[PATCH] test: Fix skip check for sleep command test
When the config option CMD_MISC was renamed to CMD_SLEEP the check in the test for the sleep command was not updated. Do that now.
Fixes: 16060854095 ("cmd: Rename CMD_MISC to CMD_SLEEP") Signed-off-by: Andrew Goodbody andrew.goodbody@linaro.org ---
test/py/tests/test_sleep.py | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/test/py/tests/test_sleep.py b/test/py/tests/test_sleep.py index 66a57434bf..8965fc3fea 100644 --- a/test/py/tests/test_sleep.py +++ b/test/py/tests/test_sleep.py @@ -27,7 +27,7 @@ def test_sleep(u_boot_console): if not sleep_skip: pytest.skip('sleep is not accurate')
- if u_boot_console.config.buildconfig.get('config_cmd_misc', 'n') != 'y': + if u_boot_console.config.buildconfig.get('config_cmd_sleep', 'n') != 'y': pytest.skip('sleep command not supported')
# 3s isn't too long, but is enough to cross a few second boundaries. @@ -42,7 +42,7 @@ def test_sleep(u_boot_console): # margin is hopefully enough to account for any system overhead. assert elapsed < (sleep_time + sleep_margin)
-@pytest.mark.buildconfigspec("cmd_misc") +@pytest.mark.buildconfigspec("cmd_time") def test_time(u_boot_console): """Test the time command, and validate that it gives approximately the correct amount of command execution time."""
On Tue, 8 Oct 2024 at 06:09, Andrew Goodbody andrew.goodbody@linaro.org wrote:
Andrew Goodbody
