[PATCH 0/5] usb: dwc3-uniphier: Replace the driver to use dwc3-generic
This series exports the structures and functions from the driver source to the header, and replaces dwc3-uniphier driver to use them.
This expects dwc3-generic to prevent more SoC-dependent codes.
Kunihiko Hayashi (5): usb: dwc3-generic: Export glue structures and functions usb: dwc3-generic: Add the size of regs property to glue structure usb: dwc3-generic: Add dependency on SIMPLE_BUS usb: dwc3-uniphier: Use dwc3-generic instead of xhci-dwc3 uniphier_defconfig: Disable USB_XHCI_DWC3
configs/uniphier_v7_defconfig | 1 - configs/uniphier_v8_defconfig | 1 - drivers/usb/dwc3/Kconfig | 7 +-- drivers/usb/dwc3/dwc3-generic.c | 19 ++------ drivers/usb/dwc3/dwc3-generic.h | 32 +++++++++++++ drivers/usb/dwc3/dwc3-uniphier.c | 79 ++++++++++++++++---------------- 6 files changed, 81 insertions(+), 58 deletions(-) create mode 100644 drivers/usb/dwc3/dwc3-generic.h
In order to allow external SoC-dependent glue drivers to use dwc3-generic functions, push the glue structures and export the functions to a header file.
The exported structures and functions are:
- struct dwc3_glue_data - struct dwc3_glue_ops - dwc3_glue_bind() - dwc3_glue_probe() - dwc3_glue_remove()
The SoC-dependent glue drivers can only define their own wrapper driver and specify these functions. The drivers can also add their own compatible strings and configure functions.
Signed-off-by: Kunihiko Hayashi hayashi.kunihiko@socionext.com --- drivers/usb/dwc3/dwc3-generic.c | 17 ++++------------- drivers/usb/dwc3/dwc3-generic.h | 31 +++++++++++++++++++++++++++++++ 2 files changed, 35 insertions(+), 13 deletions(-) create mode 100644 drivers/usb/dwc3/dwc3-generic.h
diff --git a/drivers/usb/dwc3/dwc3-generic.c b/drivers/usb/dwc3/dwc3-generic.c index 78966718d0..1708ea14bb 100644 --- a/drivers/usb/dwc3/dwc3-generic.c +++ b/drivers/usb/dwc3/dwc3-generic.c @@ -28,11 +28,7 @@ #include <usb/xhci.h> #include <asm/gpio.h>
-struct dwc3_glue_data { - struct clk_bulk clks; - struct reset_ctl_bulk resets; - fdt_addr_t regs; -}; +#include "dwc3-generic.h"
struct dwc3_generic_plat { fdt_addr_t base; @@ -258,11 +254,6 @@ U_BOOT_DRIVER(dwc3_generic_host) = { }; #endif
-struct dwc3_glue_ops { - void (*glue_configure)(struct udevice *dev, int index, - enum usb_dr_mode mode); -}; - void dwc3_imx8mp_glue_configure(struct udevice *dev, int index, enum usb_dr_mode mode) { @@ -398,7 +389,7 @@ struct dwc3_glue_ops ti_ops = { .glue_configure = dwc3_ti_glue_configure, };
-static int dwc3_glue_bind(struct udevice *parent) +int dwc3_glue_bind(struct udevice *parent) { ofnode node; int ret; @@ -493,7 +484,7 @@ static int dwc3_glue_clk_init(struct udevice *dev, return 0; }
-static int dwc3_glue_probe(struct udevice *dev) +int dwc3_glue_probe(struct udevice *dev) { struct dwc3_glue_ops *ops = (struct dwc3_glue_ops *)dev_get_driver_data(dev); struct dwc3_glue_data *glue = dev_get_plat(dev); @@ -553,7 +544,7 @@ static int dwc3_glue_probe(struct udevice *dev) return 0; }
-static int dwc3_glue_remove(struct udevice *dev) +int dwc3_glue_remove(struct udevice *dev) { struct dwc3_glue_data *glue = dev_get_plat(dev);
diff --git a/drivers/usb/dwc3/dwc3-generic.h b/drivers/usb/dwc3/dwc3-generic.h new file mode 100644 index 0000000000..c7925ce4ae --- /dev/null +++ b/drivers/usb/dwc3/dwc3-generic.h @@ -0,0 +1,31 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/** + * dwc3-generic.h - Generic DWC3 Glue layer header + * + * Copyright (C) 2016 - 2018 Xilinx, Inc. + * Copyright (C) 2023 Socionext Inc. + */ + +#ifndef __DRIVERS_USB_DWC3_GENERIC_H +#define __DRIVERS_USB_DWC3_GENERIC_H + +#include <clk.h> +#include <reset.h> +#include <dwc3-uboot.h> + +struct dwc3_glue_data { + struct clk_bulk clks; + struct reset_ctl_bulk resets; + fdt_addr_t regs; +}; + +struct dwc3_glue_ops { + void (*glue_configure)(struct udevice *dev, int index, + enum usb_dr_mode mode); +}; + +int dwc3_glue_bind(struct udevice *parent); +int dwc3_glue_probe(struct udevice *dev); +int dwc3_glue_remove(struct udevice *dev); + +#endif
- dwc3_glue_bind()
- dwc3_glue_probe()
Add the size of regs property to the glue structure to correctly specify the register region to map.
Signed-off-by: Kunihiko Hayashi hayashi.kunihiko@socionext.com --- drivers/usb/dwc3/dwc3-generic.c | 2 +- drivers/usb/dwc3/dwc3-generic.h | 1 + 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/dwc3/dwc3-generic.c b/drivers/usb/dwc3/dwc3-generic.c index 1708ea14bb..7ad26c454d 100644 --- a/drivers/usb/dwc3/dwc3-generic.c +++ b/drivers/usb/dwc3/dwc3-generic.c @@ -505,7 +505,7 @@ int dwc3_glue_probe(struct udevice *dev) phy.dev = NULL; }
- glue->regs = dev_read_addr(dev); + glue->regs = dev_read_addr_size_index(dev, 0, &glue->size);
ret = dwc3_glue_clk_init(dev, glue); if (ret) diff --git a/drivers/usb/dwc3/dwc3-generic.h b/drivers/usb/dwc3/dwc3-generic.h index c7925ce4ae..f1823a01f4 100644 --- a/drivers/usb/dwc3/dwc3-generic.h +++ b/drivers/usb/dwc3/dwc3-generic.h @@ -17,6 +17,7 @@ struct dwc3_glue_data { struct clk_bulk clks; struct reset_ctl_bulk resets; fdt_addr_t regs; + fdt_size_t size; };
The glue driver doesn't do or offer actively anything, SIMPLE_BUS is more preferable to represent the driver.
Signed-off-by: Kunihiko Hayashi hayashi.kunihiko@socionext.com --- drivers/usb/dwc3/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/dwc3/Kconfig b/drivers/usb/dwc3/Kconfig index f010291d02..dadaa083e7 100644 --- a/drivers/usb/dwc3/Kconfig +++ b/drivers/usb/dwc3/Kconfig @@ -25,14 +25,14 @@ config USB_DWC3_OMAP
config USB_DWC3_GENERIC bool "Generic implementation of a DWC3 wrapper (aka dwc3 glue)" - depends on DM_USB && USB_DWC3 && MISC + depends on DM_USB && USB_DWC3 && (MISC || SIMPLE_BUS) help Select this for Xilinx ZynqMP and similar Platforms. This wrapper supports Host and Peripheral operation modes.
config SPL_USB_DWC3_GENERIC bool "Generic implementation of a DWC3 wrapper (aka dwc3 glue) for the SPL" - depends on SPL_DM_USB && USB_DWC3 && SPL_MISC + depends on SPL_DM_USB && USB_DWC3 && (SPL_MISC || SPL_SIMPLE_BUS) help Select this for Xilinx ZynqMP and similar Platforms. This wrapper supports Host and Peripheral operation modes.
- depends on DM_USB && USB_DWC3 && (MISC || SIMPLE_BUS)
I'm afraid I don't understand why this change is needed for all variants of DWC3.
Is this needed for socionext dwc3 variant to handle the simple-mfd in e.g. arch/arm/dts/uniphier-pxs3.dtsi :
614 usb-glue@65b00000 { 615 compatible = "socionext,uniphier-pxs3-dwc3-glue", 616 "simple-mfd";
Hi Marek,
Thank you for reviewing.
Although dwc3-generic is declared as UCLASS_NOP, the similar glue driver dwc3-meson-glx is declared as UCLASS_SIMPLE_BUS.
In case of U-Boot, the glue driver is probed by:
/* FIXME: U-Boot own node */ usb@65b00000 { compatible = "socionext,uniphier-pxs3-dwc3";
And dwc3-uniphier is also declared as UCLASS_SIMPLE_BUS. Even if using "simple-mfd", this is included in drivers/core/simple-bus.c which is declared as UCLASS_SIMPLE_BUS.
Thank you,
--- Best Regards Kunihiko Hayashi
On 1/23/23 04:08, Kunihiko Hayashi wrote:
Hello Hayashi-san,
diff --git a/drivers/usb/dwc3/Kconfig b/drivers/usb/dwc3/Kconfig index f010291d02..dadaa083e7 100644 --- a/drivers/usb/dwc3/Kconfig +++ b/drivers/usb/dwc3/Kconfig @@ -25,14 +25,14 @@ config USB_DWC3_OMAP config USB_DWC3_GENERIC bool "Generic implementation of a DWC3 wrapper (aka dwc3 glue)" - depends on DM_USB && USB_DWC3 && MISC + depends on DM_USB && USB_DWC3 && (MISC || SIMPLE_BUS)
I think here it makes sense, because "amlogic,meson-axg-usb-ctrl" behaves like a bus with subnodes:
arch/arm/dts/meson-axg.dtsi: 227 usb: usb@ffe09080 { 228 compatible = "amlogic,meson-axg-usb-ctrl"; 229 reg = <0x0 0xffe09080 0x0 0x20>; ... 244 dwc2: usb@ff400000 { 245 compatible = "amlogic,meson-g12a-usb", "snps,dwc2"; 246 reg = <0x0 0xff400000 0x0 0x40000>; ... 255 }; 256 257 dwc3: usb@ff500000 { 258 compatible = "snps,dwc3"; 259 reg = <0x0 0xff500000 0x0 0x100000>; ... 264 }; 265 };
arch/arm/dts/meson-gxl.dtsi 17 usb: usb@d0078080 { 18 compatible = "amlogic,meson-gxl-usb-ctrl"; 19 reg = <0x0 0xd0078080 0x0 0x20>; ... 34 dwc2: usb@c9100000 { 35 compatible = "amlogic,meson-g12a-usb", "snps,dwc2"; 36 reg = <0x0 0xc9100000 0x0 0x40000>; ... 45 }; 46 47 dwc3: usb@c9000000 { 48 compatible = "snps,dwc3"; 49 reg = <0x0 0xc9000000 0x0 0x100000>; ... 54 }; 55 };
On the other hand, the PXS2 controller for example is not a bus:
arch/arm/dts/uniphier-pxs2.dtsi: 596 _usb0: usb@65a00000 { 597 compatible = "socionext,uniphier-dwc3", "snps,dwc3"; 598 status = "disabled"; 599 reg = <0x65a00000 0xcd00>; ... 610 };
If I understand this correctly, node compatible with "socionext,uniphier-pxs3-dwc3-glue" is not used at all , right ?
The generic driver binds to node compatible with "socionext,uniphier-dwc3" , right ?
That means, there is nothing which would be a bus, and so the dwc3-uniphier.c can be switched from UCLASS_SIMPLE_BUS to UCLASS_NOP , is that correct ?
Hi Marek,
Hello Hayashi-san,
I understand. However, this node isn't used in u-boot. (see below for details)
Yes. Original uniphier devicetree has the following usb nodes.
usb@65a00000 { compatible = "snps,dwc3"; }; usb-glue@65b00000 { compatible = "socionext,uniphier-pxs3-dwc3-glue", "simple-mfd"; };
However, U-Boot dwc3-generic needs to put dwc3 node under the glue node. Due to this restriction, there is another usb node dedicated to u-boot.
/* FIXME: U-Boot own node */ usb@65b00000 { /* glue */ compatible = "socionext,uniphier-pxs3-dwc3";
dwc3@65a00000 { compatible = "snps,dwc3"; }; };
So instead of "socionext,uniphier-pxs3-dwc3-glue", the glue driver uses "socionext,uniphier-pxs3-dwc3" in U-Boot.
No, the generic driver binds "socionext,uniphier-pxs3-dwc3".
There is still the issue of different usb node between Original and u-boot, however, the glue driver can be switched to UCLASS_NOP.
Thank you,
On 1/23/23 06:01, Kunihiko Hayashi wrote:
Hi Marek,
Hello Hayashi-san,
Have a look at arch/arm/dts/imx8mq.dtsi which does not use any glue node, the snps,dwc3 compatible node is directly placed on the soc@0 bus:
1417 1418 usb_dwc3_0: usb@38100000 { 1419 compatible = "fsl,imx8mq-dwc3", "snps,dwc3"; 1420 reg = <0x38100000 0x10000>; 1421 clocks = <&clk IMX8MQ_CLK_USB1_CTRL_ROOT>,
Can we use the same method as imx8mq.dtsi uses, to avoid this special node workaround ?
Understood, thank you for the clarification.
Hi Marek,
Hi Marek,
Hello Hayashi-san,
/* FIXME: U-Boot own node */ usb@65b00000 { /* glue */ compatible = "socionext,uniphier-pxs3-dwc3"; dwc3@65a00000 { compatible = "snps,dwc3"; }; };
Umm, it's curious. It seems imx8mq doesn't have any glue registers and defines dwc3 core registers directly.
On the other hand, "fsl,imx8mq-dwc3" is included in dwc3-generic.c, though, dwc3_glue_bind() calls the driver that the child node shows.
ofnode_for_each_subnode(node, dev_ofnode(parent)) { ... device_bind_driver_to_node(parent, driver, name, node, &dev); ... }
Maybe the child node expects the driver that "snps,dwc3" indicates.
If we use the same method as imx8mq.dtsi, I think there is no way to probe the driver for "snps,dwc3" in dwc3-generic.c.
BTW, xchi-dwc3.c can handle "snps,dwc3", but it seems this doesn't use usb/dwc3/ functions (so I'm confusing it).
Thank you,
On 1/24/23 03:53, Kunihiko Hayashi wrote:
Hi Marek,
Hello Hayashi-san,
Hi Marek,
Hello Hayashi-san,
Let's try the following, please have a look at this change:
https://source.denx.de/u-boot/custodians/u-boot-usb/-/commit/028ad9536e50198...
The change is difficult to read, use 'git show -w' to ignore space changes, that might help.
The idea is that the dwc3-generic.c (or dwc3-uniphier.c , placement does not really matter) binds to "socionext,uniphier-pxs3-dwc3-glue" compatible first.
Then, the dwc3_glue_ops is extended with a new callback glue_get_ctrl_dev, which returns the pointer to controller DT node (the node compatible with "socionext,uniphier-dwc3"). This is used in dwc3_glue_bind(), which either uses the current implementation with a loop over all subnodes and tries to find the controller subnode, OR, calls the glue_get_ctrl_dev callback, obtains controller device node pointer that way, and runs the inner loop of dwc3_glue_bind() (now dwc3_glue_bind_common()) only on that pointer.
In either case, the dwc3-generic driver is bound to the controller. You might need to re-use this trick in dwc3_glue_probe() too.
This should allow you to get rid of the custom DT node too.
Does this work ?
Hi Marek,
Hi Marek,
Hello Hayashi-san,
Hi Marek,
Hello Hayashi-san,
> Is this needed for socionext dwc3 variant to handle the simple-mfd in > e.g. arch/arm/dts/uniphier-pxs3.dtsi : > > 614 usb-glue@65b00000 { > 615 compatible = "socionext,uniphier-pxs3-dwc3-glue", > 616 "simple-mfd"; > > ?
"simple-mfd"; };
Thanks a lot for your work!
I understand your patch adds trying to call "glue_get_ctrl_dev" to get controller device node before finding subnode,
Does this work ?
I'll try this soon.
Thank you,
On 1/25/23 09:40, Kunihiko Hayashi wrote:
Hi Marek,
Hello Hayashi-san,
Yes. Feel free to adjust the patch so it fits uniphier better of course.
Does this work ?
I'll try this soon.
Thank you !
Hi Marek,
Sorry for late reply. I was stuck in some pitfalls.
Hi Marek,
Hello Hayashi-san,
Does this work ?
I'll try this soon.
Thank you !
I've successfully enabled the regular usb node using your suggested patch [1] and your earlier submitted patch [2].
[1] https://source.denx.de/u-boot/custodians/u-boot-usb/-/commit/028ad9536e50198... - Change 2nd argument type from "udevice *" to "ofnode" because glue_get_ctrl_dev() can give only "ofnode" structure from the device node. - Move soc-dependent stuffs to dwc3-uniphier.c.
[2] https://patchwork.ozlabs.org/project/uboot/patch/20221215223822.137739-1-mar... - correspond to "for top level generic node with no subnode"
However, the uniphier usb3 glue node has more child nodes (not for the controller), so I need to add more patches to enable more clocks that the child nodes have.
I should send new patches as v2 series, though, how do you treat your patches [1] and [2]?
Thank you,
On 1/30/23 06:52, Kunihiko Hayashi wrote:
Hi Marek,
Hello Hayashi-san,
No worries, the MW closed today, but rc2 should be still OK to land these patches.
Please integrate this patch into your series, feel free to change it as needed too.
Could you provide AB/RB on this one if this looks OK? Then I would apply it to usb tree .
Yes please, send V2. Regarding [1] and [2], see above.
Thank you
Hi Marek,
Hi Marek,
Hello Hayashi-san,
Thank you for caring.
OK, I'll make the commit log. You're the original author of this patch, what about your tag?
This looks good to me. The dwc3-uniphier uses this for the reference clock in the top level generic node. I'll provide my tag.
OK, I'll clean up and make the series soon.
Thank you,
On 1/31/23 01:27, Kunihiko Hayashi wrote:
Hi Marek,
Hello Hayashi-san,
Hi Marek,
Hello Hayashi-san,
Since the patch needs heavy changes anyway, maybe some 'Suggested-by: Marek' would be best, or no tag at all ?
Thank you
Thank you
dwc3-uniphier depends on xhci-dwc3 framework, however, it is preferable to use dwc3-generic.
This driver calls the exported dwc3-generic functions and redefine the SoC-dependent operations to fit dwc3-generic.
Signed-off-by: Kunihiko Hayashi hayashi.kunihiko@socionext.com --- drivers/usb/dwc3/Kconfig | 3 +- drivers/usb/dwc3/dwc3-uniphier.c | 79 ++++++++++++++++---------------- 2 files changed, 42 insertions(+), 40 deletions(-)
diff --git a/drivers/usb/dwc3/Kconfig b/drivers/usb/dwc3/Kconfig index dadaa083e7..dbd14b1e90 100644 --- a/drivers/usb/dwc3/Kconfig +++ b/drivers/usb/dwc3/Kconfig @@ -55,7 +55,8 @@ config USB_DWC3_MESON_GXL
config USB_DWC3_UNIPHIER bool "DesignWare USB3 Host Support on UniPhier Platforms" - depends on ARCH_UNIPHIER && USB_XHCI_DWC3 + depends on ARCH_UNIPHIER && USB_DWC3 + select USB_DWC3_GENERIC help Support of USB2/3 functionality in Socionext UniPhier platforms. Say 'Y' here if you have one such device. diff --git a/drivers/usb/dwc3/dwc3-uniphier.c b/drivers/usb/dwc3/dwc3-uniphier.c index 54b52dcd66..175a97c5e4 100644 --- a/drivers/usb/dwc3/dwc3-uniphier.c +++ b/drivers/usb/dwc3/dwc3-uniphier.c @@ -4,14 +4,16 @@ * * Copyright (C) 2016-2017 Socionext Inc. * Author: Masahiro Yamada yamada.masahiro@socionext.com + * Author: Kunihiko Hayashi hayashi.kunihiko@socionext.com */
#include <dm.h> -#include <dm/device_compat.h> #include <linux/bitops.h> -#include <linux/errno.h> -#include <linux/io.h> -#include <linux/sizes.h> +#include <linux/usb/gadget.h> + +#include "core.h" +#include "gadget.h" +#include "dwc3-generic.h"
#define UNIPHIER_PRO4_DWC3_RESET 0x40 #define UNIPHIER_PRO4_DWC3_RESET_XIOMMU BIT(5) @@ -27,8 +29,11 @@ #define UNIPHIER_PXS2_DWC3_RESET 0x00 #define UNIPHIER_PXS2_DWC3_RESET_XLINK BIT(15)
-static int uniphier_pro4_dwc3_init(void __iomem *regs) +static void uniphier_pro4_dwc3_init(struct udevice *dev, int index, + enum usb_dr_mode mode) { + struct dwc3_glue_data *glue = dev_get_plat(dev); + void *regs = map_physmem(glue->regs, glue->size, MAP_NOCACHE); u32 tmp;
tmp = readl(regs + UNIPHIER_PRO4_DWC3_RESET); @@ -36,11 +41,14 @@ static int uniphier_pro4_dwc3_init(void __iomem *regs) tmp |= UNIPHIER_PRO4_DWC3_RESET_XIOMMU | UNIPHIER_PRO4_DWC3_RESET_XLINK; writel(tmp, regs + UNIPHIER_PRO4_DWC3_RESET);
- return 0; + unmap_physmem(regs, MAP_NOCACHE); }
-static int uniphier_pro5_dwc3_init(void __iomem *regs) +static void uniphier_pro5_dwc3_init(struct udevice *dev, int index, + enum usb_dr_mode mode) { + struct dwc3_glue_data *glue = dev_get_plat(dev); + void *regs = map_physmem(glue->regs, glue->size, MAP_NOCACHE); u32 tmp;
tmp = readl(regs + UNIPHIER_PRO5_DWC3_RESET); @@ -49,72 +57,65 @@ static int uniphier_pro5_dwc3_init(void __iomem *regs) tmp |= UNIPHIER_PRO5_DWC3_RESET_XLINK | UNIPHIER_PRO5_DWC3_RESET_XIOMMU; writel(tmp, regs + UNIPHIER_PRO5_DWC3_RESET);
-static int uniphier_pxs2_dwc3_init(void __iomem *regs) +static void uniphier_pxs2_dwc3_init(struct udevice *dev, int index, + enum usb_dr_mode mode) { + struct dwc3_glue_data *glue = dev_get_plat(dev); + void *regs = map_physmem(glue->regs, glue->size, MAP_NOCACHE); u32 tmp;
tmp = readl(regs + UNIPHIER_PXS2_DWC3_RESET); tmp |= UNIPHIER_PXS2_DWC3_RESET_XLINK; writel(tmp, regs + UNIPHIER_PXS2_DWC3_RESET);
-static int uniphier_dwc3_probe(struct udevice *dev) -{ - fdt_addr_t base; - void __iomem *regs; - int (*init)(void __iomem *regs); - int ret; - - base = dev_read_addr(dev); - if (base == FDT_ADDR_T_NONE) - return -EINVAL; - - regs = ioremap(base, SZ_32K); - if (!regs) - return -ENOMEM; - - init = (typeof(init))dev_get_driver_data(dev); - ret = init(regs); - if (ret) - dev_err(dev, "failed to init glue layer\n"); +struct dwc3_glue_ops uniphier_pro4_dwc3_ops = { + .glue_configure = uniphier_pro4_dwc3_init, +};
- iounmap(regs); +struct dwc3_glue_ops uniphier_pro5_dwc3_ops = { + .glue_configure = uniphier_pro5_dwc3_init, +};
- return ret; -} +struct dwc3_glue_ops uniphier_pxs2_dwc3_ops = { + .glue_configure = uniphier_pxs2_dwc3_init, +};
static const struct udevice_id uniphier_dwc3_match[] = { { .compatible = "socionext,uniphier-pro4-dwc3", - .data = (ulong)uniphier_pro4_dwc3_init, + .data = (ulong)&uniphier_pro4_dwc3_ops, }, { .compatible = "socionext,uniphier-pro5-dwc3", - .data = (ulong)uniphier_pro5_dwc3_init, + .data = (ulong)&uniphier_pro5_dwc3_ops, }, { .compatible = "socionext,uniphier-pxs2-dwc3", - .data = (ulong)uniphier_pxs2_dwc3_init, + .data = (ulong)&uniphier_pxs2_dwc3_ops, }, { .compatible = "socionext,uniphier-ld20-dwc3", - .data = (ulong)uniphier_pxs2_dwc3_init, + .data = (ulong)&uniphier_pxs2_dwc3_ops, }, { .compatible = "socionext,uniphier-pxs3-dwc3", - .data = (ulong)uniphier_pxs2_dwc3_init, + .data = (ulong)&uniphier_pxs2_dwc3_ops, }, { /* sentinel */ } };
-U_BOOT_DRIVER(usb_xhci) = { +U_BOOT_DRIVER(dwc3_uniphier_wrapper) = { .name = "uniphier-dwc3", .id = UCLASS_SIMPLE_BUS, .of_match = uniphier_dwc3_match, - .probe = uniphier_dwc3_probe, + .bind = dwc3_glue_bind, + .probe = dwc3_glue_probe, + .remove = dwc3_glue_remove, + .plat_auto = sizeof(struct dwc3_glue_data), };
Replacing with dwc3-generic, no need USB_XHCI_DWC3 anymore.
Signed-off-by: Kunihiko Hayashi hayashi.kunihiko@socionext.com --- configs/uniphier_v7_defconfig | 1 - configs/uniphier_v8_defconfig | 1 - 2 files changed, 2 deletions(-)
diff --git a/configs/uniphier_v7_defconfig b/configs/uniphier_v7_defconfig index d626968c76..03feb04b93 100644 --- a/configs/uniphier_v7_defconfig +++ b/configs/uniphier_v7_defconfig @@ -82,7 +82,6 @@ CONFIG_DM_SPI=y CONFIG_UNIPHIER_SPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y diff --git a/configs/uniphier_v8_defconfig b/configs/uniphier_v8_defconfig index 6a0e2666cf..ed58b5746e 100644 --- a/configs/uniphier_v8_defconfig +++ b/configs/uniphier_v8_defconfig @@ -71,7 +71,6 @@ CONFIG_SYSRESET=y CONFIG_SYSRESET_PSCI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y
Kunihiko Hayashi
