[U-Boot-Users] [PATCH 0/2] TQM834x: N-Flash support and DHCP
the following 2 patches introduce support for NOR-Flash with sector size 128 KiB (256 KiB at 2x16 Bit) and enable DHCP as on other TQ modules.
Regards, Jens
Signed-off-by: Jens Gehrlein sew_s@tqs.de ---
include/configs/TQM834x.h | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index 8ef3f09..0f73400 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -181,7 +181,7 @@ extern int tqm834x_num_flash_banks; #define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET
#define CFG_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ -#define CFG_MALLOC_LEN (128 * 1024) /* Reserved for malloc */ +#define CFG_MALLOC_LEN (256 * 1024) /* Reserve 256 kB for malloc */
/* * Serial Port @@ -302,7 +302,7 @@ extern int tqm834x_num_flash_banks; #ifndef CFG_RAMBOOT #define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_ADDR (CFG_MONITOR_BASE + 0x40000) - #define CFG_ENV_SECT_SIZE 0x20000 /* 256K(one sector) for env */ + #define CFG_ENV_SECT_SIZE 0x40000 /* 256K(one sector) for env */ #define CFG_ENV_SIZE 0x2000 #else #define CFG_NO_FLASH 1 /* Flash is not usable now */ @@ -557,7 +557,7 @@ extern int tqm834x_num_flash_banks; #define MTDIDS_DEFAULT "nor0=TQM834x-0"
/* default mtd partition table */ -#define MTDPARTS_DEFAULT "mtdparts=TQM834x-0:256k(u-boot),128k(env),"\ +#define MTDPARTS_DEFAULT "mtdparts=TQM834x-0:256k(u-boot),256k(env),"\ "1m(kernel),2m(initrd),"\ "-(user);"\
include/configs/TQM834x.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index 0f73400..7373d7b 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -335,6 +335,7 @@ extern int tqm834x_num_flash_banks; #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII #define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP
#if defined(CONFIG_PCI) #define CONFIG_CMD_PCI
Jens Gehrlein
