[U-Boot] [PATCH 1/2] arm: kzm9g: Fix undefined reference to `__aeabi_uldivmod' error
The kzm9g board fails in building with -march=armv7-a. This fixs this problem by converting to do_div().
----- USE_PRIVATE_LIBGCC=yes ./MAKEALL kzm9g ... arch/arm/cpu/armv7/rmobile/librmobile.o: In function `get_time_us': arch/arm/cpu/armv7/rmobile/timer.c:41: undefined reference to `__aeabi_uldivmod' arch/arm/cpu/armv7/rmobile/librmobile.o: In function `get_time_ms': arch/arm/cpu/armv7/rmobile/timer.c:47: undefined reference to `__aeabi_uldivmod' -----
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com CC: Signed-off-by: Tetsuyuki Kobayashi koba@kmckk.co.jp --- arch/arm/cpu/armv7/rmobile/timer.c | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/rmobile/timer.c b/arch/arm/cpu/armv7/rmobile/timer.c index 72e0c12..04700e7 100644 --- a/arch/arm/cpu/armv7/rmobile/timer.c +++ b/arch/arm/cpu/armv7/rmobile/timer.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <div64.h> #include <asm/io.h> #include <asm/arch-armv7/globaltimer.h> #include <asm/arch/rmobile.h> @@ -38,13 +39,16 @@ static u64 get_time_us(void) u64 timer = get_cpu_global_timer();
timer = ((timer << 2) + (CLK2MHZ(CONFIG_SYS_CPU_CLK) >> 1)); - timer /= (u64)CLK2MHZ(CONFIG_SYS_CPU_CLK); + do_div(timer, CLK2MHZ(CONFIG_SYS_CPU_CLK)); return timer; }
static ulong get_time_ms(void) { - return (ulong)(get_time_us() / 1000); + u64 us = get_time_us(); + + do_div(us, 1000); + return us; }
int timer_init(void)
Renesas ARM SoCs (R-Mobile, R-Car) are armv7 only. This drops armv5 supprt from PLATFORM_CPPFLAGS and remove config.mk of rmobile.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- arch/arm/cpu/armv7/rmobile/config.mk | 9 --------- 1 file changed, 9 deletions(-) delete mode 100644 arch/arm/cpu/armv7/rmobile/config.mk
diff --git a/arch/arm/cpu/armv7/rmobile/config.mk b/arch/arm/cpu/armv7/rmobile/config.mk deleted file mode 100644 index 3a36ab6..0000000 --- a/arch/arm/cpu/armv7/rmobile/config.mk +++ /dev/null @@ -1,9 +0,0 @@ -# -# (C) Copyright 2002 -# Gary Jennejohn, DENX Software Engineering, garyj@denx.de -# -# SPDX-License-Identifier: GPL-2.0+ -# - -# Make ARMv5 to allow more compilers to work, even though its v7a. -PLATFORM_CPPFLAGS += -march=armv5
Nobuhiro Iwamatsu
