[U-Boot] [PATCH] tsec: Configure the buffer descriptor bases to always include all of the descriptors
Previously only the last N were included based on the current one in use.
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Mingkai Hu Mingkai.hu@freescale.com Cc: Andy Fleming afleming@freescale.com Cc: Kumar Gala galak@kernel.crashing.org Cc: Detlev Zundel dzu@denx.de --- drivers/net/tsec.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index 78ffc95..1805ca0 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -250,8 +250,8 @@ static void startup_tsec(struct eth_device *dev) txIdx = 0;
/* Point to the buffer descriptors */ - out_be32(®s->tbase, (unsigned int)(&rtx.txbd[txIdx])); - out_be32(®s->rbase, (unsigned int)(&rtx.rxbd[rxIdx])); + out_be32(®s->tbase, (unsigned int)(&rtx.txbd[0])); + out_be32(®s->rbase, (unsigned int)(&rtx.rxbd[0]));
/* Initialize the Rx Buffer descriptors */ for (i = 0; i < PKTBUFSRX; i++) {
Hi Joe,
I see these two lines just before the code you change (one is even in the context of your patch):
/* reset the indices to zero */ rxIdx = 0; txIdx = 0;
So can you tell me, what your change actually does? I cannot remember that we have concurrency issues here, or do we?
Cheers Detlev
- out_be32(®s->tbase, (unsigned int)(&rtx.txbd[0]));
- out_be32(®s->rbase, (unsigned int)(&rtx.rxbd[0]));
My apologies... I ported this patch from my work in u-boot 2009.11 and did not notice that change above. I think explicitly using 0 when assigning the base address pointers is clearer, though.
It seems the resetting of the indexes to 0 was added by Andy Fleming in 063c12633d5ad74d52152d9c358e715475e17629, though the log doesn't discuss it..
Best regards, -Joe
Hi Joe,
Yes, I see - it even slipped my review :( For the patch as such I don't have a preference - looking at the code both ways really read the same for me.
Cheers Detlev
On Aug 10, 2011, at 2:24 PM, Detlev Zundel wrote:
Hi Joe,
out_be32(®s->rbase, (unsigned int)(&rtx.rxbd[0])); /* Initialize the Rx Buffer descriptors */ for (i = 0; i < PKTBUFSRX; i++) {
Well, it wasn't added in that patch, exactly. What really happened is I accidentally applied two patches, and then had to break them up again. That part accidentally got put in the second patch. A careful review of the patch history indicates that the indices have always been zeroed out beforehand (though sometimes in separate functions).
All the same, it looks like this patch is a good idea, to me.
Andy
Hi Andy,
It slipped my review nevertheless.
Then submit an acked-by which should help the patch along.
Cheers Detlev
I'm curious if you were seeing a problem that this fixes?
However, while I don't believe this fixes a technical problem, I believe this makes the code more straightforward.
So if this is a fix to a problem, we need more information to understand what you're really fixing. If this is just fixing something that looked wrong...:
Acked-by: Andy Fleming afleming@freescale.com
I was searching for a performance problem on the MPC8313, and discovered this, which seemed wrong. It was not, however, the source of my problem.
I agree. It is more straightforward to use 0 explicitly.
It fixes something that was wrong before you committed 063c12633d5ad74d52152d9c358e715475e17629, but at this point, it's just cosmetic.
Best regards, -Joe
Dear Joe Hershberger,
In message CANr=Z=aNQtW_YV-XcqsE8f2RPDpYYMhKL7WWSrcPa_pqZKj8uw@mail.gmail.com you wrote:
I don't think this is worth to change the code. Can you accept that we drop this patch?
Yes, it is fine to drop this patch.
-Joe
Hello.
Signed-off-by: Joe Hershbergerjoe.hershberger@ni.com Cc: Joe Hershbergerjoe.hershberger@gmail.com Cc: Mingkai HuMingkai.hu@freescale.com Cc: Andy Flemingafleming@freescale.com Cc: Kumar Galagalak@kernel.crashing.org Cc: Detlev Zundeldzu@denx.de
Note that & and [0] are not really needed.
WBR, Sergei
participants (6)
Andy Fleming
Detlev Zundel
Joe Hershberger
Joe Hershberger
Sergei Shtylyov
