[PATCH v1 0/2] riscv: add GPIO support for the LicheePi4A
This series adds GPIO support for the LicheePi4A board. It's based on Alibaba TH1520 SoC that has DesignWare APB GPIO controller.
Best regards, Maksim
Maksim Kiselev (2): gpio: dw: Add ngpios DT-property support configs: th1520_lpi4a: Enable CMD_GPIO, DM_GPIO and DWAPB_GPIO driver
configs/th1520_lpi4a_defconfig | 4 +++- drivers/gpio/dwapb_gpio.c | 4 +++- 2 files changed, 6 insertions(+), 2 deletions(-)
Starting with Linux commit 7569486d79ae ("gpio: dwapb: Add ngpios DT-property support") the "snps,nr-gpios" property was marked as deprecated.
And since all newly added dw-apb-gpio nodes are described using generic "ngpios" property, it's time to add support for it.
Signed-off-by: Maksim Kiselev bigunclemax@gmail.com --- drivers/gpio/dwapb_gpio.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/gpio/dwapb_gpio.c b/drivers/gpio/dwapb_gpio.c index 7a6eae9ba1..04639a4cb6 100644 --- a/drivers/gpio/dwapb_gpio.c +++ b/drivers/gpio/dwapb_gpio.c @@ -177,7 +177,9 @@ static int gpio_dwapb_bind(struct udevice *dev)
plat->base = (void *)base; plat->bank = bank; - plat->pins = ofnode_read_u32_default(node, "snps,nr-gpios", 0); + + if (ofnode_read_u32(node, "ngpios", &plat->pins)) + plat->pins = ofnode_read_u32_default(node, "snps,nr-gpios", 0);
if (ofnode_read_string_index(node, "bank-name", 0, &plat->name)) {
Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com
Enable GPIO command and DWAPB_GPIO driver for LicheePi4A board.
Signed-off-by: Maksim Kiselev bigunclemax@gmail.com --- configs/th1520_lpi4a_defconfig | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/configs/th1520_lpi4a_defconfig b/configs/th1520_lpi4a_defconfig index db80e33870..bcb22730be 100644 --- a/configs/th1520_lpi4a_defconfig +++ b/configs/th1520_lpi4a_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_NR_DRAM_BANKS=1 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80200000 +CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="th1520-lichee-pi-4a" CONFIG_SYS_LOAD_ADDR=0x80200000 # CONFIG_SMP is not set @@ -49,6 +50,7 @@ CONFIG_CMD_BOOTMENU=y # CONFIG_CMD_LZMADEC is not set # CONFIG_CMD_UNLZ4 is not set # CONFIG_CMD_UNZIP is not set +CONFIG_CMD_GPIO=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_ITEST is not set @@ -60,7 +62,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_VERSION_VARIABLE=y # CONFIG_NET is not set # CONFIG_BLOCK_CACHE is not set -# CONFIG_GPIO is not set +CONFIG_DWAPB_GPIO=y # CONFIG_I2C is not set # CONFIG_INPUT is not set # CONFIG_DM_MMC is not set
Leo Liang
