[U-Boot] Saving u-boot environment on LS1046ardb QSPI bricks flash memory
Hi there,
I am currently working with a LS1046ardb development board from NXP/Layerscape. Using their provided firmware image from the primary QSPI memory bank, I have tried to flash my own compiled u-boot (using the ls1046ardb_qspi_defconfig file) onto the alternate memory bank. I have also flashed a Reset Configuration Word (RCW) which was provided by NXP.
This process is successful and the alternate bank boots into u-boot. However, I discovered that after simply executing a "saveenv" command and then rebooting again into the alternate bank, the alternate flash memory seems to be "bricked". I can no longer boot into the alternate bank and instead, the board will boot into the default bank.
I am wondering if this issue and has been noticed already by someone or if there is something I am not doing correctly.
Is their a specific denx RCW that I should use instead, rather than the one provided by NXP?
Any help would be greatly appreciated!
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Matthew Ratson Sent: Friday, September 13, 2019 12:55 AM To: u-boot@lists.denx.de Subject: [EXT] [U-Boot] Saving u-boot environment on LS1046ardb QSPI bricks flash memory
Caution: EXT Email
Hi there,
Hi Matthew,
This driver is broken in upstream and it is work in progress to fix and update in upstream. You can still fetch this from github as few other people have also reported the same. On github repo there are 2 version of driver.
One with old xfer method and one with new spi-mem version. I am debugging the spi-mem version as this is the recommended version by maintainers . LS1046 is working via both methods. There are some debug prints in spi-mem version.
https://github.com/erashish007/u-boot-spi-mem/ br: spi-mem-port https://github.com/erashish007/u-boot-spi-mem/ br: xfer_wrking
Regards Ashish
U-Boot mailing list U-Boot@lists.denx.de https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.d enx.de%2Flistinfo%2Fu- boot&data=02%7C01%7CAshish.Kumar%40nxp.com%7C8e1f67af6f3948 9afc0e08d737bbfd91%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C1%7C 637039152865550331&sdata=C6DTwmG7cZXPey9J%2BTNUcqIr937vWhu 1gE6Tq2tGr0g%3D&reserved=0
Hi Ashish,
Thank you very much for your quick response and the information you provided, greatly appreciated.
Do you possibly know what is the latest Denx u-boot release where this issue does not exist, and QSPI builds are working?
Thanks, Matthew
Caution: EXT Email
Hi there,
also
if
one
provided by NXP?
Hi Matthew,
Regards Ashish
Ashish Kumar
Matthew Ratson
