[U-Boot] [PATCH] board: ti: dra7-evm: remove net platform code
The DRA7 has DM_ETH and OF_CONTROL enabled, so remove networking platform code.
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- board/ti/dra7xx/evm.c | 106 +----------------------------------------- 1 file changed, 1 insertion(+), 105 deletions(-)
diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 74d04bb1e3..b1e1e5403c 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -11,6 +11,7 @@ */ #include <common.h> #include <env.h> +#include <spl.h> #include <palmas.h> #include <sata.h> #include <linux/string.h> @@ -29,7 +30,6 @@ #include <dwc3-omap-uboot.h> #include <i2c.h> #include <ti-usb-phy-uboot.h> -#include <miiphy.h>
#include "mux_data.h" #include "../common/board_detect.h" @@ -45,10 +45,6 @@ #define board_ti_get_emif_size() board_ti_get_emif1_size() + \ board_ti_get_emif2_size()
-#ifdef CONFIG_DRIVER_TI_CPSW -#include <cpsw.h> -#endif - DECLARE_GLOBAL_DATA_PTR;
/* GPIO 7_11 */ @@ -989,106 +985,6 @@ int spl_start_uboot(void) } #endif
-#ifdef CONFIG_DRIVER_TI_CPSW -extern u32 *const omap_si_rev; - -static void cpsw_control(int enabled) -{ - /* VTP can be added here */ - - return; -} - -static struct cpsw_slave_data cpsw_slaves[] = { - { - .slave_reg_ofs = 0x208, - .sliver_reg_ofs = 0xd80, - .phy_addr = 2, - }, - { - .slave_reg_ofs = 0x308, - .sliver_reg_ofs = 0xdc0, - .phy_addr = 3, - }, -}; - -static struct cpsw_platform_data cpsw_data = { - .mdio_base = CPSW_MDIO_BASE, - .cpsw_base = CPSW_BASE, - .mdio_div = 0xff, - .channels = 8, - .cpdma_reg_ofs = 0x800, - .slaves = 2, - .slave_data = cpsw_slaves, - .ale_reg_ofs = 0xd00, - .ale_entries = 1024, - .host_port_reg_ofs = 0x108, - .hw_stats_reg_ofs = 0x900, - .bd_ram_ofs = 0x2000, - .mac_control = (1 << 5), - .control = cpsw_control, - .host_port_num = 0, - .version = CPSW_CTRL_VERSION_2, -}; - -int board_eth_init(bd_t *bis) -{ - int ret; - uint8_t mac_addr[6]; - uint32_t mac_hi, mac_lo; - uint32_t ctrl_val; - - /* try reading mac address from efuse */ - mac_lo = readl((*ctrl)->control_core_mac_id_0_lo); - mac_hi = readl((*ctrl)->control_core_mac_id_0_hi); - mac_addr[0] = (mac_hi & 0xFF0000) >> 16; - mac_addr[1] = (mac_hi & 0xFF00) >> 8; - mac_addr[2] = mac_hi & 0xFF; - mac_addr[3] = (mac_lo & 0xFF0000) >> 16; - mac_addr[4] = (mac_lo & 0xFF00) >> 8; - mac_addr[5] = mac_lo & 0xFF; - - if (!env_get("ethaddr")) { - printf("<ethaddr> not set. Validating first E-fuse MAC\n"); - - if (is_valid_ethaddr(mac_addr)) - eth_env_set_enetaddr("ethaddr", mac_addr); - } - - mac_lo = readl((*ctrl)->control_core_mac_id_1_lo); - mac_hi = readl((*ctrl)->control_core_mac_id_1_hi); - mac_addr[0] = (mac_hi & 0xFF0000) >> 16; - mac_addr[1] = (mac_hi & 0xFF00) >> 8; - mac_addr[2] = mac_hi & 0xFF; - mac_addr[3] = (mac_lo & 0xFF0000) >> 16; - mac_addr[4] = (mac_lo & 0xFF00) >> 8; - mac_addr[5] = mac_lo & 0xFF; - - if (!env_get("eth1addr")) { - if (is_valid_ethaddr(mac_addr)) - eth_env_set_enetaddr("eth1addr", mac_addr); - } - - ctrl_val = readl((*ctrl)->control_core_control_io1) & (~0x33); - ctrl_val |= 0x22; - writel(ctrl_val, (*ctrl)->control_core_control_io1); - - if (*omap_si_rev == DRA722_ES1_0) - cpsw_data.active_slave = 1; - - if (board_is_dra72x_revc_or_later()) { - cpsw_slaves[0].phy_if = PHY_INTERFACE_MODE_RGMII_ID; - cpsw_slaves[1].phy_if = PHY_INTERFACE_MODE_RGMII_ID; - } - - ret = cpsw_register(&cpsw_data); - if (ret < 0) - printf("Error %d registering CPSW switch\n", ret); - - return ret; -} -#endif - #ifdef CONFIG_BOARD_EARLY_INIT_F /* VTT regulator enable */ static inline void vtt_regulator_enable(void)
Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
Thanks and regards, Lokesh
Grygorii Strashko
Lokesh Vutla
