[U-Boot] [PATCH] fdt: avoid bad MAKEALL status
Current versions of dtc always print a message like
DTC: dts->dtb on file "dt.dtb.tmp"
which cannot even be suppressed with "-qqq". To avoid incorrect MAKEALL status, we manually filter out this message. This is a bit complicated, as we have to make sure to set a correct return code.
Also, get rid of the temp file: dtc accepts "-" for stdin.
Signed-off-by: Wolfgang Denk wd@denx.de Cc: Simon Glass sjg@chromium.org --- dts/Makefile | 10 +++++++--- 1 files changed, 7 insertions(+), 3 deletions(-)
diff --git a/dts/Makefile b/dts/Makefile index 8b13b23..914e479 100644 --- a/dts/Makefile +++ b/dts/Makefile @@ -46,9 +46,13 @@ all: $(obj).depend $(LIB) DT_BIN := $(obj)dt.dtb
$(DT_BIN): $(TOPDIR)/board/$(VENDOR)/dts/$(DEVICE_TREE).dts - cat $< | $(CPP) -P $(DTS_CPPFLAGS) - >$@.tmp - $(DTC) -R 4 -p 0x1000 -O dtb -o ${DT_BIN} $@.tmp - rm $@.tmp + rc=$$( \ + cat $< | $(CPP) -P $(DTS_CPPFLAGS) - | \ + { { $(DTC) -R 4 -p 0x1000 -O dtb -o ${DT_BIN} - 2>&1 ; \ + echo $$? >&3 ; } | \ + grep -v '^DTC: dts->dtb on file' ; \ + } 3>&1 ) ; \ + exit $$rc
process_lds = \ $(1) | sed -r -n 's/^OUTPUT_$(2)[ ("]*([^")]*).*/\1/p'
Hi Wolfgang,
See the discussion on this patch:
http://patchwork.ozlabs.org/patch/149833/
A patch to fix this has now been accepted to dtc. So if you update dtc you should find this message goes away.
3cbf829 dtc: Remove spurious output on stderr
- rm $@.tmp
- rc=$$( \
- cat $< | $(CPP) -P $(DTS_CPPFLAGS) - | \
- { { $(DTC) -R 4 -p 0x1000 -O dtb -o ${DT_BIN} - 2>&1 ; \
- echo $$? >&3 ; } | \
- grep -v '^DTC: dts->dtb on file' ; \
- } 3>&1 ) ; \
- exit $$rc
process_lds = \ $(1) | sed -r -n 's/^OUTPUT_$(2)[ ("]*([^")]*).*/\1/p' -- 1.7.7.6
Dear Simon,
In message CAPnjgZ1=Q0=T_vZDZD47h3J65FHitO+0giUkX7pUrECYp=BOkQ@mail.gmail.com you wrote:
There are many systems out there in the field which are subject to a rigid policy, and only distribution provided packages get provided. Many of the "interesting" distributions don't have this fix yet; for example, Fedora 16 (dtc-1.3.0-2.fc16.x86_64) or Debian Wheezy (device-tree-compiler 1.3.0-2) bundle DTC version 1.3.0, which is not fixed yet.
For the sake of those people I would like to apply this patch.
On Thu, Apr 19, 2012 at 11:26 AM, Wolfgang Denk wd@denx.de wrote:
Dear Simon,
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de The number you have dialed is imaginary. Please divide by 0 and try again.
Dear Wolfgang Denk,
Applied, thanks.
