[PATCH v1 1/1] fpga: zynqmppl: fix fpga loads command for unencrypted use case
When using the fpga loads command, the driver is passing the AES encryption key address is all cases. However, for the authenticated, but not encrypted use case, there is no AES encryption key, and this value is 0.
When AES encryption is not used on the fpga bitstream, the pmufw assumes that the AES key address is a bitstream size value like what is used by the unsecure fpga load command.
To fix the problem, this patch checks to see if the AES key address is zero. If the AES key address is zero, it means that AES is not being used on the bitstream and the bitstream size should be passed instead. Thus, matching the fpga load functionality.
Signed-off-by: Neal Frager neal.frager@amd.com --- drivers/fpga/zynqmppl.c | 12 +++++++++--- 1 file changed, 9 insertions(+), 3 deletions(-)
diff --git a/drivers/fpga/zynqmppl.c b/drivers/fpga/zynqmppl.c index 6b394869db..718c04b22c 100644 --- a/drivers/fpga/zynqmppl.c +++ b/drivers/fpga/zynqmppl.c @@ -278,10 +278,16 @@ static int zynqmp_loads(xilinx_desc *desc, const void *buf, size_t bsize, buf_lo = lower_32_bits((ulong)buf); buf_hi = upper_32_bits((ulong)buf);
- ret = xilinx_pm_request(PM_FPGA_LOAD, buf_lo, + if ((u32)(uintptr_t)fpga_sec_info->userkey_addr) + ret = xilinx_pm_request(PM_FPGA_LOAD, buf_lo, buf_hi, - (u32)(uintptr_t)fpga_sec_info->userkey_addr, - flag, ret_payload); + (u32)(uintptr_t)fpga_sec_info->userkey_addr, + flag, ret_payload); + else + ret = xilinx_pm_request(PM_FPGA_LOAD, buf_lo, + buf_hi, (u32)bsize, + flag, ret_payload); + if (ret) puts("PL FPGA LOAD fail\n"); else
Acked-by: Ashok Reddy Soma ashok.reddy.soma@amd.com
Thanks, Ashok
-----Original Message----- From: Neal Frager neal.frager@amd.com Sent: Tuesday, February 14, 2023 6:50 PM To: u-boot@lists.denx.de; git-dev (AMD-Xilinx) git-dev@amd.com Cc: Simek, Michal michal.simek@amd.com; Soma, Ashok Reddy ashok.reddy.soma@amd.com; Manne, Nava kishore nava.kishore.manne@amd.com; Erkiaga Elorza, Ibai <ibai.erkiaga- elorza@amd.com>; Frager, Neal neal.frager@amd.com Subject: [PATCH v1 1/1] fpga: zynqmppl: fix fpga loads command for unencrypted use case
- if ((u32)(uintptr_t)fpga_sec_info->userkey_addr)
flag, ret_payload);
userkey_addr,
flag, ret_payload);
- else
buf_hi, (u32)bsize,
flag, ret_payload);
- if (ret) puts("PL FPGA LOAD fail\n"); else
-- 2.17.1
flag, ret_payload);
flag, ret_payload);
- else
buf_hi, (u32)bsize,
flag, ret_payload);
applied. M
Michal Simek
Neal Frager
Soma, Ashok Reddy
