[PATCH] ARM: omap3: evm: Name this directory omap3
Before this was named just evm, which doesn't match the naming of the other TI board file directory and makes it look like a common directory for evms. Name this omap3.
Signed-off-by: Andrew Davis afd@ti.com --- arch/arm/mach-omap2/omap3/Kconfig | 2 +- board/ti/{evm => omap3}/Kconfig | 2 +- board/ti/{evm => omap3}/MAINTAINERS | 2 +- board/ti/{evm => omap3}/Makefile | 0 board/ti/{evm => omap3}/evm.c | 0 board/ti/{evm => omap3}/evm.h | 0 6 files changed, 3 insertions(+), 3 deletions(-) rename board/ti/{evm => omap3}/Kconfig (87%) rename board/ti/{evm => omap3}/MAINTAINERS (87%) rename board/ti/{evm => omap3}/Makefile (100%) rename board/ti/{evm => omap3}/evm.c (100%) rename board/ti/{evm => omap3}/evm.h (100%)
diff --git a/arch/arm/mach-omap2/omap3/Kconfig b/arch/arm/mach-omap2/omap3/Kconfig index 3e97ec2629..4e9924faf7 100644 --- a/arch/arm/mach-omap2/omap3/Kconfig +++ b/arch/arm/mach-omap2/omap3/Kconfig @@ -163,7 +163,7 @@ config SYS_SOC source "board/logicpd/am3517evm/Kconfig" source "board/ti/beagle/Kconfig" source "board/timll/devkit8000/Kconfig" -source "board/ti/evm/Kconfig" +source "board/ti/omap3/Kconfig" source "board/isee/igep00x0/Kconfig" source "board/logicpd/omap3som/Kconfig" source "board/nokia/rx51/Kconfig" diff --git a/board/ti/evm/Kconfig b/board/ti/omap3/Kconfig similarity index 87% rename from board/ti/evm/Kconfig rename to board/ti/omap3/Kconfig index 4f490ddd9d..d60b229a4e 100644 --- a/board/ti/evm/Kconfig +++ b/board/ti/omap3/Kconfig @@ -1,7 +1,7 @@ if TARGET_OMAP3_EVM
config SYS_BOARD - default "evm" + default "omap3"
config SYS_VENDOR default "ti" diff --git a/board/ti/evm/MAINTAINERS b/board/ti/omap3/MAINTAINERS similarity index 87% rename from board/ti/evm/MAINTAINERS rename to board/ti/omap3/MAINTAINERS index cd315c1635..95b34bbd11 100644 --- a/board/ti/evm/MAINTAINERS +++ b/board/ti/omap3/MAINTAINERS @@ -1,6 +1,6 @@ EVM BOARD M: Derald D. Woods woods.technical@gmail.com S: Maintained -F: board/ti/evm/ +F: board/ti/omap3/ F: include/configs/omap3_evm.h F: configs/omap3_evm_defconfig diff --git a/board/ti/evm/Makefile b/board/ti/omap3/Makefile similarity index 100% rename from board/ti/evm/Makefile rename to board/ti/omap3/Makefile diff --git a/board/ti/evm/evm.c b/board/ti/omap3/evm.c similarity index 100% rename from board/ti/evm/evm.c rename to board/ti/omap3/evm.c diff --git a/board/ti/evm/evm.h b/board/ti/omap3/evm.h similarity index 100% rename from board/ti/evm/evm.h rename to board/ti/omap3/evm.h
config SYS_BOARD
default "evm"
default "omap3"
config SYS_VENDOR default "ti" diff --git a/board/ti/evm/MAINTAINERS b/board/ti/omap3/MAINTAINERS similarity index 87% rename from board/ti/evm/MAINTAINERS rename to board/ti/omap3/MAINTAINERS index cd315c1635..95b34bbd11 100644 --- a/board/ti/evm/MAINTAINERS +++ b/board/ti/omap3/MAINTAINERS @@ -1,6 +1,6 @@ EVM BOARD M: Derald D. Woods woods.technical@gmail.com S: Maintained -F: board/ti/evm/ +F: board/ti/omap3/ F: include/configs/omap3_evm.h F: configs/omap3_evm_defconfig diff --git a/board/ti/evm/Makefile b/board/ti/omap3/Makefile similarity index 100% rename from board/ti/evm/Makefile rename to board/ti/omap3/Makefile diff --git a/board/ti/evm/evm.c b/board/ti/omap3/evm.c similarity index 100% rename from board/ti/evm/evm.c rename to board/ti/omap3/evm.c diff --git a/board/ti/evm/evm.h b/board/ti/omap3/evm.h similarity index 100% rename from board/ti/evm/evm.h rename to board/ti/omap3/evm.h -- 2.37.3
It seems to me that something like 'omap3evm' would be more appropriate for a directory name. Using just 'omap3' may be too generic. The actual EVM configurations are TMDSEVM3530 [1] and TMDSEVM3730 [2], with the corresponding processor boards attached. It would also align with the TARGET_OMAP3_EVM definition still in use. These are my observations.
- Derald
[1] https://www.digikey.com/en/products/detail/texas-instruments/TMDSEVM3530/223... [2] https://www.digikey.com/en/products/detail/texas-instruments/TMDSEVM3730/262... [3] https://media.digikey.com/pdf/Data%20Sheets/Texas%20Instruments%20PDFs/tmdse... [4] https://media.digikey.com/pdf/Data%20Sheets/Texas%20Instruments%20PDFs/TMDSE...
config SYS_BOARD
default "evm"
default "omap3"
I'm not sure about that, the convention seems to be the directory name matches the SoC, then the source files match for each type/name of board. This is at least true for some newer TI boards, but I agree it is not always followed for the older devices. I have no strong preference either way, just as long as we can not call it "board/ti/evm" like it is now..
This patch still applies to the latest u-boot, or I can send a v2.
Andrew
- Derald
config SYS_BOARD
default "evm"
default "omap3"
I'd like a v2 of "omap3evm" please, we have other omap3 platforms still so it would just be a different confusion I feel (and most of the other board/ti/SOC/ directories support the EVM + SK + other stuff model, while this is just the 3530/3730 boards that are iirc otherwise very similar). Thanks!
Andrew Davis
Derald Woods
