[U-Boot] [PATCH v4] da830: fixup ARM relocation support
Fixes build breakage in da830evm after commit 97003756249bd790910417eb66f0039bbf06a02c "da8xx: fixup ARM relocation support"
The da8xx fixup commit changed da830/da850 common code to make relocation work in da850, but didn't add the required defines to da830evm_config.h resulting in build failure in the common code.
This patch adds those defines for da830, but makes no sense without also referring to the commit mentioned above.
Signed-off-by: Nick Thompson nick.thompson@ge.com Reviewed-by: Ben Gardiner bengardiner@nanometrics.ca --- Changes since v1: removed CONFIG_SKIP_RELOCATE_UBOOT
Changes since v2: removed "#undef CONFIG_SYS_ARM_WITHOUT_RELOC" as it is not defined in the first place.
Changes since v3: Rebased to lastest
include/configs/da830evm.h | 10 ++++++++-- 1 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/include/configs/da830evm.h b/include/configs/da830evm.h index 1feada9..3a2631b 100644 --- a/include/configs/da830evm.h +++ b/include/configs/da830evm.h @@ -47,8 +47,7 @@ * Memory Info */ #define CONFIG_SYS_MALLOC_LEN (0x10000 + 1*1024*1024) /* malloc() len */ -#define PHYS_SDRAM_1 DAVINCI_DDR_EMIF_DATA_BASE /* DDR Start */ -#define PHYS_SDRAM_1_SIZE (64 << 20) /* SDRAM size 64MB */ +#define PHYS_SDRAM_1 0xc0000000 /* SDRAM Start */ #define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_1 /* memtest start addr */ #define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM_1 + 16*1024*1024) /* 16MB test */ #define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ @@ -280,4 +279,11 @@ "mtdparts=davinci_nand.1:" PART_BOOT PART_PARAMS PART_KERNEL PART_REST #endif
+#define CONFIG_MAX_RAM_BANK_SIZE (512 << 20) /* max size from SPRS586*/ + +/* additions for new relocation code, must be added to all boards */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_SDRAM_BASE + 0x1000 - GENERATED_GBL_DATA_SIZE) + #endif /* __CONFIG_H */
Applied to u-boot-ti
--Sandeep
Nick Thompson
Paulraj, Sandeep
