[U-Boot] [PATCH] add support for EMK TOP7000 CPU Module (2nd try)
Add support for EMK TOP7000 CPU Module
Specifics:
1) create subdir board/emk/top7000 and files in it 2) create include/configs/top7000.h 3) update board/emk/common/vpd.c 4) add call to misc_init_r() to arch/avr32/lib/board.c 5) create arch/avr32/include/asm/unaligned.h to fix zlib.c compilation problem 6) update Makefile, MAINTAINERS, MAKEALL
Signed-off-by: Reinhard Meyer info@emk-elektronik.de
--- MAINTAINERS | 6 +- MAKEALL | 3 +- Makefile | 3 + arch/avr32/include/asm/unaligned.h | 1 + arch/avr32/lib/board.c | 5 + board/emk/common/vpd.c | 71 +++++++++++- board/emk/top7000/Makefile | 41 +++++++ board/emk/top7000/config.mk | 3 + board/emk/top7000/top7000.c | 174 +++++++++++++++++++++++++++++ board/emk/top7000/u-boot.lds | 72 ++++++++++++ include/configs/top7000.h | 217 ++++++++++++++++++++++++++++++++++++ 11 files changed, 588 insertions(+), 8 deletions(-) create mode 100644 arch/avr32/include/asm/unaligned.h create mode 100644 board/emk/top7000/Makefile create mode 100644 board/emk/top7000/config.mk create mode 100644 board/emk/top7000/top7000.c create mode 100644 board/emk/top7000/u-boot.lds create mode 100644 include/configs/top7000.h
diff --git a/MAINTAINERS b/MAINTAINERS index 7a13d28..a361be1 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -311,7 +311,7 @@ Andrea "llandre" Marson andrea.marson@dave-tech.it
PPChameleonEVB PPC405EP
-Reinhard Meyer r.meyer@emk-elektronik.de +Reinhard Meyer reinhard.meyer@emk-elektronik.de
TOP860 MPC860T TOP5200 MPC5200 @@ -919,6 +919,10 @@ Julien May julien.may@miromico.ch
HAMMERHEAD AT32AP7000
+Reinhard Meyer reinhard.meyer@emk-elektronik.de + + TOP7000 AT32AP7000 + Haavard Skinnemoen haavard.skinnemoen@atmel.com
ATSTK1000 AT32AP7xxx diff --git a/MAKEALL b/MAKEALL index 2527352..3a80041 100755 --- a/MAKEALL +++ b/MAKEALL @@ -873,7 +873,8 @@ LIST_avr32=" \ atngw100 \ favr-32-ezkit \ hammerhead \ - mimc200 \ + mimc200 \ + top7000 \ "
######################################################################### diff --git a/Makefile b/Makefile index c26e491..e57a4ca 100644 --- a/Makefile +++ b/Makefile @@ -3549,6 +3549,9 @@ hammerhead_config : unconfig mimc200_config : unconfig @$(MKCONFIG) $(@:_config=) avr32 at32ap mimc200 mimc at32ap700x
+top7000_config : unconfig + @$(MKCONFIG) $(@:_config=) avr32 at32ap top7000 emk at32ap700x + #======================================================================== # SH3 (SuperH) #======================================================================== diff --git a/arch/avr32/include/asm/unaligned.h b/arch/avr32/include/asm/unaligned.h new file mode 100644 index 0000000..6cecbbb --- /dev/null +++ b/arch/avr32/include/asm/unaligned.h @@ -0,0 +1 @@ +#include <asm-generic/unaligned.h> diff --git a/arch/avr32/lib/board.c b/arch/avr32/lib/board.c index 917ed6c..6be5ab0 100644 --- a/arch/avr32/lib/board.c +++ b/arch/avr32/lib/board.c @@ -337,6 +337,11 @@ void board_init_r(gd_t *new_gd, ulong dest_addr) jumptable_init(); console_init_r();
+#if defined(CONFIG_MISC_INIT_R) + /* miscellaneous platform dependent initialisations */ + misc_init_r(); +#endif + s = getenv("loadaddr"); if (s) load_addr = simple_strtoul(s, NULL, 16); diff --git a/board/emk/common/vpd.c b/board/emk/common/vpd.c index c2af219..d2c8af2 100644 --- a/board/emk/common/vpd.c +++ b/board/emk/common/vpd.c @@ -1,6 +1,6 @@ /* - * (C) Copyright 2003 - * Reinhard Meyer, EMK Elektronik GmbH, r.meyer@emk-elektronik.de + * (C) Copyright 2003-2010 + * EMK Elektronik GmbH & Co. KG, reinhard.meyer@emk-elektronik.de * * See file CREDITS for list of people who contributed to this * project. @@ -22,10 +22,9 @@ */
#include <common.h> - -/***************************************************************************** - * read "factory" part of EEPROM and set some environment variables - *****************************************************************************/ +#include <command.h> + +/* read "factory" part of EEPROM and set some environment variables */ void read_factory_r (void) { /* read 'factory' part of EEPROM */ @@ -70,6 +69,10 @@ void read_factory_r (void) /* search for our specific entry */ if (!strncmp ((char *) buf, "[RLA/lan/Ethernet] ", 19)) { setenv ("ethaddr", (char *)(buf + 19)); +#if defined(CONFIG_TOP7000) + } else if (!strncmp ((char *) buf, "[RLA/lan2/Ethernet] ", 20)) { + setenv ("eth1addr", (char *)(buf + 20)); +#endif } else if (!strncmp ((char *) buf, "[BOARD/SERIAL] ", 15)) { setenv ("serial#", (char *)(buf + 15)); } else if (!strncmp ((char *) buf, "[BOARD/TYPE] ", 13)) { @@ -77,3 +80,59 @@ void read_factory_r (void) } } } + +#if defined(CONFIG_TOP7000_VPD) && defined(CONFIG_SYS_FACT_ENTRY) +/* + * create VPD entries to EEPROM. + * IEEE assigned MAC adress range to EMK are 00:80:d9:xx:xx:xx + * EMK assigned MAC adress range for TOP7000 is 00:80:d9:0d:hh:ll + * Every TOP7000 can potentially use 2 MAC adresses. + * hh:ll is derived from the board serial number as follows: + * MAC0: hh:ll = (serialnumber-1)*2 + * MAC1: hh:ll = (serialnumber-1)*2+1 + * Serialnumbers are guaranteed to be unique in the range of 1 to + * 32768 max. + */ +int do_vpd (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + uchar buf[512]; + uchar *p; + int i; + u_int addr; + + if (argc != 3) + return 1; + + p = buf+2; + i = simple_strtoul(argv[1], NULL, 10); + if (i<1 || i>32766) + return 1; + + addr=(i-1)*2; + + p+=sprintf((char*)p, + "[RLA/lan/Ethernet] 00:80:d9:0d:%02x:%02x\n", + addr/256, addr%256); + addr++; + p+=sprintf((char*)p, + "[RLA/lan2/Ethernet] 00:80:d9:0d:%02x:%02x\n", + addr/256, addr%256); + p+=sprintf((char*)p, "[BOARD/SERIAL] %05d\n", i); + p+=sprintf((char*)p, "[BOARD/TYPE] %s\n", argv[2]); + + i = p-buf-2; + buf[0]=i; + buf[1]=i>>8; + if (eeprom_write (CONFIG_SYS_I2C_FACT_ADDR, + CONFIG_SYS_FACT_OFFSET, buf, i+2)) { + printf ("cannot write factory configuration\n"); + return 1; + } + + return 0; +} + +U_BOOT_CMD(vpd, 3, 0, do_vpd, + "enter vital product data", + "serialnumber type"); +#endif diff --git a/board/emk/top7000/Makefile b/board/emk/top7000/Makefile new file mode 100644 index 0000000..1fcf08b --- /dev/null +++ b/board/emk/top7000/Makefile @@ -0,0 +1,41 @@ +# +# (C) Copyright 2010 +# EMK Elektronik GmbH & Co. KG, reinhard.meyer@emk-elektronik.de +# +# See file CREDITS for list of people who contributed to this project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA + +include $(TOPDIR)/config.mk + +LIB := $(obj)lib$(BOARD).a + +COBJS := $(BOARD).o ../common/vpd.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/emk/top7000/config.mk b/board/emk/top7000/config.mk new file mode 100644 index 0000000..9a794e5 --- /dev/null +++ b/board/emk/top7000/config.mk @@ -0,0 +1,3 @@ +TEXT_BASE = 0x00000000 +PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections +PLATFORM_LDFLAGS += --gc-sections diff --git a/board/emk/top7000/top7000.c b/board/emk/top7000/top7000.c new file mode 100644 index 0000000..171c7ee --- /dev/null +++ b/board/emk/top7000/top7000.c @@ -0,0 +1,174 @@ +/* + * (C) Copyright 2010 + * EMK Elektronik GmbH & Co. KG, reinhard.meyer@emk-elektronik.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> + +#include <asm/io.h> +#include <asm/sdram.h> +#include <asm/arch/clk.h> +#include <asm/arch/gpio.h> +#include <asm/arch/hmatrix.h> +#include <asm/arch/portmux.h> +#include <netdev.h> +#include <i2c.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const struct sdram_config sdram_config = { + .data_bits = SDRAM_DATA_16BIT, + .row_bits = 13, + .col_bits = 9, + .bank_bits = 2, + .cas = 3, + .twr = 2, + .trc = 7, + .trp = 2, + .trcd = 2, + .tras = 5, + .txsr = 5, + /* 7.81 us */ + .refresh_period = (781 * (SDRAMC_BUS_HZ / 1000)) / 100000, +}; + +int board_early_init_f(void) +{ + /* Enable SDRAM in the EBI mux */ + hmatrix_slave_write(EBI, SFR, HMATRIX_BIT(EBI_SDRAM_ENABLE)); + + /* 16 data, 26 address lines */ + portmux_enable_ebi(16, 26, 0, PORTMUX_DRIVE_HIGH); + portmux_enable_usart1(PORTMUX_DRIVE_MIN); + +#if defined(CONFIG_MACB) + portmux_enable_macb0(PORTMUX_MACB_MII, PORTMUX_DRIVE_HIGH); + portmux_enable_macb1(PORTMUX_MACB_MII, PORTMUX_DRIVE_HIGH); +#endif +#if defined(CONFIG_MMC) + portmux_enable_mmci(0, PORTMUX_MMCI_4BIT, PORTMUX_DRIVE_LOW); +#endif +#if defined(CONFIG_ATMEL_SPI) + portmux_enable_spi0(1 << 0, PORTMUX_DRIVE_LOW); +#endif +#ifdef CONFIG_CMD_I2C + /* set SCL and SDA to open drain gpio */ + portmux_select_gpio(PORTMUX_PORT_A,(1<<SDA_PIN), + PORTMUX_DIR_OUTPUT|PORTMUX_INIT_LOW|PORTMUX_OPEN_DRAIN); + portmux_select_gpio(PORTMUX_PORT_A,(1<<SCL_PIN), + PORTMUX_DIR_OUTPUT|PORTMUX_INIT_LOW|PORTMUX_OPEN_DRAIN); + /* initialize i2c. note: params ignored in SOFT I2C */ + i2c_init(0, 0); +#endif + return 0; +} + +phys_size_t initdram(int board_type) +{ + unsigned long expected_size; + unsigned long actual_size; + void *sdram_base; + + sdram_base = map_physmem(EBI_SDRAM_BASE, EBI_SDRAM_SIZE, MAP_NOCACHE); + + expected_size = sdram_init(sdram_base, &sdram_config); + actual_size = get_ram_size(sdram_base, expected_size); + + unmap_physmem(sdram_base, EBI_SDRAM_SIZE); + + if (expected_size != actual_size) + printf("Warning: Only %lu of %lu MiB SDRAM is working\n", + actual_size >> 20, expected_size >> 20); + + return actual_size; +} + +int board_early_init_r(void) +{ + gd->bd->bi_phy_id[0] = 0x01; + gd->bd->bi_phy_id[1] = 0x03; + return 0; +} + +int misc_init_r(void) +{ + /* read 'factory' part of EEPROM */ + extern void read_factory_r(void); + read_factory_r(); + return 0; +} + +#ifdef CONFIG_CMD_NET +int board_eth_init(bd_t *bi) +{ + int rc; + rc = macb_eth_initialize(0, + (void *)MACB0_BASE, bi->bi_phy_id[0]); + if (rc < 0) + return rc; + rc = macb_eth_initialize(1, + (void *)MACB1_BASE, bi->bi_phy_id[1]); + if (rc < 0) + return 1; + return 2; +} +#endif + +/* SPI chip select control */ +#ifdef CONFIG_ATMEL_SPI +#include <spi.h> + +#define DATAFLASH_CS_PIN GPIO_PIN_PA(3) + +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return bus == 0 && cs == 0; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + gpio_set_value(DATAFLASH_CS_PIN, 0); +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + gpio_set_value(DATAFLASH_CS_PIN, 1); +} +#endif /* CONFIG_ATMEL_SPI */ + +/* I2C access functions */ +#ifdef CONFIG_CMD_I2C + +int iic_read(void) +{ + return pio_get_input_value(GPIO_PIN_PA(SDA_PIN)); +} + +void iic_sda(int bit) +{ + pio_set_output_value(GPIO_PIN_PA(SDA_PIN),bit); +} + +void iic_scl(int bit) +{ + pio_set_output_value(GPIO_PIN_PA(SCL_PIN),bit); +} + +#endif /* CONFIG_CMD_I2C */ diff --git a/board/emk/top7000/u-boot.lds b/board/emk/top7000/u-boot.lds new file mode 100644 index 0000000..ffa119b --- /dev/null +++ b/board/emk/top7000/u-boot.lds @@ -0,0 +1,72 @@ +/* + * (C) Copyright 2010 + * EMK Elektronik GmbH & Co. KG, reinhard.meyer@emk-elektronik.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +OUTPUT_FORMAT("elf32-avr32", "elf32-avr32", "elf32-avr32") +OUTPUT_ARCH(avr32) +ENTRY(_start) + +SECTIONS +{ + . = 0; + _text = .; + .text : { + *(.exception.text) + *(.text) + *(.text.*) + } + _etext = .; + + .rodata : { + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + } + + . = ALIGN(8); + _data = .; + .data : { + *(.data) + *(.data.*) + } + + . = ALIGN(4); + __u_boot_cmd_start = .; + .u_boot_cmd : { + KEEP(*(.u_boot_cmd)) + } + __u_boot_cmd_end = .; + + . = ALIGN(4); + _got = .; + .got : { + *(.got) + } + _egot = .; + + . = ALIGN(8); + _edata = .; + + .bss : { + *(.bss) + *(.bss.*) + } + . = ALIGN(8); + _end = .; +} diff --git a/include/configs/top7000.h b/include/configs/top7000.h new file mode 100644 index 0000000..e509611 --- /dev/null +++ b/include/configs/top7000.h @@ -0,0 +1,217 @@ +/* + * (C) Copyright 2010 + * EMK Elektronik GmbH & Co. KG, reinhard.meyer@emk-elektronik.de + * + * Configuration settings for the TOP7000 CPU Module + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * TOP7000 features/differences to ATNGW100: + * + * parallel FLASH upto 64MB (typically S29GL128/256/512Pxxxx) + * no serial FLASH (SPI not used) + * optional micro SD card for root and user file systems + * VPD and environment in I2C EEPROM + * kernel as image in parallel FLASH + * + * parallel FLASH partitioning: + * 00000000-00020000 128k U-Boot + * 00020000-00200000 2M-128k kernel + * 00200000-end root file system + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/memory-map.h> + +#define CONFIG_AVR32 1 +#define CONFIG_AT32AP 1 +#define CONFIG_AT32AP7000 1 +#define CONFIG_TOP7000 1 +#define CONFIG_SYS_HZ 1000 + +/* + * Set up the PLL to run at 140 MHz, the CPU to run at the PLL + * frequency, the HSB and PBB busses to run at 1/2 the PLL frequency + * and the PBA bus to run at 1/4 the PLL frequency. + */ +#define CONFIG_PLL 1 +#define CONFIG_SYS_POWER_MANAGER 1 +#define CONFIG_SYS_OSC0_HZ 20000000 +#define CONFIG_SYS_PLL0_DIV 1 +#define CONFIG_SYS_PLL0_MUL 7 +#define CONFIG_SYS_PLL0_SUPPRESS_CYCLES 16 +#define CONFIG_SYS_CLKDIV_CPU 0 +#define CONFIG_SYS_CLKDIV_HSB 1 +#define CONFIG_SYS_CLKDIV_PBA 2 +#define CONFIG_SYS_CLKDIV_PBB 1 + +/* + * The PLLOPT register controls the PLL like this: + * icp = PLLOPT<2> + * ivco = PLLOPT<1:0> + * + * We want icp=1 (default) and ivco=0 (80-160 MHz) or ivco=2 (150-240MHz). + */ +#define CONFIG_SYS_PLL0_OPT 0x04 + +#define CONFIG_USART1 1 + +/* User serviceable stuff */ +#define CONFIG_DOS_PARTITION 1 + +#define CONFIG_CMDLINE_TAG 1 +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +#define CONFIG_STACKSIZE (2048) + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTARGS "console=ttyS0 root=/dev/mtdblock2 rootfstype=jffs2" +#define CONFIG_BOOTCOMMAND "bootm 0xa0020000" + +/* + * Only interrupt autoboot if <space> is pressed. Otherwise, garbage + * data on the serial line may interrupt the boot sequence. + */ +#define CONFIG_BOOTDELAY 1 +#define CONFIG_AUTOBOOT 1 +#define CONFIG_AUTOBOOT_KEYED 1 +#define CONFIG_AUTOBOOT_PROMPT "Press SPACE to abort autoboot in %d seconds\n", bootdelay +#define CONFIG_AUTOBOOT_DELAY_STR "d" +#define CONFIG_AUTOBOOT_STOP_STR " " + +#define CONFIG_NET_MULTI 1 + +/* + * BOOTP/DHCP options + */ +#define CONFIG_BOOTP_SUBNETMASK +#define CONFIG_BOOTP_GATEWAY + +#define CONFIG_DOS_PARTITION 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_MMC +#define CONFIG_CMD_I2C + +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_SETGETDCR +#undef CONFIG_CMD_SOURCE +#undef CONFIG_CMD_XIMG + +#define CONFIG_ATMEL_USART 1 +#define CONFIG_MACB 1 +#define CONFIG_PORTMUX_PIO 1 +#define CONFIG_SYS_NR_PIOS 5 +#define CONFIG_SYS_HSDRAMC 1 +#define CONFIG_MMC 1 +#define CONFIG_ATMEL_MCI 1 + +#define CONFIG_SYS_DCACHE_LINESZ 32 +#define CONFIG_SYS_ICACHE_LINESZ 32 + +#define CONFIG_NR_DRAM_BANKS 1 + +#define CONFIG_SYS_FLASH_CFI 1 +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_EMPTY_INFO 1 + +/* I2C configuration */ +#define CONFIG_SOFT_I2C 1 +#define CONFIG_SYS_I2C_SPEED 400000 +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define SDA_PIN 6 +#define SCL_PIN 7 +#define I2C_SOFT_DECLARATIONS int iic_read(void);\ + void iic_sda(int);\ + void iic_scl(int); +#define I2C_ACTIVE +#define I2C_TRISTATE +#define I2C_READ iic_read() +#define I2C_SDA(bit) iic_sda(bit) +#define I2C_SCL(bit) iic_scl(bit) +#define I2C_DELAY udelay(3) + +/* EEPROM configuration */ +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 70 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +#define CONFIG_SYS_EEPROM_SIZE 0x2000 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 +#define CONFIG_MISC_INIT_R + +/* Environment settings */ +#define CONFIG_ENV_IS_IN_EEPROM 1 +#define CONFIG_ENV_OFFSET 0x1000 +#define CONFIG_ENV_SIZE 0x0700 +#define CONFIG_ENV_OVERWRITE + +/* VPD settings */ +#define CONFIG_SYS_I2C_FACT_ADDR 0x57 +#define CONFIG_SYS_FACT_OFFSET 0x1800 +#define CONFIG_SYS_FACT_SIZE 0x0800 +/* define the next only if you want to allow users to enter VPD data */ +#define CONFIG_SYS_FACT_ENTRY 1 + +/* MAX 64MB S29GL512Pxxx, 512 sectors */ +#define CONFIG_SYS_FLASH_BASE 0x00000000 +#define CONFIG_SYS_FLASH_SIZE 0x4000000 +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 512 + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE + +#define CONFIG_SYS_INTRAM_BASE INTERNAL_SRAM_BASE +#define CONFIG_SYS_INTRAM_SIZE INTERNAL_SRAM_SIZE +#define CONFIG_SYS_SDRAM_BASE EBI_SDRAM_BASE + +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INTRAM_BASE + CONFIG_SYS_INTRAM_SIZE) + +#define CONFIG_SYS_MALLOC_LEN (256*1024) +#define CONFIG_SYS_DMA_ALLOC_LEN (16384) + +/* Allow 4MB for the kernel run-time image */ +#define CONFIG_SYS_LOAD_ADDR (EBI_SDRAM_BASE + 0x00400000) +#define CONFIG_SYS_BOOTPARAMS_LEN (16 * 1024) + +/* Other configuration settings that shouldn't have to change all that often */ +#define CONFIG_SYS_PROMPT "top7000> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP 1 + +#define CONFIG_SYS_MEMTEST_START EBI_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x1f00000) + +#define CONFIG_SYS_BAUDRATE_TABLE { 115200, 38400, 19200, 9600, 2400 } + +#endif /* __CONFIG_H */
Reinhard Meyer (-VC)
