[PATCH v2] riscv: sifive: Rename fu540 board to unleashed
In preparation to add SiFive Unmatched board support, let's rename the existing fu540 board to unleashed.
Signed-off-by: Bin Meng bmeng.cn@gmail.com
Changes in v2: - fix a typo in the commit message - rename fu540.rst
arch/riscv/Kconfig | 6 +++--- arch/riscv/dts/Makefile | 2 +- board/sifive/{fu540 => unleashed}/Kconfig | 6 +++--- board/sifive/{fu540 => unleashed}/MAINTAINERS | 10 +++++----- board/sifive/{fu540 => unleashed}/Makefile | 2 +- board/sifive/{fu540 => unleashed}/spl.c | 0 board/sifive/{fu540/fu540.c => unleashed/unleashed.c} | 0 common/spl/Kconfig | 5 +++-- ...five_fu540_defconfig => sifive_unleashed_defconfig} | 2 +- doc/board/sifive/index.rst | 2 +- doc/board/sifive/{fu540.rst => unleashed.rst} | 0 drivers/ram/sifive/Kconfig | 2 +- drivers/reset/Kconfig | 2 +- include/configs/{sifive-fu540.h => sifive-unleashed.h} | 0 14 files changed, 20 insertions(+), 19 deletions(-) rename board/sifive/{fu540 => unleashed}/Kconfig (91%) rename board/sifive/{fu540 => unleashed}/MAINTAINERS (50%) rename board/sifive/{fu540 => unleashed}/Makefile (87%) rename board/sifive/{fu540 => unleashed}/spl.c (100%) rename board/sifive/{fu540/fu540.c => unleashed/unleashed.c} (100%) rename configs/{sifive_fu540_defconfig => sifive_unleashed_defconfig} (95%) rename doc/board/sifive/{fu540.rst => unleashed.rst} (100%) rename include/configs/{sifive-fu540.h => sifive-unleashed.h} (100%)
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 55eaee2da6..e8494c2a49 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -17,8 +17,8 @@ config TARGET_MICROCHIP_ICICLE config TARGET_QEMU_VIRT bool "Support QEMU Virt Board"
-config TARGET_SIFIVE_FU540 - bool "Support SiFive FU540 Board" +config TARGET_SIFIVE_UNLEASHED + bool "Support SiFive Unleashed Board"
config TARGET_SIPEED_MAIX bool "Support Sipeed Maix Board" @@ -55,7 +55,7 @@ config SPL_SYS_DCACHE_OFF source "board/AndesTech/ax25-ae350/Kconfig" source "board/emulation/qemu-riscv/Kconfig" source "board/microchip/mpfs_icicle/Kconfig" -source "board/sifive/fu540/Kconfig" +source "board/sifive/unleashed/Kconfig" source "board/sipeed/maix/Kconfig"
# platform-specific options below diff --git a/arch/riscv/dts/Makefile b/arch/riscv/dts/Makefile index 01331b0aa1..8138d89d84 100644 --- a/arch/riscv/dts/Makefile +++ b/arch/riscv/dts/Makefile @@ -1,7 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+
dtb-$(CONFIG_TARGET_AX25_AE350) += ae350_32.dtb ae350_64.dtb -dtb-$(CONFIG_TARGET_SIFIVE_FU540) += hifive-unleashed-a00.dtb +dtb-$(CONFIG_TARGET_SIFIVE_UNLEASHED) += hifive-unleashed-a00.dtb dtb-$(CONFIG_TARGET_SIPEED_MAIX) += k210-maix-bit.dtb dtb-$(CONFIG_TARGET_MICROCHIP_ICICLE) += microchip-mpfs-icicle-kit.dtb
diff --git a/board/sifive/fu540/Kconfig b/board/sifive/unleashed/Kconfig similarity index 91% rename from board/sifive/fu540/Kconfig rename to board/sifive/unleashed/Kconfig index 64fdbd44b4..dbffd59c98 100644 --- a/board/sifive/fu540/Kconfig +++ b/board/sifive/unleashed/Kconfig @@ -1,7 +1,7 @@ -if TARGET_SIFIVE_FU540 +if TARGET_SIFIVE_UNLEASHED
config SYS_BOARD - default "fu540" + default "unleashed"
config SYS_VENDOR default "sifive" @@ -10,7 +10,7 @@ config SYS_CPU default "fu540"
config SYS_CONFIG_NAME - default "sifive-fu540" + default "sifive-unleashed"
config SYS_TEXT_BASE default 0x80200000 if SPL diff --git a/board/sifive/fu540/MAINTAINERS b/board/sifive/unleashed/MAINTAINERS similarity index 50% rename from board/sifive/fu540/MAINTAINERS rename to board/sifive/unleashed/MAINTAINERS index 27620727bd..2ea00749cb 100644 --- a/board/sifive/fu540/MAINTAINERS +++ b/board/sifive/unleashed/MAINTAINERS @@ -1,10 +1,10 @@ -SiFive FU540 BOARD +SiFive HiFive Unleashed BOARD M: Paul Walmsley paul.walmsley@sifive.com M: Palmer Dabbelt palmer@dabbelt.com M: Anup Patel anup.patel@wdc.com M: Atish Patra atish.patra@wdc.com S: Maintained -F: board/sifive/fu540/ -F: doc/board/sifive/fu540.rst -F: include/configs/sifive-fu540.h -F: configs/sifive_fu540_defconfig +F: board/sifive/unleashed/ +F: doc/board/sifive/unleashed.rst +F: include/configs/sifive-unleashed.h +F: configs/sifive_unleashed_defconfig diff --git a/board/sifive/fu540/Makefile b/board/sifive/unleashed/Makefile similarity index 87% rename from board/sifive/fu540/Makefile rename to board/sifive/unleashed/Makefile index b05e2f5807..5821679dd9 100644 --- a/board/sifive/fu540/Makefile +++ b/board/sifive/unleashed/Makefile @@ -2,7 +2,7 @@ # # Copyright (c) 2019 Western Digital Corporation or its affiliates.
-obj-y += fu540.o +obj-y += unleashed.o
ifdef CONFIG_SPL_BUILD obj-y += spl.o diff --git a/board/sifive/fu540/spl.c b/board/sifive/unleashed/spl.c similarity index 100% rename from board/sifive/fu540/spl.c rename to board/sifive/unleashed/spl.c diff --git a/board/sifive/fu540/fu540.c b/board/sifive/unleashed/unleashed.c similarity index 100% rename from board/sifive/fu540/fu540.c rename to board/sifive/unleashed/unleashed.c diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 774541c02b..6e6a790dd6 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -317,7 +317,8 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR ARCH_MX6 || ARCH_MX7 || \ ARCH_ROCKCHIP || ARCH_MVEBU || ARCH_SOCFPGA || \ ARCH_AT91 || ARCH_ZYNQ || ARCH_KEYSTONE || OMAP34XX || \ - OMAP44XX || OMAP54XX || AM33XX || AM43XX || TARGET_SIFIVE_FU540 + OMAP44XX || OMAP54XX || AM33XX || AM43XX || \ + TARGET_SIFIVE_UNLEASHED help Use sector number for specifying U-Boot location on MMC/SD in raw mode. @@ -334,7 +335,7 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR default 0x300 if ARCH_ZYNQ || ARCH_KEYSTONE || OMAP34XX || OMAP44XX || \ OMAP54XX || AM33XX || AM43XX || ARCH_K3 default 0x4000 if ARCH_ROCKCHIP - default 0x822 if TARGET_SIFIVE_FU540 + default 0x822 if TARGET_SIFIVE_UNLEASHED help Address on the MMC to load U-Boot from, when the MMC is being used in raw mode. Units: MMC sectors (1 sector = 512 bytes). diff --git a/configs/sifive_fu540_defconfig b/configs/sifive_unleashed_defconfig similarity index 95% rename from configs/sifive_fu540_defconfig rename to configs/sifive_unleashed_defconfig index cabd3b1778..62416a7c1d 100644 --- a/configs/sifive_fu540_defconfig +++ b/configs/sifive_unleashed_defconfig @@ -8,7 +8,7 @@ CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="hifive-unleashed-a00" -CONFIG_TARGET_SIFIVE_FU540=y +CONFIG_TARGET_SIFIVE_UNLEASHED=y CONFIG_ARCH_RV64I=y CONFIG_RISCV_SMODE=y CONFIG_DISTRO_DEFAULTS=y diff --git a/doc/board/sifive/index.rst b/doc/board/sifive/index.rst index ad614c9bf2..ed7eacfb54 100644 --- a/doc/board/sifive/index.rst +++ b/doc/board/sifive/index.rst @@ -6,4 +6,4 @@ SiFive .. toctree:: :maxdepth: 2
- fu540 + unleashed diff --git a/doc/board/sifive/fu540.rst b/doc/board/sifive/unleashed.rst similarity index 100% rename from doc/board/sifive/fu540.rst rename to doc/board/sifive/unleashed.rst diff --git a/drivers/ram/sifive/Kconfig b/drivers/ram/sifive/Kconfig index 6aca22ab2a..08de692e02 100644 --- a/drivers/ram/sifive/Kconfig +++ b/drivers/ram/sifive/Kconfig @@ -8,6 +8,6 @@ config RAM_SIFIVE config SIFIVE_FU540_DDR bool "SiFive FU540 DDR driver" depends on RAM_SIFIVE - default y if TARGET_SIFIVE_FU540 + default y if TARGET_SIFIVE_UNLEASHED help This enables DDR support for the platforms based on SiFive FU540 SoC. diff --git a/drivers/reset/Kconfig b/drivers/reset/Kconfig index f5b3f8826f..019565f979 100644 --- a/drivers/reset/Kconfig +++ b/drivers/reset/Kconfig @@ -166,7 +166,7 @@ config RESET_IPQ419
config RESET_SIFIVE bool "Reset Driver for SiFive SoC's" - depends on DM_RESET && CLK_SIFIVE_FU540_PRCI && TARGET_SIFIVE_FU540 + depends on DM_RESET && CLK_SIFIVE_FU540_PRCI && TARGET_SIFIVE_UNLEASHED default y help PRCI module within SiFive SoC's provides mechanism to reset diff --git a/include/configs/sifive-fu540.h b/include/configs/sifive-unleashed.h similarity index 100% rename from include/configs/sifive-fu540.h rename to include/configs/sifive-unleashed.h
Changes in v2:
- rename fu540.rst
- bool "Support SiFive Unleashed Board"
config SYS_BOARD
- default "fu540"
- default "unleashed"
- default "sifive-unleashed"
help Use sector number for specifying U-Boot location on MMC/SD in raw mode.TARGET_SIFIVE_UNLEASHED
- default 0x822 if TARGET_SIFIVE_UNLEASHED help Address on the MMC to load U-Boot from, when the MMC is being used in raw mode. Units: MMC sectors (1 sector = 512 bytes).
- fu540
- unleashed
- default y if TARGET_SIFIVE_UNLEASHED help This enables DDR support for the platforms based on SiFive FU540 SoC.
- depends on DM_RESET && CLK_SIFIVE_FU540_PRCI && TARGET_SIFIVE_UNLEASHED default y help PRCI module within SiFive SoC's provides mechanism to reset
diff --git a/include/configs/sifive-fu540.h b/include/configs/sifive-unleashed.h similarity index 100% rename from include/configs/sifive-fu540.h rename to include/configs/sifive-unleashed.h -- 2.17.1
Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com
Bin Meng
Leo Liang
