[U-Boot] [PATCH V3 1/7] rsa: use new openssl API to create signature
Previous implementation of the rsa signature was using the openssl API EVP_Sign*, but the new openssl API EVP_DigestSign* is more flexible. So we move to this new API.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Clément Péron peron.clem@gmail.com --- lib/rsa/rsa-sign.c | 17 +++++++++++------ 1 file changed, 11 insertions(+), 6 deletions(-)
Changelog: v3: - no change v2: - no change
diff --git a/lib/rsa/rsa-sign.c b/lib/rsa/rsa-sign.c index 05ac67b..78e348e 100644 --- a/lib/rsa/rsa-sign.c +++ b/lib/rsa/rsa-sign.c @@ -393,7 +393,8 @@ static int rsa_sign_with_key(RSA *rsa, struct checksum_algo *checksum_algo, { EVP_PKEY *key; EVP_MD_CTX *context; - int size, ret = 0; + int ret = 0; + size_t size; uint8_t *sig; int i;
@@ -409,7 +410,7 @@ static int rsa_sign_with_key(RSA *rsa, struct checksum_algo *checksum_algo, size = EVP_PKEY_size(key); sig = malloc(size); if (!sig) { - fprintf(stderr, "Out of memory for signature (%d bytes)\n", + fprintf(stderr, "Out of memory for signature (%zu bytes)\n", size); ret = -ENOMEM; goto err_alloc; @@ -421,22 +422,26 @@ static int rsa_sign_with_key(RSA *rsa, struct checksum_algo *checksum_algo, goto err_create; } EVP_MD_CTX_init(context); - if (!EVP_SignInit(context, checksum_algo->calculate_sign())) { + if (EVP_DigestSignInit(context, NULL, + checksum_algo->calculate_sign(), + NULL, key) <= 0) { ret = rsa_err("Signer setup failed"); goto err_sign; }
for (i = 0; i < region_count; i++) { - if (!EVP_SignUpdate(context, region[i].data, region[i].size)) { + if (!EVP_DigestSignUpdate(context, region[i].data, + region[i].size)) { ret = rsa_err("Signing data failed"); goto err_sign; } }
- if (!EVP_SignFinal(context, sig, sig_size, key)) { + if (!EVP_DigestSignFinal(context, sig, &size)) { ret = rsa_err("Could not obtain signature"); goto err_sign; } + #if OPENSSL_VERSION_NUMBER < 0x10100000L || \ (defined(LIBRESSL_VERSION_NUMBER) && LIBRESSL_VERSION_NUMBER < 0x02070000fL) EVP_MD_CTX_cleanup(context); @@ -446,7 +451,7 @@ static int rsa_sign_with_key(RSA *rsa, struct checksum_algo *checksum_algo, EVP_MD_CTX_destroy(context); EVP_PKEY_free(key);
- debug("Got signature: %d bytes, expected %d\n", *sig_size, size); + debug("Got signature: %d bytes, expected %zu\n", *sig_size, size); *sigp = sig; *sig_size = size;
The rsa signature use a padding algorithm. By default, we use the padding pkcs-1.5. In order to add some new padding algorithm, we add a padding framework to manage several padding algorithm. The choice of the padding is done in the file .its.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Clément Péron peron.clem@gmail.com --- common/image-fit.c | 5 +++++ common/image-sig.c | 29 ++++++++++++++++++++++++++ include/image.h | 16 +++++++++++++++ include/u-boot/rsa.h | 13 ++++++++++++ lib/rsa/rsa-sign.c | 15 +++++++++++--- lib/rsa/rsa-verify.c | 57 ++++++++++++++++++++++++++++++++++------------------ tools/image-host.c | 4 ++++ 7 files changed, 116 insertions(+), 23 deletions(-)
diff --git a/common/image-fit.c b/common/image-fit.c index 8d39a24..ac901e1 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -165,6 +165,7 @@ static void fit_image_print_data(const void *fit, int noffset, const char *p, uint8_t *value; int value_len; char *algo; + const char *padding; int required; int ret, i;
@@ -184,6 +185,10 @@ static void fit_image_print_data(const void *fit, int noffset, const char *p, printf(" (required)"); printf("\n");
+ padding = fdt_getprop(fit, noffset, "padding", NULL); + if (padding) + printf("%s %s padding: %s\n", p, type, padding); + ret = fit_image_hash_get_value(fit, noffset, &value, &value_len); printf("%s %s value: ", p, type); diff --git a/common/image-sig.c b/common/image-sig.c index 5a269d3..b7ca657 100644 --- a/common/image-sig.c +++ b/common/image-sig.c @@ -71,6 +71,13 @@ struct crypto_algo crypto_algos[] = {
+struct padding_algo padding_algos[] = { + { + .name = "pkcs-1.5", + .verify = padding_pkcs_15_verify, + }, +}; + struct checksum_algo *image_get_checksum_algo(const char *full_name) { int i; @@ -106,6 +113,21 @@ struct crypto_algo *image_get_crypto_algo(const char *full_name) return NULL; }
+struct padding_algo *image_get_padding_algo(const char *name) +{ + int i; + + if (!name) + return NULL; + + for (i = 0; i < ARRAY_SIZE(padding_algos); i++) { + if (!strcmp(padding_algos[i].name, name)) + return &padding_algos[i]; + } + + return NULL; +} + /** * fit_region_make_list() - Make a list of image regions * @@ -155,6 +177,7 @@ static int fit_image_setup_verify(struct image_sign_info *info, char **err_msgp) { char *algo_name; + const char *padding_name;
if (fdt_totalsize(fit) > CONFIG_FIT_SIGNATURE_MAX_SIZE) { *err_msgp = "Total size too large"; @@ -165,6 +188,11 @@ static int fit_image_setup_verify(struct image_sign_info *info, *err_msgp = "Can't get hash algo property"; return -1; } + + padding_name = fdt_getprop(fit, noffset, "padding", NULL); + if (!padding_name) + padding_name = RSA_DEFAULT_PADDING_NAME; + memset(info, '\0', sizeof(*info)); info->keyname = fdt_getprop(fit, noffset, "key-name-hint", NULL); info->fit = (void *)fit; @@ -172,6 +200,7 @@ static int fit_image_setup_verify(struct image_sign_info *info, info->name = algo_name; info->checksum = image_get_checksum_algo(algo_name); info->crypto = image_get_crypto_algo(algo_name); + info->padding = image_get_padding_algo(padding_name); info->fdt_blob = gd_fdt_blob(); info->required_keynode = required_keynode; printf("%s:%s", algo_name, info->keyname); diff --git a/include/image.h b/include/image.h index 031c355..7fed0ae 100644 --- a/include/image.h +++ b/include/image.h @@ -1100,6 +1100,7 @@ struct image_sign_info { int node_offset; /* Offset of signature node */ const char *name; /* Algorithm name */ struct checksum_algo *checksum; /* Checksum algorithm information */ + struct padding_algo *padding; /* Padding algorithm information */ struct crypto_algo *crypto; /* Crypto algorithm information */ const void *fdt_blob; /* FDT containing public keys */ int required_keynode; /* Node offset of key to use: -1=any */ @@ -1185,6 +1186,13 @@ struct crypto_algo { uint8_t *sig, uint sig_len); };
+struct padding_algo { + const char *name; + int (*verify)(struct image_sign_info *info, + uint8_t *pad, int pad_len, + const uint8_t *hash, int hash_len); +}; + /** * image_get_checksum_algo() - Look up a checksum algorithm * @@ -1202,6 +1210,14 @@ struct checksum_algo *image_get_checksum_algo(const char *full_name); struct crypto_algo *image_get_crypto_algo(const char *full_name);
/** + * image_get_padding_algo() - Look up a padding algorithm + * + * @param name Name of padding algorithm + * @return pointer to algorithm information, or NULL if not found + */ +struct padding_algo *image_get_padding_algo(const char *name); + +/** * fit_image_verify_required_sigs() - Verify signatures marked as 'required' * * @fit: FIT to check diff --git a/include/u-boot/rsa.h b/include/u-boot/rsa.h index 68bcb14..16b4c4c 100644 --- a/include/u-boot/rsa.h +++ b/include/u-boot/rsa.h @@ -97,6 +97,10 @@ static inline int rsa_add_verify_data(struct image_sign_info *info, int rsa_verify(struct image_sign_info *info, const struct image_region region[], int region_count, uint8_t *sig, uint sig_len); + +int padding_pkcs_15_verify(struct image_sign_info *info, + uint8_t *msg, int msg_len, + const uint8_t *hash, int hash_len); #else static inline int rsa_verify(struct image_sign_info *info, const struct image_region region[], int region_count, @@ -104,8 +108,17 @@ static inline int rsa_verify(struct image_sign_info *info, { return -ENXIO; } + +static inline int padding_pkcs_15_verify(struct image_sign_info *info, + uint8_t *msg, int msg_len, + const uint8_t *hash, int hash_len) +{ + return -ENXIO; +} #endif
+#define RSA_DEFAULT_PADDING_NAME "pkcs-1.5" + #define RSA2048_BYTES (2048 / 8) #define RSA4096_BYTES (4096 / 8)
diff --git a/lib/rsa/rsa-sign.c b/lib/rsa/rsa-sign.c index 78e348e..6aa0e2a 100644 --- a/lib/rsa/rsa-sign.c +++ b/lib/rsa/rsa-sign.c @@ -387,11 +387,13 @@ static void rsa_engine_remove(ENGINE *e) } }
-static int rsa_sign_with_key(RSA *rsa, struct checksum_algo *checksum_algo, +static int rsa_sign_with_key(RSA *rsa, struct padding_algo *padding_algo, + struct checksum_algo *checksum_algo, const struct image_region region[], int region_count, uint8_t **sigp, uint *sig_size) { EVP_PKEY *key; + EVP_PKEY_CTX *ckey; EVP_MD_CTX *context; int ret = 0; size_t size; @@ -422,7 +424,14 @@ static int rsa_sign_with_key(RSA *rsa, struct checksum_algo *checksum_algo, goto err_create; } EVP_MD_CTX_init(context); - if (EVP_DigestSignInit(context, NULL, + + ckey = EVP_PKEY_CTX_new(key, NULL); + if (!ckey) { + ret = rsa_err("EVP key context creation failed"); + goto err_create; + } + + if (EVP_DigestSignInit(context, &ckey, checksum_algo->calculate_sign(), NULL, key) <= 0) { ret = rsa_err("Signer setup failed"); @@ -488,7 +497,7 @@ int rsa_sign(struct image_sign_info *info, ret = rsa_get_priv_key(info->keydir, info->keyname, e, &rsa); if (ret) goto err_priv; - ret = rsa_sign_with_key(rsa, info->checksum, region, + ret = rsa_sign_with_key(rsa, info->padding, info->checksum, region, region_count, sigp, sig_len); if (ret) goto err_sign; diff --git a/lib/rsa/rsa-verify.c b/lib/rsa/rsa-verify.c index bc83354..279a9ba 100644 --- a/lib/rsa/rsa-verify.c +++ b/lib/rsa/rsa-verify.c @@ -57,31 +57,57 @@ static int rsa_verify_padding(const uint8_t *msg, const int pad_len, return ret; }
+int padding_pkcs_15_verify(struct image_sign_info *info, + uint8_t *msg, int msg_len, + const uint8_t *hash, int hash_len) +{ + struct checksum_algo *checksum = info->checksum; + int ret, pad_len = msg_len - checksum->checksum_len; + + /* Check pkcs1.5 padding bytes. */ + ret = rsa_verify_padding(msg, pad_len, checksum); + if (ret) { + debug("In RSAVerify(): Padding check failed!\n"); + return -EINVAL; + } + + /* Check hash. */ + if (memcmp((uint8_t *)msg + pad_len, hash, msg_len - pad_len)) { + debug("In RSAVerify(): Hash check failed!\n"); + return -EACCES; + } + + return 0; +} + /** * rsa_verify_key() - Verify a signature against some data using RSA Key * * Verify a RSA PKCS1.5 signature against an expected hash using * the RSA Key properties in prop structure. * + * @info: Specifies key and FIT information * @prop: Specifies key * @sig: Signature * @sig_len: Number of bytes in signature * @hash: Pointer to the expected hash * @key_len: Number of bytes in rsa key - * @algo: Checksum algo structure having information on DER encoding etc. * @return 0 if verified, -ve on error */ -static int rsa_verify_key(struct key_prop *prop, const uint8_t *sig, +static int rsa_verify_key(struct image_sign_info *info, + struct key_prop *prop, const uint8_t *sig, const uint32_t sig_len, const uint8_t *hash, - const uint32_t key_len, struct checksum_algo *algo) + const uint32_t key_len) { - int pad_len; int ret; #if !defined(USE_HOSTCC) struct udevice *mod_exp_dev; #endif + struct checksum_algo *checksum = info->checksum; + struct padding_algo *padding = info->padding; + int hash_len = checksum->checksum_len;
- if (!prop || !sig || !hash || !algo) + if (!prop || !sig || !hash || !checksum) return -EIO;
if (sig_len != (prop->num_bits / 8)) { @@ -89,7 +115,7 @@ static int rsa_verify_key(struct key_prop *prop, const uint8_t *sig, return -EINVAL; }
- debug("Checksum algorithm: %s", algo->name); + debug("Checksum algorithm: %s", checksum->name);
/* Sanity check for stack size */ if (sig_len > RSA_MAX_SIG_BITS / 8) { @@ -116,19 +142,10 @@ static int rsa_verify_key(struct key_prop *prop, const uint8_t *sig, return ret; }
- pad_len = key_len - algo->checksum_len; - - /* Check pkcs1.5 padding bytes. */ - ret = rsa_verify_padding(buf, pad_len, algo); + ret = padding->verify(info, buf, key_len, hash, hash_len); if (ret) { - debug("In RSAVerify(): Padding check failed!\n"); - return -EINVAL; - } - - /* Check hash. */ - if (memcmp((uint8_t *)buf + pad_len, hash, sig_len - pad_len)) { - debug("In RSAVerify(): Hash check failed!\n"); - return -EACCES; + debug("In RSAVerify(): padding check failed!\n"); + return ret; }
return 0; @@ -182,8 +199,8 @@ static int rsa_verify_with_keynode(struct image_sign_info *info, return -EFAULT; }
- ret = rsa_verify_key(&prop, sig, sig_len, hash, - info->crypto->key_len, info->checksum); + ret = rsa_verify_key(info, &prop, sig, sig_len, hash, + info->crypto->key_len);
return ret; } diff --git a/tools/image-host.c b/tools/image-host.c index 09e4f47..88b3295 100644 --- a/tools/image-host.c +++ b/tools/image-host.c @@ -157,6 +157,7 @@ static int fit_image_setup_sig(struct image_sign_info *info, { const char *node_name; char *algo_name; + const char *padding_name;
node_name = fit_get_name(fit, noffset, NULL); if (fit_image_hash_get_algo(fit, noffset, &algo_name)) { @@ -165,6 +166,8 @@ static int fit_image_setup_sig(struct image_sign_info *info, return -1; }
+ padding_name = fdt_getprop(fit, noffset, "padding", NULL); + memset(info, '\0', sizeof(*info)); info->keydir = keydir; info->keyname = fdt_getprop(fit, noffset, "key-name-hint", NULL); @@ -173,6 +176,7 @@ static int fit_image_setup_sig(struct image_sign_info *info, info->name = strdup(algo_name); info->checksum = image_get_checksum_algo(algo_name); info->crypto = image_get_crypto_algo(algo_name); + info->padding = image_get_padding_algo(padding_name); info->require_keys = require_keys; info->engine_id = engine_id; if (!info->checksum || !info->crypto) {
We add the support of the padding pss for rsa signature. This new padding is often recommended instead of pkcs-1.5.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Clément Péron peron.clem@gmail.com --- Kconfig | 8 +++ common/image-sig.c | 6 ++ include/image.h | 1 + include/u-boot/rsa.h | 15 ++++ lib/rsa/rsa-sign.c | 10 +++ lib/rsa/rsa-verify.c | 190 +++++++++++++++++++++++++++++++++++++++++++++++++++ 6 files changed, 230 insertions(+)
Changelog: v3: no change v2: - add a Kconfig option (thanks Simon Glass) - some code cleaning (thanks Simon Glass)
diff --git a/Kconfig b/Kconfig index dca9bb4..3120553 100644 --- a/Kconfig +++ b/Kconfig @@ -290,6 +290,14 @@ config FIT_SIGNATURE_MAX_SIZE device memory. Assure this size does not extend past expected storage space.
+config FIT_ENABLE_RSASSA_PSS_SUPPORT + bool "Support rsassa-pss signature scheme of FIT image contents" + depends on FIT_SIGNATURE + default n + help + Enable this to support the pss padding algorithm as described + in the rfc8017 (https://tools.ietf.org/html/rfc8017). + config FIT_VERBOSE bool "Show verbose messages when FIT images fail" help diff --git a/common/image-sig.c b/common/image-sig.c index b7ca657..f5ce3b2 100644 --- a/common/image-sig.c +++ b/common/image-sig.c @@ -76,6 +76,12 @@ struct padding_algo padding_algos[] = { .name = "pkcs-1.5", .verify = padding_pkcs_15_verify, }, +#ifdef CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT + { + .name = "pss", + .verify = padding_pss_verify, + } +#endif /* CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT */ };
struct checksum_algo *image_get_checksum_algo(const char *full_name) diff --git a/include/image.h b/include/image.h index 7fed0ae..f4c5a15 100644 --- a/include/image.h +++ b/include/image.h @@ -30,6 +30,7 @@ struct fdt_region; #define IMAGE_ENABLE_FIT 1 #define IMAGE_ENABLE_OF_LIBFDT 1 #define CONFIG_FIT_VERBOSE 1 /* enable fit_format_{error,warning}() */ +#define CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT 1 #define CONFIG_FIT_ENABLE_SHA256_SUPPORT #define CONFIG_SHA1 #define CONFIG_SHA256 diff --git a/include/u-boot/rsa.h b/include/u-boot/rsa.h index 16b4c4c..2d3024d 100644 --- a/include/u-boot/rsa.h +++ b/include/u-boot/rsa.h @@ -101,6 +101,12 @@ int rsa_verify(struct image_sign_info *info, int padding_pkcs_15_verify(struct image_sign_info *info, uint8_t *msg, int msg_len, const uint8_t *hash, int hash_len); + +#ifdef CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT +int padding_pss_verify(struct image_sign_info *info, + uint8_t *msg, int msg_len, + const uint8_t *hash, int hash_len); +#endif /* CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT */ #else static inline int rsa_verify(struct image_sign_info *info, const struct image_region region[], int region_count, @@ -115,6 +121,15 @@ static inline int padding_pkcs_15_verify(struct image_sign_info *info, { return -ENXIO; } + +#ifdef CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT +static inline int padding_pss_verify(struct image_sign_info *info, + uint8_t *msg, int msg_len, + const uint8_t *hash, int hash_len) +{ + return -ENXIO; +} +#endif /* CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT */ #endif
#define RSA_DEFAULT_PADDING_NAME "pkcs-1.5" diff --git a/lib/rsa/rsa-sign.c b/lib/rsa/rsa-sign.c index 6aa0e2a..fb5e07b 100644 --- a/lib/rsa/rsa-sign.c +++ b/lib/rsa/rsa-sign.c @@ -438,6 +438,16 @@ static int rsa_sign_with_key(RSA *rsa, struct padding_algo *padding_algo, goto err_sign; }
+#ifdef CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT + if (padding_algo && !strcmp(padding_algo->name, "pss")) { + if (EVP_PKEY_CTX_set_rsa_padding(ckey, + RSA_PKCS1_PSS_PADDING) <= 0) { + ret = rsa_err("Signer padding setup failed"); + goto err_sign; + } + } +#endif /* CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT */ + for (i = 0; i < region_count; i++) { if (!EVP_DigestSignUpdate(context, region[i].data, region[i].size)) { diff --git a/lib/rsa/rsa-verify.c b/lib/rsa/rsa-verify.c index 279a9ba..9734f6d 100644 --- a/lib/rsa/rsa-verify.c +++ b/lib/rsa/rsa-verify.c @@ -80,6 +80,196 @@ int padding_pkcs_15_verify(struct image_sign_info *info, return 0; }
+#ifdef CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT +static void u32_i2osp(uint32_t val, uint8_t *buf) +{ + buf[0] = (uint8_t)((val >> 24) & 0xff); + buf[1] = (uint8_t)((val >> 16) & 0xff); + buf[2] = (uint8_t)((val >> 8) & 0xff); + buf[3] = (uint8_t)((val >> 0) & 0xff); +} + +/** + * mask_generation_function1() - generate an octet string + * + * Generate an octet string used to check rsa signature. + * It use an input octet string and a hash function. + * + * @checksum: A Hash function + * @seed: Specifies an input variable octet string + * @seed_len: Size of the input octet string + * @output: Specifies the output octet string + * @output_len: Size of the output octet string + * @return 0 if the octet string was correctly generated, others on error + */ +static int mask_generation_function1(struct checksum_algo *checksum, + uint8_t *seed, int seed_len, + uint8_t *output, int output_len) +{ + struct image_region region[2]; + int ret = 0, i, i_output = 0, region_count = 2; + uint32_t counter = 0; + uint8_t buf_counter[4], *tmp; + int hash_len = checksum->checksum_len; + + memset(output, 0, output_len); + + region[0].data = seed; + region[0].size = seed_len; + region[1].data = &buf_counter[0]; + region[1].size = 4; + + tmp = malloc(hash_len); + if (!tmp) { + debug("%s: can't allocate array tmp\n", __func__); + ret = -ENOMEM; + goto out; + } + + while (i_output < output_len) { + u32_i2osp(counter, &buf_counter[0]); + + ret = checksum->calculate(checksum->name, + region, region_count, + tmp); + if (ret < 0) { + debug("%s: Error in checksum calculation\n", __func__); + goto out; + } + + i = 0; + while ((i_output < output_len) && (i < hash_len)) { + output[i_output] = tmp[i]; + i_output++; + i++; + } + + counter++; + } + +out: + free(tmp); + + return ret; +} + +static int compute_hash_prime(struct checksum_algo *checksum, + uint8_t *pad, int pad_len, + uint8_t *hash, int hash_len, + uint8_t *salt, int salt_len, + uint8_t *hprime) +{ + struct image_region region[3]; + int ret, region_count = 3; + + region[0].data = pad; + region[0].size = pad_len; + region[1].data = hash; + region[1].size = hash_len; + region[2].data = salt; + region[2].size = salt_len; + + ret = checksum->calculate(checksum->name, region, region_count, hprime); + if (ret < 0) { + debug("%s: Error in checksum calculation\n", __func__); + goto out; + } + +out: + return ret; +} + +int padding_pss_verify(struct image_sign_info *info, + uint8_t *msg, int msg_len, + const uint8_t *hash, int hash_len) +{ + uint8_t *masked_db = NULL; + int masked_db_len = msg_len - hash_len - 1; + uint8_t *h = NULL, *hprime = NULL; + int h_len = hash_len; + uint8_t *db_mask = NULL; + int db_mask_len = masked_db_len; + uint8_t *db = NULL, *salt = NULL; + int db_len = masked_db_len, salt_len = msg_len - hash_len - 2; + uint8_t pad_zero[8] = { 0 }; + int ret, i, leftmost_bits = 1; + uint8_t leftmost_mask; + struct checksum_algo *checksum = info->checksum; + + /* first, allocate everything */ + masked_db = malloc(masked_db_len); + h = malloc(h_len); + db_mask = malloc(db_mask_len); + db = malloc(db_len); + salt = malloc(salt_len); + hprime = malloc(hash_len); + if (!masked_db || !h || !db_mask || !db || !salt || !hprime) { + printf("%s: can't allocate some buffer\n", __func__); + ret = -ENOMEM; + goto out; + } + + /* step 4: check if the last byte is 0xbc */ + if (msg[msg_len - 1] != 0xbc) { + printf("%s: invalid pss padding (0xbc is missing)\n", __func__); + ret = -EINVAL; + goto out; + } + + /* step 5 */ + memcpy(masked_db, msg, masked_db_len); + memcpy(h, msg + masked_db_len, h_len); + + /* step 6 */ + leftmost_mask = (0xff >> (8 - leftmost_bits)) << (8 - leftmost_bits); + if (masked_db[0] & leftmost_mask) { + printf("%s: invalid pss padding ", __func__); + printf("(leftmost bit of maskedDB not zero)\n"); + ret = -EINVAL; + goto out; + } + + /* step 7 */ + mask_generation_function1(checksum, h, h_len, db_mask, db_mask_len); + + /* step 8 */ + for (i = 0; i < db_len; i++) + db[i] = masked_db[i] ^ db_mask[i]; + + /* step 9 */ + db[0] &= 0xff >> leftmost_bits; + + /* step 10 */ + if (db[0] != 0x01) { + printf("%s: invalid pss padding ", __func__); + printf("(leftmost byte of db isn't 0x01)\n"); + ret = EINVAL; + goto out; + } + + /* step 11 */ + memcpy(salt, &db[1], salt_len); + + /* step 12 & 13 */ + compute_hash_prime(checksum, pad_zero, 8, + (uint8_t *)hash, hash_len, + salt, salt_len, hprime); + + /* step 14 */ + ret = memcmp(h, hprime, hash_len); + +out: + free(hprime); + free(salt); + free(db); + free(db_mask); + free(h); + free(masked_db); + + return ret; +} +#endif + /** * rsa_verify_key() - Verify a signature against some data using RSA Key *
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Clément Péron peron.clem@gmail.com --- doc/uImage.FIT/signature.txt | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/doc/uImage.FIT/signature.txt b/doc/uImage.FIT/signature.txt index a765722..bfff6fd 100644 --- a/doc/uImage.FIT/signature.txt +++ b/doc/uImage.FIT/signature.txt @@ -106,6 +106,9 @@ When the image is signed, the following properties are optional:
- comment: Additional information about the signer or image
+- padding: The padding algorithm, it may be pkcs-1.5 or pss, + if no value is provided we assume pkcs-1.5 + For config bindings (see Signed Configurations below), the following additional properties are optional:
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Clément Péron peron.clem@gmail.com --- configs/sandbox_defconfig | 1 + 1 file changed, 1 insertion(+)
Changelog: v3: - no change v2: - new patch in the serie
diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 2ce336f..b2565e1 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -6,6 +6,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_ANDROID_BOOT_IMAGE=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT=y CONFIG_FIT_VERBOSE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y
The padding pss is now supported for rsa signature. This add test with padding pss on vboot test.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Clément Péron peron.clem@gmail.com --- test/py/tests/test_vboot.py | 12 ++++--- test/py/tests/vboot/sign-configs-sha1-pss.its | 46 +++++++++++++++++++++++++ test/py/tests/vboot/sign-configs-sha256-pss.its | 46 +++++++++++++++++++++++++ test/py/tests/vboot/sign-images-sha1-pss.its | 44 +++++++++++++++++++++++ test/py/tests/vboot/sign-images-sha256-pss.its | 44 +++++++++++++++++++++++ 5 files changed, 187 insertions(+), 5 deletions(-) create mode 100644 test/py/tests/vboot/sign-configs-sha1-pss.its create mode 100644 test/py/tests/vboot/sign-configs-sha256-pss.its create mode 100644 test/py/tests/vboot/sign-images-sha1-pss.its create mode 100644 test/py/tests/vboot/sign-images-sha256-pss.its
Changelog: v3: - fix make_fit for sign-configs (should also use padding) v2: - new patch in the serie - add vboot for pss padding (thanks Simon Glass)
diff --git a/test/py/tests/test_vboot.py b/test/py/tests/test_vboot.py index e9cbd57..a3a3879 100644 --- a/test/py/tests/test_vboot.py +++ b/test/py/tests/test_vboot.py @@ -126,7 +126,7 @@ def test_vboot(u_boot_console): handle.write(struct.pack(">I", size)) return struct.unpack(">I", total_size)[0]
- def test_with_algo(sha_algo): + def test_with_algo(sha_algo, padding): """Test verified boot with the given hash algorithm.
This is the main part of the test code. The same procedure is followed @@ -144,7 +144,7 @@ def test_vboot(u_boot_console):
# Build the FIT, but don't sign anything yet cons.log.action('%s: Test FIT with signed images' % sha_algo) - make_fit('sign-images-%s.its' % sha_algo) + make_fit('sign-images-%s%s.its' % (sha_algo , padding)) run_bootm(sha_algo, 'unsigned images', 'dev-', True)
# Sign images with our dev keys @@ -155,7 +155,7 @@ def test_vboot(u_boot_console): dtc('sandbox-u-boot.dts')
cons.log.action('%s: Test FIT with signed configuration' % sha_algo) - make_fit('sign-configs-%s.its' % sha_algo) + make_fit('sign-configs-%s%s.its' % (sha_algo , padding)) run_bootm(sha_algo, 'unsigned config', '%s+ OK' % sha_algo, True)
# Sign images with our dev keys @@ -226,8 +226,10 @@ def test_vboot(u_boot_console): # afterwards. old_dtb = cons.config.dtb cons.config.dtb = dtb - test_with_algo('sha1') - test_with_algo('sha256') + test_with_algo('sha1','') + test_with_algo('sha1','-pss') + test_with_algo('sha256','') + test_with_algo('sha256','-pss') finally: # Go back to the original U-Boot with the correct dtb. cons.config.dtb = old_dtb diff --git a/test/py/tests/vboot/sign-configs-sha1-pss.its b/test/py/tests/vboot/sign-configs-sha1-pss.its new file mode 100644 index 0000000..3c3ab20 --- /dev/null +++ b/test/py/tests/vboot/sign-configs-sha1-pss.its @@ -0,0 +1,46 @@ +/dts-v1/; + +/ { + description = "Chrome OS kernel image with one or more FDT blobs"; + #address-cells = <1>; + + images { + kernel@1 { + data = /incbin/("test-kernel.bin"); + type = "kernel_noload"; + arch = "sandbox"; + os = "linux"; + compression = "none"; + load = <0x4>; + entry = <0x8>; + kernel-version = <1>; + hash@1 { + algo = "sha1"; + }; + }; + fdt@1 { + description = "snow"; + data = /incbin/("sandbox-kernel.dtb"); + type = "flat_dt"; + arch = "sandbox"; + compression = "none"; + fdt-version = <1>; + hash@1 { + algo = "sha1"; + }; + }; + }; + configurations { + default = "conf@1"; + conf@1 { + kernel = "kernel@1"; + fdt = "fdt@1"; + signature@1 { + algo = "sha1,rsa2048"; + padding = "pss"; + key-name-hint = "dev"; + sign-images = "fdt", "kernel"; + }; + }; + }; +}; diff --git a/test/py/tests/vboot/sign-configs-sha256-pss.its b/test/py/tests/vboot/sign-configs-sha256-pss.its new file mode 100644 index 0000000..8e33510 --- /dev/null +++ b/test/py/tests/vboot/sign-configs-sha256-pss.its @@ -0,0 +1,46 @@ +/dts-v1/; + +/ { + description = "Chrome OS kernel image with one or more FDT blobs"; + #address-cells = <1>; + + images { + kernel@1 { + data = /incbin/("test-kernel.bin"); + type = "kernel_noload"; + arch = "sandbox"; + os = "linux"; + compression = "none"; + load = <0x4>; + entry = <0x8>; + kernel-version = <1>; + hash@1 { + algo = "sha256"; + }; + }; + fdt@1 { + description = "snow"; + data = /incbin/("sandbox-kernel.dtb"); + type = "flat_dt"; + arch = "sandbox"; + compression = "none"; + fdt-version = <1>; + hash@1 { + algo = "sha256"; + }; + }; + }; + configurations { + default = "conf@1"; + conf@1 { + kernel = "kernel@1"; + fdt = "fdt@1"; + signature@1 { + algo = "sha256,rsa2048"; + padding = "pss"; + key-name-hint = "dev"; + sign-images = "fdt", "kernel"; + }; + }; + }; +}; diff --git a/test/py/tests/vboot/sign-images-sha1-pss.its b/test/py/tests/vboot/sign-images-sha1-pss.its new file mode 100644 index 0000000..d19c4d7 --- /dev/null +++ b/test/py/tests/vboot/sign-images-sha1-pss.its @@ -0,0 +1,44 @@ +/dts-v1/; + +/ { + description = "Chrome OS kernel image with one or more FDT blobs"; + #address-cells = <1>; + + images { + kernel@1 { + data = /incbin/("test-kernel.bin"); + type = "kernel_noload"; + arch = "sandbox"; + os = "linux"; + compression = "none"; + load = <0x4>; + entry = <0x8>; + kernel-version = <1>; + signature@1 { + algo = "sha1,rsa2048"; + padding = "pss"; + key-name-hint = "dev"; + }; + }; + fdt@1 { + description = "snow"; + data = /incbin/("sandbox-kernel.dtb"); + type = "flat_dt"; + arch = "sandbox"; + compression = "none"; + fdt-version = <1>; + signature@1 { + algo = "sha1,rsa2048"; + padding = "pss"; + key-name-hint = "dev"; + }; + }; + }; + configurations { + default = "conf@1"; + conf@1 { + kernel = "kernel@1"; + fdt = "fdt@1"; + }; + }; +}; diff --git a/test/py/tests/vboot/sign-images-sha256-pss.its b/test/py/tests/vboot/sign-images-sha256-pss.its new file mode 100644 index 0000000..43612f8 --- /dev/null +++ b/test/py/tests/vboot/sign-images-sha256-pss.its @@ -0,0 +1,44 @@ +/dts-v1/; + +/ { + description = "Chrome OS kernel image with one or more FDT blobs"; + #address-cells = <1>; + + images { + kernel@1 { + data = /incbin/("test-kernel.bin"); + type = "kernel_noload"; + arch = "sandbox"; + os = "linux"; + compression = "none"; + load = <0x4>; + entry = <0x8>; + kernel-version = <1>; + signature@1 { + algo = "sha256,rsa2048"; + padding = "pss"; + key-name-hint = "dev"; + }; + }; + fdt@1 { + description = "snow"; + data = /incbin/("sandbox-kernel.dtb"); + type = "flat_dt"; + arch = "sandbox"; + compression = "none"; + fdt-version = <1>; + signature@1 { + algo = "sha256,rsa2048"; + padding = "pss"; + key-name-hint = "dev"; + }; + }; + }; + configurations { + default = "conf@1"; + conf@1 { + kernel = "kernel@1"; + fdt = "fdt@1"; + }; + }; +};
This update the its file used in vboot test to respect the new node style name defined in doc/uImage.FIT (for example: replace kernel@1 by kernel and fdt@1 by fdt-1)
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Clément Péron peron.clem@gmail.com --- test/py/tests/test_vboot.py | 2 +- test/py/tests/vboot/sign-configs-sha1-pss.its | 18 +++++++++--------- test/py/tests/vboot/sign-configs-sha1.its | 18 +++++++++--------- test/py/tests/vboot/sign-configs-sha256-pss.its | 18 +++++++++--------- test/py/tests/vboot/sign-configs-sha256.its | 18 +++++++++--------- test/py/tests/vboot/sign-images-sha1-pss.its | 16 ++++++++-------- test/py/tests/vboot/sign-images-sha1.its | 16 ++++++++-------- test/py/tests/vboot/sign-images-sha256-pss.its | 16 ++++++++-------- test/py/tests/vboot/sign-images-sha256.its | 16 ++++++++-------- 9 files changed, 69 insertions(+), 69 deletions(-)
Changelog: v3: - new patch in the serie (feedback from Clément Péron)
diff --git a/test/py/tests/test_vboot.py b/test/py/tests/test_vboot.py index a3a3879..1e6ae7a 100644 --- a/test/py/tests/test_vboot.py +++ b/test/py/tests/test_vboot.py @@ -204,7 +204,7 @@ def test_vboot(u_boot_console): fit_check_sign = cons.config.build_dir + '/tools/fit_check_sign' dtc_args = '-I dts -O dtb -i %s' % tmpdir dtb = '%ssandbox-u-boot.dtb' % tmpdir - sig_node = '/configurations/conf@1/signature@1' + sig_node = '/configurations/conf-1/signature'
# Create an RSA key pair public_exponent = 65537 diff --git a/test/py/tests/vboot/sign-configs-sha1-pss.its b/test/py/tests/vboot/sign-configs-sha1-pss.its index 3c3ab20..72a5637 100644 --- a/test/py/tests/vboot/sign-configs-sha1-pss.its +++ b/test/py/tests/vboot/sign-configs-sha1-pss.its @@ -5,7 +5,7 @@ #address-cells = <1>;
images { - kernel@1 { + kernel { data = /incbin/("test-kernel.bin"); type = "kernel_noload"; arch = "sandbox"; @@ -14,28 +14,28 @@ load = <0x4>; entry = <0x8>; kernel-version = <1>; - hash@1 { + hash-1 { algo = "sha1"; }; }; - fdt@1 { + fdt-1 { description = "snow"; data = /incbin/("sandbox-kernel.dtb"); type = "flat_dt"; arch = "sandbox"; compression = "none"; fdt-version = <1>; - hash@1 { + hash-1 { algo = "sha1"; }; }; }; configurations { - default = "conf@1"; - conf@1 { - kernel = "kernel@1"; - fdt = "fdt@1"; - signature@1 { + default = "conf-1"; + conf-1 { + kernel = "kernel"; + fdt = "fdt-1"; + signature { algo = "sha1,rsa2048"; padding = "pss"; key-name-hint = "dev"; diff --git a/test/py/tests/vboot/sign-configs-sha1.its b/test/py/tests/vboot/sign-configs-sha1.its index db2ed79..d8bc1fa 100644 --- a/test/py/tests/vboot/sign-configs-sha1.its +++ b/test/py/tests/vboot/sign-configs-sha1.its @@ -5,7 +5,7 @@ #address-cells = <1>;
images { - kernel@1 { + kernel { data = /incbin/("test-kernel.bin"); type = "kernel_noload"; arch = "sandbox"; @@ -14,28 +14,28 @@ load = <0x4>; entry = <0x8>; kernel-version = <1>; - hash@1 { + hash-1 { algo = "sha1"; }; }; - fdt@1 { + fdt-1 { description = "snow"; data = /incbin/("sandbox-kernel.dtb"); type = "flat_dt"; arch = "sandbox"; compression = "none"; fdt-version = <1>; - hash@1 { + hash-1 { algo = "sha1"; }; }; }; configurations { - default = "conf@1"; - conf@1 { - kernel = "kernel@1"; - fdt = "fdt@1"; - signature@1 { + default = "conf-1"; + conf-1 { + kernel = "kernel"; + fdt = "fdt-1"; + signature { algo = "sha1,rsa2048"; key-name-hint = "dev"; sign-images = "fdt", "kernel"; diff --git a/test/py/tests/vboot/sign-configs-sha256-pss.its b/test/py/tests/vboot/sign-configs-sha256-pss.its index 8e33510..7bdcc7e 100644 --- a/test/py/tests/vboot/sign-configs-sha256-pss.its +++ b/test/py/tests/vboot/sign-configs-sha256-pss.its @@ -5,7 +5,7 @@ #address-cells = <1>;
images { - kernel@1 { + kernel { data = /incbin/("test-kernel.bin"); type = "kernel_noload"; arch = "sandbox"; @@ -14,28 +14,28 @@ load = <0x4>; entry = <0x8>; kernel-version = <1>; - hash@1 { + hash-1 { algo = "sha256"; }; }; - fdt@1 { + fdt-1 { description = "snow"; data = /incbin/("sandbox-kernel.dtb"); type = "flat_dt"; arch = "sandbox"; compression = "none"; fdt-version = <1>; - hash@1 { + hash-1 { algo = "sha256"; }; }; }; configurations { - default = "conf@1"; - conf@1 { - kernel = "kernel@1"; - fdt = "fdt@1"; - signature@1 { + default = "conf-1"; + conf-1 { + kernel = "kernel"; + fdt = "fdt-1"; + signature { algo = "sha256,rsa2048"; padding = "pss"; key-name-hint = "dev"; diff --git a/test/py/tests/vboot/sign-configs-sha256.its b/test/py/tests/vboot/sign-configs-sha256.its index 1b3432e..f5591aa 100644 --- a/test/py/tests/vboot/sign-configs-sha256.its +++ b/test/py/tests/vboot/sign-configs-sha256.its @@ -5,7 +5,7 @@ #address-cells = <1>;
images { - kernel@1 { + kernel { data = /incbin/("test-kernel.bin"); type = "kernel_noload"; arch = "sandbox"; @@ -14,28 +14,28 @@ load = <0x4>; entry = <0x8>; kernel-version = <1>; - hash@1 { + hash-1 { algo = "sha256"; }; }; - fdt@1 { + fdt-1 { description = "snow"; data = /incbin/("sandbox-kernel.dtb"); type = "flat_dt"; arch = "sandbox"; compression = "none"; fdt-version = <1>; - hash@1 { + hash-1 { algo = "sha256"; }; }; }; configurations { - default = "conf@1"; - conf@1 { - kernel = "kernel@1"; - fdt = "fdt@1"; - signature@1 { + default = "conf-1"; + conf-1 { + kernel = "kernel"; + fdt = "fdt-1"; + signature { algo = "sha256,rsa2048"; key-name-hint = "dev"; sign-images = "fdt", "kernel"; diff --git a/test/py/tests/vboot/sign-images-sha1-pss.its b/test/py/tests/vboot/sign-images-sha1-pss.its index d19c4d7..ded7ae4 100644 --- a/test/py/tests/vboot/sign-images-sha1-pss.its +++ b/test/py/tests/vboot/sign-images-sha1-pss.its @@ -5,7 +5,7 @@ #address-cells = <1>;
images { - kernel@1 { + kernel { data = /incbin/("test-kernel.bin"); type = "kernel_noload"; arch = "sandbox"; @@ -14,20 +14,20 @@ load = <0x4>; entry = <0x8>; kernel-version = <1>; - signature@1 { + signature { algo = "sha1,rsa2048"; padding = "pss"; key-name-hint = "dev"; }; }; - fdt@1 { + fdt-1 { description = "snow"; data = /incbin/("sandbox-kernel.dtb"); type = "flat_dt"; arch = "sandbox"; compression = "none"; fdt-version = <1>; - signature@1 { + signature { algo = "sha1,rsa2048"; padding = "pss"; key-name-hint = "dev"; @@ -35,10 +35,10 @@ }; }; configurations { - default = "conf@1"; - conf@1 { - kernel = "kernel@1"; - fdt = "fdt@1"; + default = "conf-1"; + conf-1 { + kernel = "kernel"; + fdt = "fdt-1"; }; }; }; diff --git a/test/py/tests/vboot/sign-images-sha1.its b/test/py/tests/vboot/sign-images-sha1.its index f69326a..18c759e 100644 --- a/test/py/tests/vboot/sign-images-sha1.its +++ b/test/py/tests/vboot/sign-images-sha1.its @@ -5,7 +5,7 @@ #address-cells = <1>;
images { - kernel@1 { + kernel { data = /incbin/("test-kernel.bin"); type = "kernel_noload"; arch = "sandbox"; @@ -14,29 +14,29 @@ load = <0x4>; entry = <0x8>; kernel-version = <1>; - signature@1 { + signature { algo = "sha1,rsa2048"; key-name-hint = "dev"; }; }; - fdt@1 { + fdt-1 { description = "snow"; data = /incbin/("sandbox-kernel.dtb"); type = "flat_dt"; arch = "sandbox"; compression = "none"; fdt-version = <1>; - signature@1 { + signature { algo = "sha1,rsa2048"; key-name-hint = "dev"; }; }; }; configurations { - default = "conf@1"; - conf@1 { - kernel = "kernel@1"; - fdt = "fdt@1"; + default = "conf-1"; + conf-1 { + kernel = "kernel"; + fdt = "fdt-1"; }; }; }; diff --git a/test/py/tests/vboot/sign-images-sha256-pss.its b/test/py/tests/vboot/sign-images-sha256-pss.its index 43612f8..34850cc 100644 --- a/test/py/tests/vboot/sign-images-sha256-pss.its +++ b/test/py/tests/vboot/sign-images-sha256-pss.its @@ -5,7 +5,7 @@ #address-cells = <1>;
images { - kernel@1 { + kernel { data = /incbin/("test-kernel.bin"); type = "kernel_noload"; arch = "sandbox"; @@ -14,20 +14,20 @@ load = <0x4>; entry = <0x8>; kernel-version = <1>; - signature@1 { + signature { algo = "sha256,rsa2048"; padding = "pss"; key-name-hint = "dev"; }; }; - fdt@1 { + fdt-1 { description = "snow"; data = /incbin/("sandbox-kernel.dtb"); type = "flat_dt"; arch = "sandbox"; compression = "none"; fdt-version = <1>; - signature@1 { + signature { algo = "sha256,rsa2048"; padding = "pss"; key-name-hint = "dev"; @@ -35,10 +35,10 @@ }; }; configurations { - default = "conf@1"; - conf@1 { - kernel = "kernel@1"; - fdt = "fdt@1"; + default = "conf-1"; + conf-1 { + kernel = "kernel"; + fdt = "fdt-1"; }; }; }; diff --git a/test/py/tests/vboot/sign-images-sha256.its b/test/py/tests/vboot/sign-images-sha256.its index e6aa9fc..bb0f8ee 100644 --- a/test/py/tests/vboot/sign-images-sha256.its +++ b/test/py/tests/vboot/sign-images-sha256.its @@ -5,7 +5,7 @@ #address-cells = <1>;
images { - kernel@1 { + kernel { data = /incbin/("test-kernel.bin"); type = "kernel_noload"; arch = "sandbox"; @@ -14,29 +14,29 @@ load = <0x4>; entry = <0x8>; kernel-version = <1>; - signature@1 { + signature { algo = "sha256,rsa2048"; key-name-hint = "dev"; }; }; - fdt@1 { + fdt-1 { description = "snow"; data = /incbin/("sandbox-kernel.dtb"); type = "flat_dt"; arch = "sandbox"; compression = "none"; fdt-version = <1>; - signature@1 { + signature { algo = "sha256,rsa2048"; key-name-hint = "dev"; }; }; }; configurations { - default = "conf@1"; - conf@1 { - kernel = "kernel@1"; - fdt = "fdt@1"; + default = "conf-1"; + conf-1 { + kernel = "kernel"; + fdt = "fdt-1"; }; }; };
Hi Philippe,
Sorry, If my explanation wasn't clear in my previous email but as your series is still not merged you should have squash this commit...
On Tue, 13 Nov 2018 at 21:37, Philippe Reynes philippe.reynes@softathome.com wrote:
Please don't do that next time, you are able to keep the "Reviewed-by" on patch already review or slightly modified. Here, you introduce a new patch in your serie and Simon didn't review it, so you should not add a "Reviewed-by' on this commit !
Also I don't gave you my "Reviewed-by" tag, only made a comment about the its format, so you should not add my tag on all your patches.
Please could you repost a v4 where This patch is squashed with the commit introducing these files. Only the Simon Glass Reviewed-by tags are present.
Thanks for your contribution, Clément
Changelog: v3:
images {
kernel@1 {
hash@1 {
fdt@1 {
hash@1 {
default = "conf@1";
conf@1 {
fdt = "fdt@1";
signature@1 {
default = "conf-1";
conf-1 {
kernel = "kernel";
fdt = "fdt-1";
images {
kernel@1 {
hash@1 {
fdt@1 {
hash@1 {
default = "conf@1";
conf@1 {
fdt = "fdt@1";
signature@1 {
default = "conf-1";
conf-1 {
kernel = "kernel";
fdt = "fdt-1";
images {
kernel@1 {
hash@1 {
fdt@1 {
hash@1 {
default = "conf@1";
conf@1 {
fdt = "fdt@1";
signature@1 {
default = "conf-1";
conf-1 {
kernel = "kernel";
fdt = "fdt-1";
images {
kernel@1 {
hash@1 {
fdt@1 {
hash@1 {
default = "conf@1";
conf@1 {
fdt = "fdt@1";
signature@1 {
default = "conf-1";
conf-1 {
kernel = "kernel";
fdt = "fdt-1";
images {
kernel@1 {
signature@1 {
fdt@1 {
signature@1 {
default = "conf@1";
conf@1 {
fdt = "fdt@1";
default = "conf-1";
conf-1 {
kernel = "kernel";
images {
kernel@1 {
signature@1 {
fdt@1 {
signature@1 {
default = "conf@1";
conf@1 {
fdt = "fdt@1";
default = "conf-1";
conf-1 {
kernel = "kernel";
images {
kernel@1 {
signature@1 {
fdt@1 {
signature@1 {
default = "conf@1";
conf@1 {
fdt = "fdt@1";
default = "conf-1";
conf-1 {
kernel = "kernel";
images {
kernel@1 {
signature@1 {
fdt@1 {
signature@1 {
default = "conf@1";
conf@1 {
fdt = "fdt@1";
default = "conf-1";
conf-1 {
kernel = "kernel";
2.7.4
Hi Clément,
You're right, I've done several mistake on the tag for the serie 3. I shouldn't add a reviewed by simon on the new patch, and sorry, I've understood that you provide a reviewed by on the whole serie.
I've send a v4 with clean tag.
Regards, Philippe
----- Mail original ----- De: "Clément Péron" peron.clem@gmail.com À: "philippe reynes" philippe.reynes@softathome.com Cc: sjg@chromium.org, "joe hershberger" joe.hershberger@ni.com, "michal simek" michal.simek@xilinx.com, "yamada masahiro" yamada.masahiro@socionext.com, "Marek Vasut" marex@denx.de, "Adam Ford" aford173@gmail.com, "woods technical" woods.technical@gmail.com, "Teddy Reed V" teddy.reed@gmail.com, "jun nie" jun.nie@linaro.org, "Kelvin Cheung" keguang.zhang@gmail.com, "peng fan" peng.fan@nxp.com, "andre przywara" andre.przywara@arm.com, "Philipp Tomsich" philipp.tomsich@theobroma-systems.com, "Bin Chen" bin.chen@linaro.org, jsg@jsg.id.au, nomble@palism.com, "paul burton" paul.burton@mips.com, "Alex Kiernan" alex.kiernan@gmail.com, "u-boot" u-boot@lists.denx.de Envoyé: Mercredi 14 Novembre 2018 13:32:32 Objet: Re: [PATCH V3 7/7] test: vboot: clean its file
Hi Philippe,
Changelog: v3:
- sig_node = '/configurations/conf-1/signature'
images {
- kernel@1 {
- kernel {
- hash@1 {
- hash-1 {
- fdt@1 {
- fdt-1 {
- hash@1 {
- hash-1 {
- conf@1 {
- fdt = "fdt@1";
- signature@1 {
- default = "conf-1";
- conf-1 {
- kernel = "kernel";
- fdt = "fdt-1";
- signature {
images {
- kernel@1 {
- kernel {
- hash@1 {
- hash-1 {
- fdt@1 {
- fdt-1 {
- hash@1 {
- hash-1 {
- conf@1 {
- fdt = "fdt@1";
- signature@1 {
- conf-1 {
- fdt = "fdt-1";
- signature {
images {
- kernel@1 {
- kernel {
- hash@1 {
- hash-1 {
- fdt@1 {
- fdt-1 {
- hash@1 {
- hash-1 {
- conf@1 {
- fdt = "fdt@1";
- signature@1 {
- conf-1 {
- fdt = "fdt-1";
- signature {
images {
- kernel@1 {
- kernel {
- hash@1 {
- hash-1 {
- fdt@1 {
- fdt-1 {
- hash@1 {
- hash-1 {
- conf@1 {
- fdt = "fdt@1";
- signature@1 {
- conf-1 {
- fdt = "fdt-1";
- signature {
images {
- kernel@1 {
- kernel {
- signature@1 {
- signature {
- fdt@1 {
- fdt-1 {
- signature@1 {
- signature {
- conf@1 {
- fdt = "fdt@1";
- conf-1 {
- fdt = "fdt-1";
images {
- kernel@1 {
- kernel {
- signature@1 {
- signature {
- fdt@1 {
- fdt-1 {
- signature@1 {
- signature {
- conf@1 {
- fdt = "fdt@1";
- conf-1 {
- fdt = "fdt-1";
images {
- kernel@1 {
- kernel {
- signature@1 {
- signature {
- fdt@1 {
- fdt-1 {
- signature@1 {
- signature {
- conf@1 {
- fdt = "fdt@1";
- conf-1 {
- fdt = "fdt-1";
images {
- kernel@1 {
- kernel {
- signature@1 {
- signature {
- fdt@1 {
- fdt-1 {
- signature@1 {
- signature {
- conf@1 {
- fdt = "fdt@1";
- conf-1 {
- fdt = "fdt-1";
}; }; }; -- 2.7.4
Clément Péron
Philippe REYNES
Philippe Reynes
