[U-Boot] [PATCH 0/4] DaVinci/DA8xx cleanups
Some general cleanup patches for the DaVinci/DA8xx CPUs made in preparation for porting to a new board based on the DA850.
This is an unchanged repost from my original, with DaVinci/DA8xx board maintainers CCed.
Laurence Withers (4): DaVinci EMAC: declare function for all DA8xx CPUs DA8xx: add MMC/SD controller addresses DA8xx: switch an enum to defines for consistency DA8xx: fix LPSC constants
arch/arm/include/asm/arch-davinci/davinci_misc.h | 2 +- arch/arm/include/asm/arch-davinci/hardware.h | 102 +++++++++++++--------- 2 files changed, 62 insertions(+), 42 deletions(-)
The function davinci_emac_mii_mode_sel() is defined in board/davinci/common/misc.c for any DA8xx CPU which has CONFIG_DRIVER_TI_EMAC enabled. However, the prototype was only being declared in <include/asm/arch/davinci_misc.h> for the DA850 EVM board. This patch declares it for all DA8xx CPUs where CONFIG_DRIVER_TI_EMAC is enabled.
Signed-off-by: Laurence Withers lwithers@guralp.com --- arch/arm/include/asm/arch-davinci/davinci_misc.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/arm/include/asm/arch-davinci/davinci_misc.h b/arch/arm/include/asm/arch-davinci/davinci_misc.h index 347aa89..211b769 100644 --- a/arch/arm/include/asm/arch-davinci/davinci_misc.h +++ b/arch/arm/include/asm/arch-davinci/davinci_misc.h @@ -57,7 +57,7 @@ void davinci_sync_env_enetaddr(uint8_t *rom_enetaddr); int davinci_configure_pin_mux(const struct pinmux_config *pins, int n_pins); int davinci_configure_pin_mux_items(const struct pinmux_resource *item, int n_items); -#if defined(CONFIG_DRIVER_TI_EMAC) && defined(CONFIG_MACH_DAVINCI_DA850_EVM) +#if defined(CONFIG_DRIVER_TI_EMAC) && defined(CONFIG_SOC_DA8XX) void davinci_emac_mii_mode_sel(int mode_sel); #endif #if defined(CONFIG_SOC_DA8XX)
Signed-off-by: Laurence Withers lwithers@guralp.com --- arch/arm/include/asm/arch-davinci/hardware.h | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-davinci/hardware.h b/arch/arm/include/asm/arch-davinci/hardware.h index df3f549..d5d4211 100644 --- a/arch/arm/include/asm/arch-davinci/hardware.h +++ b/arch/arm/include/asm/arch-davinci/hardware.h @@ -140,6 +140,8 @@ typedef volatile unsigned int * dv_reg_p; #define DAVINCI_EMAC_WRAPPER_CNTRL_REGS_BASE 0x01e22000 #define DAVINCI_EMAC_WRAPPER_RAM_BASE 0x01e20000 #define DAVINCI_MDIO_CNTRL_REGS_BASE 0x01e24000 +#define DAVINCI_MMC_SD0_BASE 0x01c40000 +#define DAVINCI_MMC_SD1_BASE 0x01e1b000 #define DAVINCI_ASYNC_EMIF_CNTRL_BASE 0x68000000 #define DAVINCI_ASYNC_EMIF_DATA_CE0_BASE 0x40000000 #define DAVINCI_ASYNC_EMIF_DATA_CE2_BASE 0x60000000
There are two main sets of LPSC constants, depending on the processor family. The DA8xx constants were given in an enum whereas the non-DA8xx constants were preprocessor defines. This commit switches the DA8xx constants to defines for consistency.
Signed-off-by: Laurence Withers lwithers@guralp.com --- arch/arm/include/asm/arch-davinci/hardware.h | 81 +++++++++++++------------- 1 files changed, 40 insertions(+), 41 deletions(-)
diff --git a/arch/arm/include/asm/arch-davinci/hardware.h b/arch/arm/include/asm/arch-davinci/hardware.h index d5d4211..551b469 100644 --- a/arch/arm/include/asm/arch-davinci/hardware.h +++ b/arch/arm/include/asm/arch-davinci/hardware.h @@ -215,47 +215,46 @@ typedef volatile unsigned int * dv_reg_p;
#else /* CONFIG_SOC_DA8XX */
-enum davinci_lpsc_ids { - DAVINCI_LPSC_TPCC = 0, - DAVINCI_LPSC_TPTC0, - DAVINCI_LPSC_TPTC1, - DAVINCI_LPSC_AEMIF, - DAVINCI_LPSC_SPI0, - DAVINCI_LPSC_MMC_SD, - DAVINCI_LPSC_AINTC, - DAVINCI_LPSC_ARM_RAM_ROM, - DAVINCI_LPSC_SECCTL_KEYMGR, - DAVINCI_LPSC_UART0, - DAVINCI_LPSC_SCR0, - DAVINCI_LPSC_SCR1, - DAVINCI_LPSC_SCR2, - DAVINCI_LPSC_DMAX, - DAVINCI_LPSC_ARM, - DAVINCI_LPSC_GEM, - /* for LPSCs in PSC1, offset from 32 for differentiation */ - DAVINCI_LPSC_PSC1_BASE = 32, - DAVINCI_LPSC_USB11, - DAVINCI_LPSC_USB20, - DAVINCI_LPSC_GPIO, - DAVINCI_LPSC_UHPI, - DAVINCI_LPSC_EMAC, - DAVINCI_LPSC_DDR_EMIF, - DAVINCI_LPSC_McASP0, - DAVINCI_LPSC_McASP1, - DAVINCI_LPSC_McASP2, - DAVINCI_LPSC_SPI1, - DAVINCI_LPSC_I2C1, - DAVINCI_LPSC_UART1, - DAVINCI_LPSC_UART2, - DAVINCI_LPSC_LCDC, - DAVINCI_LPSC_ePWM, - DAVINCI_LPSC_eCAP, - DAVINCI_LPSC_eQEP, - DAVINCI_LPSC_SCR_P0, - DAVINCI_LPSC_SCR_P1, - DAVINCI_LPSC_CR_P3, - DAVINCI_LPSC_L3_CBA_RAM -}; +#define DAVINCI_LPSC_TPCC 0 +#define DAVINCI_LPSC_TPTC0 1 +#define DAVINCI_LPSC_TPTC1 2 +#define DAVINCI_LPSC_AEMIF 3 +#define DAVINCI_LPSC_SPI0 4 +#define DAVINCI_LPSC_MMC_SD 5 +#define DAVINCI_LPSC_AINTC 6 +#define DAVINCI_LPSC_ARM_RAM_ROM 7 +#define DAVINCI_LPSC_SECCTL_KEYMGR 8 +#define DAVINCI_LPSC_UART0 9 +#define DAVINCI_LPSC_SCR0 10 +#define DAVINCI_LPSC_SCR1 11 +#define DAVINCI_LPSC_SCR2 12 +#define DAVINCI_LPSC_DMAX 13 +#define DAVINCI_LPSC_ARM 14 +#define DAVINCI_LPSC_GEM 15 + +/* for LPSCs in PSC1, offset from 32 for differentiation */ +#define DAVINCI_LPSC_PSC1_BASE 32 +#define DAVINCI_LPSC_USB11 (DAVINCI_LPSC_PSC1_BASE + 1) +#define DAVINCI_LPSC_USB20 (DAVINCI_LPSC_PSC1_BASE + 2) +#define DAVINCI_LPSC_GPIO (DAVINCI_LPSC_PSC1_BASE + 3) +#define DAVINCI_LPSC_UHPI (DAVINCI_LPSC_PSC1_BASE + 4) +#define DAVINCI_LPSC_EMAC (DAVINCI_LPSC_PSC1_BASE + 5) +#define DAVINCI_LPSC_DDR_EMIF (DAVINCI_LPSC_PSC1_BASE + 6) +#define DAVINCI_LPSC_McASP0 (DAVINCI_LPSC_PSC1_BASE + 7) +#define DAVINCI_LPSC_McASP1 (DAVINCI_LPSC_PSC1_BASE + 8) +#define DAVINCI_LPSC_McASP2 (DAVINCI_LPSC_PSC1_BASE + 9) +#define DAVINCI_LPSC_SPI1 (DAVINCI_LPSC_PSC1_BASE + 10) +#define DAVINCI_LPSC_I2C1 (DAVINCI_LPSC_PSC1_BASE + 11) +#define DAVINCI_LPSC_UART1 (DAVINCI_LPSC_PSC1_BASE + 12) +#define DAVINCI_LPSC_UART2 (DAVINCI_LPSC_PSC1_BASE + 13) +#define DAVINCI_LPSC_LCDC (DAVINCI_LPSC_PSC1_BASE + 14) +#define DAVINCI_LPSC_ePWM (DAVINCI_LPSC_PSC1_BASE + 15) +#define DAVINCI_LPSC_eCAP (DAVINCI_LPSC_PSC1_BASE + 16) +#define DAVINCI_LPSC_eQEP (DAVINCI_LPSC_PSC1_BASE + 17) +#define DAVINCI_LPSC_SCR_P0 (DAVINCI_LPSC_PSC1_BASE + 18) +#define DAVINCI_LPSC_SCR_P1 (DAVINCI_LPSC_PSC1_BASE + 19) +#define DAVINCI_LPSC_CR_P3 (DAVINCI_LPSC_PSC1_BASE + 20) +#define DAVINCI_LPSC_L3_CBA_RAM (DAVINCI_LPSC_PSC1_BASE + 21)
#endif /* CONFIG_SOC_DA8XX */
Some of the LPSC constants were incorrect, and some were missing. This commit fixes the incorrect constants (which were not used anywhere in the tree) and adds all constants for both DA830 and DA850, as per the TI datasheets.
Signed-off-by: Laurence Withers lwithers@guralp.com --- arch/arm/include/asm/arch-davinci/hardware.h | 43 ++++++++++++++++++------- 1 files changed, 31 insertions(+), 12 deletions(-)
diff --git a/arch/arm/include/asm/arch-davinci/hardware.h b/arch/arm/include/asm/arch-davinci/hardware.h index 551b469..f537c4b 100644 --- a/arch/arm/include/asm/arch-davinci/hardware.h +++ b/arch/arm/include/asm/arch-davinci/hardware.h @@ -234,27 +234,46 @@ typedef volatile unsigned int * dv_reg_p;
/* for LPSCs in PSC1, offset from 32 for differentiation */ #define DAVINCI_LPSC_PSC1_BASE 32 -#define DAVINCI_LPSC_USB11 (DAVINCI_LPSC_PSC1_BASE + 1) -#define DAVINCI_LPSC_USB20 (DAVINCI_LPSC_PSC1_BASE + 2) +#define DAVINCI_LPSC_USB20 (DAVINCI_LPSC_PSC1_BASE + 1) +#define DAVINCI_LPSC_USB11 (DAVINCI_LPSC_PSC1_BASE + 2) #define DAVINCI_LPSC_GPIO (DAVINCI_LPSC_PSC1_BASE + 3) #define DAVINCI_LPSC_UHPI (DAVINCI_LPSC_PSC1_BASE + 4) #define DAVINCI_LPSC_EMAC (DAVINCI_LPSC_PSC1_BASE + 5) #define DAVINCI_LPSC_DDR_EMIF (DAVINCI_LPSC_PSC1_BASE + 6) #define DAVINCI_LPSC_McASP0 (DAVINCI_LPSC_PSC1_BASE + 7) -#define DAVINCI_LPSC_McASP1 (DAVINCI_LPSC_PSC1_BASE + 8) -#define DAVINCI_LPSC_McASP2 (DAVINCI_LPSC_PSC1_BASE + 9) #define DAVINCI_LPSC_SPI1 (DAVINCI_LPSC_PSC1_BASE + 10) #define DAVINCI_LPSC_I2C1 (DAVINCI_LPSC_PSC1_BASE + 11) #define DAVINCI_LPSC_UART1 (DAVINCI_LPSC_PSC1_BASE + 12) #define DAVINCI_LPSC_UART2 (DAVINCI_LPSC_PSC1_BASE + 13) -#define DAVINCI_LPSC_LCDC (DAVINCI_LPSC_PSC1_BASE + 14) -#define DAVINCI_LPSC_ePWM (DAVINCI_LPSC_PSC1_BASE + 15) -#define DAVINCI_LPSC_eCAP (DAVINCI_LPSC_PSC1_BASE + 16) -#define DAVINCI_LPSC_eQEP (DAVINCI_LPSC_PSC1_BASE + 17) -#define DAVINCI_LPSC_SCR_P0 (DAVINCI_LPSC_PSC1_BASE + 18) -#define DAVINCI_LPSC_SCR_P1 (DAVINCI_LPSC_PSC1_BASE + 19) -#define DAVINCI_LPSC_CR_P3 (DAVINCI_LPSC_PSC1_BASE + 20) -#define DAVINCI_LPSC_L3_CBA_RAM (DAVINCI_LPSC_PSC1_BASE + 21) +#define DAVINCI_LPSC_LCDC (DAVINCI_LPSC_PSC1_BASE + 16) +#define DAVINCI_LPSC_ePWM (DAVINCI_LPSC_PSC1_BASE + 17) +#define DAVINCI_LPSC_eCAP (DAVINCI_LPSC_PSC1_BASE + 20) +#define DAVINCI_LPSC_L3_CBA_RAM (DAVINCI_LPSC_PSC1_BASE + 31) + +/* DA830-specific peripherals */ +#define DAVINCI_LPSC_McASP1 (DAVINCI_LPSC_PSC1_BASE + 8) +#define DAVINCI_LPSC_McASP2 (DAVINCI_LPSC_PSC1_BASE + 9) +#define DAVINCI_LPSC_eQEP (DAVINCI_LPSC_PSC1_BASE + 21) +#define DAVINCI_LPSC_SCR8 (DAVINCI_LPSC_PSC1_BASE + 24) +#define DAVINCI_LPSC_SCR7 (DAVINCI_LPSC_PSC1_BASE + 25) +#define DAVINCI_LPSC_SCR12 (DAVINCI_LPSC_PSC1_BASE + 26) + +/* DA850-specific peripherals */ +#define DAVINCI_LPSC_TPCC1 (DAVINCI_LPSC_PSC1_BASE + 0) +#define DAVINCI_LPSC_SATA (DAVINCI_LPSC_PSC1_BASE + 8) +#define DAVINCI_LPSC_VPIF (DAVINCI_LPSC_PSC1_BASE + 9) +#define DAVINCI_LPSC_McBSP0 (DAVINCI_LPSC_PSC1_BASE + 14) +#define DAVINCI_LPSC_McBSP1 (DAVINCI_LPSC_PSC1_BASE + 15) +#define DAVINCI_LPSC_MMC_SD1 (DAVINCI_LPSC_PSC1_BASE + 18) +#define DAVINCI_LPSC_uPP (DAVINCI_LPSC_PSC1_BASE + 19) +#define DAVINCI_LPSC_TPTC2 (DAVINCI_LPSC_PSC1_BASE + 21) +#define DAVINCI_LPSC_SCR_F0 (DAVINCI_LPSC_PSC1_BASE + 24) +#define DAVINCI_LPSC_SCR_F1 (DAVINCI_LPSC_PSC1_BASE + 25) +#define DAVINCI_LPSC_SCR_F2 (DAVINCI_LPSC_PSC1_BASE + 26) +#define DAVINCI_LPSC_SCR_F6 (DAVINCI_LPSC_PSC1_BASE + 27) +#define DAVINCI_LPSC_SCR_F7 (DAVINCI_LPSC_PSC1_BASE + 28) +#define DAVINCI_LPSC_SCR_F8 (DAVINCI_LPSC_PSC1_BASE + 29) +#define DAVINCI_LPSC_BR_F7 (DAVINCI_LPSC_PSC1_BASE + 30)
Why not remove the LPSC constants which are not used. They can be added as and when required.
Thanks, Sudhakar
Hi Sudhakar,
This makes sense. I'll leave it a day or two in case there are any other comments, and then post an updated patch set.
Many thanks, and bye for now,
Laurence Withers
