[PATCH] pico-imx7d: Remove board_phy_config()
With Ethernet DM in place, there is no longer the need for having the board_phy_config() anymore.
Remove it.
Tested on imx7d-pico-pi board:
=> setenv autoload no => dhcp BOOTP broadcast 1 *** Unhandled DHCP Option in OFFER/ACK: 42 DHCP client bound to address 192.168.0.138 (138 ms) => tftp zImage Using ethernet@30be0000 device TFTP from server 192.168.0.16; our IP address is 192.168.0.138 Filename 'zImage'. Load address: 0x80800000 Loading: ################################################################# .... ################################################################# ########## 4.3 MiB/s done Bytes transferred = 9034120 (89d988 hex)
Signed-off-by: Fabio Estevam festevam@denx.de --- board/technexion/pico-imx7d/pico-imx7d.c | 26 ------------------------ 1 file changed, 26 deletions(-)
diff --git a/board/technexion/pico-imx7d/pico-imx7d.c b/board/technexion/pico-imx7d/pico-imx7d.c index 6e98b85b2873..5def6eda43e5 100644 --- a/board/technexion/pico-imx7d/pico-imx7d.c +++ b/board/technexion/pico-imx7d/pico-imx7d.c @@ -101,32 +101,6 @@ static int setup_fec(void)
return set_clk_enet(ENET_125MHZ); } - -int board_phy_config(struct phy_device *phydev) -{ - unsigned short val; - - /* To enable AR8035 ouput a 125MHz clk from CLK_25M */ - phy_write(phydev, MDIO_DEVAD_NONE, 0xd, 0x7); - phy_write(phydev, MDIO_DEVAD_NONE, 0xe, 0x8016); - phy_write(phydev, MDIO_DEVAD_NONE, 0xd, 0x4007); - - val = phy_read(phydev, MDIO_DEVAD_NONE, 0xe); - val &= 0xffe7; - val |= 0x18; - phy_write(phydev, MDIO_DEVAD_NONE, 0xe, val); - - /* introduce tx clock delay */ - phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x5); - val = phy_read(phydev, MDIO_DEVAD_NONE, 0x1e); - val |= 0x0100; - phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, val); - - if (phydev->drv->config) - phydev->drv->config(phydev); - - return 0; -} #endif
static void setup_iomux_uart(void)
Remove it.
Applied to u-boot-imx next, thanks.
Fabio Estevam
