[U-Boot] [PATCH v2] arm: samsung: goni: use the driver model for max8998
Remove the "ifndef CONFIG_DM_I2C". Instead, use the driver model for max8998.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- Changelog on V2: - Removes the CONFIG_DM_PMIC_MAX8998 - Fixes the typo s/max8998_pmix/max8998_pmic
board/samsung/goni/goni.c | 61 +++++++++++++++++++++++------------------------ 1 file changed, 30 insertions(+), 31 deletions(-)
diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index b066832..80fd0d4 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -9,6 +9,7 @@ #include <common.h> #include <asm/gpio.h> #include <asm/arch/mmc.h> +#include <dm.h> #include <power/pmic.h> #include <usb/dwc2_udc.h> #include <asm/arch/cpu.h> @@ -43,19 +44,6 @@ void i2c_init_board(void) } #endif
-int power_init_board(void) -{ -#ifndef CONFIG_DM_I2C /* TODO(maintainer): Convert to driver model */ - /* - * For PMIC the I2C bus is named as I2C5, but it is connected - * to logical I2C adapter 0 - */ - return pmic_init(I2C_0); -#else - return 0; -#endif -} - int dram_init(void) { gd->ram_size = PHYS_SDRAM_1_SIZE + PHYS_SDRAM_2_SIZE + @@ -146,39 +134,50 @@ int board_mmc_init(bd_t *bis) #ifdef CONFIG_USB_GADGET static int s5pc1xx_phy_control(int on) { -#ifndef CONFIG_DM_I2C /* TODO(maintainer): Convert to driver model */ - int ret; + struct udevice *dev; static int status; - struct pmic *p = pmic_get("MAX8998_PMIC"); - if (!p) - return -ENODEV; + int reg, ret;
- if (pmic_probe(p)) - return -1; + ret = pmic_get("max8998_pmic", &dev); + if (ret) + return ret;
if (on && !status) { - ret = pmic_set_output(p, MAX8998_REG_ONOFF1, - MAX8998_LDO3, LDO_ON); - ret = pmic_set_output(p, MAX8998_REG_ONOFF2, - MAX8998_LDO8, LDO_ON); + reg = pmic_reg_read(dev, MAX8998_REG_ONOFF1); + reg |= MAX8998_LDO3; + ret = pmic_reg_write(dev, MAX8998_REG_ONOFF1, reg); if (ret) { puts("MAX8998 LDO setting error!\n"); - return -1; + return -EINVAL; + } + + reg = pmic_reg_read(dev, MAX8998_REG_ONOFF2); + reg |= MAX8998_LDO8; + ret = pmic_reg_write(dev, MAX8998_REG_ONOFF2, reg); + if (ret) { + puts("MAX8998 LDO setting error!\n"); + return -EINVAL; } status = 1; } else if (!on && status) { - ret = pmic_set_output(p, MAX8998_REG_ONOFF1, - MAX8998_LDO3, LDO_OFF); - ret = pmic_set_output(p, MAX8998_REG_ONOFF2, - MAX8998_LDO8, LDO_OFF); + reg = pmic_reg_read(dev, MAX8998_REG_ONOFF1); + reg &= ~MAX8998_LDO3; + ret = pmic_reg_write(dev, MAX8998_REG_ONOFF1, reg); + if (ret) { + puts("MAX8998 LDO setting error!\n"); + return -EINVAL; + } + + reg = pmic_reg_read(dev, MAX8998_REG_ONOFF2); + reg &= ~MAX8998_LDO8; + ret = pmic_reg_write(dev, MAX8998_REG_ONOFF2, reg); if (ret) { puts("MAX8998 LDO setting error!\n"); - return -1; + return -EINVAL; } status = 0; } udelay(10000); -#endif return 0; }
Dear Jaehoon,
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com javascript:;>
Changelog on V2:
-#else
-#endif -}
int ret;
if (!p)
return -ENODEV;
int reg, ret;
if (pmic_probe(p))
return -1;
if (ret)
return ret; if (on && !status) {
return -1;
return -EINVAL;
if (ret) {
if (ret) {
return -EINVAL;
return -1;
-#endif return 0; }
-- 2.10.2
U-Boot mailing list U-Boot@lists.denx.de javascript:; http://lists.denx.de/mailman/listinfo/u-boot
applied to u-boot-samsung
Thanks
Jaehoon Chung
Minkyu Kang
