[PATCH 00/14] video: Drop old CFB code
There is still quite a bit of cruft in the video subsystem. Mainly this is users of the now-removed CONFIG_VIDEO, cfb_console and CONFIG_LCD.
This series removes most of the first two. The exception is videomodes.c and its header, since these are used by sunxi. It looks like the code could be removed, but I did not attempt it.
This is left for the sunxi maintainer.
The LCD clean-up can come later. Once done, we can rename CONFIG_DM_VIDEO to CONFIG_VIDEO, thus completing the migration.
Simon Glass (14): video: Drop cfg_console video: nokia_rx51: Drop obsolete video code video: siemens: Drop unused video code video: nexell: Drop unused and invalid code video: Drop video_fb header video: Drop CONFIG_VIDEO_BMP_LOGO video: Drop references to CONFIG_VIDEO et al video: Clean up the uclass header video: Drop da8xx-fb video: fsl: colibri_vf: Drop FSL DCU driver video: Drop FSL DIU driver video: mxs: Drop old video code video: Convert CONFIG_VIDEO_BCM2835 to Kconfig video: Drop formike driver
README | 18 - arch/arm/cpu/armv7/ls102xa/soc.c | 4 - arch/arm/include/asm/arch-ls102xa/config.h | 1 - arch/arm/include/asm/mach-imx/mx5_video.h | 5 - .../mach-nexell/include/mach/display_dev.h | 7 +- board/aristainetos/aristainetos.c | 1 - board/freescale/common/Makefile | 4 - board/freescale/common/dcu_sii9022a.c | 248 --- board/freescale/common/dcu_sii9022a.h | 12 - board/freescale/common/diu_ch7301.c | 217 -- board/freescale/common/diu_ch7301.h | 12 - board/freescale/ls1021aiot/Makefile | 1 - board/freescale/ls1021aiot/dcu.c | 48 - board/freescale/ls1021aqds/Makefile | 1 - board/freescale/ls1021aqds/dcu.c | 110 - board/freescale/ls1021atwr/Makefile | 1 - board/freescale/ls1021atwr/dcu.c | 48 - board/freescale/mx51evk/Makefile | 1 - board/freescale/mx53loco/Makefile | 1 - board/freescale/t104xrdb/Makefile | 1 - board/freescale/t104xrdb/diu.c | 84 - board/kosagi/novena/novena_spl.c | 23 - board/nokia/rx51/rx51.c | 19 - board/siemens/common/board.c | 3 - board/siemens/common/factoryset.c | 7 - board/siemens/common/factoryset.h | 3 - board/siemens/pxm2/board.c | 189 -- board/siemens/rut/board.c | 247 --- board/socrates/socrates.c | 1 - board/toradex/colibri_vf/Makefile | 1 - board/toradex/colibri_vf/colibri_vf.c | 62 - board/toradex/colibri_vf/dcu.c | 38 - cmd/Kconfig | 2 +- cmd/bdinfo.c | 2 +- cmd/bmp.c | 4 +- cmd/cls.c | 2 - common/fdt_support.c | 2 +- common/stdio.c | 4 +- configs/colibri_vf_defconfig | 1 - configs/nokia_rx51_defconfig | 3 - configs/rpi_0_w_defconfig | 1 + configs/rpi_2_defconfig | 1 + configs/rpi_3_32b_defconfig | 1 + configs/rpi_3_b_plus_defconfig | 1 + configs/rpi_3_defconfig | 1 + configs/rpi_4_32b_defconfig | 1 + configs/rpi_4_defconfig | 1 + configs/rpi_arm64_defconfig | 1 + configs/rpi_defconfig | 1 + doc/usage/bootmenu.rst | 5 - drivers/pci/pci_rom.c | 1 - drivers/video/Kconfig | 129 +- drivers/video/Makefile | 5 - drivers/video/cfb_console.c | 1865 ----------------- drivers/video/da8xx-fb.c | 1048 --------- drivers/video/da8xx-fb.h | 115 - drivers/video/formike.c | 513 ----- drivers/video/fsl_dcu_fb.c | 549 ----- drivers/video/fsl_diu_fb.c | 416 ---- drivers/video/imx/mxc_ipuv3_fb.c | 1 - drivers/video/mxsfb.c | 90 - drivers/video/nexell_display.c | 18 +- drivers/video/omap3_dss.c | 29 - drivers/video/sunxi/sunxi_display.c | 1 - include/asm-generic/global_data.h | 2 +- include/configs/T102xRDB.h | 13 - include/configs/T104xRDB.h | 20 - include/configs/apalis_imx6.h | 1 - include/configs/aristainetos2.h | 1 - include/configs/cm_fx6.h | 2 - include/configs/colibri-imx6ull.h | 1 - include/configs/colibri_imx6.h | 1 - include/configs/colibri_imx7.h | 4 - include/configs/colibri_vf.h | 8 - include/configs/embestmx6boards.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/imx6-engicam.h | 2 - include/configs/imxrt1050-evk.h | 2 - include/configs/ls1021aqds.h | 12 - include/configs/ls1021atwr.h | 15 - include/configs/mx6cuboxi.h | 1 - include/configs/mx6sabre_common.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/mx6ul_14x14_evk.h | 1 - include/configs/mx7dsabresd.h | 4 - include/configs/nokia_rx51.h | 11 - include/configs/opos6uldev.h | 1 - include/configs/pico-imx6.h | 1 - include/configs/pico-imx6ul.h | 1 - include/configs/pico-imx7d.h | 4 - include/configs/pxm2.h | 8 - include/configs/rpi.h | 1 - include/configs/rut.h | 10 - include/configs/wandboard.h | 1 - include/fsl_dcu_fb.h | 22 - include/fsl_diu_fb.h | 14 - include/video.h | 84 +- include/video_fb.h | 91 - lib/efi_loader/Kconfig | 1 - scripts/config_whitelist.txt | 10 - 100 files changed, 33 insertions(+), 6553 deletions(-) delete mode 100644 board/freescale/common/dcu_sii9022a.c delete mode 100644 board/freescale/common/dcu_sii9022a.h delete mode 100644 board/freescale/common/diu_ch7301.c delete mode 100644 board/freescale/common/diu_ch7301.h delete mode 100644 board/freescale/ls1021aiot/dcu.c delete mode 100644 board/freescale/ls1021aqds/dcu.c delete mode 100644 board/freescale/ls1021atwr/dcu.c delete mode 100644 board/freescale/t104xrdb/diu.c delete mode 100644 board/toradex/colibri_vf/dcu.c delete mode 100644 drivers/video/cfb_console.c delete mode 100644 drivers/video/da8xx-fb.c delete mode 100644 drivers/video/da8xx-fb.h delete mode 100644 drivers/video/formike.c delete mode 100644 drivers/video/fsl_dcu_fb.c delete mode 100644 drivers/video/fsl_diu_fb.c delete mode 100644 include/fsl_dcu_fb.h delete mode 100644 include/fsl_diu_fb.h delete mode 100644 include/video_fb.h
The non-driver model video support was removed two years ago. Drop this driver, which is only used by nokia_rx51.
README | 1 - cmd/cls.c | 2 - common/stdio.c | 1 - configs/nokia_rx51_defconfig | 2 - doc/usage/bootmenu.rst | 5 - drivers/video/Kconfig | 50 - drivers/video/Makefile | 1 - drivers/video/cfb_console.c | 1865 ---------------------------------- drivers/video/omap3_dss.c | 28 - 9 files changed, 1955 deletions(-) delete mode 100644 drivers/video/cfb_console.c
diff --git a/README b/README index 9ebd4f2345a..4fa369c4dd8 100644 --- a/README +++ b/README @@ -1014,7 +1014,6 @@ The following options need to be configured:
CONFIG_SYS_DIU_ADDR CONFIG_VIDEO - CONFIG_CFB_CONSOLE CONFIG_VIDEO_SW_CURSOR CONFIG_VGA_AS_SINGLE_DEVICE CONFIG_VIDEO_BMP_LOGO diff --git a/cmd/cls.c b/cmd/cls.c index eab4e6993bb..2d5bb8da5ef 100644 --- a/cmd/cls.c +++ b/cmd/cls.c @@ -22,8 +22,6 @@ static int do_video_clear(struct cmd_tbl *cmdtp, int flag, int argc,
if (video_clear(dev)) return CMD_RET_FAILURE; -#elif defined(CONFIG_CFB_CONSOLE) - video_clear(); #elif defined(CONFIG_LCD) lcd_clear(); #else diff --git a/common/stdio.c b/common/stdio.c index 976f51c2527..aedaea14ec5 100644 --- a/common/stdio.c +++ b/common/stdio.c @@ -368,7 +368,6 @@ int stdio_add_devices(void) if (IS_ENABLED(CONFIG_LCD)) drv_lcd_init(); if (IS_ENABLED(CONFIG_VIDEO) || - IS_ENABLED(CONFIG_CFB_CONSOLE) || IS_ENABLED(CONFIG_VIDEO_VCXK)) drv_video_init(); } diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index 4a95f42e4eb..71b0b95c672 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -76,8 +76,6 @@ CONFIG_SPI=y CONFIG_USB=y CONFIG_USB_MUSB_UDC=y CONFIG_USB_OMAP3=y -CONFIG_CFB_CONSOLE=y -CONFIG_CFB_CONSOLE_ANSI=y # CONFIG_VGA_AS_SINGLE_DEVICE is not set CONFIG_SPLASH_SCREEN=y CONFIG_WATCHDOG_TIMEOUT_MSECS=31000 diff --git a/doc/usage/bootmenu.rst b/doc/usage/bootmenu.rst index 1f094ad6ed2..1016ac8cebd 100644 --- a/doc/usage/bootmenu.rst +++ b/doc/usage/bootmenu.rst @@ -88,8 +88,3 @@ To run the bootmenu at startup add these additional settings:: CONFIG_AUTOBOOT_KEYED=y CONFIG_BOOTDELAY=30 CONFIG_AUTOBOOT_MENU_SHOW=y - -When you intend to use the bootmenu on a color frame buffer console, -make sure to additionally define:: - - CONFIG_CFB_CONSOLE_ANSI=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index cfa08b501ba..c2465121a72 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -691,56 +691,6 @@ config VIDEO model. Video drivers typically provide a colour text console and cursor.
-config CFB_CONSOLE - bool "Enable colour frame buffer console" - depends on VIDEO || ARCH_OMAP2PLUS - default y if VIDEO - help - Enables the colour frame buffer driver. This supports colour - output on a bitmap display from an in-memory frame buffer. - Several colour devices are supported along with various options to - adjust the supported features. The driver is implemented in - cfb_console.c - - The following defines are needed (cf. smiLynxEM, i8042) - VIDEO_FB_LITTLE_ENDIAN graphic memory organisation - (default big endian) - VIDEO_HW_RECTFILL graphic chip supports - rectangle fill (cf. smiLynxEM) - VIDEO_HW_BITBLT graphic chip supports - bit-blit (cf. smiLynxEM) - VIDEO_VISIBLE_COLS visible pixel columns (cols=pitch) - VIDEO_VISIBLE_ROWS visible pixel rows - VIDEO_PIXEL_SIZE bytes per pixel - VIDEO_DATA_FORMAT graphic data format - (0-5, cf. cfb_console.c) - VIDEO_FB_ADRS framebuffer address - VIDEO_KBD_INIT_FCT keyboard int fct (i.e. rx51_kp_init()) - VIDEO_TSTC_FCT test char fct (i.e. rx51_kp_tstc) - VIDEO_GETC_FCT get char fct (i.e. rx51_kp_getc) - CONFIG_VIDEO_LOGO display Linux logo in upper left corner - CONFIG_VIDEO_BMP_LOGO use bmp_logo.h instead of linux_logo.h - for logo. Requires CONFIG_VIDEO_LOGO - CONFIG_CONSOLE_EXTRA_INFO - additional board info beside - the logo - CONFIG_HIDE_LOGO_VERSION - do not display bootloader - version string - - When CONFIG_CFB_CONSOLE is defined, the video console is the - default console. The serial console can be forced by setting the - environment 'console=serial'. - -config CFB_CONSOLE_ANSI - bool "Support ANSI escape sequences" - depends on CFB_CONSOLE - help - This allows the colour buffer frame buffer driver to support - a limited number of ANSI escape sequences (cursor control, - erase functions and limited graphics rendition control). Normal - output from U-Boot will pass through this filter. - config VGA_AS_SINGLE_DEVICE bool "Set the video as an output-only device" depends on CFB_CONSOLE diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 4038395b128..aaf3d80f856 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -30,7 +30,6 @@ obj-y += ti/
obj-$(CONFIG_ATMEL_HLCD) += atmel_hlcdfb.o obj-$(CONFIG_ATMEL_LCD) += atmel_lcdfb.o -obj-$(CONFIG_CFB_CONSOLE) += cfb_console.o obj-$(CONFIG_FORMIKE) += formike.o obj-$(CONFIG_FSL_DIU_FB) += fsl_diu_fb.o videomodes.o obj-$(CONFIG_IHS_VIDEO_OUT) += ihs_video_out.o diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c deleted file mode 100644 index 52b109f1551..00000000000 --- a/drivers/video/cfb_console.c +++ /dev/null @@ -1,1865 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2002 ELTEC Elektronik AG - * Frank Gottschling fgottschling@eltec.de - */ - -/* - * cfb_console.c - * - * Color Framebuffer Console driver for 8/15/16/24/32 bits per pixel. - * - * At the moment only the 8x16 font is tested and the font fore- and - * background color is limited to black/white/gray colors. The Linux - * logo can be placed in the upper left corner and additional board - * information strings (that normally goes to serial port) can be drawn. - * - * The console driver can use a keyboard interface for character input - * but this is deprecated. Only rk51 uses it. - * - * Character output goes to a memory-mapped video - * framebuffer with little or big-endian organisation. - * With environment setting 'console=serial' the console i/o can be - * forced to serial port. - * - * The driver uses graphic specific defines/parameters/functions: - * - * (for SMI LynxE graphic chip) - * - * VIDEO_FB_LITTLE_ENDIAN - framebuffer organisation default: big endian - * VIDEO_HW_RECTFILL - graphic driver supports hardware rectangle fill - * VIDEO_HW_BITBLT - graphic driver supports hardware bit blt - * - * Console Parameters are set by graphic drivers global struct: - * - * VIDEO_VISIBLE_COLS - x resolution - * VIDEO_VISIBLE_ROWS - y resolution - * VIDEO_PIXEL_SIZE - storage size in byte per pixel - * VIDEO_DATA_FORMAT - graphical data format GDF - * VIDEO_FB_ADRS - start of video memory - * - * VIDEO_KBD_INIT_FCT - init function for keyboard - * VIDEO_TSTC_FCT - keyboard_tstc function - * VIDEO_GETC_FCT - keyboard_getc function - * - * CONFIG_VIDEO_BMP_LOGO - use bmp_logo instead of linux_logo - * CONFIG_CONSOLE_EXTRA_INFO - display additional board information - * strings that normaly goes to serial - * port. This define requires a board - * specific function: - * video_drawstring (VIDEO_INFO_X, - * VIDEO_INFO_Y + i*VIDEO_FONT_HEIGHT, - * info); - * that fills a info buffer at i=row. - * s.a: board/eltec/bab7xx. - * - * CONFIG_VIDEO_SW_CURSOR: - Draws a cursor after the last - * character. No blinking is provided. - * Uses the macros CURSOR_SET and - * CURSOR_OFF. - */ - -#include <common.h> -#include <command.h> -#include <cpu_func.h> -#include <env.h> -#include <fdtdec.h> -#include <gzip.h> -#include <log.h> -#include <version_string.h> -#include <malloc.h> -#include <video.h> -#include <asm/global_data.h> -#include <dm/ofnode.h> -#include <linux/compiler.h> - -/* - * Include video_fb.h after definitions of VIDEO_HW_RECTFILL etc. - */ -#include <video_fb.h> - -#include <splash.h> - -/* - * some Macros - */ -#define VIDEO_VISIBLE_COLS (pGD->winSizeX) -#define VIDEO_VISIBLE_ROWS (pGD->winSizeY) -#define VIDEO_PIXEL_SIZE (pGD->gdfBytesPP) -#define VIDEO_DATA_FORMAT (pGD->gdfIndex) -#define VIDEO_FB_ADRS (pGD->frameAdrs) - -/* - * Console device - */ - -#include <linux/types.h> -#include <stdio_dev.h> -#include <video_font.h> - -#if defined(CONFIG_CMD_DATE) -#include <rtc.h> -#endif - -#if defined(CONFIG_CMD_BMP) || defined(CONFIG_SPLASH_SCREEN) -#include <watchdog.h> -#include <bmp_layout.h> -#include <splash.h> -#endif - -#if !defined(CONFIG_VIDEO_SW_CURSOR) -/* no Cursor defined */ -#define CURSOR_ON -#define CURSOR_OFF -#define CURSOR_SET -#endif - -#if defined(CONFIG_VIDEO_SW_CURSOR) -void console_cursor(int state); - -#define CURSOR_ON console_cursor(1) -#define CURSOR_OFF console_cursor(0) -#define CURSOR_SET video_set_cursor() -#endif /* CONFIG_VIDEO_SW_CURSOR */ - -#define VIDEO_COLS VIDEO_VISIBLE_COLS -#define VIDEO_ROWS VIDEO_VISIBLE_ROWS -#ifndef VIDEO_LINE_LEN -#define VIDEO_LINE_LEN (VIDEO_COLS * VIDEO_PIXEL_SIZE) -#endif -#define VIDEO_SIZE (VIDEO_ROWS * VIDEO_LINE_LEN) -#define VIDEO_BURST_LEN (VIDEO_COLS/8) - -#define CONSOLE_ROWS (VIDEO_ROWS / VIDEO_FONT_HEIGHT) - -#define CONSOLE_COLS (VIDEO_COLS / VIDEO_FONT_WIDTH) -#define CONSOLE_ROW_SIZE (VIDEO_FONT_HEIGHT * VIDEO_LINE_LEN) -#define CONSOLE_ROW_FIRST (video_console_address) -#define CONSOLE_ROW_SECOND (video_console_address + CONSOLE_ROW_SIZE) -#define CONSOLE_ROW_LAST (video_console_address + CONSOLE_SIZE - CONSOLE_ROW_SIZE) -#define CONSOLE_SIZE (CONSOLE_ROW_SIZE * CONSOLE_ROWS) - -/* By default we scroll by a single line */ -#ifndef CONFIG_CONSOLE_SCROLL_LINES -#define CONFIG_CONSOLE_SCROLL_LINES 1 -#endif - -/* Macros */ -#ifdef VIDEO_FB_LITTLE_ENDIAN -#define SWAP16(x) ((((x) & 0x00ff) << 8) | \ - ((x) >> 8) \ - ) -#define SWAP32(x) ((((x) & 0x000000ff) << 24) | \ - (((x) & 0x0000ff00) << 8) | \ - (((x) & 0x00ff0000) >> 8) | \ - (((x) & 0xff000000) >> 24) \ - ) -#define SHORTSWAP32(x) ((((x) & 0x000000ff) << 8) | \ - (((x) & 0x0000ff00) >> 8) | \ - (((x) & 0x00ff0000) << 8) | \ - (((x) & 0xff000000) >> 8) \ - ) -#else -#define SWAP16(x) (x) -#define SWAP32(x) (x) -#if defined(VIDEO_FB_16BPP_WORD_SWAP) -#define SHORTSWAP32(x) (((x) >> 16) | ((x) << 16)) -#else -#define SHORTSWAP32(x) (x) -#endif -#endif - -DECLARE_GLOBAL_DATA_PTR; - -/* Locals */ -static GraphicDevice *pGD; /* Pointer to Graphic array */ - -static void *video_fb_address; /* frame buffer address */ -static void *video_console_address; /* console buffer start address */ - -static int video_logo_height; /* not supported anymore */ - -static int __maybe_unused cursor_state; -static int __maybe_unused old_col; -static int __maybe_unused old_row; - -static int console_col; /* cursor col */ -static int console_row; /* cursor row */ - -static u32 eorx, fgx, bgx; /* color pats */ - -static int cfb_do_flush_cache; - -#ifdef CONFIG_CFB_CONSOLE_ANSI -static char ansi_buf[10]; -static int ansi_buf_size; -static int ansi_colors_need_revert; -static int ansi_cursor_hidden; -#endif - -static const int video_font_draw_table8[] = { - 0x00000000, 0x000000ff, 0x0000ff00, 0x0000ffff, - 0x00ff0000, 0x00ff00ff, 0x00ffff00, 0x00ffffff, - 0xff000000, 0xff0000ff, 0xff00ff00, 0xff00ffff, - 0xffff0000, 0xffff00ff, 0xffffff00, 0xffffffff -}; - -static const int video_font_draw_table15[] = { - 0x00000000, 0x00007fff, 0x7fff0000, 0x7fff7fff -}; - -static const int video_font_draw_table16[] = { - 0x00000000, 0x0000ffff, 0xffff0000, 0xffffffff -}; - -static const int video_font_draw_table24[16][3] = { - {0x00000000, 0x00000000, 0x00000000}, - {0x00000000, 0x00000000, 0x00ffffff}, - {0x00000000, 0x0000ffff, 0xff000000}, - {0x00000000, 0x0000ffff, 0xffffffff}, - {0x000000ff, 0xffff0000, 0x00000000}, - {0x000000ff, 0xffff0000, 0x00ffffff}, - {0x000000ff, 0xffffffff, 0xff000000}, - {0x000000ff, 0xffffffff, 0xffffffff}, - {0xffffff00, 0x00000000, 0x00000000}, - {0xffffff00, 0x00000000, 0x00ffffff}, - {0xffffff00, 0x0000ffff, 0xff000000}, - {0xffffff00, 0x0000ffff, 0xffffffff}, - {0xffffffff, 0xffff0000, 0x00000000}, - {0xffffffff, 0xffff0000, 0x00ffffff}, - {0xffffffff, 0xffffffff, 0xff000000}, - {0xffffffff, 0xffffffff, 0xffffffff} -}; - -static const int video_font_draw_table32[16][4] = { - {0x00000000, 0x00000000, 0x00000000, 0x00000000}, - {0x00000000, 0x00000000, 0x00000000, 0x00ffffff}, - {0x00000000, 0x00000000, 0x00ffffff, 0x00000000}, - {0x00000000, 0x00000000, 0x00ffffff, 0x00ffffff}, - {0x00000000, 0x00ffffff, 0x00000000, 0x00000000}, - {0x00000000, 0x00ffffff, 0x00000000, 0x00ffffff}, - {0x00000000, 0x00ffffff, 0x00ffffff, 0x00000000}, - {0x00000000, 0x00ffffff, 0x00ffffff, 0x00ffffff}, - {0x00ffffff, 0x00000000, 0x00000000, 0x00000000}, - {0x00ffffff, 0x00000000, 0x00000000, 0x00ffffff}, - {0x00ffffff, 0x00000000, 0x00ffffff, 0x00000000}, - {0x00ffffff, 0x00000000, 0x00ffffff, 0x00ffffff}, - {0x00ffffff, 0x00ffffff, 0x00000000, 0x00000000}, - {0x00ffffff, 0x00ffffff, 0x00000000, 0x00ffffff}, - {0x00ffffff, 0x00ffffff, 0x00ffffff, 0x00000000}, - {0x00ffffff, 0x00ffffff, 0x00ffffff, 0x00ffffff} -}; - -/* - * Implement a weak default function for boards that optionally - * need to skip the cfb initialization. - */ -__weak int board_cfb_skip(void) -{ - /* As default, don't skip cfb init */ - return 0; -} - -static void video_drawchars(int xx, int yy, unsigned char *s, int count) -{ - u8 *cdat, *dest, *dest0; - int rows, offset, c; - - offset = yy * VIDEO_LINE_LEN + xx * VIDEO_PIXEL_SIZE; - dest0 = video_fb_address + offset; - - switch (VIDEO_DATA_FORMAT) { - case GDF__8BIT_INDEX: - case GDF__8BIT_332RGB: - while (count--) { - c = *s; - cdat = video_fontdata + c * VIDEO_FONT_HEIGHT; - for (rows = VIDEO_FONT_HEIGHT, dest = dest0; - rows--; dest += VIDEO_LINE_LEN) { - u8 bits = *cdat++; - - ((u32 *) dest)[0] = - (video_font_draw_table8[bits >> 4] & - eorx) ^ bgx; - - if (VIDEO_FONT_WIDTH == 4) - continue; - - ((u32 *) dest)[1] = - (video_font_draw_table8[bits & 15] & - eorx) ^ bgx; - } - dest0 += VIDEO_FONT_WIDTH * VIDEO_PIXEL_SIZE; - s++; - } - break; - - case GDF_15BIT_555RGB: - while (count--) { - c = *s; - cdat = video_fontdata + c * VIDEO_FONT_HEIGHT; - for (rows = VIDEO_FONT_HEIGHT, dest = dest0; - rows--; dest += VIDEO_LINE_LEN) { - u8 bits = *cdat++; - - ((u32 *) dest)[0] = - SHORTSWAP32((video_font_draw_table15 - [bits >> 6] & eorx) ^ - bgx); - ((u32 *) dest)[1] = - SHORTSWAP32((video_font_draw_table15 - [bits >> 4 & 3] & eorx) ^ - bgx); - - if (VIDEO_FONT_WIDTH == 4) - continue; - - ((u32 *) dest)[2] = - SHORTSWAP32((video_font_draw_table15 - [bits >> 2 & 3] & eorx) ^ - bgx); - ((u32 *) dest)[3] = - SHORTSWAP32((video_font_draw_table15 - [bits & 3] & eorx) ^ - bgx); - } - dest0 += VIDEO_FONT_WIDTH * VIDEO_PIXEL_SIZE; - s++; - } - break; - - case GDF_16BIT_565RGB: - while (count--) { - c = *s; - cdat = video_fontdata + c * VIDEO_FONT_HEIGHT; - for (rows = VIDEO_FONT_HEIGHT, dest = dest0; - rows--; dest += VIDEO_LINE_LEN) { - u8 bits = *cdat++; - - ((u32 *) dest)[0] = - SHORTSWAP32((video_font_draw_table16 - [bits >> 6] & eorx) ^ - bgx); - ((u32 *) dest)[1] = - SHORTSWAP32((video_font_draw_table16 - [bits >> 4 & 3] & eorx) ^ - bgx); - - if (VIDEO_FONT_WIDTH == 4) - continue; - - ((u32 *) dest)[2] = - SHORTSWAP32((video_font_draw_table16 - [bits >> 2 & 3] & eorx) ^ - bgx); - ((u32 *) dest)[3] = - SHORTSWAP32((video_font_draw_table16 - [bits & 3] & eorx) ^ - bgx); - } - dest0 += VIDEO_FONT_WIDTH * VIDEO_PIXEL_SIZE; - s++; - } - break; - - case GDF_32BIT_X888RGB: - while (count--) { - c = *s; - cdat = video_fontdata + c * VIDEO_FONT_HEIGHT; - for (rows = VIDEO_FONT_HEIGHT, dest = dest0; - rows--; dest += VIDEO_LINE_LEN) { - u8 bits = *cdat++; - - ((u32 *) dest)[0] = - SWAP32((video_font_draw_table32 - [bits >> 4][0] & eorx) ^ bgx); - ((u32 *) dest)[1] = - SWAP32((video_font_draw_table32 - [bits >> 4][1] & eorx) ^ bgx); - ((u32 *) dest)[2] = - SWAP32((video_font_draw_table32 - [bits >> 4][2] & eorx) ^ bgx); - ((u32 *) dest)[3] = - SWAP32((video_font_draw_table32 - [bits >> 4][3] & eorx) ^ bgx); - - - if (VIDEO_FONT_WIDTH == 4) - continue; - - ((u32 *) dest)[4] = - SWAP32((video_font_draw_table32 - [bits & 15][0] & eorx) ^ bgx); - ((u32 *) dest)[5] = - SWAP32((video_font_draw_table32 - [bits & 15][1] & eorx) ^ bgx); - ((u32 *) dest)[6] = - SWAP32((video_font_draw_table32 - [bits & 15][2] & eorx) ^ bgx); - ((u32 *) dest)[7] = - SWAP32((video_font_draw_table32 - [bits & 15][3] & eorx) ^ bgx); - } - dest0 += VIDEO_FONT_WIDTH * VIDEO_PIXEL_SIZE; - s++; - } - break; - - case GDF_24BIT_888RGB: - while (count--) { - c = *s; - cdat = video_fontdata + c * VIDEO_FONT_HEIGHT; - for (rows = VIDEO_FONT_HEIGHT, dest = dest0; - rows--; dest += VIDEO_LINE_LEN) { - u8 bits = *cdat++; - - ((u32 *) dest)[0] = - (video_font_draw_table24[bits >> 4][0] - & eorx) ^ bgx; - ((u32 *) dest)[1] = - (video_font_draw_table24[bits >> 4][1] - & eorx) ^ bgx; - ((u32 *) dest)[2] = - (video_font_draw_table24[bits >> 4][2] - & eorx) ^ bgx; - - if (VIDEO_FONT_WIDTH == 4) - continue; - - ((u32 *) dest)[3] = - (video_font_draw_table24[bits & 15][0] - & eorx) ^ bgx; - ((u32 *) dest)[4] = - (video_font_draw_table24[bits & 15][1] - & eorx) ^ bgx; - ((u32 *) dest)[5] = - (video_font_draw_table24[bits & 15][2] - & eorx) ^ bgx; - } - dest0 += VIDEO_FONT_WIDTH * VIDEO_PIXEL_SIZE; - s++; - } - break; - } -} - -static inline void video_drawstring(int xx, int yy, unsigned char *s) -{ - video_drawchars(xx, yy, s, strlen((char *) s)); -} - -static void video_putchar(int xx, int yy, unsigned char c) -{ - video_drawchars(xx, yy + video_logo_height, &c, 1); -} - -#if defined(CONFIG_VIDEO_SW_CURSOR) -static void video_set_cursor(void) -{ - if (cursor_state) - console_cursor(0); - console_cursor(1); -} - -static void video_invertchar(int xx, int yy) -{ - int firstx = xx * VIDEO_PIXEL_SIZE; - int lastx = (xx + VIDEO_FONT_WIDTH) * VIDEO_PIXEL_SIZE; - int firsty = yy * VIDEO_LINE_LEN; - int lasty = (yy + VIDEO_FONT_HEIGHT) * VIDEO_LINE_LEN; - int x, y; - for (y = firsty; y < lasty; y += VIDEO_LINE_LEN) { - for (x = firstx; x < lastx; x++) { - u8 *dest = (u8 *)(video_fb_address) + x + y; - *dest = ~*dest; - } - } -} - -void console_cursor(int state) -{ - if (cursor_state != state) { - if (cursor_state) { - /* turn off the cursor */ - video_invertchar(old_col * VIDEO_FONT_WIDTH, - old_row * VIDEO_FONT_HEIGHT + - video_logo_height); - } else { - /* turn off the cursor and record where it is */ - video_invertchar(console_col * VIDEO_FONT_WIDTH, - console_row * VIDEO_FONT_HEIGHT + - video_logo_height); - old_col = console_col; - old_row = console_row; - } - cursor_state = state; - } - if (cfb_do_flush_cache) - flush_cache(VIDEO_FB_ADRS, VIDEO_SIZE); -} -#endif - -#ifndef VIDEO_HW_RECTFILL -static void memsetl(int *p, int c, int v) -{ - while (c--) - *(p++) = v; -} -#endif - -#ifndef VIDEO_HW_BITBLT -static void memcpyl(int *d, int *s, int c) -{ - while (c--) - *(d++) = *(s++); -} -#endif - -static void console_clear_line(int line, int begin, int end) -{ -#ifdef VIDEO_HW_RECTFILL - video_hw_rectfill(VIDEO_PIXEL_SIZE, /* bytes per pixel */ - VIDEO_FONT_WIDTH * begin, /* dest pos x */ - video_logo_height + - VIDEO_FONT_HEIGHT * line, /* dest pos y */ - VIDEO_FONT_WIDTH * (end - begin + 1), /* fr. width */ - VIDEO_FONT_HEIGHT, /* frame height */ - bgx /* fill color */ - ); -#else - if (begin == 0 && (end + 1) == CONSOLE_COLS) { - memsetl(CONSOLE_ROW_FIRST + - CONSOLE_ROW_SIZE * line, /* offset of row */ - CONSOLE_ROW_SIZE >> 2, /* length of row */ - bgx /* fill color */ - ); - } else { - void *offset; - int i, size; - - offset = CONSOLE_ROW_FIRST + - CONSOLE_ROW_SIZE * line + /* offset of row */ - VIDEO_FONT_WIDTH * - VIDEO_PIXEL_SIZE * begin; /* offset of col */ - size = VIDEO_FONT_WIDTH * VIDEO_PIXEL_SIZE * (end - begin + 1); - size >>= 2; /* length to end for memsetl() */ - /* fill at col offset of i'th line using bgx as fill color */ - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) - memsetl(offset + i * VIDEO_LINE_LEN, size, bgx); - } -#endif -} - -static void console_scrollup(void) -{ - const int rows = CONFIG_CONSOLE_SCROLL_LINES; - int i; - - /* copy up rows ignoring the first one */ - -#ifdef VIDEO_HW_BITBLT - video_hw_bitblt(VIDEO_PIXEL_SIZE, /* bytes per pixel */ - 0, /* source pos x */ - video_logo_height + - VIDEO_FONT_HEIGHT * rows, /* source pos y */ - 0, /* dest pos x */ - video_logo_height, /* dest pos y */ - VIDEO_VISIBLE_COLS, /* frame width */ - VIDEO_VISIBLE_ROWS - - video_logo_height - - VIDEO_FONT_HEIGHT * rows /* frame height */ - ); -#else - memcpyl(CONSOLE_ROW_FIRST, CONSOLE_ROW_FIRST + rows * CONSOLE_ROW_SIZE, - (CONSOLE_SIZE - CONSOLE_ROW_SIZE * rows) >> 2); -#endif - /* clear the last one */ - for (i = 1; i <= rows; i++) - console_clear_line(CONSOLE_ROWS - i, 0, CONSOLE_COLS - 1); - - /* Decrement row number */ - console_row -= rows; -} - -static void console_back(void) -{ - console_col--; - - if (console_col < 0) { - console_col = CONSOLE_COLS - 1; - console_row--; - if (console_row < 0) - console_row = 0; - } -} - -#ifdef CONFIG_CFB_CONSOLE_ANSI - -static void console_clear(void) -{ -#ifdef VIDEO_HW_RECTFILL - video_hw_rectfill(VIDEO_PIXEL_SIZE, /* bytes per pixel */ - 0, /* dest pos x */ - video_logo_height, /* dest pos y */ - VIDEO_VISIBLE_COLS, /* frame width */ - VIDEO_VISIBLE_ROWS, /* frame height */ - bgx /* fill color */ - ); -#else - memsetl(CONSOLE_ROW_FIRST, CONSOLE_SIZE, bgx); -#endif -} - -static void console_cursor_fix(void) -{ - if (console_row < 0) - console_row = 0; - if (console_row >= CONSOLE_ROWS) - console_row = CONSOLE_ROWS - 1; - if (console_col < 0) - console_col = 0; - if (console_col >= CONSOLE_COLS) - console_col = CONSOLE_COLS - 1; -} - -static void console_cursor_up(int n) -{ - console_row -= n; - console_cursor_fix(); -} - -static void console_cursor_down(int n) -{ - console_row += n; - console_cursor_fix(); -} - -static void console_cursor_left(int n) -{ - console_col -= n; - console_cursor_fix(); -} - -static void console_cursor_right(int n) -{ - console_col += n; - console_cursor_fix(); -} - -static void console_cursor_set_position(int row, int col) -{ - if (console_row != -1) - console_row = row; - if (console_col != -1) - console_col = col; - console_cursor_fix(); -} - -static void console_previousline(int n) -{ - /* FIXME: also scroll terminal ? */ - console_row -= n; - console_cursor_fix(); -} - -static void console_swap_colors(void) -{ - eorx = fgx; - fgx = bgx; - bgx = eorx; - eorx = fgx ^ bgx; -} - -static inline int console_cursor_is_visible(void) -{ - return !ansi_cursor_hidden; -} -#else -static inline int console_cursor_is_visible(void) -{ - return 1; -} -#endif - -static void console_newline(int n) -{ - console_row += n; - console_col = 0; - - /* Check if we need to scroll the terminal */ - if (console_row >= CONSOLE_ROWS) { - /* Scroll everything up */ - console_scrollup(); - } -} - -static void console_cr(void) -{ - console_col = 0; -} - -static void parse_putc(const char c) -{ - static int nl = 1; - - if (console_cursor_is_visible()) - CURSOR_OFF; - - switch (c) { - case 13: /* back to first column */ - console_cr(); - break; - - case '\n': /* next line */ - if (console_col || nl) - console_newline(1); - nl = 1; - break; - - case 9: /* tab 8 */ - console_col |= 0x0008; - console_col &= ~0x0007; - - if (console_col >= CONSOLE_COLS) - console_newline(1); - break; - - case 8: /* backspace */ - console_back(); - break; - - case 7: /* bell */ - break; /* ignored */ - - default: /* draw the char */ - video_putchar(console_col * VIDEO_FONT_WIDTH, - console_row * VIDEO_FONT_HEIGHT, c); - console_col++; - - /* check for newline */ - if (console_col >= CONSOLE_COLS) { - console_newline(1); - nl = 0; - } - } - - if (console_cursor_is_visible()) - CURSOR_SET; -} - -static void cfb_video_putc(struct stdio_dev *dev, const char c) -{ -#ifdef CONFIG_CFB_CONSOLE_ANSI - int i; - - if (c == 27) { - for (i = 0; i < ansi_buf_size; ++i) - parse_putc(ansi_buf[i]); - ansi_buf[0] = 27; - ansi_buf_size = 1; - return; - } - - if (ansi_buf_size > 0) { - /* - * 0 - ESC - * 1 - [ - * 2 - num1 - * 3 - .. - * 4 - ; - * 5 - num2 - * 6 - .. - * - cchar - */ - int next = 0; - - int flush = 0; - int fail = 0; - - int num1 = 0; - int num2 = 0; - int cchar = 0; - - ansi_buf[ansi_buf_size++] = c; - - if (ansi_buf_size >= sizeof(ansi_buf)) - fail = 1; - - for (i = 0; i < ansi_buf_size; ++i) { - if (fail) - break; - - switch (next) { - case 0: - if (ansi_buf[i] == 27) - next = 1; - else - fail = 1; - break; - - case 1: - if (ansi_buf[i] == '[') - next = 2; - else - fail = 1; - break; - - case 2: - if (ansi_buf[i] >= '0' && ansi_buf[i] <= '9') { - num1 = ansi_buf[i]-'0'; - next = 3; - } else if (ansi_buf[i] != '?') { - --i; - num1 = 1; - next = 4; - } - break; - - case 3: - if (ansi_buf[i] >= '0' && ansi_buf[i] <= '9') { - num1 *= 10; - num1 += ansi_buf[i]-'0'; - } else { - --i; - next = 4; - } - break; - - case 4: - if (ansi_buf[i] != ';') { - --i; - next = 7; - } else - next = 5; - break; - - case 5: - if (ansi_buf[i] >= '0' && ansi_buf[i] <= '9') { - num2 = ansi_buf[i]-'0'; - next = 6; - } else - fail = 1; - break; - - case 6: - if (ansi_buf[i] >= '0' && ansi_buf[i] <= '9') { - num2 *= 10; - num2 += ansi_buf[i]-'0'; - } else { - --i; - next = 7; - } - break; - - case 7: - if ((ansi_buf[i] >= 'A' && ansi_buf[i] <= 'H') - || ansi_buf[i] == 'J' - || ansi_buf[i] == 'K' - || ansi_buf[i] == 'h' - || ansi_buf[i] == 'l' - || ansi_buf[i] == 'm') { - cchar = ansi_buf[i]; - flush = 1; - } else - fail = 1; - break; - } - } - - if (fail) { - for (i = 0; i < ansi_buf_size; ++i) - parse_putc(ansi_buf[i]); - ansi_buf_size = 0; - return; - } - - if (flush) { - if (!ansi_cursor_hidden) - CURSOR_OFF; - ansi_buf_size = 0; - switch (cchar) { - case 'A': - /* move cursor num1 rows up */ - console_cursor_up(num1); - break; - case 'B': - /* move cursor num1 rows down */ - console_cursor_down(num1); - break; - case 'C': - /* move cursor num1 columns forward */ - console_cursor_right(num1); - break; - case 'D': - /* move cursor num1 columns back */ - console_cursor_left(num1); - break; - case 'E': - /* move cursor num1 rows up at begin of row */ - console_previousline(num1); - break; - case 'F': - /* move cursor num1 rows down at begin of row */ - console_newline(num1); - break; - case 'G': - /* move cursor to column num1 */ - console_cursor_set_position(-1, num1-1); - break; - case 'H': - /* move cursor to row num1, column num2 */ - console_cursor_set_position(num1-1, num2-1); - break; - case 'J': - /* clear console and move cursor to 0, 0 */ - console_clear(); - console_cursor_set_position(0, 0); - break; - case 'K': - /* clear line */ - if (num1 == 0) - console_clear_line(console_row, - console_col, - CONSOLE_COLS-1); - else if (num1 == 1) - console_clear_line(console_row, - 0, console_col); - else - console_clear_line(console_row, - 0, CONSOLE_COLS-1); - break; - case 'h': - ansi_cursor_hidden = 0; - break; - case 'l': - ansi_cursor_hidden = 1; - break; - case 'm': - if (num1 == 0) { /* reset swapped colors */ - if (ansi_colors_need_revert) { - console_swap_colors(); - ansi_colors_need_revert = 0; - } - } else if (num1 == 7) { /* once swap colors */ - if (!ansi_colors_need_revert) { - console_swap_colors(); - ansi_colors_need_revert = 1; - } - } - break; - } - if (!ansi_cursor_hidden) - CURSOR_SET; - } - } else { - parse_putc(c); - } -#else - parse_putc(c); -#endif - if (cfb_do_flush_cache) - flush_cache(VIDEO_FB_ADRS, VIDEO_SIZE); -} - -static void cfb_video_puts(struct stdio_dev *dev, const char *s) -{ - int flush = cfb_do_flush_cache; - int count = strlen(s); - - /* temporarily disable cache flush */ - cfb_do_flush_cache = 0; - - while (count--) - cfb_video_putc(dev, *s++); - - if (flush) { - cfb_do_flush_cache = flush; - flush_cache(VIDEO_FB_ADRS, VIDEO_SIZE); - } -} - -/* - * Do not enforce drivers (or board code) to provide empty - * video_set_lut() if they do not support 8 bpp format. - * Implement weak default function instead. - */ -__weak void video_set_lut(unsigned int index, unsigned char r, - unsigned char g, unsigned char b) -{ -} - -#if defined(CONFIG_CMD_BMP) || defined(CONFIG_SPLASH_SCREEN) - -#define FILL_8BIT_332RGB(r,g,b) { \ - *fb = ((r>>5)<<5) | ((g>>5)<<2) | (b>>6); \ - fb ++; \ -} - -#define FILL_15BIT_555RGB(r,g,b) { \ - *(unsigned short *)fb = \ - SWAP16((unsigned short)(((r>>3)<<10) | \ - ((g>>3)<<5) | \ - (b>>3))); \ - fb += 2; \ -} - -#define FILL_16BIT_565RGB(r,g,b) { \ - *(unsigned short *)fb = \ - SWAP16((unsigned short)((((r)>>3)<<11)| \ - (((g)>>2)<<5) | \ - ((b)>>3))); \ - fb += 2; \ -} - -#define FILL_32BIT_X888RGB(r,g,b) { \ - *(u32 *)fb = \ - SWAP32((unsigned int)(((r<<16) | \ - (g<<8) | \ - b))); \ - fb += 4; \ -} - -#ifdef VIDEO_FB_LITTLE_ENDIAN -#define FILL_24BIT_888RGB(r,g,b) { \ - fb[0] = b; \ - fb[1] = g; \ - fb[2] = r; \ - fb += 3; \ -} -#else -#define FILL_24BIT_888RGB(r,g,b) { \ - fb[0] = r; \ - fb[1] = g; \ - fb[2] = b; \ - fb += 3; \ -} -#endif - -#if defined(VIDEO_FB_16BPP_PIXEL_SWAP) -static inline void fill_555rgb_pswap(uchar *fb, int x, u8 r, u8 g, u8 b) -{ - ushort *dst = (ushort *) fb; - ushort color = (ushort) (((r >> 3) << 10) | - ((g >> 3) << 5) | - (b >> 3)); - if (x & 1) - *(--dst) = color; - else - *(++dst) = color; -} -#endif - -/* - * RLE8 bitmap support - */ - -#ifdef CONFIG_VIDEO_BMP_RLE8 -/* Pre-calculated color table entry */ -struct palette { - union { - unsigned short w; /* word */ - unsigned int dw; /* double word */ - } ce; /* color entry */ -}; - -/* - * Helper to draw encoded/unencoded run. - */ -static void draw_bitmap(uchar **fb, uchar *bm, struct palette *p, - int cnt, int enc) -{ - ulong addr = (ulong) *fb; - int *off; - int enc_off = 1; - int i; - - /* - * Setup offset of the color index in the bitmap. - * Color index of encoded run is at offset 1. - */ - off = enc ? &enc_off : &i; - - switch (VIDEO_DATA_FORMAT) { - case GDF__8BIT_INDEX: - for (i = 0; i < cnt; i++) - *(unsigned char *) addr++ = bm[*off]; - break; - case GDF_15BIT_555RGB: - case GDF_16BIT_565RGB: - /* differences handled while pre-calculating palette */ - for (i = 0; i < cnt; i++) { - *(unsigned short *) addr = p[bm[*off]].ce.w; - addr += 2; - } - break; - case GDF_32BIT_X888RGB: - for (i = 0; i < cnt; i++) { - *(u32 *) addr = p[bm[*off]].ce.dw; - addr += 4; - } - break; - } - *fb = (uchar *) addr; /* return modified address */ -} - -static int display_rle8_bitmap(struct bmp_image *img, int xoff, int yoff, - int width, int height) -{ - unsigned char *bm; - unsigned char *fbp; - unsigned int cnt, runlen; - int decode = 1; - int x, y, bpp, i, ncolors; - struct palette p[256]; - struct bmp_color_table_entry cte; - int green_shift, red_off; - int limit = (VIDEO_LINE_LEN / VIDEO_PIXEL_SIZE) * VIDEO_ROWS; - int pixels = 0; - - x = 0; - y = __le32_to_cpu(img->header.height) - 1; - ncolors = __le32_to_cpu(img->header.colors_used); - bpp = VIDEO_PIXEL_SIZE; - fbp = (unsigned char *) ((unsigned int) video_fb_address + - (y + yoff) * VIDEO_LINE_LEN + - xoff * bpp); - - bm = (uchar *) img + __le32_to_cpu(img->header.data_offset); - - /* pre-calculate and setup palette */ - switch (VIDEO_DATA_FORMAT) { - case GDF__8BIT_INDEX: - for (i = 0; i < ncolors; i++) { - cte = img->color_table[i]; - video_set_lut(i, cte.red, cte.green, cte.blue); - } - break; - case GDF_15BIT_555RGB: - case GDF_16BIT_565RGB: - if (VIDEO_DATA_FORMAT == GDF_15BIT_555RGB) { - green_shift = 3; - red_off = 10; - } else { - green_shift = 2; - red_off = 11; - } - for (i = 0; i < ncolors; i++) { - cte = img->color_table[i]; - p[i].ce.w = SWAP16((unsigned short) - (((cte.red >> 3) << red_off) | - ((cte.green >> green_shift) << 5) | - cte.blue >> 3)); - } - break; - case GDF_32BIT_X888RGB: - for (i = 0; i < ncolors; i++) { - cte = img->color_table[i]; - p[i].ce.dw = SWAP32((cte.red << 16) | - (cte.green << 8) | - cte.blue); - } - break; - default: - printf("RLE Bitmap unsupported in video mode 0x%x\n", - VIDEO_DATA_FORMAT); - return -1; - } - - while (decode) { - switch (bm[0]) { - case 0: - switch (bm[1]) { - case 0: - /* scan line end marker */ - bm += 2; - x = 0; - y--; - fbp = (unsigned char *) - ((unsigned int) video_fb_address + - (y + yoff) * VIDEO_LINE_LEN + - xoff * bpp); - continue; - case 1: - /* end of bitmap data marker */ - decode = 0; - break; - case 2: - /* run offset marker */ - x += bm[2]; - y -= bm[3]; - fbp = (unsigned char *) - ((unsigned int) video_fb_address + - (y + yoff) * VIDEO_LINE_LEN + - xoff * bpp); - bm += 4; - break; - default: - /* unencoded run */ - cnt = bm[1]; - runlen = cnt; - pixels += cnt; - if (pixels > limit) - goto error; - - bm += 2; - if (y < height) { - if (x >= width) { - x += runlen; - goto next_run; - } - if (x + runlen > width) - cnt = width - x; - draw_bitmap(&fbp, bm, p, cnt, 0); - x += runlen; - } -next_run: - bm += runlen; - if (runlen & 1) - bm++; /* 0 padding if length is odd */ - } - break; - default: - /* encoded run */ - cnt = bm[0]; - runlen = cnt; - pixels += cnt; - if (pixels > limit) - goto error; - - if (y < height) { /* only draw into visible area */ - if (x >= width) { - x += runlen; - bm += 2; - continue; - } - if (x + runlen > width) - cnt = width - x; - draw_bitmap(&fbp, bm, p, cnt, 1); - x += runlen; - } - bm += 2; - break; - } - } - - if (cfb_do_flush_cache) - flush_cache(VIDEO_FB_ADRS, VIDEO_SIZE); - - return 0; -error: - printf("Error: Too much encoded pixel data, validate your bitmap\n"); - return -1; -} -#endif - -/* - * Display the BMP file located at address bmp_image. - */ -int video_display_bitmap(ulong bmp_image, int x, int y) -{ - ushort xcount, ycount; - uchar *fb; - struct bmp_image *bmp = (struct bmp_image *)bmp_image; - uchar *bmap; - ushort padded_line; - unsigned long width, height, bpp; - unsigned colors; - unsigned long compression; - struct bmp_color_table_entry cte; - -#ifdef CONFIG_VIDEO_BMP_GZIP - unsigned char *dst = NULL; - ulong len; -#endif - - WATCHDOG_RESET(); - - if (!((bmp->header.signature[0] == 'B') && - (bmp->header.signature[1] == 'M'))) { - -#ifdef CONFIG_VIDEO_BMP_GZIP - /* - * Could be a gzipped bmp image, try to decrompress... - */ - len = CONFIG_SYS_VIDEO_LOGO_MAX_SIZE; - dst = malloc(CONFIG_SYS_VIDEO_LOGO_MAX_SIZE); - if (dst == NULL) { - printf("Error: malloc in gunzip failed!\n"); - return 1; - } - /* - * NB: we need to force offset of +2 - * See doc/README.displaying-bmps - */ - if (gunzip(dst+2, CONFIG_SYS_VIDEO_LOGO_MAX_SIZE-2, - (uchar *) bmp_image, - &len) != 0) { - printf("Error: no valid bmp or bmp.gz image at %lx\n", - bmp_image); - free(dst); - return 1; - } - if (len == CONFIG_SYS_VIDEO_LOGO_MAX_SIZE) { - printf("Image could be truncated " - "(increase CONFIG_SYS_VIDEO_LOGO_MAX_SIZE)!\n"); - } - - /* - * Set addr to decompressed image - */ - bmp = (struct bmp_image *)(dst+2); - - if (!((bmp->header.signature[0] == 'B') && - (bmp->header.signature[1] == 'M'))) { - printf("Error: no valid bmp.gz image at %lx\n", - bmp_image); - free(dst); - return 1; - } -#else - printf("Error: no valid bmp image at %lx\n", bmp_image); - return 1; -#endif /* CONFIG_VIDEO_BMP_GZIP */ - } - - width = le32_to_cpu(bmp->header.width); - height = le32_to_cpu(bmp->header.height); - bpp = le16_to_cpu(bmp->header.bit_count); - colors = le32_to_cpu(bmp->header.colors_used); - compression = le32_to_cpu(bmp->header.compression); - - debug("Display-bmp: %ld x %ld with %d colors\n", - width, height, colors); - - if (compression != BMP_BI_RGB -#ifdef CONFIG_VIDEO_BMP_RLE8 - && compression != BMP_BI_RLE8 -#endif - ) { - printf("Error: compression type %ld not supported\n", - compression); -#ifdef CONFIG_VIDEO_BMP_GZIP - if (dst) - free(dst); -#endif - return 1; - } - - padded_line = (((width * bpp + 7) / 8) + 3) & ~0x3; - -#ifdef CONFIG_SPLASH_SCREEN_ALIGN - if (x == BMP_ALIGN_CENTER) - x = max(0, (int)(VIDEO_VISIBLE_COLS - width) / 2); - else if (x < 0) - x = max(0, (int)(VIDEO_VISIBLE_COLS - width + x + 1)); - - if (y == BMP_ALIGN_CENTER) - y = max(0, (int)(VIDEO_VISIBLE_ROWS - height) / 2); - else if (y < 0) - y = max(0, (int)(VIDEO_VISIBLE_ROWS - height + y + 1)); -#endif /* CONFIG_SPLASH_SCREEN_ALIGN */ - - /* - * Just ignore elements which are completely beyond screen - * dimensions. - */ - if ((x >= VIDEO_VISIBLE_COLS) || (y >= VIDEO_VISIBLE_ROWS)) - return 0; - - if ((x + width) > VIDEO_VISIBLE_COLS) - width = VIDEO_VISIBLE_COLS - x; - if ((y + height) > VIDEO_VISIBLE_ROWS) - height = VIDEO_VISIBLE_ROWS - y; - - bmap = (uchar *) bmp + le32_to_cpu(bmp->header.data_offset); - fb = (uchar *) (video_fb_address + - ((y + height - 1) * VIDEO_LINE_LEN) + - x * VIDEO_PIXEL_SIZE); - -#ifdef CONFIG_VIDEO_BMP_RLE8 - if (compression == BMP_BI_RLE8) { - return display_rle8_bitmap(bmp, x, y, width, height); - } -#endif - - /* We handle only 4, 8, or 24 bpp bitmaps */ - switch (le16_to_cpu(bmp->header.bit_count)) { - case 4: - padded_line -= width / 2; - ycount = height; - - switch (VIDEO_DATA_FORMAT) { - case GDF_32BIT_X888RGB: - while (ycount--) { - WATCHDOG_RESET(); - /* - * Don't assume that 'width' is an - * even number - */ - for (xcount = 0; xcount < width; xcount++) { - uchar idx; - - if (xcount & 1) { - idx = *bmap & 0xF; - bmap++; - } else - idx = *bmap >> 4; - cte = bmp->color_table[idx]; - FILL_32BIT_X888RGB(cte.red, cte.green, - cte.blue); - } - bmap += padded_line; - fb -= VIDEO_LINE_LEN + width * - VIDEO_PIXEL_SIZE; - } - break; - default: - puts("4bpp bitmap unsupported with current " - "video mode\n"); - break; - } - break; - - case 8: - padded_line -= width; - if (VIDEO_DATA_FORMAT == GDF__8BIT_INDEX) { - /* Copy colormap */ - for (xcount = 0; xcount < colors; ++xcount) { - cte = bmp->color_table[xcount]; - video_set_lut(xcount, cte.red, cte.green, - cte.blue); - } - } - ycount = height; - switch (VIDEO_DATA_FORMAT) { - case GDF__8BIT_INDEX: - while (ycount--) { - WATCHDOG_RESET(); - xcount = width; - while (xcount--) { - *fb++ = *bmap++; - } - bmap += padded_line; - fb -= VIDEO_LINE_LEN + width * - VIDEO_PIXEL_SIZE; - } - break; - case GDF__8BIT_332RGB: - while (ycount--) { - WATCHDOG_RESET(); - xcount = width; - while (xcount--) { - cte = bmp->color_table[*bmap++]; - FILL_8BIT_332RGB(cte.red, cte.green, - cte.blue); - } - bmap += padded_line; - fb -= VIDEO_LINE_LEN + width * - VIDEO_PIXEL_SIZE; - } - break; - case GDF_15BIT_555RGB: - while (ycount--) { -#if defined(VIDEO_FB_16BPP_PIXEL_SWAP) - int xpos = x; -#endif - WATCHDOG_RESET(); - xcount = width; - while (xcount--) { - cte = bmp->color_table[*bmap++]; -#if defined(VIDEO_FB_16BPP_PIXEL_SWAP) - fill_555rgb_pswap(fb, xpos++, cte.red, - cte.green, - cte.blue); - fb += 2; -#else - FILL_15BIT_555RGB(cte.red, cte.green, - cte.blue); -#endif - } - bmap += padded_line; - fb -= VIDEO_LINE_LEN + width * - VIDEO_PIXEL_SIZE; - } - break; - case GDF_16BIT_565RGB: - while (ycount--) { - WATCHDOG_RESET(); - xcount = width; - while (xcount--) { - cte = bmp->color_table[*bmap++]; - FILL_16BIT_565RGB(cte.red, cte.green, - cte.blue); - } - bmap += padded_line; - fb -= VIDEO_LINE_LEN + width * - VIDEO_PIXEL_SIZE; - } - break; - case GDF_32BIT_X888RGB: - while (ycount--) { - WATCHDOG_RESET(); - xcount = width; - while (xcount--) { - cte = bmp->color_table[*bmap++]; - FILL_32BIT_X888RGB(cte.red, cte.green, - cte.blue); - } - bmap += padded_line; - fb -= VIDEO_LINE_LEN + width * - VIDEO_PIXEL_SIZE; - } - break; - case GDF_24BIT_888RGB: - while (ycount--) { - WATCHDOG_RESET(); - xcount = width; - while (xcount--) { - cte = bmp->color_table[*bmap++]; - FILL_24BIT_888RGB(cte.red, cte.green, - cte.blue); - } - bmap += padded_line; - fb -= VIDEO_LINE_LEN + width * - VIDEO_PIXEL_SIZE; - } - break; - } - break; - case 24: - padded_line -= 3 * width; - ycount = height; - switch (VIDEO_DATA_FORMAT) { - case GDF__8BIT_332RGB: - while (ycount--) { - WATCHDOG_RESET(); - xcount = width; - while (xcount--) { - FILL_8BIT_332RGB(bmap[2], bmap[1], - bmap[0]); - bmap += 3; - } - bmap += padded_line; - fb -= VIDEO_LINE_LEN + width * - VIDEO_PIXEL_SIZE; - } - break; - case GDF_15BIT_555RGB: - while (ycount--) { -#if defined(VIDEO_FB_16BPP_PIXEL_SWAP) - int xpos = x; -#endif - WATCHDOG_RESET(); - xcount = width; - while (xcount--) { -#if defined(VIDEO_FB_16BPP_PIXEL_SWAP) - fill_555rgb_pswap(fb, xpos++, bmap[2], - bmap[1], bmap[0]); - fb += 2; -#else - FILL_15BIT_555RGB(bmap[2], bmap[1], - bmap[0]); -#endif - bmap += 3; - } - bmap += padded_line; - fb -= VIDEO_LINE_LEN + width * - VIDEO_PIXEL_SIZE; - } - break; - case GDF_16BIT_565RGB: - while (ycount--) { - WATCHDOG_RESET(); - xcount = width; - while (xcount--) { - FILL_16BIT_565RGB(bmap[2], bmap[1], - bmap[0]); - bmap += 3; - } - bmap += padded_line; - fb -= VIDEO_LINE_LEN + width * - VIDEO_PIXEL_SIZE; - } - break; - case GDF_32BIT_X888RGB: - while (ycount--) { - WATCHDOG_RESET(); - xcount = width; - while (xcount--) { - FILL_32BIT_X888RGB(bmap[2], bmap[1], - bmap[0]); - bmap += 3; - } - bmap += padded_line; - fb -= VIDEO_LINE_LEN + width * - VIDEO_PIXEL_SIZE; - } - break; - case GDF_24BIT_888RGB: - while (ycount--) { - WATCHDOG_RESET(); - xcount = width; - while (xcount--) { - FILL_24BIT_888RGB(bmap[2], bmap[1], - bmap[0]); - bmap += 3; - } - bmap += padded_line; - fb -= VIDEO_LINE_LEN + width * - VIDEO_PIXEL_SIZE; - } - break; - default: - printf("Error: 24 bits/pixel bitmap incompatible " - "with current video mode\n"); - break; - } - break; - default: - printf("Error: %d bit/pixel bitmaps not supported by U-Boot\n", - le16_to_cpu(bmp->header.bit_count)); - break; - } - -#ifdef CONFIG_VIDEO_BMP_GZIP - if (dst) { - free(dst); - } -#endif - - if (cfb_do_flush_cache) - flush_cache(VIDEO_FB_ADRS, VIDEO_SIZE); - return (0); -} -#endif - -static int cfb_fb_is_in_dram(void) -{ - struct bd_info *bd = gd->bd; - ulong start, end; - int i; - - for (i = 0; i < CONFIG_NR_DRAM_BANKS; ++i) { - start = bd->bi_dram[i].start; - end = bd->bi_dram[i].start + bd->bi_dram[i].size - 1; - if ((ulong)video_fb_address >= start && - (ulong)video_fb_address < end) - return 1; - } - - return 0; -} - -void video_clear(void) -{ - if (!video_fb_address) - return; -#ifdef VIDEO_HW_RECTFILL - video_hw_rectfill(VIDEO_PIXEL_SIZE, /* bytes per pixel */ - 0, /* dest pos x */ - 0, /* dest pos y */ - VIDEO_VISIBLE_COLS, /* frame width */ - VIDEO_VISIBLE_ROWS, /* frame height */ - bgx /* fill color */ - ); -#else - memsetl(video_fb_address, - (VIDEO_VISIBLE_ROWS * VIDEO_LINE_LEN) / sizeof(int), bgx); -#endif -} - -static int cfg_video_init(void) -{ - unsigned char color8; - - pGD = video_hw_init(); - if (pGD == NULL) - return -1; - - video_fb_address = (void *) VIDEO_FB_ADRS; - - cfb_do_flush_cache = cfb_fb_is_in_dram() && dcache_status(); - - /* Init drawing pats */ - switch (VIDEO_DATA_FORMAT) { - case GDF__8BIT_INDEX: - video_set_lut(0x01, CONFIG_SYS_CONSOLE_FG_COL, - CONFIG_SYS_CONSOLE_FG_COL, - CONFIG_SYS_CONSOLE_FG_COL); - video_set_lut(0x00, CONFIG_SYS_CONSOLE_BG_COL, - CONFIG_SYS_CONSOLE_BG_COL, - CONFIG_SYS_CONSOLE_BG_COL); - fgx = 0x01010101; - bgx = 0x00000000; - break; - case GDF__8BIT_332RGB: - color8 = ((CONFIG_SYS_CONSOLE_FG_COL & 0xe0) | - ((CONFIG_SYS_CONSOLE_FG_COL >> 3) & 0x1c) | - CONFIG_SYS_CONSOLE_FG_COL >> 6); - fgx = (color8 << 24) | (color8 << 16) | (color8 << 8) | - color8; - color8 = ((CONFIG_SYS_CONSOLE_BG_COL & 0xe0) | - ((CONFIG_SYS_CONSOLE_BG_COL >> 3) & 0x1c) | - CONFIG_SYS_CONSOLE_BG_COL >> 6); - bgx = (color8 << 24) | (color8 << 16) | (color8 << 8) | - color8; - break; - case GDF_15BIT_555RGB: - fgx = (((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 26) | - ((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 21) | - ((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 16) | - ((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 10) | - ((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 5) | - (CONFIG_SYS_CONSOLE_FG_COL >> 3)); - bgx = (((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 26) | - ((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 21) | - ((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 16) | - ((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 10) | - ((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 5) | - (CONFIG_SYS_CONSOLE_BG_COL >> 3)); - break; - case GDF_16BIT_565RGB: - fgx = (((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 27) | - ((CONFIG_SYS_CONSOLE_FG_COL >> 2) << 21) | - ((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 16) | - ((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 11) | - ((CONFIG_SYS_CONSOLE_FG_COL >> 2) << 5) | - (CONFIG_SYS_CONSOLE_FG_COL >> 3)); - bgx = (((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 27) | - ((CONFIG_SYS_CONSOLE_BG_COL >> 2) << 21) | - ((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 16) | - ((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 11) | - ((CONFIG_SYS_CONSOLE_BG_COL >> 2) << 5) | - (CONFIG_SYS_CONSOLE_BG_COL >> 3)); - break; - case GDF_32BIT_X888RGB: - fgx = (CONFIG_SYS_CONSOLE_FG_COL << 16) | - (CONFIG_SYS_CONSOLE_FG_COL << 8) | - CONFIG_SYS_CONSOLE_FG_COL; - bgx = (CONFIG_SYS_CONSOLE_BG_COL << 16) | - (CONFIG_SYS_CONSOLE_BG_COL << 8) | - CONFIG_SYS_CONSOLE_BG_COL; - break; - case GDF_24BIT_888RGB: - fgx = (CONFIG_SYS_CONSOLE_FG_COL << 24) | - (CONFIG_SYS_CONSOLE_FG_COL << 16) | - (CONFIG_SYS_CONSOLE_FG_COL << 8) | - CONFIG_SYS_CONSOLE_FG_COL; - bgx = (CONFIG_SYS_CONSOLE_BG_COL << 24) | - (CONFIG_SYS_CONSOLE_BG_COL << 16) | - (CONFIG_SYS_CONSOLE_BG_COL << 8) | - CONFIG_SYS_CONSOLE_BG_COL; - break; - } - eorx = fgx ^ bgx; - - if (!CONFIG_IS_ENABLED(NO_FB_CLEAR)) - video_clear(); - -#ifdef CONFIG_VIDEO_LOGO - /* Plot the logo and get start point of console */ - debug("Video: Drawing the logo ...\n"); - video_console_address = video_logo(); -#else - video_console_address = video_fb_address; -#endif - - /* Initialize the console */ - console_col = 0; - console_row = 0; - - if (cfb_do_flush_cache) - flush_cache(VIDEO_FB_ADRS, VIDEO_SIZE); - - return 0; -} - -/* - * Implement a weak default function for boards that optionally - * need to skip the video initialization. - */ -__weak int board_video_skip(void) -{ - /* As default, don't skip test */ - return 0; -} - -int drv_video_init(void) -{ - struct stdio_dev console_dev; - bool have_keyboard; - bool __maybe_unused keyboard_ok = false; - - /* Check if video initialization should be skipped */ - if (board_video_skip()) - return 0; - - /* Init video chip - returns with framebuffer cleared */ - if (cfg_video_init() == -1) - return 0; - - if (board_cfb_skip()) - return 0; - -#if defined(CONFIG_VGA_AS_SINGLE_DEVICE) - have_keyboard = false; -#elif defined(CONFIG_OF_CONTROL) - have_keyboard = !ofnode_conf_read_bool("u-boot,no-keyboard"); -#else - have_keyboard = true; -#endif - if (have_keyboard) { - debug("KBD: Keyboard init ...\n"); -#if !defined(CONFIG_VGA_AS_SINGLE_DEVICE) - keyboard_ok = !(VIDEO_KBD_INIT_FCT == -1); -#endif - } - - /* Init vga device */ - memset(&console_dev, 0, sizeof(console_dev)); - strcpy(console_dev.name, "vga"); - console_dev.flags = DEV_FLAGS_OUTPUT; - console_dev.putc = cfb_video_putc; /* 'putc' function */ - console_dev.puts = cfb_video_puts; /* 'puts' function */ - -#if !defined(CONFIG_VGA_AS_SINGLE_DEVICE) - if (have_keyboard && keyboard_ok) { - /* Also init console device */ - console_dev.flags |= DEV_FLAGS_INPUT; - console_dev.tstc = VIDEO_TSTC_FCT; /* 'tstc' function */ - console_dev.getc = VIDEO_GETC_FCT; /* 'getc' function */ - } -#endif - - if (stdio_register(&console_dev) != 0) - return 0; - - /* Return success */ - return 1; -} - -void video_position_cursor(unsigned col, unsigned row) -{ - console_col = min(col, CONSOLE_COLS - 1); - console_row = min(row, CONSOLE_ROWS - 1); -} - -int video_get_pixel_width(void) -{ - return VIDEO_VISIBLE_COLS; -} - -int video_get_pixel_height(void) -{ - return VIDEO_VISIBLE_ROWS; -} - -int video_get_screen_rows(void) -{ - return CONSOLE_ROWS; -} - -int video_get_screen_columns(void) -{ - return CONSOLE_COLS; -} diff --git a/drivers/video/omap3_dss.c b/drivers/video/omap3_dss.c index 6efba122e78..dbd1408b6cf 100644 --- a/drivers/video/omap3_dss.c +++ b/drivers/video/omap3_dss.c @@ -137,31 +137,3 @@ void omap3_dss_enable(void) l |= LCD_ENABLE | GO_LCD | DIG_ENABLE | GO_DIG | GP_OUT0 | GP_OUT1; writel(l, &dispc->control); } - -#ifdef CONFIG_CFB_CONSOLE -int __board_video_init(void) -{ - return -1; -} - -int board_video_init(void) - __attribute__((weak, alias("__board_video_init"))); - -void *video_hw_init(void) -{ - static GraphicDevice dssfb; - GraphicDevice *pGD = &dssfb; - struct dispc_regs *dispc = (struct dispc_regs *) OMAP3_DISPC_BASE; - - if (board_video_init() || !readl(&dispc->gfx_ba0)) - return NULL; - - pGD->winSizeX = (readl(&dispc->size_lcd) & 0x7FF) + 1; - pGD->winSizeY = ((readl(&dispc->size_lcd) >> 16) & 0x7FF) + 1; - pGD->gdfBytesPP = 4; - pGD->gdfIndex = GDF_32BIT_X888RGB; - pGD->frameAdrs = readl(&dispc->gfx_ba0); - - return pGD; -} -#endif
Drop this code which uses a header that is about to be deleted.
board/nokia/rx51/rx51.c | 19 ------------------- configs/nokia_rx51_defconfig | 1 - include/configs/nokia_rx51.h | 11 ----------- 3 files changed, 31 deletions(-)
diff --git a/board/nokia/rx51/rx51.c b/board/nokia/rx51/rx51.c index 99ca36fbbea..45c569f83a3 100644 --- a/board/nokia/rx51/rx51.c +++ b/board/nokia/rx51/rx51.c @@ -30,7 +30,6 @@ #include <malloc.h> #include <twl4030.h> #include <i2c.h> -#include <video_fb.h> #include <asm/global_data.h> #include <asm/io.h> #include <asm/setup.h> @@ -61,8 +60,6 @@ struct emu_hal_params_rx51 {
-GraphicDevice gdev; - const omap3_sysinfo sysinfo = { DDR_STACKED, "Nokia RX-51", @@ -341,22 +338,6 @@ void setup_board_tags(struct tag **in_params) *in_params = params; }
-/* - * Routine: video_hw_init - * Description: Set up the GraphicDevice depending on sys_boot. - */ -void *video_hw_init(void) -{ - /* fill in Graphic Device */ - gdev.frameAdrs = 0x8f9c0000; - gdev.winSizeX = 800; - gdev.winSizeY = 480; - gdev.gdfBytesPP = 2; - gdev.gdfIndex = GDF_16BIT_565RGB; - memset((void *)gdev.frameAdrs, 0, 0xbb800); - return (void *) &gdev; -} - /* * Routine: twl4030_regulator_set_mode * Description: Set twl4030 regulator mode over i2c powerbus. diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index 71b0b95c672..0ef5a84b3f3 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -76,7 +76,6 @@ CONFIG_SPI=y CONFIG_USB=y CONFIG_USB_MUSB_UDC=y CONFIG_USB_OMAP3=y -# CONFIG_VGA_AS_SINGLE_DEVICE is not set CONFIG_SPLASH_SCREEN=y CONFIG_WATCHDOG_TIMEOUT_MSECS=31000 CONFIG_WDT=y diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index adfc055a2c9..0163f3b9852 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -70,17 +70,6 @@
#define CONFIG_SYS_ONENAND_BASE ONENAND_MAP
-/* - * Framebuffer - */ -/* Video console */ -#define VIDEO_FB_16BPP_PIXEL_SWAP -#define VIDEO_FB_16BPP_WORD_SWAP - -/* functions for cfb_console */ -#define VIDEO_KBD_INIT_FCT rx51_kp_init() -#define VIDEO_TSTC_FCT rx51_kp_tstc -#define VIDEO_GETC_FCT rx51_kp_getc #ifndef __ASSEMBLY__ struct stdio_dev; int rx51_kp_init(void);
+ Maemo
And what / where is the replacement?
- Routine: video_hw_init
- Description: Set up the GraphicDevice depending on sys_boot.
- Routine: twl4030_regulator_set_mode
- Description: Set twl4030 regulator mode over i2c powerbus.
- Framebuffer
-/* functions for cfb_console */ -#define VIDEO_KBD_INIT_FCT rx51_kp_init() -#define VIDEO_TSTC_FCT rx51_kp_tstc -#define VIDEO_GETC_FCT rx51_kp_getc #ifndef __ASSEMBLY__ struct stdio_dev; int rx51_kp_init(void); -- 2.35.0.rc0.227.g00780c9af4-goog
Hi Pali,
On Sun, 23 Jan 2022 at 07:08, Pali Rohár pali@kernel.org wrote:
- Maemo
This is DM_VIDEO. There are quite a few example drivers in drivers/video - perhaps the mxsfb.c one is a reasonable example. See the top of video_uclass.c for how frame-buffer allocation works.
On Sunday 23 January 2022 07:36:22 Simon Glass wrote:
Hi Pali,
- Maemo
I have already WIP patches for usage of video-uclass.c but because reviewing of N900 patches is slow, I have not sent them yet.
So could you please do NOT remove N900 support? I would really appreciative for reviewing pending patches instead of sending patches with board removal.
Note that there is some issue with video_post_bind(), it throws false-positive error "Video device '%s' cannot allocate frame buffer memory" with "return -ENOSPC". If I remove that "return -ENOSPC" it is working fine.
Hi Pali,
Hi Pali,
- Maemo
Who is reviewing them? If you send the patches I can review them and we can get them applied for this release.
This is not a board removal, just dropping a feature.
Do you need U-Boot to allocate the frame buffer. If so, this is likely because your driver is not bound before relocation. See the comment around that message in the code.
Hello!
On Sunday 23 January 2022 08:54:24 Simon Glass wrote:
Hi Pali,
Hi Pali,
- Maemo
Lokesh is reviewing omap3 and n900 patches.
I have already wrote in other thread I do not want to send too many patches if I see that review process is slow. And also because I totally lost the track what was send, what was not and what depends on what. And I do not want to work on too many things in paralel if I see that it took half year or more to make patches in acceptable form.
... feature which is essential and without which board is unusable.
I did not spend too much time for investigation. I just saw that removing that comment and returning makes it fully working.
Hi Pali,
On Sun, 23 Jan 2022 at 09:01, Pali Rohár pali@kernel.org wrote:
Hello!
Hi Pali,
Hi Pali,
- Maemo
Sure, but it is indicating a bug, so needs to be figured out. If you read the top of video-uclass.c you can probably see what is going on.
Drop this old code which is not built anymore, as it depends on CONFIG_VIDEO which has been removed.
board/siemens/common/board.c | 3 - board/siemens/common/factoryset.c | 7 - board/siemens/common/factoryset.h | 3 - board/siemens/pxm2/board.c | 189 ----------------------- board/siemens/rut/board.c | 247 ------------------------------ 5 files changed, 449 deletions(-)
diff --git a/board/siemens/common/board.c b/board/siemens/common/board.c index 56283660d37..85025f20efa 100644 --- a/board/siemens/common/board.c +++ b/board/siemens/common/board.c @@ -96,9 +96,6 @@ int board_init(void) #ifdef CONFIG_NAND_CS_INIT board_nand_cs_init(); #endif -#ifdef CONFIG_VIDEO - board_video_init(); -#endif
return 0; } diff --git a/board/siemens/common/factoryset.c b/board/siemens/common/factoryset.c index fba678b4260..4e36a6f3199 100644 --- a/board/siemens/common/factoryset.c +++ b/board/siemens/common/factoryset.c @@ -275,13 +275,6 @@ int factoryset_read_eeprom(int i2c_addr) } printf("DFU USB: VID = 0x%4x, PID = 0x%4x\n", factory_dat.usb_vendor_id, factory_dat.usb_product_id); -#endif -#if defined(CONFIG_VIDEO) - if (0 <= get_factory_record_val(cp, size, (uchar *)"DISP1", - (uchar *)"name", factory_dat.disp_name, - MAX_STRING_LENGTH)) { - debug("display name: %s\n", factory_dat.disp_name); - } #endif if (0 <= get_factory_record_val(cp, size, (uchar *)"DEV", (uchar *)"num", factory_dat.serial, diff --git a/board/siemens/common/factoryset.h b/board/siemens/common/factoryset.h index 261a2176879..8fa6c3b3d3b 100644 --- a/board/siemens/common/factoryset.h +++ b/board/siemens/common/factoryset.h @@ -17,9 +17,6 @@ struct factorysetcontainer { int usb_vendor_id; int usb_product_id; int pxm50; -#if defined(CONFIG_VIDEO) - unsigned char disp_name[MAX_STRING_LENGTH]; -#endif unsigned char serial[MAX_STRING_LENGTH]; int version; uchar asn[MAX_STRING_LENGTH]; diff --git a/board/siemens/pxm2/board.c b/board/siemens/pxm2/board.c index de52838d771..47f19bcb8fd 100644 --- a/board/siemens/pxm2/board.c +++ b/board/siemens/pxm2/board.c @@ -28,7 +28,6 @@ #include <asm/arch/gpio.h> #include <asm/arch/mmc_host_def.h> #include <asm/arch/sys_proto.h> -#include "../../../drivers/video/da8xx-fb.h" #include <asm/io.h> #include <asm/emif.h> #include <asm/gpio.h> @@ -243,194 +242,6 @@ int board_eth_init(struct bd_info *bis) } #endif /* #if defined(CONFIG_DRIVER_TI_CPSW) */
-#if defined(CONFIG_VIDEO) && !defined(CONFIG_SPL_BUILD) -static struct da8xx_panel lcd_panels[] = { - /* AUO G156XW01 V1 */ - [0] = { - .name = "AUO_G156XW01_V1", - .width = 1376, - .height = 768, - .hfp = 14, - .hbp = 64, - .hsw = 56, - .vfp = 1, - .vbp = 28, - .vsw = 3, - .pxl_clk = 60000000, - .invert_pxl_clk = 0, - }, - /* AUO B101EVN06 V0 */ - [1] = { - .name = "AUO_B101EVN06_V0", - .width = 1280, - .height = 800, - .hfp = 52, - .hbp = 84, - .hsw = 36, - .vfp = 3, - .vbp = 14, - .vsw = 6, - .pxl_clk = 60000000, - .invert_pxl_clk = 0, - }, - /* - * Settings from factoryset - * stored in EEPROM - */ - [2] = { - .name = "factoryset", - .width = 0, - .height = 0, - .hfp = 0, - .hbp = 0, - .hsw = 0, - .vfp = 0, - .vbp = 0, - .vsw = 0, - .pxl_clk = 60000000, - .invert_pxl_clk = 0, - }, -}; - -static const struct display_panel disp_panel = { - WVGA, - 32, - 16, - COLOR_ACTIVE, -}; - -static const struct lcd_ctrl_config lcd_cfg = { - &disp_panel, - .ac_bias = 255, - .ac_bias_intrpt = 0, - .dma_burst_sz = 16, - .bpp = 32, - .fdd = 0x80, - .tft_alt_mode = 0, - .stn_565_mode = 0, - .mono_8bit_mode = 0, - .invert_line_clock = 1, - .invert_frm_clock = 1, - .sync_edge = 0, - .sync_ctrl = 1, - .raster_order = 0, -}; - -static int set_gpio(int gpio, int state) -{ - gpio_request(gpio, "temp"); - gpio_direction_output(gpio, state); - gpio_set_value(gpio, state); - gpio_free(gpio); - return 0; -} - -static int enable_backlight(void) -{ - set_gpio(BOARD_LCD_POWER, 1); - set_gpio(BOARD_BACK_LIGHT, 1); - set_gpio(BOARD_TOUCH_POWER, 1); - return 0; -} - -static int enable_pwm(void) -{ - struct pwmss_regs *pwmss = (struct pwmss_regs *)PWMSS0_BASE; - struct pwmss_ecap_regs *ecap; - int ticks = PWM_TICKS; - int duty = PWM_DUTY; - - ecap = (struct pwmss_ecap_regs *)AM33XX_ECAP0_BASE; - /* enable clock */ - setbits_le32(&pwmss->clkconfig, ECAP_CLK_EN); - /* TimeStam Counter register */ - writel(0xdb9, &ecap->tsctr); - /* config period */ - writel(ticks - 1, &ecap->cap3); - writel(ticks - 1, &ecap->cap1); - setbits_le16(&ecap->ecctl2, - (ECTRL2_MDSL_ECAP | ECTRL2_SYNCOSEL_MASK | 0xd0)); - /* config duty */ - writel(duty, &ecap->cap2); - writel(duty, &ecap->cap4); - /* start */ - setbits_le16(&ecap->ecctl2, ECTRL2_CTRSTP_FREERUN); - return 0; -} - -static struct dpll_regs dpll_lcd_regs = { - .cm_clkmode_dpll = CM_WKUP + 0x98, - .cm_idlest_dpll = CM_WKUP + 0x48, - .cm_clksel_dpll = CM_WKUP + 0x54, -}; - -/* no console on this board */ -int board_cfb_skip(void) -{ - return 1; -} - -#define PLL_GET_M(v) ((v >> 8) & 0x7ff) -#define PLL_GET_N(v) (v & 0x7f) - -static int get_clk(struct dpll_regs *dpll_regs) -{ - unsigned int val; - unsigned int m, n; - int f = 0; - - val = readl(dpll_regs->cm_clksel_dpll); - m = PLL_GET_M(val); - n = PLL_GET_N(val); - f = (m * V_OSCK) / n; - - return f; -}; - -int clk_get(int clk) -{ - return get_clk(&dpll_lcd_regs); -}; - -static int conf_disp_pll(int m, int n) -{ - struct cm_perpll *cmper = (struct cm_perpll *)CM_PER; - struct cm_dpll *cmdpll = (struct cm_dpll *)CM_DPLL; - struct dpll_params dpll_lcd = {m, n, -1, -1, -1, -1, -1}; - - u32 *const clk_domains[] = { - &cmper->lcdclkctrl, - 0 - }; - u32 *const clk_modules_explicit_en[] = { - &cmper->lcdclkctrl, - &cmper->lcdcclkstctrl, - &cmper->epwmss0clkctrl, - 0 - }; - do_enable_clocks(clk_domains, clk_modules_explicit_en, 1); - writel(0x0, &cmdpll->clklcdcpixelclk); - - do_setup_dpll(&dpll_lcd_regs, &dpll_lcd); - - return 0; -} - -static int board_video_init(void) -{ - conf_disp_pll(24, 1); - if (factory_dat.pxm50) - da8xx_video_init(&lcd_panels[0], &lcd_cfg, lcd_cfg.bpp); - else - da8xx_video_init(&lcd_panels[1], &lcd_cfg, lcd_cfg.bpp); - - enable_pwm(); - enable_backlight(); - - return 0; -} -#endif - #ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) { diff --git a/board/siemens/rut/board.c b/board/siemens/rut/board.c index e0f232d3b80..a8b196a65c9 100644 --- a/board/siemens/rut/board.c +++ b/board/siemens/rut/board.c @@ -37,7 +37,6 @@ #include <linux/delay.h> #include "board.h" #include "../common/factoryset.h" -#include "../../../drivers/video/da8xx-fb.h"
/* * Read header information from EEPROM into global structure. @@ -224,252 +223,6 @@ void hw_watchdog_init(void) } #endif /* defined(CONFIG_HW_WATCHDOG) */
-#if defined(CONFIG_VIDEO) && !defined(CONFIG_SPL_BUILD) -static struct da8xx_panel lcd_panels[] = { - /* FORMIKE, 4.3", 480x800, KWH043MC17-F01 */ - [0] = { - .name = "KWH043MC17-F01", - .width = 480, - .height = 800, - .hfp = 50, /* no spec, "don't care" values */ - .hbp = 50, - .hsw = 50, - .vfp = 50, - .vbp = 50, - .vsw = 50, - .pxl_clk = 35910000, /* tCYCD=20ns, max 50MHz, 60fps */ - .invert_pxl_clk = 1, - }, - /* FORMIKE, 4.3", 480x800, KWH043ST20-F01 */ - [1] = { - .name = "KWH043ST20-F01", - .width = 480, - .height = 800, - .hfp = 50, /* no spec, "don't care" values */ - .hbp = 50, - .hsw = 50, - .vfp = 50, - .vbp = 50, - .vsw = 50, - .pxl_clk = 35910000, /* tCYCD=20ns, max 50MHz, 60fps */ - .invert_pxl_clk = 1, - }, - /* Multi-Inno, 4.3", 480x800, MI0430VT-1 */ - [2] = { - .name = "MI0430VT-1", - .width = 480, - .height = 800, - .hfp = 50, /* no spec, "don't care" values */ - .hbp = 50, - .hsw = 50, - .vfp = 50, - .vbp = 50, - .vsw = 50, - .pxl_clk = 35910000, /* tCYCD=20ns, max 50MHz, 60fps */ - .invert_pxl_clk = 1, - }, -}; - -static const struct display_panel disp_panels[] = { - [0] = { - WVGA, - 16, /* RGB 888 */ - 16, - COLOR_ACTIVE, - }, - [1] = { - WVGA, - 16, /* RGB 888 */ - 16, - COLOR_ACTIVE, - }, - [2] = { - WVGA, - 24, /* RGB 888 */ - 16, - COLOR_ACTIVE, - }, -}; - -static const struct lcd_ctrl_config lcd_cfgs[] = { - [0] = { - &disp_panels[0], - .ac_bias = 255, - .ac_bias_intrpt = 0, - .dma_burst_sz = 16, - .bpp = 16, - .fdd = 0x80, - .tft_alt_mode = 0, - .stn_565_mode = 0, - .mono_8bit_mode = 0, - .invert_line_clock = 1, - .invert_frm_clock = 1, - .sync_edge = 0, - .sync_ctrl = 1, - .raster_order = 0, - }, - [1] = { - &disp_panels[1], - .ac_bias = 255, - .ac_bias_intrpt = 0, - .dma_burst_sz = 16, - .bpp = 16, - .fdd = 0x80, - .tft_alt_mode = 0, - .stn_565_mode = 0, - .mono_8bit_mode = 0, - .invert_line_clock = 1, - .invert_frm_clock = 1, - .sync_edge = 0, - .sync_ctrl = 1, - .raster_order = 0, - }, - [2] = { - &disp_panels[2], - .ac_bias = 255, - .ac_bias_intrpt = 0, - .dma_burst_sz = 16, - .bpp = 24, - .fdd = 0x80, - .tft_alt_mode = 0, - .stn_565_mode = 0, - .mono_8bit_mode = 0, - .invert_line_clock = 1, - .invert_frm_clock = 1, - .sync_edge = 0, - .sync_ctrl = 1, - .raster_order = 0, - }, - -}; - -/* no console on this board */ -int board_cfb_skip(void) -{ - return 1; -} - -#define PLL_GET_M(v) ((v >> 8) & 0x7ff) -#define PLL_GET_N(v) (v & 0x7f) - -static struct dpll_regs dpll_lcd_regs = { - .cm_clkmode_dpll = CM_WKUP + 0x98, - .cm_idlest_dpll = CM_WKUP + 0x48, - .cm_clksel_dpll = CM_WKUP + 0x54, -}; - -static int get_clk(struct dpll_regs *dpll_regs) -{ - unsigned int val; - unsigned int m, n; - int f = 0; - - val = readl(dpll_regs->cm_clksel_dpll); - m = PLL_GET_M(val); - n = PLL_GET_N(val); - f = (m * V_OSCK) / n; - - return f; -}; - -int clk_get(int clk) -{ - return get_clk(&dpll_lcd_regs); -}; - -static int conf_disp_pll(int m, int n) -{ - struct cm_perpll *cmper = (struct cm_perpll *)CM_PER; - struct dpll_params dpll_lcd = {m, n, -1, -1, -1, -1, -1}; -#if defined(DISPL_PLL_SPREAD_SPECTRUM) - struct cm_wkuppll *cmwkup = (struct cm_wkuppll *)CM_WKUP; -#endif - - u32 *const clk_domains[] = { - &cmper->lcdclkctrl, - 0 - }; - u32 *const clk_modules_explicit_en[] = { - &cmper->lcdclkctrl, - &cmper->lcdcclkstctrl, - &cmper->spi1clkctrl, - 0 - }; - do_enable_clocks(clk_domains, clk_modules_explicit_en, 1); - - do_setup_dpll(&dpll_lcd_regs, &dpll_lcd); - -#if defined(DISPL_PLL_SPREAD_SPECTRUM) - writel(0x64, &cmwkup->resv6[3]); /* 0x50 */ - writel(0x800, &cmwkup->resv6[2]); /* 0x4c */ - writel(readl(&cmwkup->clkmoddplldisp) | CM_CLKMODE_DPLL_SSC_EN_MASK, - &cmwkup->clkmoddplldisp); /* 0x98 */ -#endif - return 0; -} - -static int set_gpio(int gpio, int state) -{ - gpio_request(gpio, "temp"); - gpio_direction_output(gpio, state); - gpio_set_value(gpio, state); - gpio_free(gpio); - return 0; -} - -static int enable_lcd(void) -{ - unsigned char buf[1]; - - set_gpio(BOARD_LCD_RESET, 0); - mdelay(1); - set_gpio(BOARD_LCD_RESET, 1); - mdelay(1); - - /* spi lcd init */ - kwh043st20_f01_spi_startup(1, 0, 5000000, SPI_MODE_0); - - /* backlight on */ - buf[0] = 0xf; - i2c_write(0x24, 0x7, 1, buf, 1); - buf[0] = 0x3f; - i2c_write(0x24, 0x8, 1, buf, 1); - return 0; -} - -int arch_early_init_r(void) -{ - enable_lcd(); - return 0; -} - -static int board_video_init(void) -{ - int i; - int anzdisp = ARRAY_SIZE(lcd_panels); - int display = 1; - - for (i = 0; i < anzdisp; i++) { - if (strncmp((const char *)factory_dat.disp_name, - lcd_panels[i].name, - strlen((const char *)factory_dat.disp_name)) == 0) { - printf("DISPLAY: %s\n", factory_dat.disp_name); - break; - } - } - if (i == anzdisp) { - i = 1; - printf("%s: %s not found, using default %s\n", __func__, - factory_dat.disp_name, lcd_panels[i].name); - } - conf_disp_pll(24, 1); - da8xx_video_init(&lcd_panels[display], &lcd_cfgs[display], - lcd_cfgs[display].bpp); - - return 0; -} -#endif /* ifdef CONFIG_VIDEO */ - #ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) {
Unfortunately this driver uses the old video structure to store things. This is not supported with driver model.
Drop the old code and comment out the other pieces, so the maintainer can take a look.
arch/arm/mach-nexell/include/mach/display_dev.h | 4 ++-- drivers/video/nexell_display.c | 14 +++----------- 2 files changed, 5 insertions(+), 13 deletions(-)
diff --git a/arch/arm/mach-nexell/include/mach/display_dev.h b/arch/arm/mach-nexell/include/mach/display_dev.h index 77eb614768c..0dd96f67957 100644 --- a/arch/arm/mach-nexell/include/mach/display_dev.h +++ b/arch/arm/mach-nexell/include/mach/display_dev.h @@ -15,8 +15,8 @@ #endif
struct nx_display_dev { -#if defined CONFIG_VIDEO || defined CONFIG_DM_VIDEO - GraphicDevice graphic_device; +#if defined CONFIG_DM_VIDEO + /* GraphicDevice graphic_device; -- not defined anymore */ #elif defined CONFIG_LCD vidinfo_t *panel_info; #endif diff --git a/drivers/video/nexell_display.c b/drivers/video/nexell_display.c index c7621ef49c5..a0bd44c8b84 100644 --- a/drivers/video/nexell_display.c +++ b/drivers/video/nexell_display.c @@ -537,7 +537,6 @@ static int nx_display_probe(struct udevice *dev) struct video_uc_plat *uc_plat = dev_get_uclass_plat(dev); struct video_priv *uc_priv = dev_get_uclass_priv(dev); struct nx_display_plat *plat = dev_get_plat(dev); - static GraphicDevice *graphic_device; char addr[64];
debug("%s()\n", __func__); @@ -564,7 +563,7 @@ static int nx_display_probe(struct udevice *dev) }
struct nx_display_dev *dp; - unsigned int pp_index = 0; + /* unsigned int pp_index = 0; */
dp = nx_display_setup(); if (!dp) { @@ -574,6 +573,7 @@ static int nx_display_probe(struct udevice *dev) }
switch (dp->depth) { +#if 0 /* GDF_16BIT_565RGB is not defined in video.h */ case 2: pp_index = GDF_16BIT_565RGB; uc_priv->bpix = VIDEO_BPP16; @@ -586,6 +586,7 @@ static int nx_display_probe(struct udevice *dev) pp_index = GDF_32BIT_X888RGB; uc_priv->bpix = VIDEO_BPP32; break; +#endif default: printf("fail : not support LCD bit per pixel %d\n", dp->depth * 8); @@ -596,15 +597,6 @@ static int nx_display_probe(struct udevice *dev) uc_priv->ysize = dp->fb_plane->height; uc_priv->rot = 0;
- graphic_device = &dp->graphic_device; - graphic_device->frameAdrs = dp->fb_addr; - graphic_device->gdfIndex = pp_index; - graphic_device->gdfBytesPP = dp->depth; - graphic_device->winSizeX = dp->fb_plane->width; - graphic_device->winSizeY = dp->fb_plane->height; - graphic_device->plnSizeX = - graphic_device->winSizeX * graphic_device->gdfBytesPP; - /* * set environment variable "fb_addr" (frame buffer address), required * for splash image. Because drv_video_init() in common/stdio.c is only
Hi Simon,
please find below the patch of your patch 04/14 (diff after applying your hole patch-series and my changes).
diff --git a/arch/arm/mach-nexell/include/mach/display_dev.h b/arch/arm/mach-nexell/include/mach/display_dev.h index 39b28ca1..f24fb173 100644 --- a/arch/arm/mach-nexell/include/mach/display_dev.h +++ b/arch/arm/mach-nexell/include/mach/display_dev.h @@ -8,15 +8,12 @@ #ifndef _NX__DISPLAY_DEV_H_ #define _NX__DISPLAY_DEV_H_
-#if defined CONFIG_DM_VIDEO -#elif defined CONFIG_LCD +#if !defined(CONFIG_DM_VIDEO) && defined(CONFIG_LCD) #include <lcd.h> #endif
struct nx_display_dev { -#if defined CONFIG_DM_VIDEO - /* GraphicDevice graphic_device; -- not defined anymore */ -#elif defined CONFIG_LCD +#if !defined(CONFIG_DM_VIDEO) && defined(CONFIG_LCD) vidinfo_t *panel_info; #endif unsigned long base;
diff --git a/drivers/video/nexell_display.c b/drivers/video/nexell_display.c index 2179e413..090fd6ea 100644 --- a/drivers/video/nexell_display.c +++ b/drivers/video/nexell_display.c @@ -562,7 +562,6 @@ static int nx_display_probe(struct udevice *dev) }
struct nx_display_dev *dp; - /* unsigned int pp_index = 0; */
dp = nx_display_setup(); if (!dp) { @@ -572,9 +571,7 @@ static int nx_display_probe(struct udevice *dev) }
switch (dp->depth) { -#if 0 /* GDF_16BIT_565RGB is not defined in video.h */ case 2: - pp_index = GDF_16BIT_565RGB; uc_priv->bpix = VIDEO_BPP16; break; case 3: @@ -582,10 +579,8 @@ static int nx_display_probe(struct udevice *dev) * type video_log2_bpp */ case 4: - pp_index = GDF_32BIT_X888RGB; uc_priv->bpix = VIDEO_BPP32; break; -#endif default: printf("fail : not support LCD bit per pixel %d\n", dp->depth * 8);
Regards Stefan
- /* GraphicDevice graphic_device; -- not defined anymore */ #elif defined CONFIG_LCD vidinfo_t *panel_info; #endif
- set environment variable "fb_addr" (frame buffer address), required
- for splash image. Because drv_video_init() in common/stdio.c is only
Hi Stefan,
On Mon, 31 Jan 2022 at 09:58, Stefan Bosch stefan_b@posteo.net wrote:
Hi Simon,
OK, let's see where this all goes. Once it is applied it will be clearer.
This is not used now. Drop it.
.../mach-nexell/include/mach/display_dev.h | 1 - board/aristainetos/aristainetos.c | 1 - board/freescale/t104xrdb/diu.c | 1 - board/socrates/socrates.c | 1 - drivers/pci/pci_rom.c | 1 - drivers/video/da8xx-fb.c | 1 - drivers/video/fsl_dcu_fb.c | 1 - drivers/video/fsl_diu_fb.c | 1 - drivers/video/imx/mxc_ipuv3_fb.c | 1 - drivers/video/mxsfb.c | 1 - drivers/video/nexell_display.c | 1 - drivers/video/omap3_dss.c | 1 - drivers/video/sunxi/sunxi_display.c | 1 - include/video_fb.h | 91 ------------------- 14 files changed, 104 deletions(-) delete mode 100644 include/video_fb.h
diff --git a/arch/arm/mach-nexell/include/mach/display_dev.h b/arch/arm/mach-nexell/include/mach/display_dev.h index 0dd96f67957..ffa45518d99 100644 --- a/arch/arm/mach-nexell/include/mach/display_dev.h +++ b/arch/arm/mach-nexell/include/mach/display_dev.h @@ -9,7 +9,6 @@ #define _NX__DISPLAY_DEV_H_
#if defined CONFIG_VIDEO || defined CONFIG_DM_VIDEO -#include <video_fb.h> #elif defined CONFIG_LCD #include <lcd.h> #endif diff --git a/board/aristainetos/aristainetos.c b/board/aristainetos/aristainetos.c index f13fa116374..19af59606da 100644 --- a/board/aristainetos/aristainetos.c +++ b/board/aristainetos/aristainetos.c @@ -39,7 +39,6 @@ #include <power/regulator.h> #include <power/da9063_pmic.h> #include <splash.h> -#include <video_fb.h>
DECLARE_GLOBAL_DATA_PTR;
diff --git a/board/freescale/t104xrdb/diu.c b/board/freescale/t104xrdb/diu.c index 25c8597202a..022d329713e 100644 --- a/board/freescale/t104xrdb/diu.c +++ b/board/freescale/t104xrdb/diu.c @@ -10,7 +10,6 @@ #include <command.h> #include <fsl_diu_fb.h> #include <linux/ctype.h> -#include <video_fb.h>
#include "../common/diu_ch7301.h"
diff --git a/board/socrates/socrates.c b/board/socrates/socrates.c index f6a3cc1793c..3430a1ed017 100644 --- a/board/socrates/socrates.c +++ b/board/socrates/socrates.c @@ -26,7 +26,6 @@ #include <fdt_support.h> #include <asm/io.h> #include <i2c.h> -#include <video_fb.h> #include "upm_table.h"
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/pci/pci_rom.c b/drivers/pci/pci_rom.c index f8b193058a3..73d15e797fc 100644 --- a/drivers/pci/pci_rom.c +++ b/drivers/pci/pci_rom.c @@ -36,7 +36,6 @@ #include <pci_rom.h> #include <vbe.h> #include <video.h> -#include <video_fb.h> #include <acpi/acpi_s3.h> #include <asm/global_data.h> #include <linux/screen_info.h> diff --git a/drivers/video/da8xx-fb.c b/drivers/video/da8xx-fb.c index 462c318126d..db9a820377d 100644 --- a/drivers/video/da8xx-fb.c +++ b/drivers/video/da8xx-fb.c @@ -16,7 +16,6 @@ #include <log.h> #include <malloc.h> #include <memalign.h> -#include <video_fb.h> #include <asm/global_data.h> #include <linux/delay.h> #include <linux/list.h> diff --git a/drivers/video/fsl_dcu_fb.c b/drivers/video/fsl_dcu_fb.c index dc5b24c98bb..b8bd4727c96 100644 --- a/drivers/video/fsl_dcu_fb.c +++ b/drivers/video/fsl_dcu_fb.c @@ -17,7 +17,6 @@ #include <linux/fb.h> #include <malloc.h> #include <video.h> -#include <video_fb.h> #include "videomodes.h"
/* Convert the X,Y resolution pair into a single number */ diff --git a/drivers/video/fsl_diu_fb.c b/drivers/video/fsl_diu_fb.c index 2c21e293a2c..6e335b5f43d 100644 --- a/drivers/video/fsl_diu_fb.c +++ b/drivers/video/fsl_diu_fb.c @@ -12,7 +12,6 @@ #include <asm/io.h>
#include "videomodes.h" -#include <video_fb.h> #include <fsl_diu_fb.h> #include <linux/list.h> #include <linux/fb.h> diff --git a/drivers/video/imx/mxc_ipuv3_fb.c b/drivers/video/imx/mxc_ipuv3_fb.c index 98228f2ad67..49bbeefdd8e 100644 --- a/drivers/video/imx/mxc_ipuv3_fb.c +++ b/drivers/video/imx/mxc_ipuv3_fb.c @@ -22,7 +22,6 @@ #include <asm/io.h> #include <asm/mach-imx/video.h> #include <malloc.h> -#include <video_fb.h> #include "../videomodes.h" #include "ipu.h" #include "mxcfb.h" diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c index 5f85c0c3eb7..99a15e0c25d 100644 --- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -15,7 +15,6 @@ #include <linux/errno.h> #include <malloc.h> #include <video.h> -#include <video_fb.h>
#include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> diff --git a/drivers/video/nexell_display.c b/drivers/video/nexell_display.c index a0bd44c8b84..0a9cea680fd 100644 --- a/drivers/video/nexell_display.c +++ b/drivers/video/nexell_display.c @@ -16,7 +16,6 @@ #include <linux/compat.h> #include <linux/err.h> #include <video.h> /* For struct video_uc_plat */ -#include <video_fb.h> #include <lcd.h> #include <asm/global_data.h> #include <asm/io.h> diff --git a/drivers/video/omap3_dss.c b/drivers/video/omap3_dss.c index dbd1408b6cf..432b16bfbfe 100644 --- a/drivers/video/omap3_dss.c +++ b/drivers/video/omap3_dss.c @@ -28,7 +28,6 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/dss.h> -#include <video_fb.h>
/* Configure VENC for a given Mode (NTSC / PAL) */ void omap3_dss_venc_config(const struct venc_regs *venc_cfg, diff --git a/drivers/video/sunxi/sunxi_display.c b/drivers/video/sunxi/sunxi_display.c index 5a21f7af668..2ee6212c58d 100644 --- a/drivers/video/sunxi/sunxi_display.c +++ b/drivers/video/sunxi/sunxi_display.c @@ -30,7 +30,6 @@ #include <i2c.h> #include <malloc.h> #include <video.h> -#include <video_fb.h> #include <dm/uclass-internal.h> #include "../videomodes.h" #include "../anx9804.h" diff --git a/include/video_fb.h b/include/video_fb.h deleted file mode 100644 index e4102265949..00000000000 --- a/include/video_fb.h +++ /dev/null @@ -1,91 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 1997-2002 ELTEC Elektronik AG - * Frank Gottschling fgottschling@eltec.de - */ - -/* - * smiLynxEM.h - * Silicon Motion graphic interface for sm810/sm710/sm712 accelerator - * - * - * modification history - * -------------------- - * 04-18-2002 Rewritten for U-Boot fgottschling@eltec.de. - */ - -#ifndef _VIDEO_FB_H_ -#define _VIDEO_FB_H_ - -/* - * Graphic Data Format (GDF) bits for VIDEO_DATA_FORMAT - */ -#define GDF__8BIT_INDEX 0 -#define GDF_15BIT_555RGB 1 -#define GDF_16BIT_565RGB 2 -#define GDF_32BIT_X888RGB 3 -#define GDF_24BIT_888RGB 4 -#define GDF__8BIT_332RGB 5 - -/******************************************************************************/ -/* Export Graphic Driver Control */ -/******************************************************************************/ - -typedef struct graphic_device { - unsigned int isaBase; - unsigned int pciBase; - unsigned int dprBase; - unsigned int vprBase; - unsigned int cprBase; - unsigned int frameAdrs; - unsigned int memSize; - unsigned int mode; - unsigned int gdfIndex; - unsigned int gdfBytesPP; - unsigned int fg; - unsigned int bg; - unsigned int plnSizeX; - unsigned int plnSizeY; - unsigned int winSizeX; - unsigned int winSizeY; - char modeIdent[80]; -} GraphicDevice; - - -/******************************************************************************/ -/* Export Graphic Functions */ -/******************************************************************************/ - -void *video_hw_init (void); /* returns GraphicDevice struct or NULL */ - -#ifdef VIDEO_HW_BITBLT -void video_hw_bitblt ( - unsigned int bpp, /* bytes per pixel */ - unsigned int src_x, /* source pos x */ - unsigned int src_y, /* source pos y */ - unsigned int dst_x, /* dest pos x */ - unsigned int dst_y, /* dest pos y */ - unsigned int dim_x, /* frame width */ - unsigned int dim_y /* frame height */ - ); -#endif - -#ifdef VIDEO_HW_RECTFILL -void video_hw_rectfill ( - unsigned int bpp, /* bytes per pixel */ - unsigned int dst_x, /* dest pos x */ - unsigned int dst_y, /* dest pos y */ - unsigned int dim_x, /* frame width */ - unsigned int dim_y, /* frame height */ - unsigned int color /* fill color */ - ); -#endif - -void video_set_lut ( - unsigned int index, /* color number */ - unsigned char r, /* red */ - unsigned char g, /* green */ - unsigned char b /* blue */ - ); - -#endif /*_VIDEO_FB_H_ */
This option is not implemented anymore. Drop it.
README | 1 - include/configs/T102xRDB.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/apalis_imx6.h | 1 - include/configs/aristainetos2.h | 1 - include/configs/cm_fx6.h | 2 -- include/configs/colibri-imx6ull.h | 1 - include/configs/colibri_imx6.h | 1 - include/configs/colibri_imx7.h | 4 ---- include/configs/colibri_vf.h | 1 - include/configs/embestmx6boards.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/imx6-engicam.h | 2 -- include/configs/imxrt1050-evk.h | 2 -- include/configs/ls1021aqds.h | 2 -- include/configs/ls1021atwr.h | 2 -- include/configs/mx6cuboxi.h | 1 - include/configs/mx6sabre_common.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/mx6ul_14x14_evk.h | 1 - include/configs/mx7dsabresd.h | 4 ---- include/configs/opos6uldev.h | 1 - include/configs/pico-imx6.h | 1 - include/configs/pico-imx6ul.h | 1 - include/configs/pico-imx7d.h | 4 ---- include/configs/pxm2.h | 1 - include/configs/rut.h | 1 - include/configs/wandboard.h | 1 - scripts/config_whitelist.txt | 1 - 29 files changed, 43 deletions(-)
diff --git a/README b/README index 4fa369c4dd8..816d9c4dfb2 100644 --- a/README +++ b/README @@ -1016,7 +1016,6 @@ The following options need to be configured: CONFIG_VIDEO CONFIG_VIDEO_SW_CURSOR CONFIG_VGA_AS_SINGLE_DEVICE - CONFIG_VIDEO_BMP_LOGO
The DIU driver will look for the 'video-mode' environment variable, and if defined, enable the DIU as a console during diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index d24cfce8b3b..71c96102dd4 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -372,7 +372,6 @@ #undef CONFIG_FSL_DIU_FB /* RDB doesn't support DIU */ #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) -#define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS /* * With CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS, flash I/O is really slow, so diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index f60010f7876..0a8694f186e 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -361,7 +361,6 @@ #ifdef CONFIG_FSL_DIU_FB #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) -#define CONFIG_VIDEO_BMP_LOGO #endif #endif
diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index c165f618be9..0a4ad980801 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -45,7 +45,6 @@ #define CONFIG_USBD_HS
/* Framebuffer and LCD */ -#define CONFIG_VIDEO_BMP_LOGO #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP
diff --git a/include/configs/aristainetos2.h b/include/configs/aristainetos2.h index e6397378e45..14163ae8b81 100644 --- a/include/configs/aristainetos2.h +++ b/include/configs/aristainetos2.h @@ -443,7 +443,6 @@ /* Framebuffer */ /* check this console not needed, after test remove it */ #define CONFIG_IMX_VIDEO_SKIP -#define CONFIG_VIDEO_BMP_LOGO
#define CONFIG_IMX6_PWM_PER_CLK 66000000
diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index 40bc8215480..df9c7d37221 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -176,8 +176,6 @@ /* Display */ #define CONFIG_IMX_HDMI
-#define CONFIG_VIDEO_BMP_LOGO - /* EEPROM */
#endif /* __CONFIG_CM_FX6_H */ diff --git a/include/configs/colibri-imx6ull.h b/include/configs/colibri-imx6ull.h index 787fe33941b..db8807a5569 100644 --- a/include/configs/colibri-imx6ull.h +++ b/include/configs/colibri-imx6ull.h @@ -164,7 +164,6 @@
#if defined(CONFIG_DM_VIDEO) #define MXS_LCDIF_BASE MX6UL_LCDIF1_BASE_ADDR -#define CONFIG_VIDEO_BMP_LOGO #endif
#endif /* __COLIBRI_IMX6ULL_CONFIG_H */ diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index c8e733bc366..d03263c96c6 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -35,7 +35,6 @@ #define CONFIG_USBD_HS
diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index faf27ba4fa3..876e2d84884 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -196,8 +196,4 @@
-#if defined(CONFIG_DM_VIDEO) -#define CONFIG_VIDEO_BMP_LOGO -#endif - #endif diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index 62f85185b76..3711e429a70 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -15,7 +15,6 @@ #include <linux/sizes.h>
#ifdef CONFIG_VIDEO_FSL_DCU_FB -#define CONFIG_VIDEO_BMP_LOGO #define CONFIG_SYS_FSL_DCU_LE
#define CONFIG_SYS_DCU_ADDR DCU0_BASE_ADDR diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 8ac92e480e0..f8e5c058114 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -52,7 +52,6 @@ #endif
/* Framebuffer */ -#define CONFIG_VIDEO_BMP_LOGO #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP
diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 2853d75a163..f2dd862b7fe 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -73,7 +73,6 @@ /* Framebuffer and LCD */ #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP -#define CONFIG_VIDEO_BMP_LOGO #define CONFIG_HIDE_LOGO_VERSION /* Custom config to hide U-boot version */
/* Miscellaneous configurable options */ diff --git a/include/configs/imx6-engicam.h b/include/configs/imx6-engicam.h index ff774ec54ba..26d7a88ebde 100644 --- a/include/configs/imx6-engicam.h +++ b/include/configs/imx6-engicam.h @@ -152,8 +152,6 @@ /* Framebuffer */ #ifdef CONFIG_VIDEO_IPUV3 # define CONFIG_IMX_VIDEO_SKIP - -# define CONFIG_VIDEO_BMP_LOGO #endif
/* SPL */ diff --git a/include/configs/imxrt1050-evk.h b/include/configs/imxrt1050-evk.h index b507895a0d8..5c2f975ba7f 100644 --- a/include/configs/imxrt1050-evk.h +++ b/include/configs/imxrt1050-evk.h @@ -21,8 +21,6 @@ DMAMEM_SZ_ALL)
#ifdef CONFIG_DM_VIDEO -#define CONFIG_VIDEO_BMP_LOGO - #define CONFIG_EXTRA_ENV_SETTINGS \ "stdin=serial\0" \ "stdout=serial,vidconsole\0" \ diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 8c4cb7b7205..54860af946b 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -307,8 +307,6 @@ * Video */ #ifdef CONFIG_VIDEO_FSL_DCU_FB -#define CONFIG_VIDEO_BMP_LOGO - #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_I2C_DVI_BUS_NUM 0 #define CONFIG_SYS_I2C_QIXIS_ADDR 0x66 diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index dcee79de884..dd47ba5efc6 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -198,8 +198,6 @@ * Video */ #ifdef CONFIG_VIDEO_FSL_DCU_FB -#define CONFIG_VIDEO_BMP_LOGO - #define CONFIG_FSL_DCU_SII9022A #define CONFIG_SYS_I2C_DVI_BUS_NUM 1 #define CONFIG_SYS_I2C_DVI_ADDR 0x39 diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 7d3e651f44d..7cf65f56889 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -25,7 +25,6 @@ #endif
diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index c1c012bbb53..e9781d52a37 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -153,7 +153,6 @@ /* Environment organization */
diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 8bc86749aac..fe9fef25d93 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -148,7 +148,6 @@
#ifndef CONFIG_SPL_BUILD #ifdef CONFIG_DM_VIDEO -#define CONFIG_VIDEO_BMP_LOGO #define MXS_LCDIF_BASE MX6SX_LCDIF1_BASE_ADDR #endif #endif diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index c24578aff1c..bc11cad2e4b 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -149,7 +149,6 @@
#ifndef CONFIG_SPL_BUILD #if defined(CONFIG_DM_VIDEO) -#define CONFIG_VIDEO_BMP_LOGO #define MXS_LCDIF_BASE MX6UL_LCDIF1_BASE_ADDR #endif #endif diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index d5b38fd91dd..d411b1a3866 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -122,8 +122,4 @@
-#ifdef CONFIG_DM_VIDEO -#define CONFIG_VIDEO_BMP_LOGO -#endif - #endif /* __CONFIG_H */ diff --git a/include/configs/opos6uldev.h b/include/configs/opos6uldev.h index ac8eb052756..28104183b54 100644 --- a/include/configs/opos6uldev.h +++ b/include/configs/opos6uldev.h @@ -41,7 +41,6 @@ /* LCD */ #ifndef CONFIG_SPL_BUILD #ifdef CONFIG_DM_VIDEO -#define CONFIG_VIDEO_BMP_LOGO #define MXS_LCDIF_BASE MX6UL_LCDIF1_BASE_ADDR #endif #endif diff --git a/include/configs/pico-imx6.h b/include/configs/pico-imx6.h index 4700fff0731..ddedd3cf787 100644 --- a/include/configs/pico-imx6.h +++ b/include/configs/pico-imx6.h @@ -135,7 +135,6 @@ #define CONFIG_FEC_MXC_PHYADDR 1
diff --git a/include/configs/pico-imx6ul.h b/include/configs/pico-imx6ul.h index d87bcf45d6e..606a5bea1bf 100644 --- a/include/configs/pico-imx6ul.h +++ b/include/configs/pico-imx6ul.h @@ -130,7 +130,6 @@ #define CONFIG_BOARD_SIZE_LIMIT 715776
diff --git a/include/configs/pico-imx7d.h b/include/configs/pico-imx7d.h index eb87073a430..a90befc0116 100644 --- a/include/configs/pico-imx7d.h +++ b/include/configs/pico-imx7d.h @@ -119,10 +119,6 @@ #define CONFIG_POWER_PFUZE3000 #define CONFIG_POWER_PFUZE3000_I2C_ADDR 0x08
-#ifdef CONFIG_DM_VIDEO -#define CONFIG_VIDEO_BMP_LOGO -#endif - /* FLASH and environment organization */
/* Environment starts at 768k = 768 * 1024 = 786432 */ diff --git a/include/configs/pxm2.h b/include/configs/pxm2.h index 753fc14ce0e..6cd7929db30 100644 --- a/include/configs/pxm2.h +++ b/include/configs/pxm2.h @@ -76,7 +76,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_VIDEO_DA8XX -#define CONFIG_VIDEO_BMP_LOGO #define DA8XX_LCD_CNTL_BASE LCD_CNTL_BASE #define PWM_TICKS 0x1388 #define PWM_DUTY 0x200 diff --git a/include/configs/rut.h b/include/configs/rut.h index 02d330e4f0f..410c6d379c3 100644 --- a/include/configs/rut.h +++ b/include/configs/rut.h @@ -69,7 +69,6 @@
#define BOARD_LCD_RESET 115 /* Bank 3 pin 19 */ diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index 051c18ca232..3ef7a507f3f 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -32,7 +32,6 @@ #define CONFIG_MXC_USB_FLAGS 0
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index e393fbee1b0..89f6717fdd9 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2118,7 +2118,6 @@ CONFIG_U_BOOT_HDR_SIZE CONFIG_VAR_SIZE_SPL CONFIG_VERY_BIG_RAM CONFIG_VIDEO_BCM2835 -CONFIG_VIDEO_BMP_LOGO CONFIG_VIDEO_DA8XX CONFIG_VSC7385_ENET CONFIG_VSC7385_IMAGE
Drop the Kconfigs which are not used and all references to them. In particular, this drops CONFIG_VIDEO to avoid confusion and allow us to eventually rename CONFIG_DM_VIDEO to CONFIG_VIDEO.
Also drop the prototype for video_get_info_str() which is no-longer used.
README | 3 - arch/arm/include/asm/mach-imx/mx5_video.h | 5 -- .../mach-nexell/include/mach/display_dev.h | 2 +- board/freescale/mx51evk/Makefile | 1 - board/freescale/mx53loco/Makefile | 1 - board/kosagi/novena/novena_spl.c | 23 -------- cmd/Kconfig | 2 +- cmd/bdinfo.c | 2 +- cmd/bmp.c | 4 +- common/fdt_support.c | 2 +- common/stdio.c | 3 +- drivers/video/Kconfig | 56 +------------------ drivers/video/nexell_display.c | 3 +- include/asm-generic/global_data.h | 2 +- include/configs/pxm2.h | 7 --- include/configs/rut.h | 9 --- lib/efi_loader/Kconfig | 1 - 17 files changed, 10 insertions(+), 116 deletions(-)
diff --git a/README b/README index 816d9c4dfb2..40ef21df3b5 100644 --- a/README +++ b/README @@ -1013,9 +1013,6 @@ The following options need to be configured: support, and should also define these other macros:
CONFIG_SYS_DIU_ADDR - CONFIG_VIDEO - CONFIG_VIDEO_SW_CURSOR - CONFIG_VGA_AS_SINGLE_DEVICE
The DIU driver will look for the 'video-mode' environment variable, and if defined, enable the DIU as a console during diff --git a/arch/arm/include/asm/mach-imx/mx5_video.h b/arch/arm/include/asm/mach-imx/mx5_video.h index dc6aa00c894..b55c0fe8971 100644 --- a/arch/arm/include/asm/mach-imx/mx5_video.h +++ b/arch/arm/include/asm/mach-imx/mx5_video.h @@ -6,12 +6,7 @@ #ifndef __MX5_VIDEO_H #define __MX5_VIDEO_H
-#ifdef CONFIG_VIDEO -void lcd_enable(void); -void setup_iomux_lcd(void); -#else static inline void lcd_enable(void) { } static inline void setup_iomux_lcd(void) { } -#endif
#endif diff --git a/arch/arm/mach-nexell/include/mach/display_dev.h b/arch/arm/mach-nexell/include/mach/display_dev.h index ffa45518d99..39b28ca1299 100644 --- a/arch/arm/mach-nexell/include/mach/display_dev.h +++ b/arch/arm/mach-nexell/include/mach/display_dev.h @@ -8,7 +8,7 @@ #ifndef _NX__DISPLAY_DEV_H_ #define _NX__DISPLAY_DEV_H_
-#if defined CONFIG_VIDEO || defined CONFIG_DM_VIDEO +#if defined CONFIG_DM_VIDEO #elif defined CONFIG_LCD #include <lcd.h> #endif diff --git a/board/freescale/mx51evk/Makefile b/board/freescale/mx51evk/Makefile index 1a9581cabf9..808e35015e8 100644 --- a/board/freescale/mx51evk/Makefile +++ b/board/freescale/mx51evk/Makefile @@ -5,4 +5,3 @@ # (C) Copyright 2009 Freescale Semiconductor, Inc.
obj-y += mx51evk.o -obj-$(CONFIG_VIDEO) += mx51evk_video.o diff --git a/board/freescale/mx53loco/Makefile b/board/freescale/mx53loco/Makefile index d2ebd94dca1..9befe426957 100644 --- a/board/freescale/mx53loco/Makefile +++ b/board/freescale/mx53loco/Makefile @@ -4,4 +4,3 @@ # Jason Liu r64343@freescale.com
obj-y += mx53loco.o -obj-$(CONFIG_VIDEO) += mx53loco_video.o diff --git a/board/kosagi/novena/novena_spl.c b/board/kosagi/novena/novena_spl.c index 3d22f2019e9..24c0fb22268 100644 --- a/board/kosagi/novena/novena_spl.c +++ b/board/kosagi/novena/novena_spl.c @@ -379,30 +379,7 @@ static void novena_spl_setup_iomux_uart(void) imx_iomux_v3_setup_multiple_pads(uart4_pads, ARRAY_SIZE(uart4_pads)); }
-/* - * Video - */ -#ifdef CONFIG_VIDEO -static iomux_v3_cfg_t hdmi_pads[] = { - /* "Ghost HPD" pin */ - MX6_PAD_EIM_A24__GPIO5_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL), - - /* LCD_PWR_CTL */ - MX6_PAD_CSI0_DAT10__GPIO5_IO28 | MUX_PAD_CTRL(NO_PAD_CTRL), - /* LCD_BL_ON */ - MX6_PAD_KEY_ROW4__GPIO4_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL), - /* GPIO_PWM1 */ - MX6_PAD_DISP0_DAT8__GPIO4_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL), -}; - -static void novena_spl_setup_iomux_video(void) -{ - imx_iomux_v3_setup_multiple_pads(hdmi_pads, ARRAY_SIZE(hdmi_pads)); - gpio_direction_input(NOVENA_HDMI_GHOST_HPD); -} -#else static inline void novena_spl_setup_iomux_video(void) {} -#endif
/* * SPL boots from uSDHC card diff --git a/cmd/Kconfig b/cmd/Kconfig index 84ede90eee9..02eb2c69aed 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1748,7 +1748,7 @@ config CMD_CONITRACE
config CMD_CLS bool "Enable clear screen command 'cls'" - depends on CFB_CONSOLE || DM_VIDEO || LCD || VIDEO + depends on DM_VIDEO || LCD || VIDEO default y if LCD help Enable the 'cls' command which clears the screen contents diff --git a/cmd/bdinfo.c b/cmd/bdinfo.c index c56b3f4f6ec..37cd8a57ebd 100644 --- a/cmd/bdinfo.c +++ b/cmd/bdinfo.c @@ -117,7 +117,7 @@ int do_bdinfo(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) bdinfo_print_num_l("fdt_size", (ulong)gd->fdt_size); if (IS_ENABLED(CONFIG_DM_VIDEO)) show_video_info(); -#if defined(CONFIG_LCD) || defined(CONFIG_VIDEO) +#if defined(CONFIG_LCD) bdinfo_print_num_l("FB base ", gd->fb_base); #endif #if CONFIG_IS_ENABLED(MULTI_DTB_FIT) diff --git a/cmd/bmp.c b/cmd/bmp.c index 071ba90b435..45f4c1296de 100644 --- a/cmd/bmp.c +++ b/cmd/bmp.c @@ -268,10 +268,8 @@ int bmp_display(ulong addr, int x, int y) } #elif defined(CONFIG_LCD) ret = lcd_display_bitmap(addr, x, y); -#elif defined(CONFIG_VIDEO) - ret = video_display_bitmap(addr, x, y); #else -# error bmp_display() requires CONFIG_LCD or CONFIG_VIDEO +# error bmp_display() requires CONFIG_LCD #endif
if (bmp_alloc_addr) diff --git a/common/fdt_support.c b/common/fdt_support.c index daa24d4c10b..867d74e0c0c 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -1720,7 +1720,7 @@ int fdt_set_status_by_pathf(void *fdt, enum fdt_status status, const char *fmt, return fdt_set_node_status(fdt, offset, status); }
-#if defined(CONFIG_VIDEO) || defined(CONFIG_LCD) +#if defined(CONFIG_LCD) int fdt_add_edid(void *blob, const char *compat, unsigned char *edid_buf) { int noff; diff --git a/common/stdio.c b/common/stdio.c index aedaea14ec5..e20427c6fbd 100644 --- a/common/stdio.c +++ b/common/stdio.c @@ -367,8 +367,7 @@ int stdio_add_devices(void) } else { if (IS_ENABLED(CONFIG_LCD)) drv_lcd_init(); - if (IS_ENABLED(CONFIG_VIDEO) || - IS_ENABLED(CONFIG_VIDEO_VCXK)) + if (IS_ENABLED(CONFIG_VIDEO_VCXK)) drv_video_init(); }
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index c2465121a72..51570310533 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -691,39 +691,9 @@ config VIDEO model. Video drivers typically provide a colour text console and cursor.
-config VGA_AS_SINGLE_DEVICE - bool "Set the video as an output-only device" - depends on CFB_CONSOLE - default y - help - If enable the framebuffer device will be initialized as an - output-only device. The Keyboard driver will not be set up. This - may be used if you have no keyboard device, or more than one - (USB Keyboard, AT Keyboard). - -config VIDEO_SW_CURSOR - bool "Enable a software cursor" - depends on CFB_CONSOLE - default y if CFB_CONSOLE - help - This draws a cursor after the last character. No blinking is - provided. This makes it possible to see the current cursor - position when entering text on the console. It is recommended to - enable this. - -config CONSOLE_EXTRA_INFO - bool "Display additional board information" - depends on CFB_CONSOLE - help - Display additional board information strings that normally go to - the serial port. When this option is enabled, a board-specific - function video_get_info_str() is called to get the string for - each line of the display. The function should return the string, - which can be empty if there is nothing to display for that line. - config CONSOLE_SCROLL_LINES int "Number of lines to scroll the console by" - depends on CFB_CONSOLE || DM_VIDEO || LCD + depends on DM_VIDEO || LCD default 1 help When the console need to be scrolled, this is the number of @@ -731,28 +701,6 @@ config CONSOLE_SCROLL_LINES console jump but can help speed up operation when scrolling is slow.
-config SYS_CONSOLE_BG_COL - hex "Background colour" - depends on CFB_CONSOLE - default 0x00 - help - Defines the background colour for the console. The value is from - 0x00 to 0xff and the meaning depends on the graphics card. - Typically, 0x00 means black and 0xff means white. Do not set - the background and foreground to the same colour or you will see - nothing. - -config SYS_CONSOLE_FG_COL - hex "Foreground colour" - depends on CFB_CONSOLE - default 0xa0 - help - Defines the foreground colour for the console. The value is from - 0x00 to 0xff and the meaning depends on the graphics card. - Typically, 0x00 means black and 0xff means white. Do not set - the background and foreground to the same colour or you will see - nothing. - config LCD bool "Enable legacy LCD support" help @@ -938,7 +886,7 @@ config VIDEO_BMP_GZIP
config VIDEO_BMP_RLE8 bool "Run length encoded BMP image (RLE8) support" - depends on DM_VIDEO || CFB_CONSOLE + depends on DM_VIDEO help If this option is set, the 8-bit RLE compressed BMP images is supported. diff --git a/drivers/video/nexell_display.c b/drivers/video/nexell_display.c index 0a9cea680fd..2179e413300 100644 --- a/drivers/video/nexell_display.c +++ b/drivers/video/nexell_display.c @@ -598,8 +598,7 @@ static int nx_display_probe(struct udevice *dev)
/* * set environment variable "fb_addr" (frame buffer address), required - * for splash image. Because drv_video_init() in common/stdio.c is only - * called when CONFIG_VIDEO is set (and not if CONFIG_DM_VIDEO is set). + * for splash image, which is not set if CONFIG_DM_VIDEO is enabled). */ sprintf(addr, "0x%x", dp->fb_addr); debug("%s(): env_set("fb_addr", %s) ...\n", __func__, addr); diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index 104282bd479..78986b5bee0 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -66,7 +66,7 @@ struct global_data { * @mem_clk: memory clock rate in Hz */ unsigned long mem_clk; -#if defined(CONFIG_LCD) || defined(CONFIG_VIDEO) || defined(CONFIG_DM_VIDEO) +#if defined(CONFIG_LCD) || defined(CONFIG_DM_VIDEO) /** * @fb_base: base address of frame buffer memory */ diff --git a/include/configs/pxm2.h b/include/configs/pxm2.h index 6cd7929db30..7272470d12e 100644 --- a/include/configs/pxm2.h +++ b/include/configs/pxm2.h @@ -74,11 +74,4 @@ #endif #endif /* CONFIG_SPL_BUILD */
-#if defined(CONFIG_VIDEO) -#define CONFIG_VIDEO_DA8XX -#define DA8XX_LCD_CNTL_BASE LCD_CNTL_BASE -#define PWM_TICKS 0x1388 -#define PWM_DUTY 0x200 -#endif - #endif /* ! __CONFIG_PXM2_H */ diff --git a/include/configs/rut.h b/include/configs/rut.h index 410c6d379c3..b30b12af52c 100644 --- a/include/configs/rut.h +++ b/include/configs/rut.h @@ -67,13 +67,4 @@
-#if defined(CONFIG_VIDEO) -#define CONFIG_VIDEO_DA8XX -#define DA8XX_LCD_CNTL_BASE LCD_CNTL_BASE - -#define BOARD_LCD_RESET 115 /* Bank 3 pin 19 */ -#define CONFIG_FORMIKE -#define DISPL_PLL_SPREAD_SPECTRUM -#endif - #endif /* ! __CONFIG_RUT_H */ diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 24f9a2bb757..2876acce066 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -18,7 +18,6 @@ config EFI_LOADER select PARTITION_UUIDS select HAVE_BLOCK_DEVICE select REGEX - imply CFB_CONSOLE_ANSI imply FAT imply FAT_WRITE imply USB_KEYBOARD_FN_KEYS
-----Original Message----- From: Simon Glass sjg@chromium.org Sent: 2022年1月23日 22:04 To: U-Boot Mailing List u-boot@lists.denx.de Cc: Anatolij Gustschin agust@denx.de; Jagan Teki jagan@amarulasolutions.com; Andre Przywara andre.przywara@arm.com; Simon Glass sjg@chromium.org; Andy Shevchenko andriy.shevchenko@linux.intel.com; Aswath Govindraju a-govindraju@ti.com; Aymen Sghaier aymen.sghaier@nxp.com; Bin Meng bmeng.cn@gmail.com; Dario Binacchi dariobin@libero.it; Fabio Estevam festevam@gmail.com; Heiko Schocher hs@denx.de; Heinrich Schuchardt xypron.glpk@gmx.de; Jaehoon Chung jh80.chung@samsung.com; Jason Liu jason.hui.liu@nxp.com; Joel Peshkin joel.peshkin@broadcom.com; Kory Maincent kory.maincent@bootlin.com; Marek Vasut marex@denx.de; Michal Simek michal.simek@xilinx.com; dl-uboot-imx uboot-imx@nxp.com; Ovidiu Panait ovidiu.panait@windriver.com; Peng Fan peng.fan@nxp.com; Rasmus Villemoes rasmus.villemoes@prevas.dk; samuel.egli@siemens.com; Stefan Bosch stefan_b@posteo.net; Stefan Roese sr@denx.de; Stefano Babic sbabic@denx.de Subject: [PATCH 07/14] video: Drop references to CONFIG_VIDEO et al
particular,
For the imx51/53 board. Acked-by: Jason Liu jason.hui.liu@nxp.com
CONFIG_SYS_DIU_ADDR
CONFIG_VIDEO
diff --git
{ } -#endif
- Video
- /* LCD_PWR_CTL */
- /* LCD_BL_ON */
- /* GPIO_PWM1 */
- SPL boots from uSDHC card
- depends on DM_VIDEO || LCD || VIDEO default y if LCD help Enable the 'cls' command which clears the screen contents diff
--git
argc,
}if (IS_ENABLED(CONFIG_VIDEO_VCXK)) drv_video_init();
- default y
- help
- help
enable this.
- help
- depends on DM_VIDEO || LCD default 1 help When the console need to be scrolled, this is the number of @@
- default 0x00
- help
nothing.
- default 0xa0
- help
nothing.
- depends on DM_VIDEO help If this option is set, the 8-bit RLE compressed BMP images is supported.
required
only
set).
enabled).
--git
Drop the unnecessary cruft from this header and update the title.
include/video.h | 84 +------------------------------------------------ 1 file changed, 1 insertion(+), 83 deletions(-)
diff --git a/include/video.h b/include/video.h index 48a71dc2379..43e2c899778 100644 --- a/include/video.h +++ b/include/video.h @@ -1,13 +1,7 @@ /* - * Video uclass and legacy implementation + * Video uclass to support displays (see also vidconsole for text) * * Copyright (c) 2015 Google, Inc - * - * MPC823 Video Controller - * ======================= - * (C) 2000 by Paolo Scaffardi (arsenio@tin.it) - * AIRVENT SAM s.p.a - RIMINI(ITALY) - * */
#ifndef _VIDEO_H_ @@ -155,7 +149,6 @@ struct video_ops { */ int video_reserve(ulong *addrp);
-#ifdef CONFIG_DM_VIDEO /** * video_clear() - Clear a device's frame buffer to background color. * @@ -163,7 +156,6 @@ int video_reserve(ulong *addrp); * Return: 0 */ int video_clear(struct udevice *dev); -#endif /* CONFIG_DM_VIDEO */
/** * video_sync() - Sync a device's frame buffer with its hardware @@ -283,78 +275,4 @@ static inline int video_sync_copy_all(struct udevice *dev) */ bool video_is_active(void);
-#ifndef CONFIG_DM_VIDEO - -/* Video functions */ - -/** - * Display a BMP format bitmap on the screen - * - * @param bmp_image Address of BMP image - * @param x X position to draw image - * @param y Y position to draw image - */ -int video_display_bitmap(ulong bmp_image, int x, int y); - -/** - * Get the width of the screen in pixels - * - * Return: width of screen in pixels - */ -int video_get_pixel_width(void); - -/** - * Get the height of the screen in pixels - * - * Return: height of screen in pixels - */ -int video_get_pixel_height(void); - -/** - * Get the number of text lines/rows on the screen - * - * Return: number of rows - */ -int video_get_screen_rows(void); - -/** - * Get the number of text columns on the screen - * - * Return: number of columns - */ -int video_get_screen_columns(void); - -/** - * Set the position of the text cursor - * - * @param col Column to place cursor (0 = left side) - * @param row Row to place cursor (0 = top line) - */ -void video_position_cursor(unsigned col, unsigned row); - -/* Clear the display */ -void video_clear(void); - -#if defined(CONFIG_FORMIKE) -int kwh043st20_f01_spi_startup(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int spi_mode); -#endif -#if defined(CONFIG_LG4573) -int lg4573_spi_startup(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int spi_mode); -#endif - -/* - * video_get_info_str() - obtain a board string: type, speed, etc. - * - * This is called if CONFIG_CONSOLE_EXTRA_INFO is enabled. - * - * line_number: location to place info string beside logo - * info: buffer for info string (empty if nothing to display on this - * line) - */ -void video_get_info_str(int line_number, char *info); - -#endif /* !CONFIG_DM_VIDEO */ - #endif
This is not used in U-Boot anymore. Drop it.
drivers/video/Makefile | 1 - drivers/video/da8xx-fb.c | 1047 ---------------------------------- drivers/video/da8xx-fb.h | 115 ---- scripts/config_whitelist.txt | 1 - 4 files changed, 1164 deletions(-) delete mode 100644 drivers/video/da8xx-fb.c delete mode 100644 drivers/video/da8xx-fb.h
diff --git a/drivers/video/Makefile b/drivers/video/Makefile index aaf3d80f856..18d53e5803c 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -46,7 +46,6 @@ obj-$(CONFIG_VIDEO_ARM_MALIDP) += mali_dp.o obj-$(CONFIG_VIDEO_BCM2835) += bcm2835.o obj-$(CONFIG_VIDEO_BROADWELL_IGD) += broadwell_igd.o obj-$(CONFIG_VIDEO_COREBOOT) += coreboot.o -obj-$(CONFIG_VIDEO_DA8XX) += da8xx-fb.o videomodes.o obj-$(CONFIG_VIDEO_DW_HDMI) += dw_hdmi.o obj-$(CONFIG_VIDEO_DW_MIPI_DSI) += dw_mipi_dsi.o obj-$(CONFIG_VIDEO_EFI) += efi.o diff --git a/drivers/video/da8xx-fb.c b/drivers/video/da8xx-fb.c deleted file mode 100644 index db9a820377d..00000000000 --- a/drivers/video/da8xx-fb.c +++ /dev/null @@ -1,1047 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Porting to u-boot: - * - * (C) Copyright 2011 - * Stefano Babic, DENX Software Engineering, sbabic@denx.de. - * - * Copyright (C) 2008-2009 MontaVista Software Inc. - * Copyright (C) 2008-2009 Texas Instruments Inc - * - * Based on the LCD driver for TI Avalanche processors written by - * Ajay Singh and Shalom Hai. - */ - -#include <common.h> -#include <log.h> -#include <malloc.h> -#include <memalign.h> -#include <asm/global_data.h> -#include <linux/delay.h> -#include <linux/list.h> -#include <linux/fb.h> - -#include <linux/errno.h> -#include <asm/io.h> -#include <asm/arch/hardware.h> - -#include "videomodes.h" -#include "da8xx-fb.h" - -#if !defined(DA8XX_LCD_CNTL_BASE) -#define DA8XX_LCD_CNTL_BASE DAVINCI_LCD_CNTL_BASE -#endif - -#define DRIVER_NAME "da8xx_lcdc" - -#define LCD_VERSION_1 1 -#define LCD_VERSION_2 2 - -/* LCD Status Register */ -#define LCD_END_OF_FRAME1 (1 << 9) -#define LCD_END_OF_FRAME0 (1 << 8) -#define LCD_PL_LOAD_DONE (1 << 6) -#define LCD_FIFO_UNDERFLOW (1 << 5) -#define LCD_SYNC_LOST (1 << 2) - -/* LCD DMA Control Register */ -#define LCD_DMA_BURST_SIZE(x) ((x) << 4) -#define LCD_DMA_BURST_1 0x0 -#define LCD_DMA_BURST_2 0x1 -#define LCD_DMA_BURST_4 0x2 -#define LCD_DMA_BURST_8 0x3 -#define LCD_DMA_BURST_16 0x4 -#define LCD_V1_END_OF_FRAME_INT_ENA (1 << 2) -#define LCD_V2_END_OF_FRAME0_INT_ENA (1 << 8) -#define LCD_V2_END_OF_FRAME1_INT_ENA (1 << 9) -#define LCD_DUAL_FRAME_BUFFER_ENABLE (1 << 0) - -#define LCD_V2_TFT_24BPP_MODE (1 << 25) -#define LCD_V2_TFT_24BPP_UNPACK (1 << 26) - -/* LCD Control Register */ -#define LCD_CLK_DIVISOR(x) ((x) << 8) -#define LCD_RASTER_MODE 0x01 - -/* LCD Raster Control Register */ -#define LCD_PALETTE_LOAD_MODE(x) ((x) << 20) -#define PALETTE_AND_DATA 0x00 -#define PALETTE_ONLY 0x01 -#define DATA_ONLY 0x02 - -#define LCD_MONO_8BIT_MODE (1 << 9) -#define LCD_RASTER_ORDER (1 << 8) -#define LCD_TFT_MODE (1 << 7) -#define LCD_V1_UNDERFLOW_INT_ENA (1 << 6) -#define LCD_V2_UNDERFLOW_INT_ENA (1 << 5) -#define LCD_V1_PL_INT_ENA (1 << 4) -#define LCD_V2_PL_INT_ENA (1 << 6) -#define LCD_MONOCHROME_MODE (1 << 1) -#define LCD_RASTER_ENABLE (1 << 0) -#define LCD_TFT_ALT_ENABLE (1 << 23) -#define LCD_STN_565_ENABLE (1 << 24) -#define LCD_V2_DMA_CLK_EN (1 << 2) -#define LCD_V2_LIDD_CLK_EN (1 << 1) -#define LCD_V2_CORE_CLK_EN (1 << 0) -#define LCD_V2_LPP_B10 26 -#define LCD_V2_TFT_24BPP_MODE (1 << 25) -#define LCD_V2_TFT_24BPP_UNPACK (1 << 26) - -/* LCD Raster Timing 2 Register */ -#define LCD_AC_BIAS_TRANSITIONS_PER_INT(x) ((x) << 16) -#define LCD_AC_BIAS_FREQUENCY(x) ((x) << 8) -#define LCD_SYNC_CTRL (1 << 25) -#define LCD_SYNC_EDGE (1 << 24) -#define LCD_INVERT_PIXEL_CLOCK (1 << 22) -#define LCD_INVERT_LINE_CLOCK (1 << 21) -#define LCD_INVERT_FRAME_CLOCK (1 << 20) - -/* Clock registers available only on Version 2 */ -#define LCD_CLK_MAIN_RESET (1 << 3) -/* LCD Block */ -struct da8xx_lcd_regs { - u32 revid; - u32 ctrl; - u32 stat; - u32 lidd_ctrl; - u32 lidd_cs0_conf; - u32 lidd_cs0_addr; - u32 lidd_cs0_data; - u32 lidd_cs1_conf; - u32 lidd_cs1_addr; - u32 lidd_cs1_data; - u32 raster_ctrl; - u32 raster_timing_0; - u32 raster_timing_1; - u32 raster_timing_2; - u32 raster_subpanel; - u32 reserved; - u32 dma_ctrl; - u32 dma_frm_buf_base_addr_0; - u32 dma_frm_buf_ceiling_addr_0; - u32 dma_frm_buf_base_addr_1; - u32 dma_frm_buf_ceiling_addr_1; - u32 resv1; - u32 raw_stat; - u32 masked_stat; - u32 int_ena_set; - u32 int_ena_clr; - u32 end_of_int_ind; - /* Clock registers available only on Version 2 */ - u32 clk_ena; - u32 clk_reset; -}; - -#define LCD_NUM_BUFFERS 1 - -#define WSI_TIMEOUT 50 -#define PALETTE_SIZE 256 -#define LEFT_MARGIN 64 -#define RIGHT_MARGIN 64 -#define UPPER_MARGIN 32 -#define LOWER_MARGIN 32 -#define WAIT_FOR_FRAME_DONE true -#define NO_WAIT_FOR_FRAME_DONE false - -#define calc_fbsize() (panel.plnSizeX * panel.plnSizeY * panel.gdfBytesPP) - -static struct da8xx_lcd_regs *da8xx_fb_reg_base; - -DECLARE_GLOBAL_DATA_PTR; - -/* graphics setup */ -static GraphicDevice gpanel; -static const struct da8xx_panel *lcd_panel; -static struct fb_info *da8xx_fb_info; -static int bits_x_pixel; -static unsigned int lcd_revision; -const struct lcd_ctrl_config *da8xx_lcd_cfg; - -static inline unsigned int lcdc_read(u32 *addr) -{ - return (unsigned int)readl(addr); -} - -static inline void lcdc_write(unsigned int val, u32 *addr) -{ - writel(val, addr); -} - -struct da8xx_fb_par { - u32 p_palette_base; - unsigned char *v_palette_base; - dma_addr_t vram_phys; - unsigned long vram_size; - void *vram_virt; - unsigned int dma_start; - unsigned int dma_end; - struct clk *lcdc_clk; - int irq; - unsigned short pseudo_palette[16]; - unsigned int palette_sz; - unsigned int pxl_clk; - int blank; - int vsync_flag; - int vsync_timeout; -}; - - -/* Variable Screen Information */ -static struct fb_var_screeninfo da8xx_fb_var = { - .xoffset = 0, - .yoffset = 0, - .transp = {0, 0, 0}, - .nonstd = 0, - .activate = 0, - .height = -1, - .width = -1, - .pixclock = 46666, /* 46us - AUO display */ - .accel_flags = 0, - .left_margin = LEFT_MARGIN, - .right_margin = RIGHT_MARGIN, - .upper_margin = UPPER_MARGIN, - .lower_margin = LOWER_MARGIN, - .sync = 0, - .vmode = FB_VMODE_NONINTERLACED -}; - -static struct fb_fix_screeninfo da8xx_fb_fix = { - .id = "DA8xx FB Drv", - .type = FB_TYPE_PACKED_PIXELS, - .type_aux = 0, - .visual = FB_VISUAL_PSEUDOCOLOR, - .xpanstep = 0, - .ypanstep = 1, - .ywrapstep = 0, - .accel = FB_ACCEL_NONE -}; - -/* Enable the Raster Engine of the LCD Controller */ -static inline void lcd_enable_raster(void) -{ - u32 reg; - - /* Put LCDC in reset for several cycles */ - if (lcd_revision == LCD_VERSION_2) - lcdc_write(LCD_CLK_MAIN_RESET, - &da8xx_fb_reg_base->clk_reset); - - udelay(1000); - /* Bring LCDC out of reset */ - if (lcd_revision == LCD_VERSION_2) - lcdc_write(0, - &da8xx_fb_reg_base->clk_reset); - - udelay(1000); - - reg = lcdc_read(&da8xx_fb_reg_base->raster_ctrl); - if (!(reg & LCD_RASTER_ENABLE)) - lcdc_write(reg | LCD_RASTER_ENABLE, - &da8xx_fb_reg_base->raster_ctrl); -} - -/* Disable the Raster Engine of the LCD Controller */ -static inline void lcd_disable_raster(bool wait_for_frame_done) -{ - u32 reg; - u32 loop_cnt = 0; - u32 stat; - u32 i = 0; - - if (wait_for_frame_done) - loop_cnt = 5000; - - reg = lcdc_read(&da8xx_fb_reg_base->raster_ctrl); - if (reg & LCD_RASTER_ENABLE) - lcdc_write(reg & ~LCD_RASTER_ENABLE, - &da8xx_fb_reg_base->raster_ctrl); - - /* Wait for the current frame to complete */ - do { - if (lcd_revision == LCD_VERSION_1) - stat = lcdc_read(&da8xx_fb_reg_base->stat); - else - stat = lcdc_read(&da8xx_fb_reg_base->raw_stat); - - mdelay(1); - } while (!(stat & 0x01) && (i++ < loop_cnt)); - - if (lcd_revision == LCD_VERSION_1) - lcdc_write(stat, &da8xx_fb_reg_base->stat); - else - lcdc_write(stat, &da8xx_fb_reg_base->raw_stat); - - if ((loop_cnt != 0) && (i >= loop_cnt)) { - printf("LCD Controller timed out\n"); - return; - } -} - -static void lcd_blit(int load_mode, struct da8xx_fb_par *par) -{ - u32 start; - u32 end; - u32 reg_ras; - u32 reg_dma; - u32 reg_int; - - /* init reg to clear PLM (loading mode) fields */ - reg_ras = lcdc_read(&da8xx_fb_reg_base->raster_ctrl); - reg_ras &= ~(3 << 20); - - reg_dma = lcdc_read(&da8xx_fb_reg_base->dma_ctrl); - - if (load_mode == LOAD_DATA) { - start = par->dma_start; - end = par->dma_end; - - reg_ras |= LCD_PALETTE_LOAD_MODE(DATA_ONLY); - if (lcd_revision == LCD_VERSION_1) { - reg_dma |= LCD_V1_END_OF_FRAME_INT_ENA; - } else { - reg_int = lcdc_read(&da8xx_fb_reg_base->int_ena_set) | - LCD_V2_END_OF_FRAME0_INT_ENA | - LCD_V2_END_OF_FRAME1_INT_ENA | - LCD_V2_UNDERFLOW_INT_ENA | LCD_SYNC_LOST; - lcdc_write(reg_int, &da8xx_fb_reg_base->int_ena_set); - } - -#if (LCD_NUM_BUFFERS == 2) - reg_dma |= LCD_DUAL_FRAME_BUFFER_ENABLE; - lcdc_write(start, &da8xx_fb_reg_base->dma_frm_buf_base_addr_0); - lcdc_write(end, &da8xx_fb_reg_base->dma_frm_buf_ceiling_addr_0); - lcdc_write(start, &da8xx_fb_reg_base->dma_frm_buf_base_addr_1); - lcdc_write(end, &da8xx_fb_reg_base->dma_frm_buf_ceiling_addr_1); -#else - reg_dma &= ~LCD_DUAL_FRAME_BUFFER_ENABLE; - lcdc_write(start, &da8xx_fb_reg_base->dma_frm_buf_base_addr_0); - lcdc_write(end, &da8xx_fb_reg_base->dma_frm_buf_ceiling_addr_0); - lcdc_write(0, &da8xx_fb_reg_base->dma_frm_buf_base_addr_1); - lcdc_write(0, &da8xx_fb_reg_base->dma_frm_buf_ceiling_addr_1); -#endif - - } else if (load_mode == LOAD_PALETTE) { - start = par->p_palette_base; - end = start + par->palette_sz - 1; - - reg_ras |= LCD_PALETTE_LOAD_MODE(PALETTE_ONLY); - if (lcd_revision == LCD_VERSION_1) { - reg_ras |= LCD_V1_PL_INT_ENA; - } else { - reg_int = lcdc_read(&da8xx_fb_reg_base->int_ena_set) | - LCD_V2_PL_INT_ENA; - lcdc_write(reg_int, &da8xx_fb_reg_base->int_ena_set); - } - - lcdc_write(start, &da8xx_fb_reg_base->dma_frm_buf_base_addr_0); - lcdc_write(end, &da8xx_fb_reg_base->dma_frm_buf_ceiling_addr_0); - } - - lcdc_write(reg_dma, &da8xx_fb_reg_base->dma_ctrl); - lcdc_write(reg_ras, &da8xx_fb_reg_base->raster_ctrl); - - /* - * The Raster enable bit must be set after all other control fields are - * set. - */ - lcd_enable_raster(); -} - -/* Configure the Burst Size of DMA */ -static int lcd_cfg_dma(int burst_size) -{ - u32 reg; - - reg = lcdc_read(&da8xx_fb_reg_base->dma_ctrl) & 0x00000001; - switch (burst_size) { - case 1: - reg |= LCD_DMA_BURST_SIZE(LCD_DMA_BURST_1); - break; - case 2: - reg |= LCD_DMA_BURST_SIZE(LCD_DMA_BURST_2); - break; - case 4: - reg |= LCD_DMA_BURST_SIZE(LCD_DMA_BURST_4); - break; - case 8: - reg |= LCD_DMA_BURST_SIZE(LCD_DMA_BURST_8); - break; - case 16: - reg |= LCD_DMA_BURST_SIZE(LCD_DMA_BURST_16); - break; - default: - return -EINVAL; - } - lcdc_write(reg, &da8xx_fb_reg_base->dma_ctrl); - - return 0; -} - -static void lcd_cfg_ac_bias(int period, int transitions_per_int) -{ - u32 reg; - - /* Set the AC Bias Period and Number of Transitions per Interrupt */ - reg = lcdc_read(&da8xx_fb_reg_base->raster_timing_2) & 0xFFF00000; - reg |= LCD_AC_BIAS_FREQUENCY(period) | - LCD_AC_BIAS_TRANSITIONS_PER_INT(transitions_per_int); - lcdc_write(reg, &da8xx_fb_reg_base->raster_timing_2); -} - -static void lcd_cfg_horizontal_sync(int back_porch, int pulse_width, - int front_porch) -{ - u32 reg; - - reg = lcdc_read(&da8xx_fb_reg_base->raster_timing_0) & 0xf; - reg |= ((back_porch & 0xff) << 24) - | ((front_porch & 0xff) << 16) - | ((pulse_width & 0x3f) << 10); - lcdc_write(reg, &da8xx_fb_reg_base->raster_timing_0); -} - -static void lcd_cfg_vertical_sync(int back_porch, int pulse_width, - int front_porch) -{ - u32 reg; - - reg = lcdc_read(&da8xx_fb_reg_base->raster_timing_1) & 0x3ff; - reg |= ((back_porch & 0xff) << 24) - | ((front_porch & 0xff) << 16) - | ((pulse_width & 0x3f) << 10); - lcdc_write(reg, &da8xx_fb_reg_base->raster_timing_1); -} - -static int lcd_cfg_display(const struct lcd_ctrl_config *cfg) -{ - u32 reg; - u32 reg_int; - - reg = lcdc_read(&da8xx_fb_reg_base->raster_ctrl) & ~(LCD_TFT_MODE | - LCD_MONO_8BIT_MODE | - LCD_MONOCHROME_MODE); - - switch (cfg->p_disp_panel->panel_shade) { - case MONOCHROME: - reg |= LCD_MONOCHROME_MODE; - if (cfg->mono_8bit_mode) - reg |= LCD_MONO_8BIT_MODE; - break; - case COLOR_ACTIVE: - reg |= LCD_TFT_MODE; - if (cfg->tft_alt_mode) - reg |= LCD_TFT_ALT_ENABLE; - break; - - case COLOR_PASSIVE: - if (cfg->stn_565_mode) - reg |= LCD_STN_565_ENABLE; - break; - - default: - return -EINVAL; - } - - /* enable additional interrupts here */ - if (lcd_revision == LCD_VERSION_1) { - reg |= LCD_V1_UNDERFLOW_INT_ENA; - } else { - reg_int = lcdc_read(&da8xx_fb_reg_base->int_ena_set) | - LCD_V2_UNDERFLOW_INT_ENA; - lcdc_write(reg_int, &da8xx_fb_reg_base->int_ena_set); - } - - lcdc_write(reg, &da8xx_fb_reg_base->raster_ctrl); - - reg = lcdc_read(&da8xx_fb_reg_base->raster_timing_2); - - if (cfg->sync_ctrl) - reg |= LCD_SYNC_CTRL; - else - reg &= ~LCD_SYNC_CTRL; - - if (cfg->sync_edge) - reg |= LCD_SYNC_EDGE; - else - reg &= ~LCD_SYNC_EDGE; - - if (cfg->invert_line_clock) - reg |= LCD_INVERT_LINE_CLOCK; - else - reg &= ~LCD_INVERT_LINE_CLOCK; - - if (cfg->invert_frm_clock) - reg |= LCD_INVERT_FRAME_CLOCK; - else - reg &= ~LCD_INVERT_FRAME_CLOCK; - - lcdc_write(reg, &da8xx_fb_reg_base->raster_timing_2); - - return 0; -} - -static int lcd_cfg_frame_buffer(struct da8xx_fb_par *par, u32 width, u32 height, - u32 bpp, u32 raster_order) -{ - u32 reg; - - /* Set the Panel Width */ - /* Pixels per line = (PPL + 1)*16 */ - if (lcd_revision == LCD_VERSION_1) { - /* - * 0x3F in bits 4..9 gives max horizontal resolution = 1024 - * pixels - */ - width &= 0x3f0; - } else { - /* - * 0x7F in bits 4..10 gives max horizontal resolution = 2048 - * pixels. - */ - width &= 0x7f0; - } - reg = lcdc_read(&da8xx_fb_reg_base->raster_timing_0); - reg &= 0xfffffc00; - if (lcd_revision == LCD_VERSION_1) { - reg |= ((width >> 4) - 1) << 4; - } else { - width = (width >> 4) - 1; - reg |= ((width & 0x3f) << 4) | ((width & 0x40) >> 3); - } - lcdc_write(reg, &da8xx_fb_reg_base->raster_timing_0); - - /* Set the Panel Height */ - /* Set bits 9:0 of Lines Per Pixel */ - reg = lcdc_read(&da8xx_fb_reg_base->raster_timing_1); - reg = ((height - 1) & 0x3ff) | (reg & 0xfffffc00); - lcdc_write(reg, &da8xx_fb_reg_base->raster_timing_1); - - /* Set bit 10 of Lines Per Pixel */ - if (lcd_revision == LCD_VERSION_2) { - reg = lcdc_read(&da8xx_fb_reg_base->raster_timing_2); - reg |= ((height - 1) & 0x400) << 16; - lcdc_write(reg, &da8xx_fb_reg_base->raster_timing_2); - } - - /* Set the Raster Order of the Frame Buffer */ - reg = lcdc_read(&da8xx_fb_reg_base->raster_ctrl) & ~(1 << 8); - if (raster_order) - reg |= LCD_RASTER_ORDER; - - if (bpp == 24) - reg |= (LCD_TFT_MODE | LCD_V2_TFT_24BPP_MODE); - else if (bpp == 32) - reg |= (LCD_TFT_MODE | LCD_V2_TFT_24BPP_MODE - | LCD_V2_TFT_24BPP_UNPACK); - - lcdc_write(reg, &da8xx_fb_reg_base->raster_ctrl); - - switch (bpp) { - case 1: - case 2: - case 4: - case 16: - case 24: - case 32: - par->palette_sz = 16 * 2; - break; - - case 8: - par->palette_sz = 256 * 2; - break; - - default: - return -EINVAL; - } - - return 0; -} - -static int fb_setcolreg(unsigned regno, unsigned red, unsigned green, - unsigned blue, unsigned transp, - struct fb_info *info) -{ - struct da8xx_fb_par *par = info->par; - unsigned short *palette = (unsigned short *) par->v_palette_base; - u_short pal; - int update_hw = 0; - - if (regno > 255) - return 1; - - if (info->fix.visual == FB_VISUAL_DIRECTCOLOR) - return 1; - - if (info->var.bits_per_pixel == 8) { - red >>= 4; - green >>= 8; - blue >>= 12; - - pal = (red & 0x0f00); - pal |= (green & 0x00f0); - pal |= (blue & 0x000f); - - if (palette[regno] != pal) { - update_hw = 1; - palette[regno] = pal; - } - } else if ((info->var.bits_per_pixel == 16) && regno < 16) { - red >>= (16 - info->var.red.length); - red <<= info->var.red.offset; - - green >>= (16 - info->var.green.length); - green <<= info->var.green.offset; - - blue >>= (16 - info->var.blue.length); - blue <<= info->var.blue.offset; - - par->pseudo_palette[regno] = red | green | blue; - - if (palette[0] != 0x4000) { - update_hw = 1; - palette[0] = 0x4000; - } - } else if (((info->var.bits_per_pixel == 32) && regno < 32) || - ((info->var.bits_per_pixel == 24) && regno < 24)) { - red >>= (24 - info->var.red.length); - red <<= info->var.red.offset; - - green >>= (24 - info->var.green.length); - green <<= info->var.green.offset; - - blue >>= (24 - info->var.blue.length); - blue <<= info->var.blue.offset; - - par->pseudo_palette[regno] = red | green | blue; - - if (palette[0] != 0x4000) { - update_hw = 1; - palette[0] = 0x4000; - } - } - - /* Update the palette in the h/w as needed. */ - if (update_hw) - lcd_blit(LOAD_PALETTE, par); - - return 0; -} - -static void lcd_reset(struct da8xx_fb_par *par) -{ - /* Disable the Raster if previously Enabled */ - lcd_disable_raster(NO_WAIT_FOR_FRAME_DONE); - - /* DMA has to be disabled */ - lcdc_write(0, &da8xx_fb_reg_base->dma_ctrl); - lcdc_write(0, &da8xx_fb_reg_base->raster_ctrl); - - if (lcd_revision == LCD_VERSION_2) { - lcdc_write(0, &da8xx_fb_reg_base->int_ena_set); - /* Write 1 to reset */ - lcdc_write(LCD_CLK_MAIN_RESET, &da8xx_fb_reg_base->clk_reset); - lcdc_write(0, &da8xx_fb_reg_base->clk_reset); - } -} - -static void lcd_calc_clk_divider(struct da8xx_fb_par *par) -{ - unsigned int lcd_clk, div; - - /* Get clock from sysclk2 */ - lcd_clk = clk_get(2); - - div = lcd_clk / par->pxl_clk; - debug("LCD Clock: %d Divider: %d PixClk: %d\n", - lcd_clk, div, par->pxl_clk); - - /* Configure the LCD clock divisor. */ - lcdc_write(LCD_CLK_DIVISOR(div) | - (LCD_RASTER_MODE & 0x1), &da8xx_fb_reg_base->ctrl); - - if (lcd_revision == LCD_VERSION_2) - lcdc_write(LCD_V2_DMA_CLK_EN | LCD_V2_LIDD_CLK_EN | - LCD_V2_CORE_CLK_EN, - &da8xx_fb_reg_base->clk_ena); -} - -static int lcd_init(struct da8xx_fb_par *par, const struct lcd_ctrl_config *cfg, - const struct da8xx_panel *panel) -{ - u32 bpp; - int ret = 0; - - lcd_reset(par); - - /* Calculate the divider */ - lcd_calc_clk_divider(par); - - if (panel->invert_pxl_clk) - lcdc_write((lcdc_read(&da8xx_fb_reg_base->raster_timing_2) | - LCD_INVERT_PIXEL_CLOCK), - &da8xx_fb_reg_base->raster_timing_2); - else - lcdc_write((lcdc_read(&da8xx_fb_reg_base->raster_timing_2) & - ~LCD_INVERT_PIXEL_CLOCK), - &da8xx_fb_reg_base->raster_timing_2); - - /* Configure the DMA burst size. */ - ret = lcd_cfg_dma(cfg->dma_burst_sz); - if (ret < 0) - return ret; - - /* Configure the AC bias properties. */ - lcd_cfg_ac_bias(cfg->ac_bias, cfg->ac_bias_intrpt); - - /* Configure the vertical and horizontal sync properties. */ - lcd_cfg_vertical_sync(panel->vbp, panel->vsw, panel->vfp); - lcd_cfg_horizontal_sync(panel->hbp, panel->hsw, panel->hfp); - - /* Configure for display */ - ret = lcd_cfg_display(cfg); - if (ret < 0) - return ret; - - if ((QVGA != cfg->p_disp_panel->panel_type) && - (WVGA != cfg->p_disp_panel->panel_type)) - return -EINVAL; - - if (cfg->bpp <= cfg->p_disp_panel->max_bpp && - cfg->bpp >= cfg->p_disp_panel->min_bpp) - bpp = cfg->bpp; - else - bpp = cfg->p_disp_panel->max_bpp; - if (bpp == 12) - bpp = 16; - ret = lcd_cfg_frame_buffer(par, (unsigned int)panel->width, - (unsigned int)panel->height, bpp, - cfg->raster_order); - if (ret < 0) - return ret; - - /* Configure FDD */ - lcdc_write((lcdc_read(&da8xx_fb_reg_base->raster_ctrl) & 0xfff00fff) | - (cfg->fdd << 12), &da8xx_fb_reg_base->raster_ctrl); - - return 0; -} - -static void lcdc_dma_start(void) -{ - struct da8xx_fb_par *par = da8xx_fb_info->par; - lcdc_write(par->dma_start, - &da8xx_fb_reg_base->dma_frm_buf_base_addr_0); - lcdc_write(par->dma_end, - &da8xx_fb_reg_base->dma_frm_buf_ceiling_addr_0); - lcdc_write(0, - &da8xx_fb_reg_base->dma_frm_buf_base_addr_1); - lcdc_write(0, - &da8xx_fb_reg_base->dma_frm_buf_ceiling_addr_1); -} - -static u32 lcdc_irq_handler_rev01(void) -{ - struct da8xx_fb_par *par = da8xx_fb_info->par; - u32 stat = lcdc_read(&da8xx_fb_reg_base->stat); - u32 reg_ras; - - if ((stat & LCD_SYNC_LOST) && (stat & LCD_FIFO_UNDERFLOW)) { - debug("LCD_SYNC_LOST\n"); - lcd_disable_raster(NO_WAIT_FOR_FRAME_DONE); - lcdc_write(stat, &da8xx_fb_reg_base->stat); - lcd_enable_raster(); - return LCD_SYNC_LOST; - } else if (stat & LCD_PL_LOAD_DONE) { - debug("LCD_PL_LOAD_DONE\n"); - /* - * Must disable raster before changing state of any control bit. - * And also must be disabled before clearing the PL loading - * interrupt via the following write to the status register. If - * this is done after then one gets multiple PL done interrupts. - */ - lcd_disable_raster(NO_WAIT_FOR_FRAME_DONE); - - lcdc_write(stat, &da8xx_fb_reg_base->stat); - - /* Disable PL completion interrupt */ - reg_ras = lcdc_read(&da8xx_fb_reg_base->raster_ctrl); - reg_ras &= ~LCD_V1_PL_INT_ENA; - lcdc_write(reg_ras, &da8xx_fb_reg_base->raster_ctrl); - - /* Setup and start data loading mode */ - lcd_blit(LOAD_DATA, par); - return LCD_PL_LOAD_DONE; - } else { - lcdc_write(stat, &da8xx_fb_reg_base->stat); - - if (stat & LCD_END_OF_FRAME0) - debug("LCD_END_OF_FRAME0\n"); - - lcdc_write(par->dma_start, - &da8xx_fb_reg_base->dma_frm_buf_base_addr_0); - lcdc_write(par->dma_end, - &da8xx_fb_reg_base->dma_frm_buf_ceiling_addr_0); - par->vsync_flag = 1; - return LCD_END_OF_FRAME0; - } - return stat; -} - -static u32 lcdc_irq_handler_rev02(void) -{ - struct da8xx_fb_par *par = da8xx_fb_info->par; - u32 stat = lcdc_read(&da8xx_fb_reg_base->masked_stat); - u32 reg_int; - - if ((stat & LCD_SYNC_LOST) && (stat & LCD_FIFO_UNDERFLOW)) { - debug("LCD_SYNC_LOST\n"); - lcd_disable_raster(NO_WAIT_FOR_FRAME_DONE); - lcdc_write(stat, &da8xx_fb_reg_base->masked_stat); - lcd_enable_raster(); - lcdc_write(0, &da8xx_fb_reg_base->end_of_int_ind); - return LCD_SYNC_LOST; - } else if (stat & LCD_PL_LOAD_DONE) { - debug("LCD_PL_LOAD_DONE\n"); - /* - * Must disable raster before changing state of any control bit. - * And also must be disabled before clearing the PL loading - * interrupt via the following write to the status register. If - * this is done after then one gets multiple PL done interrupts. - */ - lcd_disable_raster(NO_WAIT_FOR_FRAME_DONE); - - lcdc_write(stat, &da8xx_fb_reg_base->masked_stat); - - /* Disable PL completion interrupt */ - reg_int = lcdc_read(&da8xx_fb_reg_base->int_ena_clr) | - (LCD_V2_PL_INT_ENA); - lcdc_write(reg_int, &da8xx_fb_reg_base->int_ena_clr); - - /* Setup and start data loading mode */ - lcd_blit(LOAD_DATA, par); - lcdc_write(0, &da8xx_fb_reg_base->end_of_int_ind); - return LCD_PL_LOAD_DONE; - } else { - lcdc_write(stat, &da8xx_fb_reg_base->masked_stat); - - if (stat & LCD_END_OF_FRAME0) - debug("LCD_END_OF_FRAME0\n"); - - lcdc_write(par->dma_start, - &da8xx_fb_reg_base->dma_frm_buf_base_addr_0); - lcdc_write(par->dma_end, - &da8xx_fb_reg_base->dma_frm_buf_ceiling_addr_0); - par->vsync_flag = 1; - lcdc_write(0, &da8xx_fb_reg_base->end_of_int_ind); - return LCD_END_OF_FRAME0; - } - lcdc_write(0, &da8xx_fb_reg_base->end_of_int_ind); - return stat; -} - -static u32 lcdc_irq_handler(void) -{ - if (lcd_revision == LCD_VERSION_1) - return lcdc_irq_handler_rev01(); - else - return lcdc_irq_handler_rev02(); -} - -static u32 wait_for_event(u32 event) -{ - u32 timeout = 50000; - u32 ret; - - do { - ret = lcdc_irq_handler(); - udelay(1000); - --timeout; - } while (!(ret & event) && timeout); - - if (!(ret & event)) { - printf("%s: event %d not hit\n", __func__, event); - return -1; - } - - return 0; - -} - -void *video_hw_init(void) -{ - struct da8xx_fb_par *par; - u32 size; - u32 rev; - char *p; - - if (!lcd_panel) { - printf("Display not initialized\n"); - return NULL; - } - gpanel.winSizeX = lcd_panel->width; - gpanel.winSizeY = lcd_panel->height; - gpanel.plnSizeX = lcd_panel->width; - gpanel.plnSizeY = lcd_panel->height; - - switch (bits_x_pixel) { - case 32: - gpanel.gdfBytesPP = 4; - gpanel.gdfIndex = GDF_32BIT_X888RGB; - break; - case 24: - gpanel.gdfBytesPP = 4; - gpanel.gdfIndex = GDF_32BIT_X888RGB; - break; - case 16: - gpanel.gdfBytesPP = 2; - gpanel.gdfIndex = GDF_16BIT_565RGB; - break; - default: - gpanel.gdfBytesPP = 1; - gpanel.gdfIndex = GDF__8BIT_INDEX; - break; - } - - da8xx_fb_reg_base = (struct da8xx_lcd_regs *)DA8XX_LCD_CNTL_BASE; - - /* Determine LCD IP Version */ - rev = lcdc_read(&da8xx_fb_reg_base->revid); - switch (rev) { - case 0x4C100102: - lcd_revision = LCD_VERSION_1; - break; - case 0x4F200800: - case 0x4F201000: - lcd_revision = LCD_VERSION_2; - break; - default: - printf("Unknown PID Reg value 0x%x, defaulting to LCD revision 1\n", - rev); - lcd_revision = LCD_VERSION_1; - break; - } - - debug("rev: 0x%x Resolution: %dx%d %d\n", rev, - gpanel.winSizeX, - gpanel.winSizeY, - da8xx_lcd_cfg->bpp); - - size = sizeof(struct fb_info) + sizeof(struct da8xx_fb_par); - da8xx_fb_info = malloc_cache_aligned(size); - debug("da8xx_fb_info at %x\n", (unsigned int)da8xx_fb_info); - - if (!da8xx_fb_info) { - printf("Memory allocation failed for fb_info\n"); - return NULL; - } - memset(da8xx_fb_info, 0, size); - p = (char *)da8xx_fb_info; - da8xx_fb_info->par = p + sizeof(struct fb_info); - debug("da8xx_par at %x\n", (unsigned int)da8xx_fb_info->par); - - par = da8xx_fb_info->par; - par->pxl_clk = lcd_panel->pxl_clk; - - if (lcd_init(par, da8xx_lcd_cfg, lcd_panel) < 0) { - printf("lcd_init failed\n"); - goto err_release_fb; - } - - /* allocate frame buffer */ - par->vram_size = lcd_panel->width * lcd_panel->height * - da8xx_lcd_cfg->bpp; - par->vram_size = par->vram_size * LCD_NUM_BUFFERS / 8; - - par->vram_virt = malloc_cache_aligned(par->vram_size); - - par->vram_phys = (dma_addr_t) par->vram_virt; - debug("Requesting 0x%x bytes for framebuffer at 0x%x\n", - (unsigned int)par->vram_size, - (unsigned int)par->vram_virt); - if (!par->vram_virt) { - printf("GLCD: malloc for frame buffer failed\n"); - goto err_release_fb; - } - gd->fb_base = (int)par->vram_virt; - - gpanel.frameAdrs = (unsigned int)par->vram_virt; - da8xx_fb_info->screen_base = (char *) par->vram_virt; - da8xx_fb_fix.smem_start = gpanel.frameAdrs; - da8xx_fb_fix.smem_len = par->vram_size; - da8xx_fb_fix.line_length = (lcd_panel->width * da8xx_lcd_cfg->bpp) / 8; - - par->dma_start = par->vram_phys; - par->dma_end = par->dma_start + lcd_panel->height * - da8xx_fb_fix.line_length - 1; - - /* allocate palette buffer */ - par->v_palette_base = malloc_cache_aligned(PALETTE_SIZE); - if (!par->v_palette_base) { - printf("GLCD: malloc for palette buffer failed\n"); - goto err_release_fb_mem; - } - memset(par->v_palette_base, 0, PALETTE_SIZE); - par->p_palette_base = (unsigned int)par->v_palette_base; - - /* Initialize par */ - da8xx_fb_info->var.bits_per_pixel = da8xx_lcd_cfg->bpp; - - da8xx_fb_var.xres = lcd_panel->width; - da8xx_fb_var.xres_virtual = lcd_panel->width; - - da8xx_fb_var.yres = lcd_panel->height; - da8xx_fb_var.yres_virtual = lcd_panel->height * LCD_NUM_BUFFERS; - - da8xx_fb_var.grayscale = - da8xx_lcd_cfg->p_disp_panel->panel_shade == MONOCHROME ? 1 : 0; - da8xx_fb_var.bits_per_pixel = da8xx_lcd_cfg->bpp; - - da8xx_fb_var.hsync_len = lcd_panel->hsw; - da8xx_fb_var.vsync_len = lcd_panel->vsw; - - /* Initialize fbinfo */ - da8xx_fb_info->flags = FBINFO_FLAG_DEFAULT; - da8xx_fb_info->fix = da8xx_fb_fix; - da8xx_fb_info->var = da8xx_fb_var; - da8xx_fb_info->pseudo_palette = par->pseudo_palette; - da8xx_fb_info->fix.visual = (da8xx_fb_info->var.bits_per_pixel <= 8) ? - FB_VISUAL_PSEUDOCOLOR : FB_VISUAL_TRUECOLOR; - - /* Clear interrupt */ - memset((void *)par->vram_virt, 0, par->vram_size); - lcd_disable_raster(NO_WAIT_FOR_FRAME_DONE); - if (lcd_revision == LCD_VERSION_1) - lcdc_write(0xFFFF, &da8xx_fb_reg_base->stat); - else - lcdc_write(0xFFFF, &da8xx_fb_reg_base->masked_stat); - debug("Palette at 0x%x size %d\n", par->p_palette_base, - par->palette_sz); - lcdc_dma_start(); - - /* Load a default palette */ - fb_setcolreg(0, 0, 0, 0, 0xffff, da8xx_fb_info); - - /* Check that the palette is loaded */ - wait_for_event(LCD_PL_LOAD_DONE); - - /* Wait until DMA is working */ - wait_for_event(LCD_END_OF_FRAME0); - - return (void *)&gpanel; - -err_release_fb_mem: - free(par->vram_virt); - -err_release_fb: - free(da8xx_fb_info); - - return NULL; -} - -void da8xx_video_init(const struct da8xx_panel *panel, - const struct lcd_ctrl_config *lcd_cfg, int bits_pixel) -{ - lcd_panel = panel; - da8xx_lcd_cfg = lcd_cfg; - bits_x_pixel = bits_pixel; -} diff --git a/drivers/video/da8xx-fb.h b/drivers/video/da8xx-fb.h deleted file mode 100644 index 9b30d984741..00000000000 --- a/drivers/video/da8xx-fb.h +++ /dev/null @@ -1,115 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Porting to u-boot: - * - * (C) Copyright 2011 - * Stefano Babic, DENX Software Engineering, sbabic@denx.de. - * - * Copyright (C) 2008-2009 MontaVista Software Inc. - * Copyright (C) 2008-2009 Texas Instruments Inc - * - * Based on the LCD driver for TI Avalanche processors written by - * Ajay Singh and Shalom Hai. - */ - -#ifndef DA8XX_FB_H -#define DA8XX_FB_H - -enum panel_type { - QVGA = 0, - WVGA -}; - -enum panel_shade { - MONOCHROME = 0, - COLOR_ACTIVE, - COLOR_PASSIVE, -}; - -enum raster_load_mode { - LOAD_DATA = 1, - LOAD_PALETTE, -}; - -struct display_panel { - enum panel_type panel_type; /* QVGA */ - int max_bpp; - int min_bpp; - enum panel_shade panel_shade; -}; - -struct da8xx_panel { - const char name[25]; /* Full name <vendor>_<model> */ - unsigned short width; - unsigned short height; - int hfp; /* Horizontal front porch */ - int hbp; /* Horizontal back porch */ - int hsw; /* Horizontal Sync Pulse Width */ - int vfp; /* Vertical front porch */ - int vbp; /* Vertical back porch */ - int vsw; /* Vertical Sync Pulse Width */ - unsigned int pxl_clk; /* Pixel clock */ - unsigned char invert_pxl_clk; /* Invert Pixel clock */ -}; - -struct da8xx_lcdc_platform_data { - const char manu_name[10]; - void *controller_data; - const char type[25]; - void (*panel_power_ctrl)(int); -}; - -struct lcd_ctrl_config { - const struct display_panel *p_disp_panel; - - /* AC Bias Pin Frequency */ - int ac_bias; - - /* AC Bias Pin Transitions per Interrupt */ - int ac_bias_intrpt; - - /* DMA burst size */ - int dma_burst_sz; - - /* Bits per pixel */ - int bpp; - - /* FIFO DMA Request Delay */ - int fdd; - - /* TFT Alternative Signal Mapping (Only for active) */ - unsigned char tft_alt_mode; - - /* 12 Bit Per Pixel (5-6-5) Mode (Only for passive) */ - unsigned char stn_565_mode; - - /* Mono 8-bit Mode: 1=D0-D7 or 0=D0-D3 */ - unsigned char mono_8bit_mode; - - /* Invert line clock */ - unsigned char invert_line_clock; - - /* Invert frame clock */ - unsigned char invert_frm_clock; - - /* Horizontal and Vertical Sync Edge: 0=rising 1=falling */ - unsigned char sync_edge; - - /* Horizontal and Vertical Sync: Control: 0=ignore */ - unsigned char sync_ctrl; - - /* Raster Data Order Select: 1=Most-to-least 0=Least-to-most */ - unsigned char raster_order; -}; - -struct lcd_sync_arg { - int back_porch; - int front_porch; - int pulse_width; -}; - -void da8xx_video_init(const struct da8xx_panel *panel, - const struct lcd_ctrl_config *lcd_cfg, - int bits_pixel); - -#endif /* ifndef DA8XX_FB_H */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 89f6717fdd9..536a8ee13f6 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2118,7 +2118,6 @@ CONFIG_U_BOOT_HDR_SIZE CONFIG_VAR_SIZE_SPL CONFIG_VERY_BIG_RAM CONFIG_VIDEO_BCM2835 -CONFIG_VIDEO_DA8XX CONFIG_VSC7385_ENET CONFIG_VSC7385_IMAGE CONFIG_VSC7385_IMAGE_SIZE
This does not use driver model and is more than two years past the migration date. Drop it.
It can be added back later if needed.
arch/arm/cpu/armv7/ls102xa/soc.c | 4 - arch/arm/include/asm/arch-ls102xa/config.h | 1 - board/freescale/common/Makefile | 2 - board/freescale/common/dcu_sii9022a.c | 248 ---------- board/freescale/common/dcu_sii9022a.h | 12 - board/freescale/ls1021aiot/Makefile | 1 - board/freescale/ls1021aiot/dcu.c | 48 -- board/freescale/ls1021aqds/Makefile | 1 - board/freescale/ls1021aqds/dcu.c | 110 ----- board/freescale/ls1021atwr/Makefile | 1 - board/freescale/ls1021atwr/dcu.c | 48 -- board/toradex/colibri_vf/Makefile | 1 - board/toradex/colibri_vf/colibri_vf.c | 62 --- board/toradex/colibri_vf/dcu.c | 38 -- configs/colibri_vf_defconfig | 1 - drivers/video/Kconfig | 15 - drivers/video/Makefile | 1 - drivers/video/fsl_dcu_fb.c | 548 --------------------- include/configs/colibri_vf.h | 7 - include/configs/ls1021aqds.h | 10 - include/configs/ls1021atwr.h | 13 - include/fsl_dcu_fb.h | 22 - scripts/config_whitelist.txt | 3 - 23 files changed, 1197 deletions(-) delete mode 100644 board/freescale/common/dcu_sii9022a.c delete mode 100644 board/freescale/common/dcu_sii9022a.h delete mode 100644 board/freescale/ls1021aiot/dcu.c delete mode 100644 board/freescale/ls1021aqds/dcu.c delete mode 100644 board/freescale/ls1021atwr/dcu.c delete mode 100644 board/toradex/colibri_vf/dcu.c delete mode 100644 drivers/video/fsl_dcu_fb.c delete mode 100644 include/fsl_dcu_fb.h
diff --git a/arch/arm/cpu/armv7/ls102xa/soc.c b/arch/arm/cpu/armv7/ls102xa/soc.c index 8a95ee86a9b..f5e4bd4bc0c 100644 --- a/arch/arm/cpu/armv7/ls102xa/soc.c +++ b/arch/arm/cpu/armv7/ls102xa/soc.c @@ -172,10 +172,6 @@ int arch_soc_init(void) out_be32(&scfg->qspi_cfg, SCFG_QSPI_CLKSEL); #endif
-#ifdef CONFIG_VIDEO_FSL_DCU_FB - out_be32(&scfg->pixclkcr, SCFG_PIXCLKCR_PXCKEN); -#endif - /* Configure Little endian for SAI, ASRC and SPDIF */ out_be32(&scfg->endiancr, SCFG_ENDIANCR_LE);
diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index 0e1f9e0c0d8..50e9d08f323 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -93,7 +93,6 @@ #define CONFIG_SYS_FSL_ESDHC_BE #define CONFIG_SYS_FSL_WDOG_BE #define CONFIG_SYS_FSL_DSPI_BE -#define CONFIG_SYS_FSL_DCU_BE #define CONFIG_SYS_FSL_SEC_MON_LE #define CONFIG_SYS_FSL_SFP_VER_3_2 #define CONFIG_SYS_FSL_SFP_BE diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index 0ddfb59d7de..c8f62bfc198 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -52,8 +52,6 @@ else obj-$(CONFIG_DEEP_SLEEP) += mpc85xx_sleep.o endif
-obj-$(CONFIG_FSL_DCU_SII9022A) += dcu_sii9022a.o - obj-$(CONFIG_TARGET_MPC8548CDS) += cds_pci_ft.o
obj-$(CONFIG_TARGET_MPC8536DS) += ics307_clk.o diff --git a/board/freescale/common/dcu_sii9022a.c b/board/freescale/common/dcu_sii9022a.c deleted file mode 100644 index 9137d246ea0..00000000000 --- a/board/freescale/common/dcu_sii9022a.c +++ /dev/null @@ -1,248 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2014 Freescale Semiconductor, Inc. - * Copyright 2019 NXP - */ - -#include <asm/io.h> -#include <common.h> -#include <fsl_dcu_fb.h> -#include <i2c.h> -#include <linux/fb.h> - -#define PIXEL_CLK_LSB_REG 0x00 -#define PIXEL_CLK_MSB_REG 0x01 -#define VERT_FREQ_LSB_REG 0x02 -#define VERT_FREQ_MSB_REG 0x03 -#define TOTAL_PIXELS_LSB_REG 0x04 -#define TOTAL_PIXELS_MSB_REG 0x05 -#define TOTAL_LINES_LSB_REG 0x06 -#define TOTAL_LINES_MSB_REG 0x07 -#define TPI_INBUS_FMT_REG 0x08 -#define TPI_INPUT_FMT_REG 0x09 -#define TPI_OUTPUT_FMT_REG 0x0A -#define TPI_SYS_CTRL_REG 0x1A -#define TPI_PWR_STAT_REG 0x1E -#define TPI_AUDIO_HANDING_REG 0x25 -#define TPI_AUDIO_INTF_REG 0x26 -#define TPI_AUDIO_FREQ_REG 0x27 -#define TPI_SET_PAGE_REG 0xBC -#define TPI_SET_OFFSET_REG 0xBD -#define TPI_RW_ACCESS_REG 0xBE -#define TPI_TRANS_MODE_REG 0xC7 - -#define TPI_INBUS_CLOCK_RATIO_1 (1 << 6) -#define TPI_INBUS_FULL_PIXEL_WIDE (1 << 5) -#define TPI_INBUS_RISING_EDGE (1 << 4) -#define TPI_INPUT_CLR_DEPTH_8BIT (0 << 6) -#define TPI_INPUT_VRANGE_EXPAN_AUTO (0 << 2) -#define TPI_INPUT_CLR_RGB (0 << 0) -#define TPI_OUTPUT_CLR_DEPTH_8BIT (0 << 6) -#define TPI_OUTPUT_VRANGE_COMPRE_AUTO (0 << 2) -#define TPI_OUTPUT_CLR_HDMI_RGB (0 << 0) -#define TPI_SYS_TMDS_OUTPUT (0 << 4) -#define TPI_SYS_AV_NORAML (0 << 3) -#define TPI_SYS_AV_MUTE (1 << 3) -#define TPI_SYS_DVI_MODE (0 << 0) -#define TPI_SYS_HDMI_MODE (1 << 0) -#define TPI_PWR_STAT_MASK (3 << 0) -#define TPI_PWR_STAT_D0 (0 << 0) -#define TPI_AUDIO_PASS_BASIC (0 << 0) -#define TPI_AUDIO_INTF_I2S (2 << 6) -#define TPI_AUDIO_INTF_NORMAL (0 << 4) -#define TPI_AUDIO_TYPE_PCM (1 << 0) -#define TPI_AUDIO_SAMP_SIZE_16BIT (1 << 6) -#define TPI_AUDIO_SAMP_FREQ_44K (2 << 3) -#define TPI_SET_PAGE_SII9022A 0x01 -#define TPI_SET_OFFSET_SII9022A 0x82 -#define TPI_RW_EN_SRC_TERMIN (1 << 0) -#define TPI_TRANS_MODE_ENABLE (0 << 7) - -/* Programming of Silicon SIi9022a HDMI Transmitter */ -int dcu_set_dvi_encoder(struct fb_videomode *videomode) -{ - u8 temp; - u16 temp1, temp2; - u32 temp3; -#if CONFIG_IS_ENABLED(DM_I2C) - struct udevice *dev; - int ret; - - ret = i2c_get_chip_for_busnum(CONFIG_SYS_I2C_DVI_BUS_NUM, - CONFIG_SYS_I2C_DVI_ADDR, - 1, &dev); - if (ret) { - printf("%s: Cannot find udev for a bus %d\n", __func__, - CONFIG_SYS_I2C_DVI_BUS_NUM); - return ret; - } - - /* Enable TPI transmitter mode */ - temp = TPI_TRANS_MODE_ENABLE; - dm_i2c_write(dev, TPI_TRANS_MODE_REG, &temp, 1); - - /* Enter into D0 state, full operation */ - dm_i2c_read(dev, TPI_PWR_STAT_REG, &temp, 1); - temp &= ~TPI_PWR_STAT_MASK; - temp |= TPI_PWR_STAT_D0; - dm_i2c_write(dev, TPI_PWR_STAT_REG, &temp, 1); - - /* Enable source termination */ - temp = TPI_SET_PAGE_SII9022A; - dm_i2c_write(dev, TPI_SET_PAGE_REG, &temp, 1); - temp = TPI_SET_OFFSET_SII9022A; - dm_i2c_write(dev, TPI_SET_OFFSET_REG, &temp, 1); - - dm_i2c_read(dev, TPI_RW_ACCESS_REG, &temp, 1); - temp |= TPI_RW_EN_SRC_TERMIN; - dm_i2c_write(dev, TPI_RW_ACCESS_REG, &temp, 1); - - /* Set TPI system control */ - temp = TPI_SYS_TMDS_OUTPUT | TPI_SYS_AV_NORAML | TPI_SYS_DVI_MODE; - dm_i2c_write(dev, TPI_SYS_CTRL_REG, &temp, 1); - - /* Set pixel clock */ - temp1 = PICOS2KHZ(videomode->pixclock) / 10; - temp = (u8)(temp1 & 0xFF); - dm_i2c_write(dev, PIXEL_CLK_LSB_REG, &temp, 1); - temp = (u8)(temp1 >> 8); - dm_i2c_write(dev, PIXEL_CLK_MSB_REG, &temp, 1); - - /* Set total pixels per line */ - temp1 = videomode->hsync_len + videomode->left_margin + - videomode->xres + videomode->right_margin; - temp = (u8)(temp1 & 0xFF); - dm_i2c_write(dev, TOTAL_PIXELS_LSB_REG, &temp, 1); - temp = (u8)(temp1 >> 8); - dm_i2c_write(dev, TOTAL_PIXELS_MSB_REG, &temp, 1); - - /* Set total lines */ - temp2 = videomode->vsync_len + videomode->upper_margin + - videomode->yres + videomode->lower_margin; - temp = (u8)(temp2 & 0xFF); - dm_i2c_write(dev, TOTAL_LINES_LSB_REG, &temp, 1); - temp = (u8)(temp2 >> 8); - dm_i2c_write(dev, TOTAL_LINES_MSB_REG, &temp, 1); - - /* Set vertical frequency in Hz */ - temp3 = temp1 * temp2; - temp3 = (PICOS2KHZ(videomode->pixclock) * 1000) / temp3; - temp1 = (u16)temp3 * 100; - temp = (u8)(temp1 & 0xFF); - dm_i2c_write(dev, VERT_FREQ_LSB_REG, &temp, 1); - temp = (u8)(temp1 >> 8); - dm_i2c_write(dev, VERT_FREQ_MSB_REG, &temp, 1); - - /* Set TPI input bus and pixel repetition data */ - temp = TPI_INBUS_CLOCK_RATIO_1 | TPI_INBUS_FULL_PIXEL_WIDE | - TPI_INBUS_RISING_EDGE; - dm_i2c_write(dev, TPI_INBUS_FMT_REG, &temp, 1); - - /* Set TPI AVI Input format data */ - temp = TPI_INPUT_CLR_DEPTH_8BIT | TPI_INPUT_VRANGE_EXPAN_AUTO | - TPI_INPUT_CLR_RGB; - dm_i2c_write(dev, TPI_INPUT_FMT_REG, &temp, 1); - - /* Set TPI AVI Output format data */ - temp = TPI_OUTPUT_CLR_DEPTH_8BIT | TPI_OUTPUT_VRANGE_COMPRE_AUTO | - TPI_OUTPUT_CLR_HDMI_RGB; - dm_i2c_write(dev, TPI_OUTPUT_FMT_REG, &temp, 1); - - /* Set TPI audio configuration write data */ - temp = TPI_AUDIO_PASS_BASIC; - dm_i2c_write(dev, TPI_AUDIO_HANDING_REG, &temp, 1); - - temp = TPI_AUDIO_INTF_I2S | TPI_AUDIO_INTF_NORMAL | - TPI_AUDIO_TYPE_PCM; - dm_i2c_write(dev, TPI_AUDIO_INTF_REG, &temp, 1); - - temp = TPI_AUDIO_SAMP_SIZE_16BIT | TPI_AUDIO_SAMP_FREQ_44K; - dm_i2c_write(dev, TPI_AUDIO_FREQ_REG, &temp, 1); -#else - i2c_set_bus_num(CONFIG_SYS_I2C_DVI_BUS_NUM); - - /* Enable TPI transmitter mode */ - temp = TPI_TRANS_MODE_ENABLE; - i2c_write(CONFIG_SYS_I2C_DVI_ADDR, TPI_TRANS_MODE_REG, 1, &temp, 1); - - /* Enter into D0 state, full operation */ - i2c_read(CONFIG_SYS_I2C_DVI_ADDR, TPI_PWR_STAT_REG, 1, &temp, 1); - temp &= ~TPI_PWR_STAT_MASK; - temp |= TPI_PWR_STAT_D0; - i2c_write(CONFIG_SYS_I2C_DVI_ADDR, TPI_PWR_STAT_REG, 1, &temp, 1); - - /* Enable source termination */ - temp = TPI_SET_PAGE_SII9022A; - i2c_write(CONFIG_SYS_I2C_DVI_ADDR, TPI_SET_PAGE_REG, 1, &temp, 1); - temp = TPI_SET_OFFSET_SII9022A; - i2c_write(CONFIG_SYS_I2C_DVI_ADDR, TPI_SET_OFFSET_REG, 1, &temp, 1); - - i2c_read(CONFIG_SYS_I2C_DVI_ADDR, TPI_RW_ACCESS_REG, 1, &temp, 1); - temp |= TPI_RW_EN_SRC_TERMIN; - i2c_write(CONFIG_SYS_I2C_DVI_ADDR, TPI_RW_ACCESS_REG, 1, &temp, 1); - - /* Set TPI system control */ - temp = TPI_SYS_TMDS_OUTPUT | TPI_SYS_AV_NORAML | TPI_SYS_DVI_MODE; - i2c_write(CONFIG_SYS_I2C_DVI_ADDR, TPI_SYS_CTRL_REG, 1, &temp, 1); - - /* Set pixel clock */ - temp1 = PICOS2KHZ(videomode->pixclock) / 10; - temp = (u8)(temp1 & 0xFF); - i2c_write(CONFIG_SYS_I2C_DVI_ADDR, PIXEL_CLK_LSB_REG, 1, &temp, 1); - temp = (u8)(temp1 >> 8); - i2c_write(CONFIG_SYS_I2C_DVI_ADDR, PIXEL_CLK_MSB_REG, 1, &temp, 1); - - /* Set total pixels per line */ - temp1 = videomode->hsync_len + videomode->left_margin + - videomode->xres + videomode->right_margin; - temp = (u8)(temp1 & 0xFF); - i2c_write(CONFIG_SYS_I2C_DVI_ADDR, TOTAL_PIXELS_LSB_REG, 1, &temp, 1); - temp = (u8)(temp1 >> 8); - i2c_write(CONFIG_SYS_I2C_DVI_ADDR, TOTAL_PIXELS_MSB_REG, 1, &temp, 1); - - /* Set total lines */ - temp2 = videomode->vsync_len + videomode->upper_margin + - videomode->yres + videomode->lower_margin; - temp = (u8)(temp2 & 0xFF); - i2c_write(CONFIG_SYS_I2C_DVI_ADDR, TOTAL_LINES_LSB_REG, 1, &temp, 1); - temp = (u8)(temp2 >> 8); - i2c_write(CONFIG_SYS_I2C_DVI_ADDR, TOTAL_LINES_MSB_REG, 1, &temp, 1); - - /* Set vertical frequency in Hz */ - temp3 = temp1 * temp2; - temp3 = (PICOS2KHZ(videomode->pixclock) * 1000) / temp3; - temp1 = (u16)temp3 * 100; - temp = (u8)(temp1 & 0xFF); - i2c_write(CONFIG_SYS_I2C_DVI_ADDR, VERT_FREQ_LSB_REG, 1, &temp, 1); - temp = (u8)(temp1 >> 8); - i2c_write(CONFIG_SYS_I2C_DVI_ADDR, VERT_FREQ_MSB_REG, 1, &temp, 1); - - /* Set TPI input bus and pixel repetition data */ - temp = TPI_INBUS_CLOCK_RATIO_1 | TPI_INBUS_FULL_PIXEL_WIDE | - TPI_INBUS_RISING_EDGE; - i2c_write(CONFIG_SYS_I2C_DVI_ADDR, TPI_INBUS_FMT_REG, 1, &temp, 1); - - /* Set TPI AVI Input format data */ - temp = TPI_INPUT_CLR_DEPTH_8BIT | TPI_INPUT_VRANGE_EXPAN_AUTO | - TPI_INPUT_CLR_RGB; - i2c_write(CONFIG_SYS_I2C_DVI_ADDR, TPI_INPUT_FMT_REG, 1, &temp, 1); - - /* Set TPI AVI Output format data */ - temp = TPI_OUTPUT_CLR_DEPTH_8BIT | TPI_OUTPUT_VRANGE_COMPRE_AUTO | - TPI_OUTPUT_CLR_HDMI_RGB; - i2c_write(CONFIG_SYS_I2C_DVI_ADDR, TPI_OUTPUT_FMT_REG, 1, &temp, 1); - - /* Set TPI audio configuration write data */ - temp = TPI_AUDIO_PASS_BASIC; - i2c_write(CONFIG_SYS_I2C_DVI_ADDR, TPI_AUDIO_HANDING_REG, 1, &temp, 1); - - temp = TPI_AUDIO_INTF_I2S | TPI_AUDIO_INTF_NORMAL | - TPI_AUDIO_TYPE_PCM; - i2c_write(CONFIG_SYS_I2C_DVI_ADDR, TPI_AUDIO_INTF_REG, 1, &temp, 1); - - temp = TPI_AUDIO_SAMP_SIZE_16BIT | TPI_AUDIO_SAMP_FREQ_44K; - i2c_write(CONFIG_SYS_I2C_DVI_ADDR, TPI_AUDIO_FREQ_REG, 1, &temp, 1); -#endif - - return 0; -} diff --git a/board/freescale/common/dcu_sii9022a.h b/board/freescale/common/dcu_sii9022a.h deleted file mode 100644 index 7851775530d..00000000000 --- a/board/freescale/common/dcu_sii9022a.h +++ /dev/null @@ -1,12 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright 2014 Freescale Semiconductor, Inc. - */ - -#ifndef __DCU_HDMI_SII9022A__ -#define __DCU_HDMI_SII9022A__ - -/* Programming of Silicon SII9022A connector HDMI Transmitter*/ -int dcu_set_dvi_encoder(struct fb_videomode *videomode); - -#endif diff --git a/board/freescale/ls1021aiot/Makefile b/board/freescale/ls1021aiot/Makefile index bec151fd2ac..587bbd79ddf 100644 --- a/board/freescale/ls1021aiot/Makefile +++ b/board/freescale/ls1021aiot/Makefile @@ -3,5 +3,4 @@ # Copyright 2016 Freescale Semiconductor, Inc.
obj-y += ls1021aiot.o -obj-$(CONFIG_VIDEO_FSL_DCU_FB) += dcu.o obj-$(CONFIG_ARMV7_PSCI) += psci.o diff --git a/board/freescale/ls1021aiot/dcu.c b/board/freescale/ls1021aiot/dcu.c deleted file mode 100644 index e4fbcbcaad3..00000000000 --- a/board/freescale/ls1021aiot/dcu.c +++ /dev/null @@ -1,48 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2016 Freescale Semiconductor, Inc. - * - * FSL DCU Framebuffer driver - */ - -#include <common.h> -#include <fsl_dcu_fb.h> -#include <asm/global_data.h> -#include "div64.h" -#include "../common/dcu_sii9022a.h" - -DECLARE_GLOBAL_DATA_PTR; - -unsigned int dcu_set_pixel_clock(unsigned int pixclock) -{ - unsigned long long div; - - div = (unsigned long long)(gd->bus_clk / 1000); - div *= (unsigned long long)pixclock; - do_div(div, 1000000000); - - return div; -} - -int platform_dcu_init(struct fb_info *fbinfo, - unsigned int xres, unsigned int yres, - const char *port, - struct fb_videomode *dcu_fb_videomode) -{ - const char *name; - unsigned int pixel_format; - - if (strncmp(port, "twr_lcd", 4) == 0) { - name = "TWR_LCD_RGB card"; - } else { - name = "HDMI"; - dcu_set_dvi_encoder(dcu_fb_videomode); - } - - printf("DCU: Switching to %s monitor @ %ux%u\n", name, xres, yres); - - pixel_format = 32; - fsl_dcu_init(fbinfo, xres, yres, pixel_format); - - return 0; -} diff --git a/board/freescale/ls1021aqds/Makefile b/board/freescale/ls1021aqds/Makefile index 1e50e468a32..65030342be3 100644 --- a/board/freescale/ls1021aqds/Makefile +++ b/board/freescale/ls1021aqds/Makefile @@ -7,5 +7,4 @@ obj-y += ls1021aqds.o obj-y += ddr.o obj-y += eth.o -obj-$(CONFIG_VIDEO_FSL_DCU_FB) += dcu.o obj-$(CONFIG_ARMV7_PSCI) += psci.o diff --git a/board/freescale/ls1021aqds/dcu.c b/board/freescale/ls1021aqds/dcu.c deleted file mode 100644 index b5fee06b5b0..00000000000 --- a/board/freescale/ls1021aqds/dcu.c +++ /dev/null @@ -1,110 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2014 Freescale Semiconductor, Inc. - * Copyright 2019 NXP - * - * FSL DCU Framebuffer driver - */ - -#include <asm/global_data.h> -#include <asm/io.h> -#include <common.h> -#include <fsl_dcu_fb.h> -#include <i2c.h> -#include "../common/i2c_mux.h" -#include "div64.h" -#include "../common/diu_ch7301.h" -#include "ls1021aqds_qixis.h" - -DECLARE_GLOBAL_DATA_PTR; - -unsigned int dcu_set_pixel_clock(unsigned int pixclock) -{ - unsigned long long div; - - div = (unsigned long long)(gd->bus_clk / 1000); - div *= (unsigned long long)pixclock; - do_div(div, 1000000000); - - return div; -} - -int platform_dcu_init(struct fb_info *fbinfo, - unsigned int xres, - unsigned int yres, - const char *port, - struct fb_videomode *dcu_fb_videomode) -{ - const char *name; - unsigned int pixel_format; - int ret; - u8 ch; - - /* Mux I2C3+I2C4 as HSYNC+VSYNC */ -#if CONFIG_IS_ENABLED(DM_I2C) - struct udevice *dev; - - /* QIXIS device mount on I2C1 bus*/ - ret = i2c_get_chip_for_busnum(0, CONFIG_SYS_I2C_QIXIS_ADDR, - 1, &dev); - if (ret) { - printf("%s: Cannot find udev for a bus %d\n", __func__, - 0); - return ret; - } - ret = dm_i2c_read(dev, QIXIS_DCU_BRDCFG5, &ch, 1); - if (ret) { - printf("Error: failed to read I2C @%02x\n", - CONFIG_SYS_I2C_QIXIS_ADDR); - return ret; - } - ch &= 0x1F; - ch |= 0xA0; - ret = dm_i2c_write(dev, QIXIS_DCU_BRDCFG5, &ch, 1); - -#else - ret = i2c_read(CONFIG_SYS_I2C_QIXIS_ADDR, QIXIS_DCU_BRDCFG5, - 1, &ch, 1); - if (ret) { - printf("Error: failed to read I2C @%02x\n", - CONFIG_SYS_I2C_QIXIS_ADDR); - return ret; - } - ch &= 0x1F; - ch |= 0xA0; - ret = i2c_write(CONFIG_SYS_I2C_QIXIS_ADDR, QIXIS_DCU_BRDCFG5, - 1, &ch, 1); -#endif - if (ret) { - printf("Error: failed to write I2C @%02x\n", - CONFIG_SYS_I2C_QIXIS_ADDR); - return ret; - } - - if (strncmp(port, "hdmi", 4) == 0) { - unsigned long pixval; - - name = "HDMI"; - - pixval = 1000000000 / dcu_fb_videomode->pixclock; - pixval *= 1000; - -#if !CONFIG_IS_ENABLED(DM_I2C) - i2c_set_bus_num(CONFIG_SYS_I2C_DVI_BUS_NUM); -#endif - select_i2c_ch_pca9547(I2C_MUX_CH_CH7301, - CONFIG_SYS_I2C_DVI_BUS_NUM); - diu_set_dvi_encoder(pixval); - select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT, - CONFIG_SYS_I2C_DVI_BUS_NUM); - } else { - return 0; - } - - printf("DCU: Switching to %s monitor @ %ux%u\n", name, xres, yres); - - pixel_format = 32; - fsl_dcu_init(fbinfo, xres, yres, pixel_format); - - return 0; -} diff --git a/board/freescale/ls1021atwr/Makefile b/board/freescale/ls1021atwr/Makefile index d9a2f52f2b6..cfa6c0c8540 100644 --- a/board/freescale/ls1021atwr/Makefile +++ b/board/freescale/ls1021atwr/Makefile @@ -5,5 +5,4 @@ #
obj-y += ls1021atwr.o -obj-$(CONFIG_VIDEO_FSL_DCU_FB) += dcu.o obj-$(CONFIG_ARMV7_PSCI) += psci.o diff --git a/board/freescale/ls1021atwr/dcu.c b/board/freescale/ls1021atwr/dcu.c deleted file mode 100644 index 7bf283e3d66..00000000000 --- a/board/freescale/ls1021atwr/dcu.c +++ /dev/null @@ -1,48 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2014 Freescale Semiconductor, Inc. - * - * FSL DCU Framebuffer driver - */ - -#include <common.h> -#include <fsl_dcu_fb.h> -#include <asm/global_data.h> -#include "div64.h" -#include "../common/dcu_sii9022a.h" - -DECLARE_GLOBAL_DATA_PTR; - -unsigned int dcu_set_pixel_clock(unsigned int pixclock) -{ - unsigned long long div; - - div = (unsigned long long)(gd->bus_clk / 1000); - div *= (unsigned long long)pixclock; - do_div(div, 1000000000); - - return div; -} - -int platform_dcu_init(struct fb_info *fbinfo, - unsigned int xres, unsigned int yres, - const char *port, - struct fb_videomode *dcu_fb_videomode) -{ - const char *name; - unsigned int pixel_format; - - if (strncmp(port, "twr_lcd", 4) == 0) { - name = "TWR_LCD_RGB card"; - } else { - name = "HDMI"; - dcu_set_dvi_encoder(dcu_fb_videomode); - } - - printf("DCU: Switching to %s monitor @ %ux%u\n", name, xres, yres); - - pixel_format = 32; - fsl_dcu_init(fbinfo, xres, yres, pixel_format); - - return 0; -} diff --git a/board/toradex/colibri_vf/Makefile b/board/toradex/colibri_vf/Makefile index 6272a774963..9be2cbc037b 100644 --- a/board/toradex/colibri_vf/Makefile +++ b/board/toradex/colibri_vf/Makefile @@ -3,4 +3,3 @@ # Copyright 2013 Freescale Semiconductor, Inc.
obj-y := colibri_vf.o -obj-$(CONFIG_VIDEO_FSL_DCU_FB) += dcu.o diff --git a/board/toradex/colibri_vf/colibri_vf.c b/board/toradex/colibri_vf/colibri_vf.c index c09591e5436..dcef2db360a 100644 --- a/board/toradex/colibri_vf/colibri_vf.c +++ b/board/toradex/colibri_vf/colibri_vf.c @@ -19,7 +19,6 @@ #include <asm/io.h> #include <env.h> #include <fdt_support.h> -#include <fsl_dcu_fb.h> #include <g_dnl.h> #include <jffs2/load_kernel.h> #include <mtd_node.h> @@ -205,49 +204,6 @@ static void setup_iomux_gpio(void) } #endif
-#ifdef CONFIG_VIDEO_FSL_DCU_FB -static void setup_iomux_fsl_dcu(void) -{ - static const iomux_v3_cfg_t dcu0_pads[] = { - VF610_PAD_PTE0__DCU0_HSYNC, - VF610_PAD_PTE1__DCU0_VSYNC, - VF610_PAD_PTE2__DCU0_PCLK, - VF610_PAD_PTE4__DCU0_DE, - VF610_PAD_PTE5__DCU0_R0, - VF610_PAD_PTE6__DCU0_R1, - VF610_PAD_PTE7__DCU0_R2, - VF610_PAD_PTE8__DCU0_R3, - VF610_PAD_PTE9__DCU0_R4, - VF610_PAD_PTE10__DCU0_R5, - VF610_PAD_PTE11__DCU0_R6, - VF610_PAD_PTE12__DCU0_R7, - VF610_PAD_PTE13__DCU0_G0, - VF610_PAD_PTE14__DCU0_G1, - VF610_PAD_PTE15__DCU0_G2, - VF610_PAD_PTE16__DCU0_G3, - VF610_PAD_PTE17__DCU0_G4, - VF610_PAD_PTE18__DCU0_G5, - VF610_PAD_PTE19__DCU0_G6, - VF610_PAD_PTE20__DCU0_G7, - VF610_PAD_PTE21__DCU0_B0, - VF610_PAD_PTE22__DCU0_B1, - VF610_PAD_PTE23__DCU0_B2, - VF610_PAD_PTE24__DCU0_B3, - VF610_PAD_PTE25__DCU0_B4, - VF610_PAD_PTE26__DCU0_B5, - VF610_PAD_PTE27__DCU0_B6, - VF610_PAD_PTE28__DCU0_B7, - }; - - imx_iomux_v3_setup_multiple_pads(dcu0_pads, ARRAY_SIZE(dcu0_pads)); -} - -static void setup_tcon(void) -{ - setbits_le32(TCON0_BASE_ADDR, (1 << 29)); -} -#endif - static inline int is_colibri_vf61(void) { struct mscm *mscm = (struct mscm *)MSCM_BASE_ADDR; @@ -353,11 +309,6 @@ static void clock_init(void) CCM_CSCDR3_NFC_PRE_DIV(3)); clrsetbits_le32(&ccm->cscmr2, CCM_REG_CTRL_MASK, CCM_CSCMR2_RMII_CLK_SEL(2)); - -#ifdef CONFIG_VIDEO_FSL_DCU_FB - setbits_le32(&ccm->ccgr1, CCM_CCGR1_TCON0_CTRL_MASK); - setbits_le32(&ccm->ccgr3, CCM_CCGR3_DCU0_CTRL_MASK); -#endif }
static void mscm_init(void) @@ -378,11 +329,6 @@ int board_early_init_f(void) setup_iomux_gpio(); #endif
-#ifdef CONFIG_VIDEO_FSL_DCU_FB - setup_tcon(); - setup_iomux_fsl_dcu(); -#endif - return 0; }
@@ -433,9 +379,6 @@ int checkboard(void) #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, struct bd_info *bd) { -#if defined(CONFIG_VIDEO_FSL_DCU_FB) && !defined(CONFIG_DM_VIDEO) - int ret = 0; -#endif #ifdef CONFIG_FDT_FIXUP_PARTITIONS static const struct node_info nodes[] = { { "fsl,vf610-nfc", MTD_DEV_TYPE_NAND, }, /* NAND flash */ @@ -445,11 +388,6 @@ int ft_board_setup(void *blob, struct bd_info *bd) puts(" Updating MTD partitions...\n"); fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes)); #endif -#if defined(CONFIG_VIDEO_FSL_DCU_FB) && !defined(CONFIG_DM_VIDEO) - ret = fsl_dcu_fixedfb_setup(blob); - if (ret) - return ret; -#endif
return ft_common_board_setup(blob, bd); } diff --git a/board/toradex/colibri_vf/dcu.c b/board/toradex/colibri_vf/dcu.c deleted file mode 100644 index c688ed79ffd..00000000000 --- a/board/toradex/colibri_vf/dcu.c +++ /dev/null @@ -1,38 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2017 Toradex AG - * - * FSL DCU platform driver - */ - -#include <asm/arch/crm_regs.h> -#include <asm/io.h> -#include <common.h> -#include <fsl_dcu_fb.h> -#include "div64.h" - -unsigned int dcu_set_pixel_clock(unsigned int pixclock) -{ - struct ccm_reg *ccm = (struct ccm_reg *)CCM_BASE_ADDR; - unsigned long long div; - - clrbits_le32(&ccm->cscmr1, CCM_CSCMR1_DCU0_CLK_SEL); - clrsetbits_le32(&ccm->cscdr3, - CCM_CSCDR3_DCU0_DIV_MASK | CCM_CSCDR3_DCU0_EN, - CCM_CSCDR3_DCU0_DIV(0) | CCM_CSCDR3_DCU0_EN); - div = (unsigned long long)(PLL1_PFD2_FREQ / 1000); - do_div(div, pixclock); - - return div; -} - -int platform_dcu_init(struct fb_info *fbinfo, - unsigned int xres, - unsigned int yres, - const char *port, - struct fb_videomode *dcu_fb_videomode) -{ - fsl_dcu_init(fbinfo, xres, yres, 32); - - return 0; -} diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index 350e1cf30e4..6afe9e0bfa5 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -102,7 +102,6 @@ CONFIG_DM_VIDEO=y CONFIG_VIDEO_LOGO=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP16 is not set -CONFIG_VIDEO_FSL_DCU_FB=y CONFIG_SPLASH_SCREEN_ALIGN=y CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 51570310533..e74a3dd9285 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -601,21 +601,6 @@ config VIDEO_IVYBRIDGE_IGD a special tool which configures the VGA ROM, but the graphics resolution can be selected in U-Boot.
-config VIDEO_FSL_DCU_FB - bool "Enable Freescale Display Control Unit" - depends on VIDEO || DM_VIDEO - help - This enables support for Freescale Display Control Unit (DCU4) - module found on Freescale Vybrid and QorIQ family of SoCs. - -config VIDEO_FSL_DCU_MAX_FB_SIZE_MB - int "Freescale DCU framebuffer size" - depends on VIDEO_FSL_DCU_FB - default 4194304 - help - Set maximum framebuffer size to be used for Freescale Display - Controller Unit (DCU4). - source "drivers/video/rockchip/Kconfig"
config VIDEO_ARM_MALIDP diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 18d53e5803c..656b981ca9d 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -49,7 +49,6 @@ obj-$(CONFIG_VIDEO_COREBOOT) += coreboot.o obj-$(CONFIG_VIDEO_DW_HDMI) += dw_hdmi.o obj-$(CONFIG_VIDEO_DW_MIPI_DSI) += dw_mipi_dsi.o obj-$(CONFIG_VIDEO_EFI) += efi.o -obj-$(CONFIG_VIDEO_FSL_DCU_FB) += fsl_dcu_fb.o videomodes.o obj-$(CONFIG_VIDEO_IPUV3) += imx/ obj-$(CONFIG_VIDEO_IVYBRIDGE_IGD) += ivybridge_igd.o obj-$(CONFIG_VIDEO_LCD_ANX9804) += anx9804.o diff --git a/drivers/video/fsl_dcu_fb.c b/drivers/video/fsl_dcu_fb.c deleted file mode 100644 index b8bd4727c96..00000000000 --- a/drivers/video/fsl_dcu_fb.c +++ /dev/null @@ -1,548 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2014 Freescale Semiconductor, Inc. - * Copyright 2019 Toradex AG - * - * FSL DCU Framebuffer driver - */ - -#include <init.h> -#include <asm/cache.h> -#include <asm/global_data.h> -#include <asm/io.h> -#include <common.h> -#include <dm.h> -#include <fdt_support.h> -#include <fsl_dcu_fb.h> -#include <linux/fb.h> -#include <malloc.h> -#include <video.h> -#include "videomodes.h" - -/* Convert the X,Y resolution pair into a single number */ -#define RESOLUTION(x, y) (((u32)(x) << 16) | (y)) - -#ifdef CONFIG_SYS_FSL_DCU_LE -#define dcu_read32 in_le32 -#define dcu_write32 out_le32 -#elif defined(CONFIG_SYS_FSL_DCU_BE) -#define dcu_read32 in_be32 -#define dcu_write32 out_be32 -#endif - -#define DCU_MODE_BLEND_ITER(x) ((x) << 20) -#define DCU_MODE_RASTER_EN (1 << 14) -#define DCU_MODE_NORMAL 1 -#define DCU_MODE_COLORBAR 3 -#define DCU_BGND_R(x) ((x) << 16) -#define DCU_BGND_G(x) ((x) << 8) -#define DCU_BGND_B(x) (x) -#define DCU_DISP_SIZE_DELTA_Y(x) ((x) << 16) -#define DCU_DISP_SIZE_DELTA_X(x) (x) -#define DCU_HSYN_PARA_BP(x) ((x) << 22) -#define DCU_HSYN_PARA_PW(x) ((x) << 11) -#define DCU_HSYN_PARA_FP(x) (x) -#define DCU_VSYN_PARA_BP(x) ((x) << 22) -#define DCU_VSYN_PARA_PW(x) ((x) << 11) -#define DCU_VSYN_PARA_FP(x) (x) -#define DCU_SYN_POL_INV_PXCK_FALL (1 << 6) -#define DCU_SYN_POL_NEG_REMAIN (0 << 5) -#define DCU_SYN_POL_INV_VS_LOW (1 << 1) -#define DCU_SYN_POL_INV_HS_LOW (1) -#define DCU_THRESHOLD_LS_BF_VS(x) ((x) << 16) -#define DCU_THRESHOLD_OUT_BUF_HIGH(x) ((x) << 8) -#define DCU_THRESHOLD_OUT_BUF_LOW(x) (x) -#define DCU_UPDATE_MODE_MODE (1 << 31) -#define DCU_UPDATE_MODE_READREG (1 << 30) - -#define DCU_CTRLDESCLN_1_HEIGHT(x) ((x) << 16) -#define DCU_CTRLDESCLN_1_WIDTH(x) (x) -#define DCU_CTRLDESCLN_2_POSY(x) ((x) << 16) -#define DCU_CTRLDESCLN_2_POSX(x) (x) -#define DCU_CTRLDESCLN_4_EN (1 << 31) -#define DCU_CTRLDESCLN_4_TILE_EN (1 << 30) -#define DCU_CTRLDESCLN_4_DATA_SEL_CLUT (1 << 29) -#define DCU_CTRLDESCLN_4_SAFETY_EN (1 << 28) -#define DCU_CTRLDESCLN_4_TRANS(x) ((x) << 20) -#define DCU_CTRLDESCLN_4_BPP(x) ((x) << 16) -#define DCU_CTRLDESCLN_4_RLE_EN (1 << 15) -#define DCU_CTRLDESCLN_4_LUOFFS(x) ((x) << 4) -#define DCU_CTRLDESCLN_4_BB_ON (1 << 2) -#define DCU_CTRLDESCLN_4_AB(x) (x) -#define DCU_CTRLDESCLN_5_CKMAX_R(x) ((x) << 16) -#define DCU_CTRLDESCLN_5_CKMAX_G(x) ((x) << 8) -#define DCU_CTRLDESCLN_5_CKMAX_B(x) (x) -#define DCU_CTRLDESCLN_6_CKMIN_R(x) ((x) << 16) -#define DCU_CTRLDESCLN_6_CKMIN_G(x) ((x) << 8) -#define DCU_CTRLDESCLN_6_CKMIN_B(x) (x) -#define DCU_CTRLDESCLN_7_TILE_VER(x) ((x) << 16) -#define DCU_CTRLDESCLN_7_TILE_HOR(x) (x) -#define DCU_CTRLDESCLN_8_FG_FCOLOR(x) (x) -#define DCU_CTRLDESCLN_9_BG_BCOLOR(x) (x) - -#define BPP_16_RGB565 4 -#define BPP_24_RGB888 5 -#define BPP_32_ARGB8888 6 - -DECLARE_GLOBAL_DATA_PTR; - -/* - * This setting is used for the TWR_LCD_RGB card - */ -static struct fb_videomode fsl_dcu_mode_480_272 = { - .name = "480x272-60", - .refresh = 60, - .xres = 480, - .yres = 272, - .pixclock = 91996, - .left_margin = 2, - .right_margin = 2, - .upper_margin = 1, - .lower_margin = 1, - .hsync_len = 41, - .vsync_len = 2, - .sync = FB_SYNC_COMP_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, - .vmode = FB_VMODE_NONINTERLACED -}; - -/* - * This setting is used for Siliconimage SiI9022A HDMI - */ -static struct fb_videomode fsl_dcu_cea_mode_640_480 = { - .name = "640x480-60", - .refresh = 60, - .xres = 640, - .yres = 480, - .pixclock = 39722, - .left_margin = 48, - .right_margin = 16, - .upper_margin = 33, - .lower_margin = 10, - .hsync_len = 96, - .vsync_len = 2, - .sync = 0, - .vmode = FB_VMODE_NONINTERLACED, -}; - -static struct fb_videomode fsl_dcu_mode_640_480 = { - .name = "640x480-60", - .refresh = 60, - .xres = 640, - .yres = 480, - .pixclock = 25175, - .left_margin = 40, - .right_margin = 24, - .upper_margin = 32, - .lower_margin = 11, - .hsync_len = 96, - .vsync_len = 2, - .sync = 0, - .vmode = FB_VMODE_NONINTERLACED, -}; - -static struct fb_videomode fsl_dcu_mode_800_480 = { - .name = "800x480-60", - .refresh = 60, - .xres = 800, - .yres = 480, - .pixclock = 33260, - .left_margin = 216, - .right_margin = 40, - .upper_margin = 35, - .lower_margin = 10, - .hsync_len = 128, - .vsync_len = 2, - .sync = 0, - .vmode = FB_VMODE_NONINTERLACED, -}; - -static struct fb_videomode fsl_dcu_mode_1024_600 = { - .name = "1024x600-60", - .refresh = 60, - .xres = 1024, - .yres = 600, - .pixclock = 48000, - .left_margin = 104, - .right_margin = 43, - .upper_margin = 24, - .lower_margin = 20, - .hsync_len = 5, - .vsync_len = 5, - .sync = 0, - .vmode = FB_VMODE_NONINTERLACED, -}; - -/* - * DCU register map - */ -struct dcu_reg { - u32 desc_cursor[4]; - u32 mode; - u32 bgnd; - u32 disp_size; - u32 hsyn_para; - u32 vsyn_para; - u32 synpol; - u32 threshold; - u32 int_status; - u32 int_mask; - u32 colbar[8]; - u32 div_ratio; - u32 sign_calc[2]; - u32 crc_val; - u8 res_064[0x6c-0x64]; - u32 parr_err_status1; - u8 res_070[0x7c-0x70]; - u32 parr_err_status3; - u32 mparr_err_status1; - u8 res_084[0x90-0x84]; - u32 mparr_err_status3; - u32 threshold_inp_buf[2]; - u8 res_09c[0xa0-0x9c]; - u32 luma_comp; - u32 chroma_red; - u32 chroma_green; - u32 chroma_blue; - u32 crc_pos; - u32 lyr_intpol_en; - u32 lyr_luma_comp; - u32 lyr_chrm_red; - u32 lyr_chrm_grn; - u32 lyr_chrm_blue; - u8 res_0c4[0xcc-0xc8]; - u32 update_mode; - u32 underrun; - u8 res_0d4[0x100-0xd4]; - u32 gpr; - u32 slr_l[2]; - u32 slr_disp_size; - u32 slr_hvsync_para; - u32 slr_pol; - u32 slr_l_transp[2]; - u8 res_120[0x200-0x120]; - u32 ctrldescl[DCU_LAYER_MAX_NUM][16]; -}; - -static void reset_total_layers(void) -{ - struct dcu_reg *regs = (struct dcu_reg *)CONFIG_SYS_DCU_ADDR; - int i; - - for (i = 0; i < DCU_LAYER_MAX_NUM; i++) { - dcu_write32(®s->ctrldescl[i][0], 0); - dcu_write32(®s->ctrldescl[i][1], 0); - dcu_write32(®s->ctrldescl[i][2], 0); - dcu_write32(®s->ctrldescl[i][3], 0); - dcu_write32(®s->ctrldescl[i][4], 0); - dcu_write32(®s->ctrldescl[i][5], 0); - dcu_write32(®s->ctrldescl[i][6], 0); - dcu_write32(®s->ctrldescl[i][7], 0); - dcu_write32(®s->ctrldescl[i][8], 0); - dcu_write32(®s->ctrldescl[i][9], 0); - dcu_write32(®s->ctrldescl[i][10], 0); - } -} - -static int layer_ctrldesc_init(struct fb_info fbinfo, - int index, u32 pixel_format) -{ - struct dcu_reg *regs = (struct dcu_reg *)CONFIG_SYS_DCU_ADDR; - unsigned int bpp = BPP_24_RGB888; - - dcu_write32(®s->ctrldescl[index][0], - DCU_CTRLDESCLN_1_HEIGHT(fbinfo.var.yres) | - DCU_CTRLDESCLN_1_WIDTH(fbinfo.var.xres)); - - dcu_write32(®s->ctrldescl[index][1], - DCU_CTRLDESCLN_2_POSY(0) | - DCU_CTRLDESCLN_2_POSX(0)); - - dcu_write32(®s->ctrldescl[index][2], - (unsigned int)fbinfo.screen_base); - - switch (pixel_format) { - case 16: - bpp = BPP_16_RGB565; - break; - case 24: - bpp = BPP_24_RGB888; - break; - case 32: - bpp = BPP_32_ARGB8888; - break; - default: - printf("unsupported color depth: %u\n", pixel_format); - } - - dcu_write32(®s->ctrldescl[index][3], - DCU_CTRLDESCLN_4_EN | - DCU_CTRLDESCLN_4_TRANS(0xff) | - DCU_CTRLDESCLN_4_BPP(bpp) | - DCU_CTRLDESCLN_4_AB(0)); - - dcu_write32(®s->ctrldescl[index][4], - DCU_CTRLDESCLN_5_CKMAX_R(0xff) | - DCU_CTRLDESCLN_5_CKMAX_G(0xff) | - DCU_CTRLDESCLN_5_CKMAX_B(0xff)); - dcu_write32(®s->ctrldescl[index][5], - DCU_CTRLDESCLN_6_CKMIN_R(0) | - DCU_CTRLDESCLN_6_CKMIN_G(0) | - DCU_CTRLDESCLN_6_CKMIN_B(0)); - - dcu_write32(®s->ctrldescl[index][6], - DCU_CTRLDESCLN_7_TILE_VER(0) | - DCU_CTRLDESCLN_7_TILE_HOR(0)); - - dcu_write32(®s->ctrldescl[index][7], DCU_CTRLDESCLN_8_FG_FCOLOR(0)); - dcu_write32(®s->ctrldescl[index][8], DCU_CTRLDESCLN_9_BG_BCOLOR(0)); - - return 0; -} - -int fsl_dcu_init(struct fb_info *fbinfo, unsigned int xres, - unsigned int yres, unsigned int pixel_format) -{ - struct dcu_reg *regs = (struct dcu_reg *)CONFIG_SYS_DCU_ADDR; - unsigned int div, mode; -/* - * When DM_VIDEO is enabled reservation of framebuffer is done - * in advance during bind() call. - */ -#if !CONFIG_IS_ENABLED(DM_VIDEO) - fbinfo->screen_size = fbinfo->var.xres * fbinfo->var.yres * - (fbinfo->var.bits_per_pixel / 8); - - if (fbinfo->screen_size > CONFIG_VIDEO_FSL_DCU_MAX_FB_SIZE_MB) { - fbinfo->screen_size = 0; - return -ENOMEM; - } - /* Reserve framebuffer at the end of memory */ - gd->fb_base = gd->bd->bi_dram[0].start + - gd->bd->bi_dram[0].size - fbinfo->screen_size; - fbinfo->screen_base = (char *)gd->fb_base; - - memset(fbinfo->screen_base, 0, fbinfo->screen_size); -#endif - - reset_total_layers(); - - dcu_write32(®s->disp_size, - DCU_DISP_SIZE_DELTA_Y(fbinfo->var.yres) | - DCU_DISP_SIZE_DELTA_X(fbinfo->var.xres / 16)); - - dcu_write32(®s->hsyn_para, - DCU_HSYN_PARA_BP(fbinfo->var.left_margin) | - DCU_HSYN_PARA_PW(fbinfo->var.hsync_len) | - DCU_HSYN_PARA_FP(fbinfo->var.right_margin)); - - dcu_write32(®s->vsyn_para, - DCU_VSYN_PARA_BP(fbinfo->var.upper_margin) | - DCU_VSYN_PARA_PW(fbinfo->var.vsync_len) | - DCU_VSYN_PARA_FP(fbinfo->var.lower_margin)); - - dcu_write32(®s->synpol, - DCU_SYN_POL_INV_PXCK_FALL | - DCU_SYN_POL_NEG_REMAIN | - DCU_SYN_POL_INV_VS_LOW | - DCU_SYN_POL_INV_HS_LOW); - - dcu_write32(®s->bgnd, - DCU_BGND_R(0) | DCU_BGND_G(0) | DCU_BGND_B(0)); - - dcu_write32(®s->mode, - DCU_MODE_BLEND_ITER(2) | - DCU_MODE_RASTER_EN); - - dcu_write32(®s->threshold, - DCU_THRESHOLD_LS_BF_VS(0x3) | - DCU_THRESHOLD_OUT_BUF_HIGH(0x78) | - DCU_THRESHOLD_OUT_BUF_LOW(0)); - - mode = dcu_read32(®s->mode); - dcu_write32(®s->mode, mode | DCU_MODE_NORMAL); - - layer_ctrldesc_init(*fbinfo, 0, pixel_format); - - div = dcu_set_pixel_clock(fbinfo->var.pixclock); - dcu_write32(®s->div_ratio, (div - 1)); - - dcu_write32(®s->update_mode, DCU_UPDATE_MODE_READREG); - - return 0; -} - -ulong board_get_usable_ram_top(ulong total_size) -{ - return gd->ram_top - CONFIG_VIDEO_FSL_DCU_MAX_FB_SIZE_MB; -} - -int fsl_probe_common(struct fb_info *fbinfo, unsigned int *win_x, - unsigned int *win_y) -{ - const char *options; - unsigned int depth = 0, freq = 0; - - struct fb_videomode *fsl_dcu_mode_db = &fsl_dcu_mode_480_272; - - if (!video_get_video_mode(win_x, win_y, &depth, &freq, - &options)) - return -EINVAL; - - /* Find the monitor port, which is a required option */ - if (!options) - return -EINVAL; - - if (strncmp(options, "monitor=", 8) != 0) - return -EINVAL; - - switch (RESOLUTION(*win_x, *win_y)) { - case RESOLUTION(480, 272): - fsl_dcu_mode_db = &fsl_dcu_mode_480_272; - break; - case RESOLUTION(640, 480): - if (!strncmp(options, "monitor=hdmi", 12)) - fsl_dcu_mode_db = &fsl_dcu_cea_mode_640_480; - else - fsl_dcu_mode_db = &fsl_dcu_mode_640_480; - break; - case RESOLUTION(800, 480): - fsl_dcu_mode_db = &fsl_dcu_mode_800_480; - break; - case RESOLUTION(1024, 600): - fsl_dcu_mode_db = &fsl_dcu_mode_1024_600; - break; - default: - printf("unsupported resolution %ux%u\n", - *win_x, *win_y); - } - - fbinfo->var.xres = fsl_dcu_mode_db->xres; - fbinfo->var.yres = fsl_dcu_mode_db->yres; - fbinfo->var.bits_per_pixel = 32; - fbinfo->var.pixclock = fsl_dcu_mode_db->pixclock; - fbinfo->var.left_margin = fsl_dcu_mode_db->left_margin; - fbinfo->var.right_margin = fsl_dcu_mode_db->right_margin; - fbinfo->var.upper_margin = fsl_dcu_mode_db->upper_margin; - fbinfo->var.lower_margin = fsl_dcu_mode_db->lower_margin; - fbinfo->var.hsync_len = fsl_dcu_mode_db->hsync_len; - fbinfo->var.vsync_len = fsl_dcu_mode_db->vsync_len; - fbinfo->var.sync = fsl_dcu_mode_db->sync; - fbinfo->var.vmode = fsl_dcu_mode_db->vmode; - fbinfo->fix.line_length = fbinfo->var.xres * - fbinfo->var.bits_per_pixel / 8; - - return platform_dcu_init(fbinfo, *win_x, *win_y, - options + 8, fsl_dcu_mode_db); -} - -#ifndef CONFIG_DM_VIDEO -static struct fb_info info; - -#if defined(CONFIG_OF_BOARD_SETUP) -int fsl_dcu_fixedfb_setup(void *blob) -{ - u64 start, size; - int ret; - - start = gd->bd->bi_dram[0].start; - size = gd->bd->bi_dram[0].size - info.screen_size; - - /* - * Align size on section size (1 MiB). - */ - size &= 0xfff00000; - ret = fdt_fixup_memory_banks(blob, &start, &size, 1); - if (ret) { - eprintf("Cannot setup fb: Error reserving memory\n"); - return ret; - } - - return 0; -} -#endif - -void *video_hw_init(void) -{ - static GraphicDevice ctfb; - - if (fsl_probe_common(&info, &ctfb.winSizeX, &ctfb.winSizeY) < 0) - return NULL; - - ctfb.frameAdrs = (unsigned int)info.screen_base; - ctfb.plnSizeX = ctfb.winSizeX; - ctfb.plnSizeY = ctfb.winSizeY; - - ctfb.gdfBytesPP = 4; - ctfb.gdfIndex = GDF_32BIT_X888RGB; - - ctfb.memSize = info.screen_size; - - return &ctfb; -} - -#else /* ifndef CONFIG_DM_VIDEO */ - -static int fsl_dcu_video_probe(struct udevice *dev) -{ - struct video_uc_plat *plat = dev_get_uclass_plat(dev); - struct video_priv *uc_priv = dev_get_uclass_priv(dev); - struct fb_info fbinfo = { 0 }; - unsigned int win_x; - unsigned int win_y; - u32 fb_start, fb_end; - int ret = 0; - - fb_start = plat->base & ~(MMU_SECTION_SIZE - 1); - fb_end = plat->base + plat->size; - fb_end = ALIGN(fb_end, 1 << MMU_SECTION_SHIFT); - - fbinfo.screen_base = (char *)fb_start; - fbinfo.screen_size = plat->size; - - ret = fsl_probe_common(&fbinfo, &win_x, &win_y); - if (ret < 0) - return ret; - - uc_priv->bpix = VIDEO_BPP32; - uc_priv->xsize = win_x; - uc_priv->ysize = win_y; - - /* Enable dcache for the frame buffer */ - mmu_set_region_dcache_behaviour(fb_start, fb_end - fb_start, - DCACHE_WRITEBACK); - video_set_flush_dcache(dev, true); - return ret; -} - -static int fsl_dcu_video_bind(struct udevice *dev) -{ - struct video_uc_plat *plat = dev_get_uclass_plat(dev); - unsigned int win_x; - unsigned int win_y; - unsigned int depth = 0, freq = 0; - const char *options; - int ret = 0; - - ret = video_get_video_mode(&win_x, &win_y, &depth, &freq, &options); - if (ret < 0) - return ret; - - plat->size = win_x * win_y * 32; - - return 0; -} - -static const struct udevice_id fsl_dcu_video_ids[] = { - { .compatible = "fsl,vf610-dcu" }, - { /* sentinel */ } -}; - -U_BOOT_DRIVER(fsl_dcu_video) = { - .name = "fsl_dcu_video", - .id = UCLASS_VIDEO, - .of_match = fsl_dcu_video_ids, - .bind = fsl_dcu_video_bind, - .probe = fsl_dcu_video_probe, - .flags = DM_FLAG_PRE_RELOC, -}; -#endif /* ifndef CONFIG_DM_VIDEO */ diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index 3711e429a70..2e7b640357e 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -14,13 +14,6 @@ #include <asm/arch/imx-regs.h> #include <linux/sizes.h>
-#ifdef CONFIG_VIDEO_FSL_DCU_FB -#define CONFIG_SYS_FSL_DCU_LE - -#define CONFIG_SYS_DCU_ADDR DCU0_BASE_ADDR -#define DCU_LAYER_MAX_NUM 64 -#endif - /* NAND support */ #define CONFIG_SYS_MAX_NAND_DEVICE 1
diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 54860af946b..94749c1f7f1 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -303,16 +303,6 @@ * MMC */
-/* - * Video - */ -#ifdef CONFIG_VIDEO_FSL_DCU_FB -#define CONFIG_FSL_DIU_CH7301 -#define CONFIG_SYS_I2C_DVI_BUS_NUM 0 -#define CONFIG_SYS_I2C_QIXIS_ADDR 0x66 -#define CONFIG_SYS_I2C_DVI_ADDR 0x75 -#endif - /* * eTSEC */ diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index dd47ba5efc6..7292ee8e836 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -190,19 +190,6 @@ #define CONFIG_SYS_I2C_EEPROM_NXID #define CONFIG_SYS_EEPROM_BUS_NUM 1
-/* - * MMC - */ - -/* - * Video - */ -#ifdef CONFIG_VIDEO_FSL_DCU_FB -#define CONFIG_FSL_DCU_SII9022A -#define CONFIG_SYS_I2C_DVI_BUS_NUM 1 -#define CONFIG_SYS_I2C_DVI_ADDR 0x39 -#endif - /* * eTSEC */ diff --git a/include/fsl_dcu_fb.h b/include/fsl_dcu_fb.h deleted file mode 100644 index 7a5347a9247..00000000000 --- a/include/fsl_dcu_fb.h +++ /dev/null @@ -1,22 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright 2014 Freescale Semiconductor, Inc. - * - * FSL DCU Framebuffer driver - */ -#include <linux/fb.h> - -int fsl_dcu_init(struct fb_info *fbinfo, - unsigned int xres, - unsigned int yres, - unsigned int pixel_format); - -int fsl_dcu_fixedfb_setup(void *blob); - -/* Prototypes for external board-specific functions */ -int platform_dcu_init(struct fb_info *fbinfo, - unsigned int xres, - unsigned int yres, - const char *port, - struct fb_videomode *dcu_fb_videomode); -unsigned int dcu_set_pixel_clock(unsigned int pixclock); diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 536a8ee13f6..f63eddfea4f 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -210,7 +210,6 @@ CONFIG_FPGA_STRATIX_V CONFIG_FSL_CADMUS CONFIG_FSL_CORENET CONFIG_FSL_CPLD -CONFIG_FSL_DCU_SII9022A CONFIG_FSL_DEVICE_DISABLE CONFIG_FSL_DIU_CH7301 CONFIG_FSL_DIU_FB @@ -1218,8 +1217,6 @@ CONFIG_SYS_FSL_DCSR_DDR2_ADDR CONFIG_SYS_FSL_DCSR_DDR3_ADDR CONFIG_SYS_FSL_DCSR_DDR4_ADDR CONFIG_SYS_FSL_DCSR_DDR_ADDR -CONFIG_SYS_FSL_DCU_BE -CONFIG_SYS_FSL_DCU_LE CONFIG_SYS_FSL_DDR2_ADDR CONFIG_SYS_FSL_DDR3_ADDR CONFIG_SYS_FSL_DDR_ADDR
README | 13 - board/freescale/common/Makefile | 2 - board/freescale/common/diu_ch7301.c | 217 --------------- board/freescale/common/diu_ch7301.h | 12 - board/freescale/t104xrdb/Makefile | 1 - board/freescale/t104xrdb/diu.c | 83 ------ drivers/video/Makefile | 1 - drivers/video/fsl_diu_fb.c | 415 ---------------------------- include/configs/T102xRDB.h | 12 - include/configs/T104xRDB.h | 19 -- include/fsl_diu_fb.h | 14 - scripts/config_whitelist.txt | 3 - 12 files changed, 792 deletions(-) delete mode 100644 board/freescale/common/diu_ch7301.c delete mode 100644 board/freescale/common/diu_ch7301.h delete mode 100644 board/freescale/t104xrdb/diu.c delete mode 100644 drivers/video/fsl_diu_fb.c delete mode 100644 include/fsl_diu_fb.h
diff --git a/README b/README index 40ef21df3b5..56c9bc3e676 100644 --- a/README +++ b/README @@ -1006,19 +1006,6 @@ The following options need to be configured: - Keyboard Support: See Kconfig help for available keyboard drivers.
-- Video support: - CONFIG_FSL_DIU_FB - Enable the Freescale DIU video driver. Reference boards for - SOCs that have a DIU should define this macro to enable DIU - support, and should also define these other macros: - - CONFIG_SYS_DIU_ADDR - - The DIU driver will look for the 'video-mode' environment - variable, and if defined, enable the DIU as a console during - boot. See the documentation file doc/README.video for a - description of this variable. - - LCD Support: CONFIG_LCD
Define this to enable LCD support (for output to LCD diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index c8f62bfc198..f13965daf2e 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -44,8 +44,6 @@ ifndef CONFIG_RAMBOOT_PBL obj-$(CONFIG_FSL_FIXED_MMC_LOCATION) += sdhc_boot.o endif
-obj-$(CONFIG_FSL_DIU_CH7301) += diu_ch7301.o - ifdef CONFIG_ARM obj-$(CONFIG_DEEP_SLEEP) += arm_sleep.o else diff --git a/board/freescale/common/diu_ch7301.c b/board/freescale/common/diu_ch7301.c deleted file mode 100644 index 05e6a3acf11..00000000000 --- a/board/freescale/common/diu_ch7301.c +++ /dev/null @@ -1,217 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2014 Freescale Semiconductor, Inc. - * Copyright 2019 NXP - * Authors: Priyanka Jain Priyanka.Jain@freescale.com - * Wang Dongsheng dongsheng.wang@freescale.com - * - * This file is copied and modified from the original t1040qds/diu.c. - * Encoder can be used in T104x and LSx Platform. - */ - -#include <common.h> -#include <stdio_dev.h> -#include <i2c.h> -#include <linux/delay.h> - -#define I2C_DVI_INPUT_DATA_FORMAT_REG 0x1F -#define I2C_DVI_PLL_CHARGE_CNTL_REG 0x33 -#define I2C_DVI_PLL_DIVIDER_REG 0x34 -#define I2C_DVI_PLL_SUPPLY_CNTL_REG 0x35 -#define I2C_DVI_PLL_FILTER_REG 0x36 -#define I2C_DVI_TEST_PATTERN_REG 0x48 -#define I2C_DVI_POWER_MGMT_REG 0x49 -#define I2C_DVI_LOCK_STATE_REG 0x4D -#define I2C_DVI_SYNC_POLARITY_REG 0x56 - -/* - * Set VSYNC/HSYNC to active high. This is polarity of sync signals - * from DIU->DVI. The DIU default is active igh, so DVI is set to - * active high. - */ -#define I2C_DVI_INPUT_DATA_FORMAT_VAL 0x98 - -#define I2C_DVI_PLL_CHARGE_CNTL_HIGH_SPEED_VAL 0x06 -#define I2C_DVI_PLL_DIVIDER_HIGH_SPEED_VAL 0x26 -#define I2C_DVI_PLL_FILTER_HIGH_SPEED_VAL 0xA0 -#define I2C_DVI_PLL_CHARGE_CNTL_LOW_SPEED_VAL 0x08 -#define I2C_DVI_PLL_DIVIDER_LOW_SPEED_VAL 0x16 -#define I2C_DVI_PLL_FILTER_LOW_SPEED_VAL 0x60 - -/* Clear test pattern */ -#define I2C_DVI_TEST_PATTERN_VAL 0x18 -/* Exit Power-down mode */ -#define I2C_DVI_POWER_MGMT_VAL 0xC0 - -/* Monitor polarity is handled via DVI Sync Polarity Register */ -#define I2C_DVI_SYNC_POLARITY_VAL 0x00 - -/* Programming of HDMI Chrontel CH7301 connector */ -int diu_set_dvi_encoder(unsigned int pixclock) -{ - int ret; - u8 temp; - - temp = I2C_DVI_TEST_PATTERN_VAL; -#if CONFIG_IS_ENABLED(DM_I2C) - struct udevice *dev; - - ret = i2c_get_chip_for_busnum(CONFIG_SYS_I2C_DVI_BUS_NUM, - CONFIG_SYS_I2C_DVI_ADDR, - 1, &dev); - if (ret) { - printf("%s: Cannot find udev for a bus %d\n", __func__, - CONFIG_SYS_I2C_DVI_BUS_NUM); - return ret; - } - ret = dm_i2c_write(dev, I2C_DVI_TEST_PATTERN_REG, &temp, 1); - if (ret) { - puts("I2C: failed to select proper dvi test pattern\n"); - return ret; - } - temp = I2C_DVI_INPUT_DATA_FORMAT_VAL; - ret = dm_i2c_write(dev, I2C_DVI_INPUT_DATA_FORMAT_REG, &temp, 1); - if (ret) { - puts("I2C: failed to select dvi input data format\n"); - return ret; - } - - /* Set Sync polarity register */ - temp = I2C_DVI_SYNC_POLARITY_VAL; - ret = dm_i2c_write(dev, I2C_DVI_SYNC_POLARITY_REG, &temp, 1); - if (ret) { - puts("I2C: failed to select dvi syc polarity\n"); - return ret; - } - - /* Set PLL registers based on pixel clock rate*/ - if (pixclock > 65000000) { - temp = I2C_DVI_PLL_CHARGE_CNTL_HIGH_SPEED_VAL; - ret = dm_i2c_write(dev, I2C_DVI_PLL_CHARGE_CNTL_REG, &temp, 1); - if (ret) { - puts("I2C: failed to select dvi pll charge_cntl\n"); - return ret; - } - temp = I2C_DVI_PLL_DIVIDER_HIGH_SPEED_VAL; - ret = dm_i2c_write(dev, I2C_DVI_PLL_DIVIDER_REG, &temp, 1); - if (ret) { - puts("I2C: failed to select dvi pll divider\n"); - return ret; - } - temp = I2C_DVI_PLL_FILTER_HIGH_SPEED_VAL; - ret = dm_i2c_write(dev, I2C_DVI_PLL_FILTER_REG, &temp, 1); - if (ret) { - puts("I2C: failed to select dvi pll filter\n"); - return ret; - } - } else { - temp = I2C_DVI_PLL_CHARGE_CNTL_LOW_SPEED_VAL; - ret = dm_i2c_write(dev, I2C_DVI_PLL_CHARGE_CNTL_REG, &temp, 1); - if (ret) { - puts("I2C: failed to select dvi pll charge_cntl\n"); - return ret; - } - temp = I2C_DVI_PLL_DIVIDER_LOW_SPEED_VAL; - ret = dm_i2c_write(dev, I2C_DVI_PLL_DIVIDER_REG, &temp, 1); - if (ret) { - puts("I2C: failed to select dvi pll divider\n"); - return ret; - } - temp = I2C_DVI_PLL_FILTER_LOW_SPEED_VAL; - ret = dm_i2c_write(dev, I2C_DVI_PLL_FILTER_REG, &temp, 1); - if (ret) { - puts("I2C: failed to select dvi pll filter\n"); - return ret; - } - } - - temp = I2C_DVI_POWER_MGMT_VAL; - ret = dm_i2c_write(dev, I2C_DVI_POWER_MGMT_REG, &temp, 1); - if (ret) { - puts("I2C: failed to select dvi power mgmt\n"); - return ret; - } -#else - ret = i2c_write(CONFIG_SYS_I2C_DVI_ADDR, I2C_DVI_TEST_PATTERN_REG, 1, - &temp, 1); - if (ret) { - puts("I2C: failed to select proper dvi test pattern\n"); - return ret; - } - temp = I2C_DVI_INPUT_DATA_FORMAT_VAL; - ret = i2c_write(CONFIG_SYS_I2C_DVI_ADDR, I2C_DVI_INPUT_DATA_FORMAT_REG, - 1, &temp, 1); - if (ret) { - puts("I2C: failed to select dvi input data format\n"); - return ret; - } - - /* Set Sync polarity register */ - temp = I2C_DVI_SYNC_POLARITY_VAL; - ret = i2c_write(CONFIG_SYS_I2C_DVI_ADDR, I2C_DVI_SYNC_POLARITY_REG, 1, - &temp, 1); - if (ret) { - puts("I2C: failed to select dvi syc polarity\n"); - return ret; - } - - /* Set PLL registers based on pixel clock rate*/ - if (pixclock > 65000000) { - temp = I2C_DVI_PLL_CHARGE_CNTL_HIGH_SPEED_VAL; - ret = i2c_write(CONFIG_SYS_I2C_DVI_ADDR, - I2C_DVI_PLL_CHARGE_CNTL_REG, 1, &temp, 1); - if (ret) { - puts("I2C: failed to select dvi pll charge_cntl\n"); - return ret; - } - temp = I2C_DVI_PLL_DIVIDER_HIGH_SPEED_VAL; - ret = i2c_write(CONFIG_SYS_I2C_DVI_ADDR, - I2C_DVI_PLL_DIVIDER_REG, 1, &temp, 1); - if (ret) { - puts("I2C: failed to select dvi pll divider\n"); - return ret; - } - temp = I2C_DVI_PLL_FILTER_HIGH_SPEED_VAL; - ret = i2c_write(CONFIG_SYS_I2C_DVI_ADDR, - I2C_DVI_PLL_FILTER_REG, 1, &temp, 1); - if (ret) { - puts("I2C: failed to select dvi pll filter\n"); - return ret; - } - } else { - temp = I2C_DVI_PLL_CHARGE_CNTL_LOW_SPEED_VAL; - ret = i2c_write(CONFIG_SYS_I2C_DVI_ADDR, - I2C_DVI_PLL_CHARGE_CNTL_REG, 1, &temp, 1); - if (ret) { - puts("I2C: failed to select dvi pll charge_cntl\n"); - return ret; - } - temp = I2C_DVI_PLL_DIVIDER_LOW_SPEED_VAL; - ret = i2c_write(CONFIG_SYS_I2C_DVI_ADDR, - I2C_DVI_PLL_DIVIDER_REG, 1, &temp, 1); - if (ret) { - puts("I2C: failed to select dvi pll divider\n"); - return ret; - } - temp = I2C_DVI_PLL_FILTER_LOW_SPEED_VAL; - ret = i2c_write(CONFIG_SYS_I2C_DVI_ADDR, - I2C_DVI_PLL_FILTER_REG, 1, &temp, 1); - if (ret) { - puts("I2C: failed to select dvi pll filter\n"); - return ret; - } - } - - temp = I2C_DVI_POWER_MGMT_VAL; - ret = i2c_write(CONFIG_SYS_I2C_DVI_ADDR, I2C_DVI_POWER_MGMT_REG, 1, - &temp, 1); - if (ret) { - puts("I2C: failed to select dvi power mgmt\n"); - return ret; - } -#endif - - udelay(500); - - return 0; -} diff --git a/board/freescale/common/diu_ch7301.h b/board/freescale/common/diu_ch7301.h deleted file mode 100644 index f35661cdc49..00000000000 --- a/board/freescale/common/diu_ch7301.h +++ /dev/null @@ -1,12 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright 2014 Freescale Semiconductor, Inc. - */ - -#ifndef __DIU_HDMI_CH7301__ -#define __DIU_HDMI_CH7301__ - -/* Programming of HDMI Chrontel CH7301 connector */ -int diu_set_dvi_encoder(unsigned int pixclock); - -#endif diff --git a/board/freescale/t104xrdb/Makefile b/board/freescale/t104xrdb/Makefile index d67e9412ecd..a9495019430 100644 --- a/board/freescale/t104xrdb/Makefile +++ b/board/freescale/t104xrdb/Makefile @@ -8,7 +8,6 @@ else obj-y += t104xrdb.o obj-y += cpld.o obj-y += eth.o -obj-$(CONFIG_FSL_DIU_FB)+= diu.o endif obj-y += ddr.o obj-y += law.o diff --git a/board/freescale/t104xrdb/diu.c b/board/freescale/t104xrdb/diu.c deleted file mode 100644 index 022d329713e..00000000000 --- a/board/freescale/t104xrdb/diu.c +++ /dev/null @@ -1,83 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2014 Freescale Semiconductor, Inc. - * Author: Priyanka Jain Priyanka.Jain@freescale.com - */ - -#include <clock_legacy.h> -#include <asm/io.h> -#include <common.h> -#include <command.h> -#include <fsl_diu_fb.h> -#include <linux/ctype.h> - -#include "../common/diu_ch7301.h" - -#include "cpld.h" -#include "t104xrdb.h" - -/* - * DIU Area Descriptor - * - * Note that we need to byte-swap the value before it's written to the AD - * register. So even though the registers don't look like they're in the same - * bit positions as they are on the MPC8610, the same value is written to the - * AD register on the MPC8610 and on the P1022. - */ -#define AD_BYTE_F 0x10000000 -#define AD_ALPHA_C_SHIFT 25 -#define AD_BLUE_C_SHIFT 23 -#define AD_GREEN_C_SHIFT 21 -#define AD_RED_C_SHIFT 19 -#define AD_PIXEL_S_SHIFT 16 -#define AD_COMP_3_SHIFT 12 -#define AD_COMP_2_SHIFT 8 -#define AD_COMP_1_SHIFT 4 -#define AD_COMP_0_SHIFT 0 - -void diu_set_pixel_clock(unsigned int pixclock) -{ - unsigned long speed_ccb, temp; - u32 pixval; - int ret; - - speed_ccb = get_bus_freq(0); - temp = 1000000000 / pixclock; - temp *= 1000; - pixval = speed_ccb / temp; - - /* Program HDMI encoder */ - ret = diu_set_dvi_encoder(temp); - if (ret) { - puts("Failed to set DVI encoder\n"); - return; - } - - /* Program pixel clock */ - out_be32((unsigned *)CONFIG_SYS_FSL_SCFG_PIXCLK_ADDR, - ((pixval << PXCK_BITS_START) & PXCK_MASK)); - - /* enable clock*/ - out_be32((unsigned *)CONFIG_SYS_FSL_SCFG_PIXCLK_ADDR, PXCKEN_MASK | - ((pixval << PXCK_BITS_START) & PXCK_MASK)); -} - -int platform_diu_init(unsigned int xres, unsigned int yres, const char *port) -{ - u32 pixel_format; - u8 sw; - - /*Configure Display ouput port as HDMI*/ - sw = CPLD_READ(sfp_ctl_status); - CPLD_WRITE(sfp_ctl_status , sw & ~(CPLD_DIU_SEL_DFP)); - - pixel_format = cpu_to_le32(AD_BYTE_F | (3 << AD_ALPHA_C_SHIFT) | - (0 << AD_BLUE_C_SHIFT) | (1 << AD_GREEN_C_SHIFT) | - (2 << AD_RED_C_SHIFT) | (8 << AD_COMP_3_SHIFT) | - (8 << AD_COMP_2_SHIFT) | (8 << AD_COMP_1_SHIFT) | - (8 << AD_COMP_0_SHIFT) | (3 << AD_PIXEL_S_SHIFT)); - - printf("DIU: Switching to monitor DVI @ %ux%u\n", xres, yres); - - return fsl_diu_init(xres, yres, pixel_format, 0); -} diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 656b981ca9d..4f8fe3810b3 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -31,7 +31,6 @@ obj-y += ti/ obj-$(CONFIG_ATMEL_HLCD) += atmel_hlcdfb.o obj-$(CONFIG_ATMEL_LCD) += atmel_lcdfb.o obj-$(CONFIG_FORMIKE) += formike.o -obj-$(CONFIG_FSL_DIU_FB) += fsl_diu_fb.o videomodes.o obj-$(CONFIG_IHS_VIDEO_OUT) += ihs_video_out.o obj-$(CONFIG_LD9040) += ld9040.o obj-$(CONFIG_LG4573) += lg4573.o diff --git a/drivers/video/fsl_diu_fb.c b/drivers/video/fsl_diu_fb.c deleted file mode 100644 index 6e335b5f43d..00000000000 --- a/drivers/video/fsl_diu_fb.c +++ /dev/null @@ -1,415 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2007, 2010-2011 Freescale Semiconductor, Inc. - * Authors: York Sun yorksun@freescale.com - * Timur Tabi timur@freescale.com - * - * FSL DIU Framebuffer driver - */ - -#include <common.h> -#include <malloc.h> -#include <asm/io.h> - -#include "videomodes.h" -#include <fsl_diu_fb.h> -#include <linux/list.h> -#include <linux/fb.h> - -/* This setting is used for the ifm pdm360ng with PRIMEVIEW PM070WL3 */ -static struct fb_videomode fsl_diu_mode_800_480 = { - .name = "800x480-60", - .refresh = 60, - .xres = 800, - .yres = 480, - .pixclock = 31250, - .left_margin = 86, - .right_margin = 42, - .upper_margin = 33, - .lower_margin = 10, - .hsync_len = 128, - .vsync_len = 2, - .sync = 0, - .vmode = FB_VMODE_NONINTERLACED -}; - -/* For the SHARP LQ084S3LG01, used on the P1022DS board */ -static struct fb_videomode fsl_diu_mode_800_600 = { - .name = "800x600-60", - .refresh = 60, - .xres = 800, - .yres = 600, - .pixclock = 25000, - .left_margin = 88, - .right_margin = 40, - .upper_margin = 23, - .lower_margin = 1, - .hsync_len = 128, - .vsync_len = 4, - .sync = FB_SYNC_COMP_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, - .vmode = FB_VMODE_NONINTERLACED -}; - -/* - * These parameters give default parameters - * for video output 1024x768, - * FIXME - change timing to proper amounts - * hsync 31.5kHz, vsync 60Hz - */ -static struct fb_videomode fsl_diu_mode_1024_768 = { - .name = "1024x768-60", - .refresh = 60, - .xres = 1024, - .yres = 768, - .pixclock = 15385, - .left_margin = 160, - .right_margin = 24, - .upper_margin = 29, - .lower_margin = 3, - .hsync_len = 136, - .vsync_len = 6, - .sync = FB_SYNC_COMP_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, - .vmode = FB_VMODE_NONINTERLACED -}; - -static struct fb_videomode fsl_diu_mode_1280_1024 = { - .name = "1280x1024-60", - .refresh = 60, - .xres = 1280, - .yres = 1024, - .pixclock = 9375, - .left_margin = 38, - .right_margin = 128, - .upper_margin = 2, - .lower_margin = 7, - .hsync_len = 216, - .vsync_len = 37, - .sync = FB_SYNC_COMP_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, - .vmode = FB_VMODE_NONINTERLACED -}; - -static struct fb_videomode fsl_diu_mode_1280_720 = { - .name = "1280x720-60", - .refresh = 60, - .xres = 1280, - .yres = 720, - .pixclock = 13426, - .left_margin = 192, - .right_margin = 64, - .upper_margin = 22, - .lower_margin = 1, - .hsync_len = 136, - .vsync_len = 3, - .sync = FB_SYNC_COMP_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, - .vmode = FB_VMODE_NONINTERLACED -}; - -static struct fb_videomode fsl_diu_mode_1920_1080 = { - .name = "1920x1080-60", - .refresh = 60, - .xres = 1920, - .yres = 1080, - .pixclock = 5787, - .left_margin = 328, - .right_margin = 120, - .upper_margin = 34, - .lower_margin = 1, - .hsync_len = 208, - .vsync_len = 3, - .sync = FB_SYNC_COMP_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, - .vmode = FB_VMODE_NONINTERLACED -}; - -/* - * These are the fields of area descriptor(in DDR memory) for every plane - */ -struct diu_ad { - /* Word 0(32-bit) in DDR memory */ - __le32 pix_fmt; /* hard coding pixel format */ - /* Word 1(32-bit) in DDR memory */ - __le32 addr; - /* Word 2(32-bit) in DDR memory */ - __le32 src_size_g_alpha; - /* Word 3(32-bit) in DDR memory */ - __le32 aoi_size; - /* Word 4(32-bit) in DDR memory */ - __le32 offset_xyi; - /* Word 5(32-bit) in DDR memory */ - __le32 offset_xyd; - /* Word 6(32-bit) in DDR memory */ - __le32 ckmax_r:8; - __le32 ckmax_g:8; - __le32 ckmax_b:8; - __le32 res9:8; - /* Word 7(32-bit) in DDR memory */ - __le32 ckmin_r:8; - __le32 ckmin_g:8; - __le32 ckmin_b:8; - __le32 res10:8; - /* Word 8(32-bit) in DDR memory */ - __le32 next_ad; - /* Word 9(32-bit) in DDR memory, just for 64-bit aligned */ - __le32 res[3]; -} __attribute__ ((packed)); - -/* - * DIU register map - */ -struct diu { - __be32 desc[3]; - __be32 gamma; - __be32 pallete; - __be32 cursor; - __be32 curs_pos; - __be32 diu_mode; - __be32 bgnd; - __be32 bgnd_wb; - __be32 disp_size; - __be32 wb_size; - __be32 wb_mem_addr; - __be32 hsyn_para; - __be32 vsyn_para; - __be32 syn_pol; - __be32 thresholds; - __be32 int_status; - __be32 int_mask; - __be32 colorbar[8]; - __be32 filling; - __be32 plut; -} __attribute__ ((packed)); - -struct diu_addr { - void *vaddr; /* Virtual address */ - u32 paddr; /* 32-bit physical address */ - unsigned int offset; /* Alignment offset */ -}; - -static struct fb_info info; - -/* - * Align to 64-bit(8-byte), 32-byte, etc. - */ -static int allocate_buf(struct diu_addr *buf, u32 size, u32 bytes_align) -{ - u32 offset, ssize; - u32 mask; - - ssize = size + bytes_align; - buf->vaddr = malloc(ssize); - if (!buf->vaddr) - return -1; - - memset(buf->vaddr, 0, ssize); - mask = bytes_align - 1; - offset = (u32)buf->vaddr & mask; - if (offset) { - buf->offset = bytes_align - offset; - buf->vaddr += offset; - } else - buf->offset = 0; - - buf->paddr = virt_to_phys(buf->vaddr); - return 0; -} - -/* - * Allocate a framebuffer and an Area Descriptor that points to it. Both - * are created in the same memory block. The Area Descriptor is updated to - * point to the framebuffer memory. Memory is aligned as needed. - */ -static struct diu_ad *allocate_fb(unsigned int xres, unsigned int yres, - unsigned int depth, char **fb) -{ - unsigned long size = xres * yres * depth; - struct diu_addr addr; - struct diu_ad *ad; - size_t ad_size = roundup(sizeof(struct diu_ad), 32); - - /* - * Allocate a memory block that holds the Area Descriptor and the - * frame buffer right behind it. To keep the code simple, everything - * is aligned on a 32-byte address. - */ - if (allocate_buf(&addr, ad_size + size, 32) < 0) - return NULL; - - ad = addr.vaddr; - ad->addr = cpu_to_le32(addr.paddr + ad_size); - ad->aoi_size = cpu_to_le32((yres << 16) | xres); - ad->src_size_g_alpha = cpu_to_le32((yres << 12) | xres); - ad->offset_xyi = 0; - ad->offset_xyd = 0; - - if (fb) - *fb = addr.vaddr + ad_size; - - return ad; -} - -int fsl_diu_init(u16 xres, u16 yres, u32 pixel_format, int gamma_fix) -{ - struct fb_videomode *fsl_diu_mode_db; - struct diu_ad *ad; - struct diu *hw = (struct diu *)CONFIG_SYS_DIU_ADDR; - u8 *gamma_table_base; - unsigned int i, j; - struct diu_addr gamma; - struct diu_addr cursor; - -/* Convert the X,Y resolution pair into a single number */ -#define RESOLUTION(x, y) (((u32)(x) << 16) | (y)) - - switch (RESOLUTION(xres, yres)) { - case RESOLUTION(800, 480): - fsl_diu_mode_db = &fsl_diu_mode_800_480; - break; - case RESOLUTION(800, 600): - fsl_diu_mode_db = &fsl_diu_mode_800_600; - break; - case RESOLUTION(1024, 768): - fsl_diu_mode_db = &fsl_diu_mode_1024_768; - break; - case RESOLUTION(1280, 1024): - fsl_diu_mode_db = &fsl_diu_mode_1280_1024; - break; - case RESOLUTION(1280, 720): - fsl_diu_mode_db = &fsl_diu_mode_1280_720; - break; - case RESOLUTION(1920, 1080): - fsl_diu_mode_db = &fsl_diu_mode_1920_1080; - break; - default: - printf("DIU: Unsupported resolution %ux%u\n", xres, yres); - return -1; - } - - /* read mode info */ - info.var.xres = fsl_diu_mode_db->xres; - info.var.yres = fsl_diu_mode_db->yres; - info.var.bits_per_pixel = 32; - info.var.pixclock = fsl_diu_mode_db->pixclock; - info.var.left_margin = fsl_diu_mode_db->left_margin; - info.var.right_margin = fsl_diu_mode_db->right_margin; - info.var.upper_margin = fsl_diu_mode_db->upper_margin; - info.var.lower_margin = fsl_diu_mode_db->lower_margin; - info.var.hsync_len = fsl_diu_mode_db->hsync_len; - info.var.vsync_len = fsl_diu_mode_db->vsync_len; - info.var.sync = fsl_diu_mode_db->sync; - info.var.vmode = fsl_diu_mode_db->vmode; - info.fix.line_length = info.var.xres * info.var.bits_per_pixel / 8; - - /* Memory allocation for framebuffer */ - info.screen_size = - info.var.xres * info.var.yres * (info.var.bits_per_pixel / 8); - ad = allocate_fb(info.var.xres, info.var.yres, - info.var.bits_per_pixel / 8, &info.screen_base); - if (!ad) { - printf("DIU: Out of memory\n"); - return -1; - } - - ad->pix_fmt = pixel_format; - - /* Disable chroma keying function */ - ad->ckmax_r = 0; - ad->ckmax_g = 0; - ad->ckmax_b = 0; - - ad->ckmin_r = 255; - ad->ckmin_g = 255; - ad->ckmin_b = 255; - - /* Initialize the gamma table */ - if (allocate_buf(&gamma, 256 * 3, 32) < 0) { - printf("DIU: Out of memory\n"); - return -1; - } - gamma_table_base = gamma.vaddr; - for (i = 0; i <= 2; i++) - for (j = 0; j < 256; j++) - *gamma_table_base++ = j; - - if (gamma_fix == 1) { /* fix the gamma */ - gamma_table_base = gamma.vaddr; - for (i = 0; i < 256 * 3; i++) { - gamma_table_base[i] = (gamma_table_base[i] << 2) - | ((gamma_table_base[i] >> 6) & 0x03); - } - } - - /* Initialize the cursor */ - if (allocate_buf(&cursor, 32 * 32 * 2, 32) < 0) { - printf("DIU: Can't alloc cursor data\n"); - return -1; - } - - /* Program DIU registers */ - out_be32(&hw->diu_mode, 0); /* Temporarily disable the DIU */ - - out_be32(&hw->gamma, gamma.paddr); - out_be32(&hw->cursor, cursor.paddr); - out_be32(&hw->bgnd, 0x007F7F7F); - out_be32(&hw->disp_size, info.var.yres << 16 | info.var.xres); - out_be32(&hw->hsyn_para, info.var.left_margin << 22 | - info.var.hsync_len << 11 | - info.var.right_margin); - - out_be32(&hw->vsyn_para, info.var.upper_margin << 22 | - info.var.vsync_len << 11 | - info.var.lower_margin); - - /* Pixel Clock configuration */ - diu_set_pixel_clock(info.var.pixclock); - - /* Set the frame buffers */ - out_be32(&hw->desc[0], virt_to_phys(ad)); - out_be32(&hw->desc[1], 0); - out_be32(&hw->desc[2], 0); - - /* Enable the DIU, set display to all three planes */ - out_be32(&hw->diu_mode, 1); - - return 0; -} - -void *video_hw_init(void) -{ - static GraphicDevice ctfb; - const char *options; - unsigned int depth = 0, freq = 0; - - if (!video_get_video_mode(&ctfb.winSizeX, &ctfb.winSizeY, &depth, &freq, - &options)) - return NULL; - - /* Find the monitor port, which is a required option */ - if (!options) - return NULL; - if (strncmp(options, "monitor=", 8) != 0) - return NULL; - - if (platform_diu_init(ctfb.winSizeX, ctfb.winSizeY, options + 8) < 0) - return NULL; - - /* fill in Graphic device struct */ - sprintf(ctfb.modeIdent, "%ix%ix%i %ikHz %iHz", - ctfb.winSizeX, ctfb.winSizeY, depth, 64, freq); - - ctfb.frameAdrs = (unsigned int)info.screen_base; - ctfb.plnSizeX = ctfb.winSizeX; - ctfb.plnSizeY = ctfb.winSizeY; - - ctfb.gdfBytesPP = 4; - ctfb.gdfIndex = GDF_32BIT_X888RGB; - - ctfb.isaBase = 0; - ctfb.pciBase = 0; - ctfb.memSize = info.screen_size; - - /* Cursor Start Address */ - ctfb.dprBase = 0; - ctfb.vprBase = 0; - ctfb.cprBase = 0; - - return &ctfb; -} diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 71c96102dd4..aac8103df2b 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -368,18 +368,6 @@ #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600)
-/* Video */ -#undef CONFIG_FSL_DIU_FB /* RDB doesn't support DIU */ -#ifdef CONFIG_FSL_DIU_FB -#define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) -#define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS -/* - * With CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS, flash I/O is really slow, so - * disable empty flash sector detection, which is I/O-intensive. - */ -#undef CONFIG_SYS_FLASH_EMPTY_INFO -#endif - /* I2C */
#define I2C_PCA6408_BUS_NUM 1 diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 0a8694f186e..2d48e14077d 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -354,18 +354,6 @@ #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600)
-#if defined(CONFIG_TARGET_T1042RDB_PI) || defined(CONFIG_TARGET_T1042D4RDB) -/* Video */ -#define CONFIG_FSL_DIU_FB - -#ifdef CONFIG_FSL_DIU_FB -#define CONFIG_FSL_DIU_CH7301 -#define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) -#endif -#endif - -/* I2C */ - /* I2C bus multiplexer */ #define I2C_MUX_PCA_ADDR 0x70 #define I2C_MUX_CH_DEFAULT 0x8 @@ -571,18 +559,11 @@ #define FDTFILE "t1042rdb/t1042d4rdb.dtb" #endif
-#ifdef CONFIG_FSL_DIU_FB -#define DIU_ENVIRONMENT "video-mode=fslfb:1024x768-32@60,monitor=dvi" -#else -#define DIU_ENVIRONMENT -#endif - #define CONFIG_EXTRA_ENV_SETTINGS \ "hwconfig=fsl_ddr:bank_intlv=cs0_cs1;" \ "usb1:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) ";"\ "usb2:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) "\0"\ "netdev=eth0\0" \ - "video-mode=" __stringify(DIU_ENVIRONMENT) "\0" \ "uboot=" __stringify(CONFIG_UBOOTPATH) "\0" \ "ubootaddr=" __stringify(CONFIG_SYS_TEXT_BASE) "\0" \ "tftpflash=tftpboot $loadaddr $uboot && " \ diff --git a/include/fsl_diu_fb.h b/include/fsl_diu_fb.h deleted file mode 100644 index 139851ba1a8..00000000000 --- a/include/fsl_diu_fb.h +++ /dev/null @@ -1,14 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright 2007, 2011 Freescale Semiconductor, Inc. - * Authors: York Sun yorksun@freescale.com - * Timur Tabi timur@freescale.com - * - * FSL DIU Framebuffer driver - */ - -int fsl_diu_init(u16 xres, u16 yres, u32 pixel_format, int gamma_fix); - -/* Prototypes for external board-specific functions */ -int platform_diu_init(unsigned int xres, unsigned int yres, const char *port); -void diu_set_pixel_clock(unsigned int pixclock); diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index f63eddfea4f..1edee279c4e 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -211,8 +211,6 @@ CONFIG_FSL_CADMUS CONFIG_FSL_CORENET CONFIG_FSL_CPLD CONFIG_FSL_DEVICE_DISABLE -CONFIG_FSL_DIU_CH7301 -CONFIG_FSL_DIU_FB CONFIG_FSL_DSPI1 CONFIG_FSL_ESDHC_PIN_MUX CONFIG_FSL_FIXED_MMC_LOCATION @@ -1074,7 +1072,6 @@ CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS CONFIG_SYS_DIALOG_PMIC_I2C_ADDR CONFIG_SYS_DIRECT_FLASH_TFTP CONFIG_SYS_DISCOVER_PHY -CONFIG_SYS_DIU_ADDR CONFIG_SYS_DPAA_DCE CONFIG_SYS_DPAA_FMAN CONFIG_SYS_DPAA_PME
This is no-longer used and is the last reference to video_hw_init(). Drop it.
drivers/video/mxsfb.c | 89 ------------------------------------------- 1 file changed, 89 deletions(-)
diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c index 99a15e0c25d..10433949bb8 100644 --- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -252,94 +252,6 @@ static int mxs_remove_common(u32 fb) return 0; }
-#ifndef CONFIG_DM_VIDEO - -static GraphicDevice panel; - -void lcdif_power_down(void) -{ - mxs_remove_common(panel.frameAdrs); -} - -void *video_hw_init(void) -{ - int bpp = -1; - int ret = 0; - char *penv; - void *fb = NULL; - struct ctfb_res_modes mode; - struct display_timing timings; - - puts("Video: "); - - /* Suck display configuration from "videomode" variable */ - penv = env_get("videomode"); - if (!penv) { - puts("MXSFB: 'videomode' variable not set!\n"); - return NULL; - } - - bpp = video_get_params(&mode, penv); - - /* fill in Graphic device struct */ - sprintf(panel.modeIdent, "%dx%dx%d", mode.xres, mode.yres, bpp); - - panel.winSizeX = mode.xres; - panel.winSizeY = mode.yres; - panel.plnSizeX = mode.xres; - panel.plnSizeY = mode.yres; - - switch (bpp) { - case 24: - case 18: - panel.gdfBytesPP = 4; - panel.gdfIndex = GDF_32BIT_X888RGB; - break; - case 16: - panel.gdfBytesPP = 2; - panel.gdfIndex = GDF_16BIT_565RGB; - break; - case 8: - panel.gdfBytesPP = 1; - panel.gdfIndex = GDF__8BIT_INDEX; - break; - default: - printf("MXSFB: Invalid BPP specified! (bpp = %i)\n", bpp); - return NULL; - } - - panel.memSize = mode.xres * mode.yres * panel.gdfBytesPP; - - /* Allocate framebuffer */ - fb = memalign(ARCH_DMA_MINALIGN, - roundup(panel.memSize, ARCH_DMA_MINALIGN)); - if (!fb) { - printf("MXSFB: Error allocating framebuffer!\n"); - return NULL; - } - - /* Wipe framebuffer */ - memset(fb, 0, panel.memSize); - - panel.frameAdrs = (u32)fb; - - printf("%s\n", panel.modeIdent); - - video_ctfb_mode_to_display_timing(&mode, &timings); - - ret = mxs_probe_common(NULL, &timings, bpp, (u32)fb); - if (ret) - goto dealloc_fb; - - return (void *)&panel; - -dealloc_fb: - free(fb); - - return NULL; -} -#else /* ifndef CONFIG_DM_VIDEO */ - static int mxs_of_get_timings(struct udevice *dev, struct display_timing *timings, u32 *bpp) @@ -489,4 +401,3 @@ U_BOOT_DRIVER(mxs_video) = { .remove = mxs_video_remove, .flags = DM_FLAG_PRE_RELOC | DM_FLAG_OS_PREPARE, }; -#endif /* ifndef CONFIG_DM_VIDEO */
This converts the following to Kconfig: CONFIG_VIDEO_BCM2835
This is the final ad-hoc CONFIG_VIDEO_... to convert.
configs/rpi_0_w_defconfig | 1 + configs/rpi_2_defconfig | 1 + configs/rpi_3_32b_defconfig | 1 + configs/rpi_3_b_plus_defconfig | 1 + configs/rpi_3_defconfig | 1 + configs/rpi_4_32b_defconfig | 1 + configs/rpi_4_defconfig | 1 + configs/rpi_arm64_defconfig | 1 + configs/rpi_defconfig | 1 + drivers/video/Kconfig | 8 ++++++++ include/configs/rpi.h | 1 - scripts/config_whitelist.txt | 1 - 12 files changed, 17 insertions(+), 2 deletions(-)
diff --git a/configs/rpi_0_w_defconfig b/configs/rpi_0_w_defconfig index 195541c6e76..819618280f7 100644 --- a/configs/rpi_0_w_defconfig +++ b/configs/rpi_0_w_defconfig @@ -41,6 +41,7 @@ CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP16 is not set CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_VIDEO_BCM2835=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index eb63fbdd8d9..9ccd69cbd88 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -42,6 +42,7 @@ CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP16 is not set CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_VIDEO_BCM2835=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/rpi_3_32b_defconfig b/configs/rpi_3_32b_defconfig index 46102899f03..de4a14e69ce 100644 --- a/configs/rpi_3_32b_defconfig +++ b/configs/rpi_3_32b_defconfig @@ -45,6 +45,7 @@ CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP16 is not set CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_VIDEO_BCM2835=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/rpi_3_b_plus_defconfig b/configs/rpi_3_b_plus_defconfig index 91b63b62721..1d4346c0ec8 100644 --- a/configs/rpi_3_b_plus_defconfig +++ b/configs/rpi_3_b_plus_defconfig @@ -44,6 +44,7 @@ CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP16 is not set CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_VIDEO_BCM2835=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/rpi_3_defconfig b/configs/rpi_3_defconfig index 528b12ea5b5..c7615403d33 100644 --- a/configs/rpi_3_defconfig +++ b/configs/rpi_3_defconfig @@ -44,6 +44,7 @@ CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP16 is not set CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_VIDEO_BCM2835=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/rpi_4_32b_defconfig b/configs/rpi_4_32b_defconfig index 8f87a4336d2..d9d9331f580 100644 --- a/configs/rpi_4_32b_defconfig +++ b/configs/rpi_4_32b_defconfig @@ -59,6 +59,7 @@ CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP16 is not set CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_VIDEO_BCM2835=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_PHYS_TO_BUS=y CONFIG_ADDR_MAP=y diff --git a/configs/rpi_4_defconfig b/configs/rpi_4_defconfig index 461a7655ab9..eac55ccbcb8 100644 --- a/configs/rpi_4_defconfig +++ b/configs/rpi_4_defconfig @@ -59,6 +59,7 @@ CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP16 is not set CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_VIDEO_BCM2835=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/rpi_arm64_defconfig b/configs/rpi_arm64_defconfig index 351d247daeb..a0cbdbef02f 100644 --- a/configs/rpi_arm64_defconfig +++ b/configs/rpi_arm64_defconfig @@ -51,6 +51,7 @@ CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP16 is not set CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_VIDEO_BCM2835=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/rpi_defconfig b/configs/rpi_defconfig index 0baef3b6abf..bd4e3dc42d7 100644 --- a/configs/rpi_defconfig +++ b/configs/rpi_defconfig @@ -41,6 +41,7 @@ CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP16 is not set CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_VIDEO_BCM2835=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index e74a3dd9285..2fba1f2e122 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -421,6 +421,14 @@ config VIDEO_LCD_ANX9804 from a parallel LCD interface and translate it on the fy into a DP interface for driving eDP TFT displays. It uses I2C for configuration.
+config VIDEO_BCM2835 + bool "Display support for BCM2835" + help + The graphics processor already sets up the display so this driver + simply checks the resolution and then sets up the frame buffer with + that same resolution (or as near as possible) and 32bpp depth, so + that U-Boot can access it with full colour depth. + config VIDEO_LCD_ORISETECH_OTM8009A bool "OTM8009A DSI LCD panel support" depends on DM_VIDEO diff --git a/include/configs/rpi.h b/include/configs/rpi.h index d5e064fb379..c439ec1b302 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -44,7 +44,6 @@ /* GPIO */ #define CONFIG_BCM2835_GPIO /* LCD */ -#define CONFIG_VIDEO_BCM2835
/* DFU over USB/UDC */ #ifdef CONFIG_CMD_DFU diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 1edee279c4e..28702543087 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2111,7 +2111,6 @@ CONFIG_USE_ONENAND_BOARD_INIT CONFIG_U_BOOT_HDR_SIZE CONFIG_VAR_SIZE_SPL CONFIG_VERY_BIG_RAM -CONFIG_VIDEO_BCM2835 CONFIG_VSC7385_ENET CONFIG_VSC7385_IMAGE CONFIG_VSC7385_IMAGE_SIZE
Acked-by: Matthias Brugger mbrugger@suse.com
- bool "Display support for BCM2835"
- help
- config VIDEO_LCD_ORISETECH_OTM8009A bool "OTM8009A DSI LCD panel support" depends on DM_VIDEO
This is not used. Drop it.
drivers/video/Makefile | 1 - drivers/video/formike.c | 513 ----------------------------------- scripts/config_whitelist.txt | 1 - 3 files changed, 515 deletions(-) delete mode 100644 drivers/video/formike.c
diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 4f8fe3810b3..50de161c35a 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -30,7 +30,6 @@ obj-y += ti/
obj-$(CONFIG_ATMEL_HLCD) += atmel_hlcdfb.o obj-$(CONFIG_ATMEL_LCD) += atmel_lcdfb.o -obj-$(CONFIG_FORMIKE) += formike.o obj-$(CONFIG_IHS_VIDEO_OUT) += ihs_video_out.o obj-$(CONFIG_LD9040) += ld9040.o obj-$(CONFIG_LG4573) += lg4573.o diff --git a/drivers/video/formike.c b/drivers/video/formike.c deleted file mode 100644 index 5cbe50d4cbd..00000000000 --- a/drivers/video/formike.c +++ /dev/null @@ -1,513 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * LCD: Formike, TFT 4.3", 480x800, RGB24, KWH043ST20-F01, DriverIC NT35510-16 - * LCD initialization via SPI - * Based on: - * - */ -#include <common.h> -#include <errno.h> -#include <log.h> -#include <spi.h> -#include <linux/delay.h> - -#define TAG_READ 0x80 -#define TAG_WRITE 0x00 - -#define TAG_DATA 0x40 -#define TAG_COMMAND 0x00 - -#define TAG_ADDR_H 0x20 -#define TAG_ADDR_L 0x00 - -static int spi_write_tag_val(struct spi_slave *spi, unsigned char tag, - unsigned char val) -{ - unsigned long flags = SPI_XFER_BEGIN; - u8 buf[2]; - int ret; - - buf[0] = tag; - ret = spi_xfer(spi, 8, buf, NULL, flags); - buf[0] = val; - flags = SPI_XFER_END; - ret = spi_xfer(spi, 8, buf, NULL, flags); - -#ifdef KWH043ST20_F01_SPI_DEBUG - printf("spi_write_tag_val: tag=%02X, val=%02X ret: %d\n", - tag, val, ret); -#endif /* KWH043ST20_F01_SPI_DEBUG */ - if (ret) - debug("%s: Failed to send: %d\n", __func__, ret); - - return ret; -} - -static void spi_write_dat(struct spi_slave *spi, unsigned int val) -{ - spi_write_tag_val(spi, TAG_WRITE|TAG_DATA, val); -} - -static void spi_write_com(struct spi_slave *spi, unsigned int addr) -{ - spi_write_tag_val(spi, TAG_WRITE|TAG_COMMAND|TAG_ADDR_H, - (addr & 0xff00) >> 8); - spi_write_tag_val(spi, TAG_WRITE|TAG_COMMAND|TAG_ADDR_L, - (addr & 0x00ff) >> 0); -} - -int kwh043st20_f01_spi_startup(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int spi_mode) -{ - struct spi_slave *spi; - int ret; - - spi = spi_setup_slave(bus, cs, max_hz, spi_mode); - if (!spi) { - debug("%s: Failed to set up slave\n", __func__); - return -1; - } - - ret = spi_claim_bus(spi); - if (ret) { - debug("%s: Failed to claim SPI bus: %d\n", __func__, ret); - goto err_claim_bus; - } - - - /* LV2 Page 1 enable */ - spi_write_com(spi, 0xF000); spi_write_dat(spi, 0x55); - spi_write_com(spi, 0xF001); spi_write_dat(spi, 0xAA); - spi_write_com(spi, 0xF002); spi_write_dat(spi, 0x52); - spi_write_com(spi, 0xF003); spi_write_dat(spi, 0x08); - spi_write_com(spi, 0xF004); spi_write_dat(spi, 0x01); - - /* AVDD Set AVDD 5.2V */ - spi_write_com(spi, 0xB000); spi_write_dat(spi, 0x0D); - spi_write_com(spi, 0xB001); spi_write_dat(spi, 0x0D); - spi_write_com(spi, 0xB002); spi_write_dat(spi, 0x0D); - - /* AVDD ratio */ - spi_write_com(spi, 0xB600); spi_write_dat(spi, 0x34); - spi_write_com(spi, 0xB601); spi_write_dat(spi, 0x34); - spi_write_com(spi, 0xB602); spi_write_dat(spi, 0x34); - - /* AVEE -5.2V */ - spi_write_com(spi, 0xB100); spi_write_dat(spi, 0x0D); - spi_write_com(spi, 0xB101); spi_write_dat(spi, 0x0D); - spi_write_com(spi, 0xB102); spi_write_dat(spi, 0x0D); - - /* AVEE ratio */ - spi_write_com(spi, 0xB700); spi_write_dat(spi, 0x35); - spi_write_com(spi, 0xB701); spi_write_dat(spi, 0x35); - spi_write_com(spi, 0xB702); spi_write_dat(spi, 0x35); - - /* VCL -2.5V */ - spi_write_com(spi, 0xB200); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xB201); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xB202); spi_write_dat(spi, 0x00); - - /* VCL ratio */ - spi_write_com(spi, 0xB800); spi_write_dat(spi, 0x24); - spi_write_com(spi, 0xB801); spi_write_dat(spi, 0x24); - spi_write_com(spi, 0xB802); spi_write_dat(spi, 0x24); - - /* VGH 15V */ - spi_write_com(spi, 0xBF00); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xB300); spi_write_dat(spi, 0x08); - spi_write_com(spi, 0xB301); spi_write_dat(spi, 0x08); - spi_write_com(spi, 0xB302); spi_write_dat(spi, 0x08); - - /* VGH ratio */ - spi_write_com(spi, 0xB900); spi_write_dat(spi, 0x34); - spi_write_com(spi, 0xB901); spi_write_dat(spi, 0x34); - spi_write_com(spi, 0xB902); spi_write_dat(spi, 0x34); - - /* VGLX ratio */ - spi_write_com(spi, 0xBA00); spi_write_dat(spi, 0x24); - spi_write_com(spi, 0xBA01); spi_write_dat(spi, 0x24); - spi_write_com(spi, 0xBA02); spi_write_dat(spi, 0x24); - - /* VGMP/VGSP 4.7V/0V */ - spi_write_com(spi, 0xBC00); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xBC01); spi_write_dat(spi, 0x88); - spi_write_com(spi, 0xBC02); spi_write_dat(spi, 0x00); - - /* VGMN/VGSN -4.7V/0V */ - spi_write_com(spi, 0xBD00); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xBD01); spi_write_dat(spi, 0x88); - spi_write_com(spi, 0xBD02); spi_write_dat(spi, 0x00); - - /* VCOM 1.525V */ - spi_write_com(spi, 0xBE00); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xBE01); spi_write_dat(spi, 0x7A); - - /* Gamma Setting */ - spi_write_com(spi, 0xD100); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD101); spi_write_dat(spi, 0x05); - spi_write_com(spi, 0xD102); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD103); spi_write_dat(spi, 0x15); - spi_write_com(spi, 0xD104); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD105); spi_write_dat(spi, 0x30); - spi_write_com(spi, 0xD106); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD107); spi_write_dat(spi, 0x47); - spi_write_com(spi, 0xD108); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD109); spi_write_dat(spi, 0x5B); - spi_write_com(spi, 0xD10A); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD10B); spi_write_dat(spi, 0x7D); - spi_write_com(spi, 0xD10C); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD10D); spi_write_dat(spi, 0x9D); - spi_write_com(spi, 0xD10E); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD10F); spi_write_dat(spi, 0xCC); - spi_write_com(spi, 0xD110); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD111); spi_write_dat(spi, 0xF3); - spi_write_com(spi, 0xD112); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD113); spi_write_dat(spi, 0x32); - spi_write_com(spi, 0xD114); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD115); spi_write_dat(spi, 0x63); - spi_write_com(spi, 0xD116); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD117); spi_write_dat(spi, 0xB1); - spi_write_com(spi, 0xD118); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD119); spi_write_dat(spi, 0xF0); - spi_write_com(spi, 0xD11A); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD11B); spi_write_dat(spi, 0xF2); - spi_write_com(spi, 0xD11C); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD11D); spi_write_dat(spi, 0x2A); - spi_write_com(spi, 0xD11E); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD11F); spi_write_dat(spi, 0x67); - spi_write_com(spi, 0xD120); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD121); spi_write_dat(spi, 0x90); - spi_write_com(spi, 0xD122); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD123); spi_write_dat(spi, 0xCB); - spi_write_com(spi, 0xD124); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD125); spi_write_dat(spi, 0xF2); - spi_write_com(spi, 0xD126); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD127); spi_write_dat(spi, 0x2A); - spi_write_com(spi, 0xD128); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD129); spi_write_dat(spi, 0x51); - spi_write_com(spi, 0xD12A); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD12B); spi_write_dat(spi, 0x80); - spi_write_com(spi, 0xD12C); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD12D); spi_write_dat(spi, 0x9F); - spi_write_com(spi, 0xD12E); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD12F); spi_write_dat(spi, 0xBE); - spi_write_com(spi, 0xD130); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD131); spi_write_dat(spi, 0xF9); - spi_write_com(spi, 0xD132); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD133); spi_write_dat(spi, 0xFF); - - spi_write_com(spi, 0xD200); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD201); spi_write_dat(spi, 0x05); - spi_write_com(spi, 0xD202); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD203); spi_write_dat(spi, 0x15); - spi_write_com(spi, 0xD204); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD205); spi_write_dat(spi, 0x30); - spi_write_com(spi, 0xD206); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD207); spi_write_dat(spi, 0x47); - spi_write_com(spi, 0xD208); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD209); spi_write_dat(spi, 0x5B); - spi_write_com(spi, 0xD20A); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD20B); spi_write_dat(spi, 0x7D); - spi_write_com(spi, 0xD20C); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD20D); spi_write_dat(spi, 0x9D); - spi_write_com(spi, 0xD20E); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD20F); spi_write_dat(spi, 0xCC); - spi_write_com(spi, 0xD210); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD211); spi_write_dat(spi, 0xF3); - spi_write_com(spi, 0xD212); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD213); spi_write_dat(spi, 0x32); - spi_write_com(spi, 0xD214); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD215); spi_write_dat(spi, 0x63); - spi_write_com(spi, 0xD216); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD217); spi_write_dat(spi, 0xB1); - spi_write_com(spi, 0xD218); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD219); spi_write_dat(spi, 0xF0); - spi_write_com(spi, 0xD21A); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD21B); spi_write_dat(spi, 0xF2); - spi_write_com(spi, 0xD21C); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD21D); spi_write_dat(spi, 0x2A); - spi_write_com(spi, 0xD21E); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD21F); spi_write_dat(spi, 0x67); - spi_write_com(spi, 0xD220); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD221); spi_write_dat(spi, 0x90); - spi_write_com(spi, 0xD222); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD223); spi_write_dat(spi, 0xCB); - spi_write_com(spi, 0xD224); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD225); spi_write_dat(spi, 0xF2); - spi_write_com(spi, 0xD226); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD227); spi_write_dat(spi, 0x2A); - spi_write_com(spi, 0xD228); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD229); spi_write_dat(spi, 0x51); - spi_write_com(spi, 0xD22A); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD22B); spi_write_dat(spi, 0x80); - spi_write_com(spi, 0xD22C); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD22D); spi_write_dat(spi, 0x9F); - spi_write_com(spi, 0xD22E); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD22F); spi_write_dat(spi, 0xBE); - spi_write_com(spi, 0xD230); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD231); spi_write_dat(spi, 0xF9); - spi_write_com(spi, 0xD232); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD233); spi_write_dat(spi, 0xFF); - - spi_write_com(spi, 0xD300); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD301); spi_write_dat(spi, 0x05); - spi_write_com(spi, 0xD302); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD303); spi_write_dat(spi, 0x15); - spi_write_com(spi, 0xD304); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD305); spi_write_dat(spi, 0x30); - spi_write_com(spi, 0xD306); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD307); spi_write_dat(spi, 0x47); - spi_write_com(spi, 0xD308); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD309); spi_write_dat(spi, 0x5B); - spi_write_com(spi, 0xD30A); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD30B); spi_write_dat(spi, 0x7D); - spi_write_com(spi, 0xD30C); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD30D); spi_write_dat(spi, 0x9D); - spi_write_com(spi, 0xD30E); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD30F); spi_write_dat(spi, 0xCC); - spi_write_com(spi, 0xD310); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD311); spi_write_dat(spi, 0xF3); - spi_write_com(spi, 0xD312); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD313); spi_write_dat(spi, 0x32); - spi_write_com(spi, 0xD314); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD315); spi_write_dat(spi, 0x63); - spi_write_com(spi, 0xD316); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD317); spi_write_dat(spi, 0xB1); - spi_write_com(spi, 0xD318); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD319); spi_write_dat(spi, 0xF0); - spi_write_com(spi, 0xD31A); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD31B); spi_write_dat(spi, 0xF2); - spi_write_com(spi, 0xD31C); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD31D); spi_write_dat(spi, 0x2A); - spi_write_com(spi, 0xD31E); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD31F); spi_write_dat(spi, 0x67); - spi_write_com(spi, 0xD320); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD321); spi_write_dat(spi, 0x90); - spi_write_com(spi, 0xD322); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD323); spi_write_dat(spi, 0xCB); - spi_write_com(spi, 0xD324); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD325); spi_write_dat(spi, 0xF2); - spi_write_com(spi, 0xD326); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD327); spi_write_dat(spi, 0x2A); - spi_write_com(spi, 0xD328); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD329); spi_write_dat(spi, 0x51); - spi_write_com(spi, 0xD32A); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD32B); spi_write_dat(spi, 0x80); - spi_write_com(spi, 0xD32C); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD32D); spi_write_dat(spi, 0x9F); - spi_write_com(spi, 0xD32E); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD32F); spi_write_dat(spi, 0xBE); - spi_write_com(spi, 0xD330); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD331); spi_write_dat(spi, 0xF9); - spi_write_com(spi, 0xD332); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD333); spi_write_dat(spi, 0xFF); - - spi_write_com(spi, 0xD400); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD401); spi_write_dat(spi, 0x05); - spi_write_com(spi, 0xD402); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD403); spi_write_dat(spi, 0x15); - spi_write_com(spi, 0xD404); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD405); spi_write_dat(spi, 0x30); - spi_write_com(spi, 0xD406); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD407); spi_write_dat(spi, 0x47); - spi_write_com(spi, 0xD408); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD409); spi_write_dat(spi, 0x5B); - spi_write_com(spi, 0xD40A); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD40B); spi_write_dat(spi, 0x7D); - spi_write_com(spi, 0xD40C); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD40D); spi_write_dat(spi, 0x9D); - spi_write_com(spi, 0xD40E); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD40F); spi_write_dat(spi, 0xCC); - spi_write_com(spi, 0xD410); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD411); spi_write_dat(spi, 0xF3); - spi_write_com(spi, 0xD412); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD413); spi_write_dat(spi, 0x32); - spi_write_com(spi, 0xD414); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD415); spi_write_dat(spi, 0x63); - spi_write_com(spi, 0xD416); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD417); spi_write_dat(spi, 0xB1); - spi_write_com(spi, 0xD418); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD419); spi_write_dat(spi, 0xF0); - spi_write_com(spi, 0xD41A); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD41B); spi_write_dat(spi, 0xF2); - spi_write_com(spi, 0xD41C); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD41D); spi_write_dat(spi, 0x2A); - spi_write_com(spi, 0xD41E); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD41F); spi_write_dat(spi, 0x67); - spi_write_com(spi, 0xD420); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD421); spi_write_dat(spi, 0x90); - spi_write_com(spi, 0xD422); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD423); spi_write_dat(spi, 0xCB); - spi_write_com(spi, 0xD424); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD425); spi_write_dat(spi, 0xF2); - spi_write_com(spi, 0xD426); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD427); spi_write_dat(spi, 0x2A); - spi_write_com(spi, 0xD428); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD429); spi_write_dat(spi, 0x51); - spi_write_com(spi, 0xD42A); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD42B); spi_write_dat(spi, 0x80); - spi_write_com(spi, 0xD42C); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD42D); spi_write_dat(spi, 0x9F); - spi_write_com(spi, 0xD42E); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD42F); spi_write_dat(spi, 0xBE); - spi_write_com(spi, 0xD430); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD431); spi_write_dat(spi, 0xF9); - spi_write_com(spi, 0xD432); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD433); spi_write_dat(spi, 0xFF); - - spi_write_com(spi, 0xD500); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD501); spi_write_dat(spi, 0x05); - spi_write_com(spi, 0xD502); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD503); spi_write_dat(spi, 0x15); - spi_write_com(spi, 0xD504); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD505); spi_write_dat(spi, 0x30); - spi_write_com(spi, 0xD506); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD507); spi_write_dat(spi, 0x47); - spi_write_com(spi, 0xD508); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD509); spi_write_dat(spi, 0x5B); - spi_write_com(spi, 0xD50A); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD50B); spi_write_dat(spi, 0x7D); - spi_write_com(spi, 0xD50C); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD50D); spi_write_dat(spi, 0x9D); - spi_write_com(spi, 0xD50E); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD50F); spi_write_dat(spi, 0xCC); - spi_write_com(spi, 0xD510); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD511); spi_write_dat(spi, 0xF3); - spi_write_com(spi, 0xD512); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD513); spi_write_dat(spi, 0x32); - spi_write_com(spi, 0xD514); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD515); spi_write_dat(spi, 0x63); - spi_write_com(spi, 0xD516); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD517); spi_write_dat(spi, 0xB1); - spi_write_com(spi, 0xD518); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD519); spi_write_dat(spi, 0xF0); - spi_write_com(spi, 0xD51A); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD51B); spi_write_dat(spi, 0xF2); - spi_write_com(spi, 0xD51C); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD51D); spi_write_dat(spi, 0x2A); - spi_write_com(spi, 0xD51E); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD51F); spi_write_dat(spi, 0x67); - spi_write_com(spi, 0xD520); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD521); spi_write_dat(spi, 0x90); - spi_write_com(spi, 0xD522); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD523); spi_write_dat(spi, 0xCB); - spi_write_com(spi, 0xD524); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD525); spi_write_dat(spi, 0xF2); - spi_write_com(spi, 0xD526); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD527); spi_write_dat(spi, 0x2A); - spi_write_com(spi, 0xD528); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD529); spi_write_dat(spi, 0x51); - spi_write_com(spi, 0xD52A); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD52B); spi_write_dat(spi, 0x80); - spi_write_com(spi, 0xD52C); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD52D); spi_write_dat(spi, 0x9F); - spi_write_com(spi, 0xD52E); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD52F); spi_write_dat(spi, 0xBE); - spi_write_com(spi, 0xD530); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD531); spi_write_dat(spi, 0xF9); - spi_write_com(spi, 0xD532); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD533); spi_write_dat(spi, 0xFF); - - spi_write_com(spi, 0xD600); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD601); spi_write_dat(spi, 0x05); - spi_write_com(spi, 0xD602); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD603); spi_write_dat(spi, 0x15); - spi_write_com(spi, 0xD604); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD605); spi_write_dat(spi, 0x30); - spi_write_com(spi, 0xD606); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD607); spi_write_dat(spi, 0x47); - spi_write_com(spi, 0xD608); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD609); spi_write_dat(spi, 0x5B); - spi_write_com(spi, 0xD60A); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD60B); spi_write_dat(spi, 0x7D); - spi_write_com(spi, 0xD60C); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD60D); spi_write_dat(spi, 0x9D); - spi_write_com(spi, 0xD60E); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD60F); spi_write_dat(spi, 0xCC); - spi_write_com(spi, 0xD610); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xD611); spi_write_dat(spi, 0xF3); - spi_write_com(spi, 0xD612); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD613); spi_write_dat(spi, 0x32); - spi_write_com(spi, 0xD614); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD615); spi_write_dat(spi, 0x63); - spi_write_com(spi, 0xD616); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD617); spi_write_dat(spi, 0xB1); - spi_write_com(spi, 0xD618); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD619); spi_write_dat(spi, 0xF0); - spi_write_com(spi, 0xD61A); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xD61B); spi_write_dat(spi, 0xF2); - spi_write_com(spi, 0xD61C); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD61D); spi_write_dat(spi, 0x2A); - spi_write_com(spi, 0xD61E); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD61F); spi_write_dat(spi, 0x67); - spi_write_com(spi, 0xD620); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD621); spi_write_dat(spi, 0x90); - spi_write_com(spi, 0xD622); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD623); spi_write_dat(spi, 0xCB); - spi_write_com(spi, 0xD624); spi_write_dat(spi, 0x02); - spi_write_com(spi, 0xD625); spi_write_dat(spi, 0xF2); - spi_write_com(spi, 0xD626); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD627); spi_write_dat(spi, 0x2A); - spi_write_com(spi, 0xD628); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD629); spi_write_dat(spi, 0x51); - spi_write_com(spi, 0xD62A); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD62B); spi_write_dat(spi, 0x80); - spi_write_com(spi, 0xD62C); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD62D); spi_write_dat(spi, 0x9F); - spi_write_com(spi, 0xD62E); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD62F); spi_write_dat(spi, 0xBE); - spi_write_com(spi, 0xD630); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD631); spi_write_dat(spi, 0xF9); - spi_write_com(spi, 0xD632); spi_write_dat(spi, 0x03); - spi_write_com(spi, 0xD633); spi_write_dat(spi, 0xFF); - - /* LV2 Page 0 enable */ - spi_write_com(spi, 0xF000); spi_write_dat(spi, 0x55); - spi_write_com(spi, 0xF001); spi_write_dat(spi, 0xAA); - spi_write_com(spi, 0xF002); spi_write_dat(spi, 0x52); - spi_write_com(spi, 0xF003); spi_write_dat(spi, 0x08); - spi_write_com(spi, 0xF004); spi_write_dat(spi, 0x00); - - /* Display control */ - spi_write_com(spi, 0xB100); spi_write_dat(spi, 0xFC); - spi_write_com(spi, 0xB101); spi_write_dat(spi, 0x00); - - /* Source hold time */ - spi_write_com(spi, 0xB600); spi_write_dat(spi, 0x05); - - /* Gate EQ control */ - spi_write_com(spi, 0xB700); spi_write_dat(spi, 0x70); - spi_write_com(spi, 0xB701); spi_write_dat(spi, 0x70); - - /* Source EQ control (Mode 2) */ - spi_write_com(spi, 0xB800); spi_write_dat(spi, 0x01); - spi_write_com(spi, 0xB801); spi_write_dat(spi, 0x05); - spi_write_com(spi, 0xB802); spi_write_dat(spi, 0x05); - spi_write_com(spi, 0xB803); spi_write_dat(spi, 0x05); - - /* Inversion mode (Column) */ - spi_write_com(spi, 0xBC00); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xBC01); spi_write_dat(spi, 0x00); - spi_write_com(spi, 0xBC02); spi_write_dat(spi, 0x00); - - /* Timing control 8phase dual side/4H/4delay/RST_EN */ - spi_write_com(spi, 0xC900); spi_write_dat(spi, 0xD0); - spi_write_com(spi, 0xC901); spi_write_dat(spi, 0x82); - spi_write_com(spi, 0xC902); spi_write_dat(spi, 0x50); - spi_write_com(spi, 0xC903); spi_write_dat(spi, 0x50); - spi_write_com(spi, 0xC904); spi_write_dat(spi, 0x50); - - spi_write_com(spi, 0x3A00); spi_write_dat(spi, 0x55); - mdelay(120); - spi_write_com(spi, 0x1100); - mdelay(120); - spi_write_com(spi, 0x2900); - mdelay(120); - /* spi_write_com(spi, 0x2100); spi_write_dat(spi, 0x00); */ - spi_write_com(spi, 0x2C00); - - return 0; -err_claim_bus: - spi_free_slave(spi); - return -1; -} diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 28702543087..eeb0fdce432 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -204,7 +204,6 @@ CONFIG_FLASH_SHOW_PROGRESS CONFIG_FLASH_SPANSION_S29WS_N CONFIG_FLASH_VERIFY CONFIG_FM_PLAT_CLK_DIV -CONFIG_FORMIKE CONFIG_FPGA_COUNT CONFIG_FPGA_STRATIX_V CONFIG_FSL_CADMUS
Hi Anatolij,
On Sun, 23 Jan 2022 at 07:04, Simon Glass sjg@chromium.org wrote:
There is still quite a bit of cruft in the video subsystem. Mainly this is users of the now-removed CONFIG_VIDEO, cfb_console and CONFIG_LCD.
This series removes most of the first two. The exception is videomodes.c and its header, since these are used by sunxi. It looks like the code could be removed, but I did not attempt it.
This is left for the sunxi maintainer.
The LCD clean-up can come later. Once done, we can rename CONFIG_DM_VIDEO to CONFIG_VIDEO, thus completing the migration.
Simon Glass (14): video: Drop cfg_console video: nokia_rx51: Drop obsolete video code video: siemens: Drop unused video code video: nexell: Drop unused and invalid code video: Drop video_fb header video: Drop CONFIG_VIDEO_BMP_LOGO video: Drop references to CONFIG_VIDEO et al video: Clean up the uclass header video: Drop da8xx-fb video: fsl: colibri_vf: Drop FSL DCU driver video: Drop FSL DIU driver video: mxs: Drop old video code video: Convert CONFIG_VIDEO_BCM2835 to Kconfig video: Drop formike driver
README | 18 - arch/arm/cpu/armv7/ls102xa/soc.c | 4 - arch/arm/include/asm/arch-ls102xa/config.h | 1 - arch/arm/include/asm/mach-imx/mx5_video.h | 5 - .../mach-nexell/include/mach/display_dev.h | 7 +- board/aristainetos/aristainetos.c | 1 - board/freescale/common/Makefile | 4 - board/freescale/common/dcu_sii9022a.c | 248 --- board/freescale/common/dcu_sii9022a.h | 12 - board/freescale/common/diu_ch7301.c | 217 -- board/freescale/common/diu_ch7301.h | 12 - board/freescale/ls1021aiot/Makefile | 1 - board/freescale/ls1021aiot/dcu.c | 48 - board/freescale/ls1021aqds/Makefile | 1 - board/freescale/ls1021aqds/dcu.c | 110 - board/freescale/ls1021atwr/Makefile | 1 - board/freescale/ls1021atwr/dcu.c | 48 - board/freescale/mx51evk/Makefile | 1 - board/freescale/mx53loco/Makefile | 1 - board/freescale/t104xrdb/Makefile | 1 - board/freescale/t104xrdb/diu.c | 84 - board/kosagi/novena/novena_spl.c | 23 - board/nokia/rx51/rx51.c | 19 - board/siemens/common/board.c | 3 - board/siemens/common/factoryset.c | 7 - board/siemens/common/factoryset.h | 3 - board/siemens/pxm2/board.c | 189 -- board/siemens/rut/board.c | 247 --- board/socrates/socrates.c | 1 - board/toradex/colibri_vf/Makefile | 1 - board/toradex/colibri_vf/colibri_vf.c | 62 - board/toradex/colibri_vf/dcu.c | 38 - cmd/Kconfig | 2 +- cmd/bdinfo.c | 2 +- cmd/bmp.c | 4 +- cmd/cls.c | 2 - common/fdt_support.c | 2 +- common/stdio.c | 4 +- configs/colibri_vf_defconfig | 1 - configs/nokia_rx51_defconfig | 3 - configs/rpi_0_w_defconfig | 1 + configs/rpi_2_defconfig | 1 + configs/rpi_3_32b_defconfig | 1 + configs/rpi_3_b_plus_defconfig | 1 + configs/rpi_3_defconfig | 1 + configs/rpi_4_32b_defconfig | 1 + configs/rpi_4_defconfig | 1 + configs/rpi_arm64_defconfig | 1 + configs/rpi_defconfig | 1 + doc/usage/bootmenu.rst | 5 - drivers/pci/pci_rom.c | 1 - drivers/video/Kconfig | 129 +- drivers/video/Makefile | 5 - drivers/video/cfb_console.c | 1865 ----------------- drivers/video/da8xx-fb.c | 1048 --------- drivers/video/da8xx-fb.h | 115 - drivers/video/formike.c | 513 ----- drivers/video/fsl_dcu_fb.c | 549 ----- drivers/video/fsl_diu_fb.c | 416 ---- drivers/video/imx/mxc_ipuv3_fb.c | 1 - drivers/video/mxsfb.c | 90 - drivers/video/nexell_display.c | 18 +- drivers/video/omap3_dss.c | 29 - drivers/video/sunxi/sunxi_display.c | 1 - include/asm-generic/global_data.h | 2 +- include/configs/T102xRDB.h | 13 - include/configs/T104xRDB.h | 20 - include/configs/apalis_imx6.h | 1 - include/configs/aristainetos2.h | 1 - include/configs/cm_fx6.h | 2 - include/configs/colibri-imx6ull.h | 1 - include/configs/colibri_imx6.h | 1 - include/configs/colibri_imx7.h | 4 - include/configs/colibri_vf.h | 8 - include/configs/embestmx6boards.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/imx6-engicam.h | 2 - include/configs/imxrt1050-evk.h | 2 - include/configs/ls1021aqds.h | 12 - include/configs/ls1021atwr.h | 15 - include/configs/mx6cuboxi.h | 1 - include/configs/mx6sabre_common.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/mx6ul_14x14_evk.h | 1 - include/configs/mx7dsabresd.h | 4 - include/configs/nokia_rx51.h | 11 - include/configs/opos6uldev.h | 1 - include/configs/pico-imx6.h | 1 - include/configs/pico-imx6ul.h | 1 - include/configs/pico-imx7d.h | 4 - include/configs/pxm2.h | 8 - include/configs/rpi.h | 1 - include/configs/rut.h | 10 - include/configs/wandboard.h | 1 - include/fsl_dcu_fb.h | 22 - include/fsl_diu_fb.h | 14 - include/video.h | 84 +- include/video_fb.h | 91 - lib/efi_loader/Kconfig | 1 - scripts/config_whitelist.txt | 10 - 100 files changed, 33 insertions(+), 6553 deletions(-) delete mode 100644 board/freescale/common/dcu_sii9022a.c delete mode 100644 board/freescale/common/dcu_sii9022a.h delete mode 100644 board/freescale/common/diu_ch7301.c delete mode 100644 board/freescale/common/diu_ch7301.h delete mode 100644 board/freescale/ls1021aiot/dcu.c delete mode 100644 board/freescale/ls1021aqds/dcu.c delete mode 100644 board/freescale/ls1021atwr/dcu.c delete mode 100644 board/freescale/t104xrdb/diu.c delete mode 100644 board/toradex/colibri_vf/dcu.c delete mode 100644 drivers/video/cfb_console.c delete mode 100644 drivers/video/da8xx-fb.c delete mode 100644 drivers/video/da8xx-fb.h delete mode 100644 drivers/video/formike.c delete mode 100644 drivers/video/fsl_dcu_fb.c delete mode 100644 drivers/video/fsl_diu_fb.c delete mode 100644 include/fsl_dcu_fb.h delete mode 100644 include/fsl_diu_fb.h delete mode 100644 include/video_fb.h
-- 2.35.0.rc0.227.g00780c9af4-goog
Is there any word on this series, please?
On Thursday 24 March 2022 13:54:22 Simon Glass wrote:
Hi Anatolij,
Nokia board code does not use this cfb_console anymore... Or it is still affected?
Hi Pali,
Hi Anatolij,
It should not be affected. Maybe this patch can be dropped?
Hi Simon,
On Thu, 24 Mar 2022 13:54:22 -0600 Simon Glass sjg@chromium.org wrote: ...
last week I've rebased and applied this series to next (PATCH 02/14 dropped) and will submit a pull request when Tom merges last -rc into his next branch. Otherwise there will be a build error due to missing Nokia RX-51 related changes. Thanks!
-- Anatolij
Hi Anatloij,
On Fri, 25 Mar 2022 at 11:16, Anatolij Gustschin agust@denx.de wrote:
Hi Simon,
That's great, thank you! I was thinking of doing the same thing for LCD. What do you think?
Hi Simon,
On Fri, 25 Mar 2022 11:41:54 +1300 Simon Glass sjg@chromium.org wrote:
Hi Anatloij,
Hi Simon,
Yes, removing CONFIG_LCD code would be good. I hope we can do frame buffer support by DM_VIDEO for boards still using LCD.
-- Anatolij
On Sun, 23 Jan 2022 07:04:01 -0700 Simon Glass sjg@chromium.org wrote: ...
Re-based and applied to u-boot-video/next, thanks!
-- Anatolij
participants (6)
Anatolij Gustschin
Jason Liu
Matthias Brugger
Pali Rohár
Stefan Bosch
