[U-Boot] [PATCH] Revert "arm: Switch 32-bit ARM to using generic global_data setup"
This reverts commit 5ba534d247d418e09c5b4fe5fb7fa780aac08e49.
This commit causes cgtqmx6eval to not boot anymore:
U-Boot SPL 2015.10-00527-g8800bee (Nov 09 2015 - 21:23:54) mxc_spi: SPI Slave not allocated !
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/lib/crt0.S | 28 ++++++++++++++++++++++++---- 1 file changed, 24 insertions(+), 4 deletions(-)
diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S index 80548eb..4c3a94a 100644 --- a/arch/arm/lib/crt0.S +++ b/arch/arm/lib/crt0.S @@ -82,11 +82,31 @@ ENTRY(_main) #else bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ #endif - mov r0, sp - bl board_init_f_mem - mov sp, r0 - + mov r2, sp + sub sp, sp, #GD_SIZE /* allocate one GD above SP */ +#if defined(CONFIG_CPU_V7M) /* v7M forbids using SP as BIC destination */ + mov r3, sp + bic r3, r3, #7 + mov sp, r3 +#else + bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ +#endif + mov r9, sp /* GD is above SP */ + mov r1, sp mov r0, #0 +clr_gd: + cmp r1, r2 /* while not at end of GD */ +#if defined(CONFIG_CPU_V7M) + itt lo +#endif + strlo r0, [r1] /* clear 32-bit GD word */ + addlo r1, r1, #4 /* move to next */ + blo clr_gd +#if defined(CONFIG_SYS_MALLOC_F_LEN) + sub sp, sp, #CONFIG_SYS_MALLOC_F_LEN + str sp, [r9, #GD_MALLOC_BASE] +#endif + /* mov r0, #0 not needed due to above code */ bl board_init_f
#if ! defined(CONFIG_SPL_BUILD)
Hi Fabio,
On 10 November 2015 at 04:40, Fabio Estevam fabio.estevam@freescale.com wrote:
We're at the very start the release process, so I wonder if we can try to figure out what is wrong here?
Is it because malloc() is not working, perhaps?
The C code should be roughly equivalent to the assembly code. Albert found a problem with the code on toolchain 5.2.1 to do with setting 'gd', so may have some thoughts on this. But this might be a different problem.
mov r0, sp
bl board_init_f_mem
mov sp, r0
mov r2, sp
mov r3, sp
bic r3, r3, #7
mov sp, r3
+#else
+clr_gd:
itt lo
blo clr_gd
1.9.1
Hi Simon,
Yes, exactly. malloc() is not working.
Issue happens on Congatec board, but the SPL patch for Congatec has not reached mainline yet.
It is simple to reproduce the problem on a mx6sabresd board with the following change:
--- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -30,6 +30,7 @@ #include "../common/pfuze.h" #include <asm/arch/mx6-ddr.h> #include <usb.h> +#include <malloc.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -833,6 +834,8 @@ static void spl_dram_init(void)
void board_init_f(ulong dummy) { + void __iomem *ptr; + /* setup AIPS and disable watchdog */ arch_cpu_init();
@@ -848,6 +851,12 @@ void board_init_f(ulong dummy) /* UART clocks enabled and gd valid - init serial console */ preloader_console_init();
+ spl_init(); + + ptr = malloc(64); + if (!ptr) + puts("******* malloc returned NULL\n"); + /* DDR initialization */ spl_dram_init();
It is the ame issue I reported back in August: http://lists.denx.de/pipermail/u-boot/2015-August/222406.html
After I followed your suggestion to call spl_init() prior to malloc() the issue went away.
However with 5ba534d247d4 applied, this no longer works, so I am interested in knowing the appropriate way to fix this malloc() issue inside SPL.
I am using 4.7.3 here.
Thanks,
Fabio Estevam
Hi Fabio,
On 10 November 2015 at 06:50, Fabio Estevam festevam@gmail.com wrote:
Hi Simon,
- void __iomem *ptr;
- /* setup AIPS and disable watchdog */ arch_cpu_init();
- spl_init();
- ptr = malloc(64);
- if (!ptr)
Is this patch against mainline or does your tree have other changes?
Are you using CONFIG_SYS_MALLOC_F?
Thanks,
Fabio Estevam
This change is against a clean mainline tree.
No, I am not, but I have also tried adding CONFIG_SYS_MALLOC_F_LEN inside configs/mx6sabresd_spl_defconfig, but it did not help.
Regards,
Fabio Estevam
Sorry, you asked for CONFIG_SYS_MALLOC_F. I do have CONFIG_SYS_MALLOC_F selected
Thanks
Hi Fabio,
Then I wonder why malloc() is failing? Is it because there is too much being allocated, or is the simple malloc region not being set up correctly?
Hi Simon,
In the example I sent I only allocate 64 bytes. malloc() does fail even if I decrease this number.
This puzzles me too. I am not very familiar with this code and I don't know the reason why reverting 5ba534d247d41 'fixes' the problem.
Regards,
Fabio Estevam
Hi Fabio,
On 10 November 2015 at 14:23, Fabio Estevam festevam@gmail.com wrote:
Hi Simon,
Are you able to check what is happening in malloc_simple()? It is a really simple function.
Yes, I turned on debug inside malloc_simple() and it returns NULL:
U-Boot SPL 2015.10-00523-ge490ad2-dirty (Nov 10 2015 - 19:44:06) malloc_simple: size=40, ptr=40, limit=1000 **** malloc_simple returns NULL ******* malloc returned NULL
map_sysmem() is returning NULL inside malloc_simple().
Regards,
Fabio Estevam
Hi Fabio,
That suggests that gd->malloc_base is not being set up, or is being overwritten later. Presumably it should not be NULL?
Is it possible that you have a memset() somewhere which is zeroing gd? It would be after board_init_f_mem() and before your malloc().
Yes, gd->malloc_base is NULL. I just prepared a patch to fix this issue and will submit it soon.
Regards,
Fabio Estevam
Hello Simon,
On Tue, 10 Nov 2015 06:41:25 -0800, Simon Glass sjg@chromium.org wrote:
Hi Fabio,
"Roughly". :)
However:
I've looked into cgtqmx6eval, and if I'm not mistaken it builds ARM, not Thumb, code, whereas the bug I found is on Thumb code (thumb-1 at least).
So yes, this seems like a different problem than the gcc-5.2.1-induced one.
Amicalement,
Albert ARIBAUD
Fabio Estevam
Fabio Estevam
