = &rtc_i2c; + rtc1 = &wkup_rtc0; + serial0 = &main_uart1; + serial1 = &wkup_uart0; + serial2 = &main_uart0; + serial3 = &mcu_uart0; + serial4 = &main_uart5; +#if 0 + usb0 = &usb0; + usb1 = &usb1; +#endif + }; + + verdin_gpio_keys: gpio-keys { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ctrl_wake1_mico>; + status = "disabled"; + + verdin_key_wakeup: key-wakeup { + debounce-interval = <10>; + /* Verdin CTRL_WAKE1_MICO# (SODIMM 252) */ + gpios = <&main_gpio0 32 GPIO_ACTIVE_LOW>; + label = "Wake-Up"; + linux,code = <KEY_WAKEUP>; + wakeup-source; + }; + }; + + memory@80000000 { + device_type = "memory"; + reg = <0x00000000 0x80000000 0x00000000 0x40000000>; /* 1G RAM */ + }; + + opp-table { + /* Add 1.4GHz OPP. Requires VDD_CORE to be at 0.85V */ + opp-1400000000 { + opp-hz = /bits/ 64 <1400000000>; + opp-supported-hw = <0x01 0x0004>; + clock-latency-ns = <6000000>; + }; + }; + + /* Module Power Supply */ + reg_vsodimm: regulator-vsodimm { + compatible = "regulator-fixed"; + regulator-name = "+V_SODIMM"; + }; + + /* Non PMIC On-module Supplies */ + reg_3v3: regulator-3v3 { + compatible = "regulator-fixed"; + regulator-max-microvolt = <3300000>; + regulator-min-microvolt = <3300000>; + regulator-name = "On-module +V3.3"; + vin-supply = <®_vsodimm>; + }; + + reg_1v2_dsi: regulator-1v2-dsi { + compatible = "regulator-fixed"; + regulator-max-microvolt = <1200000>; + regulator-min-microvolt = <1200000>; + regulator-name = "On-module +V1.2_DSI"; + vin-supply = <®_1v8>; + }; + + /* Enabled by +V1.2_DSI */ + reg_1v8_dsi: regulator-1v8-dsi { + compatible = "regulator-fixed"; + regulator-max-microvolt = <1800000>; + regulator-min-microvolt = <1800000>; + regulator-name = "On-module +V1.8_DSI"; + vin-supply = <®_1v8>; + }; + + /* Enabled by +V2.5_ETH */ + reg_1v0_eth: regulator-1v0-eth { + compatible = "regulator-fixed"; + regulator-max-microvolt = <1000000>; + regulator-min-microvolt = <1000000>; + regulator-name = "On-module +V1.0_ETH"; + vin-supply = <®_1v8>; + }; + + /* Enabled by +V2.5_ETH */ + reg_1v8_eth: regulator-1v8-eth { + compatible = "regulator-fixed"; + regulator-max-microvolt = <1800000>; + regulator-min-microvolt = <1800000>; + regulator-name = "On-module +V1.8_ETH"; + vin-supply = <®_1v8>; + }; + + /* Verdin SD_1 Power Supply */ + reg_sdhc1_vmmc: regulator-sdhci1 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sd1_pwr_en>; + enable-active-high; + /* Verdin SD_1_PWR_EN (SODIMM 76) */ + gpio = <&main_gpio0 29 GPIO_ACTIVE_HIGH>; + off-on-delay-us = <100000>; + regulator-max-microvolt = <3300000>; + regulator-min-microvolt = <3300000>; + regulator-name = "+V3.3_SD"; + startup-delay-us = <2000>; + }; + + reg_sdhc1_vqmmc: regulator-sdhci1-vqmmc { + compatible = "regulator-gpio"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_vsel_sd>; + /* PMIC_VSEL_SD */ + gpios = <&main_gpio0 21 GPIO_ACTIVE_HIGH>; + regulator-name = "LDO1-VSEL-SD (PMIC)"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + states = <1800000 0x0>, + <3300000 0x1>; + vin-supply = <®_sd_3v3_1v8>; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + secure_tfa_ddr: tfa@9e780000 { + reg = <0x00 0x9e780000 0x00 0x80000>; + alignment = <0x1000>; + no-map; + }; + + secure_ddr: optee@9e800000 { + reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */ + alignment = <0x1000>; + no-map; + }; + + wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9db00000 { + compatible = "shared-dma-pool"; + reg = <0x00 0x9db00000 0x00 0xc00000>; + no-map; + }; + }; +}; + +&main_pmx0 { + /* Verdin PWM_1 */ + pinctrl_epwm0_a: main-epwm0a-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01b4, PIN_OUTPUT, 2) /* (A13) SPI0_CS0.EHRPWM0_A */ /* SODIMM 15 */ + >; + }; + + /* Verdin PWM_2 */ + pinctrl_epwm0_b: main-epwm0b-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01b8, PIN_OUTPUT, 2) /* (C13) SPI0_CS1.EHRPWM0_B */ /* SODIMM 16 */ + >; + }; + + /* Verdin PWM_3_DSI */ + pinctrl_epwm1_a: main-epwm1a-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01bc, PIN_OUTPUT, 2) /* (A14) SPI0_CLK.EHRPWM1_A */ /* SODIMM 19 */ + >; + }; + + /* Verdin QSPI_1_CLK as GPIO (conflict with Verdin QSPI_1 interface) */ + pinctrl_qspi1_clk_gpio: main-gpio0-0-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0000, PIN_INPUT, 7) /* (H24) OSPI0_CLK.GPIO0_0 */ /* SODIMM 52 */ + >; + }; + + /* Verdin QSPI_1_IO0 as GPIO (conflict with Verdin QSPI_1 interface) */ + pinctrl_qspi1_io0_gpio: main-gpio0-3-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x000c, PIN_INPUT, 7) /* (E25) OSPI0_D0.GPIO0_3 */ /* SODIMM 56 */ + >; + }; + + /* Verdin QSPI_1_IO1 as GPIO (conflict with Verdin QSPI_1 interface) */ + pinctrl_qspi1_io1_gpio: main-gpio0-4-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0010, PIN_INPUT, 7) /* (G24) OSPI0_D1.GPIO0_4 */ /* SODIMM 58 */ + >; + }; + + /* Verdin QSPI_1_IO2 as GPIO (conflict with Verdin QSPI_1 interface) */ + pinctrl_qspi1_io2_gpio: main-gpio0-5-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0014, PIN_INPUT, 7) /* (F25) OSPI0_D2.GPIO0_5 */ /* SODIMM 60 */ + >; + }; + + /* Verdin QSPI_1_IO3 as GPIO (conflict with Verdin QSPI_1 interface) */ + pinctrl_qspi1_io3_gpio: main-gpio0-6-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0018, PIN_INPUT, 7) /* (F24) OSPI0_D3.GPIO0_6 */ /* SODIMM 62 */ + >; + }; + + /* Verdin QSPI_1_CS# as GPIO (conflict with Verdin QSPI_1 interface) */ + pinctrl_qspi1_cs_gpio: main-gpio0-11-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x002c, PIN_INPUT, 7) /* (F23) OSPI0_CSn0.GPIO0_11 */ /* SODIMM 54 */ + >; + }; + + /* Verdin QSPI_1_CS2# as GPIO (conflict with Verdin QSPI_1 interface) */ + pinctrl_qspi1_cs2_gpio: main-gpio0-12-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0030, PIN_INPUT, 7) /* (G21) OSPI0_CSn1.GPIO0_12 */ /* SODIMM 64 */ + >; + }; + + /* WiFi_W_WKUP_HOST# */ + pinctrl_wifi_w_wkup_host: main-gpio0-15-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x003c, PIN_INPUT, 7) /* (M25) GPMC0_AD0.GPIO0_15 */ /* SODIMM 174 */ + >; + }; + + /* WiFi_BT_WKUP_HOST# */ + pinctrl_bt_wkup_host: main-gpio0-16-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0040, PIN_INPUT, 7) /* (N23) GPMC0_AD1.GPIO0_16 */ /* SODIMM 172 */ + >; + }; + + /* PMIC_ETH_RESET# */ + pinctrl_eth_reset: main-gpio0-17-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0044, PIN_INPUT, 7) /* (N24) GPMC0_AD2.GPIO0_17 */ + >; + }; + + /* PMIC_BRIDGE_RESET# */ + pinctrl_bridge_reset: main-gpio0-20-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0050, PIN_INPUT, 7) /* (P22) GPMC0_AD5.GPIO0_20 */ + >; + }; + + /* PMIC_VSEL_SD */ + pinctrl_vsel_sd: main-gpio0-21-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0054, PIN_INPUT, 7) /* (P21) GPMC0_AD6.GPIO0_21 */ + >; + }; + + /* PMIC_EN_WIFI */ + pinctrl_wifi_en: main-gpio0-22-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0058, PIN_INPUT, 7) /* (R23) GPMC0_AD7.GPIO0_22 */ + >; + }; + + /* PMIC_ETH_INT# */ + pinctrl_eth_int: main-gpio0-25-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0064, PIN_INPUT_PULLUP, 7) /* (T25) GPMC0_AD10.GPIO0_25 */ + >; + }; + + /* WiFi_WKUP_BT# */ + pinctrl_wifi_wkup_bt: main-gpio0-26-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0068, PIN_INPUT, 7) /* (R21) GPMC0_AD11.GPIO0_26 */ + >; + }; + + /* WiFi_WKUP_WLAN# */ + pinctrl_wifi_wkup_wlan: main-gpio0-27-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x006c, PIN_INPUT, 7) /* (T22) GPMC0_AD12.GPIO0_27 */ + >; + }; + + /* Verdin SD_1_PWR_EN */ + pinctrl_sd1_pwr_en: main-gpio0-29-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0074, PIN_INPUT, 7) /* (U25) GPMC0_AD14.GPIO0_29 */ /* SODIMM 76 */ + >; + }; + + /* Verdin DSI_1_BKL_EN */ + pinctrl_dsi1_bkl_en: main-gpio0-30-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0078, PIN_INPUT, 7) /* (U24) GPMC0_AD15.GPIO0_30 */ /* SODIMM 21 */ + >; + }; + + /* Verdin CTRL_SLEEP_MOCI# */ + pinctrl_ctrl_sleep_moci: main-gpio0-31-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x007c, PIN_INPUT, 7) /* (P25) GPMC0_CLK.GPIO0_31 */ /* SODIMM 256 */ + >; + }; + + /* Verdin CTRL_WAKE1_MICO# */ + pinctrl_ctrl_wake1_mico: main-gpio0-32-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0084, PIN_INPUT_PULLUP, 7) /* (L23) GPMC0_ADVn_ALE.GPIO0_32 */ /* SODIMM 252 */ + >; + }; + + /* Verdin I2S_2_D_OUT as GPIO (conflict with Verdin I2S_2 interface) */ + pinctrl_i2s_2_d_out_gpio: main-gpio0-34-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x008c, PIN_INPUT, 7) /* (L25) GPMC0_WEn.GPIO0_34 */ /* SODIMM 46 */ + >; + }; + + /* Verdin I2S_2_BCLK as GPIO (conflict with Verdin I2S_2 interface) */ + pinctrl_i2s_2_bclk_gpio: main-gpio0-35-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0090, PIN_INPUT, 7) /* (M24) GPMC0_BE0n_CLE.GPIO0_35 */ /* SODIMM 42 */ + >; + }; + + /* Verdin GPIO_6 */ + pinctrl_gpio_6: main-gpio0-36-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0094, PIN_INPUT, 7) /* (N20) GPMC0_BE1n.GPIO0_36 */ /* SODIMM 218 */ + >; + }; + + /* Verdin ETH_2_RGMII_INT# */ + pinctrl_eth2_rgmii_int: main-gpio0-38-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x009c, PIN_INPUT, 7) /* (V25) GPMC0_WAIT1.GPIO0_38 */ /* SODIMM 189 */ + >; + }; + + /* Verdin GPIO_5 */ + pinctrl_gpio_5: main-gpio0-40-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x00a4, PIN_INPUT, 7) /* (M22) GPMC0_DIR.GPIO0_40 */ /* SODIMM 216 */ + >; + }; + + /* Verdin GPIO_7 */ + pinctrl_gpio_7: main-gpio0-41-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x00a8, PIN_INPUT, 7) /* (M21) GPMC0_CSn0.GPIO0_41 */ /* SODIMM 220 */ + >; + }; + + /* Verdin GPIO_8 */ + pinctrl_gpio_8: main-gpio0-42-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x00ac, PIN_INPUT, 7) /* (L21) GPMC0_CSn1.GPIO0_42 */ /* SODIMM 222 */ + >; + }; + + /* Verdin USB_1_OC# */ + pinctrl_usb1_oc: main-gpio0-71-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0124, PIN_INPUT, 7) /* (A23) MMC2_SDCD.GPIO0_71 */ /* SODIMM 157 */ + >; + }; + + /* Verdin USB_2_OC# */ + pinctrl_usb2_oc: main-gpio0-72-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0128, PIN_INPUT, 7) /* (B23) MMC2_SDWP.GPIO0_72 */ /* SODIMM 187 */ + >; + }; + + /* Verdin PWM_3_DSI as GPIO */ + pinctrl_pwm3_dsi_gpio: main-gpio1-17-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01bc, PIN_INPUT, 7) /* (A14) SPI0_CLK.GPIO1_17 */ /* SODIMM 19 */ + >; + }; + + /* Verdin QSPI_1_DQS as GPIO */ + pinctrl_qspi1_dqs_gpio: main-gpio1-18-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01c0, PIN_INPUT, 7) /* (B13) SPI0_D0.GPIO1_18 */ /* SODIMM 66 */ + >; + }; + + /* Verdin USB_1_ID */ + pinctrl_usb0_id: main-gpio1-19-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01c4, PIN_INPUT, 7) /* (B14) SPI0_D1.GPIO1_19 */ /* SODIMM 161 */ + >; + }; + + /* Verdin DSI_1_INT# (pulled-up as active-low) */ + pinctrl_dsi1_int: main-gpio1-49-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0244, PIN_INPUT_PULLUP, 7) /* (C17) MMC1_SDWP.GPIO1_49 */ /* SODIMM 17 */ + >; + }; + + /* On-module I2C - PMIC_I2C */ + pinctrl_i2c0: main-i2c0-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01e0, PIN_INPUT, 0) /* (B16) I2C0_SCL */ /* PMIC_I2C_SCL */ + AM62X_IOPAD(0x01e4, PIN_INPUT, 0) /* (A16) I2C0_SDA */ /* PMIC_I2C_SDA */ + >; + }; + + /* Verdin I2C_1 */ + pinctrl_i2c1: main-i2c1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01e8, PIN_INPUT_PULLUP, 0) /* (B17) I2C1_SCL */ /* SODIMM 14 */ + AM62X_IOPAD(0x01ec, PIN_INPUT_PULLUP, 0) /* (A17) I2C1_SDA */ /* SODIMM 12 */ + >; + }; + + /* Verdin I2C_2_DSI */ + pinctrl_i2c2: main-i2c2-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x00b0, PIN_INPUT, 1) /* (K22) GPMC0_CSn2.I2C2_SCL */ /* SODIMM 55 */ + AM62X_IOPAD(0x00b4, PIN_INPUT, 1) /* (K24) GPMC0_CSn3.I2C2_SDA */ /* SODIMM 53 */ + >; + }; + + /* Verdin I2C_4_CSI */ + pinctrl_i2c3: main-i2c3-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01d0, PIN_INPUT, 2) /* (A15) UART0_CTSn.I2C3_SCL */ /* SODIMM 95 */ + AM62X_IOPAD(0x01d4, PIN_INPUT, 2) /* (B15) UART0_RTSn.I2C3_SDA */ /* SODIMM 93 */ + >; + }; + + /* I2S_1_MCLK */ + pinctrl_i2s1_mclk: main-system-audio-ext-reflock1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x00a0, PIN_OUTPUT, 1) /* (K25) GPMC0_WPn.AUDIO_EXT_REFCLK1 */ /* SODIMM 38 */ + >; + }; + + /* Verdin I2S_1 */ + pinctrl_mcasp0: main-mcasp0-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01a4, PIN_INPUT, 0) /* (B20) MCASP0_ACLKX */ /* SODIMM 30 */ + AM62X_IOPAD(0x01a8, PIN_INPUT, 0) /* (D20) MCASP0_AFSX */ /* SODIMM 32 */ + AM62X_IOPAD(0x01a0, PIN_OUTPUT, 0) /* (E18) MCASP0_AXR0 */ /* SODIMM 34 */ + AM62X_IOPAD(0x019c, PIN_INPUT, 0) /* (B18) MCASP0_AXR1 */ /* SODIMM 36 */ + >; + }; + + /* Verdin I2S_2 */ + pinctrl_mcasp1: main-mcasp1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0090, PIN_INPUT, 2) /* (M24) GPMC0_BE0n_CLE.MCASP1_ACLKX */ /* SODIMM 42 */ + AM62X_IOPAD(0x0098, PIN_INPUT, 2) /* (U23) GPMC0_WAIT0.MCASP1_AFSX */ /* SODIMM 44 */ + AM62X_IOPAD(0x008c, PIN_OUTPUT, 2) /* (L25) GPMC0_WEn.MCASP1_AXR0 */ /* SODIMM 46 */ + AM62X_IOPAD(0x0088, PIN_INPUT, 2) /* (L24) GPMC0_OEn_REn.MCASP1_AXR1 */ /* SODIMM 48 */ + >; + }; + + /* Verdin CAN_1 */ + pinctrl_mcan0: main-mcan0-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01dc, PIN_INPUT, 0) /* (E15) MCAN0_RX */ /* SODIMM 22 */ + AM62X_IOPAD(0x01d8, PIN_OUTPUT, 0) /* (C15) MCAN0_TX */ /* SODIMM 20 */ + >; + }; + + /* MDIO, shared by Verdin ETH_1 (On-module PHY) and Verdin ETH_2_RGMII */ + pinctrl_mdio: main-mdio1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x160, PIN_OUTPUT, 0) /* (AD24) MDIO0_MDC */ /* ETH_1_MDC, SODIMM 193 */ + AM62X_IOPAD(0x15c, PIN_INPUT, 0) /* (AB22) MDIO0_MDIO */ /* ETH_1_MDIO, SODIMM 191 */ + >; + }; + + /* On-module eMMC */ + pinctrl_sdhci0: main-mmc0-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x220, PIN_INPUT, 0) /* (Y3) MMC0_CMD */ + AM62X_IOPAD(0x218, PIN_INPUT, 0) /* (AB1) MMC0_CLK */ + AM62X_IOPAD(0x214, PIN_INPUT, 0) /* (AA2) MMC0_DAT0 */ + AM62X_IOPAD(0x210, PIN_INPUT, 0) /* (AA1) MMC0_DAT1 */ + AM62X_IOPAD(0x20c, PIN_INPUT, 0) /* (AA3) MMC0_DAT2 */ + AM62X_IOPAD(0x208, PIN_INPUT, 0) /* (Y4) MMC0_DAT3 */ + AM62X_IOPAD(0x204, PIN_INPUT, 0) /* (AB2) MMC0_DAT4 */ + AM62X_IOPAD(0x200, PIN_INPUT, 0) /* (AC1) MMC0_DAT5 */ + AM62X_IOPAD(0x1fc, PIN_INPUT, 0) /* (AD2) MMC0_DAT6 */ + AM62X_IOPAD(0x1f8, PIN_INPUT, 0) /* (AC2) MMC0_DAT7 */ + >; + }; + + /* Verdin SD_1 */ + pinctrl_sdhci1: main-mmc1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x23c, PIN_INPUT, 0) /* (A21) MMC1_CMD */ /* SODIMM 74 */ + AM62X_IOPAD(0x234, PIN_INPUT, 0) /* (B22) MMC1_CLK */ /* SODIMM 78 */ + AM62X_IOPAD(0x230, PIN_INPUT, 0) /* (A22) MMC1_DAT0 */ /* SODIMM 80 */ + AM62X_IOPAD(0x22c, PIN_INPUT, 0) /* (B21) MMC1_DAT1 */ /* SODIMM 82 */ + AM62X_IOPAD(0x228, PIN_INPUT, 0) /* (C21) MMC1_DAT2 */ /* SODIMM 70 */ + AM62X_IOPAD(0x224, PIN_INPUT, 0) /* (D22) MMC1_DAT3 */ /* SODIMM 72 */ + AM62X_IOPAD(0x240, PIN_INPUT_PULLUP, 0) /* (D17) MMC1_SDCD */ /* SODIMM 84 */ + >; + }; + + /* On-module Wi-Fi on WB SKUs, module-specific SDIO otherwise */ + pinctrl_sdhci2: main-mmc2-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x120, PIN_INPUT, 0) /* (C24) MMC2_CMD */ /* WiFi_SDIO_CMD */ + AM62X_IOPAD(0x118, PIN_INPUT, 0) /* (D25) MMC2_CLK */ /* WiFi_SDIO_CLK */ + AM62X_IOPAD(0x114, PIN_INPUT, 0) /* (B24) MMC2_DAT0 */ /* WiFi_SDIO_DATA0 */ + AM62X_IOPAD(0x110, PIN_INPUT, 0) /* (C25) MMC2_DAT1 */ /* WiFi_SDIO_DATA1 */ + AM62X_IOPAD(0x10c, PIN_INPUT, 0) /* (E23) MMC2_DAT2 */ /* WiFi_SDIO_DATA2 */ + AM62X_IOPAD(0x108, PIN_INPUT, 0) /* (D24) MMC2_DAT3 */ /* WiFi_SDIO_DATA3 */ + AM62X_IOPAD(0x11c, PIN_INPUT, 0) /* (#N/A) MMC2_CLKB */ + >; + }; + + /* Verdin QSPI_1 */ + pinctrl_ospi0: main-ospi0-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0000, PIN_OUTPUT, 0) /* (H24) OSPI0_CLK */ /* SODIMM 52 */ + AM62X_IOPAD(0x002c, PIN_OUTPUT, 0) /* (F23) OSPI0_CSn0 */ /* SODIMM 54 */ + AM62X_IOPAD(0x0030, PIN_OUTPUT, 0) /* (G21) OSPI0_CSn1 */ /* SODIMM 64 */ + AM62X_IOPAD(0x000c, PIN_INPUT, 0) /* (E25) OSPI0_D0 */ /* SODIMM 56 */ + AM62X_IOPAD(0x0010, PIN_INPUT, 0) /* (G24) OSPI0_D1 */ /* SODIMM 58 */ + AM62X_IOPAD(0x0014, PIN_INPUT, 0) /* (F25) OSPI0_D2 */ /* SODIMM 60 */ + AM62X_IOPAD(0x0018, PIN_INPUT, 0) /* (F24) OSPI0_D3 */ /* SODIMM 62 */ + >; + }; + + /* Verdin ETH_1 RGMII (On-module PHY) */ + pinctrl_rgmii1: main-rgmii1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x14c, PIN_INPUT, 0) /* (AB17) RGMII1_RD0 */ + AM62X_IOPAD(0x150, PIN_INPUT, 0) /* (AC17) RGMII1_RD1 */ + AM62X_IOPAD(0x154, PIN_INPUT, 0) /* (AB16) RGMII1_RD2 */ + AM62X_IOPAD(0x158, PIN_INPUT, 0) /* (AA15) RGMII1_RD3 */ + AM62X_IOPAD(0x148, PIN_INPUT, 0) /* (AD17) RGMII1_RXC */ + AM62X_IOPAD(0x144, PIN_INPUT, 0) /* (AE17) RGMII1_RX_CTL */ + AM62X_IOPAD(0x134, PIN_OUTPUT, 0) /* (AE20) RGMII1_TD0 */ + AM62X_IOPAD(0x138, PIN_OUTPUT, 0) /* (AD20) RGMII1_TD1 */ + AM62X_IOPAD(0x13c, PIN_OUTPUT, 0) /* (AE18) RGMII1_TD2 */ + AM62X_IOPAD(0x140, PIN_OUTPUT, 0) /* (AD18) RGMII1_TD3 */ + AM62X_IOPAD(0x130, PIN_OUTPUT, 0) /* (AE19) RGMII1_TXC */ + AM62X_IOPAD(0x12c, PIN_OUTPUT, 0) /* (AD19) RGMII1_TX_CTL */ + >; + }; + + /* Verdin ETH_2 RGMII */ + pinctrl_rgmii2: main-rgmii2-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x184, PIN_INPUT, 0) /* (AE23) RGMII2_RD0 */ /* SODIMM 201 */ + AM62X_IOPAD(0x188, PIN_INPUT, 0) /* (AB20) RGMII2_RD1 */ /* SODIMM 203 */ + AM62X_IOPAD(0x18c, PIN_INPUT, 0) /* (AC21) RGMII2_RD2 */ /* SODIMM 205 */ + AM62X_IOPAD(0x190, PIN_INPUT, 0) /* (AE22) RGMII2_RD3 */ /* SODIMM 207 */ + AM62X_IOPAD(0x180, PIN_INPUT, 0) /* (AD23) RGMII2_RXC */ /* SODIMM 197 */ + AM62X_IOPAD(0x17c, PIN_INPUT, 0) /* (AD22) RGMII2_RX_CTL */ /* SODIMM 199 */ + AM62X_IOPAD(0x16c, PIN_OUTPUT, 0) /* (Y18) RGMII2_TD0 */ /* SODIMM 221 */ + AM62X_IOPAD(0x170, PIN_OUTPUT, 0) /* (AA18) RGMII2_TD1 */ /* SODIMM 219 */ + AM62X_IOPAD(0x174, PIN_OUTPUT, 0) /* (AD21) RGMII2_TD2 */ /* SODIMM 217 */ + AM62X_IOPAD(0x178, PIN_OUTPUT, 0) /* (AC20) RGMII2_TD3 */ /* SODIMM 215 */ + AM62X_IOPAD(0x168, PIN_OUTPUT, 0) /* (AE21) RGMII2_TXC */ /* SODIMM 213 */ + AM62X_IOPAD(0x164, PIN_OUTPUT, 0) /* (AA19) RGMII2_TX_CTL */ /* SODIMM 211 */ + >; + }; + + /* Verdin SPI_1 */ + pinctrl_spi1: main-spi1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0020, PIN_INPUT, 1) /* (J25) OSPI0_D5.SPI1_CLK */ /* SODIMM 196 */ + AM62X_IOPAD(0x001c, PIN_INPUT, 1) /* (J23) OSPI0_D4.SPI1_CS0 */ /* SODIMM 202 */ + AM62X_IOPAD(0x0024, PIN_INPUT, 1) /* (H25) OSPI0_D6.SPI1_D0 */ /* SODIMM 200 */ + AM62X_IOPAD(0x0028, PIN_INPUT, 1) /* (J22) OSPI0_D7.SPI1_D1 */ /* SODIMM 198 */ + >; + }; + + /* ETH_25MHz_CLK */ + pinctrl_eth_clock: main-system-clkout0-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01f0, PIN_OUTPUT_PULLUP, 5) /* (A18) EXT_REFCLK1.CLKOUT0 */ + >; + }; + + /* PMIC_EXTINT# */ + pinctrl_pmic_extint: main-system-extint-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01f4, PIN_INPUT, 0) /* (D16) EXTINTn */ + >; + }; + + /* Verdin UART_3, used as the Linux console */ + pinctrl_uart0: main-uart0-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x1c8, PIN_INPUT_PULLUP, 0) /* (D14) UART0_RXD */ /* SODIMM 147 */ + AM62X_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */ /* SODIMM 149 */ + >; + }; + + /* Verdin UART_1 */ + pinctrl_uart1: main-uart1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0194, PIN_INPUT_PULLUP, 2) /* (B19) MCASP0_AXR3.UART1_CTSn */ /* SODIMM 135 */ + AM62X_IOPAD(0x0198, PIN_OUTPUT, 2) /* (A19) MCASP0_AXR2.UART1_RTSn */ /* SODIMM 133 */ + AM62X_IOPAD(0x01ac, PIN_INPUT_PULLUP, 2) /* (E19) MCASP0_AFSR.UART1_RXD */ /* SODIMM 129 */ + AM62X_IOPAD(0x01b0, PIN_OUTPUT, 2) /* (A20) MCASP0_ACLKR.UART1_TXD */ /* SODIMM 131 */ + >; + }; + + /* Bluetooth on WB SKUs, module-specific UART otherwise */ + pinctrl_uart5: main-uart5-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0008, PIN_INPUT_PULLUP, 5) /* (J24) OSPI0_DQS.UART5_CTSn */ /* WiFi_UART_CTS */ + AM62X_IOPAD(0x0004, PIN_OUTPUT, 5) /* (G25) OSPI0_LBCLKO.UART5_RTSn */ /* WiFi_UART_RTS */ + AM62X_IOPAD(0x0034, PIN_INPUT_PULLUP, 5) /* (H21) OSPI0_CSn2.UART5_RXD */ /* WiFi_UART_RXD */ + AM62X_IOPAD(0x0038, PIN_OUTPUT, 5) /* (E24) OSPI0_CSn3.UART5_TXD */ /* WiFi_UART_TXD */ + >; + }; + + /* Verdin USB_1 */ + pinctrl_usb0: main-usb0-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0254, PIN_OUTPUT, 0) /* (C20) USB0_DRVVBUS */ /* SODIMM 155 */ + >; + }; + + /* Verdin USB_2 */ + pinctrl_usb1: main-usb1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0258, PIN_OUTPUT, 0) /* (F18) USB1_DRVVBUS */ /* SODIMM 185 */ + >; + }; + + /* DSS VOUT0 RGB */ + pinctrl_parallel_rgb: main-vout-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0100, PIN_OUTPUT, 0) /* (AC25) VOUT0_VSYNC */ + AM62X_IOPAD(0x00f8, PIN_OUTPUT, 0) /* (AB24) VOUT0_HSYNC */ + AM62X_IOPAD(0x0104, PIN_OUTPUT, 0) /* (AC24) VOUT0_PCLK */ + AM62X_IOPAD(0x00fc, PIN_OUTPUT, 0) /* (Y20) VOUT0_DE */ + AM62X_IOPAD(0x00b8, PIN_OUTPUT, 0) /* (U22) VOUT0_DATA0 */ + AM62X_IOPAD(0x00bc, PIN_OUTPUT, 0) /* (V24) VOUT0_DATA1 */ + AM62X_IOPAD(0x00c0, PIN_OUTPUT, 0) /* (W25) VOUT0_DATA2 */ + AM62X_IOPAD(0x00c4, PIN_OUTPUT, 0) /* (W24) VOUT0_DATA3 */ + AM62X_IOPAD(0x00c8, PIN_OUTPUT, 0) /* (Y25) VOUT0_DATA4 */ + AM62X_IOPAD(0x00cc, PIN_OUTPUT, 0) /* (Y24) VOUT0_DATA5 */ + AM62X_IOPAD(0x00d0, PIN_OUTPUT, 0) /* (Y23) VOUT0_DATA6 */ + AM62X_IOPAD(0x00d4, PIN_OUTPUT, 0) /* (AA25) VOUT0_DATA7 */ + AM62X_IOPAD(0x00d8, PIN_OUTPUT, 0) /* (V21) VOUT0_DATA8 */ + AM62X_IOPAD(0x00dc, PIN_OUTPUT, 0) /* (W21) VOUT0_DATA9 */ + AM62X_IOPAD(0x00e0, PIN_OUTPUT, 0) /* (V20) VOUT0_DATA10 */ + AM62X_IOPAD(0x00e4, PIN_OUTPUT, 0) /* (AA23) VOUT0_DATA11 */ + AM62X_IOPAD(0x00e8, PIN_OUTPUT, 0) /* (AB25) VOUT0_DATA12 */ + AM62X_IOPAD(0x00ec, PIN_OUTPUT, 0) /* (AA24) VOUT0_DATA13 */ + AM62X_IOPAD(0x00f0, PIN_OUTPUT, 0) /* (Y22) VOUT0_DATA14 */ + AM62X_IOPAD(0x00f4, PIN_OUTPUT, 0) /* (AA21) VOUT0_DATA15 */ + AM62X_IOPAD(0x005c, PIN_OUTPUT, 1) /* (R24) GPMC0_AD8.VOUT0_DATA16 */ + AM62X_IOPAD(0x0060, PIN_OUTPUT, 1) /* (R25) GPMC0_AD9.VOUT0_DATA17 */ + >; + }; +}; + +&mcu_pmx0 { + /* Verdin PCIE_1_RESET# */ + pinctrl_pcie_1_reset: mcu-gpio0-0-default-pins { + pinctrl-single,pins = < + AM62X_MCU_IOPAD(0x0000, PIN_INPUT, 7) /* (E8) MCU_SPI0_CS0.MCU_GPIO0_0 */ /* SODIMM 244 */ + >; + }; + + /* Verdin GPIO_1 */ + pinctrl_gpio_1: mcu-gpio0-1-default-pins { + pinctrl-single,pins = < + AM62X_MCU_IOPAD(0x0004, PIN_INPUT, 7) /* (B8) MCU_SPI0_CS1.MCU_GPIO0_1 */ /* SODIMM 206 */ + >; + }; + + /* Verdin GPIO_2 */ + pinctrl_gpio_2: mcu-gpio0-2-default-pins { + pinctrl-single,pins = < + AM62X_MCU_IOPAD(0x0008, PIN_INPUT, 7) /* (A7) MCU_SPI0_CLK.MCU_GPIO0_2 */ /* SODIMM 208 */ + >; + }; + + /* Verdin GPIO_3 */ + pinctrl_gpio_3: mcu-gpio0-3-default-pins { + pinctrl-single,pins = < + AM62X_MCU_IOPAD(0x000c, PIN_INPUT, 7) /* (D9) MCU_SPI0_D0.MCU_GPIO0_3 */ /* SODIMM 210 */ + >; + }; + + /* Verdin GPIO_4 */ + pinctrl_gpio_4: mcu-gpio0-4-default-pins { + pinctrl-single,pins = < + AM62X_MCU_IOPAD(0x0010, PIN_INPUT, 7) /* (C9) MCU_SPI0_D1.MCU_GPIO0_4 */ /* SODIMM 212 */ + >; + }; + + /* Verdin I2C_3_HDMI */ + pinctrl_mcu_i2c0: mcu-i2c0-default-pins { + pinctrl-single,pins = < + AM62X_MCU_IOPAD(0x0044, PIN_INPUT, 0) /* (A8) MCU_I2C0_SCL */ /* SODIMM 59 */ + AM62X_MCU_IOPAD(0x0048, PIN_INPUT, 0) /* (D10) MCU_I2C0_SDA */ /* SODIMM 57 */ + >; + }; + + /* Verdin UART_4 - Reserved to Cortex-M4 */ + pinctrl_mcu_uart0: mcu-uart0-default-pins { + pinctrl-single,pins = < + AM62X_MCU_IOPAD(0x0014, PIN_INPUT_PULLUP, 0) /* (B5) MCU_UART0_RXD */ /* SODIMM 151 */ + AM62X_MCU_IOPAD(0x0018, PIN_OUTPUT, 0) /* (A5) MCU_UART0_TXD */ /* SODIMM 153 */ + >; + }; + + /* Verdin CSI_1_MCLK */ + pinctrl_csi1_mclk: wkup-clkout0-default-pins { + pinctrl-single,pins = < + AM62X_MCU_IOPAD(0x0084, PIN_OUTPUT, 0) /* (A12) WKUP_CLKOUT0 */ /* SODIMM 91 */ + >; + }; + + /* Verdin UART_2 */ + pinctrl_wkup_uart0: wkup-uart0-default-pins { + pinctrl-single,pins = < + AM62X_MCU_IOPAD(0x002c, PIN_INPUT_PULLUP, 0) /* (C6) WKUP_UART0_CTSn */ /* SODIMM 143 */ + AM62X_MCU_IOPAD(0x0030, PIN_OUTPUT, 0) /* (A4) WKUP_UART0_RTSn */ /* SODIMM 141 */ + AM62X_MCU_IOPAD(0x0024, PIN_INPUT_PULLUP, 0) /* (B4) WKUP_UART0_RXD */ /* SODIMM 137 */ + AM62X_MCU_IOPAD(0x0028, PIN_OUTPUT, 0) /* (C5) WKUP_UART0_TXD */ /* SODIMM 139 */ + >; + }; +}; + +&cpsw3g { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_rgmii1>; + status = "disabled"; +}; + +/* Verdin ETH_1 (On-module PHY) */ +&cpsw_port1 { + phy-handle = <&cpsw3g_phy0>; + phy-mode = "rgmii-rxid"; + status = "disabled"; +}; + +/* Verdin ETH_2_RGMII */ +&cpsw_port2 { + status = "disabled"; +}; + +/* MDIO, shared by Verdin ETH_1 (On-module PHY) and Verdin ETH_2_RGMII */ +&cpsw3g_mdio { + assigned-clocks = <&k3_clks 157 20>; + assigned-clock-parents = <&k3_clks 157 22>; + assigned-clock-rates = <25000000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_eth_clock>, <&pinctrl_mdio>; + status = "disabled"; + + cpsw3g_phy0: ethernet-phy@0 { + compatible = "ethernet-phy-id2000.a231"; + reg = <0>; + interrupt-parent = <&main_gpio0>; + interrupts = <25 IRQ_TYPE_EDGE_FALLING>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_eth_int>, <&pinctrl_eth_reset>; + reset-gpios = <&main_gpio0 17 GPIO_ACTIVE_LOW>; + reset-assert-us = <10>; + reset-deassert-us = <1000>; + ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; + ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; + }; +}; + +/* Verdin PWM_1, PWM_2 */ +&epwm0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_epwm0_a>, <&pinctrl_epwm0_b>; + status = "disabled"; +}; + +/* Verdin PWM_3_DSI */ +&epwm1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_epwm1_a>; + status = "disabled"; +}; + +&main_gpio0 { + gpio-line-names = + "SODIMM_52", /* 0 */ + "", + "", + "SODIMM_56", + "SODIMM_58", + "SODIMM_60", + "SODIMM_62", + "", + "", + "", + "", /* 10 */ + "SODIMM_54", + "SODIMM_64", + "", + "", + "SODIMM_174", + "SODIMM_172", + "", + "", + "", + "", /* 20 */ + "", + "", + "", + "", + "", + "", + "", + "", + "SODIMM_76", + "SODIMM_21", /* 30 */ + "SODIMM_256", + "SODIMM_252", + "", + "SODIMM_46", + "SODIMM_42", + "SODIMM_218", + "", + "SODIMM_189", + "", + "SODIMM_216", /* 40 */ + "SODIMM_220", + "SODIMM_222", + "", + "", + "", + "", + "", + "", + "", + "", /* 50 */ + "", + "", + "", + "", + "", + "", + "", + "", + "", + "", /* 60 */ + "", + "", + "", + "", + "", + "", + "", + "", + "", + "", /* 70 */ + "SODIMM_157", + "SODIMM_187", + "", + "", + "", + "", + "", + "", + "", + "", /* 80 */ + "", + "", + "", + "", + "", + ""; + + verdin_ctrl_sleep_moci: ctrl-sleep-moci-hog { + gpio-hog; + /* Verdin CTRL_SLEEP_MOCI# (SODIMM 256) */ + gpios = <31 GPIO_ACTIVE_HIGH>; + line-name = "CTRL_SLEEP_MOCI#"; + output-high; + }; +}; + +&main_gpio1 { + gpio-line-names = + "", /* 0 */ + "", + "", + "", + "", + "", + "", + "", + "", + "", + "", /* 10 */ + "", + "", + "", + "", + "SODIMM_15", + "SODIMM_16", + "SODIMM_19", + "SODIMM_66", + "SODIMM_161", + "", /* 20 */ + "", + "", + "", + "", + "", + "", + "", + "", + "", + "", /* 30 */ + "", + "", + "", + "", + "", + "", + "", + "", + "", + "", /* 40 */ + "", + "", + "", + "", + "", + "", + "", + "", + "SODIMM_17", + "", /* 50 */ + "", + "", + "", + "", + "", + "", + "", + "", + "", + "", /* 60 */ + "", + "", + "", + "", + "", + "", + "", + "", + "", + "", /* 70 */ + "", + "", + "", + "", + "", + "", + "", + "", + "", + "", /* 80 */ + "", + "", + "", + "", + "", + "", + ""; +}; + +/* On-module I2C - PMIC_I2C */ +&main_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c0>; + clock-frequency = <400000>; + status = "okay"; + + dsi_bridge: dsi@e { + compatible = "toshiba,tc358778"; + reg = <0xe>; + assigned-clocks = <&k3_clks 157 20>; + assigned-clock-parents = <&k3_clks 157 22>; + assigned-clock-rates = <25000000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_bridge_reset>; + clocks = <&k3_clks 157 20>; + clock-names = "refclk"; + reset-gpios = <&main_gpio0 20 GPIO_ACTIVE_LOW>; + vddc-supply = <®_1v2_dsi>; + vddmipi-supply = <®_1v2_dsi>; + vddio-supply = <®_1v8_dsi>; + + dsi_bridge_ports: ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + rgb_in: endpoint { + data-lines = <18>; + }; + }; + + port@1 { + reg = <1>; + }; + }; + }; + + pmic@30 { + compatible = "ti,tps65219"; + reg = <0x30>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pmic_extint>; + interrupt-parent = <&gic500>; + interrupts = <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>; + + buck1-supply = <®_vsodimm>; + buck2-supply = <®_vsodimm>; + buck3-supply = <®_vsodimm>; + ldo1-supply = <®_3v3>; + ldo2-supply = <®_1v8>; + ldo3-supply = <®_3v3>; + ldo4-supply = <®_3v3>; + system-power-controller; + ti,power-button; + + regulators { + reg_vdd_core: buck1 { + regulator-always-on; + regulator-boot-on; + regulator-max-microvolt = <850000>; + regulator-min-microvolt = <850000>; + regulator-name = "+VDD_CORE (PMIC BUCK1)"; + }; + + reg_1v8: buck2 { + regulator-always-on; + regulator-boot-on; + regulator-max-microvolt = <1800000>; + regulator-min-microvolt = <1800000>; + regulator-name = "+V1.8 (PMIC BUCK2)"; /* On-module and SODIMM 214 */ + }; + + reg_vdd_ddr: buck3 { + regulator-always-on; + regulator-boot-on; + regulator-max-microvolt = <1100000>; + regulator-min-microvolt = <1100000>; + regulator-name = "+VDD_DDR (PMIC BUCK3)"; + }; + + reg_sd_3v3_1v8: ldo1 { + regulator-allow-bypass; + regulator-always-on; + regulator-boot-on; + regulator-max-microvolt = <3300000>; + regulator-min-microvolt = <3300000>; + regulator-name = "+V3.3_1.8_SD (PMIC LDO1)"; + }; + + reg_vddr_core: ldo2 { + regulator-always-on; + regulator-boot-on; + regulator-max-microvolt = <850000>; + regulator-min-microvolt = <850000>; + regulator-name = "+VDDR_CORE (PMIC LDO2)"; + }; + + reg_1v8a: ldo3 { + regulator-always-on; + regulator-boot-on; + regulator-max-microvolt = <1800000>; + regulator-min-microvolt = <1800000>; + regulator-name = "+V1.8A (PMIC LDO3)"; + }; + + reg_eth_2v5: ldo4 { + regulator-always-on; + regulator-boot-on; + regulator-max-microvolt = <2500000>; + regulator-min-microvolt = <2500000>; + regulator-name = "+V2.5_ETH (PMIC LDO4)"; + }; + }; + }; + + rtc_i2c: rtc@32 { + compatible = "epson,rx8130"; + reg = <0x32>; + }; + + sensor@48 { + compatible = "ti,tmp1075"; + reg = <0x48>; + }; + + adc@49 { + compatible = "ti,ads1015"; + reg = <0x49>; + #address-cells = <1>; + #size-cells = <0>; + + /* Verdin PMIC_I2C (ADC_4 - ADC_3) */ + channel@0 { + reg = <0>; + ti,datarate = <4>; + ti,gain = <2>; + }; + + /* Verdin PMIC_I2C (ADC_4 - ADC_1) */ + channel@1 { + reg = <1>; + ti,datarate = <4>; + ti,gain = <2>; + }; + + /* Verdin PMIC_I2C (ADC_3 - ADC_1) */ + channel@2 { + reg = <2>; + ti,datarate = <4>; + ti,gain = <2>; + }; + + /* Verdin PMIC_I2C (ADC_2 - ADC_1) */ + channel@3 { + reg = <3>; + ti,datarate = <4>; + ti,gain = <2>; + }; + + /* Verdin PMIC_I2C ADC_4 */ + channel@4 { + reg = <4>; + ti,datarate = <4>; + ti,gain = <2>; + }; + + /* Verdin PMIC_I2C ADC_3 */ + channel@5 { + reg = <5>; + ti,datarate = <4>; + ti,gain = <2>; + }; + + /* Verdin PMIC_I2C ADC_2 */ + channel@6 { + reg = <6>; + ti,datarate = <4>; + ti,gain = <2>; + }; + + /* Verdin PMIC_I2C ADC_1 */ + channel@7 { + reg = <7>; + ti,datarate = <4>; + ti,gain = <2>; + }; + }; + + eeprom@50 { + compatible = "st,24c02", "atmel,24c02"; + pagesize = <16>; + reg = <0x50>; + }; +}; + +/* Verdin I2C_1 */ +&main_i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "disabled"; +}; + +/* Verdin I2C_2_DSI */ +&main_i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "disabled"; +}; + +/* Verdin I2C_4_CSI */ +&main_i2c3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + status = "disabled"; +}; + +&mailbox0_cluster0 { + mbox_m4_0: mbox-m4-0 { + ti,mbox-rx = <0 0 0>; + ti,mbox-tx = <1 0 0>; + }; +}; + +/* Verdin CAN_1 */ +&main_mcan0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_mcan0>; + status = "disabled"; +}; + +/* Verdin CAN_2 - Reserved to Cortex-M4 */ + +/* Verdin SPI_1 */ +&main_spi1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_spi1>; + ti,pindir-d0-out-d1-in; + status = "disabled"; +}; + +/* Verdin UART_3, used as the Linux console */ +&main_uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart0>; + status = "disabled"; +}; + +/* Verdin UART_1 */ +&main_uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "disabled"; +}; + +/* Verdin I2S_1 */ +&mcasp0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_mcasp0>; + op-mode = <0>; /* I2S mode */ + serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ + 1 2 0 0 + 0 0 0 0 + 0 0 0 0 + 0 0 0 0 + >; + tdm-slots = <2>; + rx-num-evt = <32>; + tx-num-evt = <32>; + #sound-dai-cells = <0>; + status = "disabled"; +}; + +/* Verdin I2S_2 */ +&mcasp1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_mcasp1>; + op-mode = <0>; /* I2S mode */ + serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ + 1 2 0 0 + 0 0 0 0 + 0 0 0 0 + 0 0 0 0 + >; + tdm-slots = <2>; + rx-num-evt = <32>; + tx-num-evt = <32>; + #sound-dai-cells = <0>; + status = "disabled"; +}; + +/* Verdin I2C_3_HDMI */ +&mcu_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_mcu_i2c0>; + status = "disabled"; +}; + +&mcu_gpio0 { + gpio-line-names = + "SODIMM_244", + "SODIMM_206", + "SODIMM_208", + "SODIMM_210", + "SODIMM_212", + "", + "", + "", + "", + "", + "", + "", + "", + "", + "", + "", + "", + "", + "", + "", + "", + "", + "", + ""; +}; + +/* Verdin UART_4 - Cortex-M4 UART */ +&mcu_uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_mcu_uart0>; + status = "disabled"; +}; + +/* Verdin QSPI_1 */ +&ospi0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ospi0>; + status = "disabled"; +}; + +/* On-module eMMC */ +&sdhci0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sdhci0>; + non-removable; + ti,driver-strength-ohm = <50>; + status = "okay"; +}; + +/* Verdin SD_1 */ +&sdhci1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sdhci1>; + disable-wp; + ti,driver-strength-ohm = <50>; + vmmc-supply = <®_sdhc1_vmmc>; + vqmmc-supply = <®_sdhc1_vqmmc>; + status = "disabled"; +}; + +#if 0 +/* Verdin USB_1 */ +&usbss0 { + ti,vbus-divider; + status = "disabled"; +}; + +/* TODO: role swich using ID pin */ +&usb0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb0>, <&pinctrl_usb0_id>; + status = "disabled"; +}; + +/* Verdin USB_2 */ +&usbss1 { + ti,vbus-divider; + status = "disabled"; +}; + +&usb1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb1>; + dr_mode = "host"; + status = "disabled"; +}; +#endif + +/* Verdin UART_2 */ +&wkup_uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wkup_uart0>; + status = "disabled"; +}; diff --git a/arch/arm/dts/k3-am625-verdin-lpddr4-1600MTs.dtsi b/arch/arm/dts/k3-am625-verdin-lpddr4-1600MTs.dtsi new file mode 100644 index 00000000000..9bad4309b49 --- /dev/null +++ b/arch/arm/dts/k3-am625-verdin-lpddr4-1600MTs.dtsi @@ -0,0 +1,2190 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * This file was generated with the + * AM62x SysConfig DDR Subsystem Register Configuration Tool v0.09.08 + * Fri Jun 09 2023 08:01:37 GMT+0200 (Central European Summer Time) + * DDR Type: LPDDR4 + * F0 = 50MHz F1 = NA F2 = 800MHz + * Density (per channel): 16Gb + * Write DBI: Enable + * Number of Ranks: 1 + */ + +#define DDRSS_PLL_FHS_CNT 3 +#define DDRSS_PLL_FREQUENCY_1 400000000 +#define DDRSS_PLL_FREQUENCY_2 400000000 + +#define DDRSS_CTL_0_DATA 0x00000B00 +#define DDRSS_CTL_1_DATA 0x00000000 +#define DDRSS_CTL_2_DATA 0x00000000 +#define DDRSS_CTL_3_DATA 0x00000000 +#define DDRSS_CTL_4_DATA 0x00000000 +#define DDRSS_CTL_5_DATA 0x00000000 +#define DDRSS_CTL_6_DATA 0x00000000 +#define DDRSS_CTL_7_DATA 0x00002710 +#define DDRSS_CTL_8_DATA 0x000186A0 +#define DDRSS_CTL_9_DATA 0x00000005 +#define DDRSS_CTL_10_DATA 0x00000064 +#define DDRSS_CTL_11_DATA 0x00027100 +#define DDRSS_CTL_12_DATA 0x00186A00 +#define DDRSS_CTL_13_DATA 0x00000005 +#define DDRSS_CTL_14_DATA 0x00000640 +#define DDRSS_CTL_15_DATA 0x00027100 +#define DDRSS_CTL_16_DATA 0x00186A00 +#define DDRSS_CTL_17_DATA 0x00000005 +#define DDRSS_CTL_18_DATA 0x00000640 +#define DDRSS_CTL_19_DATA 0x01010100 +#define DDRSS_CTL_20_DATA 0x01010100 +#define DDRSS_CTL_21_DATA 0x01000110 +#define DDRSS_CTL_22_DATA 0x02010002 +#define DDRSS_CTL_23_DATA 0x0000000A +#define DDRSS_CTL_24_DATA 0x000186A0 +#define DDRSS_CTL_25_DATA 0x00000000 +#define DDRSS_CTL_26_DATA 0x00000000 +#define DDRSS_CTL_27_DATA 0x00000000 +#define DDRSS_CTL_28_DATA 0x00000000 +#define DDRSS_CTL_29_DATA 0x00020200 +#define DDRSS_CTL_30_DATA 0x00000000 +#define DDRSS_CTL_31_DATA 0x00000000 +#define DDRSS_CTL_32_DATA 0x00000000 +#define DDRSS_CTL_33_DATA 0x00000000 +#define DDRSS_CTL_34_DATA 0x08000010 +#define DDRSS_CTL_35_DATA 0x00002020 +#define DDRSS_CTL_36_DATA 0x00000000 +#define DDRSS_CTL_37_DATA 0x00000000 +#define DDRSS_CTL_38_DATA 0x0000040C +#define DDRSS_CTL_39_DATA 0x00000000 +#define DDRSS_CTL_40_DATA 0x0000081C +#define DDRSS_CTL_41_DATA 0x00000000 +#define DDRSS_CTL_42_DATA 0x0000081C +#define DDRSS_CTL_43_DATA 0x00000000 +#define DDRSS_CTL_44_DATA 0x05000804 +#define DDRSS_CTL_45_DATA 0x00000B00 +#define DDRSS_CTL_46_DATA 0x09090004 +#define DDRSS_CTL_47_DATA 0x00000204 +#define DDRSS_CTL_48_DATA 0x00370008 +#define DDRSS_CTL_49_DATA 0x09090024 +#define DDRSS_CTL_50_DATA 0x00001910 +#define DDRSS_CTL_51_DATA 0x00370008 +#define DDRSS_CTL_52_DATA 0x09090024 +#define DDRSS_CTL_53_DATA 0x09001910 +#define DDRSS_CTL_54_DATA 0x000A0A09 +#define DDRSS_CTL_55_DATA 0x0400036D +#define DDRSS_CTL_56_DATA 0x09092004 +#define DDRSS_CTL_57_DATA 0x00000C0A +#define DDRSS_CTL_58_DATA 0x060036D8 +#define DDRSS_CTL_59_DATA 0x09092006 +#define DDRSS_CTL_60_DATA 0x00000C0A +#define DDRSS_CTL_61_DATA 0x060036D8 +#define DDRSS_CTL_62_DATA 0x03042006 +#define DDRSS_CTL_63_DATA 0x06050002 +#define DDRSS_CTL_64_DATA 0x10111011 +#define DDRSS_CTL_65_DATA 0x01010008 +#define DDRSS_CTL_66_DATA 0x0420200A +#define DDRSS_CTL_67_DATA 0x04131304 +#define DDRSS_CTL_68_DATA 0x00001313 +#define DDRSS_CTL_69_DATA 0x00000101 +#define DDRSS_CTL_70_DATA 0x00000000 +#define DDRSS_CTL_71_DATA 0x01000000 +#define DDRSS_CTL_72_DATA 0x00130803 +#define DDRSS_CTL_73_DATA 0x00000059 +#define DDRSS_CTL_74_DATA 0x00000130 +#define DDRSS_CTL_75_DATA 0x00000610 +#define DDRSS_CTL_76_DATA 0x00000130 +#define DDRSS_CTL_77_DATA 0x00000610 +#define DDRSS_CTL_78_DATA 0x00000005 +#define DDRSS_CTL_79_DATA 0x0000000A +#define DDRSS_CTL_80_DATA 0x00000004 +#define DDRSS_CTL_81_DATA 0x00000098 +#define DDRSS_CTL_82_DATA 0x000000BB +#define DDRSS_CTL_83_DATA 0x00000098 +#define DDRSS_CTL_84_DATA 0x000000BB +#define DDRSS_CTL_85_DATA 0x03004000 +#define DDRSS_CTL_86_DATA 0x00001201 +#define DDRSS_CTL_87_DATA 0x00060005 +#define DDRSS_CTL_88_DATA 0x00000006 +#define DDRSS_CTL_89_DATA 0x00000000 +#define DDRSS_CTL_90_DATA 0x05141408 +#define DDRSS_CTL_91_DATA 0x05030A05 +#define DDRSS_CTL_92_DATA 0x05030C06 +#define DDRSS_CTL_93_DATA 0x01030C06 +#define DDRSS_CTL_94_DATA 0x02010201 +#define DDRSS_CTL_95_DATA 0x00001401 +#define DDRSS_CTL_96_DATA 0x01360014 +#define DDRSS_CTL_97_DATA 0x01360136 +#define DDRSS_CTL_98_DATA 0x00000136 +#define DDRSS_CTL_99_DATA 0x00000000 +#define DDRSS_CTL_100_DATA 0x05010303 +#define DDRSS_CTL_101_DATA 0x0C040505 +#define DDRSS_CTL_102_DATA 0x06050203 +#define DDRSS_CTL_103_DATA 0x030C0605 +#define DDRSS_CTL_104_DATA 0x05060502 +#define DDRSS_CTL_105_DATA 0x03030306 +#define DDRSS_CTL_106_DATA 0x03010000 +#define DDRSS_CTL_107_DATA 0x00010000 +#define DDRSS_CTL_108_DATA 0x00000000 +#define DDRSS_CTL_109_DATA 0x01000000 +#define DDRSS_CTL_110_DATA 0x80104002 +#define DDRSS_CTL_111_DATA 0x00040003 +#define DDRSS_CTL_112_DATA 0x00040005 +#define DDRSS_CTL_113_DATA 0x00030000 +#define DDRSS_CTL_114_DATA 0x00050004 +#define DDRSS_CTL_115_DATA 0x00000004 +#define DDRSS_CTL_116_DATA 0x00040003 +#define DDRSS_CTL_117_DATA 0x00040005 +#define DDRSS_CTL_118_DATA 0x00000000 +#define DDRSS_CTL_119_DATA 0x00001640 +#define DDRSS_CTL_120_DATA 0x00001640 +#define DDRSS_CTL_121_DATA 0x00001640 +#define DDRSS_CTL_122_DATA 0x00001640 +#define DDRSS_CTL_123_DATA 0x00001640 +#define DDRSS_CTL_124_DATA 0x00000000 +#define DDRSS_CTL_125_DATA 0x0000026F +#define DDRSS_CTL_126_DATA 0x00018400 +#define DDRSS_CTL_127_DATA 0x00018400 +#define DDRSS_CTL_128_DATA 0x00018400 +#define DDRSS_CTL_129_DATA 0x00018400 +#define DDRSS_CTL_130_DATA 0x00018400 +#define DDRSS_CTL_131_DATA 0x00000000 +#define DDRSS_CTL_132_DATA 0x00002A70 +#define DDRSS_CTL_133_DATA 0x00018400 +#define DDRSS_CTL_134_DATA 0x00018400 +#define DDRSS_CTL_135_DATA 0x00018400 +#define DDRSS_CTL_136_DATA 0x00018400 +#define DDRSS_CTL_137_DATA 0x00018400 +#define DDRSS_CTL_138_DATA 0x00000000 +#define DDRSS_CTL_139_DATA 0x00002A70 +#define DDRSS_CTL_140_DATA 0x00000000 +#define DDRSS_CTL_141_DATA 0x00000000 +#define DDRSS_CTL_142_DATA 0x00000000 +#define DDRSS_CTL_143_DATA 0x00000000 +#define DDRSS_CTL_144_DATA 0x00000000 +#define DDRSS_CTL_145_DATA 0x00000000 +#define DDRSS_CTL_146_DATA 0x00000000 +#define DDRSS_CTL_147_DATA 0x00000000 +#define DDRSS_CTL_148_DATA 0x00000000 +#define DDRSS_CTL_149_DATA 0x00000000 +#define DDRSS_CTL_150_DATA 0x00000000 +#define DDRSS_CTL_151_DATA 0x00000000 +#define DDRSS_CTL_152_DATA 0x00000000 +#define DDRSS_CTL_153_DATA 0x00000000 +#define DDRSS_CTL_154_DATA 0x00000000 +#define DDRSS_CTL_155_DATA 0x00000000 +#define DDRSS_CTL_156_DATA 0x03050000 +#define DDRSS_CTL_157_DATA 0x03050305 +#define DDRSS_CTL_158_DATA 0x00000000 +#define DDRSS_CTL_159_DATA 0x08010000 +#define DDRSS_CTL_160_DATA 0x000E0808 +#define DDRSS_CTL_161_DATA 0x01000000 +#define DDRSS_CTL_162_DATA 0x0E080808 +#define DDRSS_CTL_163_DATA 0x00000000 +#define DDRSS_CTL_164_DATA 0x08080801 +#define DDRSS_CTL_165_DATA 0x0000080E +#define DDRSS_CTL_166_DATA 0x00040003 +#define DDRSS_CTL_167_DATA 0x00000007 +#define DDRSS_CTL_168_DATA 0x00000000 +#define DDRSS_CTL_169_DATA 0x00000000 +#define DDRSS_CTL_170_DATA 0x00000000 +#define DDRSS_CTL_171_DATA 0x00000000 +#define DDRSS_CTL_172_DATA 0x00000000 +#define DDRSS_CTL_173_DATA 0x00000000 +#define DDRSS_CTL_174_DATA 0x01000000 +#define DDRSS_CTL_175_DATA 0x00000000 +#define DDRSS_CTL_176_DATA 0x00001500 +#define DDRSS_CTL_177_DATA 0x0000100E +#define DDRSS_CTL_178_DATA 0x00000002 +#define DDRSS_CTL_179_DATA 0x00000000 +#define DDRSS_CTL_180_DATA 0x00000001 +#define DDRSS_CTL_181_DATA 0x00000002 +#define DDRSS_CTL_182_DATA 0x00000C00 +#define DDRSS_CTL_183_DATA 0x00001000 +#define DDRSS_CTL_184_DATA 0x00000C00 +#define DDRSS_CTL_185_DATA 0x00001000 +#define DDRSS_CTL_186_DATA 0x00000C00 +#define DDRSS_CTL_187_DATA 0x00001000 +#define DDRSS_CTL_188_DATA 0x00000000 +#define DDRSS_CTL_189_DATA 0x00000000 +#define DDRSS_CTL_190_DATA 0x00000000 +#define DDRSS_CTL_191_DATA 0x00000000 +#define DDRSS_CTL_192_DATA 0x0005000A +#define DDRSS_CTL_193_DATA 0x0404000D +#define DDRSS_CTL_194_DATA 0x0000000D +#define DDRSS_CTL_195_DATA 0x005000A0 +#define DDRSS_CTL_196_DATA 0x060600C8 +#define DDRSS_CTL_197_DATA 0x000000C8 +#define DDRSS_CTL_198_DATA 0x005000A0 +#define DDRSS_CTL_199_DATA 0x060600C8 +#define DDRSS_CTL_200_DATA 0x000000C8 +#define DDRSS_CTL_201_DATA 0x00000000 +#define DDRSS_CTL_202_DATA 0x00000000 +#define DDRSS_CTL_203_DATA 0x00000000 +#define DDRSS_CTL_204_DATA 0x00000000 +#define DDRSS_CTL_205_DATA 0x00000004 +#define DDRSS_CTL_206_DATA 0x00000000 +#define DDRSS_CTL_207_DATA 0x00000000 +#define DDRSS_CTL_208_DATA 0x00000024 +#define DDRSS_CTL_209_DATA 0x00000012 +#define DDRSS_CTL_210_DATA 0x00000000 +#define DDRSS_CTL_211_DATA 0x00000024 +#define DDRSS_CTL_212_DATA 0x00000012 +#define DDRSS_CTL_213_DATA 0x00000000 +#define DDRSS_CTL_214_DATA 0x00000004 +#define DDRSS_CTL_215_DATA 0x00000000 +#define DDRSS_CTL_216_DATA 0x00000000 +#define DDRSS_CTL_217_DATA 0x00000024 +#define DDRSS_CTL_218_DATA 0x00000012 +#define DDRSS_CTL_219_DATA 0x00000000 +#define DDRSS_CTL_220_DATA 0x00000024 +#define DDRSS_CTL_221_DATA 0x00000012 +#define DDRSS_CTL_222_DATA 0x00000000 +#define DDRSS_CTL_223_DATA 0x00000000 +#define DDRSS_CTL_224_DATA 0x00000031 +#define DDRSS_CTL_225_DATA 0x000000B1 +#define DDRSS_CTL_226_DATA 0x000000B1 +#define DDRSS_CTL_227_DATA 0x00000031 +#define DDRSS_CTL_228_DATA 0x000000B1 +#define DDRSS_CTL_229_DATA 0x000000B1 +#define DDRSS_CTL_230_DATA 0x00000000 +#define DDRSS_CTL_231_DATA 0x00000000 +#define DDRSS_CTL_232_DATA 0x00000000 +#define DDRSS_CTL_233_DATA 0x00000000 +#define DDRSS_CTL_234_DATA 0x00000000 +#define DDRSS_CTL_235_DATA 0x00000000 +#define DDRSS_CTL_236_DATA 0x00000000 +#define DDRSS_CTL_237_DATA 0x00000000 +#define DDRSS_CTL_238_DATA 0x00000000 +#define DDRSS_CTL_239_DATA 0x00000000 +#define DDRSS_CTL_240_DATA 0x00000000 +#define DDRSS_CTL_241_DATA 0x00000000 +#define DDRSS_CTL_242_DATA 0x00000000 +#define DDRSS_CTL_243_DATA 0x00000000 +#define DDRSS_CTL_244_DATA 0x00000000 +#define DDRSS_CTL_245_DATA 0x00000000 +#define DDRSS_CTL_246_DATA 0x00000000 +#define DDRSS_CTL_247_DATA 0x00000000 +#define DDRSS_CTL_248_DATA 0x00000000 +#define DDRSS_CTL_249_DATA 0x00000000 +#define DDRSS_CTL_250_DATA 0x00000000 +#define DDRSS_CTL_251_DATA 0x00000000 +#define DDRSS_CTL_252_DATA 0x00000000 +#define DDRSS_CTL_253_DATA 0x00000000 +#define DDRSS_CTL_254_DATA 0x46004646 +#define DDRSS_CTL_255_DATA 0x00002746 +#define DDRSS_CTL_256_DATA 0x00000027 +#define DDRSS_CTL_257_DATA 0x00000027 +#define DDRSS_CTL_258_DATA 0x00000027 +#define DDRSS_CTL_259_DATA 0x00000027 +#define DDRSS_CTL_260_DATA 0x00000027 +#define DDRSS_CTL_261_DATA 0x00000000 +#define DDRSS_CTL_262_DATA 0x00000000 +#define DDRSS_CTL_263_DATA 0x0000000F +#define DDRSS_CTL_264_DATA 0x0000000F +#define DDRSS_CTL_265_DATA 0x0000000F +#define DDRSS_CTL_266_DATA 0x0000000F +#define DDRSS_CTL_267_DATA 0x0000000F +#define DDRSS_CTL_268_DATA 0x0000000F +#define DDRSS_CTL_269_DATA 0x00000000 +#define DDRSS_CTL_270_DATA 0x00001000 +#define DDRSS_CTL_271_DATA 0x00000015 +#define DDRSS_CTL_272_DATA 0x00000015 +#define DDRSS_CTL_273_DATA 0x00000010 +#define DDRSS_CTL_274_DATA 0x00000015 +#define DDRSS_CTL_275_DATA 0x00000015 +#define DDRSS_CTL_276_DATA 0x00000020 +#define DDRSS_CTL_277_DATA 0x00010000 +#define DDRSS_CTL_278_DATA 0x00000100 +#define DDRSS_CTL_279_DATA 0x00000000 +#define DDRSS_CTL_280_DATA 0x00000000 +#define DDRSS_CTL_281_DATA 0x00000101 +#define DDRSS_CTL_282_DATA 0x00000000 +#define DDRSS_CTL_283_DATA 0x00000000 +#define DDRSS_CTL_284_DATA 0x00000000 +#define DDRSS_CTL_285_DATA 0x00000000 +#define DDRSS_CTL_286_DATA 0x00000000 +#define DDRSS_CTL_287_DATA 0x00000000 +#define DDRSS_CTL_288_DATA 0x00000000 +#define DDRSS_CTL_289_DATA 0x00000000 +#define DDRSS_CTL_290_DATA 0x0C181511 +#define DDRSS_CTL_291_DATA 0x00000304 +#define DDRSS_CTL_292_DATA 0x00000000 +#define DDRSS_CTL_293_DATA 0x00000000 +#define DDRSS_CTL_294_DATA 0x00000000 +#define DDRSS_CTL_295_DATA 0x00000000 +#define DDRSS_CTL_296_DATA 0x00000000 +#define DDRSS_CTL_297_DATA 0x00000000 +#define DDRSS_CTL_298_DATA 0x00000000 +#define DDRSS_CTL_299_DATA 0x00000000 +#define DDRSS_CTL_300_DATA 0x00000000 +#define DDRSS_CTL_301_DATA 0x00000000 +#define DDRSS_CTL_302_DATA 0x00000000 +#define DDRSS_CTL_303_DATA 0x00000000 +#define DDRSS_CTL_304_DATA 0x00000000 +#define DDRSS_CTL_305_DATA 0x00020000 +#define DDRSS_CTL_306_DATA 0x00400100 +#define DDRSS_CTL_307_DATA 0x00080032 +#define DDRSS_CTL_308_DATA 0x01000200 +#define DDRSS_CTL_309_DATA 0x03200040 +#define DDRSS_CTL_310_DATA 0x00020018 +#define DDRSS_CTL_311_DATA 0x00400100 +#define DDRSS_CTL_312_DATA 0x00180320 +#define DDRSS_CTL_313_DATA 0x00030000 +#define DDRSS_CTL_314_DATA 0x00280028 +#define DDRSS_CTL_315_DATA 0x00000100 +#define DDRSS_CTL_316_DATA 0x01010000 +#define DDRSS_CTL_317_DATA 0x00000000 +#define DDRSS_CTL_318_DATA 0x3FFF0000 +#define DDRSS_CTL_319_DATA 0x000FFF00 +#define DDRSS_CTL_320_DATA 0xFFFFFFFF +#define DDRSS_CTL_321_DATA 0x00FFFF00 +#define DDRSS_CTL_322_DATA 0x0B000000 +#define DDRSS_CTL_323_DATA 0x0001FFFF +#define DDRSS_CTL_324_DATA 0x01010101 +#define DDRSS_CTL_325_DATA 0x01010101 +#define DDRSS_CTL_326_DATA 0x00000118 +#define DDRSS_CTL_327_DATA 0x00000C01 +#define DDRSS_CTL_328_DATA 0x01000100 +#define DDRSS_CTL_329_DATA 0x00000000 +#define DDRSS_CTL_330_DATA 0x00000000 +#define DDRSS_CTL_331_DATA 0x01030303 +#define DDRSS_CTL_332_DATA 0x00000001 +#define DDRSS_CTL_333_DATA 0x00000000 +#define DDRSS_CTL_334_DATA 0x00000000 +#define DDRSS_CTL_335_DATA 0x00000000 +#define DDRSS_CTL_336_DATA 0x00000000 +#define DDRSS_CTL_337_DATA 0x00000000 +#define DDRSS_CTL_338_DATA 0x00000000 +#define DDRSS_CTL_339_DATA 0x00000000 +#define DDRSS_CTL_340_DATA 0x00000000 +#define DDRSS_CTL_341_DATA 0x00000000 +#define DDRSS_CTL_342_DATA 0x00000000 +#define DDRSS_CTL_343_DATA 0x00000000 +#define DDRSS_CTL_344_DATA 0x00000000 +#define DDRSS_CTL_345_DATA 0x00000000 +#define DDRSS_CTL_346_DATA 0x00000000 +#define DDRSS_CTL_347_DATA 0x00000000 +#define DDRSS_CTL_348_DATA 0x00000000 +#define DDRSS_CTL_349_DATA 0x00000000 +#define DDRSS_CTL_350_DATA 0x00000000 +#define DDRSS_CTL_351_DATA 0x00000000 +#define DDRSS_CTL_352_DATA 0x00000000 +#define DDRSS_CTL_353_DATA 0x00000000 +#define DDRSS_CTL_354_DATA 0x00000000 +#define DDRSS_CTL_355_DATA 0x00000000 +#define DDRSS_CTL_356_DATA 0x00000000 +#define DDRSS_CTL_357_DATA 0x00000000 +#define DDRSS_CTL_358_DATA 0x00000000 +#define DDRSS_CTL_359_DATA 0x00000000 +#define DDRSS_CTL_360_DATA 0x00000000 +#define DDRSS_CTL_361_DATA 0x00000000 +#define DDRSS_CTL_362_DATA 0x00000000 +#define DDRSS_CTL_363_DATA 0x00000000 +#define DDRSS_CTL_364_DATA 0x00000000 +#define DDRSS_CTL_365_DATA 0x00000000 +#define DDRSS_CTL_366_DATA 0x00000000 +#define DDRSS_CTL_367_DATA 0x00000000 +#define DDRSS_CTL_368_DATA 0x00000000 +#define DDRSS_CTL_369_DATA 0x00000000 +#define DDRSS_CTL_370_DATA 0x00000000 +#define DDRSS_CTL_371_DATA 0x01000101 +#define DDRSS_CTL_372_DATA 0x01010001 +#define DDRSS_CTL_373_DATA 0x00010101 +#define DDRSS_CTL_374_DATA 0x01050503 +#define DDRSS_CTL_375_DATA 0x05020201 +#define DDRSS_CTL_376_DATA 0x08080C0C +#define DDRSS_CTL_377_DATA 0x00080308 +#define DDRSS_CTL_378_DATA 0x000B030E +#define DDRSS_CTL_379_DATA 0x000B0310 +#define DDRSS_CTL_380_DATA 0x0B0B0810 +#define DDRSS_CTL_381_DATA 0x01000000 +#define DDRSS_CTL_382_DATA 0x03020301 +#define DDRSS_CTL_383_DATA 0x04000102 +#define DDRSS_CTL_384_DATA 0x1B000004 +#define DDRSS_CTL_385_DATA 0x000000B2 +#define DDRSS_CTL_386_DATA 0x00000200 +#define DDRSS_CTL_387_DATA 0x00000200 +#define DDRSS_CTL_388_DATA 0x00000200 +#define DDRSS_CTL_389_DATA 0x00000200 +#define DDRSS_CTL_390_DATA 0x00000321 +#define DDRSS_CTL_391_DATA 0x000006F4 +#define DDRSS_CTL_392_DATA 0x03050202 +#define DDRSS_CTL_393_DATA 0x00260201 +#define DDRSS_CTL_394_DATA 0x00000C20 +#define DDRSS_CTL_395_DATA 0x00000200 +#define DDRSS_CTL_396_DATA 0x00000200 +#define DDRSS_CTL_397_DATA 0x00000200 +#define DDRSS_CTL_398_DATA 0x00000200 +#define DDRSS_CTL_399_DATA 0x00003690 +#define DDRSS_CTL_400_DATA 0x00007940 +#define DDRSS_CTL_401_DATA 0x070D0402 +#define DDRSS_CTL_402_DATA 0x00260405 +#define DDRSS_CTL_403_DATA 0x00000C20 +#define DDRSS_CTL_404_DATA 0x00000200 +#define DDRSS_CTL_405_DATA 0x00000200 +#define DDRSS_CTL_406_DATA 0x00000200 +#define DDRSS_CTL_407_DATA 0x00000200 +#define DDRSS_CTL_408_DATA 0x00003690 +#define DDRSS_CTL_409_DATA 0x00007940 +#define DDRSS_CTL_410_DATA 0x070D0402 +#define DDRSS_CTL_411_DATA 0x00000405 +#define DDRSS_CTL_412_DATA 0x00000000 +#define DDRSS_CTL_413_DATA 0x0302000A +#define DDRSS_CTL_414_DATA 0x01000500 +#define DDRSS_CTL_415_DATA 0x01010001 +#define DDRSS_CTL_416_DATA 0x00010001 +#define DDRSS_CTL_417_DATA 0x01010001 +#define DDRSS_CTL_418_DATA 0x02010000 +#define DDRSS_CTL_419_DATA 0x00000200 +#define DDRSS_CTL_420_DATA 0x02000201 +#define DDRSS_CTL_421_DATA 0x10100600 +#define DDRSS_CTL_422_DATA 0x00202020 +#define DDRSS_PI_0_DATA 0x00000B00 +#define DDRSS_PI_1_DATA 0x00000000 +#define DDRSS_PI_2_DATA 0x00000000 +#define DDRSS_PI_3_DATA 0x01000000 +#define DDRSS_PI_4_DATA 0x00000001 +#define DDRSS_PI_5_DATA 0x00010064 +#define DDRSS_PI_6_DATA 0x00000000 +#define DDRSS_PI_7_DATA 0x00000000 +#define DDRSS_PI_8_DATA 0x00000000 +#define DDRSS_PI_9_DATA 0x00000000 +#define DDRSS_PI_10_DATA 0x00000000 +#define DDRSS_PI_11_DATA 0x00000002 +#define DDRSS_PI_12_DATA 0x00000005 +#define DDRSS_PI_13_DATA 0x00010001 +#define DDRSS_PI_14_DATA 0x08000000 +#define DDRSS_PI_15_DATA 0x00010300 +#define DDRSS_PI_16_DATA 0x00000005 +#define DDRSS_PI_17_DATA 0x00000000 +#define DDRSS_PI_18_DATA 0x00000000 +#define DDRSS_PI_19_DATA 0x00000000 +#define DDRSS_PI_20_DATA 0x00000000 +#define DDRSS_PI_21_DATA 0x00000000 +#define DDRSS_PI_22_DATA 0x00000000 +#define DDRSS_PI_23_DATA 0x00010000 +#define DDRSS_PI_24_DATA 0x280A0001 +#define DDRSS_PI_25_DATA 0x00000000 +#define DDRSS_PI_26_DATA 0x00010000 +#define DDRSS_PI_27_DATA 0x00003200 +#define DDRSS_PI_28_DATA 0x00000000 +#define DDRSS_PI_29_DATA 0x00000000 +#define DDRSS_PI_30_DATA 0x01010102 +#define DDRSS_PI_31_DATA 0x00000000 +#define DDRSS_PI_32_DATA 0x00000000 +#define DDRSS_PI_33_DATA 0x00000000 +#define DDRSS_PI_34_DATA 0x00000001 +#define DDRSS_PI_35_DATA 0x000000AA +#define DDRSS_PI_36_DATA 0x00000055 +#define DDRSS_PI_37_DATA 0x000000B5 +#define DDRSS_PI_38_DATA 0x0000004A +#define DDRSS_PI_39_DATA 0x00000056 +#define DDRSS_PI_40_DATA 0x000000A9 +#define DDRSS_PI_41_DATA 0x000000A9 +#define DDRSS_PI_42_DATA 0x000000B5 +#define DDRSS_PI_43_DATA 0x00000000 +#define DDRSS_PI_44_DATA 0x00000000 +#define DDRSS_PI_45_DATA 0x00010100 +#define DDRSS_PI_46_DATA 0x00000015 +#define DDRSS_PI_47_DATA 0x000007D0 +#define DDRSS_PI_48_DATA 0x00000300 +#define DDRSS_PI_49_DATA 0x00000000 +#define DDRSS_PI_50_DATA 0x00000000 +#define DDRSS_PI_51_DATA 0x01000000 +#define DDRSS_PI_52_DATA 0x00010101 +#define DDRSS_PI_53_DATA 0x01000000 +#define DDRSS_PI_54_DATA 0x03000000 +#define DDRSS_PI_55_DATA 0x00000000 +#define DDRSS_PI_56_DATA 0x00001701 +#define DDRSS_PI_57_DATA 0x00000000 +#define DDRSS_PI_58_DATA 0x00000000 +#define DDRSS_PI_59_DATA 0x00000000 +#define DDRSS_PI_60_DATA 0x0A0A140A +#define DDRSS_PI_61_DATA 0x10020101 +#define DDRSS_PI_62_DATA 0x01000210 +#define DDRSS_PI_63_DATA 0x05000404 +#define DDRSS_PI_64_DATA 0x00010001 +#define DDRSS_PI_65_DATA 0x0001000E +#define DDRSS_PI_66_DATA 0x01010100 +#define DDRSS_PI_67_DATA 0x00010000 +#define DDRSS_PI_68_DATA 0x00000034 +#define DDRSS_PI_69_DATA 0x00000000 +#define DDRSS_PI_70_DATA 0x00000000 +#define DDRSS_PI_71_DATA 0x0000FFFF +#define DDRSS_PI_72_DATA 0x00000000 +#define DDRSS_PI_73_DATA 0x00000000 +#define DDRSS_PI_74_DATA 0x00000000 +#define DDRSS_PI_75_DATA 0x00000000 +#define DDRSS_PI_76_DATA 0x01000000 +#define DDRSS_PI_77_DATA 0x08000100 +#define DDRSS_PI_78_DATA 0x00020000 +#define DDRSS_PI_79_DATA 0x00010002 +#define DDRSS_PI_80_DATA 0x00000001 +#define DDRSS_PI_81_DATA 0x00020001 +#define DDRSS_PI_82_DATA 0x00020002 +#define DDRSS_PI_83_DATA 0x00000000 +#define DDRSS_PI_84_DATA 0x00000000 +#define DDRSS_PI_85_DATA 0x00000000 +#define DDRSS_PI_86_DATA 0x00000000 +#define DDRSS_PI_87_DATA 0x00000000 +#define DDRSS_PI_88_DATA 0x00000000 +#define DDRSS_PI_89_DATA 0x00000000 +#define DDRSS_PI_90_DATA 0x00000000 +#define DDRSS_PI_91_DATA 0x00000400 +#define DDRSS_PI_92_DATA 0x0A090B0C +#define DDRSS_PI_93_DATA 0x04060708 +#define DDRSS_PI_94_DATA 0x01000005 +#define DDRSS_PI_95_DATA 0x00000800 +#define DDRSS_PI_96_DATA 0x00000000 +#define DDRSS_PI_97_DATA 0x00010008 +#define DDRSS_PI_98_DATA 0x00000000 +#define DDRSS_PI_99_DATA 0x0000AA00 +#define DDRSS_PI_100_DATA 0x00000000 +#define DDRSS_PI_101_DATA 0x00010000 +#define DDRSS_PI_102_DATA 0x00000000 +#define DDRSS_PI_103_DATA 0x00000000 +#define DDRSS_PI_104_DATA 0x00000000 +#define DDRSS_PI_105_DATA 0x00000000 +#define DDRSS_PI_106_DATA 0x00000000 +#define DDRSS_PI_107_DATA 0x00000000 +#define DDRSS_PI_108_DATA 0x00000000 +#define DDRSS_PI_109_DATA 0x00000000 +#define DDRSS_PI_110_DATA 0x00000000 +#define DDRSS_PI_111_DATA 0x00000000 +#define DDRSS_PI_112_DATA 0x00000000 +#define DDRSS_PI_113_DATA 0x00000000 +#define DDRSS_PI_114_DATA 0x00000000 +#define DDRSS_PI_115_DATA 0x00000000 +#define DDRSS_PI_116_DATA 0x00000000 +#define DDRSS_PI_117_DATA 0x00000000 +#define DDRSS_PI_118_DATA 0x00000000 +#define DDRSS_PI_119_DATA 0x00000000 +#define DDRSS_PI_120_DATA 0x00000000 +#define DDRSS_PI_121_DATA 0x00000000 +#define DDRSS_PI_122_DATA 0x00000000 +#define DDRSS_PI_123_DATA 0x00000000 +#define DDRSS_PI_124_DATA 0x00000008 +#define DDRSS_PI_125_DATA 0x00000000 +#define DDRSS_PI_126_DATA 0x00000000 +#define DDRSS_PI_127_DATA 0x00000000 +#define DDRSS_PI_128_DATA 0x00000000 +#define DDRSS_PI_129_DATA 0x00000000 +#define DDRSS_PI_130_DATA 0x00000000 +#define DDRSS_PI_131_DATA 0x00000000 +#define DDRSS_PI_132_DATA 0x00000000 +#define DDRSS_PI_133_DATA 0x00010000 +#define DDRSS_PI_134_DATA 0x00000000 +#define DDRSS_PI_135_DATA 0x00000000 +#define DDRSS_PI_136_DATA 0x0000000A +#define DDRSS_PI_137_DATA 0x000186A0 +#define DDRSS_PI_138_DATA 0x00000100 +#define DDRSS_PI_139_DATA 0x00000000 +#define DDRSS_PI_140_DATA 0x00000000 +#define DDRSS_PI_141_DATA 0x00000000 +#define DDRSS_PI_142_DATA 0x00000000 +#define DDRSS_PI_143_DATA 0x00000000 +#define DDRSS_PI_144_DATA 0x01000000 +#define DDRSS_PI_145_DATA 0x00010003 +#define DDRSS_PI_146_DATA 0x02000101 +#define DDRSS_PI_147_DATA 0x01030001 +#define DDRSS_PI_148_DATA 0x00010400 +#define DDRSS_PI_149_DATA 0x06000105 +#define DDRSS_PI_150_DATA 0x01070001 +#define DDRSS_PI_151_DATA 0x00000000 +#define DDRSS_PI_152_DATA 0x00000000 +#define DDRSS_PI_153_DATA 0x00000000 +#define DDRSS_PI_154_DATA 0x00010001 +#define DDRSS_PI_155_DATA 0x00000000 +#define DDRSS_PI_156_DATA 0x00000000 +#define DDRSS_PI_157_DATA 0x00000000 +#define DDRSS_PI_158_DATA 0x00000000 +#define DDRSS_PI_159_DATA 0x00010000 +#define DDRSS_PI_160_DATA 0x00000004 +#define DDRSS_PI_161_DATA 0x00000000 +#define DDRSS_PI_162_DATA 0x00000000 +#define DDRSS_PI_163_DATA 0x00000000 +#define DDRSS_PI_164_DATA 0x00000800 +#define DDRSS_PI_165_DATA 0x00780078 +#define DDRSS_PI_166_DATA 0x00101001 +#define DDRSS_PI_167_DATA 0x00000034 +#define DDRSS_PI_168_DATA 0x00000043 +#define DDRSS_PI_169_DATA 0x00020043 +#define DDRSS_PI_170_DATA 0x02000200 +#define DDRSS_PI_171_DATA 0x00000004 +#define DDRSS_PI_172_DATA 0x0000080C +#define DDRSS_PI_173_DATA 0x00081C00 +#define DDRSS_PI_174_DATA 0x001C0000 +#define DDRSS_PI_175_DATA 0x00000013 +#define DDRSS_PI_176_DATA 0x00000059 +#define DDRSS_PI_177_DATA 0x00000130 +#define DDRSS_PI_178_DATA 0x00000610 +#define DDRSS_PI_179_DATA 0x00000130 +#define DDRSS_PI_180_DATA 0x04000610 +#define DDRSS_PI_181_DATA 0x01010404 +#define DDRSS_PI_182_DATA 0x00001501 +#define DDRSS_PI_183_DATA 0x001D001D +#define DDRSS_PI_184_DATA 0x01000100 +#define DDRSS_PI_185_DATA 0x00000100 +#define DDRSS_PI_186_DATA 0x00000000 +#define DDRSS_PI_187_DATA 0x05050503 +#define DDRSS_PI_188_DATA 0x01010C0C +#define DDRSS_PI_189_DATA 0x01010101 +#define DDRSS_PI_190_DATA 0x000C0C0A +#define DDRSS_PI_191_DATA 0x00000000 +#define DDRSS_PI_192_DATA 0x00000000 +#define DDRSS_PI_193_DATA 0x04000000 +#define DDRSS_PI_194_DATA 0x04020808 +#define DDRSS_PI_195_DATA 0x04040204 +#define DDRSS_PI_196_DATA 0x00090031 +#define DDRSS_PI_197_DATA 0x00110039 +#define DDRSS_PI_198_DATA 0x00110039 +#define DDRSS_PI_199_DATA 0x01010101 +#define DDRSS_PI_200_DATA 0x0002000D +#define DDRSS_PI_201_DATA 0x000200C8 +#define DDRSS_PI_202_DATA 0x010000C8 +#define DDRSS_PI_203_DATA 0x000E000E +#define DDRSS_PI_204_DATA 0x00C90100 +#define DDRSS_PI_205_DATA 0x010000C9 +#define DDRSS_PI_206_DATA 0x00C900C9 +#define DDRSS_PI_207_DATA 0x32103200 +#define DDRSS_PI_208_DATA 0x01013210 +#define DDRSS_PI_209_DATA 0x0A070601 +#define DDRSS_PI_210_DATA 0x0D09070D +#define DDRSS_PI_211_DATA 0x0D09070D +#define DDRSS_PI_212_DATA 0x000C000D +#define DDRSS_PI_213_DATA 0x00001000 +#define DDRSS_PI_214_DATA 0x00000C00 +#define DDRSS_PI_215_DATA 0x00001000 +#define DDRSS_PI_216_DATA 0x00000C00 +#define DDRSS_PI_217_DATA 0x02001000 +#define DDRSS_PI_218_DATA 0x0016000D +#define DDRSS_PI_219_DATA 0x001600C8 +#define DDRSS_PI_220_DATA 0x000000C8 +#define DDRSS_PI_221_DATA 0x00001900 +#define DDRSS_PI_222_DATA 0x32000056 +#define DDRSS_PI_223_DATA 0x06000101 +#define DDRSS_PI_224_DATA 0x001D0204 +#define DDRSS_PI_225_DATA 0x32120058 +#define DDRSS_PI_226_DATA 0x05000101 +#define DDRSS_PI_227_DATA 0x001D0408 +#define DDRSS_PI_228_DATA 0x32120058 +#define DDRSS_PI_229_DATA 0x05000101 +#define DDRSS_PI_230_DATA 0x00000408 +#define DDRSS_PI_231_DATA 0x05040900 +#define DDRSS_PI_232_DATA 0x00060900 +#define DDRSS_PI_233_DATA 0x00000315 +#define DDRSS_PI_234_DATA 0x20010004 +#define DDRSS_PI_235_DATA 0x0A0A0A03 +#define DDRSS_PI_236_DATA 0x13090000 +#define DDRSS_PI_237_DATA 0x10090011 +#define DDRSS_PI_238_DATA 0x0000315C +#define DDRSS_PI_239_DATA 0x20030024 +#define DDRSS_PI_240_DATA 0x0C0A0C0C +#define DDRSS_PI_241_DATA 0x13090000 +#define DDRSS_PI_242_DATA 0x10090011 +#define DDRSS_PI_243_DATA 0x0000315C +#define DDRSS_PI_244_DATA 0x20030024 +#define DDRSS_PI_245_DATA 0x0C0A0C0C +#define DDRSS_PI_246_DATA 0x00000000 +#define DDRSS_PI_247_DATA 0x000000B2 +#define DDRSS_PI_248_DATA 0x000006F4 +#define DDRSS_PI_249_DATA 0x00000C20 +#define DDRSS_PI_250_DATA 0x00007940 +#define DDRSS_PI_251_DATA 0x00000C20 +#define DDRSS_PI_252_DATA 0x00007940 +#define DDRSS_PI_253_DATA 0x01360014 +#define DDRSS_PI_254_DATA 0x03030136 +#define DDRSS_PI_255_DATA 0x00000003 +#define DDRSS_PI_256_DATA 0x00000000 +#define DDRSS_PI_257_DATA 0x05030503 +#define DDRSS_PI_258_DATA 0x00000503 +#define DDRSS_PI_259_DATA 0x00002710 +#define DDRSS_PI_260_DATA 0x000186A0 +#define DDRSS_PI_261_DATA 0x00000005 +#define DDRSS_PI_262_DATA 0x00000064 +#define DDRSS_PI_263_DATA 0x00000014 +#define DDRSS_PI_264_DATA 0x00027100 +#define DDRSS_PI_265_DATA 0x000186A0 +#define DDRSS_PI_266_DATA 0x00000005 +#define DDRSS_PI_267_DATA 0x00000640 +#define DDRSS_PI_268_DATA 0x00000136 +#define DDRSS_PI_269_DATA 0x00027100 +#define DDRSS_PI_270_DATA 0x000186A0 +#define DDRSS_PI_271_DATA 0x00000005 +#define DDRSS_PI_272_DATA 0x00000640 +#define DDRSS_PI_273_DATA 0x01000136 +#define DDRSS_PI_274_DATA 0x00320040 +#define DDRSS_PI_275_DATA 0x00010008 +#define DDRSS_PI_276_DATA 0x03200040 +#define DDRSS_PI_277_DATA 0x00010018 +#define DDRSS_PI_278_DATA 0x03200040 +#define DDRSS_PI_279_DATA 0x00000318 +#define DDRSS_PI_280_DATA 0x00280028 +#define DDRSS_PI_281_DATA 0x03040404 +#define DDRSS_PI_282_DATA 0x00000303 +#define DDRSS_PI_283_DATA 0x02020101 +#define DDRSS_PI_284_DATA 0x67676767 +#define DDRSS_PI_285_DATA 0x00000000 +#define DDRSS_PI_286_DATA 0x55000000 +#define DDRSS_PI_287_DATA 0x00000000 +#define DDRSS_PI_288_DATA 0x3C00005A +#define DDRSS_PI_289_DATA 0x00005500 +#define DDRSS_PI_290_DATA 0x00005A00 +#define DDRSS_PI_291_DATA 0x0D100F3C +#define DDRSS_PI_292_DATA 0x0003020E +#define DDRSS_PI_293_DATA 0x00000001 +#define DDRSS_PI_294_DATA 0x01000000 +#define DDRSS_PI_295_DATA 0x00020201 +#define DDRSS_PI_296_DATA 0x00000000 +#define DDRSS_PI_297_DATA 0x00000000 +#define DDRSS_PI_298_DATA 0x00000004 +#define DDRSS_PI_299_DATA 0x00000000 +#define DDRSS_PI_300_DATA 0x00000031 +#define DDRSS_PI_301_DATA 0x00000000 +#define DDRSS_PI_302_DATA 0x00000000 +#define DDRSS_PI_303_DATA 0x00000000 +#define DDRSS_PI_304_DATA 0x00100F27 +#define DDRSS_PI_305_DATA 0x00000000 +#define DDRSS_PI_306_DATA 0x00000024 +#define DDRSS_PI_307_DATA 0x00000012 +#define DDRSS_PI_308_DATA 0x000000B1 +#define DDRSS_PI_309_DATA 0x00000000 +#define DDRSS_PI_310_DATA 0x00000000 +#define DDRSS_PI_311_DATA 0x46000000 +#define DDRSS_PI_312_DATA 0x00150F27 +#define DDRSS_PI_313_DATA 0x00000000 +#define DDRSS_PI_314_DATA 0x00000024 +#define DDRSS_PI_315_DATA 0x00000012 +#define DDRSS_PI_316_DATA 0x000000B1 +#define DDRSS_PI_317_DATA 0x00000000 +#define DDRSS_PI_318_DATA 0x00000000 +#define DDRSS_PI_319_DATA 0x46000000 +#define DDRSS_PI_320_DATA 0x00150F27 +#define DDRSS_PI_321_DATA 0x00000000 +#define DDRSS_PI_322_DATA 0x00000004 +#define DDRSS_PI_323_DATA 0x00000000 +#define DDRSS_PI_324_DATA 0x00000031 +#define DDRSS_PI_325_DATA 0x00000000 +#define DDRSS_PI_326_DATA 0x00000000 +#define DDRSS_PI_327_DATA 0x00000000 +#define DDRSS_PI_328_DATA 0x00100F27 +#define DDRSS_PI_329_DATA 0x00000000 +#define DDRSS_PI_330_DATA 0x00000024 +#define DDRSS_PI_331_DATA 0x00000012 +#define DDRSS_PI_332_DATA 0x000000B1 +#define DDRSS_PI_333_DATA 0x00000000 +#define DDRSS_PI_334_DATA 0x00000000 +#define DDRSS_PI_335_DATA 0x46000000 +#define DDRSS_PI_336_DATA 0x00150F27 +#define DDRSS_PI_337_DATA 0x00000000 +#define DDRSS_PI_338_DATA 0x00000024 +#define DDRSS_PI_339_DATA 0x00000012 +#define DDRSS_PI_340_DATA 0x000000B1 +#define DDRSS_PI_341_DATA 0x00000000 +#define DDRSS_PI_342_DATA 0x00000000 +#define DDRSS_PI_343_DATA 0x46000000 +#define DDRSS_PI_344_DATA 0x00150F27 +#define DDRSS_PHY_0_DATA 0x04F00000 +#define DDRSS_PHY_1_DATA 0x00000000 +#define DDRSS_PHY_2_DATA 0x00030200 +#define DDRSS_PHY_3_DATA 0x00000000 +#define DDRSS_PHY_4_DATA 0x00000000 +#define DDRSS_PHY_5_DATA 0x01000000 +#define DDRSS_PHY_6_DATA 0x03000400 +#define DDRSS_PHY_7_DATA 0x00000001 +#define DDRSS_PHY_8_DATA 0x00000001 +#define DDRSS_PHY_9_DATA 0x00000000 +#define DDRSS_PHY_10_DATA 0x00000000 +#define DDRSS_PHY_11_DATA 0x01010000 +#define DDRSS_PHY_12_DATA 0x00010000 +#define DDRSS_PHY_13_DATA 0x00C00001 +#define DDRSS_PHY_14_DATA 0x00CC0008 +#define DDRSS_PHY_15_DATA 0x00660601 +#define DDRSS_PHY_16_DATA 0x00000003 +#define DDRSS_PHY_17_DATA 0x00000000 +#define DDRSS_PHY_18_DATA 0x00000000 +#define DDRSS_PHY_19_DATA 0x0000AAAA +#define DDRSS_PHY_20_DATA 0x00005555 +#define DDRSS_PHY_21_DATA 0x0000B5B5 +#define DDRSS_PHY_22_DATA 0x00004A4A +#define DDRSS_PHY_23_DATA 0x00005656 +#define DDRSS_PHY_24_DATA 0x0000A9A9 +#define DDRSS_PHY_25_DATA 0x0000B7B7 +#define DDRSS_PHY_26_DATA 0x00004848 +#define DDRSS_PHY_27_DATA 0x00000000 +#define DDRSS_PHY_28_DATA 0x00000000 +#define DDRSS_PHY_29_DATA 0x08000000 +#define DDRSS_PHY_30_DATA 0x0F000008 +#define DDRSS_PHY_31_DATA 0x00000F0F +#define DDRSS_PHY_32_DATA 0x00E4E400 +#define DDRSS_PHY_33_DATA 0x00071020 +#define DDRSS_PHY_34_DATA 0x000C0020 +#define DDRSS_PHY_35_DATA 0x00062000 +#define DDRSS_PHY_36_DATA 0x00000000 +#define DDRSS_PHY_37_DATA 0x55555555 +#define DDRSS_PHY_38_DATA 0xAAAAAAAA +#define DDRSS_PHY_39_DATA 0x55555555 +#define DDRSS_PHY_40_DATA 0xAAAAAAAA +#define DDRSS_PHY_41_DATA 0x00005555 +#define DDRSS_PHY_42_DATA 0x01000100 +#define DDRSS_PHY_43_DATA 0x00800180 +#define DDRSS_PHY_44_DATA 0x00000001 +#define DDRSS_PHY_45_DATA 0x00000000 +#define DDRSS_PHY_46_DATA 0x00000000 +#define DDRSS_PHY_47_DATA 0x00000000 +#define DDRSS_PHY_48_DATA 0x00000000 +#define DDRSS_PHY_49_DATA 0x00000000 +#define DDRSS_PHY_50_DATA 0x00000000 +#define DDRSS_PHY_51_DATA 0x00000000 +#define DDRSS_PHY_52_DATA 0x00000000 +#define DDRSS_PHY_53_DATA 0x00000000 +#define DDRSS_PHY_54_DATA 0x00000000 +#define DDRSS_PHY_55_DATA 0x00000000 +#define DDRSS_PHY_56_DATA 0x00000000 +#define DDRSS_PHY_57_DATA 0x00000000 +#define DDRSS_PHY_58_DATA 0x00000000 +#define DDRSS_PHY_59_DATA 0x00000000 +#define DDRSS_PHY_60_DATA 0x00000000 +#define DDRSS_PHY_61_DATA 0x00000000 +#define DDRSS_PHY_62_DATA 0x00000000 +#define DDRSS_PHY_63_DATA 0x00000000 +#define DDRSS_PHY_64_DATA 0x00000000 +#define DDRSS_PHY_65_DATA 0x00000004 +#define DDRSS_PHY_66_DATA 0x00000000 +#define DDRSS_PHY_67_DATA 0x00000000 +#define DDRSS_PHY_68_DATA 0x00000000 +#define DDRSS_PHY_69_DATA 0x00000000 +#define DDRSS_PHY_70_DATA 0x00000000 +#define DDRSS_PHY_71_DATA 0x00000000 +#define DDRSS_PHY_72_DATA 0x041F07FF +#define DDRSS_PHY_73_DATA 0x00000000 +#define DDRSS_PHY_74_DATA 0x01CC0B01 +#define DDRSS_PHY_75_DATA 0x1003CC0B +#define DDRSS_PHY_76_DATA 0x20000140 +#define DDRSS_PHY_77_DATA 0x07FF0200 +#define DDRSS_PHY_78_DATA 0x0000DD01 +#define DDRSS_PHY_79_DATA 0x00100303 +#define DDRSS_PHY_80_DATA 0x00000000 +#define DDRSS_PHY_81_DATA 0x00000000 +#define DDRSS_PHY_82_DATA 0x00021000 +#define DDRSS_PHY_83_DATA 0x00100010 +#define DDRSS_PHY_84_DATA 0x00100010 +#define DDRSS_PHY_85_DATA 0x00100010 +#define DDRSS_PHY_86_DATA 0x00100010 +#define DDRSS_PHY_87_DATA 0x02020010 +#define DDRSS_PHY_88_DATA 0x51516041 +#define DDRSS_PHY_89_DATA 0x31C06000 +#define DDRSS_PHY_90_DATA 0x07AB0340 +#define DDRSS_PHY_91_DATA 0x0000C0C0 +#define DDRSS_PHY_92_DATA 0x04050000 +#define DDRSS_PHY_93_DATA 0x00000504 +#define DDRSS_PHY_94_DATA 0x42100010 +#define DDRSS_PHY_95_DATA 0x010C053E +#define DDRSS_PHY_96_DATA 0x000F0C1D +#define DDRSS_PHY_97_DATA 0x01000140 +#define DDRSS_PHY_98_DATA 0x007A0120 +#define DDRSS_PHY_99_DATA 0x00000C00 +#define DDRSS_PHY_100_DATA 0x000001CC +#define DDRSS_PHY_101_DATA 0x20100200 +#define DDRSS_PHY_102_DATA 0x00000005 +#define DDRSS_PHY_103_DATA 0x56704132 +#define DDRSS_PHY_104_DATA 0x00000008 +#define DDRSS_PHY_105_DATA 0x034C034C +#define DDRSS_PHY_106_DATA 0x034C034C +#define DDRSS_PHY_107_DATA 0x034C034C +#define DDRSS_PHY_108_DATA 0x034C034C +#define DDRSS_PHY_109_DATA 0x0000034C +#define DDRSS_PHY_110_DATA 0x00008000 +#define DDRSS_PHY_111_DATA 0x00800080 +#define DDRSS_PHY_112_DATA 0x00800080 +#define DDRSS_PHY_113_DATA 0x00800080 +#define DDRSS_PHY_114_DATA 0x00800080 +#define DDRSS_PHY_115_DATA 0x00800080 +#define DDRSS_PHY_116_DATA 0x00800080 +#define DDRSS_PHY_117_DATA 0x00800080 +#define DDRSS_PHY_118_DATA 0x00800080 +#define DDRSS_PHY_119_DATA 0x01800080 +#define DDRSS_PHY_120_DATA 0x01000000 +#define DDRSS_PHY_121_DATA 0x00000000 +#define DDRSS_PHY_122_DATA 0x00000000 +#define DDRSS_PHY_123_DATA 0x00080200 +#define DDRSS_PHY_124_DATA 0x00000000 +#define DDRSS_PHY_125_DATA 0x0000F0F0 +#define DDRSS_PHY_126_DATA 0x00000000 +#define DDRSS_PHY_127_DATA 0x00000000 +#define DDRSS_PHY_128_DATA 0x00000000 +#define DDRSS_PHY_129_DATA 0x00000000 +#define DDRSS_PHY_130_DATA 0x00000000 +#define DDRSS_PHY_131_DATA 0x00000000 +#define DDRSS_PHY_132_DATA 0x00000000 +#define DDRSS_PHY_133_DATA 0x00000000 +#define DDRSS_PHY_134_DATA 0x00000000 +#define DDRSS_PHY_135_DATA 0x00000000 +#define DDRSS_PHY_136_DATA 0x00000000 +#define DDRSS_PHY_137_DATA 0x00000000 +#define DDRSS_PHY_138_DATA 0x00000000 +#define DDRSS_PHY_139_DATA 0x00000000 +#define DDRSS_PHY_140_DATA 0x00000000 +#define DDRSS_PHY_141_DATA 0x00000000 +#define DDRSS_PHY_142_DATA 0x00000000 +#define DDRSS_PHY_143_DATA 0x00000000 +#define DDRSS_PHY_144_DATA 0x00000000 +#define DDRSS_PHY_145_DATA 0x00000000 +#define DDRSS_PHY_146_DATA 0x00000000 +#define DDRSS_PHY_147_DATA 0x00000000 +#define DDRSS_PHY_148_DATA 0x00000000 +#define DDRSS_PHY_149_DATA 0x00000000 +#define DDRSS_PHY_150_DATA 0x00000000 +#define DDRSS_PHY_151_DATA 0x00000000 +#define DDRSS_PHY_152_DATA 0x00000000 +#define DDRSS_PHY_153_DATA 0x00000000 +#define DDRSS_PHY_154_DATA 0x00000000 +#define DDRSS_PHY_155_DATA 0x00000000 +#define DDRSS_PHY_156_DATA 0x00000000 +#define DDRSS_PHY_157_DATA 0x00000000 +#define DDRSS_PHY_158_DATA 0x00000000 +#define DDRSS_PHY_159_DATA 0x00000000 +#define DDRSS_PHY_160_DATA 0x00000000 +#define DDRSS_PHY_161_DATA 0x00000000 +#define DDRSS_PHY_162_DATA 0x00000000 +#define DDRSS_PHY_163_DATA 0x00000000 +#define DDRSS_PHY_164_DATA 0x00000000 +#define DDRSS_PHY_165_DATA 0x00000000 +#define DDRSS_PHY_166_DATA 0x00000000 +#define DDRSS_PHY_167_DATA 0x00000000 +#define DDRSS_PHY_168_DATA 0x00000000 +#define DDRSS_PHY_169_DATA 0x00000000 +#define DDRSS_PHY_170_DATA 0x00000000 +#define DDRSS_PHY_171_DATA 0x00000000 +#define DDRSS_PHY_172_DATA 0x00000000 +#define DDRSS_PHY_173_DATA 0x00000000 +#define DDRSS_PHY_174_DATA 0x00000000 +#define DDRSS_PHY_175_DATA 0x00000000 +#define DDRSS_PHY_176_DATA 0x00000000 +#define DDRSS_PHY_177_DATA 0x00000000 +#define DDRSS_PHY_178_DATA 0x00000000 +#define DDRSS_PHY_179_DATA 0x00000000 +#define DDRSS_PHY_180_DATA 0x00000000 +#define DDRSS_PHY_181_DATA 0x00000000 +#define DDRSS_PHY_182_DATA 0x00000000 +#define DDRSS_PHY_183_DATA 0x00000000 +#define DDRSS_PHY_184_DATA 0x00000000 +#define DDRSS_PHY_185_DATA 0x00000000 +#define DDRSS_PHY_186_DATA 0x00000000 +#define DDRSS_PHY_187_DATA 0x00000000 +#define DDRSS_PHY_188_DATA 0x00000000 +#define DDRSS_PHY_189_DATA 0x00000000 +#define DDRSS_PHY_190_DATA 0x00000000 +#define DDRSS_PHY_191_DATA 0x00000000 +#define DDRSS_PHY_192_DATA 0x00000000 +#define DDRSS_PHY_193_DATA 0x00000000 +#define DDRSS_PHY_194_DATA 0x00000000 +#define DDRSS_PHY_195_DATA 0x00000000 +#define DDRSS_PHY_196_DATA 0x00000000 +#define DDRSS_PHY_197_DATA 0x00000000 +#define DDRSS_PHY_198_DATA 0x00000000 +#define DDRSS_PHY_199_DATA 0x00000000 +#define DDRSS_PHY_200_DATA 0x00000000 +#define DDRSS_PHY_201_DATA 0x00000000 +#define DDRSS_PHY_202_DATA 0x00000000 +#define DDRSS_PHY_203_DATA 0x00000000 +#define DDRSS_PHY_204_DATA 0x00000000 +#define DDRSS_PHY_205_DATA 0x00000000 +#define DDRSS_PHY_206_DATA 0x00000000 +#define DDRSS_PHY_207_DATA 0x00000000 +#define DDRSS_PHY_208_DATA 0x00000000 +#define DDRSS_PHY_209_DATA 0x00000000 +#define DDRSS_PHY_210_DATA 0x00000000 +#define DDRSS_PHY_211_DATA 0x00000000 +#define DDRSS_PHY_212_DATA 0x00000000 +#define DDRSS_PHY_213_DATA 0x00000000 +#define DDRSS_PHY_214_DATA 0x00000000 +#define DDRSS_PHY_215_DATA 0x00000000 +#define DDRSS_PHY_216_DATA 0x00000000 +#define DDRSS_PHY_217_DATA 0x00000000 +#define DDRSS_PHY_218_DATA 0x00000000 +#define DDRSS_PHY_219_DATA 0x00000000 +#define DDRSS_PHY_220_DATA 0x00000000 +#define DDRSS_PHY_221_DATA 0x00000000 +#define DDRSS_PHY_222_DATA 0x00000000 +#define DDRSS_PHY_223_DATA 0x00000000 +#define DDRSS_PHY_224_DATA 0x00000000 +#define DDRSS_PHY_225_DATA 0x00000000 +#define DDRSS_PHY_226_DATA 0x00000000 +#define DDRSS_PHY_227_DATA 0x00000000 +#define DDRSS_PHY_228_DATA 0x00000000 +#define DDRSS_PHY_229_DATA 0x00000000 +#define DDRSS_PHY_230_DATA 0x00000000 +#define DDRSS_PHY_231_DATA 0x00000000 +#define DDRSS_PHY_232_DATA 0x00000000 +#define DDRSS_PHY_233_DATA 0x00000000 +#define DDRSS_PHY_234_DATA 0x00000000 +#define DDRSS_PHY_235_DATA 0x00000000 +#define DDRSS_PHY_236_DATA 0x00000000 +#define DDRSS_PHY_237_DATA 0x00000000 +#define DDRSS_PHY_238_DATA 0x00000000 +#define DDRSS_PHY_239_DATA 0x00000000 +#define DDRSS_PHY_240_DATA 0x00000000 +#define DDRSS_PHY_241_DATA 0x00000000 +#define DDRSS_PHY_242_DATA 0x00000000 +#define DDRSS_PHY_243_DATA 0x00000000 +#define DDRSS_PHY_244_DATA 0x00000000 +#define DDRSS_PHY_245_DATA 0x00000000 +#define DDRSS_PHY_246_DATA 0x00000000 +#define DDRSS_PHY_247_DATA 0x00000000 +#define DDRSS_PHY_248_DATA 0x00000000 +#define DDRSS_PHY_249_DATA 0x00000000 +#define DDRSS_PHY_250_DATA 0x00000000 +#define DDRSS_PHY_251_DATA 0x00000000 +#define DDRSS_PHY_252_DATA 0x00000000 +#define DDRSS_PHY_253_DATA 0x00000000 +#define DDRSS_PHY_254_DATA 0x00000000 +#define DDRSS_PHY_255_DATA 0x00000000 +#define DDRSS_PHY_256_DATA 0x04F00000 +#define DDRSS_PHY_257_DATA 0x00000000 +#define DDRSS_PHY_258_DATA 0x00030200 +#define DDRSS_PHY_259_DATA 0x00000000 +#define DDRSS_PHY_260_DATA 0x00000000 +#define DDRSS_PHY_261_DATA 0x01000000 +#define DDRSS_PHY_262_DATA 0x03000400 +#define DDRSS_PHY_263_DATA 0x00000001 +#define DDRSS_PHY_264_DATA 0x00000001 +#define DDRSS_PHY_265_DATA 0x00000000 +#define DDRSS_PHY_266_DATA 0x00000000 +#define DDRSS_PHY_267_DATA 0x01010000 +#define DDRSS_PHY_268_DATA 0x00010000 +#define DDRSS_PHY_269_DATA 0x00C00001 +#define DDRSS_PHY_270_DATA 0x00CC0008 +#define DDRSS_PHY_271_DATA 0x00660601 +#define DDRSS_PHY_272_DATA 0x00000003 +#define DDRSS_PHY_273_DATA 0x00000000 +#define DDRSS_PHY_274_DATA 0x00000000 +#define DDRSS_PHY_275_DATA 0x0000AAAA +#define DDRSS_PHY_276_DATA 0x00005555 +#define DDRSS_PHY_277_DATA 0x0000B5B5 +#define DDRSS_PHY_278_DATA 0x00004A4A +#define DDRSS_PHY_279_DATA 0x00005656 +#define DDRSS_PHY_280_DATA 0x0000A9A9 +#define DDRSS_PHY_281_DATA 0x0000B7B7 +#define DDRSS_PHY_282_DATA 0x00004848 +#define DDRSS_PHY_283_DATA 0x00000000 +#define DDRSS_PHY_284_DATA 0x00000000 +#define DDRSS_PHY_285_DATA 0x08000000 +#define DDRSS_PHY_286_DATA 0x0F000008 +#define DDRSS_PHY_287_DATA 0x00000F0F +#define DDRSS_PHY_288_DATA 0x00E4E400 +#define DDRSS_PHY_289_DATA 0x00071020 +#define DDRSS_PHY_290_DATA 0x000C0020 +#define DDRSS_PHY_291_DATA 0x00062000 +#define DDRSS_PHY_292_DATA 0x00000000 +#define DDRSS_PHY_293_DATA 0x55555555 +#define DDRSS_PHY_294_DATA 0xAAAAAAAA +#define DDRSS_PHY_295_DATA 0x55555555 +#define DDRSS_PHY_296_DATA 0xAAAAAAAA +#define DDRSS_PHY_297_DATA 0x00005555 +#define DDRSS_PHY_298_DATA 0x01000100 +#define DDRSS_PHY_299_DATA 0x00800180 +#define DDRSS_PHY_300_DATA 0x00000000 +#define DDRSS_PHY_301_DATA 0x00000000 +#define DDRSS_PHY_302_DATA 0x00000000 +#define DDRSS_PHY_303_DATA 0x00000000 +#define DDRSS_PHY_304_DATA 0x00000000 +#define DDRSS_PHY_305_DATA 0x00000000 +#define DDRSS_PHY_306_DATA 0x00000000 +#define DDRSS_PHY_307_DATA 0x00000000 +#define DDRSS_PHY_308_DATA 0x00000000 +#define DDRSS_PHY_309_DATA 0x00000000 +#define DDRSS_PHY_310_DATA 0x00000000 +#define DDRSS_PHY_311_DATA 0x00000000 +#define DDRSS_PHY_312_DATA 0x00000000 +#define DDRSS_PHY_313_DATA 0x00000000 +#define DDRSS_PHY_314_DATA 0x00000000 +#define DDRSS_PHY_315_DATA 0x00000000 +#define DDRSS_PHY_316_DATA 0x00000000 +#define DDRSS_PHY_317_DATA 0x00000000 +#define DDRSS_PHY_318_DATA 0x00000000 +#define DDRSS_PHY_319_DATA 0x00000000 +#define DDRSS_PHY_320_DATA 0x00000000 +#define DDRSS_PHY_321_DATA 0x00000004 +#define DDRSS_PHY_322_DATA 0x00000000 +#define DDRSS_PHY_323_DATA 0x00000000 +#define DDRSS_PHY_324_DATA 0x00000000 +#define DDRSS_PHY_325_DATA 0x00000000 +#define DDRSS_PHY_326_DATA 0x00000000 +#define DDRSS_PHY_327_DATA 0x00000000 +#define DDRSS_PHY_328_DATA 0x041F07FF +#define DDRSS_PHY_329_DATA 0x00000000 +#define DDRSS_PHY_330_DATA 0x01CC0B01 +#define DDRSS_PHY_331_DATA 0x1003CC0B +#define DDRSS_PHY_332_DATA 0x20000140 +#define DDRSS_PHY_333_DATA 0x07FF0200 +#define DDRSS_PHY_334_DATA 0x0000DD01 +#define DDRSS_PHY_335_DATA 0x00100303 +#define DDRSS_PHY_336_DATA 0x00000000 +#define DDRSS_PHY_337_DATA 0x00000000 +#define DDRSS_PHY_338_DATA 0x00021000 +#define DDRSS_PHY_339_DATA 0x00100010 +#define DDRSS_PHY_340_DATA 0x00100010 +#define DDRSS_PHY_341_DATA 0x00100010 +#define DDRSS_PHY_342_DATA 0x00100010 +#define DDRSS_PHY_343_DATA 0x02020010 +#define DDRSS_PHY_344_DATA 0x51516041 +#define DDRSS_PHY_345_DATA 0x31C06000 +#define DDRSS_PHY_346_DATA 0x07AB0340 +#define DDRSS_PHY_347_DATA 0x0000C0C0 +#define DDRSS_PHY_348_DATA 0x04050000 +#define DDRSS_PHY_349_DATA 0x00000504 +#define DDRSS_PHY_350_DATA 0x42100010 +#define DDRSS_PHY_351_DATA 0x010C053E +#define DDRSS_PHY_352_DATA 0x000F0C1D +#define DDRSS_PHY_353_DATA 0x01000140 +#define DDRSS_PHY_354_DATA 0x007A0120 +#define DDRSS_PHY_355_DATA 0x00000C00 +#define DDRSS_PHY_356_DATA 0x000001CC +#define DDRSS_PHY_357_DATA 0x20100200 +#define DDRSS_PHY_358_DATA 0x00000005 +#define DDRSS_PHY_359_DATA 0x03415762 +#define DDRSS_PHY_360_DATA 0x00000008 +#define DDRSS_PHY_361_DATA 0x034C034C +#define DDRSS_PHY_362_DATA 0x034C034C +#define DDRSS_PHY_363_DATA 0x034C034C +#define DDRSS_PHY_364_DATA 0x034C034C +#define DDRSS_PHY_365_DATA 0x0000034C +#define DDRSS_PHY_366_DATA 0x00008000 +#define DDRSS_PHY_367_DATA 0x00800080 +#define DDRSS_PHY_368_DATA 0x00800080 +#define DDRSS_PHY_369_DATA 0x00800080 +#define DDRSS_PHY_370_DATA 0x00800080 +#define DDRSS_PHY_371_DATA 0x00800080 +#define DDRSS_PHY_372_DATA 0x00800080 +#define DDRSS_PHY_373_DATA 0x00800080 +#define DDRSS_PHY_374_DATA 0x00800080 +#define DDRSS_PHY_375_DATA 0x01800080 +#define DDRSS_PHY_376_DATA 0x01000000 +#define DDRSS_PHY_377_DATA 0x00000000 +#define DDRSS_PHY_378_DATA 0x00000000 +#define DDRSS_PHY_379_DATA 0x00080200 +#define DDRSS_PHY_380_DATA 0x00000000 +#define DDRSS_PHY_381_DATA 0x0000F0F0 +#define DDRSS_PHY_382_DATA 0x00000000 +#define DDRSS_PHY_383_DATA 0x00000000 +#define DDRSS_PHY_384_DATA 0x00000000 +#define DDRSS_PHY_385_DATA 0x00000000 +#define DDRSS_PHY_386_DATA 0x00000000 +#define DDRSS_PHY_387_DATA 0x00000000 +#define DDRSS_PHY_388_DATA 0x00000000 +#define DDRSS_PHY_389_DATA 0x00000000 +#define DDRSS_PHY_390_DATA 0x00000000 +#define DDRSS_PHY_391_DATA 0x00000000 +#define DDRSS_PHY_392_DATA 0x00000000 +#define DDRSS_PHY_393_DATA 0x00000000 +#define DDRSS_PHY_394_DATA 0x00000000 +#define DDRSS_PHY_395_DATA 0x00000000 +#define DDRSS_PHY_396_DATA 0x00000000 +#define DDRSS_PHY_397_DATA 0x00000000 +#define DDRSS_PHY_398_DATA 0x00000000 +#define DDRSS_PHY_399_DATA 0x00000000 +#define DDRSS_PHY_400_DATA 0x00000000 +#define DDRSS_PHY_401_DATA 0x00000000 +#define DDRSS_PHY_402_DATA 0x00000000 +#define DDRSS_PHY_403_DATA 0x00000000 +#define DDRSS_PHY_404_DATA 0x00000000 +#define DDRSS_PHY_405_DATA 0x00000000 +#define DDRSS_PHY_406_DATA 0x00000000 +#define DDRSS_PHY_407_DATA 0x00000000 +#define DDRSS_PHY_408_DATA 0x00000000 +#define DDRSS_PHY_409_DATA 0x00000000 +#define DDRSS_PHY_410_DATA 0x00000000 +#define DDRSS_PHY_411_DATA 0x00000000 +#define DDRSS_PHY_412_DATA 0x00000000 +#define DDRSS_PHY_413_DATA 0x00000000 +#define DDRSS_PHY_414_DATA 0x00000000 +#define DDRSS_PHY_415_DATA 0x00000000 +#define DDRSS_PHY_416_DATA 0x00000000 +#define DDRSS_PHY_417_DATA 0x00000000 +#define DDRSS_PHY_418_DATA 0x00000000 +#define DDRSS_PHY_419_DATA 0x00000000 +#define DDRSS_PHY_420_DATA 0x00000000 +#define DDRSS_PHY_421_DATA 0x00000000 +#define DDRSS_PHY_422_DATA 0x00000000 +#define DDRSS_PHY_423_DATA 0x00000000 +#define DDRSS_PHY_424_DATA 0x00000000 +#define DDRSS_PHY_425_DATA 0x00000000 +#define DDRSS_PHY_426_DATA 0x00000000 +#define DDRSS_PHY_427_DATA 0x00000000 +#define DDRSS_PHY_428_DATA 0x00000000 +#define DDRSS_PHY_429_DATA 0x00000000 +#define DDRSS_PHY_430_DATA 0x00000000 +#define DDRSS_PHY_431_DATA 0x00000000 +#define DDRSS_PHY_432_DATA 0x00000000 +#define DDRSS_PHY_433_DATA 0x00000000 +#define DDRSS_PHY_434_DATA 0x00000000 +#define DDRSS_PHY_435_DATA 0x00000000 +#define DDRSS_PHY_436_DATA 0x00000000 +#define DDRSS_PHY_437_DATA 0x00000000 +#define DDRSS_PHY_438_DATA 0x00000000 +#define DDRSS_PHY_439_DATA 0x00000000 +#define DDRSS_PHY_440_DATA 0x00000000 +#define DDRSS_PHY_441_DATA 0x00000000 +#define DDRSS_PHY_442_DATA 0x00000000 +#define DDRSS_PHY_443_DATA 0x00000000 +#define DDRSS_PHY_444_DATA 0x00000000 +#define DDRSS_PHY_445_DATA 0x00000000 +#define DDRSS_PHY_446_DATA 0x00000000 +#define DDRSS_PHY_447_DATA 0x00000000 +#define DDRSS_PHY_448_DATA 0x00000000 +#define DDRSS_PHY_449_DATA 0x00000000 +#define DDRSS_PHY_450_DATA 0x00000000 +#define DDRSS_PHY_451_DATA 0x00000000 +#define DDRSS_PHY_452_DATA 0x00000000 +#define DDRSS_PHY_453_DATA 0x00000000 +#define DDRSS_PHY_454_DATA 0x00000000 +#define DDRSS_PHY_455_DATA 0x00000000 +#define DDRSS_PHY_456_DATA 0x00000000 +#define DDRSS_PHY_457_DATA 0x00000000 +#define DDRSS_PHY_458_DATA 0x00000000 +#define DDRSS_PHY_459_DATA 0x00000000 +#define DDRSS_PHY_460_DATA 0x00000000 +#define DDRSS_PHY_461_DATA 0x00000000 +#define DDRSS_PHY_462_DATA 0x00000000 +#define DDRSS_PHY_463_DATA 0x00000000 +#define DDRSS_PHY_464_DATA 0x00000000 +#define DDRSS_PHY_465_DATA 0x00000000 +#define DDRSS_PHY_466_DATA 0x00000000 +#define DDRSS_PHY_467_DATA 0x00000000 +#define DDRSS_PHY_468_DATA 0x00000000 +#define DDRSS_PHY_469_DATA 0x00000000 +#define DDRSS_PHY_470_DATA 0x00000000 +#define DDRSS_PHY_471_DATA 0x00000000 +#define DDRSS_PHY_472_DATA 0x00000000 +#define DDRSS_PHY_473_DATA 0x00000000 +#define DDRSS_PHY_474_DATA 0x00000000 +#define DDRSS_PHY_475_DATA 0x00000000 +#define DDRSS_PHY_476_DATA 0x00000000 +#define DDRSS_PHY_477_DATA 0x00000000 +#define DDRSS_PHY_478_DATA 0x00000000 +#define DDRSS_PHY_479_DATA 0x00000000 +#define DDRSS_PHY_480_DATA 0x00000000 +#define DDRSS_PHY_481_DATA 0x00000000 +#define DDRSS_PHY_482_DATA 0x00000000 +#define DDRSS_PHY_483_DATA 0x00000000 +#define DDRSS_PHY_484_DATA 0x00000000 +#define DDRSS_PHY_485_DATA 0x00000000 +#define DDRSS_PHY_486_DATA 0x00000000 +#define DDRSS_PHY_487_DATA 0x00000000 +#define DDRSS_PHY_488_DATA 0x00000000 +#define DDRSS_PHY_489_DATA 0x00000000 +#define DDRSS_PHY_490_DATA 0x00000000 +#define DDRSS_PHY_491_DATA 0x00000000 +#define DDRSS_PHY_492_DATA 0x00000000 +#define DDRSS_PHY_493_DATA 0x00000000 +#define DDRSS_PHY_494_DATA 0x00000000 +#define DDRSS_PHY_495_DATA 0x00000000 +#define DDRSS_PHY_496_DATA 0x00000000 +#define DDRSS_PHY_497_DATA 0x00000000 +#define DDRSS_PHY_498_DATA 0x00000000 +#define DDRSS_PHY_499_DATA 0x00000000 +#define DDRSS_PHY_500_DATA 0x00000000 +#define DDRSS_PHY_501_DATA 0x00000000 +#define DDRSS_PHY_502_DATA 0x00000000 +#define DDRSS_PHY_503_DATA 0x00000000 +#define DDRSS_PHY_504_DATA 0x00000000 +#define DDRSS_PHY_505_DATA 0x00000000 +#define DDRSS_PHY_506_DATA 0x00000000 +#define DDRSS_PHY_507_DATA 0x00000000 +#define DDRSS_PHY_508_DATA 0x00000000 +#define DDRSS_PHY_509_DATA 0x00000000 +#define DDRSS_PHY_510_DATA 0x00000000 +#define DDRSS_PHY_511_DATA 0x00000000 +#define DDRSS_PHY_512_DATA 0x00000000 +#define DDRSS_PHY_513_DATA 0x00000000 +#define DDRSS_PHY_514_DATA 0x00000000 +#define DDRSS_PHY_515_DATA 0x00000000 +#define DDRSS_PHY_516_DATA 0x00000000 +#define DDRSS_PHY_517_DATA 0x00000100 +#define DDRSS_PHY_518_DATA 0x00000200 +#define DDRSS_PHY_519_DATA 0x00000000 +#define DDRSS_PHY_520_DATA 0x00000000 +#define DDRSS_PHY_521_DATA 0x00000000 +#define DDRSS_PHY_522_DATA 0x00000000 +#define DDRSS_PHY_523_DATA 0x00400000 +#define DDRSS_PHY_524_DATA 0x00000080 +#define DDRSS_PHY_525_DATA 0x00DCBA98 +#define DDRSS_PHY_526_DATA 0x03000000 +#define DDRSS_PHY_527_DATA 0x00200000 +#define DDRSS_PHY_528_DATA 0x00000000 +#define DDRSS_PHY_529_DATA 0x00000000 +#define DDRSS_PHY_530_DATA 0x00000000 +#define DDRSS_PHY_531_DATA 0x00000000 +#define DDRSS_PHY_532_DATA 0x0000002A +#define DDRSS_PHY_533_DATA 0x00000015 +#define DDRSS_PHY_534_DATA 0x00000015 +#define DDRSS_PHY_535_DATA 0x0000002A +#define DDRSS_PHY_536_DATA 0x00000033 +#define DDRSS_PHY_537_DATA 0x0000000C +#define DDRSS_PHY_538_DATA 0x0000000C +#define DDRSS_PHY_539_DATA 0x00000033 +#define DDRSS_PHY_540_DATA 0x0A418820 +#define DDRSS_PHY_541_DATA 0x003F0000 +#define DDRSS_PHY_542_DATA 0x000F013F +#define DDRSS_PHY_543_DATA 0x0000000F +#define DDRSS_PHY_544_DATA 0x020002CC +#define DDRSS_PHY_545_DATA 0x00030000 +#define DDRSS_PHY_546_DATA 0x00000300 +#define DDRSS_PHY_547_DATA 0x00000300 +#define DDRSS_PHY_548_DATA 0x00000300 +#define DDRSS_PHY_549_DATA 0x00000300 +#define DDRSS_PHY_550_DATA 0x00000300 +#define DDRSS_PHY_551_DATA 0x42080010 +#define DDRSS_PHY_552_DATA 0x0000803E +#define DDRSS_PHY_553_DATA 0x00000003 +#define DDRSS_PHY_554_DATA 0x00000002 +#define DDRSS_PHY_555_DATA 0x00000000 +#define DDRSS_PHY_556_DATA 0x00000000 +#define DDRSS_PHY_557_DATA 0x00000000 +#define DDRSS_PHY_558_DATA 0x00000000 +#define DDRSS_PHY_559_DATA 0x00000000 +#define DDRSS_PHY_560_DATA 0x00000000 +#define DDRSS_PHY_561_DATA 0x00000000 +#define DDRSS_PHY_562_DATA 0x00000000 +#define DDRSS_PHY_563_DATA 0x00000000 +#define DDRSS_PHY_564_DATA 0x00000000 +#define DDRSS_PHY_565_DATA 0x00000000 +#define DDRSS_PHY_566_DATA 0x00000000 +#define DDRSS_PHY_567_DATA 0x00000000 +#define DDRSS_PHY_568_DATA 0x00000000 +#define DDRSS_PHY_569_DATA 0x00000000 +#define DDRSS_PHY_570_DATA 0x00000000 +#define DDRSS_PHY_571_DATA 0x00000000 +#define DDRSS_PHY_572_DATA 0x00000000 +#define DDRSS_PHY_573_DATA 0x00000000 +#define DDRSS_PHY_574_DATA 0x00000000 +#define DDRSS_PHY_575_DATA 0x00000000 +#define DDRSS_PHY_576_DATA 0x00000000 +#define DDRSS_PHY_577_DATA 0x00000000 +#define DDRSS_PHY_578_DATA 0x00000000 +#define DDRSS_PHY_579_DATA 0x00000000 +#define DDRSS_PHY_580_DATA 0x00000000 +#define DDRSS_PHY_581_DATA 0x00000000 +#define DDRSS_PHY_582_DATA 0x00000000 +#define DDRSS_PHY_583_DATA 0x00000000 +#define DDRSS_PHY_584_DATA 0x00000000 +#define DDRSS_PHY_585_DATA 0x00000000 +#define DDRSS_PHY_586_DATA 0x00000000 +#define DDRSS_PHY_587_DATA 0x00000000 +#define DDRSS_PHY_588_DATA 0x00000000 +#define DDRSS_PHY_589_DATA 0x00000000 +#define DDRSS_PHY_590_DATA 0x00000000 +#define DDRSS_PHY_591_DATA 0x00000000 +#define DDRSS_PHY_592_DATA 0x00000000 +#define DDRSS_PHY_593_DATA 0x00000000 +#define DDRSS_PHY_594_DATA 0x00000000 +#define DDRSS_PHY_595_DATA 0x00000000 +#define DDRSS_PHY_596_DATA 0x00000000 +#define DDRSS_PHY_597_DATA 0x00000000 +#define DDRSS_PHY_598_DATA 0x00000000 +#define DDRSS_PHY_599_DATA 0x00000000 +#define DDRSS_PHY_600_DATA 0x00000000 +#define DDRSS_PHY_601_DATA 0x00000000 +#define DDRSS_PHY_602_DATA 0x00000000 +#define DDRSS_PHY_603_DATA 0x00000000 +#define DDRSS_PHY_604_DATA 0x00000000 +#define DDRSS_PHY_605_DATA 0x00000000 +#define DDRSS_PHY_606_DATA 0x00000000 +#define DDRSS_PHY_607_DATA 0x00000000 +#define DDRSS_PHY_608_DATA 0x00000000 +#define DDRSS_PHY_609_DATA 0x00000000 +#define DDRSS_PHY_610_DATA 0x00000000 +#define DDRSS_PHY_611_DATA 0x00000000 +#define DDRSS_PHY_612_DATA 0x00000000 +#define DDRSS_PHY_613_DATA 0x00000000 +#define DDRSS_PHY_614_DATA 0x00000000 +#define DDRSS_PHY_615_DATA 0x00000000 +#define DDRSS_PHY_616_DATA 0x00000000 +#define DDRSS_PHY_617_DATA 0x00000000 +#define DDRSS_PHY_618_DATA 0x00000000 +#define DDRSS_PHY_619_DATA 0x00000000 +#define DDRSS_PHY_620_DATA 0x00000000 +#define DDRSS_PHY_621_DATA 0x00000000 +#define DDRSS_PHY_622_DATA 0x00000000 +#define DDRSS_PHY_623_DATA 0x00000000 +#define DDRSS_PHY_624_DATA 0x00000000 +#define DDRSS_PHY_625_DATA 0x00000000 +#define DDRSS_PHY_626_DATA 0x00000000 +#define DDRSS_PHY_627_DATA 0x00000000 +#define DDRSS_PHY_628_DATA 0x00000000 +#define DDRSS_PHY_629_DATA 0x00000000 +#define DDRSS_PHY_630_DATA 0x00000000 +#define DDRSS_PHY_631_DATA 0x00000000 +#define DDRSS_PHY_632_DATA 0x00000000 +#define DDRSS_PHY_633_DATA 0x00000000 +#define DDRSS_PHY_634_DATA 0x00000000 +#define DDRSS_PHY_635_DATA 0x00000000 +#define DDRSS_PHY_636_DATA 0x00000000 +#define DDRSS_PHY_637_DATA 0x00000000 +#define DDRSS_PHY_638_DATA 0x00000000 +#define DDRSS_PHY_639_DATA 0x00000000 +#define DDRSS_PHY_640_DATA 0x00000000 +#define DDRSS_PHY_641_DATA 0x00000000 +#define DDRSS_PHY_642_DATA 0x00000000 +#define DDRSS_PHY_643_DATA 0x00000000 +#define DDRSS_PHY_644_DATA 0x00000000 +#define DDRSS_PHY_645_DATA 0x00000000 +#define DDRSS_PHY_646_DATA 0x00000000 +#define DDRSS_PHY_647_DATA 0x00000000 +#define DDRSS_PHY_648_DATA 0x00000000 +#define DDRSS_PHY_649_DATA 0x00000000 +#define DDRSS_PHY_650_DATA 0x00000000 +#define DDRSS_PHY_651_DATA 0x00000000 +#define DDRSS_PHY_652_DATA 0x00000000 +#define DDRSS_PHY_653_DATA 0x00000000 +#define DDRSS_PHY_654_DATA 0x00000000 +#define DDRSS_PHY_655_DATA 0x00000000 +#define DDRSS_PHY_656_DATA 0x00000000 +#define DDRSS_PHY_657_DATA 0x00000000 +#define DDRSS_PHY_658_DATA 0x00000000 +#define DDRSS_PHY_659_DATA 0x00000000 +#define DDRSS_PHY_660_DATA 0x00000000 +#define DDRSS_PHY_661_DATA 0x00000000 +#define DDRSS_PHY_662_DATA 0x00000000 +#define DDRSS_PHY_663_DATA 0x00000000 +#define DDRSS_PHY_664_DATA 0x00000000 +#define DDRSS_PHY_665_DATA 0x00000000 +#define DDRSS_PHY_666_DATA 0x00000000 +#define DDRSS_PHY_667_DATA 0x00000000 +#define DDRSS_PHY_668_DATA 0x00000000 +#define DDRSS_PHY_669_DATA 0x00000000 +#define DDRSS_PHY_670_DATA 0x00000000 +#define DDRSS_PHY_671_DATA 0x00000000 +#define DDRSS_PHY_672_DATA 0x00000000 +#define DDRSS_PHY_673_DATA 0x00000000 +#define DDRSS_PHY_674_DATA 0x00000000 +#define DDRSS_PHY_675_DATA 0x00000000 +#define DDRSS_PHY_676_DATA 0x00000000 +#define DDRSS_PHY_677_DATA 0x00000000 +#define DDRSS_PHY_678_DATA 0x00000000 +#define DDRSS_PHY_679_DATA 0x00000000 +#define DDRSS_PHY_680_DATA 0x00000000 +#define DDRSS_PHY_681_DATA 0x00000000 +#define DDRSS_PHY_682_DATA 0x00000000 +#define DDRSS_PHY_683_DATA 0x00000000 +#define DDRSS_PHY_684_DATA 0x00000000 +#define DDRSS_PHY_685_DATA 0x00000000 +#define DDRSS_PHY_686_DATA 0x00000000 +#define DDRSS_PHY_687_DATA 0x00000000 +#define DDRSS_PHY_688_DATA 0x00000000 +#define DDRSS_PHY_689_DATA 0x00000000 +#define DDRSS_PHY_690_DATA 0x00000000 +#define DDRSS_PHY_691_DATA 0x00000000 +#define DDRSS_PHY_692_DATA 0x00000000 +#define DDRSS_PHY_693_DATA 0x00000000 +#define DDRSS_PHY_694_DATA 0x00000000 +#define DDRSS_PHY_695_DATA 0x00000000 +#define DDRSS_PHY_696_DATA 0x00000000 +#define DDRSS_PHY_697_DATA 0x00000000 +#define DDRSS_PHY_698_DATA 0x00000000 +#define DDRSS_PHY_699_DATA 0x00000000 +#define DDRSS_PHY_700_DATA 0x00000000 +#define DDRSS_PHY_701_DATA 0x00000000 +#define DDRSS_PHY_702_DATA 0x00000000 +#define DDRSS_PHY_703_DATA 0x00000000 +#define DDRSS_PHY_704_DATA 0x00000000 +#define DDRSS_PHY_705_DATA 0x00000000 +#define DDRSS_PHY_706_DATA 0x00000000 +#define DDRSS_PHY_707_DATA 0x00000000 +#define DDRSS_PHY_708_DATA 0x00000000 +#define DDRSS_PHY_709_DATA 0x00000000 +#define DDRSS_PHY_710_DATA 0x00000000 +#define DDRSS_PHY_711_DATA 0x00000000 +#define DDRSS_PHY_712_DATA 0x00000000 +#define DDRSS_PHY_713_DATA 0x00000000 +#define DDRSS_PHY_714_DATA 0x00000000 +#define DDRSS_PHY_715_DATA 0x00000000 +#define DDRSS_PHY_716_DATA 0x00000000 +#define DDRSS_PHY_717_DATA 0x00000000 +#define DDRSS_PHY_718_DATA 0x00000000 +#define DDRSS_PHY_719_DATA 0x00000000 +#define DDRSS_PHY_720_DATA 0x00000000 +#define DDRSS_PHY_721_DATA 0x00000000 +#define DDRSS_PHY_722_DATA 0x00000000 +#define DDRSS_PHY_723_DATA 0x00000000 +#define DDRSS_PHY_724_DATA 0x00000000 +#define DDRSS_PHY_725_DATA 0x00000000 +#define DDRSS_PHY_726_DATA 0x00000000 +#define DDRSS_PHY_727_DATA 0x00000000 +#define DDRSS_PHY_728_DATA 0x00000000 +#define DDRSS_PHY_729_DATA 0x00000000 +#define DDRSS_PHY_730_DATA 0x00000000 +#define DDRSS_PHY_731_DATA 0x00000000 +#define DDRSS_PHY_732_DATA 0x00000000 +#define DDRSS_PHY_733_DATA 0x00000000 +#define DDRSS_PHY_734_DATA 0x00000000 +#define DDRSS_PHY_735_DATA 0x00000000 +#define DDRSS_PHY_736_DATA 0x00000000 +#define DDRSS_PHY_737_DATA 0x00000000 +#define DDRSS_PHY_738_DATA 0x00000000 +#define DDRSS_PHY_739_DATA 0x00000000 +#define DDRSS_PHY_740_DATA 0x00000000 +#define DDRSS_PHY_741_DATA 0x00000000 +#define DDRSS_PHY_742_DATA 0x00000000 +#define DDRSS_PHY_743_DATA 0x00000000 +#define DDRSS_PHY_744_DATA 0x00000000 +#define DDRSS_PHY_745_DATA 0x00000000 +#define DDRSS_PHY_746_DATA 0x00000000 +#define DDRSS_PHY_747_DATA 0x00000000 +#define DDRSS_PHY_748_DATA 0x00000000 +#define DDRSS_PHY_749_DATA 0x00000000 +#define DDRSS_PHY_750_DATA 0x00000000 +#define DDRSS_PHY_751_DATA 0x00000000 +#define DDRSS_PHY_752_DATA 0x00000000 +#define DDRSS_PHY_753_DATA 0x00000000 +#define DDRSS_PHY_754_DATA 0x00000000 +#define DDRSS_PHY_755_DATA 0x00000000 +#define DDRSS_PHY_756_DATA 0x00000000 +#define DDRSS_PHY_757_DATA 0x00000000 +#define DDRSS_PHY_758_DATA 0x00000000 +#define DDRSS_PHY_759_DATA 0x00000000 +#define DDRSS_PHY_760_DATA 0x00000000 +#define DDRSS_PHY_761_DATA 0x00000000 +#define DDRSS_PHY_762_DATA 0x00000000 +#define DDRSS_PHY_763_DATA 0x00000000 +#define DDRSS_PHY_764_DATA 0x00000000 +#define DDRSS_PHY_765_DATA 0x00000000 +#define DDRSS_PHY_766_DATA 0x00000000 +#define DDRSS_PHY_767_DATA 0x00000000 +#define DDRSS_PHY_768_DATA 0x00000000 +#define DDRSS_PHY_769_DATA 0x00000000 +#define DDRSS_PHY_770_DATA 0x00000000 +#define DDRSS_PHY_771_DATA 0x00000000 +#define DDRSS_PHY_772_DATA 0x00000000 +#define DDRSS_PHY_773_DATA 0x00000100 +#define DDRSS_PHY_774_DATA 0x00000200 +#define DDRSS_PHY_775_DATA 0x00000000 +#define DDRSS_PHY_776_DATA 0x00000000 +#define DDRSS_PHY_777_DATA 0x00000000 +#define DDRSS_PHY_778_DATA 0x00000000 +#define DDRSS_PHY_779_DATA 0x00400000 +#define DDRSS_PHY_780_DATA 0x00000080 +#define DDRSS_PHY_781_DATA 0x00DCBA98 +#define DDRSS_PHY_782_DATA 0x03000000 +#define DDRSS_PHY_783_DATA 0x00200000 +#define DDRSS_PHY_784_DATA 0x00000000 +#define DDRSS_PHY_785_DATA 0x00000000 +#define DDRSS_PHY_786_DATA 0x00000000 +#define DDRSS_PHY_787_DATA 0x00000000 +#define DDRSS_PHY_788_DATA 0x0000002A +#define DDRSS_PHY_789_DATA 0x00000015 +#define DDRSS_PHY_790_DATA 0x00000015 +#define DDRSS_PHY_791_DATA 0x0000002A +#define DDRSS_PHY_792_DATA 0x00000033 +#define DDRSS_PHY_793_DATA 0x0000000C +#define DDRSS_PHY_794_DATA 0x0000000C +#define DDRSS_PHY_795_DATA 0x00000033 +#define DDRSS_PHY_796_DATA 0x00000000 +#define DDRSS_PHY_797_DATA 0x00000000 +#define DDRSS_PHY_798_DATA 0x000F0000 +#define DDRSS_PHY_799_DATA 0x0000000F +#define DDRSS_PHY_800_DATA 0x020002CC +#define DDRSS_PHY_801_DATA 0x00030000 +#define DDRSS_PHY_802_DATA 0x00000300 +#define DDRSS_PHY_803_DATA 0x00000300 +#define DDRSS_PHY_804_DATA 0x00000300 +#define DDRSS_PHY_805_DATA 0x00000300 +#define DDRSS_PHY_806_DATA 0x00000300 +#define DDRSS_PHY_807_DATA 0x42080010 +#define DDRSS_PHY_808_DATA 0x0000803E +#define DDRSS_PHY_809_DATA 0x00000003 +#define DDRSS_PHY_810_DATA 0x00000002 +#define DDRSS_PHY_811_DATA 0x00000000 +#define DDRSS_PHY_812_DATA 0x00000000 +#define DDRSS_PHY_813_DATA 0x00000000 +#define DDRSS_PHY_814_DATA 0x00000000 +#define DDRSS_PHY_815_DATA 0x00000000 +#define DDRSS_PHY_816_DATA 0x00000000 +#define DDRSS_PHY_817_DATA 0x00000000 +#define DDRSS_PHY_818_DATA 0x00000000 +#define DDRSS_PHY_819_DATA 0x00000000 +#define DDRSS_PHY_820_DATA 0x00000000 +#define DDRSS_PHY_821_DATA 0x00000000 +#define DDRSS_PHY_822_DATA 0x00000000 +#define DDRSS_PHY_823_DATA 0x00000000 +#define DDRSS_PHY_824_DATA 0x00000000 +#define DDRSS_PHY_825_DATA 0x00000000 +#define DDRSS_PHY_826_DATA 0x00000000 +#define DDRSS_PHY_827_DATA 0x00000000 +#define DDRSS_PHY_828_DATA 0x00000000 +#define DDRSS_PHY_829_DATA 0x00000000 +#define DDRSS_PHY_830_DATA 0x00000000 +#define DDRSS_PHY_831_DATA 0x00000000 +#define DDRSS_PHY_832_DATA 0x00000000 +#define DDRSS_PHY_833_DATA 0x00000000 +#define DDRSS_PHY_834_DATA 0x00000000 +#define DDRSS_PHY_835_DATA 0x00000000 +#define DDRSS_PHY_836_DATA 0x00000000 +#define DDRSS_PHY_837_DATA 0x00000000 +#define DDRSS_PHY_838_DATA 0x00000000 +#define DDRSS_PHY_839_DATA 0x00000000 +#define DDRSS_PHY_840_DATA 0x00000000 +#define DDRSS_PHY_841_DATA 0x00000000 +#define DDRSS_PHY_842_DATA 0x00000000 +#define DDRSS_PHY_843_DATA 0x00000000 +#define DDRSS_PHY_844_DATA 0x00000000 +#define DDRSS_PHY_845_DATA 0x00000000 +#define DDRSS_PHY_846_DATA 0x00000000 +#define DDRSS_PHY_847_DATA 0x00000000 +#define DDRSS_PHY_848_DATA 0x00000000 +#define DDRSS_PHY_849_DATA 0x00000000 +#define DDRSS_PHY_850_DATA 0x00000000 +#define DDRSS_PHY_851_DATA 0x00000000 +#define DDRSS_PHY_852_DATA 0x00000000 +#define DDRSS_PHY_853_DATA 0x00000000 +#define DDRSS_PHY_854_DATA 0x00000000 +#define DDRSS_PHY_855_DATA 0x00000000 +#define DDRSS_PHY_856_DATA 0x00000000 +#define DDRSS_PHY_857_DATA 0x00000000 +#define DDRSS_PHY_858_DATA 0x00000000 +#define DDRSS_PHY_859_DATA 0x00000000 +#define DDRSS_PHY_860_DATA 0x00000000 +#define DDRSS_PHY_861_DATA 0x00000000 +#define DDRSS_PHY_862_DATA 0x00000000 +#define DDRSS_PHY_863_DATA 0x00000000 +#define DDRSS_PHY_864_DATA 0x00000000 +#define DDRSS_PHY_865_DATA 0x00000000 +#define DDRSS_PHY_866_DATA 0x00000000 +#define DDRSS_PHY_867_DATA 0x00000000 +#define DDRSS_PHY_868_DATA 0x00000000 +#define DDRSS_PHY_869_DATA 0x00000000 +#define DDRSS_PHY_870_DATA 0x00000000 +#define DDRSS_PHY_871_DATA 0x00000000 +#define DDRSS_PHY_872_DATA 0x00000000 +#define DDRSS_PHY_873_DATA 0x00000000 +#define DDRSS_PHY_874_DATA 0x00000000 +#define DDRSS_PHY_875_DATA 0x00000000 +#define DDRSS_PHY_876_DATA 0x00000000 +#define DDRSS_PHY_877_DATA 0x00000000 +#define DDRSS_PHY_878_DATA 0x00000000 +#define DDRSS_PHY_879_DATA 0x00000000 +#define DDRSS_PHY_880_DATA 0x00000000 +#define DDRSS_PHY_881_DATA 0x00000000 +#define DDRSS_PHY_882_DATA 0x00000000 +#define DDRSS_PHY_883_DATA 0x00000000 +#define DDRSS_PHY_884_DATA 0x00000000 +#define DDRSS_PHY_885_DATA 0x00000000 +#define DDRSS_PHY_886_DATA 0x00000000 +#define DDRSS_PHY_887_DATA 0x00000000 +#define DDRSS_PHY_888_DATA 0x00000000 +#define DDRSS_PHY_889_DATA 0x00000000 +#define DDRSS_PHY_890_DATA 0x00000000 +#define DDRSS_PHY_891_DATA 0x00000000 +#define DDRSS_PHY_892_DATA 0x00000000 +#define DDRSS_PHY_893_DATA 0x00000000 +#define DDRSS_PHY_894_DATA 0x00000000 +#define DDRSS_PHY_895_DATA 0x00000000 +#define DDRSS_PHY_896_DATA 0x00000000 +#define DDRSS_PHY_897_DATA 0x00000000 +#define DDRSS_PHY_898_DATA 0x00000000 +#define DDRSS_PHY_899_DATA 0x00000000 +#define DDRSS_PHY_900_DATA 0x00000000 +#define DDRSS_PHY_901_DATA 0x00000000 +#define DDRSS_PHY_902_DATA 0x00000000 +#define DDRSS_PHY_903_DATA 0x00000000 +#define DDRSS_PHY_904_DATA 0x00000000 +#define DDRSS_PHY_905_DATA 0x00000000 +#define DDRSS_PHY_906_DATA 0x00000000 +#define DDRSS_PHY_907_DATA 0x00000000 +#define DDRSS_PHY_908_DATA 0x00000000 +#define DDRSS_PHY_909_DATA 0x00000000 +#define DDRSS_PHY_910_DATA 0x00000000 +#define DDRSS_PHY_911_DATA 0x00000000 +#define DDRSS_PHY_912_DATA 0x00000000 +#define DDRSS_PHY_913_DATA 0x00000000 +#define DDRSS_PHY_914_DATA 0x00000000 +#define DDRSS_PHY_915_DATA 0x00000000 +#define DDRSS_PHY_916_DATA 0x00000000 +#define DDRSS_PHY_917_DATA 0x00000000 +#define DDRSS_PHY_918_DATA 0x00000000 +#define DDRSS_PHY_919_DATA 0x00000000 +#define DDRSS_PHY_920_DATA 0x00000000 +#define DDRSS_PHY_921_DATA 0x00000000 +#define DDRSS_PHY_922_DATA 0x00000000 +#define DDRSS_PHY_923_DATA 0x00000000 +#define DDRSS_PHY_924_DATA 0x00000000 +#define DDRSS_PHY_925_DATA 0x00000000 +#define DDRSS_PHY_926_DATA 0x00000000 +#define DDRSS_PHY_927_DATA 0x00000000 +#define DDRSS_PHY_928_DATA 0x00000000 +#define DDRSS_PHY_929_DATA 0x00000000 +#define DDRSS_PHY_930_DATA 0x00000000 +#define DDRSS_PHY_931_DATA 0x00000000 +#define DDRSS_PHY_932_DATA 0x00000000 +#define DDRSS_PHY_933_DATA 0x00000000 +#define DDRSS_PHY_934_DATA 0x00000000 +#define DDRSS_PHY_935_DATA 0x00000000 +#define DDRSS_PHY_936_DATA 0x00000000 +#define DDRSS_PHY_937_DATA 0x00000000 +#define DDRSS_PHY_938_DATA 0x00000000 +#define DDRSS_PHY_939_DATA 0x00000000 +#define DDRSS_PHY_940_DATA 0x00000000 +#define DDRSS_PHY_941_DATA 0x00000000 +#define DDRSS_PHY_942_DATA 0x00000000 +#define DDRSS_PHY_943_DATA 0x00000000 +#define DDRSS_PHY_944_DATA 0x00000000 +#define DDRSS_PHY_945_DATA 0x00000000 +#define DDRSS_PHY_946_DATA 0x00000000 +#define DDRSS_PHY_947_DATA 0x00000000 +#define DDRSS_PHY_948_DATA 0x00000000 +#define DDRSS_PHY_949_DATA 0x00000000 +#define DDRSS_PHY_950_DATA 0x00000000 +#define DDRSS_PHY_951_DATA 0x00000000 +#define DDRSS_PHY_952_DATA 0x00000000 +#define DDRSS_PHY_953_DATA 0x00000000 +#define DDRSS_PHY_954_DATA 0x00000000 +#define DDRSS_PHY_955_DATA 0x00000000 +#define DDRSS_PHY_956_DATA 0x00000000 +#define DDRSS_PHY_957_DATA 0x00000000 +#define DDRSS_PHY_958_DATA 0x00000000 +#define DDRSS_PHY_959_DATA 0x00000000 +#define DDRSS_PHY_960_DATA 0x00000000 +#define DDRSS_PHY_961_DATA 0x00000000 +#define DDRSS_PHY_962_DATA 0x00000000 +#define DDRSS_PHY_963_DATA 0x00000000 +#define DDRSS_PHY_964_DATA 0x00000000 +#define DDRSS_PHY_965_DATA 0x00000000 +#define DDRSS_PHY_966_DATA 0x00000000 +#define DDRSS_PHY_967_DATA 0x00000000 +#define DDRSS_PHY_968_DATA 0x00000000 +#define DDRSS_PHY_969_DATA 0x00000000 +#define DDRSS_PHY_970_DATA 0x00000000 +#define DDRSS_PHY_971_DATA 0x00000000 +#define DDRSS_PHY_972_DATA 0x00000000 +#define DDRSS_PHY_973_DATA 0x00000000 +#define DDRSS_PHY_974_DATA 0x00000000 +#define DDRSS_PHY_975_DATA 0x00000000 +#define DDRSS_PHY_976_DATA 0x00000000 +#define DDRSS_PHY_977_DATA 0x00000000 +#define DDRSS_PHY_978_DATA 0x00000000 +#define DDRSS_PHY_979_DATA 0x00000000 +#define DDRSS_PHY_980_DATA 0x00000000 +#define DDRSS_PHY_981_DATA 0x00000000 +#define DDRSS_PHY_982_DATA 0x00000000 +#define DDRSS_PHY_983_DATA 0x00000000 +#define DDRSS_PHY_984_DATA 0x00000000 +#define DDRSS_PHY_985_DATA 0x00000000 +#define DDRSS_PHY_986_DATA 0x00000000 +#define DDRSS_PHY_987_DATA 0x00000000 +#define DDRSS_PHY_988_DATA 0x00000000 +#define DDRSS_PHY_989_DATA 0x00000000 +#define DDRSS_PHY_990_DATA 0x00000000 +#define DDRSS_PHY_991_DATA 0x00000000 +#define DDRSS_PHY_992_DATA 0x00000000 +#define DDRSS_PHY_993_DATA 0x00000000 +#define DDRSS_PHY_994_DATA 0x00000000 +#define DDRSS_PHY_995_DATA 0x00000000 +#define DDRSS_PHY_996_DATA 0x00000000 +#define DDRSS_PHY_997_DATA 0x00000000 +#define DDRSS_PHY_998_DATA 0x00000000 +#define DDRSS_PHY_999_DATA 0x00000000 +#define DDRSS_PHY_1000_DATA 0x00000000 +#define DDRSS_PHY_1001_DATA 0x00000000 +#define DDRSS_PHY_1002_DATA 0x00000000 +#define DDRSS_PHY_1003_DATA 0x00000000 +#define DDRSS_PHY_1004_DATA 0x00000000 +#define DDRSS_PHY_1005_DATA 0x00000000 +#define DDRSS_PHY_1006_DATA 0x00000000 +#define DDRSS_PHY_1007_DATA 0x00000000 +#define DDRSS_PHY_1008_DATA 0x00000000 +#define DDRSS_PHY_1009_DATA 0x00000000 +#define DDRSS_PHY_1010_DATA 0x00000000 +#define DDRSS_PHY_1011_DATA 0x00000000 +#define DDRSS_PHY_1012_DATA 0x00000000 +#define DDRSS_PHY_1013_DATA 0x00000000 +#define DDRSS_PHY_1014_DATA 0x00000000 +#define DDRSS_PHY_1015_DATA 0x00000000 +#define DDRSS_PHY_1016_DATA 0x00000000 +#define DDRSS_PHY_1017_DATA 0x00000000 +#define DDRSS_PHY_1018_DATA 0x00000000 +#define DDRSS_PHY_1019_DATA 0x00000000 +#define DDRSS_PHY_1020_DATA 0x00000000 +#define DDRSS_PHY_1021_DATA 0x00000000 +#define DDRSS_PHY_1022_DATA 0x00000000 +#define DDRSS_PHY_1023_DATA 0x00000000 +#define DDRSS_PHY_1024_DATA 0x00000000 +#define DDRSS_PHY_1025_DATA 0x00000000 +#define DDRSS_PHY_1026_DATA 0x00000000 +#define DDRSS_PHY_1027_DATA 0x00000000 +#define DDRSS_PHY_1028_DATA 0x00000000 +#define DDRSS_PHY_1029_DATA 0x00000100 +#define DDRSS_PHY_1030_DATA 0x00000200 +#define DDRSS_PHY_1031_DATA 0x00000000 +#define DDRSS_PHY_1032_DATA 0x00000000 +#define DDRSS_PHY_1033_DATA 0x00000000 +#define DDRSS_PHY_1034_DATA 0x00000000 +#define DDRSS_PHY_1035_DATA 0x00400000 +#define DDRSS_PHY_1036_DATA 0x00000080 +#define DDRSS_PHY_1037_DATA 0x00DCBA98 +#define DDRSS_PHY_1038_DATA 0x03000000 +#define DDRSS_PHY_1039_DATA 0x00200000 +#define DDRSS_PHY_1040_DATA 0x00000000 +#define DDRSS_PHY_1041_DATA 0x00000000 +#define DDRSS_PHY_1042_DATA 0x00000000 +#define DDRSS_PHY_1043_DATA 0x00000000 +#define DDRSS_PHY_1044_DATA 0x0000002A +#define DDRSS_PHY_1045_DATA 0x00000015 +#define DDRSS_PHY_1046_DATA 0x00000015 +#define DDRSS_PHY_1047_DATA 0x0000002A +#define DDRSS_PHY_1048_DATA 0x00000033 +#define DDRSS_PHY_1049_DATA 0x0000000C +#define DDRSS_PHY_1050_DATA 0x0000000C +#define DDRSS_PHY_1051_DATA 0x00000033 +#define DDRSS_PHY_1052_DATA 0x2307B9AC +#define DDRSS_PHY_1053_DATA 0x10000000 +#define DDRSS_PHY_1054_DATA 0x000F0000 +#define DDRSS_PHY_1055_DATA 0x0000000F +#define DDRSS_PHY_1056_DATA 0x020002CC +#define DDRSS_PHY_1057_DATA 0x00030000 +#define DDRSS_PHY_1058_DATA 0x00000300 +#define DDRSS_PHY_1059_DATA 0x00000300 +#define DDRSS_PHY_1060_DATA 0x00000300 +#define DDRSS_PHY_1061_DATA 0x00000300 +#define DDRSS_PHY_1062_DATA 0x00000300 +#define DDRSS_PHY_1063_DATA 0x42080010 +#define DDRSS_PHY_1064_DATA 0x0000803E +#define DDRSS_PHY_1065_DATA 0x00000003 +#define DDRSS_PHY_1066_DATA 0x00000002 +#define DDRSS_PHY_1067_DATA 0x00000000 +#define DDRSS_PHY_1068_DATA 0x00000000 +#define DDRSS_PHY_1069_DATA 0x00000000 +#define DDRSS_PHY_1070_DATA 0x00000000 +#define DDRSS_PHY_1071_DATA 0x00000000 +#define DDRSS_PHY_1072_DATA 0x00000000 +#define DDRSS_PHY_1073_DATA 0x00000000 +#define DDRSS_PHY_1074_DATA 0x00000000 +#define DDRSS_PHY_1075_DATA 0x00000000 +#define DDRSS_PHY_1076_DATA 0x00000000 +#define DDRSS_PHY_1077_DATA 0x00000000 +#define DDRSS_PHY_1078_DATA 0x00000000 +#define DDRSS_PHY_1079_DATA 0x00000000 +#define DDRSS_PHY_1080_DATA 0x00000000 +#define DDRSS_PHY_1081_DATA 0x00000000 +#define DDRSS_PHY_1082_DATA 0x00000000 +#define DDRSS_PHY_1083_DATA 0x00000000 +#define DDRSS_PHY_1084_DATA 0x00000000 +#define DDRSS_PHY_1085_DATA 0x00000000 +#define DDRSS_PHY_1086_DATA 0x00000000 +#define DDRSS_PHY_1087_DATA 0x00000000 +#define DDRSS_PHY_1088_DATA 0x00000000 +#define DDRSS_PHY_1089_DATA 0x00000000 +#define DDRSS_PHY_1090_DATA 0x00000000 +#define DDRSS_PHY_1091_DATA 0x00000000 +#define DDRSS_PHY_1092_DATA 0x00000000 +#define DDRSS_PHY_1093_DATA 0x00000000 +#define DDRSS_PHY_1094_DATA 0x00000000 +#define DDRSS_PHY_1095_DATA 0x00000000 +#define DDRSS_PHY_1096_DATA 0x00000000 +#define DDRSS_PHY_1097_DATA 0x00000000 +#define DDRSS_PHY_1098_DATA 0x00000000 +#define DDRSS_PHY_1099_DATA 0x00000000 +#define DDRSS_PHY_1100_DATA 0x00000000 +#define DDRSS_PHY_1101_DATA 0x00000000 +#define DDRSS_PHY_1102_DATA 0x00000000 +#define DDRSS_PHY_1103_DATA 0x00000000 +#define DDRSS_PHY_1104_DATA 0x00000000 +#define DDRSS_PHY_1105_DATA 0x00000000 +#define DDRSS_PHY_1106_DATA 0x00000000 +#define DDRSS_PHY_1107_DATA 0x00000000 +#define DDRSS_PHY_1108_DATA 0x00000000 +#define DDRSS_PHY_1109_DATA 0x00000000 +#define DDRSS_PHY_1110_DATA 0x00000000 +#define DDRSS_PHY_1111_DATA 0x00000000 +#define DDRSS_PHY_1112_DATA 0x00000000 +#define DDRSS_PHY_1113_DATA 0x00000000 +#define DDRSS_PHY_1114_DATA 0x00000000 +#define DDRSS_PHY_1115_DATA 0x00000000 +#define DDRSS_PHY_1116_DATA 0x00000000 +#define DDRSS_PHY_1117_DATA 0x00000000 +#define DDRSS_PHY_1118_DATA 0x00000000 +#define DDRSS_PHY_1119_DATA 0x00000000 +#define DDRSS_PHY_1120_DATA 0x00000000 +#define DDRSS_PHY_1121_DATA 0x00000000 +#define DDRSS_PHY_1122_DATA 0x00000000 +#define DDRSS_PHY_1123_DATA 0x00000000 +#define DDRSS_PHY_1124_DATA 0x00000000 +#define DDRSS_PHY_1125_DATA 0x00000000 +#define DDRSS_PHY_1126_DATA 0x00000000 +#define DDRSS_PHY_1127_DATA 0x00000000 +#define DDRSS_PHY_1128_DATA 0x00000000 +#define DDRSS_PHY_1129_DATA 0x00000000 +#define DDRSS_PHY_1130_DATA 0x00000000 +#define DDRSS_PHY_1131_DATA 0x00000000 +#define DDRSS_PHY_1132_DATA 0x00000000 +#define DDRSS_PHY_1133_DATA 0x00000000 +#define DDRSS_PHY_1134_DATA 0x00000000 +#define DDRSS_PHY_1135_DATA 0x00000000 +#define DDRSS_PHY_1136_DATA 0x00000000 +#define DDRSS_PHY_1137_DATA 0x00000000 +#define DDRSS_PHY_1138_DATA 0x00000000 +#define DDRSS_PHY_1139_DATA 0x00000000 +#define DDRSS_PHY_1140_DATA 0x00000000 +#define DDRSS_PHY_1141_DATA 0x00000000 +#define DDRSS_PHY_1142_DATA 0x00000000 +#define DDRSS_PHY_1143_DATA 0x00000000 +#define DDRSS_PHY_1144_DATA 0x00000000 +#define DDRSS_PHY_1145_DATA 0x00000000 +#define DDRSS_PHY_1146_DATA 0x00000000 +#define DDRSS_PHY_1147_DATA 0x00000000 +#define DDRSS_PHY_1148_DATA 0x00000000 +#define DDRSS_PHY_1149_DATA 0x00000000 +#define DDRSS_PHY_1150_DATA 0x00000000 +#define DDRSS_PHY_1151_DATA 0x00000000 +#define DDRSS_PHY_1152_DATA 0x00000000 +#define DDRSS_PHY_1153_DATA 0x00000000 +#define DDRSS_PHY_1154_DATA 0x00000000 +#define DDRSS_PHY_1155_DATA 0x00000000 +#define DDRSS_PHY_1156_DATA 0x00000000 +#define DDRSS_PHY_1157_DATA 0x00000000 +#define DDRSS_PHY_1158_DATA 0x00000000 +#define DDRSS_PHY_1159_DATA 0x00000000 +#define DDRSS_PHY_1160_DATA 0x00000000 +#define DDRSS_PHY_1161_DATA 0x00000000 +#define DDRSS_PHY_1162_DATA 0x00000000 +#define DDRSS_PHY_1163_DATA 0x00000000 +#define DDRSS_PHY_1164_DATA 0x00000000 +#define DDRSS_PHY_1165_DATA 0x00000000 +#define DDRSS_PHY_1166_DATA 0x00000000 +#define DDRSS_PHY_1167_DATA 0x00000000 +#define DDRSS_PHY_1168_DATA 0x00000000 +#define DDRSS_PHY_1169_DATA 0x00000000 +#define DDRSS_PHY_1170_DATA 0x00000000 +#define DDRSS_PHY_1171_DATA 0x00000000 +#define DDRSS_PHY_1172_DATA 0x00000000 +#define DDRSS_PHY_1173_DATA 0x00000000 +#define DDRSS_PHY_1174_DATA 0x00000000 +#define DDRSS_PHY_1175_DATA 0x00000000 +#define DDRSS_PHY_1176_DATA 0x00000000 +#define DDRSS_PHY_1177_DATA 0x00000000 +#define DDRSS_PHY_1178_DATA 0x00000000 +#define DDRSS_PHY_1179_DATA 0x00000000 +#define DDRSS_PHY_1180_DATA 0x00000000 +#define DDRSS_PHY_1181_DATA 0x00000000 +#define DDRSS_PHY_1182_DATA 0x00000000 +#define DDRSS_PHY_1183_DATA 0x00000000 +#define DDRSS_PHY_1184_DATA 0x00000000 +#define DDRSS_PHY_1185_DATA 0x00000000 +#define DDRSS_PHY_1186_DATA 0x00000000 +#define DDRSS_PHY_1187_DATA 0x00000000 +#define DDRSS_PHY_1188_DATA 0x00000000 +#define DDRSS_PHY_1189_DATA 0x00000000 +#define DDRSS_PHY_1190_DATA 0x00000000 +#define DDRSS_PHY_1191_DATA 0x00000000 +#define DDRSS_PHY_1192_DATA 0x00000000 +#define DDRSS_PHY_1193_DATA 0x00000000 +#define DDRSS_PHY_1194_DATA 0x00000000 +#define DDRSS_PHY_1195_DATA 0x00000000 +#define DDRSS_PHY_1196_DATA 0x00000000 +#define DDRSS_PHY_1197_DATA 0x00000000 +#define DDRSS_PHY_1198_DATA 0x00000000 +#define DDRSS_PHY_1199_DATA 0x00000000 +#define DDRSS_PHY_1200_DATA 0x00000000 +#define DDRSS_PHY_1201_DATA 0x00000000 +#define DDRSS_PHY_1202_DATA 0x00000000 +#define DDRSS_PHY_1203_DATA 0x00000000 +#define DDRSS_PHY_1204_DATA 0x00000000 +#define DDRSS_PHY_1205_DATA 0x00000000 +#define DDRSS_PHY_1206_DATA 0x00000000 +#define DDRSS_PHY_1207_DATA 0x00000000 +#define DDRSS_PHY_1208_DATA 0x00000000 +#define DDRSS_PHY_1209_DATA 0x00000000 +#define DDRSS_PHY_1210_DATA 0x00000000 +#define DDRSS_PHY_1211_DATA 0x00000000 +#define DDRSS_PHY_1212_DATA 0x00000000 +#define DDRSS_PHY_1213_DATA 0x00000000 +#define DDRSS_PHY_1214_DATA 0x00000000 +#define DDRSS_PHY_1215_DATA 0x00000000 +#define DDRSS_PHY_1216_DATA 0x00000000 +#define DDRSS_PHY_1217_DATA 0x00000000 +#define DDRSS_PHY_1218_DATA 0x00000000 +#define DDRSS_PHY_1219_DATA 0x00000000 +#define DDRSS_PHY_1220_DATA 0x00000000 +#define DDRSS_PHY_1221_DATA 0x00000000 +#define DDRSS_PHY_1222_DATA 0x00000000 +#define DDRSS_PHY_1223_DATA 0x00000000 +#define DDRSS_PHY_1224_DATA 0x00000000 +#define DDRSS_PHY_1225_DATA 0x00000000 +#define DDRSS_PHY_1226_DATA 0x00000000 +#define DDRSS_PHY_1227_DATA 0x00000000 +#define DDRSS_PHY_1228_DATA 0x00000000 +#define DDRSS_PHY_1229_DATA 0x00000000 +#define DDRSS_PHY_1230_DATA 0x00000000 +#define DDRSS_PHY_1231_DATA 0x00000000 +#define DDRSS_PHY_1232_DATA 0x00000000 +#define DDRSS_PHY_1233_DATA 0x00000000 +#define DDRSS_PHY_1234_DATA 0x00000000 +#define DDRSS_PHY_1235_DATA 0x00000000 +#define DDRSS_PHY_1236_DATA 0x00000000 +#define DDRSS_PHY_1237_DATA 0x00000000 +#define DDRSS_PHY_1238_DATA 0x00000000 +#define DDRSS_PHY_1239_DATA 0x00000000 +#define DDRSS_PHY_1240_DATA 0x00000000 +#define DDRSS_PHY_1241_DATA 0x00000000 +#define DDRSS_PHY_1242_DATA 0x00000000 +#define DDRSS_PHY_1243_DATA 0x00000000 +#define DDRSS_PHY_1244_DATA 0x00000000 +#define DDRSS_PHY_1245_DATA 0x00000000 +#define DDRSS_PHY_1246_DATA 0x00000000 +#define DDRSS_PHY_1247_DATA 0x00000000 +#define DDRSS_PHY_1248_DATA 0x00000000 +#define DDRSS_PHY_1249_DATA 0x00000000 +#define DDRSS_PHY_1250_DATA 0x00000000 +#define DDRSS_PHY_1251_DATA 0x00000000 +#define DDRSS_PHY_1252_DATA 0x00000000 +#define DDRSS_PHY_1253_DATA 0x00000000 +#define DDRSS_PHY_1254_DATA 0x00000000 +#define DDRSS_PHY_1255_DATA 0x00000000 +#define DDRSS_PHY_1256_DATA 0x00000000 +#define DDRSS_PHY_1257_DATA 0x00000000 +#define DDRSS_PHY_1258_DATA 0x00000000 +#define DDRSS_PHY_1259_DATA 0x00000000 +#define DDRSS_PHY_1260_DATA 0x00000000 +#define DDRSS_PHY_1261_DATA 0x00000000 +#define DDRSS_PHY_1262_DATA 0x00000000 +#define DDRSS_PHY_1263_DATA 0x00000000 +#define DDRSS_PHY_1264_DATA 0x00000000 +#define DDRSS_PHY_1265_DATA 0x00000000 +#define DDRSS_PHY_1266_DATA 0x00000000 +#define DDRSS_PHY_1267_DATA 0x00000000 +#define DDRSS_PHY_1268_DATA 0x00000000 +#define DDRSS_PHY_1269_DATA 0x00000000 +#define DDRSS_PHY_1270_DATA 0x00000000 +#define DDRSS_PHY_1271_DATA 0x00000000 +#define DDRSS_PHY_1272_DATA 0x00000000 +#define DDRSS_PHY_1273_DATA 0x00000000 +#define DDRSS_PHY_1274_DATA 0x00000000 +#define DDRSS_PHY_1275_DATA 0x00000000 +#define DDRSS_PHY_1276_DATA 0x00000000 +#define DDRSS_PHY_1277_DATA 0x00000000 +#define DDRSS_PHY_1278_DATA 0x00000000 +#define DDRSS_PHY_1279_DATA 0x00000000 +#define DDRSS_PHY_1280_DATA 0x00000000 +#define DDRSS_PHY_1281_DATA 0x00010100 +#define DDRSS_PHY_1282_DATA 0x00000000 +#define DDRSS_PHY_1283_DATA 0x00000000 +#define DDRSS_PHY_1284_DATA 0x00000000 +#define DDRSS_PHY_1285_DATA 0x00000000 +#define DDRSS_PHY_1286_DATA 0x00050000 +#define DDRSS_PHY_1287_DATA 0x04000000 +#define DDRSS_PHY_1288_DATA 0x00000055 +#define DDRSS_PHY_1289_DATA 0x00000000 +#define DDRSS_PHY_1290_DATA 0x00000000 +#define DDRSS_PHY_1291_DATA 0x00000000 +#define DDRSS_PHY_1292_DATA 0x00000000 +#define DDRSS_PHY_1293_DATA 0x00002001 +#define DDRSS_PHY_1294_DATA 0x00004001 +#define DDRSS_PHY_1295_DATA 0x00020028 +#define DDRSS_PHY_1296_DATA 0x01010100 +#define DDRSS_PHY_1297_DATA 0x00000000 +#define DDRSS_PHY_1298_DATA 0x00000000 +#define DDRSS_PHY_1299_DATA 0x0F0F0E06 +#define DDRSS_PHY_1300_DATA 0x00010101 +#define DDRSS_PHY_1301_DATA 0x010F0004 +#define DDRSS_PHY_1302_DATA 0x00000000 +#define DDRSS_PHY_1303_DATA 0x00000000 +#define DDRSS_PHY_1304_DATA 0x00000064 +#define DDRSS_PHY_1305_DATA 0x00000000 +#define DDRSS_PHY_1306_DATA 0x00000000 +#define DDRSS_PHY_1307_DATA 0x01020103 +#define DDRSS_PHY_1308_DATA 0x0F020102 +#define DDRSS_PHY_1309_DATA 0x03030303 +#define DDRSS_PHY_1310_DATA 0x03030303 +#define DDRSS_PHY_1311_DATA 0x00041B42 +#define DDRSS_PHY_1312_DATA 0x00005201 +#define DDRSS_PHY_1313_DATA 0x00000000 +#define DDRSS_PHY_1314_DATA 0x00000000 +#define DDRSS_PHY_1315_DATA 0x00000000 +#define DDRSS_PHY_1316_DATA 0x00000000 +#define DDRSS_PHY_1317_DATA 0x00000000 +#define DDRSS_PHY_1318_DATA 0x00000000 +#define DDRSS_PHY_1319_DATA 0x07030101 +#define DDRSS_PHY_1320_DATA 0x00005400 +#define DDRSS_PHY_1321_DATA 0x000040A2 +#define DDRSS_PHY_1322_DATA 0x00024410 +#define DDRSS_PHY_1323_DATA 0x00004410 +#define DDRSS_PHY_1324_DATA 0x00004410 +#define DDRSS_PHY_1325_DATA 0x00004410 +#define DDRSS_PHY_1326_DATA 0x00004410 +#define DDRSS_PHY_1327_DATA 0x00004410 +#define DDRSS_PHY_1328_DATA 0x00004410 +#define DDRSS_PHY_1329_DATA 0x00004410 +#define DDRSS_PHY_1330_DATA 0x00004410 +#define DDRSS_PHY_1331_DATA 0x00004410 +#define DDRSS_PHY_1332_DATA 0x00000000 +#define DDRSS_PHY_1333_DATA 0x00000076 +#define DDRSS_PHY_1334_DATA 0x00000400 +#define DDRSS_PHY_1335_DATA 0x00000008 +#define DDRSS_PHY_1336_DATA 0x00000000 +#define DDRSS_PHY_1337_DATA 0x00000000 +#define DDRSS_PHY_1338_DATA 0x00000000 +#define DDRSS_PHY_1339_DATA 0x00000000 +#define DDRSS_PHY_1340_DATA 0x00000000 +#define DDRSS_PHY_1341_DATA 0x03000000 +#define DDRSS_PHY_1342_DATA 0x00000000 +#define DDRSS_PHY_1343_DATA 0x00000000 +#define DDRSS_PHY_1344_DATA 0x00000000 +#define DDRSS_PHY_1345_DATA 0x04102006 +#define DDRSS_PHY_1346_DATA 0x00041020 +#define DDRSS_PHY_1347_DATA 0x01C98C98 +#define DDRSS_PHY_1348_DATA 0x3F400000 +#define DDRSS_PHY_1349_DATA 0x3F3F1F3F +#define DDRSS_PHY_1350_DATA 0x0000001F +#define DDRSS_PHY_1351_DATA 0x00000000 +#define DDRSS_PHY_1352_DATA 0x00000000 +#define DDRSS_PHY_1353_DATA 0x00000000 +#define DDRSS_PHY_1354_DATA 0x00000001 +#define DDRSS_PHY_1355_DATA 0x00000000 +#define DDRSS_PHY_1356_DATA 0x00000000 +#define DDRSS_PHY_1357_DATA 0x00000000 +#define DDRSS_PHY_1358_DATA 0x00000000 +#define DDRSS_PHY_1359_DATA 0x76543210 +#define DDRSS_PHY_1360_DATA 0x00040198 +#define DDRSS_PHY_1361_DATA 0x00000000 +#define DDRSS_PHY_1362_DATA 0x00000000 +#define DDRSS_PHY_1363_DATA 0x00000000 +#define DDRSS_PHY_1364_DATA 0x00040700 +#define DDRSS_PHY_1365_DATA 0x00000000 +#define DDRSS_PHY_1366_DATA 0x00000000 +#define DDRSS_PHY_1367_DATA 0x00000000 +#define DDRSS_PHY_1368_DATA 0x00000002 +#define DDRSS_PHY_1369_DATA 0x00000000 +#define DDRSS_PHY_1370_DATA 0x00000000 +#define DDRSS_PHY_1371_DATA 0x0001F7C2 +#define DDRSS_PHY_1372_DATA 0x00020002 +#define DDRSS_PHY_1373_DATA 0x00000000 +#define DDRSS_PHY_1374_DATA 0x00001142 +#define DDRSS_PHY_1375_DATA 0x03020000 +#define DDRSS_PHY_1376_DATA 0x00000080 +#define DDRSS_PHY_1377_DATA 0x03900390 +#define DDRSS_PHY_1378_DATA 0x03900390 +#define DDRSS_PHY_1379_DATA 0x03900390 +#define DDRSS_PHY_1380_DATA 0x03900390 +#define DDRSS_PHY_1381_DATA 0x03000300 +#define DDRSS_PHY_1382_DATA 0x03000300 +#define DDRSS_PHY_1383_DATA 0x00000300 +#define DDRSS_PHY_1384_DATA 0x00000300 +#define DDRSS_PHY_1385_DATA 0x00000300 +#define DDRSS_PHY_1386_DATA 0x00000300 +#define DDRSS_PHY_1387_DATA 0x3183BF77 +#define DDRSS_PHY_1388_DATA 0x00000000 +#define DDRSS_PHY_1389_DATA 0x0C000DFF +#define DDRSS_PHY_1390_DATA 0x30000DFF +#define DDRSS_PHY_1391_DATA 0x3F0DFF11 +#define DDRSS_PHY_1392_DATA 0x01990000 +#define DDRSS_PHY_1393_DATA 0x780DFFCC +#define DDRSS_PHY_1394_DATA 0x00000C11 +#define DDRSS_PHY_1395_DATA 0x00018011 +#define DDRSS_PHY_1396_DATA 0x0089FF00 +#define DDRSS_PHY_1397_DATA 0x000C3F11 +#define DDRSS_PHY_1398_DATA 0x01990000 +#define DDRSS_PHY_1399_DATA 0x000C3F11 +#define DDRSS_PHY_1400_DATA 0x01990000 +#define DDRSS_PHY_1401_DATA 0x3F0DFF11 +#define DDRSS_PHY_1402_DATA 0x01990000 +#define DDRSS_PHY_1403_DATA 0x00018011 +#define DDRSS_PHY_1404_DATA 0x0089FF00 +#define DDRSS_PHY_1405_DATA 0x20040004 diff --git a/arch/arm/dts/k3-am625-verdin-r5.dts b/arch/arm/dts/k3-am625-verdin-r5.dts new file mode 100644 index 00000000000..4fda412129c --- /dev/null +++ b/arch/arm/dts/k3-am625-verdin-r5.dts @@ -0,0 +1,116 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Toradex Verdin AM62 dts file for R5 SPL + * Copyright 2023 Toradex - https://www.toradex.com/ + */ + +#include "k3-am625-verdin-wifi-dev.dts" +#include "k3-am625-verdin-lpddr4-1600MTs.dtsi" +#include "k3-am62-ddr.dtsi" + +#include "k3-am625-verdin-wifi-dev-binman.dtsi" +#include "k3-am625-verdin-wifi-dev-u-boot.dtsi" + +/ { + a53_0: a53@0 { + compatible = "ti,am654-rproc"; + reg = <0x00 0x00a90000 0x00 0x10>; + /* + * FIXME: Currently only the SPL running on the R5 has a clock + * driver. As a workaround therefore move the assigned-clock + * stuff required for our ETH_25MHz_CLK from the cpsw3g_mdio + * node of the regular device tree to here (last one each in + * below three lines, adding a <0> as spacing for parents). + */ + assigned-clocks = <&k3_clks 61 0>, <&k3_clks 135 0>, <&k3_clks 157 20>; + assigned-clock-parents = <&k3_clks 61 2>, <0>, <&k3_clks 157 22>; + assigned-clock-rates = <200000000>, <1200000000>, <25000000>; + clocks = <&k3_clks 61 0>; + power-domains = <&k3_pds 61 TI_SCI_PD_EXCLUSIVE>, + <&k3_pds 135 TI_SCI_PD_EXCLUSIVE>, + <&k3_pds 166 TI_SCI_PD_EXCLUSIVE>; + resets = <&k3_reset 135 0>; + ti,sci = <&dmsc>; + ti,sci-host-id = <10>; + ti,sci-proc-id = <32>; + bootph-pre-ram; + }; + + aliases { + remoteproc0 = &sysctrler; + remoteproc1 = &a53_0; + }; + + dm_tifs: dm-tifs { + compatible = "ti,j721e-dm-sci"; + mbox-names = "rx", "tx"; + mboxes= <&secure_proxy_main 22>, + <&secure_proxy_main 23>; + ti,host-id = <36>; + ti,secure-host; + bootph-pre-ram; + }; + + memory@80000000 { + device_type = "memory"; + /* 1G RAM */ + reg = <0x00000000 0x80000000 0x00000000 0x40000000>; + bootph-pre-ram; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + secure_ddr: optee@9e800000 { + reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */ + alignment = <0x1000>; + no-map; + }; + }; +}; + +&cbass_main { + sa3_secproxy: secproxy@44880000 { + compatible = "ti,am654-secure-proxy"; + #mbox-cells = <1>; + reg-names = "rt", "scfg", "target_data"; + reg = <0x00 0x44880000 0x00 0x20000>, + <0x00 0x44860000 0x00 0x20000>, + <0x00 0x43600000 0x00 0x10000>; + bootph-pre-ram; + }; + + sysctrler: sysctrler { + compatible = "ti,am654-system-controller"; + mboxes= <&secure_proxy_main 1>, <&secure_proxy_main 0>, <&sa3_secproxy 0>; + mbox-names = "tx", "rx", "boot_notify"; + bootph-pre-ram; + }; + + main_esm: esm@420000 { + compatible = "ti,j721e-esm"; + reg = <0x0 0x420000 0x0 0x1000>; + ti,esm-pins = <160>, <161>, <162>, <163>, <177>, <178>; + bootph-pre-ram; + }; +}; + +&cbass_mcu { + mcu_esm: esm@4100000 { + compatible = "ti,j721e-esm"; + reg = <0x0 0x4100000 0x0 0x1000>; + ti,esm-pins = <0>, <1>, <2>, <85>; + bootph-pre-ram; + }; +}; + +&dmsc { + mboxes= <&secure_proxy_main 0>, + <&secure_proxy_main 1>, + <&secure_proxy_main 0>; + mbox-names = "rx", "tx", "notify"; + ti,host-id = <35>; + ti,secure-host; +}; diff --git a/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi b/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi new file mode 100644 index 00000000000..e8c926f48b9 --- /dev/null +++ b/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi @@ -0,0 +1,570 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright 2023 Toradex + */ + +#include "k3-binman.dtsi" + +&binman { + custMpk { + filename = "custMpk.pem"; + blob-ext { + filename = "../../ti/keys/custMpk.pem"; + }; + }; + + ti-degenerate-key { + filename = "ti-degenerate-key.pem"; + blob-ext { + filename = "../../ti/keys/ti-degenerate-key.pem"; + }; + }; +}; + +#ifndef CONFIG_ARM64 + +&binman { + board-cfg { + filename = "board-cfg.bin"; + bcfg_yaml: ti-board-config { + config = "board-cfg.yaml"; + schema = "../../ti/common/schema.yaml"; + }; + }; + pm-cfg { + filename = "pm-cfg.bin"; + rcfg_yaml: ti-board-config { + config = "pm-cfg.yaml"; + schema = "../../ti/common/schema.yaml"; + }; + }; + rm-cfg { + filename = "rm-cfg.bin"; + pcfg_yaml: ti-board-config { + config = "rm-cfg.yaml"; + schema = "../../ti/common/schema.yaml"; + }; + }; + sec-cfg { + filename = "sec-cfg.bin"; + scfg_yaml: ti-board-config { + config = "sec-cfg.yaml"; + schema = "../../ti/common/schema.yaml"; + }; + }; + combined-tifs-cfg { + filename = "combined-tifs-cfg.bin"; + ti-board-config { + bcfg_yaml_tifs: board-cfg { + config = "board-cfg.yaml"; + schema = "../../ti/common/schema.yaml"; + }; + scfg_yaml_tifs: sec-cfg { + config = "sec-cfg.yaml"; + schema = "../../ti/common/schema.yaml"; + }; + pcfg_yaml_tifs: pm-cfg { + config = "pm-cfg.yaml"; + schema = "../../ti/common/schema.yaml"; + }; + rcfg_yaml_tifs: rm-cfg { + config = "rm-cfg.yaml"; + schema = "../../ti/common/schema.yaml"; + }; + }; + }; + combined-dm-cfg { + filename = "combined-dm-cfg.bin"; + ti-board-config { + pcfg_yaml_dm: pm-cfg { + config = "pm-cfg.yaml"; + schema = "../../ti/common/schema.yaml"; + }; + rcfg_yaml_dm: rm-cfg { + config = "rm-cfg.yaml"; + schema = "../../ti/common/schema.yaml"; + }; + }; + }; + combined-sysfw-cfg { + filename = "combined-sysfw-cfg.bin"; + ti-board-config { + board-cfg { + config = "board-cfg.yaml"; + schema = "../../ti/common/schema.yaml"; + }; + sec-cfg { + config = "sec-cfg.yaml"; + schema = "../../ti/common/schema.yaml"; + }; + pm-cfg { + config = "pm-cfg.yaml"; + schema = "../../ti/common/schema.yaml"; + }; + rm-cfg { + config = "rm-cfg.yaml"; + schema = "../../ti/common/schema.yaml"; + }; + }; + }; +}; + +#endif /* CONFIG_ARM64 */ + +#ifdef CONFIG_TARGET_VERDIN_AM62_R5 + +&binman { + tiboot3-am62x-hs-verdin.bin { + filename = "tiboot3-am62x-hs-verdin.bin"; + ti-secure-rom { + content = <&u_boot_spl>, <&ti_fs_enc>, <&combined_tifs_cfg>, + <&combined_dm_cfg>, <&sysfw_inner_cert>; + combined; + dm-data; + sysfw-inner-cert; + keyfile = "custMpk.pem"; + sw-rev = <1>; + content-sbl = <&u_boot_spl>; + content-sysfw = <&ti_fs_enc>; + content-sysfw-data = <&combined_tifs_cfg>; + content-sysfw-inner-cert = <&sysfw_inner_cert>; + content-dm-data = <&combined_dm_cfg>; + load = <0x43c00000>; + load-sysfw = <0x40000>; + load-sysfw-data = <0x67000>; + load-dm-data = <0x43c3a800>; + }; + u_boot_spl: u-boot-spl { + no-expanded; + }; + ti_fs_enc: ti-fs-enc.bin { + filename = "ti-sysfw/ti-fs-firmware-am62x-hs-enc.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg: combined-tifs-cfg.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + sysfw_inner_cert: sysfw-inner-cert { + filename = "ti-sysfw/ti-fs-firmware-am62x-hs-cert.bin"; + type = "blob-ext"; + optional; + }; + combined_dm_cfg: combined-dm-cfg.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + }; +}; + +&binman { + tiboot3-am62x-hs-fs-verdin.bin { + filename = "tiboot3-am62x-hs-fs-verdin.bin"; + symlink = "tiboot3.bin"; + ti-secure-rom { + content = <&u_boot_spl_fs>, <&ti_fs_enc_fs>, <&combined_tifs_cfg_fs>, + <&combined_dm_cfg_fs>, <&sysfw_inner_cert_fs>; + combined; + dm-data; + sysfw-inner-cert; + keyfile = "custMpk.pem"; + sw-rev = <1>; + content-sbl = <&u_boot_spl_fs>; + content-sysfw = <&ti_fs_enc_fs>; + content-sysfw-data = <&combined_tifs_cfg_fs>; + content-sysfw-inner-cert = <&sysfw_inner_cert_fs>; + content-dm-data = <&combined_dm_cfg_fs>; + load = <0x43c00000>; + load-sysfw = <0x40000>; + load-sysfw-data = <0x67000>; + load-dm-data = <0x43c3a800>; + }; + u_boot_spl_fs: u-boot-spl { + no-expanded; + }; + ti_fs_enc_fs: ti-fs-enc.bin { + filename = "ti-sysfw/ti-fs-firmware-am62x-hs-fs-enc.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg_fs: combined-tifs-cfg.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + sysfw_inner_cert_fs: sysfw-inner-cert { + filename = "ti-sysfw/ti-fs-firmware-am62x-hs-fs-cert.bin"; + type = "blob-ext"; + optional; + }; + combined_dm_cfg_fs: combined-dm-cfg.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + }; +}; + +&binman { + tiboot3-am62x-gp-verdin.bin { + filename = "tiboot3-am62x-gp-verdin.bin"; + ti-secure-rom { + content = <&u_boot_spl_unsigned>, <&ti_fs_gp>, + <&combined_tifs_cfg_gp>, <&combined_dm_cfg_gp>; + combined; + dm-data; + content-sbl = <&u_boot_spl_unsigned>; + load = <0x43c00000>; + content-sysfw = <&ti_fs_gp>; + load-sysfw = <0x40000>; + content-sysfw-data = <&combined_tifs_cfg_gp>; + load-sysfw-data = <0x67000>; + content-dm-data = <&combined_dm_cfg_gp>; + load-dm-data = <0x43c3a800>; + sw-rev = <1>; + keyfile = "ti-degenerate-key.pem"; + }; + u_boot_spl_unsigned: u-boot-spl { + no-expanded; + }; + ti_fs_gp: ti-fs-gp.bin { + filename = "ti-sysfw/ti-fs-firmware-am62x-gp.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg_gp: combined-tifs-cfg-gp.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + combined_dm_cfg_gp: combined-dm-cfg-gp.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + + }; +}; + +#endif /* CONFIG_TARGET_VERDIN_AM62_R5 */ + +#ifdef CONFIG_TARGET_VERDIN_AM62_A53 + +#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" +#define SPL_VERDIN_AM62_DTB "spl/dts/k3-am625-verdin-wifi-dev.dtb" + +#define UBOOT_NODTB "u-boot-nodtb.bin" +#define VERDIN_AM62_DTB "u-boot.dtb" + +&binman { + ti-dm { + filename = "ti-dm.bin"; + blob-ext { + filename = "ti-dm/am62xx/ipc_echo_testb_mcu1_0_release_strip.xer5f"; + }; + }; + ti-spl { + filename = "tispl.bin"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + ti-secure { + content = <&atf>; + keyfile = "custMpk.pem"; + }; + atf: atf-bl31 { + }; + }; + + tee { + description = "OP-TEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + ti-secure { + content = <&tee>; + keyfile = "custMpk.pem"; + }; + tee: tee-os { + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + ti-secure { + content = <&dm>; + keyfile = "custMpk.pem"; + }; + dm: blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + ti-secure { + content = <&u_boot_spl_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_spl_nodtb: blob-ext { + filename = SPL_NODTB; + }; + }; + + fdt-0 { + description = "k3-am625-verdin-wifi-dev"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_verdin_am62_dtb>; + keyfile = "custMpk.pem"; + }; + spl_verdin_am62_dtb: blob-ext { + filename = SPL_VERDIN_AM62_DTB; + }; + + }; + + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am625-verdin-wifi-dev"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; + +&binman { + u-boot { + filename = "u-boot.img"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for AM625 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + ti-secure { + content = <&u_boot_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_nodtb: u-boot-nodtb { + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-am625-verdin-wifi-dev"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&verdin_am62_dtb>; + keyfile = "custMpk.pem"; + }; + verdin_am62_dtb: blob-ext { + filename = VERDIN_AM62_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am625-verdin-wifi-dev"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + + }; + }; + }; +}; + +&binman { + ti-spl_unsigned { + filename = "tispl.bin_unsigned"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + filename = "bl31.bin"; + }; + }; + + tee { + description = "OP-TEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + filename = "tee-raw.bin"; + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + blob { + filename = "spl/u-boot-spl-nodtb.bin"; + }; + }; + + fdt-0 { + description = "k3-am625-verdin-wifi-dev"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = SPL_VERDIN_AM62_DTB; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am625-verdin-wifi-dev"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; + +&binman { + u-boot_unsigned { + filename = "u-boot.img_unsigned"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for AM625 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + blob { + filename = UBOOT_NODTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-am625-verdin-wifi-dev"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = VERDIN_AM62_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am625-verdin-wifi-dev"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; + +#endif /* CONFIG_TARGET_VERDIN_AM62_A53 */ diff --git a/arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi b/arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi new file mode 100644 index 00000000000..5d564603eb2 --- /dev/null +++ b/arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi @@ -0,0 +1,201 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright 2023 Toradex + */ + +#include "k3-am625-verdin-wifi-dev-binman.dtsi" + +/ { + aliases { + eeprom0 = &eeprom_module; + eeprom1 = &eeprom_carrier_board; + eeprom2 = &eeprom_display_adapter; + }; + + chosen { + tick-timer = &main_timer0; + }; + + memory@80000000 { + bootph-pre-ram; + }; +}; + +&cbass_main { + bootph-pre-ram; + + timer@2400000 { + clock-frequency = <25000000>; + bootph-pre-ram; + }; +}; + +&cbass_mcu { + bootph-pre-ram; +}; + +&cbass_wakeup { + bootph-pre-ram; +}; + +&chipid { + bootph-pre-ram; +}; + +&cpsw3g { + bootph-pre-ram; +}; + +&cpsw3g_phy0 { + bootph-pre-ram; +}; + +&cpsw3g_phy1 { + bootph-pre-ram; +}; + +&cpsw_port1 { + bootph-pre-ram; +}; + +&cpsw_port2 { + bootph-pre-ram; +}; + +/* MDIO, shared by Verdin ETH_1 (On-module PHY) and Verdin ETH_2_RGMII */ +&cpsw3g_mdio { + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-parents; + /delete-property/ assigned-clock-rates; + bootph-pre-ram; +}; + +&dmsc { + bootph-pre-ram; + + k3_sysreset: sysreset-controller { + compatible = "ti,sci-sysreset"; + bootph-pre-ram; + }; +}; + +&dmss { + bootph-pre-ram; +}; + +&fss { + bootph-pre-ram; +}; + +&k3_clks { + bootph-pre-ram; +}; + +&k3_pds { + bootph-pre-ram; +}; + +&k3_reset { + bootph-pre-ram; +}; + +&main_gpio0 { + bootph-pre-ram; +}; + +/* On-module I2C - PMIC_I2C */ +&main_i2c0 { + eeprom_module: eeprom@50 { + compatible = "i2c-eeprom"; + pagesize = <16>; + reg = <0x50>; + }; +}; + +/* Verdin I2C_1 */ +&main_i2c1 { + /* EEPROM on display adapter (MIPI DSI Display Adapter) */ + eeprom_display_adapter: eeprom@50 { + compatible = "i2c-eeprom"; + reg = <0x50>; + pagesize = <16>; + }; + + /* EEPROM on carrier board */ + eeprom_carrier_board: eeprom@57 { + compatible = "i2c-eeprom"; + reg = <0x57>; + pagesize = <16>; + }; +}; + +&main_pmx0 { + bootph-pre-ram; +}; + +/* Verdin UART_3, used as the Linux console */ +&main_uart0 { + bootph-pre-ram; +}; + +/* Verdin UART_1 */ +&main_uart1 { + bootph-pre-ram; +}; + +&mcu_pmx0 { + bootph-pre-ram; +}; + +&pinctrl_ctrl_sleep_moci { + bootph-pre-ram; +}; + +&pinctrl_i2c0 { + bootph-pre-ram; +}; + +&pinctrl_i2c1 { + bootph-pre-ram; +}; + +&pinctrl_sdhci0 { + bootph-pre-ram; +}; + +&pinctrl_uart0 { + bootph-pre-ram; +}; + +&pinctrl_uart1 { + bootph-pre-ram; +}; + +&pinctrl_wkup_uart0 { + bootph-pre-ram; +}; + +&sdhci0 { + bootph-pre-ram; +}; + +&sdhci2 { + status = "disabled"; +}; + +&secure_proxy_main { + bootph-pre-ram; +}; + +&verdin_ctrl_sleep_moci { + bootph-pre-ram; +}; + +&wkup_conf { + bootph-pre-ram; +}; + +/* Verdin UART_2 */ +&wkup_uart0 { + bootph-pre-ram; +}; diff --git a/arch/arm/dts/k3-am625-verdin-wifi-dev.dts b/arch/arm/dts/k3-am625-verdin-wifi-dev.dts new file mode 100644 index 00000000000..4b657d6d3e0 --- /dev/null +++ b/arch/arm/dts/k3-am625-verdin-wifi-dev.dts @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright 2023 Toradex + * + * https://www.toradex.com/computer-on-modules/verdin-arm-family/ti-am62 + * https://www.toradex.com/products/carrier-board/verdin-development-board-kit + */ + +/dts-v1/; + +#include "k3-am625.dtsi" +#include "k3-am62-verdin.dtsi" +#include "k3-am62-verdin-wifi.dtsi" +#include "k3-am62-verdin-dev.dtsi" + +/ { + model = "Toradex Verdin AM62 WB on Verdin Development Board"; + compatible = "toradex,verdin-am62-wifi-dev", + "toradex,verdin-am62-wifi", + "toradex,verdin-am62", + "ti,am625"; +}; diff --git a/arch/arm/mach-k3/Kconfig b/arch/arm/mach-k3/Kconfig index bf1c3c51a41..9168bf842dc 100644 --- a/arch/arm/mach-k3/Kconfig +++ b/arch/arm/mach-k3/Kconfig @@ -194,4 +194,5 @@ source "board/ti/am62ax/Kconfig" source "board/ti/j721e/Kconfig" source "board/siemens/iot2050/Kconfig" source "board/ti/j721s2/Kconfig" +source "board/toradex/verdin-am62/Kconfig" endif diff --git a/board/toradex/verdin-am62/Kconfig b/board/toradex/verdin-am62/Kconfig new file mode 100644 index 00000000000..e7522244070 --- /dev/null +++ b/board/toradex/verdin-am62/Kconfig @@ -0,0 +1,82 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# +# Copyright 2023 Toradex +# + +choice + prompt "Toradex Verdin AM62 based boards" + optional + +config TARGET_VERDIN_AM62_A53 + bool "Toradex Verdin AM62 running on A53" + select ARM64 + select BINMAN + +config TARGET_VERDIN_AM62_R5 + bool "Toradex Verdin AM62 running on R5" + select CPU_V7R + select SYS_THUMB_BUILD + select K3_LOAD_SYSFW + select RAM + select SPL_RAM + select K3_DDRSS + select BINMAN + imply SYS_K3_SPL_ATF + +endchoice + +if TARGET_VERDIN_AM62_A53 + +config SYS_BOARD + default "verdin-am62" + +config SYS_CONFIG_NAME + default "verdin-am62" + +config SYS_VENDOR + default "toradex" + +config TDX_CFG_BLOCK + default y + +config TDX_CFG_BLOCK_2ND_ETHADDR + default y + +config TDX_CFG_BLOCK_DEV + default "0" + +config TDX_CFG_BLOCK_EXTRA + default y + +# Toradex config block in eMMC, at the end of 1st "boot sector" +config TDX_CFG_BLOCK_OFFSET + default "-512" + +config TDX_CFG_BLOCK_PART + default "1" + +config TDX_HAVE_EEPROM_EXTRA + default y + +config TDX_HAVE_MMC + default y + +source "board/toradex/common/Kconfig" + +endif + +if TARGET_VERDIN_AM62_R5 + +config SPL_LDSCRIPT + default "arch/arm/mach-omap2/u-boot-spl.lds" + +config SYS_BOARD + default "verdin-am62" + +config SYS_CONFIG_NAME + default "verdin-am62" + +config SYS_VENDOR + default "toradex" + +endif diff --git a/board/toradex/verdin-am62/MAINTAINERS b/board/toradex/verdin-am62/MAINTAINERS new file mode 100644 index 00000000000..4e75980dbd7 --- /dev/null +++ b/board/toradex/verdin-am62/MAINTAINERS @@ -0,0 +1,17 @@ +Verdin AM62 +F: arch/arm/dts/k3-am625-verdin-lpddr4-1600MTs.dtsi +F: arch/arm/dts/k3-am625-verdin-r5.dts +F: arch/arm/dts/k3-am625-verdin-wifi-dev.dts +F: arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi +F: arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi +F: arch/arm/dts/k3-am62-verdin-dev.dtsi +F: arch/arm/dts/k3-am62-verdin.dtsi +F: arch/arm/dts/k3-am62-verdin-wifi.dtsi +F: board/toradex/verdin-am62/ +F: configs/verdin-am62_a53_defconfig +F: configs/verdin-am62_r5_defconfig +F: doc/board/toradex/verdin-am62.rst +F: include/configs/verdin-am62.h +M: Marcel Ziswiler marcel.ziswiler@toradex.com +S: Maintained +W: https://www.toradex.com/computer-on-modules/verdin-arm-family/ti-am-62 diff --git a/board/toradex/verdin-am62/Makefile b/board/toradex/verdin-am62/Makefile new file mode 100644 index 00000000000..af1a5508ed1 --- /dev/null +++ b/board/toradex/verdin-am62/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# +# Copyright 2023 Toradex +# + +obj-y += verdin-am62.o diff --git a/board/toradex/verdin-am62/board-cfg.yaml b/board/toradex/verdin-am62/board-cfg.yaml new file mode 100644 index 00000000000..36cfb550adf --- /dev/null +++ b/board/toradex/verdin-am62/board-cfg.yaml @@ -0,0 +1,36 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022-2023 Texas Instruments Incorporated - https://www.ti.com/ +# +# Board configuration for AM62 +# + +--- + +board-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + control: + subhdr: + magic: 0xC1D3 + size: 7 + main_isolation_enable : 0x5A + main_isolation_hostid : 0x2 + secproxy: + subhdr: + magic: 0x1207 + size: 7 + scaling_factor : 0x1 + scaling_profile : 0x1 + disable_main_nav_secure_proxy : 0 + msmc: + subhdr: + magic: 0xA5C3 + size: 5 + msmc_cache_size : 0x0 + debug_cfg: + subhdr: + magic: 0x020C + size: 8 + trace_dst_enables : 0x00 + trace_src_enables : 0x00 diff --git a/board/toradex/verdin-am62/pm-cfg.yaml b/board/toradex/verdin-am62/pm-cfg.yaml new file mode 100644 index 00000000000..5d04cf82ef7 --- /dev/null +++ b/board/toradex/verdin-am62/pm-cfg.yaml @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022-2023 Texas Instruments Incorporated - https://www.ti.com/ +# +# Power management configuration for AM62 +# + +--- + +pm-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 diff --git a/board/toradex/verdin-am62/rm-cfg.yaml b/board/toradex/verdin-am62/rm-cfg.yaml new file mode 100644 index 00000000000..c28707be8e2 --- /dev/null +++ b/board/toradex/verdin-am62/rm-cfg.yaml @@ -0,0 +1,1088 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022-2023 Texas Instruments Incorporated - https://www.ti.com/ +# +# Resource management configuration for AM62 +# + +--- + +rm-cfg: + rm_boardcfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + host_cfg: + subhdr: + magic: 0x4C41 + size : 356 + host_cfg_entries: + - #1 + host_id: 12 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #2 + host_id: 30 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #3 + host_id: 36 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #4 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #5 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #6 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #7 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #8 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #9 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #10 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #11 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #12 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #13 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #14 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #15 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #16 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #17 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #18 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #19 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #20 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #21 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #22 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #23 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #24 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #25 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #26 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #27 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #28 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #29 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #30 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #31 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #32 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + resasg: + subhdr: + magic: 0x7B25 + size : 8 + resasg_entries_size: 960 + reserved : 0 + resasg_entries: + - + start_resource: 0 + num_resource: 16 + type: 64 + host_id: 12 + reserved: 0 + + - + start_resource: 16 + num_resource: 4 + type: 64 + host_id: 35 + reserved: 0 + + - + start_resource: 16 + num_resource: 4 + type: 64 + host_id: 36 + reserved: 0 + + - + start_resource: 20 + num_resource: 22 + type: 64 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 16 + type: 192 + host_id: 12 + reserved: 0 + + - + start_resource: 34 + num_resource: 2 + type: 192 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 320 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 320 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 26 + type: 384 + host_id: 128 + reserved: 0 + + - + start_resource: 50176 + num_resource: 164 + type: 1666 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 1667 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 18 + type: 1677 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1677 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1677 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 1677 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 6 + type: 1677 + host_id: 128 + reserved: 0 + + - + start_resource: 54 + num_resource: 18 + type: 1678 + host_id: 12 + reserved: 0 + + - + start_resource: 72 + num_resource: 6 + type: 1678 + host_id: 35 + reserved: 0 + + - + start_resource: 72 + num_resource: 6 + type: 1678 + host_id: 36 + reserved: 0 + + - + start_resource: 78 + num_resource: 2 + type: 1678 + host_id: 30 + reserved: 0 + + - + start_resource: 80 + num_resource: 2 + type: 1678 + host_id: 128 + reserved: 0 + + - + start_resource: 32 + num_resource: 12 + type: 1679 + host_id: 12 + reserved: 0 + + - + start_resource: 44 + num_resource: 6 + type: 1679 + host_id: 35 + reserved: 0 + + - + start_resource: 44 + num_resource: 6 + type: 1679 + host_id: 36 + reserved: 0 + + - + start_resource: 50 + num_resource: 2 + type: 1679 + host_id: 30 + reserved: 0 + + - + start_resource: 52 + num_resource: 2 + type: 1679 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 18 + type: 1696 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1696 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1696 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 1696 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 6 + type: 1696 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 18 + type: 1697 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1697 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1697 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 1697 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 2 + type: 1697 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 12 + type: 1698 + host_id: 12 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 1698 + host_id: 35 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 1698 + host_id: 36 + reserved: 0 + + - + start_resource: 18 + num_resource: 2 + type: 1698 + host_id: 30 + reserved: 0 + + - + start_resource: 20 + num_resource: 2 + type: 1698 + host_id: 128 + reserved: 0 + + - + start_resource: 5 + num_resource: 35 + type: 1802 + host_id: 12 + reserved: 0 + + - + start_resource: 44 + num_resource: 36 + type: 1802 + host_id: 35 + reserved: 0 + + - + start_resource: 44 + num_resource: 36 + type: 1802 + host_id: 36 + reserved: 0 + + - + start_resource: 168 + num_resource: 8 + type: 1802 + host_id: 30 + reserved: 0 + + - + start_resource: 13 + num_resource: 512 + type: 1805 + host_id: 12 + reserved: 0 + + - + start_resource: 525 + num_resource: 256 + type: 1805 + host_id: 35 + reserved: 0 + + - + start_resource: 525 + num_resource: 256 + type: 1805 + host_id: 36 + reserved: 0 + + - + start_resource: 781 + num_resource: 128 + type: 1805 + host_id: 30 + reserved: 0 + + - + start_resource: 909 + num_resource: 627 + type: 1805 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1024 + type: 1807 + host_id: 128 + reserved: 0 + + - + start_resource: 4096 + num_resource: 29 + type: 1808 + host_id: 128 + reserved: 0 + + - + start_resource: 4608 + num_resource: 99 + type: 1809 + host_id: 128 + reserved: 0 + + - + start_resource: 5120 + num_resource: 24 + type: 1810 + host_id: 128 + reserved: 0 + + - + start_resource: 5632 + num_resource: 51 + type: 1811 + host_id: 128 + reserved: 0 + + - + start_resource: 6144 + num_resource: 51 + type: 1812 + host_id: 128 + reserved: 0 + + - + start_resource: 6656 + num_resource: 51 + type: 1813 + host_id: 128 + reserved: 0 + + - + start_resource: 8192 + num_resource: 32 + type: 1814 + host_id: 128 + reserved: 0 + + - + start_resource: 8704 + num_resource: 32 + type: 1815 + host_id: 128 + reserved: 0 + + - + start_resource: 9216 + num_resource: 32 + type: 1816 + host_id: 128 + reserved: 0 + + - + start_resource: 9728 + num_resource: 22 + type: 1817 + host_id: 128 + reserved: 0 + + - + start_resource: 10240 + num_resource: 22 + type: 1818 + host_id: 128 + reserved: 0 + + - + start_resource: 10752 + num_resource: 22 + type: 1819 + host_id: 128 + reserved: 0 + + - + start_resource: 11264 + num_resource: 28 + type: 1820 + host_id: 128 + reserved: 0 + + - + start_resource: 11776 + num_resource: 28 + type: 1821 + host_id: 128 + reserved: 0 + + - + start_resource: 12288 + num_resource: 28 + type: 1822 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 1923 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 1936 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1936 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1936 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 1936 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 1936 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 64 + type: 1937 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 64 + type: 1937 + host_id: 36 + reserved: 0 + + - + start_resource: 83 + num_resource: 8 + type: 1938 + host_id: 12 + reserved: 0 + + - + start_resource: 91 + num_resource: 8 + type: 1939 + host_id: 12 + reserved: 0 + + - + start_resource: 99 + num_resource: 10 + type: 1942 + host_id: 12 + reserved: 0 + + - + start_resource: 109 + num_resource: 3 + type: 1942 + host_id: 35 + reserved: 0 + + - + start_resource: 109 + num_resource: 3 + type: 1942 + host_id: 36 + reserved: 0 + + - + start_resource: 112 + num_resource: 3 + type: 1942 + host_id: 30 + reserved: 0 + + - + start_resource: 115 + num_resource: 3 + type: 1942 + host_id: 128 + reserved: 0 + + - + start_resource: 118 + num_resource: 16 + type: 1943 + host_id: 12 + reserved: 0 + + - + start_resource: 118 + num_resource: 16 + type: 1943 + host_id: 36 + reserved: 0 + + - + start_resource: 134 + num_resource: 8 + type: 1944 + host_id: 12 + reserved: 0 + + - + start_resource: 134 + num_resource: 8 + type: 1945 + host_id: 12 + reserved: 0 + + - + start_resource: 142 + num_resource: 8 + type: 1946 + host_id: 12 + reserved: 0 + + - + start_resource: 142 + num_resource: 8 + type: 1947 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 1955 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1955 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1955 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 1955 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 1955 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 8 + type: 1956 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 8 + type: 1956 + host_id: 36 + reserved: 0 + + - + start_resource: 27 + num_resource: 1 + type: 1957 + host_id: 12 + reserved: 0 + + - + start_resource: 28 + num_resource: 1 + type: 1958 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 1961 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1961 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1961 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 1961 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 1961 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 1962 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1962 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1962 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 1962 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 1962 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 1 + type: 1963 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 1 + type: 1963 + host_id: 36 + reserved: 0 + + - + start_resource: 19 + num_resource: 16 + type: 1964 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 16 + type: 1964 + host_id: 36 + reserved: 0 + + - + start_resource: 20 + num_resource: 1 + type: 1965 + host_id: 12 + reserved: 0 + + - + start_resource: 35 + num_resource: 8 + type: 1966 + host_id: 12 + reserved: 0 + + - + start_resource: 21 + num_resource: 1 + type: 1967 + host_id: 12 + reserved: 0 + + - + start_resource: 35 + num_resource: 8 + type: 1968 + host_id: 12 + reserved: 0 + + - + start_resource: 22 + num_resource: 1 + type: 1969 + host_id: 12 + reserved: 0 + + - + start_resource: 43 + num_resource: 8 + type: 1970 + host_id: 12 + reserved: 0 + + - + start_resource: 23 + num_resource: 1 + type: 1971 + host_id: 12 + reserved: 0 + + - + start_resource: 43 + num_resource: 8 + type: 1972 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 2112 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 2 + type: 2122 + host_id: 12 + reserved: 0 diff --git a/board/toradex/verdin-am62/sec-cfg.yaml b/board/toradex/verdin-am62/sec-cfg.yaml new file mode 100644 index 00000000000..07081ce06ca --- /dev/null +++ b/board/toradex/verdin-am62/sec-cfg.yaml @@ -0,0 +1,379 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022-2023 Texas Instruments Incorporated - https://www.ti.com/ +# +# Security management configuration for AM62 +# + +--- + +sec-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + processor_acl_list: + subhdr: + magic: 0xF1EA + size: 164 + proc_acl_entries: + - #1 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #2 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #3 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #4 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #5 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #6 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #7 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #8 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #9 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #10 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #11 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #12 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #13 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #14 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #15 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #16 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #17 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #18 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #19 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #20 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #21 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #22 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #23 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #24 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #25 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #26 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #27 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #28 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #29 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #30 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #31 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #32 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + host_hierarchy: + subhdr: + magic: 0x8D27 + size: 68 + host_hierarchy_entries: + - #1 + host_id: 0 + supervisor_host_id: 0 + - #2 + host_id: 0 + supervisor_host_id: 0 + - #3 + host_id: 0 + supervisor_host_id: 0 + - #4 + host_id: 0 + supervisor_host_id: 0 + - #5 + host_id: 0 + supervisor_host_id: 0 + - #6 + host_id: 0 + supervisor_host_id: 0 + - #7 + host_id: 0 + supervisor_host_id: 0 + - #8 + host_id: 0 + supervisor_host_id: 0 + - #9 + host_id: 0 + supervisor_host_id: 0 + - #10 + host_id: 0 + supervisor_host_id: 0 + - #11 + host_id: 0 + supervisor_host_id: 0 + - #12 + host_id: 0 + supervisor_host_id: 0 + - #13 + host_id: 0 + supervisor_host_id: 0 + - #14 + host_id: 0 + supervisor_host_id: 0 + - #15 + host_id: 0 + supervisor_host_id: 0 + - #16 + host_id: 0 + supervisor_host_id: 0 + - #17 + host_id: 0 + supervisor_host_id: 0 + - #18 + host_id: 0 + supervisor_host_id: 0 + - #19 + host_id: 0 + supervisor_host_id: 0 + - #20 + host_id: 0 + supervisor_host_id: 0 + - #21 + host_id: 0 + supervisor_host_id: 0 + - #22 + host_id: 0 + supervisor_host_id: 0 + - #23 + host_id: 0 + supervisor_host_id: 0 + - #24 + host_id: 0 + supervisor_host_id: 0 + - #25 + host_id: 0 + supervisor_host_id: 0 + - #26 + host_id: 0 + supervisor_host_id: 0 + - #27 + host_id: 0 + supervisor_host_id: 0 + - #28 + host_id: 0 + supervisor_host_id: 0 + - #29 + host_id: 0 + supervisor_host_id: 0 + - #30 + host_id: 0 + supervisor_host_id: 0 + - #31 + host_id: 0 + supervisor_host_id: 0 + - #32 + host_id: 0 + supervisor_host_id: 0 + otp_config: + subhdr: + magic: 0x4081 + size: 69 + write_host_id : 0 + otp_entry: + - #1 + host_id: 0 + host_perms: 0 + - #2 + host_id: 0 + host_perms: 0 + - #3 + host_id: 0 + host_perms: 0 + - #4 + host_id: 0 + host_perms: 0 + - #5 + host_id: 0 + host_perms: 0 + - #6 + host_id: 0 + host_perms: 0 + - #7 + host_id: 0 + host_perms: 0 + - #8 + host_id: 0 + host_perms: 0 + - #9 + host_id: 0 + host_perms: 0 + - #10 + host_id: 0 + host_perms: 0 + - #11 + host_id: 0 + host_perms: 0 + - #12 + host_id: 0 + host_perms: 0 + - #13 + host_id: 0 + host_perms: 0 + - #14 + host_id: 0 + host_perms: 0 + - #15 + host_id: 0 + host_perms: 0 + - #16 + host_id: 0 + host_perms: 0 + - #17 + host_id: 0 + host_perms: 0 + - #18 + host_id: 0 + host_perms: 0 + - #19 + host_id: 0 + host_perms: 0 + - #20 + host_id: 0 + host_perms: 0 + - #21 + host_id: 0 + host_perms: 0 + - #22 + host_id: 0 + host_perms: 0 + - #23 + host_id: 0 + host_perms: 0 + - #24 + host_id: 0 + host_perms: 0 + - #25 + host_id: 0 + host_perms: 0 + - #26 + host_id: 0 + host_perms: 0 + - #27 + host_id: 0 + host_perms: 0 + - #28 + host_id: 0 + host_perms: 0 + - #29 + host_id: 0 + host_perms: 0 + - #30 + host_id: 0 + host_perms: 0 + - #31 + host_id: 0 + host_perms: 0 + - #32 + host_id: 0 + host_perms: 0 + dkek_config: + subhdr: + magic: 0x5170 + size: 12 + allowed_hosts: [128, 0, 0, 0] + allow_dkek_export_tisci : 0x5A + rsvd: [0, 0, 0] + sa2ul_cfg: + subhdr: + magic: 0x23BE + size : 0 + auth_resource_owner: 0 + enable_saul_psil_global_config_writes: 0x5A + rsvd: [0, 0] + sec_dbg_config: + subhdr: + magic: 0x42AF + size: 16 + allow_jtag_unlock : 0x5A + allow_wildcard_unlock : 0x5A + allowed_debug_level_rsvd: 0 + rsvd: 0 + min_cert_rev : 0x0 + jtag_unlock_hosts: [0, 0, 0, 0] + sec_handover_cfg: + subhdr: + magic: 0x608F + size: 10 + handover_msg_sender : 0 + handover_to_host_id : 0 + rsvd: [0, 0, 0, 0] diff --git a/board/toradex/verdin-am62/verdin-am62.c b/board/toradex/verdin-am62/verdin-am62.c new file mode 100644 index 00000000000..5b166b14ca6 --- /dev/null +++ b/board/toradex/verdin-am62/verdin-am62.c @@ -0,0 +1,131 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Board specific initialization for Verdin AM62 SoM + * + * Copyright 2023 Toradex - https://www.toradex.com/ + * + */ + +#include <asm/arch/hardware.h> +#include <asm/io.h> +#include <dm/uclass.h> +#include <env.h> +#include <fdt_support.h> +#include <init.h> +#include <k3-ddrss.h> +#include <spl.h> + +#include "../common/tdx-cfg-block.h" + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + return 0; +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((long *)CFG_SYS_SDRAM_BASE, CFG_SYS_SDRAM_SIZE); + + if (gd->ram_size < SZ_64M) + puts("## WARNING: Less than 64MB RAM detected\n"); + + return 0; +} + +/* + * Avoid relocated U-Boot clash with Linux reserved-memory on 512 MB SoM + */ +phys_size_t board_get_usable_ram_top(phys_size_t total_size) +{ + return 0x9C000000; +} + +#if defined(CONFIG_SPL_LOAD_FIT) +int board_fit_config_name_match(const char *name) +{ + return 0; +} +#endif + +#if IS_ENABLED(CONFIG_OF_LIBFDT) && IS_ENABLED(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, struct bd_info *bd) +{ + return ft_common_board_setup(blob, bd); +} +#endif + +static void select_dt_from_module_version(void) +{ + char variant[32]; + char *env_variant = env_get("variant"); + int is_wifi = 0; + + if (IS_ENABLED(CONFIG_TDX_CFG_BLOCK)) { + /* + * If we have a valid config block and it says we are a module with + * Wi-Fi/Bluetooth make sure we use the -wifi device tree. + */ + is_wifi = (tdx_hw_tag.prodid == VERDIN_AM62Q_WIFI_BT_IT) || + (tdx_hw_tag.prodid == VERDIN_AM62S_512MB_WIFI_BT_IT) || + (tdx_hw_tag.prodid == VERDIN_AM62D_1G_WIFI_BT_IT) || + (tdx_hw_tag.prodid == VERDIN_AM62Q_2G_WIFI_BT_IT); + } + + if (is_wifi) + strlcpy(&variant[0], "wifi", sizeof(variant)); + else + strlcpy(&variant[0], "nonwifi", sizeof(variant)); + + if (strcmp(variant, env_variant)) { + printf("Setting variant to %s\n", variant); + env_set("variant", variant); + } +} + +int board_late_init(void) +{ + select_dt_from_module_version(); + + return 0; +} + +#define CTRLMMR_USB0_PHY_CTRL 0x43004008 +#define CTRLMMR_USB1_PHY_CTRL 0x43004018 +#define CORE_VOLTAGE 0x80000000 +#define MCU_CTRL_LFXOSC_32K_BYPASS_VAL BIT(4) + +#ifdef CONFIG_SPL_BOARD_INIT +void spl_board_init(void) +{ + u32 val; + + /* Set USB0 PHY core voltage to 0.85V */ + val = readl(CTRLMMR_USB0_PHY_CTRL); + val &= ~(CORE_VOLTAGE); + writel(val, CTRLMMR_USB0_PHY_CTRL); + + /* Set USB1 PHY core voltage to 0.85V */ + val = readl(CTRLMMR_USB1_PHY_CTRL); + val &= ~(CORE_VOLTAGE); + writel(val, CTRLMMR_USB1_PHY_CTRL); + + /* We use the 32k FOUT from the Epson RX8130CE RTC chip */ + /* In WKUP_LFOSC0 clear the power down bit and set the bypass bit + * The bypass bit is required as we provide a CMOS clock signal and + * the power down seems to be required also in the bypass case + * despite of the datasheet stating otherwise + */ + /* Compare with the AM62 datasheet, + * Table 7-21. LFXOSC Modes of Operation + */ + val = readl(MCU_CTRL_LFXOSC_CTRL); + val &= ~MCU_CTRL_LFXOSC_32K_DISABLE_VAL; + val |= MCU_CTRL_LFXOSC_32K_BYPASS_VAL; + writel(val, MCU_CTRL_LFXOSC_CTRL); + /* Make sure to mux up to take the SoC 32k from the LFOSC input */ + writel(MCU_CTRL_DEVICE_CLKOUT_LFOSC_SELECT_VAL, + MCU_CTRL_DEVICE_CLKOUT_32K_CTRL); +} +#endif diff --git a/configs/verdin-am62_a53_defconfig b/configs/verdin-am62_a53_defconfig new file mode 100644 index 00000000000..efeb9e2e38b --- /dev/null +++ b/configs/verdin-am62_a53_defconfig @@ -0,0 +1,187 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_ARCH_K3=y +CONFIG_TI_SECURE_DEVICE=y +CONFIG_SYS_MALLOC_LEN=0x2000000 +CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_SOC_K3_AM625=y +CONFIG_K3_ATF_LOAD_ADDR=0x9e780000 +CONFIG_TARGET_VERDIN_AM62_A53=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80b80000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFDE00 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="k3-am625-verdin-wifi-dev" +CONFIG_SPL_TEXT_BASE=0x80080000 +CONFIG_SYS_PROMPT="Verdin AM62 # " +CONFIG_DM_RESET=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_STACK_R_ADDR=0x82000000 +CONFIG_SPL_SIZE_LIMIT=0x40000 +CONFIG_SPL_SIZE_LIMIT_PROVIDE_STACK=0x800 +CONFIG_SPL_FS_FAT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SYS_LOAD_ADDR=0x88200000 +CONFIG_SYS_MEMTEST_START=0x80000000 +CONFIG_SYS_MEMTEST_END=0xB0000000 +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 +CONFIG_SPL_LOAD_FIT_APPLY_OVERLAY=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_BOOTDELAY=1 +CONFIG_USE_PREBOOT=y +CONFIG_PREBOOT="test -n ${fdtfile} || setenv fdtfile k3-am625-verdin-${variant}-${fdt_board}.dtb" +CONFIG_LOG=y +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x58000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x80c80000 +CONFIG_SPL_BSS_MAX_SIZE=0x80000 +CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_STACK_R=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 +CONFIG_SPL_DMA=y +CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" +CONFIG_SPL_I2C=y +CONFIG_SPL_DM_MAILBOX=y +CONFIG_SPL_POWER_DOMAIN=y +CONFIG_SPL_RAM_SUPPORT=y +CONFIG_SPL_RAM_DEVICE=y +CONFIG_SPL_THERMAL=y +CONFIG_SPL_YMODEM_SUPPORT=y +CONFIG_SYS_MAXARGS=64 +CONFIG_SYS_BOOTM_LEN=0x40000000 +CONFIG_CMD_ADTIMG=y +CONFIG_CMD_ASKENV=y +# CONFIG_CMD_EXPORTENV is not set +CONFIG_CRC32_VERIFY=y +CONFIG_CMD_MD5SUM=y +CONFIG_MD5SUM_VERIFY=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_BCB=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DM=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_READ=y +CONFIG_CMD_REMOTEPROC=y +CONFIG_CMD_BOOTCOUNT=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_UUID=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT4_WRITE=y +# CONFIG_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_PART=1 +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_USE_ETHPRIME=y +CONFIG_ETHPRIME="eth0" +CONFIG_VERSION_VARIABLE=y +CONFIG_IP_DEFRAG=y +CONFIG_TFTP_BLOCKSIZE=4096 +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_CLK_TI_SCI=y +CONFIG_DMA_CHANNELS=y +CONFIG_TI_K3_NAVSS_UDMA=y +CONFIG_TI_SCI_PROTOCOL=y +CONFIG_GPIO_HOG=y +CONFIG_SPL_GPIO_HOG=y +CONFIG_SPL_DM_GPIO_LOOKUP_LABEL=y +CONFIG_DA8XX_GPIO=y +CONFIG_DM_I2C=y +CONFIG_DM_I2C_GPIO=y +CONFIG_SYS_I2C_OMAP24XX=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_DM_MAILBOX=y +CONFIG_K3_SEC_PROXY=y +CONFIG_I2C_EEPROM=y +CONFIG_SPL_I2C_EEPROM=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_SPL_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_SPL_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS200_SUPPORT=y +CONFIG_SPL_MMC_HS200_SUPPORT=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ADMA=y +CONFIG_SPL_MMC_SDHCI_ADMA=y +CONFIG_MMC_SDHCI_AM654=y +CONFIG_PHY_ADDR_ENABLE=y +CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_PHY_TI_DP83867=y +CONFIG_PHY_ETHERNET_ID=y +CONFIG_PHY_FIXED=y +CONFIG_DM_MDIO=y +CONFIG_DM_ETH_PHY=y +CONFIG_RGMII=y +CONFIG_MII=y +CONFIG_TI_AM65_CPSW_NUSS=y +CONFIG_PHY=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_SINGLE=y +CONFIG_POWER_DOMAIN=y +CONFIG_TI_SCI_POWER_DOMAIN=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_TPS65219=y +CONFIG_DM_REGULATOR=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_SPL_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPL_DM_REGULATOR_GPIO=y +CONFIG_DM_REGULATOR_TPS65219=y +CONFIG_K3_SYSTEM_CONTROLLER=y +CONFIG_REMOTEPROC_TI_K3_ARM64=y +CONFIG_RESET_TI_SCI=y +CONFIG_DM_SERIAL=y +CONFIG_SOC_DEVICE=y +CONFIG_SOC_DEVICE_TI_K3=y +CONFIG_SOC_TI=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_TI_SCI=y +CONFIG_DM_THERMAL=y +CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 +CONFIG_HEXDUMP=y diff --git a/configs/verdin-am62_r5_defconfig b/configs/verdin-am62_r5_defconfig new file mode 100644 index 00000000000..878195a61ac --- /dev/null +++ b/configs/verdin-am62_r5_defconfig @@ -0,0 +1,111 @@ +CONFIG_ARM=y +CONFIG_ARCH_K3=y +CONFIG_TI_SECURE_DEVICE=y +CONFIG_SYS_MALLOC_LEN=0x08000000 +CONFIG_SYS_MALLOC_F_LEN=0x9000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_SOC_K3_AM625=y +CONFIG_TARGET_VERDIN_AM62_R5=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x43c3a7f0 +CONFIG_ENV_SIZE=0x20000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="k3-am625-verdin-r5" +CONFIG_SPL_TEXT_BASE=0x43c00000 +CONFIG_DM_RESET=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_STACK_R_ADDR=0x82000000 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x7000 +CONFIG_SPL_SIZE_LIMIT=0x3A7F0 +CONFIG_SPL_SIZE_LIMIT_PROVIDE_STACK=0x3500 +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y +CONFIG_SPL_SIZE_LIMIT_SUBTRACT_MALLOC=y +CONFIG_SPL_MAX_SIZE=0x3B000 +CONFIG_SPL_PAD_TO=0x0 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x43c3b000 +CONFIG_SPL_BSS_MAX_SIZE=0x3000 +CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x140000 +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 +CONFIG_SPL_EARLY_BSS=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 +CONFIG_SPL_I2C=y +CONFIG_SPL_DM_MAILBOX=y +CONFIG_SPL_DM_RESET=y +CONFIG_SPL_POWER_DOMAIN=y +CONFIG_SPL_RAM_SUPPORT=y +CONFIG_SPL_RAM_DEVICE=y +CONFIG_SPL_REMOTEPROC=y +CONFIG_SPL_YMODEM_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_DFU=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_REMOTEPROC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_SPL_CLK_CCF=y +CONFIG_SPL_CLK_K3_PLL=y +CONFIG_SPL_CLK_K3=y +CONFIG_TI_SCI_PROTOCOL=y +CONFIG_DA8XX_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_OMAP24XX=y +CONFIG_DM_MAILBOX=y +CONFIG_K3_SEC_PROXY=y +CONFIG_SPL_MISC=y +CONFIG_ESM_K3=y +CONFIG_SPL_MMC_HS200_SUPPORT=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ADMA=y +CONFIG_SPL_MMC_SDHCI_ADMA=y +CONFIG_MMC_SDHCI_AM654=y +CONFIG_PINCTRL=y +# CONFIG_PINCTRL_GENERIC is not set +CONFIG_SPL_PINCTRL=y +# CONFIG_SPL_PINCTRL_GENERIC is not set +CONFIG_PINCTRL_SINGLE=y +CONFIG_POWER_DOMAIN=y +CONFIG_TI_POWER_DOMAIN=y +CONFIG_K3_SYSTEM_CONTROLLER=y +CONFIG_REMOTEPROC_TI_K3_ARM64=y +CONFIG_RESET_TI_SCI=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_DM_SERIAL=y +CONFIG_SOC_DEVICE=y +CONFIG_SOC_DEVICE_TI_K3=y +CONFIG_SOC_TI=y +CONFIG_TIMER=y +CONFIG_SPL_TIMER=y +CONFIG_OMAP_TIMER=y +CONFIG_LIB_RATIONAL=y +CONFIG_SPL_LIB_RATIONAL=y diff --git a/doc/board/toradex/verdin-am62.rst b/doc/board/toradex/verdin-am62.rst new file mode 100644 index 00000000000..2ece3757a41 --- /dev/null +++ b/doc/board/toradex/verdin-am62.rst @@ -0,0 +1,169 @@ +.. SPDX-License-Identifier: GPL-2.0-or-later +.. sectionauthor:: Marcel Ziswiler marcel.ziswiler@toradex.com + +Verdin AM62 Module +================== + +Quick Start +----------- + +- Get the binary-only SYSFW +- Get binary-only TI Linux firmware +- Build the ARM trusted firmware binary +- Build the OPTEE binary +- Build U-Boot for the R5 +- Build U-Boot for the A53 +- Flash to eMMC +- Boot + +For an overview of the TI AM62 SoC boot flow please head over to: +.. file:: ../ti/am62x_sk.rst + +Get the SYSFW +------------- + +.. code-block:: bash + + $ echo "Downloading SYSFW..." + $ git clone git://git.ti.com/k3-image-gen/k3-image-gen.git + +Get the TI Linux Firmware +------------- + +.. code-block:: bash + + $ echo "Downloading TI Linux Firmware..." + $ git clone -b ti-linux-firmware git://git.ti.com/processor-firmware/ti-linux-firmware.git + +Get and Build the ARM Trusted Firmware (Trusted Firmware A) +----------------------------------------------------------- + +.. code-block:: bash + + $ echo "Downloading and building TF-A..." + $ git clone https://github.com/ARM-software/arm-trusted-firmware.git + $ cd arm-trusted-firmware + +Then build ATF (TF-A): + +.. code-block:: bash + + $ export ARCH=aarch64 + $ export CROSS_COMPILE=aarch64-none-linux-gnu- + $ make PLAT=k3 TARGET_BOARD=lite SPD=opteed + +Get and Build OPTEE +------------------- + +.. code-block:: bash + + $ echo "Downloading and building OPTEE..." + $ git clone https://github.com/OP-TEE/optee_os.git + $ cd optee_os + +Then build OPTEE: + +.. code-block:: bash + + $ export CROSS_COMPILE=arm-none-linux-gnueabihf- + $ export CROSS_COMPILE64=aarch64-none-linux-gnu- + $ make PLATFORM=k3 CFG_ARM64_core=y + +Build U-Boot for R5 +------------------- + +.. code-block:: bash + + $ export ARCH=arm + $ export CROSS_COMPILE=arm-none-linux-gnueabihf- + $ make verdin-am62_r5_defconfig + $ make BINMAN_INDIRS=<path/to/ti-linux-firmware> + +Build U-Boot for A53 +-------------------- + +.. code-block:: bash + + $ export ARCH=arm64 + $ export CROSS_COMPILE=aarch64-none-linux-gnu- + $ make verdin-am62_a53_defconfig + $ make BL31=<path to ATF dir>/build/k3/lite/release/bl31.bin \ + TEE=<path to OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin \ + BINMAN_INDIRS=<path/to/ti-linux-firmware> + +Flash to eMMC +------------- + +.. code-block:: bash + + => mmc dev 0 1 + => fatload mmc 1 ${loadaddr} tiboot3.bin + => mmc write ${loadaddr} 0x0 0x400 + => fatload mmc 1 ${loadaddr} tispl.bin + => mmc write ${loadaddr} 0x400 0x1000 + => fatload mmc 1 ${loadaddr} u-boot.img + => mmc write ${loadaddr} 0x1400 0x2000 + +Boot +---- + +Output: + +.. code-block:: bash + +U-Boot SPL 2023.07-00559-g523f64a2a40 (Jul 26 2023 - 17:55:45 +0200) +SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.1--v09.00.01 (Kool Koala)') +SPL initial stack usage: 13368 bytes +Trying to boot from MMC1 +Authentication passed +Authentication passed +Authentication passed +Authentication passed +Authentication passed +Starting ATF on ARM64 core... + +NOTICE: BL31: v2.9(release):v2.9.0-73-g463655cc8 +NOTICE: BL31: Built : 14:51:42, Jun 5 2023 +I/TC: +I/TC: OP-TEE version: 3.21.0-168-g322cf9e33 (gcc version 12.2.1 20221205 (Arm GNU Toolchain 12.2.Rel1 (Build arm-12.24))) #2 Mon Jun 5 13:04:15 UTC 2023 aarch64 +I/TC: WARNING: This OP-TEE configuration might be insecure! +I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html +I/TC: Primary CPU initializing +I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.1--v09.00.01 (Kool Koala)') +I/TC: HUK Initialized +I/TC: Primary CPU switching to normal world boot + +U-Boot SPL 2023.07-00559-g523f64a2a40 (Jul 26 2023 - 17:56:56 +0200) +SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.1--v09.00.01 (Kool Koala)') +SPL initial stack usage: 1840 bytes +Trying to boot from MMC1 +Authentication passed +Authentication passed + + +U-Boot 2023.07-00559-g523f64a2a40 (Jul 26 2023 - 17:56:56 +0200) + +SoC: AM62X SR1.0 HS-FS +DRAM: 2 GiB +Core: 140 devices, 29 uclasses, devicetree: separate +MMC: mmc@fa10000: 0, mmc@fa00000: 1 +Loading Environment from MMC... OK +In: serial@2800000 +Out: serial@2800000 +Err: serial@2800000 +Model: Toradex 0076 Verdin AM62 Quad 2GB WB IT V1.0A +Serial#: 15037380 +Carrier: Toradex Verdin Development Board V1.1A, Serial# 10754333 +am65_cpsw_nuss ethernet@8000000: K3 CPSW: nuss_ver: 0x6BA01103 cpsw_ver: 0x6BA81103 ale_ver: 0x00290105 Ports:2 mdio_freq:1000000 +Setting variant to wifi +Net: +Warning: ethernet@8000000port@1 MAC addresses don't match: +Address in ROM is 1c:63:49:07:f5:13 +Address in environment is 00:14:2d:e5:73:c4 +eth0: ethernet@8000000port@1 [PRIME] +Warning: ethernet@8000000port@2 MAC addresses don't match: +Address in ROM is 1c:63:49:07:f5:13 +Address in environment is 00:14:2d:f5:73:c4 +, eth1: ethernet@8000000port@2 +Hit any key to stop autoboot: 0 +Verdin AM62 # diff --git a/include/configs/verdin-am62.h b/include/configs/verdin-am62.h new file mode 100644 index 00000000000..e0c35dfa061 --- /dev/null +++ b/include/configs/verdin-am62.h @@ -0,0 +1,55 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * Configuration header file for Verdin AM62 SoM + * + * Copyright 2023 Toradex - https://www.toradex.com/ + */ + +#ifndef __VERDIN_AM62_H +#define __VERDIN_AM62_H + +#define RAMDISK_ADDR_R 0x90300000 +#define SCRIPTADDR 0x90280000 + +/* DDR Configuration */ +#define CFG_SYS_SDRAM_BASE 0x80000000 +#define CFG_SYS_SDRAM_BASE1 0x880000000 +#define CFG_SYS_SDRAM_SIZE SZ_2G /* Maximum supported size */ + +#define MEM_LAYOUT_ENV_SETTINGS \ + "fdt_addr_r=0x90200000\0" \ + "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "kernel_comp_addr_r=0x80200000\0" \ + "kernel_comp_size=0x08000000\0" \ + "ramdisk_addr_r=" __stringify(RAMDISK_ADDR_R) "\0" \ + "scriptaddr=" __stringify(SCRIPTADDR) "\0" + +#if CONFIG_TARGET_VERDIN_AM62_A53 +/* Enable Distro Boot */ +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 1) \ + func(MMC, mmc, 0) \ + func(DHCP, dhcp, na) +#include <config_distro_bootcmd.h> +#else /* CONFIG_TARGET_VERDIN_AM62_A53 */ +#define BOOTENV \ + "" +#endif /* CONFIG_TARGET_VERDIN_AM62_A53 */ + +/* Incorporate settings into the U-Boot environment */ +#define CFG_EXTRA_ENV_SETTINGS \ + BOOTENV \ + MEM_LAYOUT_ENV_SETTINGS \ + "boot_scripts=boot.scr\0" \ + "boot_script_dhcp=boot.scr\0" \ + "console=ttyS2\0" \ + "fdt_board=dev\0" \ + "setup=setenv setupargs console=tty1 console=${console},${baudrate} " \ + "consoleblank=0 earlycon=ns16550a,mmio32,0x02800000\0" \ + "update_uboot=askenv confirm Did you load flash.bin (y/N)?; " \ + "if test "$confirm" = "y"; then " \ + "setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt " \ + "${blkcnt} / 0x200; mmc dev 0 1; mmc write ${loadaddr} 0x0 " \ + "${blkcnt}; fi\0" + +#endif /* __VERDIN_AM62_H */
On 22:54-20230728, Marcel Ziswiler wrote:
This adds initial support for the Toradex Verdin AM62 Quad 1GB WB IT V1.0A module and subsequent V1.1 launch configuration SKUs. They are strapped to boot from their on-module eMMC. U-Boot supports booting from the on-module eMMC only, DFU support is disabled for now due to missing AM62x USB support.
Boot sequence is: SYSFW ---> R5 SPL (both in tiboot3.bin) ---> ATF (TF-A) ---> OP-TEE ---> A53 SPL (part of tispl.bin) ---> U-boot proper (u-boot.img)
Please state the dts is from v6.5-rc1 - this is to ensure we can track over time the updates needed - typically we want to get to a place where we can update in one shot to stay in sync.
just a side note: we might want to see how to get those eeproms merged in for kernel (we'd really like to get rid of u-boot.dtsi)
Also drop #include "k3-am625-verdin-wifi-dev-binman.dtsi" from r5.dts (you already get it from u-boot.dtsi)
you also dont need the memory@, reserved-memory sa_secproxy, esm etc in r5.dts - please see am62-r5-sk.dts to see how it is done. all of these are now inherited from SoC.dtsi or board.dts.. (yaay - your r5.dts is going to be much tinier once you clean that up)..
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Marcel, copying the files from v6.5-rc1, I see the following deltas
we try to migrate the dts files as is.. so trying to understand the #if 0 here. Just disabling the driver in defconfig should get the feature out, correct?
I suspect some debuggy stuff creeped in perhaps?
diff --git a/arch/arm/dts/k3-am62-verdin-dev.dtsi b/arch/arm/dts/k3-am62-verdin-dev.dtsi index e5443cd3c2d3..846caee7dfa4 100644 --- a/arch/arm/dts/k3-am62-verdin-dev.dtsi +++ b/arch/arm/dts/k3-am62-verdin-dev.dtsi @@ -160,7 +160,6 @@ status = "okay"; };
-#if 0 /* Verdin USB_1 */ &usbss0 { status = "okay"; @@ -178,7 +177,6 @@ &usb1 { status = "okay"; }; -#endif
/* Verdin CTRL_WAKE1_MICO# */ &verdin_gpio_keys { diff --git a/arch/arm/dts/k3-am62-verdin.dtsi b/arch/arm/dts/k3-am62-verdin.dtsi index 9f626c869725..57dd061911ab 100644 --- a/arch/arm/dts/k3-am62-verdin.dtsi +++ b/arch/arm/dts/k3-am62-verdin.dtsi @@ -36,10 +36,8 @@ serial2 = &main_uart0; serial3 = &mcu_uart0; serial4 = &main_uart5; -#if 0 usb0 = &usb0; usb1 = &usb1; -#endif };
verdin_gpio_keys: gpio-keys { @@ -1369,7 +1367,6 @@ status = "disabled"; };
-#if 0 /* Verdin USB_1 */ &usbss0 { ti,vbus-divider; @@ -1395,7 +1392,6 @@ dr_mode = "host"; status = "disabled"; }; -#endif
/* Verdin UART_2 */ &wkup_uart0 {
Hi Nishanth
I did, but only in the change log. Let me add it to the commit message as well.
Yes, one may dream...
Okay.
I guess I missed that recent change. Thanks!
No, USB support is not there yet and this used to fail. I actually still do have a series on top adding USB support and dropped those there, but yeah, now with the synced stuff I may drop those here already. Thanks!
diff --git a/arch/arm/dts/k3-am62-verdin-dev.dtsi b/arch/arm/dts/k3-am62-verdin-dev.dtsi index e5443cd3c2d3..846caee7dfa4 100644 --- a/arch/arm/dts/k3-am62-verdin-dev.dtsi +++ b/arch/arm/dts/k3-am62-verdin-dev.dtsi @@ -160,7 +160,6 @@ status = "okay"; }; -#if 0 /* Verdin USB_1 */ &usbss0 { status = "okay"; @@ -178,7 +177,6 @@ &usb1 { status = "okay"; }; -#endif /* Verdin CTRL_WAKE1_MICO# */ &verdin_gpio_keys { diff --git a/arch/arm/dts/k3-am62-verdin.dtsi b/arch/arm/dts/k3-am62-verdin.dtsi index 9f626c869725..57dd061911ab 100644 --- a/arch/arm/dts/k3-am62-verdin.dtsi +++ b/arch/arm/dts/k3-am62-verdin.dtsi @@ -36,10 +36,8 @@ serial2 = &main_uart0; serial3 = &mcu_uart0; serial4 = &main_uart5; -#if 0 usb0 = &usb0; usb1 = &usb1; -#endif }; verdin_gpio_keys: gpio-keys { @@ -1369,7 +1367,6 @@ status = "disabled"; }; -#if 0 /* Verdin USB_1 */ &usbss0 { ti,vbus-divider; @@ -1395,7 +1392,6 @@ dr_mode = "host"; status = "disabled"; }; -#endif /* Verdin UART_2 */ &wkup_uart0 {
Cheers
Marcel
- $ echo "Downloading SYSFW..."
- $ git clone git://git.ti.com/k3-image-gen/k3-image-gen.git
we dont need k3-image-gen anymore..
Umm.. https://u-boot.readthedocs.io/en/latest/build/documentation.html?highlight=h... make htmldocs: u-boot/doc/board/toradex/verdin-am62.rst:31:Title underline too short.
If you like, please consider the following diff to your changes - as I had setup am62x doc to be a bit re-usable to help keep things sane and central:
diff --git a/doc/board/ti/am62x_sk.rst b/doc/board/ti/am62x_sk.rst index 637985cb096e..4646bc0f5257 100644 --- a/doc/board/ti/am62x_sk.rst +++ b/doc/board/ti/am62x_sk.rst @@ -54,7 +54,7 @@ Below is the pictorial representation of boot flow: Sources: --------
-.. include:: k3.rst +.. include:: ../ti/k3.rst :start-after: .. k3_rst_include_start_boot_sources :end-before: .. k3_rst_include_end_boot_sources
@@ -62,17 +62,17 @@ Build procedure: ---------------- 0. Setup the environment variables:
-.. include:: k3.rst +.. include:: ../ti/k3.rst :start-after: .. k3_rst_include_start_common_env_vars_desc :end-before: .. k3_rst_include_end_common_env_vars_desc
-.. include:: k3.rst +.. include:: ../ti/k3.rst :start-after: .. k3_rst_include_start_board_env_vars_desc :end-before: .. k3_rst_include_end_board_env_vars_desc
Set the variables corresponding to this platform:
-.. include:: k3.rst +.. include:: ../ti/k3.rst :start-after: .. k3_rst_include_start_common_env_vars_defn :end-before: .. k3_rst_include_end_common_env_vars_defn .. code-block:: bash @@ -89,14 +89,14 @@ Set the variables corresponding to this platform:
1. Trusted Firmware-A:
-.. include:: k3.rst +.. include:: ../ti/k3.rst :start-after: .. k3_rst_include_start_build_steps_tfa :end-before: .. k3_rst_include_end_build_steps_tfa
2. OP-TEE:
-.. include:: k3.rst +.. include:: ../ti/k3.rst :start-after: .. k3_rst_include_start_build_steps_optee :end-before: .. k3_rst_include_end_build_steps_optee
@@ -104,13 +104,13 @@ Set the variables corresponding to this platform:
* 4.1 R5:
-.. include:: k3.rst +.. include:: ../ti/k3.rst :start-after: .. k3_rst_include_start_build_steps_spl_r5 :end-before: .. k3_rst_include_end_build_steps_spl_r5
* 4.2 A53:
-.. include:: k3.rst +.. include:: ../ti/k3.rst :start-after: .. k3_rst_include_start_build_steps_uboot :end-before: .. k3_rst_include_end_build_steps_uboot .. am62x_evm_rst_include_end_build_steps diff --git a/doc/board/ti/k3.rst b/doc/board/ti/k3.rst index 74fdc6b41c9b..02cfd9316883 100644 --- a/doc/board/ti/k3.rst +++ b/doc/board/ti/k3.rst @@ -31,6 +31,7 @@ K3 Based SoCs :maxdepth: 1
am62x_sk + ../toradex/verdin-am62 am64x_evm am65x_evm j7200_evm diff --git a/doc/board/toradex/index.rst b/doc/board/toradex/index.rst index ead5efbb9551..7728b9db6629 100644 --- a/doc/board/toradex/index.rst +++ b/doc/board/toradex/index.rst @@ -11,3 +11,4 @@ Toradex colibri-imx8x verdin-imx8mm verdin-imx8mp + verdin-am62 diff --git a/doc/board/toradex/verdin-am62.rst b/doc/board/toradex/verdin-am62.rst index 2ece3757a410..f5ff6638df35 100644 --- a/doc/board/toradex/verdin-am62.rst +++ b/doc/board/toradex/verdin-am62.rst @@ -17,79 +17,44 @@ Quick Start - Boot
For an overview of the TI AM62 SoC boot flow please head over to: -.. file:: ../ti/am62x_sk.rst +:doc:`../ti/am62x_sk`
-Get the SYSFW -------------- - -.. code-block:: bash - - $ echo "Downloading SYSFW..." - $ git clone git://git.ti.com/k3-image-gen/k3-image-gen.git - -Get the TI Linux Firmware -------------- - -.. code-block:: bash - - $ echo "Downloading TI Linux Firmware..." - $ git clone -b ti-linux-firmware git://git.ti.com/processor-firmware/ti-linux-firmware.git - -Get and Build the ARM Trusted Firmware (Trusted Firmware A) ------------------------------------------------------------ - -.. code-block:: bash - - $ echo "Downloading and building TF-A..." - $ git clone https://github.com/ARM-software/arm-trusted-firmware.git - $ cd arm-trusted-firmware +Sources: +-------- +.. include:: ../ti/k3.rst + :start-after: .. k3_rst_include_start_boot_sources + :end-before: .. k3_rst_include_end_boot_sources
-Then build ATF (TF-A): +Build procedure: +---------------- +0. Setup the environment variables:
-.. code-block:: bash - - $ export ARCH=aarch64 - $ export CROSS_COMPILE=aarch64-none-linux-gnu- - $ make PLAT=k3 TARGET_BOARD=lite SPD=opteed - -Get and Build OPTEE -------------------- - -.. code-block:: bash - - $ echo "Downloading and building OPTEE..." - $ git clone https://github.com/OP-TEE/optee_os.git - $ cd optee_os - -Then build OPTEE: - -.. code-block:: bash - - $ export CROSS_COMPILE=arm-none-linux-gnueabihf- - $ export CROSS_COMPILE64=aarch64-none-linux-gnu- - $ make PLATFORM=k3 CFG_ARM64_core=y - -Build U-Boot for R5 -------------------- - -.. code-block:: bash +.. include:: ../ti/k3.rst + :start-after: .. k3_rst_include_start_common_env_vars_desc + :end-before: .. k3_rst_include_end_common_env_vars_desc
- $ export ARCH=arm - $ export CROSS_COMPILE=arm-none-linux-gnueabihf- - $ make verdin-am62_r5_defconfig - $ make BINMAN_INDIRS=<path/to/ti-linux-firmware> +.. include:: ../ti/k3.rst + :start-after: .. k3_rst_include_start_board_env_vars_desc + :end-before: .. k3_rst_include_end_board_env_vars_desc
-Build U-Boot for A53 --------------------- +Set the variables corresponding to this platform:
+.. include:: ../ti/k3.rst + :start-after: .. k3_rst_include_start_common_env_vars_defn + :end-before: .. k3_rst_include_end_common_env_vars_defn .. code-block:: bash
- $ export ARCH=arm64 - $ export CROSS_COMPILE=aarch64-none-linux-gnu- - $ make verdin-am62_a53_defconfig - $ make BL31=<path to ATF dir>/build/k3/lite/release/bl31.bin \ - TEE=<path to OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin \ - BINMAN_INDIRS=<path/to/ti-linux-firmware> + $ export UBOOT_CFG_CORTEXR=verdin-am62_r5_defconfig + $ export UBOOT_CFG_CORTEXA=verdin-am62_a53_defconfig + $ export TFA_BOARD=lite + $ # we dont use any extra TFA parameters + $ unset TFA_EXTRA_ARGS + $ export OPTEE_PLATFORM=k3-am62x + $ export OPTEE_EXTRA_ARGS="CFG_WITH_SOFTWARE_PRNG=y" + +.. include:: ../ti/am62x_sk.rst + :start-after: .. am62x_evm_rst_include_start_build_steps + :end-before: .. am62x_evm_rst_include_end_build_steps
Flash to eMMC -------------
Hi Nishanth
Yes, true.
Yes, Emanuele already spotted that trying to run Azure CI earlier today.
Cool, thanks. I applied this, run Azure CI on it [1] and sent a v5 [2].
Thanks again!
diff --git a/doc/board/ti/am62x_sk.rst b/doc/board/ti/am62x_sk.rst index 637985cb096e..4646bc0f5257 100644 --- a/doc/board/ti/am62x_sk.rst +++ b/doc/board/ti/am62x_sk.rst @@ -54,7 +54,7 @@ Below is the pictorial representation of boot flow: Sources: -------- -.. include:: k3.rst +.. include:: ../ti/k3.rst :start-after: .. k3_rst_include_start_boot_sources :end-before: .. k3_rst_include_end_boot_sources @@ -62,17 +62,17 @@ Build procedure: ---------------- 0. Setup the environment variables: -.. include:: k3.rst +.. include:: ../ti/k3.rst :start-after: .. k3_rst_include_start_common_env_vars_desc :end-before: .. k3_rst_include_end_common_env_vars_desc -.. include:: k3.rst +.. include:: ../ti/k3.rst :start-after: .. k3_rst_include_start_board_env_vars_desc :end-before: .. k3_rst_include_end_board_env_vars_desc Set the variables corresponding to this platform: -.. include:: k3.rst +.. include:: ../ti/k3.rst :start-after: .. k3_rst_include_start_common_env_vars_defn :end-before: .. k3_rst_include_end_common_env_vars_defn .. code-block:: bash @@ -89,14 +89,14 @@ Set the variables corresponding to this platform: 1. Trusted Firmware-A: -.. include:: k3.rst +.. include:: ../ti/k3.rst :start-after: .. k3_rst_include_start_build_steps_tfa :end-before: .. k3_rst_include_end_build_steps_tfa 2. OP-TEE: -.. include:: k3.rst +.. include:: ../ti/k3.rst :start-after: .. k3_rst_include_start_build_steps_optee :end-before: .. k3_rst_include_end_build_steps_optee @@ -104,13 +104,13 @@ Set the variables corresponding to this platform: * 4.1 R5: -.. include:: k3.rst +.. include:: ../ti/k3.rst :start-after: .. k3_rst_include_start_build_steps_spl_r5 :end-before: .. k3_rst_include_end_build_steps_spl_r5 * 4.2 A53: -.. include:: k3.rst +.. include:: ../ti/k3.rst :start-after: .. k3_rst_include_start_build_steps_uboot :end-before: .. k3_rst_include_end_build_steps_uboot .. am62x_evm_rst_include_end_build_steps diff --git a/doc/board/ti/k3.rst b/doc/board/ti/k3.rst index 74fdc6b41c9b..02cfd9316883 100644 --- a/doc/board/ti/k3.rst +++ b/doc/board/ti/k3.rst @@ -31,6 +31,7 @@ K3 Based SoCs :maxdepth: 1 am62x_sk + ../toradex/verdin-am62 am64x_evm am65x_evm j7200_evm diff --git a/doc/board/toradex/index.rst b/doc/board/toradex/index.rst index ead5efbb9551..7728b9db6629 100644 --- a/doc/board/toradex/index.rst +++ b/doc/board/toradex/index.rst @@ -11,3 +11,4 @@ Toradex colibri-imx8x verdin-imx8mm verdin-imx8mp + verdin-am62 diff --git a/doc/board/toradex/verdin-am62.rst b/doc/board/toradex/verdin-am62.rst index 2ece3757a410..f5ff6638df35 100644 --- a/doc/board/toradex/verdin-am62.rst +++ b/doc/board/toradex/verdin-am62.rst @@ -17,79 +17,44 @@ Quick Start - Boot For an overview of the TI AM62 SoC boot flow please head over to: -.. file:: ../ti/am62x_sk.rst +:doc:`../ti/am62x_sk`
-Get the SYSFW
- $ echo "Downloading and building TF-A..." - $ git clone https://github.com/ARM-software/arm-trusted-firmware.git - $ cd arm-trusted-firmware +Sources: +-------- +.. include:: ../ti/k3.rst + :start-after: .. k3_rst_include_start_boot_sources + :end-before: .. k3_rst_include_end_boot_sources -Then build ATF (TF-A): +Build procedure: +---------------- +0. Setup the environment variables: -.. code-block:: bash
-Then build OPTEE:
-.. code-block:: bash +.. include:: ../ti/k3.rst + :start-after: .. k3_rst_include_start_common_env_vars_desc + :end-before: .. k3_rst_include_end_common_env_vars_desc - $ export ARCH=arm - $ export CROSS_COMPILE=arm-none-linux-gnueabihf- - $ make verdin-am62_r5_defconfig - $ make BINMAN_INDIRS=<path/to/ti-linux-firmware> +.. include:: ../ti/k3.rst + :start-after: .. k3_rst_include_start_board_env_vars_desc + :end-before: .. k3_rst_include_end_board_env_vars_desc
+Set the variables corresponding to this platform: +.. include:: ../ti/k3.rst + :start-after: .. k3_rst_include_start_common_env_vars_defn + :end-before: .. k3_rst_include_end_common_env_vars_defn .. code-block:: bash - $ export ARCH=arm64 - $ export CROSS_COMPILE=aarch64-none-linux-gnu- - $ make verdin-am62_a53_defconfig - $ make BL31=<path to ATF dir>/build/k3/lite/release/bl31.bin \ - TEE=<path to OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin \ - BINMAN_INDIRS=<path/to/ti-linux-firmware>
- $ export UBOOT_CFG_CORTEXR=verdin-am62_r5_defconfig
- $ export UBOOT_CFG_CORTEXA=verdin-am62_a53_defconfig
- $ export TFA_BOARD=lite
- $ # we dont use any extra TFA parameters
- $ unset TFA_EXTRA_ARGS
- $ export OPTEE_PLATFORM=k3-am62x
- $ export OPTEE_EXTRA_ARGS="CFG_WITH_SOFTWARE_PRNG=y"
+.. include:: ../ti/am62x_sk.rst + :start-after: .. am62x_evm_rst_include_start_build_steps + :end-before: .. am62x_evm_rst_include_end_build_steps Flash to eMMC -------------
[1] https://dev.azure.com/u-boot/u-boot/_build/results?buildId=6792&view=res... [2] https://lore.kernel.org/all/20230803140016.52846-1-marcel@ziswiler.com
Cheers
Marcel
Hi Marcel
- mbox-names = "rx", "tx", "notify";
- ti,host-id = <35>;
- ti,secure-host;
+}; diff --git a/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi b/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi new file mode 100644 index 00000000000..e8c926f48b9 --- /dev/null +++ b/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi @@ -0,0 +1,570 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/*
- Copyright 2023 Toradex
+#include "k3-binman.dtsi"
+&binman {
- custMpk {
filename = "custMpk.pem";
blob-ext {
filename = "../../ti/keys/custMpk.pem";
- ti-degenerate-key {
filename = "ti-degenerate-key.pem";
blob-ext {
filename = "../../ti/keys/ti-degenerate-key.pem";
+#ifndef CONFIG_ARM64
+&binman {
- board-cfg {
filename = "board-cfg.bin";
bcfg_yaml: ti-board-config {
config = "board-cfg.yaml";
schema = "../../ti/common/schema.yaml";
- pm-cfg {
filename = "pm-cfg.bin";
rcfg_yaml: ti-board-config {
config = "pm-cfg.yaml";
- rm-cfg {
filename = "rm-cfg.bin";
pcfg_yaml: ti-board-config {
config = "rm-cfg.yaml";
- sec-cfg {
filename = "sec-cfg.bin";
scfg_yaml: ti-board-config {
config = "sec-cfg.yaml";
- combined-tifs-cfg {
filename = "combined-tifs-cfg.bin";
ti-board-config {
bcfg_yaml_tifs: board-cfg {
scfg_yaml_tifs: sec-cfg {
pcfg_yaml_tifs: pm-cfg {
rcfg_yaml_tifs: rm-cfg {
- combined-dm-cfg {
filename = "combined-dm-cfg.bin";
ti-board-config {
pcfg_yaml_dm: pm-cfg {
rcfg_yaml_dm: rm-cfg {
- combined-sysfw-cfg {
filename = "combined-sysfw-cfg.bin";
ti-board-config {
board-cfg {
sec-cfg {
pm-cfg {
rm-cfg {
^ If you are already including k3-binman.dtsi, why are you redefining these?
+#endif /* CONFIG_ARM64 */
+#ifdef CONFIG_TARGET_VERDIN_AM62_R5
+&binman {
- tiboot3-am62x-hs-verdin.bin {
filename = "tiboot3-am62x-hs-verdin.bin";
ti-secure-rom {
content = <&u_boot_spl>, <&ti_fs_enc>, <&combined_tifs_cfg>,
<&combined_dm_cfg>, <&sysfw_inner_cert>;
combined;
dm-data;
sysfw-inner-cert;
keyfile = "custMpk.pem";
sw-rev = <1>;
content-sbl = <&u_boot_spl>;
content-sysfw = <&ti_fs_enc>;
content-sysfw-data = <&combined_tifs_cfg>;
content-sysfw-inner-cert = <&sysfw_inner_cert>;
content-dm-data = <&combined_dm_cfg>;
If the R5 builds are exactly the same as that generated by k3-am625-binman.dtsi, would it make sense to include that file and just replace the filenames using phandles?
conf-0 {
description = "k3-am625-verdin-wifi-dev";
firmware = "uboot";
loadables = "uboot";
fdt = "fdt-0";
+#endif /* CONFIG_TARGET_VERDIN_AM62_A53 */ diff --git a/arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi b/arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi new file mode 100644 index 00000000000..5d564603eb2 --- /dev/null +++ b/arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi @@ -0,0 +1,201 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/*
Nitpick: indentation
- "fdt_addr_r=0x90200000\0" \
- "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \
- "kernel_comp_addr_r=0x80200000\0" \
- "kernel_comp_size=0x08000000\0" \
- "ramdisk_addr_r=" __stringify(RAMDISK_ADDR_R) "\0" \
- "scriptaddr=" __stringify(SCRIPTADDR) "\0"
- func(MMC, mmc, 1) \
- func(MMC, mmc, 0) \
- func(DHCP, dhcp, na)
- BOOTENV \
- MEM_LAYOUT_ENV_SETTINGS \
- "boot_scripts=boot.scr\0" \
- "boot_script_dhcp=boot.scr\0" \
- "console=ttyS2\0" \
- "fdt_board=dev\0" \
- "setup=setenv setupargs console=tty1 console=${console},${baudrate} " \
- "update_uboot=askenv confirm Did you load flash.bin (y/N)?; " \
"if test \"$confirm\" = \"y\"; then " \
"${blkcnt}; fi\0"
I'm not responsible for k3, so do not send me these emails.
On Friday 28 July 2023 22:54:53 Marcel Ziswiler wrote:
This series adds initial support for the Toradex Verdin AM62 SoM [1]. The first commit adds resp. PID4s to the ConfigBlock, the second one fixes an early clocking issue confirmed to be a weird bug in TI's scripting. And last but not least support for the Toradex Verdin AM62 is added.
[1] https://www.toradex.com/computer-on-modules/verdin-arm-family/ti-am62
Changes in v4:
- Re-based on top of master with recent binman integration, mac_efuse, cpsw-phy-sel and mdio clean-up and dtsi bump from linux v6.5-rc1.
- Verdin AM62 binman enablement and further clean-up after re-base.
- Removed all ifdefs from DTs now with bumped Linux dtsi.
- Avoid relocated U-Boot and DT reserved-memory clash.
- Enable of_system_setup.
Changes in v3:
- Add Verdin AM62 launch configuration SKUs as well.
- Integrate our recent find of CTRL_SLEEP_MOCI# needing to be driven from A53 SPL as it may be used to control some power-rails on the carrier board. E.g. on the Yavia carrier board it is needed to power the I2C EEPROM on the carrier board.
- Improve boot environment in R5 SPL vs. A53.
- Integrate launch configuration SKUs to Wi-Fi handling.
- Re-sync device trees from Linux kernel v6.5-rc1.
- Add warning if memory is less than expected.
Changes in v2:
- Add Bryan's reviewed-by tag. Thanks!
- Use 1.2 GHz rather than 1.25 GHz A53 clock as on the EVM/SK.
- Also add power-domain 166 as on the EVM/SK.
- Get rid of main_bcdma and main_pktdma as not required in R5 SPL.
- Get rid of all bootph-pre-ram in Ethernet and SDHC1 aka SD card related pinctrls as not required in any SPL.
- Enable CONFIG_TI_SECURE_DEVICE by default as Non-HS devices will continue to boot due to runtime device type detection.
- Disable FAT and SPI support as not required in R5 SPL.
- Also enable CONFIG_SPL_MMC_HS200_SUPPORT in R5 SPL.
- Enable CONFIG_LEGACY_IMAGE_FORMAT to allow sourcing unsigned script images e.g. like our current boot scripts.
- Increase CONFIG_SYS_BOOTM_LEN to 64 MB to allow booting bigger compressed images as e.g. in the Toradex Easy Installer case.
- Change memory configurations to operate at temperatures of up to 95 degrees celsius.
- Increase CONFIG_SYS_MAXARGS from default 16 to 64.
- Enable CONFIG_CMD_REMOTEPROC, CONFIG_SPL_DM_GPIO_LOOKUP_LABEL and CONFIG_SPL_I2C_EEPROM.
- For R5 SPL increase CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN to 0x140000, enable CONFIG_SPL_I2C, CONFIG_DM_I2C and CONFIG_SYS_I2C_OMAP24XX and savedefconfig got rid of CONFIG_SPL_FIT_IMAGE_POST_PROCESS.
Marcel Ziswiler (3): toradex: tdx-cfg-block: add verdin am62 skus arm: mach-k3: am62: fix 2nd mux option of clkout0 board: toradex: add verdin am62 support
arch/arm/dts/Makefile | 4 +- arch/arm/dts/k3-am62-verdin-dev.dtsi | 192 ++ arch/arm/dts/k3-am62-verdin-wifi.dtsi | 39 + arch/arm/dts/k3-am62-verdin.dtsi | 1405 +++++++++++ .../dts/k3-am625-verdin-lpddr4-1600MTs.dtsi | 2190 +++++++++++++++++ arch/arm/dts/k3-am625-verdin-r5.dts | 116 + .../dts/k3-am625-verdin-wifi-dev-binman.dtsi | 570 +++++ .../dts/k3-am625-verdin-wifi-dev-u-boot.dtsi | 201 ++ arch/arm/dts/k3-am625-verdin-wifi-dev.dts | 22 + arch/arm/mach-k3/Kconfig | 1 + arch/arm/mach-k3/am62x/clk-data.c | 5 +- board/toradex/common/tdx-cfg-block.c | 7 + board/toradex/common/tdx-cfg-block.h | 10 +- board/toradex/verdin-am62/Kconfig | 82 + board/toradex/verdin-am62/MAINTAINERS | 17 + board/toradex/verdin-am62/Makefile | 6 + board/toradex/verdin-am62/board-cfg.yaml | 36 + board/toradex/verdin-am62/pm-cfg.yaml | 12 + board/toradex/verdin-am62/rm-cfg.yaml | 1088 ++++++++ board/toradex/verdin-am62/sec-cfg.yaml | 379 +++ board/toradex/verdin-am62/verdin-am62.c | 131 + configs/verdin-am62_a53_defconfig | 187 ++ configs/verdin-am62_r5_defconfig | 111 + doc/board/toradex/verdin-am62.rst | 169 ++ include/configs/verdin-am62.h | 55 + 25 files changed, 7030 insertions(+), 5 deletions(-) create mode 100644 arch/arm/dts/k3-am62-verdin-dev.dtsi create mode 100644 arch/arm/dts/k3-am62-verdin-wifi.dtsi create mode 100644 arch/arm/dts/k3-am62-verdin.dtsi create mode 100644 arch/arm/dts/k3-am625-verdin-lpddr4-1600MTs.dtsi create mode 100644 arch/arm/dts/k3-am625-verdin-r5.dts create mode 100644 arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi create mode 100644 arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi create mode 100644 arch/arm/dts/k3-am625-verdin-wifi-dev.dts create mode 100644 board/toradex/verdin-am62/Kconfig create mode 100644 board/toradex/verdin-am62/MAINTAINERS create mode 100644 board/toradex/verdin-am62/Makefile create mode 100644 board/toradex/verdin-am62/board-cfg.yaml create mode 100644 board/toradex/verdin-am62/pm-cfg.yaml create mode 100644 board/toradex/verdin-am62/rm-cfg.yaml create mode 100644 board/toradex/verdin-am62/sec-cfg.yaml create mode 100644 board/toradex/verdin-am62/verdin-am62.c create mode 100644 configs/verdin-am62_a53_defconfig create mode 100644 configs/verdin-am62_r5_defconfig create mode 100644 doc/board/toradex/verdin-am62.rst create mode 100644 include/configs/verdin-am62.h
-- 2.36.1
Sorry about that. Looks like patman somehow choose you. I will add a rule to no longer do that. Thanks!
Changes in v4:
Changes in v3:
Changes in v2:
-- 2.36.1
participants (5)
Marcel Ziswiler
Marcel Ziswiler
Neha Malcom Francis
Nishanth Menon
Pali Rohár
