[U-Boot] [PATCH 1/1] armv7: start.S: Fix relocation address caculation
There will have issue if the _start not equal TEXT_BASE when enable relocation. The reason is as the followings,
The _dynsym_start_ofs and _rel_dyn_start_ofs is the offset from _start, so, need use _start address instead of _TEXT_BASE to caculate the rel dyn start and sym table address. This patch also correct the board_init_r function address caculation in relocation area. The addr of board_init_r after relocation is: _board_init_r_offs + relocation start address.
This patch also make code cleanup by removing some useless code
Signed-off-by: Jason Liu r64343@freescale.com --- arch/arm/cpu/armv7/start.S | 8 ++------ 1 files changed, 2 insertions(+), 6 deletions(-)
diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 684f2d2..08902b0 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -171,7 +171,6 @@ stack_setup: beq clear_bss /* skip relocation */ #endif mov r1, r6 /* r1 <- scratch for copy_loop */ - ldr r2, _TEXT_BASE ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */
@@ -185,7 +184,7 @@ copy_loop: /* * fix .rel.dyn relocations */ - ldr r0, _TEXT_BASE /* r0 <- Text base */ + adr r0, _start sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ @@ -224,7 +223,6 @@ fixnext: clear_bss: ldr r0, _bss_start_ofs ldr r1, _bss_end_ofs - ldr r3, _TEXT_BASE /* Text base */ mov r4, r6 /* reloc addr */ add r0, r0, r4 add r1, r1, r4 @@ -242,9 +240,7 @@ clbss_l:str r2, [r0] /* clear loop... */ */ jump_2_ram: ldr r0, _board_init_r_ofs - adr r1, _start - add lr, r0, r1 - add lr, lr, r9 + add lr, r0, r4 /* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ mov r1, r6 /* dest_addr */
Hi Jason,
In what case does this happen?
Amicalement,
Hi, Albert,
2010/12/16 Albert ARIBAUD albert.aribaud@free.fr:
Hi Jason,
Some ARM SOC ROM need run the plug-in code first in IRAM and the plugin-in code need appear at the beginning of the u-boot. ROM will check the plugin-in header to do security check and run the plug-in code to init the DDR etc. In this case the _start will be not the same as TEXT_BASE.
Thanks for your comments. Cheers,
Amicalement,
Albert. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Le 16/12/2010 04:04, Jason Liu a écrit :
Hi, Albert,
2010/12/16 Albert ARIBAUDalbert.aribaud@free.fr:
Hi Jason,
I still don't see why u-boot would not end up where specified.
The fact that there is a "plug-in" (I assume it's what I would call an IPL) does not change the fact that its payload (u-boot) can and will be loaded where specified, i.e. at TEXT_BASE -- and if it is loaded elsewhere, it is at a fixed address, so TEXT_BASE can be adjusted) All IPLs that I know of put their payload where specified.
Amicalement,
Hi, Albert,
Hi, Albert,
Hi Jason,
It's not an IPL. The layout is that as the following,
---- ----- TEXT_BASE plug-in ---------- _start
---------- _end
No matter what you adjusted the TEXT_BASE, the _star is not equal to it.
The fix doe not affect the original functionality but just make it more flexible.
Amicalement,
Albert.
Le 16/12/2010 10:18, Jason Liu a écrit :
Hi, Albert,
Hi, Albert,
Hi Jason,
---------- _end
This layout is not that of u-boot for ARM; the fix thus corrects a fault not inherent to u-boot but introduced by inserting this "plug-in" where it should not be.
Why must you modify the original layout?
Also, what is this 'plug-in' if it is not an IPL?
Amicalement,
Dear Albert ARIBAUD,
right!
Yes, and why must it be linked at TEXT_BASE?
Let's stop this here.
Let's wait until any code is submitted or proposed that actually needs such a feature. Then we can discuss the design and try to find a solution that makes sense.
Hi, Wolfgang,
2010/12/16 Wolfgang Denk wd@denx.de:
right!
In fact, this is indeed one bug in the code as I said in the comit log:
"the _dynsym_start_ofs and _rel_dyn_start_ofs is the offset from _start, so, need use _start address instead of _TEXT_BASE to caculate the rel dyn start and sym table address. This patch also correct the board_init_r function address caculation in relocation area. The addr of board_init_r after relocation is: _board_init_r_offs + relocation start address."
Is there any thing wrong with my patch? The case I met just make the bug show up.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de History is only a confused heap of facts. -- Philip Earl of Chesterfield
Dear Jason Liu,
In message AANLkTik=BSaBbV-NOJYg2QXx0Q-YYK4=Ox3iF8dWR5re@mail.gmail.com you wrote:
If there are really two different bugs, then please split your patch into to separate commits, and explain the respective problem in the commit messages.
Dear Jason Liu,
In message AANLkTimMct8TKe7k-0LA4Gob1mJZnCw0f9xbbp9VKMoz@mail.gmail.com you wrote:
So we are talking about aSoC that is not supported yet in U-Boot. Let's talk about this when such support gets added to U-Boot.
Albert ARIBAUD
Jason Liu
Jason Liu
