[U-Boot] Pull request for UEFI sub-system for v2019.07-rc1 (2)
The following changes since commit 40a9546c7b6217a78a3a010a0142529a837e46b6:
Merge branch '2019-04-11-ti-master-imports' (2019-04-12 12:22:43 -0400)
https://git.denx.de/u-boot-efi.git tags/efi-2019-07-rc1-2
for you to fetch changes up to 8688b753916bfdde3c2911f14d4489c36e705db7:
efi_selftest: expect boot services data for fdt (2019-04-12 22:09:09 +0200)
Travis CI showed no errors: https://travis-ci.org/xypron2/u-boot/builds/519424329
Primary key fingerprint: 6DC4 F9C7 1F29 A6FA 06B7 6D33 C481 DBBC 2C05 1AC4
---------------------------------------------------------------- Pull request for UEFI sub-system for v2019.07-rc1 (2)
In the aarch64 crash dump information about the loaded EFI images is added.
In README.uefi the development target is for the UEFI subsystem is described as "Embedded Base Boot Requirements (EBBR) Specification" compliance.
Several bug fixes are supplied.
---------------------------------------------------------------- Heinrich Schuchardt (12): efi_loader: assign HII protocols to root node efi_loader: enable HII protocols by default efi_loader: remove stray #define LOG_CATEGORY LOGL_ERR efi_loader: move efi_save_gd() call to board_r.c arm: print information about loaded UEFI images efi_loader: the development target should be the EBBR efi_loader: fix setting PlatformLang efi_loader: update virtual address in efi_mem_carve_out efi_selftest: physical and virtual addresses must match efi_loader: export efi_install_multiple_protocol_interfaces efi_loader: simplify protocol installation efi_selftest: expect boot services data for fdt
Ilias Apalodimas (1): Change FDT memory type from runtime data to boot services data
Patrick Delaunay (1): efi_loader: add protection for block_dev
Patrick Wildt (1): efi: fix memory calculation overflow on 32-bit systems
arch/arm/lib/interrupts_64.c | 13 ++++++ cmd/bootefi.c | 4 +- common/board_r.c | 7 ++++ doc/README.uefi | 12 ++++-- include/efi.h | 2 +- include/efi_loader.h | 3 ++ lib/efi_driver/efi_uclass.c | 3 -- lib/efi_loader/Kconfig | 17 +++++--- lib/efi_loader/efi_boottime.c | 22 +--------- lib/efi_loader/efi_device_path.c | 4 +- lib/efi_loader/efi_memory.c | 2 + lib/efi_loader/efi_root_node.c | 60 ++++++++++++--------------- lib/efi_loader/efi_setup.c | 75 +++++++++++++++++++++++++--------- lib/efi_selftest/efi_selftest_memory.c | 11 +++-- 14 files changed, 140 insertions(+), 95 deletions(-)
