[U-Boot] [PATCH] usb: musb_hcd: fix compilation error
commit 65c1f9820c8f79f "usb: Add nonblock argument to submit_int_msg" breaks the musb_hcd driver. Fixing it by adding the missing argument
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com ---
This patch is intended only for the u-boot-usb tree.
drivers/usb/musb/musb_hcd.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/musb/musb_hcd.c b/drivers/usb/musb/musb_hcd.c index 1f2805270a..adcd319b6d 100644 --- a/drivers/usb/musb/musb_hcd.c +++ b/drivers/usb/musb/musb_hcd.c @@ -1049,8 +1049,8 @@ int usb_lowlevel_stop(int index) * This function supports usb interrupt transfers. Currently, usb interrupt * transfers are not supported. */ -int submit_int_msg(struct usb_device *dev, unsigned long pipe, - void *buffer, int len, int interval) +int submit_int_msg(struct usb_device *dev, unsigned long pipe, void *buffer, + int len, int interval, bool nonblock) { int dir_out = usb_pipeout(pipe); int ep = usb_pipeendpoint(pipe);
Applied, thanks.
Jean-Jacques Hiblot
