[U-Boot] [PATCH 01/31] powerpc: 8xx serial: add configurable SMC Rx buffer len
This patch adds the configuration option CONFIG_SYS_SMC_RXBUFLEN. With this option it is possible to allow the receive buffer for the SMC on 8xx to be greater then 1. In case CONFIG_SYS_SMC_RXBUFLEN == 1 or it is not defined this driver works as the old version.
Signed-off-by: Heiko Schocher hs@denx.de --- cpu/mpc8xx/serial.c | 102 +++++++++++++++++++++++++++++----------------- include/configs/mgsuvd.h | 1 + 2 files changed, 65 insertions(+), 38 deletions(-)
diff --git a/cpu/mpc8xx/serial.c b/cpu/mpc8xx/serial.c index bd90dcd..cb8c2e5 100644 --- a/cpu/mpc8xx/serial.c +++ b/cpu/mpc8xx/serial.c @@ -65,6 +65,18 @@ DECLARE_GLOBAL_DATA_PTR;
#endif /* CONFIG_8xx_CONS_SCCx */
+typedef volatile struct serialbuffer { + cbd_t rxbd; /* Rx BD */ + cbd_t txbd; /* Tx BD */ +#ifdef CONFIG_SYS_SMC_RXBUFLEN + uint rxindex; /* index for next character to read */ + volatile uchar rxbuf[CONFIG_SYS_SMC_RXBUFLEN];/* rx buffers */ +#else + volatile uchar rxbuf[1]; /* rx buffers */ +#endif + volatile uchar txbuf; /* tx buffers */ +} serialbuffer_t; + static void serial_setdivisor(volatile cpm8xx_t *cp) { int divisor=(gd->cpu_clk + 8*gd->baudrate)/16/gd->baudrate; @@ -113,12 +125,12 @@ static int smc_init (void) volatile immap_t *im = (immap_t *)CONFIG_SYS_IMMR; volatile smc_t *sp; volatile smc_uart_t *up; - volatile cbd_t *tbdf, *rbdf; volatile cpm8xx_t *cp = &(im->im_cpm); #if (!defined(CONFIG_8xx_CONS_SMC1)) && (defined(CONFIG_MPC823) || defined(CONFIG_MPC850)) volatile iop8xx_t *ip = (iop8xx_t *)&(im->im_ioport); #endif uint dpaddr; + volatile serialbuffer_t *rtx;
/* initialize pointers to SMC */
@@ -194,23 +206,26 @@ static int smc_init (void) */
#ifdef CONFIG_SYS_ALLOC_DPRAM - dpaddr = dpram_alloc_align (sizeof(cbd_t)*2 + 2, 8) ; + /* allocate + * size of struct serialbuffer with bd rx/tx, buffer rx/tx and rx index + */ + dpaddr = dpram_alloc_align((sizeof(serialbuffer_t)), 8); #else dpaddr = CPM_SERIAL_BASE ; #endif
+ rtx = (serialbuffer_t *)&cp->cp_dpmem[dpaddr]; /* Allocate space for two buffer descriptors in the DP ram. * For now, this address seems OK, but it may have to * change with newer versions of the firmware. * damm: allocating space after the two buffers for rx/tx data */
- rbdf = (cbd_t *)&cp->cp_dpmem[dpaddr]; - rbdf->cbd_bufaddr = (uint) (rbdf+2); - rbdf->cbd_sc = 0; - tbdf = rbdf + 1; - tbdf->cbd_bufaddr = ((uint) (rbdf+2)) + 1; - tbdf->cbd_sc = 0; + rtx->rxbd.cbd_bufaddr = (uint) &rtx->rxbuf; + rtx->rxbd.cbd_sc = 0; + + rtx->txbd.cbd_bufaddr = (uint) &rtx->txbuf; + rtx->txbd.cbd_sc = 0;
/* Set up the uart parameters in the parameter ram. */ @@ -256,13 +271,21 @@ static int smc_init (void)
/* Make the first buffer the only buffer. */ - tbdf->cbd_sc |= BD_SC_WRAP; - rbdf->cbd_sc |= BD_SC_EMPTY | BD_SC_WRAP; + rtx->txbd.cbd_sc |= BD_SC_WRAP; + rtx->rxbd.cbd_sc |= BD_SC_EMPTY | BD_SC_WRAP;
+#ifdef CONFIG_SYS_SMC_RXBUFLEN + /* multi-character receive. + */ + up->smc_mrblr = CONFIG_SYS_SMC_RXBUFLEN; + up->smc_maxidl = 10; + rtx->rxindex = 0; +#else /* Single character receive. */ up->smc_mrblr = 1; up->smc_maxidl = 0; +#endif
/* Initialize Tx/Rx parameters. */ @@ -285,11 +308,10 @@ static int smc_init (void) static void smc_putc(const char c) { - volatile cbd_t *tbdf; - volatile char *buf; volatile smc_uart_t *up; volatile immap_t *im = (immap_t *)CONFIG_SYS_IMMR; volatile cpm8xx_t *cpmp = &(im->im_cpm); + volatile serialbuffer_t *rtx;
#ifdef CONFIG_MODEM_SUPPORT if (gd->be_quiet) @@ -300,23 +322,18 @@ smc_putc(const char c) smc_putc ('\r');
up = (smc_uart_t *)&cpmp->cp_dparam[PROFF_SMC]; -#ifdef CONFIG_SYS_SMC_UCODE_PATCH - up = (smc_uart_t *) &cpmp->cp_dpmem[up->smc_rpbase]; -#endif + #ifdef CONFIG_SYS_SMC_UCODE_PATCH + up = (smc_uart_t *)&cpmp->cp_dpmem[up->smc_rpbase]; + #endif
- tbdf = (cbd_t *)&cpmp->cp_dpmem[up->smc_tbase]; + rtx = (serialbuffer_t *)&cpmp->cp_dpmem[up->smc_rbase];
- /* Wait for last character to go. - */ - - buf = (char *)tbdf->cbd_bufaddr; - - *buf = c; - tbdf->cbd_datlen = 1; - tbdf->cbd_sc |= BD_SC_READY; + rtx->txbuf = c; + rtx->txbd.cbd_datlen = 1; + rtx->txbd.cbd_sc |= BD_SC_READY; __asm__("eieio");
- while (tbdf->cbd_sc & BD_SC_READY) { + while (rtx->txbd.cbd_sc & BD_SC_READY) { WATCHDOG_RESET (); __asm__("eieio"); } @@ -333,49 +350,58 @@ smc_puts (const char *s) static int smc_getc(void) { - volatile cbd_t *rbdf; - volatile unsigned char *buf; volatile smc_uart_t *up; volatile immap_t *im = (immap_t *)CONFIG_SYS_IMMR; volatile cpm8xx_t *cpmp = &(im->im_cpm); - unsigned char c; + volatile serialbuffer_t *rtx; + unsigned char c;
up = (smc_uart_t *)&cpmp->cp_dparam[PROFF_SMC]; #ifdef CONFIG_SYS_SMC_UCODE_PATCH up = (smc_uart_t *) &cpmp->cp_dpmem[up->smc_rpbase]; #endif - - rbdf = (cbd_t *)&cpmp->cp_dpmem[up->smc_rbase]; + rtx = (serialbuffer_t *)&cpmp->cp_dpmem[up->smc_rbase];
/* Wait for character to show up. */ - buf = (unsigned char *)rbdf->cbd_bufaddr; - - while (rbdf->cbd_sc & BD_SC_EMPTY) + while (rtx->rxbd.cbd_sc & BD_SC_EMPTY) WATCHDOG_RESET ();
- c = *buf; - rbdf->cbd_sc |= BD_SC_EMPTY; +#ifdef CONFIG_SYS_SMC_RXBUFLEN + /* the characters are read one by one, + * use the rxindex to know the next char to deliver + */ + c = *(unsigned char *) (rtx->rxbd.cbd_bufaddr+rtx->rxindex); + rtx->rxindex++;
+ /* check if all char are readout, then make prepare for next receive */ + if (rtx->rxindex >= rtx->rxbd.cbd_datlen) { + rtx->rxindex = 0; + rtx->rxbd.cbd_sc |= BD_SC_EMPTY; + } +#else + c = *(unsigned char *) (rtx->rxbd.cbd_bufaddr); + rtx->rxbd.cbd_sc |= BD_SC_EMPTY; +#endif return(c); }
static int smc_tstc(void) { - volatile cbd_t *rbdf; volatile smc_uart_t *up; volatile immap_t *im = (immap_t *)CONFIG_SYS_IMMR; volatile cpm8xx_t *cpmp = &(im->im_cpm); + volatile serialbuffer_t *rtx;
- return(!(rbdf->cbd_sc & BD_SC_EMPTY)); + return !(rtx->rxbd.cbd_sc & BD_SC_EMPTY); }
struct serial_device serial_smc_device = diff --git a/include/configs/mgsuvd.h b/include/configs/mgsuvd.h index f53b6d3..8f82751 100644 --- a/include/configs/mgsuvd.h +++ b/include/configs/mgsuvd.h @@ -44,6 +44,7 @@ #define CONFIG_SYS_SMC_UCODE_PATCH 1 /* Relocate SMC1 */ #define CONFIG_SYS_SMC_DPMEM_OFFSET 0x1fc0 #define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ +#define CONFIG_SYS_SMC_RXBUFLEN 16
#define CONFIG_SYS_CPM_BOOTCOUNT_ADDR 0x1eb0 /* In case of SMC relocation, the * default value is not working */
Heiko Schocher
