Please pull u-boot-marvell/master
Hi Tom,
please pull this next batch of mostly Marvell related patches:
---------------------------------------------------------------- - Misc Kconfig cleanups (Chris & Pali) - turris_omnia: Fix hangup in debug UART (this introduces TPL/SPL_DEBUG_UART_BASE) Pali - mvebu: uDPU: include fixed-phy support (Robert) - pinctrl: probe pinctrl drivers during post-bind (Robert) ----------------------------------------------------------------
Here the Azure build, without any issues:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=196&view=resu...
Thanks, Stefan
The following changes since commit c387e62614713d0cc9e3ed022b86c9f320b02853:
Merge branch '2022-05-11-Kconfig-cleanups-etc' (2022-05-11 13:27:44 -0400)
git@source.denx.de:u-boot/custodians/u-boot-marvell.git
for you to fetch changes up to f9ec791b5e24378b71590877499f8683d5f54dac:
pinctrl: probe pinctrl drivers during post-bind (2022-05-17 06:44:06 +0200)
---------------------------------------------------------------- Chris Packham (1): arm: mvebu: Remove unused ARMADA_64BIT
Pali Rohár (9): cmd: mvebu: Hide bubt specific options when bubt is disabled arm: Add new config option ARCH_VERY_EARLY_INIT arm: mvebu: Move internal registers in arch_very_early_init() function serial: Add new config option SPL_DEBUG_UART_BASE serial: Add new config option TPL_DEBUG_UART_BASE serial: ns16550: Add support for SPL_DEBUG_UART_BASE arm: mvebu: turris_omnia: Fix DEBUG_UART_BASE arm: mvebu: Fix DEBUG_UART_BASE for all 32-bit boards arm: mvebu: turris_{omnia,mox}: Enable CONFIG_NETCONSOLE
Robert Marko (2): mvebu: uDPU: include fixed-phy support pinctrl: probe pinctrl drivers during post-bind
arch/arm/Kconfig | 6 ++++++ arch/arm/lib/crt0.S | 5 +++++ arch/arm/mach-mvebu/Kconfig | 5 +---- arch/arm/mach-mvebu/Makefile | 1 + arch/arm/mach-mvebu/cpu.c | 31 ------------------------------- arch/arm/mach-mvebu/lowlevel.S | 27 +++++++++++++++++++++++++++ cmd/mvebu/Kconfig | 4 ++++ configs/clearfog_defconfig | 3 ++- configs/controlcenterdc_defconfig | 3 ++- configs/db-88f6820-amc_defconfig | 3 ++- configs/db-88f6820-gp_defconfig | 3 ++- configs/db-mv784mp-gp_defconfig | 3 ++- configs/ds414_defconfig | 3 ++- configs/helios4_defconfig | 3 ++- configs/maxbcm_defconfig | 3 ++- configs/theadorable_debug_defconfig | 3 ++- configs/turris_mox_defconfig | 1 + configs/turris_omnia_defconfig | 4 +++- configs/uDPU_defconfig | 1 + configs/x530_defconfig | 3 ++- drivers/pinctrl/pinctrl-uclass.c | 7 +++++++ drivers/serial/Kconfig | 14 ++++++++++++++ drivers/serial/ns16550.c | 4 ++-- 23 files changed, 92 insertions(+), 48 deletions(-) create mode 100644 arch/arm/mach-mvebu/lowlevel.S
Stefan Roese
