[RFC PATCH v2 00/15] Introduce ICSSG Ethernet driver
Introduce ICSSG PRUETH support in uboot. The ICSSG driver is used in TI AM654 SR2.0.
The ICSSG PRU Sub-system runs on EMAC firmware. This series Introduces support for ICSSG driver in uboot. This series also adds the driver's dependencies.
The ICSSG2 node is added in device tree overlay so that it remains in sync with linux kernel.
The series introduces device tree and config changes and AM65x to enable ICSSG driver. The series also enables SPL_LOAD_FIT_APPLY_OVERLAY for AM65x in order to load overlay over spl.
This series has been tested on AM65x SR2.0, and the ICSSG interface is able to ping / dhcp and boot kernel using tftp in uboot.
To use ICSSG2 ethernet, the ICSSG firmware needs to be loaded to PRU RPROC cores and RPROC cores need to be booted with the firmware. This step is done inside driver similar to kernel.
The remoteproc driver uses request_fw_into_buf() API from fs-loader driver to load and start rproc with the required firmwares.
The users need to set env variables fw_storage_interface, fw_dev_part, fw_ubi_mtdpart, fw_ubi_volume to indicate which storage medium and partition they want to use to load firmware files from. By default the env fw_storage_interface=mmc and fw_dev_part=1:2 but users can modify these envs as per their requirements.
Log while running dhcp at u-boot:
k3-navss-ringacc ringacc@3c000000: Ring Accelerator probed rings:818, gp-rings[304,100] sci-dev-id:187 k3-navss-ringacc ringacc@3c000000: dma-ring-reset-quirk: disabled prueth icssg2-eth: K3 ICSSG: rflow_id_base: 8, chn_name = rx0 link up on port 0, speed 1000, full duplex BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 DHCP client bound to address 192.168.4.97 (1037 ms)
This is v2 of the series [1]. This addresses comments made on v1.
Changes from v1 to v2: *) Modified the driver to load the firmware inside the driver only instead of loading the firmware using commands at u-boot prompt. Added patch 3/16 for this. *) Rebased the series on the latest u-boot/next. *) Modified conf-0 configuration in k3-am65x-binman.dtsi as suggested by Roger. *) Dropped patch [2] as the patch is no longer needed. *) Added patch 2/15 to modify fs-loader driver to use fw_storage_interface env instead of storage_interface and keep the env storage_interface as fallback as suggested by Roger. *) Added patch 15/15 to set default values to env fw_storage_interface and fw_dev_part.
[1] https://lore.kernel.org/all/20231219103418.3445886-1-danishanwar@ti.com/ [2] https://lore.kernel.org/all/20231219103418.3445886-16-danishanwar@ti.com/
NOTE: All the device tree changes introduced in this patch are already part of linux kernel.
Thanks and Regards, MD Danish Anwar
MD Danish Anwar (15): dma: ti: k3-udma: Use ring_idx to pair k3 nav rings misc: fs-loader: Use fw_storage_interface instead of storage_interface remoteproc: uclass: Add methods to load firmware to rproc and boot rproc net: ti: icssg: Add Firmware Interface for ICSSG Ethernet driver. net: ti: icssg: Add Firmware config and classification APIs. net: ti: icssg: Add icssg queues APIs and macros net: ti: icssg: Add ICSSG ethernet driver net: ti: icssg: Add support sending FDB command to update rx_flow_id net: ti: icssg: Enforce pinctrl state on the MDIO child node arm: dts: k3-am654-base-board: Add ICSSG2 Ethernet support arm: dts: k3-am65x-binman: Add ICSSG2 overlay and configuration configs: am65x_evm_a53: Enable ICSSG Driver configs: am65x_evm_a53: add SPL_LOAD_FIT_APPLY_OVERLAY board: ti: am65x: Add check for k3-am654-icssg2 in board_fit_config_match() board: ti: am65x: Set fw_storage_interface and fw_dev_part ENVs
arch/arm/dts/Makefile | 3 +- arch/arm/dts/k3-am654-icssg2.dtso | 145 ++++ arch/arm/dts/k3-am65x-binman.dtsi | 65 +- board/ti/am65x/am65x.env | 4 + board/ti/am65x/evm.c | 11 +- configs/am65x_evm_a53_defconfig | 2 + .../driver-model/fs_firmware_loader.rst | 5 +- drivers/dma/ti/k3-udma.c | 11 +- drivers/misc/fs_loader.c | 5 +- drivers/net/ti/Kconfig | 9 + drivers/net/ti/Makefile | 1 + drivers/net/ti/icss_mii_rt.h | 192 +++++ drivers/net/ti/icssg_classifier.c | 376 +++++++++ drivers/net/ti/icssg_config.c | 463 +++++++++++ drivers/net/ti/icssg_config.h | 195 +++++ drivers/net/ti/icssg_prueth.c | 762 ++++++++++++++++++ drivers/net/ti/icssg_prueth.h | 92 +++ drivers/net/ti/icssg_queues.c | 51 ++ drivers/net/ti/icssg_switch_map.h | 209 +++++ drivers/remoteproc/Kconfig | 1 + drivers/remoteproc/rproc-uclass.c | 85 ++ include/remoteproc.h | 35 + 22 files changed, 2709 insertions(+), 13 deletions(-) create mode 100644 arch/arm/dts/k3-am654-icssg2.dtso create mode 100644 drivers/net/ti/icss_mii_rt.h create mode 100644 drivers/net/ti/icssg_classifier.c create mode 100644 drivers/net/ti/icssg_config.c create mode 100644 drivers/net/ti/icssg_config.h create mode 100644 drivers/net/ti/icssg_prueth.c create mode 100644 drivers/net/ti/icssg_prueth.h create mode 100644 drivers/net/ti/icssg_queues.c create mode 100644 drivers/net/ti/icssg_switch_map.h
base-commit: f28a77589e7505535a4eebdc7269df98f67dbe68
Use ring_idx to pair rings. ring_idx will be same as tx flow_id for all non-negative flow_ids. For negative flow_ids, ring_idx will be tchan->id added with bchan_cnt.
Signed-off-by: MD Danish Anwar danishanwar@ti.com --- drivers/dma/ti/k3-udma.c | 11 +++++++++-- 1 file changed, 9 insertions(+), 2 deletions(-)
diff --git a/drivers/dma/ti/k3-udma.c b/drivers/dma/ti/k3-udma.c index 8a62d63dfe..eea9ec9659 100644 --- a/drivers/dma/ti/k3-udma.c +++ b/drivers/dma/ti/k3-udma.c @@ -876,13 +876,20 @@ static int udma_alloc_tx_resources(struct udma_chan *uc) { struct k3_nav_ring_cfg ring_cfg; struct udma_dev *ud = uc->ud; - int ret; + struct udma_tchan *tchan; + int ring_idx, ret;
ret = udma_get_tchan(uc); if (ret) return ret;
- ret = k3_nav_ringacc_request_rings_pair(ud->ringacc, uc->tchan->id, -1, + tchan = uc->tchan; + if (tchan->tflow_id >= 0) + ring_idx = tchan->tflow_id; + else + ring_idx = ud->bchan_cnt + tchan->id; + + ret = k3_nav_ringacc_request_rings_pair(ud->ringacc, ring_idx, -1, &uc->tchan->t_ring, &uc->tchan->tc_ring); if (ret) {
The fs-loader driver reads env storage_interface and uses it to load firmware file into memory using the medium set by env. Update the driver to use env fw_storage_interface as this variable is only used to load firmwares. The env storage_interface will act as fallback so that the existing implementations do not break.
Also update the FS Loader documentation accordingly.
Signed-off-by: MD Danish Anwar danishanwar@ti.com --- doc/develop/driver-model/fs_firmware_loader.rst | 5 ++++- drivers/misc/fs_loader.c | 5 ++++- 2 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/doc/develop/driver-model/fs_firmware_loader.rst b/doc/develop/driver-model/fs_firmware_loader.rst index 149b8b436e..410cc1442d 100644 --- a/doc/develop/driver-model/fs_firmware_loader.rst +++ b/doc/develop/driver-model/fs_firmware_loader.rst @@ -98,8 +98,11 @@ through the U-Boot environment variable during run time.
For examples:
+fw_storage_interface: + Firmware storage interface, it can be "mmc", "usb", "sata" or "ubi". storage_interface: - Storage interface, it can be "mmc", "usb", "sata" or "ubi". + Storage interface, it can be "mmc", "usb", "sata" or "ubi". This acts + as a fallback if fw_storage_interface is not set. fw_dev_part: Block device number and its partition, it can be "0:1". fw_ubi_mtdpart: diff --git a/drivers/misc/fs_loader.c b/drivers/misc/fs_loader.c index 1ffc199ba1..3798dab5b6 100644 --- a/drivers/misc/fs_loader.c +++ b/drivers/misc/fs_loader.c @@ -153,7 +153,10 @@ static int fw_get_filesystem_firmware(struct udevice *dev) char *storage_interface, *dev_part, *ubi_mtdpart, *ubi_volume; int ret;
- storage_interface = env_get("storage_interface"); + storage_interface = env_get("fw_storage_interface"); + if (!storage_interface) + storage_interface = env_get("storage_interface"); + dev_part = env_get("fw_dev_part"); ubi_mtdpart = env_get("fw_ubi_mtdpart"); ubi_volume = env_get("fw_ubi_volume");
Add APIs to set a firmware_name to a rproc and boot the rproc with the same firmware.
Clients can call rproc_set_firmware() API to set firmware_name for a rproc whereas rproc_boot() will load the firmware set by rproc_set_firmware() to a buffer by calling request_firmware_into_buf(). rproc_boot() will then load the firmware file to the remote processor and start the remote processor.
Also include "fs-loader.h" and make remoteproc driver select FS_LOADER in Kconfig so that we can call request_firmware_into_buf() from remoteproc driver.
Signed-off-by: MD Danish Anwar danishanwar@ti.com --- drivers/remoteproc/Kconfig | 1 + drivers/remoteproc/rproc-uclass.c | 85 +++++++++++++++++++++++++++++++ include/remoteproc.h | 35 +++++++++++++ 3 files changed, 121 insertions(+)
diff --git a/drivers/remoteproc/Kconfig b/drivers/remoteproc/Kconfig index 781de530af..0fdf1b38ea 100644 --- a/drivers/remoteproc/Kconfig +++ b/drivers/remoteproc/Kconfig @@ -10,6 +10,7 @@ menu "Remote Processor drivers" # All users should depend on DM config REMOTEPROC bool + select FS_LOADER depends on DM
# Please keep the configuration alphabetically sorted. diff --git a/drivers/remoteproc/rproc-uclass.c b/drivers/remoteproc/rproc-uclass.c index 28b362c887..76db4157f7 100644 --- a/drivers/remoteproc/rproc-uclass.c +++ b/drivers/remoteproc/rproc-uclass.c @@ -13,6 +13,7 @@ #include <log.h> #include <malloc.h> #include <virtio_ring.h> +#include <fs_loader.h> #include <remoteproc.h> #include <asm/io.h> #include <dm/device-internal.h> @@ -961,3 +962,87 @@ unsigned long rproc_parse_resource_table(struct udevice *dev, struct rproc *cfg)
return 1; } + +int rproc_set_firmware(struct udevice *rproc_dev, const char *fw_name) +{ + struct dm_rproc_uclass_pdata *uc_pdata; + int len; + char *p; + + if (!rproc_dev || !fw_name) + return -EINVAL; + + uc_pdata = dev_get_uclass_plat(rproc_dev); + + len = strcspn(fw_name, "\n"); + if (!len) { + debug("can't provide empty string for firmware name\n"); + return -EINVAL; + } + + p = strndup(fw_name, len); + if (!p) + return -ENOMEM; + + uc_pdata->fw_name = p; + + return 0; +} + +int rproc_boot(struct udevice *rproc_dev, size_t fw_size) +{ + struct dm_rproc_uclass_pdata *uc_pdata; + struct udevice *fs_loader; + void *addr = malloc(fw_size); + int core_id, ret = 0; + char *firmware; + ulong rproc_addr; + + if (!rproc_dev) + return -EINVAL; + + if (!addr) + return -ENOMEM; + + uc_pdata = dev_get_uclass_plat(rproc_dev); + core_id = dev_seq(rproc_dev); + firmware = uc_pdata->fw_name; + + if (!firmware) { + debug("No firmware set for rproc core %d\n", core_id); + return -EINVAL; + } + + /* Initialize all rproc cores */ + rproc_init(); + + /* Loading firmware to a given address */ + ret = get_fs_loader(&fs_loader); + if (ret) { + debug("could not get fs loader: %d\n", ret); + return ret; + } + + ret = request_firmware_into_buf(fs_loader, firmware, addr, fw_size, 0); + if (ret < 0) { + debug("could not request %s: %d\n", firmware, ret); + return ret; + } + + rproc_addr = (ulong)addr; + + ret = rproc_load(core_id, rproc_addr, ret); + if (ret) { + debug("failed to load %s to rproc core %d from addr 0x%08lX err %d\n", + uc_pdata->fw_name, core_id, rproc_addr, ret); + return ret; + } + + ret = rproc_start(core_id); + if (ret) { + debug("failed to start rproc core %d\n", core_id); + return ret; + } + + return ret; +} diff --git a/include/remoteproc.h b/include/remoteproc.h index a11dc8a9b6..65b0ff7477 100644 --- a/include/remoteproc.h +++ b/include/remoteproc.h @@ -402,6 +402,7 @@ enum rproc_mem_type { * @name: Platform-specific way of naming the Remote proc * @mem_type: one of 'enum rproc_mem_type' * @driver_plat_data: driver specific platform data that may be needed. + * @fw_name: firmware name * * This can be accessed with dev_get_uclass_plat() for any UCLASS_REMOTEPROC * device. @@ -411,6 +412,7 @@ struct dm_rproc_uclass_pdata { const char *name; enum rproc_mem_type mem_type; void *driver_plat_data; + char *fw_name; };
/** @@ -704,6 +706,35 @@ unsigned long rproc_parse_resource_table(struct udevice *dev, struct resource_table *rproc_find_resource_table(struct udevice *dev, unsigned int addr, int *tablesz); +/** + * rproc_set_firmware() - assign a new firmware + * @rproc_dev: device for wich new firmware is being assigned + * @fw_name: new firmware name to be assigned + * + * This function allows remoteproc drivers or clients to configure a custom + * firmware name. The function does not trigger a remote processor boot, + * only sets the firmware name used for a subsequent boot. + * + * This function sets the fw_name field in uclass pdata of the Remote proc + * + * Return: 0 on success or a negative value upon failure + */ +int rproc_set_firmware(struct udevice *rproc_dev, const char *fw_name); + +/** + * rproc_boot() - boot a remote processor + * @rproc_dev: rproc device to boot + * @fw_size: Size of the memory to allocate for firmeware + * + * Boot a remote processor (i.e. load its firmware, power it on, ...). + * + * This function first loads the firmware set in the uclass pdata of Remote + * processor to a buffer and then loads firmware to the remote processor + * using rproc_load(). + * + * Return: 0 on success, and an appropriate error value otherwise + */ +int rproc_boot(struct udevice *rproc_dev, size_t fw_size); #else static inline int rproc_init(void) { return -ENOSYS; } static inline int rproc_dev_init(int id) { return -ENOSYS; } @@ -743,6 +774,10 @@ static inline int rproc_elf_load_rsc_table(struct udevice *dev, ulong fw_addr, ulong fw_size, ulong *rsc_addr, ulong *rsc_size) { return -ENOSYS; } +static inline int rproc_set_firmware(struct udevice *rproc_dev, const char *fw_name) +{ return -ENOSYS; } +static inline int rproc_boot(struct udevice *rproc_dev, size_t fw_size) +{ return -ENOSYS; } #endif
#endif /* _RPROC_H_ */
Add firmware interface related headers and macros for ICSSG Ethernet driver. These macros will be later used by the ICSSG ethernet driver.
Signed-off-by: MD Danish Anwar danishanwar@ti.com --- drivers/net/ti/icssg_switch_map.h | 209 ++++++++++++++++++++++++++++++ 1 file changed, 209 insertions(+) create mode 100644 drivers/net/ti/icssg_switch_map.h
diff --git a/drivers/net/ti/icssg_switch_map.h b/drivers/net/ti/icssg_switch_map.h new file mode 100644 index 0000000000..ba87a44023 --- /dev/null +++ b/drivers/net/ti/icssg_switch_map.h @@ -0,0 +1,209 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* Texas Instruments ICSSG Ethernet driver + * + * Copyright (C) 2020 Texas Instruments Incorporated - https://www.ti.com/ + * + */ + +#ifndef __NET_TI_ICSSG_SWITCH_MAP_H +#define __NET_TI_ICSSG_SWITCH_MAP_H + +/*Time after which FDB entries are checked for aged out values. Value in nanoseconds*/ +#define FDB_AGEING_TIMEOUT_OFFSET 0x0014 + +/*default VLAN tag for Host Port*/ +#define HOST_PORT_DF_VLAN_OFFSET 0x001C + +/*Same as HOST_PORT_DF_VLAN_OFFSET*/ +#define EMAC_ICSSG_SWITCH_PORT0_DEFAULT_VLAN_OFFSET HOST_PORT_DF_VLAN_OFFSET + +/*default VLAN tag for P1 Port*/ +#define P1_PORT_DF_VLAN_OFFSET 0x0020 + +/*Same as P1_PORT_DF_VLAN_OFFSET*/ +#define EMAC_ICSSG_SWITCH_PORT1_DEFAULT_VLAN_OFFSET P1_PORT_DF_VLAN_OFFSET + +/*default VLAN tag for P2 Port*/ +#define P2_PORT_DF_VLAN_OFFSET 0x0024 + +/*Same as P2_PORT_DF_VLAN_OFFSET*/ +#define EMAC_ICSSG_SWITCH_PORT2_DEFAULT_VLAN_OFFSET P2_PORT_DF_VLAN_OFFSET + +/*VLAN-FID Table offset. 4096 VIDs. 2B per VID = 8KB = 0x2000*/ +#define VLAN_STATIC_REG_TABLE_OFFSET 0x0100 + +/*VLAN-FID Table offset for EMAC*/ +#define EMAC_ICSSG_SWITCH_DEFAULT_VLAN_TABLE_OFFSET VLAN_STATIC_REG_TABLE_OFFSET + +/*packet descriptor Q reserved memory*/ +#define PORT_DESC0_HI 0x2104 + +/*packet descriptor Q reserved memory*/ +#define PORT_DESC0_LO 0x2F6C + +/*packet descriptor Q reserved memory*/ +#define PORT_DESC1_HI 0x3DD4 + +/*packet descriptor Q reserved memory*/ +#define PORT_DESC1_LO 0x4C3C + +/*packet descriptor Q reserved memory*/ +#define HOST_DESC0_HI 0x5AA4 + +/*packet descriptor Q reserved memory*/ +#define HOST_DESC0_LO 0x5F0C + +/*packet descriptor Q reserved memory*/ +#define HOST_DESC1_HI 0x6374 + +/*packet descriptor Q reserved memory*/ +#define HOST_DESC1_LO 0x67DC + +/*special packet descriptor Q reserved memory*/ +#define HOST_SPPD0 0x7AAC + +/*special packet descriptor Q reserved memory*/ +#define HOST_SPPD1 0x7EAC + +/*_Small_Description_*/ +#define TIMESYNC_FW_WC_CYCLECOUNT_OFFSET 0x83EC + +/*IEP count hi roll over count*/ +#define TIMESYNC_FW_WC_HI_ROLLOVER_COUNT_OFFSET 0x83F4 + +/*_Small_Description_*/ +#define TIMESYNC_FW_WC_COUNT_HI_SW_OFFSET_OFFSET 0x83F8 + +/*Set clock descriptor*/ +#define TIMESYNC_FW_WC_SETCLOCK_DESC_OFFSET 0x83FC + +/*_Small_Description_*/ +#define TIMESYNC_FW_WC_SYNCOUT_REDUCTION_FACTOR_OFFSET 0x843C + +/*_Small_Description_*/ +#define TIMESYNC_FW_WC_SYNCOUT_REDUCTION_COUNT_OFFSET 0x8440 + +/*_Small_Description_*/ +#define TIMESYNC_FW_WC_SYNCOUT_START_TIME_CYCLECOUNT_OFFSET 0x8444 + +/*Control variable to generate SYNC1*/ +#define TIMESYNC_FW_WC_ISOM_PIN_SIGNAL_EN_OFFSET 0x844C + +/*SystemTime Sync0 periodicity*/ +#define TIMESYNC_FW_ST_SYNCOUT_PERIOD_OFFSET 0x8450 + +/*pktTxDelay for P1 = link speed dependent p1 mac delay + p1 phy delay*/ +#define TIMESYNC_FW_WC_PKTTXDELAY_P1_OFFSET 0x8454 + +/*pktTxDelay for P2 = link speed dependent p2 mac delay + p2 phy delay*/ +#define TIMESYNC_FW_WC_PKTTXDELAY_P2_OFFSET 0x8458 + +/*Set clock operation done signal for next task*/ +#define TIMESYNC_FW_SIG_PNFW_OFFSET 0x845C + +/*Set clock operation done signal for next task*/ +#define TIMESYNC_FW_SIG_TIMESYNCFW_OFFSET 0x8460 + +/*New list is copied at this time*/ +#define TAS_CONFIG_CHANGE_TIME 0x000C + +/*config change error counter*/ +#define TAS_CONFIG_CHANGE_ERROR_COUNTER 0x0014 + +/*TAS List update pending flag*/ +#define TAS_CONFIG_PENDING 0x0018 + +/*TAS list update trigger flag*/ +#define TAS_CONFIG_CHANGE 0x0019 + +/*List length for new TAS schedule*/ +#define TAS_ADMIN_LIST_LENGTH 0x001A + +/*Currently active TAS list index*/ +#define TAS_ACTIVE_LIST_INDEX 0x001B + +/*Cycle time for the new TAS schedule*/ +#define TAS_ADMIN_CYCLE_TIME 0x001C + +/*Cycle counts remaining till the TAS list update*/ +#define TAS_CONFIG_CHANGE_CYCLE_COUNT 0x0020 + +/*Base Flow ID for sending packets to Host for Slice0*/ +#define PSI_L_REGULAR_FLOW_ID_BASE_OFFSET 0x0024 + +/*Same as PSI_L_REGULAR_FLOW_ID_BASE_OFFSET*/ +#define EMAC_ICSSG_SWITCH_PSI_L_REGULAR_FLOW_ID_BASE_OFFSET PSI_L_REGULAR_FLOW_ID_BASE_OFFSET + +/*Base Flow ID for sending mgmt and Tx TS to Host for Slice0*/ +#define PSI_L_MGMT_FLOW_ID_OFFSET 0x0026 + +/*Same as PSI_L_MGMT_FLOW_ID_OFFSET*/ +#define EMAC_ICSSG_SWITCH_PSI_L_MGMT_FLOW_ID_BASE_OFFSET PSI_L_MGMT_FLOW_ID_OFFSET + +/*Queue number for Special packets written here*/ +#define SPL_PKT_DEFAULT_PRIORITY 0x0028 + +/*Express Preemptible Queue Mask*/ +#define EXPRESS_PRE_EMPTIVE_Q_MASK 0x0029 + +/*Port1/Port2 Default Queue number for untagged packets, only 1B is used*/ +#define QUEUE_NUM_UNTAGGED 0x002A + +/*Stores the table used for priority regeneration. 1B per PCP/Queue*/ +#define PORT_Q_PRIORITY_REGEN_OFFSET 0x002C + +/* For marking Packet as priority/express (this feature is disabled) or + * cut-through/S&F. + */ +#define EXPRESS_PRE_EMPTIVE_Q_MAP 0x0034 + +/*Stores the table used for priority mapping. 1B per PCP/Queue*/ +#define PORT_Q_PRIORITY_MAPPING_OFFSET 0x003C + +/*TAS gate mask for windows list0*/ +#define TAS_GATE_MASK_LIST0 0x0100 + +/*TAS gate mask for windows list1*/ +#define TAS_GATE_MASK_LIST1 0x0350 + +/*Memory to Enable/Disable Preemption on TX side*/ +#define PRE_EMPTION_ENABLE_TX 0x05A0 + +/*Active State of Preemption on TX side*/ +#define PRE_EMPTION_ACTIVE_TX 0x05A1 + +/*Memory to Enable/Disable Verify State Machine Preemption*/ +#define PRE_EMPTION_ENABLE_VERIFY 0x05A2 + +/*Verify Status of State Machine*/ +#define PRE_EMPTION_VERIFY_STATUS 0x05A3 + +/*Non Final Fragment Size supported by Link Partner*/ +#define PRE_EMPTION_ADD_FRAG_SIZE_REMOTE 0x05A4 + +/*Non Final Fragment Size supported by Firmware*/ +#define PRE_EMPTION_ADD_FRAG_SIZE_LOCAL 0x05A6 + +/*Time in ms the State machine waits for respond packet*/ +#define PRE_EMPTION_VERIFY_TIME 0x05A8 + +/*Memory used for R30 related management commands*/ +#define MGR_R30_CMD_OFFSET 0x05AC + +/*HW Buffer Pool0 base address*/ +#define BUFFER_POOL_0_ADDR_OFFSET 0x05BC + +/*16B for Host Egress MSMC Q (Pre-emptible) context*/ +#define HOST_RX_Q_PRE_CONTEXT_OFFSET 0x0684 + +/*Buffer for 8 FDB entries to be added by 'Add Multiple FDB entries IOCTL*/ +#define FDB_CMD_BUFFER 0x0894 + +/*16B for Host Egress MSMC Q (Express) context*/ +#define HOST_RX_Q_EXP_CONTEXT_OFFSET 0x0940 + +/*Start of 32 bits PA_STAT counters*/ +#define PA_STAT_32b_START_OFFSET 0x0080 + +#endif +/* __NET_TI_ICSSG_SWITCH_MAP_H */
Add icssg_config.h / .c and icssg_classifier.c files. These are firmware configuration and classification related files. Add MII helper APIs and MACROs. These APIs and MACROs will be later used by ICSSG Ethernet driver. Also introduce icssg_prueth.h which has definition of prueth related structures.
Signed-off-by: MD Danish Anwar danishanwar@ti.com --- drivers/net/ti/icss_mii_rt.h | 192 +++++++++++++++ drivers/net/ti/icssg_classifier.c | 376 ++++++++++++++++++++++++++++ drivers/net/ti/icssg_config.c | 397 ++++++++++++++++++++++++++++++ drivers/net/ti/icssg_config.h | 177 +++++++++++++ drivers/net/ti/icssg_prueth.h | 78 ++++++ 5 files changed, 1220 insertions(+) create mode 100644 drivers/net/ti/icss_mii_rt.h create mode 100644 drivers/net/ti/icssg_classifier.c create mode 100644 drivers/net/ti/icssg_config.c create mode 100644 drivers/net/ti/icssg_config.h create mode 100644 drivers/net/ti/icssg_prueth.h
diff --git a/drivers/net/ti/icss_mii_rt.h b/drivers/net/ti/icss_mii_rt.h new file mode 100644 index 0000000000..6b2449e736 --- /dev/null +++ b/drivers/net/ti/icss_mii_rt.h @@ -0,0 +1,192 @@ +/* SPDX-License-Identifier: GPL-2.0 */ + +/* PRU-ICSS MII_RT register definitions + * + * Copyright (C) 2015-2020 Texas Instruments Incorporated - http://www.ti.com + */ + +#ifndef __NET_PRUSS_MII_RT_H__ +#define __NET_PRUSS_MII_RT_H__ + +#include <regmap.h> + +/* PRUSS_MII_RT Registers */ +#define PRUSS_MII_RT_RXCFG0 0x0 +#define PRUSS_MII_RT_RXCFG1 0x4 +#define PRUSS_MII_RT_TXCFG0 0x10 +#define PRUSS_MII_RT_TXCFG1 0x14 +#define PRUSS_MII_RT_TX_CRC0 0x20 +#define PRUSS_MII_RT_TX_CRC1 0x24 +#define PRUSS_MII_RT_TX_IPG0 0x30 +#define PRUSS_MII_RT_TX_IPG1 0x34 +#define PRUSS_MII_RT_PRS0 0x38 +#define PRUSS_MII_RT_PRS1 0x3c +#define PRUSS_MII_RT_RX_FRMS0 0x40 +#define PRUSS_MII_RT_RX_FRMS1 0x44 +#define PRUSS_MII_RT_RX_PCNT0 0x48 +#define PRUSS_MII_RT_RX_PCNT1 0x4c +#define PRUSS_MII_RT_RX_ERR0 0x50 +#define PRUSS_MII_RT_RX_ERR1 0x54 + +/* PRUSS_MII_RT_RXCFG0/1 bits */ +#define PRUSS_MII_RT_RXCFG_RX_ENABLE BIT(0) +#define PRUSS_MII_RT_RXCFG_RX_DATA_RDY_MODE_DIS BIT(1) +#define PRUSS_MII_RT_RXCFG_RX_CUT_PREAMBLE BIT(2) +#define PRUSS_MII_RT_RXCFG_RX_MUX_SEL BIT(3) +#define PRUSS_MII_RT_RXCFG_RX_L2_EN BIT(4) +#define PRUSS_MII_RT_RXCFG_RX_BYTE_SWAP BIT(5) +#define PRUSS_MII_RT_RXCFG_RX_AUTO_FWD_PRE BIT(6) +#define PRUSS_MII_RT_RXCFG_RX_L2_EOF_SCLR_DIS BIT(9) + +/* PRUSS_MII_RT_TXCFG0/1 bits */ +#define PRUSS_MII_RT_TXCFG_TX_ENABLE BIT(0) +#define PRUSS_MII_RT_TXCFG_TX_AUTO_PREAMBLE BIT(1) +#define PRUSS_MII_RT_TXCFG_TX_EN_MODE BIT(2) +#define PRUSS_MII_RT_TXCFG_TX_BYTE_SWAP BIT(3) +#define PRUSS_MII_RT_TXCFG_TX_MUX_SEL BIT(8) +#define PRUSS_MII_RT_TXCFG_PRE_TX_AUTO_SEQUENCE BIT(9) +#define PRUSS_MII_RT_TXCFG_PRE_TX_AUTO_ESC_ERR BIT(10) +#define PRUSS_MII_RT_TXCFG_TX_32_MODE_EN BIT(11) +#define PRUSS_MII_RT_TXCFG_TX_IPG_WIRE_CLK_EN BIT(12) /* SR2.0 onwards */ + +#define PRUSS_MII_RT_TXCFG_TX_START_DELAY_SHIFT 16 +#define PRUSS_MII_RT_TXCFG_TX_START_DELAY_MASK GENMASK(25, 16) + +#define PRUSS_MII_RT_TXCFG_TX_CLK_DELAY_SHIFT 28 +#define PRUSS_MII_RT_TXCFG_TX_CLK_DELAY_MASK GENMASK(30, 28) + +/* PRUSS_MII_RT_TX_IPG0/1 bits */ +#define PRUSS_MII_RT_TX_IPG_IPG_SHIFT 0 +#define PRUSS_MII_RT_TX_IPG_IPG_MASK GENMASK(9, 0) + +/* PRUSS_MII_RT_PRS0/1 bits */ +#define PRUSS_MII_RT_PRS_COL BIT(0) +#define PRUSS_MII_RT_PRS_CRS BIT(1) + +/* PRUSS_MII_RT_RX_FRMS0/1 bits */ +#define PRUSS_MII_RT_RX_FRMS_MIN_FRM_SHIFT 0 +#define PRUSS_MII_RT_RX_FRMS_MIN_FRM_MASK GENMASK(15, 0) + +#define PRUSS_MII_RT_RX_FRMS_MAX_FRM_SHIFT 16 +#define PRUSS_MII_RT_RX_FRMS_MAX_FRM_MASK GENMASK(31, 16) + +/* Min/Max in MII_RT_RX_FRMS */ +/* For EMAC and Switch */ +#define PRUSS_MII_RT_RX_FRMS_MAX (VLAN_ETH_FRAME_LEN + ETH_FCS_LEN) +#define PRUSS_MII_RT_RX_FRMS_MIN_FRM (64) + +/* for HSR and PRP */ +#define PRUSS_MII_RT_RX_FRMS_MAX_FRM_LRE (PRUSS_MII_RT_RX_FRMS_MAX + \ + ICSS_LRE_TAG_RCT_SIZE) +/* PRUSS_MII_RT_RX_PCNT0/1 bits */ +#define PRUSS_MII_RT_RX_PCNT_MIN_PCNT_SHIFT 0 +#define PRUSS_MII_RT_RX_PCNT_MIN_PCNT_MASK GENMASK(3, 0) + +#define PRUSS_MII_RT_RX_PCNT_MAX_PCNT_SHIFT 4 +#define PRUSS_MII_RT_RX_PCNT_MAX_PCNT_MASK GENMASK(7, 4) + +/* PRUSS_MII_RT_RX_ERR0/1 bits */ +#define PRUSS_MII_RT_RX_ERR_MIN_PCNT_ERR BIT(0) +#define PRUSS_MII_RT_RX_ERR_MAX_PCNT_ERR BIT(1) +#define PRUSS_MII_RT_RX_ERR_MIN_FRM_ERR BIT(2) +#define PRUSS_MII_RT_RX_ERR_MAX_FRM_ERR BIT(3) + +#define ICSSG_CFG_OFFSET 0 +#define RGMII_CFG_OFFSET 4 + +/* Constant to choose between MII0 and MII1 */ +#define ICSS_MII0 0 +#define ICSS_MII1 1 + +/* ICSSG_CFG Register bits */ +#define ICSSG_CFG_SGMII_MODE BIT(16) +#define ICSSG_CFG_TX_PRU_EN BIT(11) +#define ICSSG_CFG_RX_SFD_TX_SOF_EN BIT(10) +#define ICSSG_CFG_RTU_PRU_PSI_SHARE_EN BIT(9) +#define ICSSG_CFG_IEP1_TX_EN BIT(8) +#define ICSSG_CFG_MII1_MODE GENMASK(6, 5) +#define ICSSG_CFG_MII1_MODE_SHIFT 5 +#define ICSSG_CFG_MII0_MODE GENMASK(4, 3) +#define ICSSG_CFG_MII0_MODE_SHIFT 3 +#define ICSSG_CFG_RX_L2_G_EN BIT(2) +#define ICSSG_CFG_TX_L2_EN BIT(1) +#define ICSSG_CFG_TX_L1_EN BIT(0) + +enum mii_mode { MII_MODE_MII = 0, MII_MODE_RGMII, MII_MODE_SGMII }; + +/* RGMII CFG Register bits */ +#define RGMII_CFG_INBAND_EN_MII0 BIT(16) +#define RGMII_CFG_GIG_EN_MII0 BIT(17) +#define RGMII_CFG_INBAND_EN_MII1 BIT(20) +#define RGMII_CFG_GIG_EN_MII1 BIT(21) +#define RGMII_CFG_FULL_DUPLEX_MII0 BIT(18) +#define RGMII_CFG_FULL_DUPLEX_MII1 BIT(22) +#define RGMII_CFG_SPEED_MII0 GENMASK(2, 1) +#define RGMII_CFG_SPEED_MII1 GENMASK(6, 5) +#define RGMII_CFG_SPEED_MII0_SHIFT 1 +#define RGMII_CFG_SPEED_MII1_SHIFT 5 +#define RGMII_CFG_FULLDUPLEX_MII0 BIT(3) +#define RGMII_CFG_FULLDUPLEX_MII1 BIT(7) +#define RGMII_CFG_FULLDUPLEX_MII0_SHIFT 3 +#define RGMII_CFG_FULLDUPLEX_MII1_SHIFT 7 +#define RGMII_CFG_SPEED_10M 0 +#define RGMII_CFG_SPEED_100M 1 +#define RGMII_CFG_SPEED_1G 2 + +static inline void icssg_mii_update_ipg(struct regmap *mii_rt, int mii, u32 ipg) +{ + u32 val; + + if (mii == ICSS_MII0) { + regmap_write(mii_rt, PRUSS_MII_RT_TX_IPG0, ipg); + } else { + /* Errata workaround: IEP1 is not read by h/w unless IEP0 is written */ + regmap_read(mii_rt, PRUSS_MII_RT_TX_IPG0, &val); + regmap_write(mii_rt, PRUSS_MII_RT_TX_IPG1, ipg); + regmap_write(mii_rt, PRUSS_MII_RT_TX_IPG0, val); + } +} + +static inline void icssg_update_rgmii_cfg(struct regmap *miig_rt, int speed, + bool full_duplex, int slice, struct prueth *priv) +{ + u32 gig_en_mask, gig_val = 0, full_duplex_mask, full_duplex_val = 0; + u32 inband_en_mask, inband_val = 0; + + gig_en_mask = (slice == ICSS_MII0) ? RGMII_CFG_GIG_EN_MII0 : + RGMII_CFG_GIG_EN_MII1; + if (speed == SPEED_1000) + gig_val = gig_en_mask; + regmap_update_bits(miig_rt, RGMII_CFG_OFFSET, gig_en_mask, gig_val); + + inband_en_mask = (slice == ICSS_MII0) ? RGMII_CFG_INBAND_EN_MII0 : + RGMII_CFG_INBAND_EN_MII1; + if (speed == SPEED_10 && phy_interface_is_rgmii(priv->phydev)) + inband_val = inband_en_mask; + regmap_update_bits(miig_rt, RGMII_CFG_OFFSET, inband_en_mask, inband_val); + + full_duplex_mask = (slice == ICSS_MII0) ? RGMII_CFG_FULL_DUPLEX_MII0 : + RGMII_CFG_FULL_DUPLEX_MII1; + if (full_duplex) + full_duplex_val = full_duplex_mask; + regmap_update_bits(miig_rt, RGMII_CFG_OFFSET, full_duplex_mask, + full_duplex_val); +} + +static inline void icssg_miig_set_interface_mode(struct regmap *miig_rt, int mii, int phy_if) +{ + u32 val, mask, shift; + + mask = mii == ICSS_MII0 ? ICSSG_CFG_MII0_MODE : ICSSG_CFG_MII1_MODE; + shift = mii == ICSS_MII0 ? ICSSG_CFG_MII0_MODE_SHIFT : ICSSG_CFG_MII1_MODE_SHIFT; + + val = MII_MODE_RGMII; + if (phy_if == PHY_INTERFACE_MODE_MII) + val = MII_MODE_MII; + + val <<= shift; + regmap_update_bits(miig_rt, ICSSG_CFG_OFFSET, mask, val); + regmap_read(miig_rt, ICSSG_CFG_OFFSET, &val); +} + +#endif /* __NET_PRUSS_MII_RT_H__ */ diff --git a/drivers/net/ti/icssg_classifier.c b/drivers/net/ti/icssg_classifier.c new file mode 100644 index 0000000000..f2440a5a5f --- /dev/null +++ b/drivers/net/ti/icssg_classifier.c @@ -0,0 +1,376 @@ +// SPDX-License-Identifier: GPL-2.0 +/* Texas Instruments ICSSG Ethernet Driver + * + * Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/ + * + */ + +#include <dm/ofnode.h> +#include <regmap.h> + +#define ICSSG_NUM_CLASSIFIERS 16 +#define ICSSG_NUM_FT1_SLOTS 8 +#define ICSSG_NUM_FT3_SLOTS 16 + +#define ICSSG_NUM_CLASSIFIERS_IN_USE 1 + +/* Filter 1 - FT1 */ +#define FT1_NUM_SLOTS 8 +#define FT1_SLOT_SIZE 0x10 /* bytes */ + +/* offsets from FT1 slot base i.e. slot 1 start */ +#define FT1_DA0 0x0 +#define FT1_DA1 0x4 +#define FT1_DA0_MASK 0x8 +#define FT1_DA1_MASK 0xc + +#define FT1_N_REG(slize, n, reg) (offs[slice].ft1_slot_base + FT1_SLOT_SIZE * (n) + (reg)) + +#define FT1_LEN_MASK GENMASK(19, 16) +#define FT1_LEN_SHIFT 16 +#define FT1_LEN(len) (((len) << FT1_LEN_SHIFT) & FT1_LEN_MASK) + +#define FT1_START_MASK GENMASK(14, 0) +#define FT1_START(start) ((start) & FT1_START_MASK) + +#define FT1_MATCH_SLOT(n) (GENMASK(23, 16) & (BIT(n) << 16)) + +enum ft1_cfg_type { + FT1_CFG_TYPE_DISABLED = 0, + FT1_CFG_TYPE_EQ, + FT1_CFG_TYPE_GT, + FT1_CFG_TYPE_LT, +}; + +#define FT1_CFG_SHIFT(n) (2 * (n)) +#define FT1_CFG_MASK(n) (0x3 << FT1_CFG_SHIFT((n))) + +/* Filter 3 - FT3 */ +#define FT3_NUM_SLOTS 16 +#define FT3_SLOT_SIZE 0x20 /* bytes */ + +/* offsets from FT3 slot n's base */ +#define FT3_START 0 +#define FT3_START_AUTO 0x4 +#define FT3_START_OFFSET 0x8 +#define FT3_JUMP_OFFSET 0xc +#define FT3_LEN 0x10 +#define FT3_CFG 0x14 +#define FT3_T 0x18 +#define FT3_T_MASK 0x1c + +#define FT3_N_REG(slize, n, reg) \ + (offs[slice].ft3_slot_base + FT3_SLOT_SIZE * (n) + (reg)) + +/* offsets from rx_class n's base */ +#define RX_CLASS_AND_EN 0 +#define RX_CLASS_OR_EN 0x4 + +#define RX_CLASS_NUM_SLOTS 16 +#define RX_CLASS_EN_SIZE 0x8 /* bytes */ + +#define RX_CLASS_N_REG(slice, n, reg) \ + (offs[slice].rx_class_base + RX_CLASS_EN_SIZE * (n) + (reg)) + +/* RX Class Gates */ +#define RX_CLASS_GATES_SIZE 0x4 /* bytes */ + +#define RX_CLASS_GATES_N_REG(slice, n) \ + (offs[slice].rx_class_gates_base + RX_CLASS_GATES_SIZE * (n)) + +#define RX_CLASS_GATES_ALLOW_MASK BIT(6) +#define RX_CLASS_GATES_RAW_MASK BIT(5) +#define RX_CLASS_GATES_PHASE_MASK BIT(4) + +/* RX Class traffic data matching bits */ +#define RX_CLASS_FT_UC BIT(31) +#define RX_CLASS_FT_MC BIT(30) +#define RX_CLASS_FT_BC BIT(29) +#define RX_CLASS_FT_FW BIT(28) +#define RX_CLASS_FT_RCV BIT(27) +#define RX_CLASS_FT_VLAN BIT(26) +#define RX_CLASS_FT_DA_P BIT(25) +#define RX_CLASS_FT_DA_I BIT(24) +#define RX_CLASS_FT_FT1_MATCH_MASK GENMASK(23, 16) +#define RX_CLASS_FT_FT1_MATCH_SHIFT 16 +#define RX_CLASS_FT_FT3_MATCH_MASK GENMASK(15, 0) +#define RX_CLASS_FT_FT3_MATCH_SHIFT 0 + +#define RX_CLASS_FT_FT1_MATCH(slot) \ + ((BIT(slot) << RX_CLASS_FT_FT1_MATCH_SHIFT) & \ + RX_CLASS_FT_FT1_MATCH_MASK) + +enum rx_class_sel_type { + RX_CLASS_SEL_TYPE_OR = 0, + RX_CLASS_SEL_TYPE_AND = 1, + RX_CLASS_SEL_TYPE_OR_AND_AND = 2, + RX_CLASS_SEL_TYPE_OR_OR_AND = 3, +}; + +#define FT1_CFG_SHIFT(n) (2 * (n)) +#define FT1_CFG_MASK(n) (0x3 << FT1_CFG_SHIFT((n))) + +#define RX_CLASS_SEL_SHIFT(n) (2 * (n)) +#define RX_CLASS_SEL_MASK(n) (0x3 << RX_CLASS_SEL_SHIFT((n))) + +#define ICSSG_CFG_OFFSET 0 +#define MAC_INTERFACE_0 0x18 +#define MAC_INTERFACE_1 0x1c + +#define ICSSG_CFG_RX_L2_G_EN BIT(2) + +/* these are register offsets per PRU */ +struct miig_rt_offsets { + u32 mac0; + u32 mac1; + u32 ft1_start_len; + u32 ft1_cfg; + u32 ft1_slot_base; + u32 ft3_slot_base; + u32 ft3_p_base; + u32 ft_rx_ptr; + u32 rx_class_base; + u32 rx_class_cfg1; + u32 rx_class_cfg2; + u32 rx_class_gates_base; + u32 rx_green; + u32 rx_rate_cfg_base; + u32 rx_rate_src_sel0; + u32 rx_rate_src_sel1; + u32 tx_rate_cfg_base; + u32 stat_base; + u32 tx_hsr_tag; + u32 tx_hsr_seq; + u32 tx_vlan_type; + u32 tx_vlan_ins; +}; + +static struct miig_rt_offsets offs[] = { + /* PRU0 */ + { + 0x8, + 0xc, + 0x80, + 0x84, + 0x88, + 0x108, + 0x308, + 0x408, + 0x40c, + 0x48c, + 0x490, + 0x494, + 0x4d4, + 0x4e4, + 0x504, + 0x508, + 0x50c, + 0x54c, + 0x63c, + 0x640, + 0x644, + 0x648, + }, + /* PRU1 */ + { + 0x10, + 0x14, + 0x64c, + 0x650, + 0x654, + 0x6d4, + 0x8d4, + 0x9d4, + 0x9d8, + 0xa58, + 0xa5c, + 0xa60, + 0xaa0, + 0xab0, + 0xad0, + 0xad4, + 0xad8, + 0xb18, + 0xc08, + 0xc0c, + 0xc10, + 0xc14, + }, +}; + +static inline u32 addr_to_da0(const u8 *addr) +{ + return (u32)(addr[0] | addr[1] << 8 | + addr[2] << 16 | addr[3] << 24); +}; + +static inline u32 addr_to_da1(const u8 *addr) +{ + return (u32)(addr[4] | addr[5] << 8); +}; + +static void rx_class_ft1_set_start_len(struct regmap *miig_rt, int slice, + u16 start, u8 len) +{ + u32 offset, val; + + offset = offs[slice].ft1_start_len; + val = FT1_LEN(len) | FT1_START(start); + regmap_write(miig_rt, offset, val); +} + +static void rx_class_ft1_set_da(struct regmap *miig_rt, int slice, + int n, const u8 *addr) +{ + u32 offset; + + offset = FT1_N_REG(slice, n, FT1_DA0); + regmap_write(miig_rt, offset, addr_to_da0(addr)); + offset = FT1_N_REG(slice, n, FT1_DA1); + regmap_write(miig_rt, offset, addr_to_da1(addr)); +} + +static void rx_class_ft1_set_da_mask(struct regmap *miig_rt, int slice, + int n, const u8 *addr) +{ + u32 offset; + + offset = FT1_N_REG(slice, n, FT1_DA0_MASK); + regmap_write(miig_rt, offset, addr_to_da0(addr)); + offset = FT1_N_REG(slice, n, FT1_DA1_MASK); + regmap_write(miig_rt, offset, addr_to_da1(addr)); +} + +static void rx_class_ft1_cfg_set_type(struct regmap *miig_rt, int slice, int n, + enum ft1_cfg_type type) +{ + u32 offset; + + offset = offs[slice].ft1_cfg; + regmap_update_bits(miig_rt, offset, FT1_CFG_MASK(n), + type << FT1_CFG_SHIFT(n)); +} + +static void rx_class_sel_set_type(struct regmap *miig_rt, int slice, int n, + enum rx_class_sel_type type) +{ + u32 offset; + + offset = offs[slice].rx_class_cfg1; + regmap_update_bits(miig_rt, offset, RX_CLASS_SEL_MASK(n), + type << RX_CLASS_SEL_SHIFT(n)); +} + +static void rx_class_set_and(struct regmap *miig_rt, int slice, int n, + u32 data) +{ + u32 offset; + + offset = RX_CLASS_N_REG(slice, n, RX_CLASS_AND_EN); + regmap_write(miig_rt, offset, data); +} + +static void rx_class_set_or(struct regmap *miig_rt, int slice, int n, + u32 data) +{ + u32 offset; + + offset = RX_CLASS_N_REG(slice, n, RX_CLASS_OR_EN); + regmap_write(miig_rt, offset, data); +} + +void icssg_class_set_host_mac_addr(struct regmap *miig_rt, u8 *mac) +{ + regmap_write(miig_rt, MAC_INTERFACE_0, addr_to_da0(mac)); + regmap_write(miig_rt, MAC_INTERFACE_1, addr_to_da1(mac)); +} + +void icssg_class_set_mac_addr(struct regmap *miig_rt, int slice, u8 *mac) +{ + regmap_write(miig_rt, offs[slice].mac0, addr_to_da0(mac)); + regmap_write(miig_rt, offs[slice].mac1, addr_to_da1(mac)); +} + +void icssg_class_disable_n(struct regmap *miig_rt, int slice, int n) +{ + u32 data, offset; + + /* AND_EN = 0 */ + rx_class_set_and(miig_rt, slice, n, 0); + /* OR_EN = 0 */ + rx_class_set_or(miig_rt, slice, n, 0); + + /* set CFG1 to OR */ + rx_class_sel_set_type(miig_rt, slice, n, RX_CLASS_SEL_TYPE_OR); + + /* configure gate */ + offset = RX_CLASS_GATES_N_REG(slice, n); + regmap_read(miig_rt, offset, &data); + /* clear class_raw so we go through filters */ + data &= ~RX_CLASS_GATES_RAW_MASK; + /* set allow and phase mask */ + data |= RX_CLASS_GATES_ALLOW_MASK | RX_CLASS_GATES_PHASE_MASK; + regmap_write(miig_rt, offset, data); +} + +/* disable all RX traffic */ +void icssg_class_disable(struct regmap *miig_rt, int slice) +{ + int n; + + /* Enable RX_L2_G */ + regmap_update_bits(miig_rt, ICSSG_CFG_OFFSET, ICSSG_CFG_RX_L2_G_EN, + ICSSG_CFG_RX_L2_G_EN); + + for (n = 0; n < ICSSG_NUM_CLASSIFIERS; n++) + icssg_class_disable_n(miig_rt, slice, n); + + /* FT1 Disabled */ + for (n = 0; n < ICSSG_NUM_FT1_SLOTS; n++) { + u8 addr[] = { 0, 0, 0, 0, 0, 0, }; + + rx_class_ft1_cfg_set_type(miig_rt, slice, n, + FT1_CFG_TYPE_DISABLED); + rx_class_ft1_set_da(miig_rt, slice, n, addr); + rx_class_ft1_set_da_mask(miig_rt, slice, n, addr); + } + + /* clear CFG2 */ + regmap_write(miig_rt, offs[slice].rx_class_cfg2, 0); +} + +void icssg_class_default(struct regmap *miig_rt, int slice, bool allmulti) +{ + u32 data; + + /* defaults */ + icssg_class_disable(miig_rt, slice); + + /* Setup Classifier */ + /* match on Broadcast or MAC_PRU address */ + data = RX_CLASS_FT_BC | RX_CLASS_FT_DA_P; + + /* multicast? */ + if (allmulti) + data |= RX_CLASS_FT_MC; + + rx_class_set_or(miig_rt, slice, 0, data); + + /* set CFG1 for OR_OR_AND for classifier */ + rx_class_sel_set_type(miig_rt, slice, 0, + RX_CLASS_SEL_TYPE_OR_OR_AND); + + /* clear CFG2 */ + regmap_write(miig_rt, offs[slice].rx_class_cfg2, 0); +} + +/* required for SR2 for SAV check */ +void icssg_ft1_set_mac_addr(struct regmap *miig_rt, int slice, u8 *mac_addr) +{ + u8 mask_addr[] = { 0, 0, 0, 0, 0, 0, }; + + rx_class_ft1_set_start_len(miig_rt, slice, 6, 6); + rx_class_ft1_set_da(miig_rt, slice, 0, mac_addr); + rx_class_ft1_set_da_mask(miig_rt, slice, 0, mask_addr); + rx_class_ft1_cfg_set_type(miig_rt, slice, 0, FT1_CFG_TYPE_EQ); +} diff --git a/drivers/net/ti/icssg_config.c b/drivers/net/ti/icssg_config.c new file mode 100644 index 0000000000..0dc2c0fa3a --- /dev/null +++ b/drivers/net/ti/icssg_config.c @@ -0,0 +1,397 @@ +// SPDX-License-Identifier: GPL-2.0 +/* ICSSG Ethernet driver + * + * Copyright (C) 2020 Texas Instruments Incorporated - http://www.ti.com + */ + +#include <phy.h> +#include "icssg_prueth.h" +#include "icssg_switch_map.h" +#include "icss_mii_rt.h" +#include <dm/device_compat.h> + +/* TX IPG Values to be set for 100M and 1G link speeds. These values are + * in ocp_clk cycles. So need change if ocp_clk is changed for a specific + * h/w design. + */ + +/* SR2.0 IPG is in rgmii_clk (125MHz) clock cycles + 1 */ +#define MII_RT_TX_IPG_100M 0x17 +#define MII_RT_TX_IPG_1G 0xb + +#define ICSSG_QUEUES_MAX 64 +#define ICSSG_QUEUE_OFFSET 0xd00 +#define ICSSG_QUEUE_PEEK_OFFSET 0xe00 +#define ICSSG_QUEUE_CNT_OFFSET 0xe40 +#define ICSSG_QUEUE_RESET_OFFSET 0xf40 + +#define ICSSG_NUM_TX_QUEUES 8 + +#define RECYCLE_Q_SLICE0 16 +#define RECYCLE_Q_SLICE1 17 + +#define ICSSG_NUM_OTHER_QUEUES 5 /* port, host and special queues */ + +#define PORT_HI_Q_SLICE0 32 +#define PORT_LO_Q_SLICE0 33 +#define HOST_HI_Q_SLICE0 34 +#define HOST_LO_Q_SLICE0 35 +#define HOST_SPL_Q_SLICE0 40 /* Special Queue */ + +#define PORT_HI_Q_SLICE1 36 +#define PORT_LO_Q_SLICE1 37 +#define HOST_HI_Q_SLICE1 38 +#define HOST_LO_Q_SLICE1 39 +#define HOST_SPL_Q_SLICE1 41 /* Special Queue */ + +#define MII_RXCFG_DEFAULT (PRUSS_MII_RT_RXCFG_RX_ENABLE | \ + PRUSS_MII_RT_RXCFG_RX_DATA_RDY_MODE_DIS | \ + PRUSS_MII_RT_RXCFG_RX_L2_EN | \ + PRUSS_MII_RT_RXCFG_RX_L2_EOF_SCLR_DIS) + +#define MII_TXCFG_DEFAULT (PRUSS_MII_RT_TXCFG_TX_ENABLE | \ + PRUSS_MII_RT_TXCFG_TX_AUTO_PREAMBLE | \ + PRUSS_MII_RT_TXCFG_TX_32_MODE_EN | \ + PRUSS_MII_RT_TXCFG_TX_IPG_WIRE_CLK_EN) + +#define ICSSG_CFG_DEFAULT (ICSSG_CFG_TX_L1_EN | \ + ICSSG_CFG_TX_L2_EN | ICSSG_CFG_RX_L2_G_EN | \ + ICSSG_CFG_TX_PRU_EN | /* SR2.0 only */ \ + ICSSG_CFG_SGMII_MODE) + +#define FDB_GEN_CFG1 0x60 +#define SMEM_VLAN_OFFSET 8 +#define SMEM_VLAN_OFFSET_MASK GENMASK(25, 8) + +#define FDB_GEN_CFG2 0x64 +#define FDB_VLAN_EN BIT(6) +#define FDB_HOST_EN BIT(2) +#define FDB_PRU1_EN BIT(1) +#define FDB_PRU0_EN BIT(0) +#define FDB_EN_ALL (FDB_PRU0_EN | FDB_PRU1_EN | \ + FDB_HOST_EN | FDB_VLAN_EN) + +struct map { + int queue; + u32 pd_addr_start; + u32 flags; + bool special; +}; + +struct map hwq_map[2][ICSSG_NUM_OTHER_QUEUES] = { + { + { PORT_HI_Q_SLICE0, PORT_DESC0_HI, 0x200000, 0 }, + { PORT_LO_Q_SLICE0, PORT_DESC0_LO, 0, 0 }, + { HOST_HI_Q_SLICE0, HOST_DESC0_HI, 0x200000, 0 }, + { HOST_LO_Q_SLICE0, HOST_DESC0_LO, 0, 0 }, + { HOST_SPL_Q_SLICE0, HOST_SPPD0, 0x400000, 1 }, + }, + { + { PORT_HI_Q_SLICE1, PORT_DESC1_HI, 0xa00000, 0 }, + { PORT_LO_Q_SLICE1, PORT_DESC1_LO, 0x800000, 0 }, + { HOST_HI_Q_SLICE1, HOST_DESC1_HI, 0xa00000, 0 }, + { HOST_LO_Q_SLICE1, HOST_DESC1_LO, 0x800000, 0 }, + { HOST_SPL_Q_SLICE1, HOST_SPPD1, 0xc00000, 1 }, + }, +}; + +static void icssg_config_mii_init(struct prueth *prueth, int slice) +{ + struct regmap *mii_rt = prueth->mii_rt; + u32 txcfg_reg, pcnt_reg; + u32 txcfg; + + txcfg_reg = (slice == ICSS_MII0) ? PRUSS_MII_RT_TXCFG0 : + PRUSS_MII_RT_TXCFG1; + pcnt_reg = (slice == ICSS_MII0) ? PRUSS_MII_RT_RX_PCNT0 : + PRUSS_MII_RT_RX_PCNT1; + + txcfg = MII_TXCFG_DEFAULT; + + if (prueth->phy_interface == PHY_INTERFACE_MODE_MII && slice == ICSS_MII0) + txcfg |= PRUSS_MII_RT_TXCFG_TX_MUX_SEL; + else if (prueth->phy_interface != PHY_INTERFACE_MODE_MII && slice == ICSS_MII1) + txcfg |= PRUSS_MII_RT_TXCFG_TX_MUX_SEL; + + regmap_write(mii_rt, txcfg_reg, txcfg); + regmap_write(mii_rt, pcnt_reg, 0x1); +} + +static void icssg_miig_queues_init(struct prueth *prueth, int slice) +{ + void __iomem *smem = (void __iomem *)prueth->shram.pa; + struct regmap *miig_rt = prueth->miig_rt; + int queue = 0, i, j; + u8 pd[ICSSG_SPECIAL_PD_SIZE]; + u32 *pdword; + + /* reset hwqueues */ + if (slice) + queue = ICSSG_NUM_TX_QUEUES; + + for (i = 0; i < ICSSG_NUM_TX_QUEUES; i++) { + regmap_write(miig_rt, ICSSG_QUEUE_RESET_OFFSET, queue); + queue++; + } + + queue = slice ? RECYCLE_Q_SLICE1 : RECYCLE_Q_SLICE0; + regmap_write(miig_rt, ICSSG_QUEUE_RESET_OFFSET, queue); + + for (i = 0; i < ICSSG_NUM_OTHER_QUEUES; i++) { + regmap_write(miig_rt, ICSSG_QUEUE_RESET_OFFSET, + hwq_map[slice][i].queue); + } + + /* initialize packet descriptors in SMEM */ + /* push pakcet descriptors to hwqueues */ + + pdword = (u32 *)pd; + for (j = 0; j < ICSSG_NUM_OTHER_QUEUES; j++) { + struct map *mp; + int pd_size, num_pds; + u32 pdaddr; + + mp = &hwq_map[slice][j]; + if (mp->special) { + pd_size = ICSSG_SPECIAL_PD_SIZE; + num_pds = ICSSG_NUM_SPECIAL_PDS; + } else { + pd_size = ICSSG_NORMAL_PD_SIZE; + num_pds = ICSSG_NUM_NORMAL_PDS; + } + + for (i = 0; i < num_pds; i++) { + memset(pd, 0, pd_size); + + pdword[0] &= cpu_to_le32(ICSSG_FLAG_MASK); + pdword[0] |= cpu_to_le32(mp->flags); + pdaddr = mp->pd_addr_start + i * pd_size; + + memcpy_toio(smem + pdaddr, pd, pd_size); + queue = mp->queue; + regmap_write(miig_rt, ICSSG_QUEUE_OFFSET + 4 * queue, + pdaddr); + } + } +} + +void icssg_config_ipg(struct prueth *prueth, int speed, int mii) +{ + switch (speed) { + case SPEED_1000: + icssg_mii_update_ipg(prueth->mii_rt, mii, MII_RT_TX_IPG_1G); + break; + case SPEED_100: + icssg_mii_update_ipg(prueth->mii_rt, mii, MII_RT_TX_IPG_100M); + break; + default: + /* Other links speeds not supported */ + pr_err("Unsupported link speed\n"); + return; + } +} + +static void emac_r30_cmd_init(struct prueth *prueth) +{ + int i; + struct icssg_r30_cmd *p; + + p = (struct icssg_r30_cmd *)(prueth->dram.pa + MGR_R30_CMD_OFFSET); + + for (i = 0; i < 4; i++) + writel(EMAC_NONE, &p->cmd[i]); +} + +static int emac_r30_is_done(struct prueth *prueth) +{ + const struct icssg_r30_cmd *p; + int i; + u32 cmd; + + p = (const struct icssg_r30_cmd *)(prueth->dram.pa + MGR_R30_CMD_OFFSET); + + for (i = 0; i < 4; i++) { + cmd = readl(&p->cmd[i]); + if (cmd != EMAC_NONE) + return 0; + } + + return 1; +} + +static int prueth_emac_buffer_setup(struct prueth *prueth) +{ + struct icssg_buffer_pool_cfg *bpool_cfg; + struct icssg_rxq_ctx *rxq_ctx; + int slice = prueth->slice; + u32 addr; + int i; + + /* Layout to have 64KB aligned buffer pool + * |BPOOL0|BPOOL1|RX_CTX0|RX_CTX1| + */ + + addr = lower_32_bits(prueth->sram_pa); + if (slice) + addr += PRUETH_NUM_BUF_POOLS * PRUETH_EMAC_BUF_POOL_SIZE; + + if (addr % SZ_64K) { + dev_warn(prueth->dev, "buffer pool needs to be 64KB aligned\n"); + return -EINVAL; + } + + bpool_cfg = (struct icssg_buffer_pool_cfg *)(prueth->dram.pa + BUFFER_POOL_0_ADDR_OFFSET); + /* workaround for f/w bug. bpool 0 needs to be initilalized */ + bpool_cfg[0].addr = cpu_to_le32(addr); + bpool_cfg[0].len = 0; + + for (i = PRUETH_EMAC_BUF_POOL_START; + i < (PRUETH_EMAC_BUF_POOL_START + PRUETH_NUM_BUF_POOLS); + i++) { + bpool_cfg[i].addr = cpu_to_le32(addr); + bpool_cfg[i].len = cpu_to_le32(PRUETH_EMAC_BUF_POOL_SIZE); + addr += PRUETH_EMAC_BUF_POOL_SIZE; + } + + if (!slice) + addr += PRUETH_NUM_BUF_POOLS * PRUETH_EMAC_BUF_POOL_SIZE; + else + addr += PRUETH_EMAC_RX_CTX_BUF_SIZE * 2; + + rxq_ctx = (struct icssg_rxq_ctx *)(prueth->dram.pa + HOST_RX_Q_PRE_CONTEXT_OFFSET); + + for (i = 0; i < 3; i++) + rxq_ctx->start[i] = cpu_to_le32(addr); + + addr += PRUETH_EMAC_RX_CTX_BUF_SIZE; + rxq_ctx->end = cpu_to_le32(addr); + + /* Express RX buffer queue */ + rxq_ctx = (struct icssg_rxq_ctx *)(prueth->dram.pa + HOST_RX_Q_EXP_CONTEXT_OFFSET); + for (i = 0; i < 3; i++) + rxq_ctx->start[i] = cpu_to_le32(addr); + + addr += PRUETH_EMAC_RX_CTX_BUF_SIZE; + rxq_ctx->end = cpu_to_le32(addr); + + return 0; +} + +static void icssg_init_emac_mode(struct prueth *prueth) +{ + u8 mac[6] = { 0 }; + + regmap_update_bits(prueth->miig_rt, FDB_GEN_CFG1, SMEM_VLAN_OFFSET_MASK, 0); + regmap_write(prueth->miig_rt, FDB_GEN_CFG2, 0); + /* Clear host MAC address */ + icssg_class_set_host_mac_addr(prueth->miig_rt, mac); +} + +int icssg_config(struct prueth *prueth) +{ + void *config = (void *)(prueth->dram.pa + ICSSG_CONFIG_OFFSET); + u8 *cfg_byte_ptr = config; + struct icssg_flow_cfg *flow_cfg; + u32 mask; + int ret; + + int slice = prueth->slice; + + icssg_init_emac_mode(prueth); + + memset_io(config, 0, TAS_GATE_MASK_LIST0); + icssg_miig_queues_init(prueth, slice); + + prueth->speed = SPEED_1000; + prueth->duplex = DUPLEX_FULL; + if (!phy_interface_is_rgmii(prueth->phydev)) { + prueth->speed = SPEED_100; + prueth->duplex = DUPLEX_FULL; + } + + regmap_update_bits(prueth->miig_rt, ICSSG_CFG_OFFSET, + ICSSG_CFG_DEFAULT, ICSSG_CFG_DEFAULT); + icssg_miig_set_interface_mode(prueth->miig_rt, ICSS_MII0, prueth->phy_interface); + icssg_miig_set_interface_mode(prueth->miig_rt, ICSS_MII1, prueth->phy_interface); + icssg_config_mii_init(prueth, slice); + + icssg_config_ipg(prueth, SPEED_1000, slice); + icssg_update_rgmii_cfg(prueth->miig_rt, SPEED_1000, true, slice, prueth); + + /* set GPI mode */ + pruss_cfg_gpimode(prueth->pruss, slice, PRUSS_GPI_MODE_MII); + + /* enable XFR shift for PRU and RTU */ + mask = PRUSS_SPP_XFER_SHIFT_EN | PRUSS_SPP_RTU_XFR_SHIFT_EN; + pruss_cfg_update(prueth->pruss, PRUSS_CFG_SPP, mask, mask); + + flow_cfg = config + PSI_L_REGULAR_FLOW_ID_BASE_OFFSET; + flow_cfg->rx_base_flow = prueth->dma_rx.id; + flow_cfg->mgm_base_flow = 0; + *(cfg_byte_ptr + SPL_PKT_DEFAULT_PRIORITY) = 0; + *(cfg_byte_ptr + QUEUE_NUM_UNTAGGED) = 0x0; + + ret = prueth_emac_buffer_setup(prueth); + + if (ret) + return ret; + + emac_r30_cmd_init(prueth); + return 0; +} + +/* commands to program ICSSG R30 registers */ +static struct icssg_r30_cmd emac_r32_bitmask[] = { + {{0xffff0004, 0xffff0100, 0xffff0004, EMAC_NONE}}, /* EMAC_PORT_DISABLE */ + {{0xfffb0040, 0xfeff0200, 0xfeff0200, EMAC_NONE}}, /* EMAC_PORT_BLOCK */ + {{0xffbb0000, 0xfcff0000, 0xdcfb0000, EMAC_NONE}}, /* EMAC_PORT_FORWARD */ + {{0xffbb0000, 0xfcff0000, 0xfcff2000, EMAC_NONE}}, /* EMAC_PORT_FORWARD_WO_LEARNING */ + {{0xffff0001, EMAC_NONE, EMAC_NONE, EMAC_NONE}}, /* ACCEPT ALL */ + {{0xfffe0002, EMAC_NONE, EMAC_NONE, EMAC_NONE}}, /* ACCEPT TAGGED */ + {{0xfffc0000, EMAC_NONE, EMAC_NONE, EMAC_NONE}}, /* ACCEPT UNTAGGED and PRIO */ + {{EMAC_NONE, 0xffff0020, EMAC_NONE, EMAC_NONE}}, /* TAS Trigger List change */ + {{EMAC_NONE, 0xdfff1000, EMAC_NONE, EMAC_NONE}}, /* TAS set state ENABLE*/ + {{EMAC_NONE, 0xefff2000, EMAC_NONE, EMAC_NONE}}, /* TAS set state RESET*/ + {{EMAC_NONE, 0xcfff0000, EMAC_NONE, EMAC_NONE}}, /* TAS set state DISABLE*/ + {{EMAC_NONE, EMAC_NONE, 0xffff0400, EMAC_NONE}}, /* UC flooding ENABLE*/ + {{EMAC_NONE, EMAC_NONE, 0xfbff0000, EMAC_NONE}}, /* UC flooding DISABLE*/ + {{EMAC_NONE, EMAC_NONE, 0xffff0800, EMAC_NONE}}, /* MC flooding ENABLE*/ + {{EMAC_NONE, EMAC_NONE, 0xf7ff0000, EMAC_NONE}}, /* MC flooding DISABLE*/ + {{EMAC_NONE, 0xffff4000, EMAC_NONE, EMAC_NONE}}, /* Preemption on Tx ENABLE*/ + {{EMAC_NONE, 0xbfff0000, EMAC_NONE, EMAC_NONE}} /* Preemption on Tx DISABLE*/ +}; + +int emac_set_port_state(struct prueth *prueth, + enum icssg_port_state_cmd cmd) +{ + struct icssg_r30_cmd *p; + int ret = -ETIMEDOUT; + int timeout = 10; + int i; + + p = (struct icssg_r30_cmd *)(prueth->dram.pa + MGR_R30_CMD_OFFSET); + + if (cmd >= ICSSG_EMAC_PORT_MAX_COMMANDS) { + dev_err(prueth->dev, "invalid port command\n"); + return -EINVAL; + } + + for (i = 0; i < 4; i++) + writel(emac_r32_bitmask[cmd].cmd[i], &p->cmd[i]); + + /* wait for done */ + while (timeout) { + if (emac_r30_is_done(prueth)) { + ret = 0; + break; + } + + udelay(2000); + timeout--; + } + + if (ret == -ETIMEDOUT) + dev_err(prueth->dev, "timeout waiting for command done\n"); + + return ret; +} diff --git a/drivers/net/ti/icssg_config.h b/drivers/net/ti/icssg_config.h new file mode 100644 index 0000000000..fc6eae0426 --- /dev/null +++ b/drivers/net/ti/icssg_config.h @@ -0,0 +1,177 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* Texas Instruments ICSSG Ethernet driver + * + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + * + */ + +#ifndef __NET_TI_ICSSG_CONFIG_H +#define __NET_TI_ICSSG_CONFIG_H + +struct icssg_buffer_pool_cfg { + __le32 addr; + __le32 len; +} __packed; + +struct icssg_flow_cfg { + __le16 rx_base_flow; + __le16 mgm_base_flow; +} __packed; + +/* Config area lies in shared RAM */ +#define ICSSG_CONFIG_OFFSET_SLICE0 0 +#define ICSSG_CONFIG_OFFSET_SLICE1 0x8000 + +/* pstate speed/duplex command to set speed and duplex settings + * in firmware. + * Command format : 0x8102ssPN. ss - sequence number: currently not + * used by driver, P - port number: For switch, N - Speed/Duplex state + * - Possible values of N: + * 0x0 - 10Mbps/Half duplex ; + * 0x8 - 10Mbps/Full duplex ; + * 0x2 - 100Mbps/Half duplex; + * 0xa - 100Mbps/Full duplex; + * 0xc - 1Gbps/Full duplex; + * NOTE: The above are same as bits [3..1](slice 0) or bits [8..6](slice 1) of + * RGMII CFG register. So suggested to read the register to populate the command + * bits. + */ +#define ICSSG_PSTATE_SPEED_DUPLEX_CMD 0x81020000 +#define ICSSG_PSTATE_FULL_DUPLEX BIT(3) +#define ICSSG_PSTATE_SPEED_100 BIT(1) +#define ICSSG_PSTATE_SPEED_1000 BIT(2) + +/* Flow IDs used in config structure to firmware. Should match with + * flow_id in struct dma for rx channels. + */ +#define ICSSG_RX_CHAN_FLOW_ID 0 /* flow id for host port */ +#define ICSSG_RX_MGM_CHAN_FLOW_ID 1 /* flow id for command response */ + +/* Used to notify the FW of the current link speed */ +#define PORT_LINK_SPEED_OFFSET 0x00A8 + +#define FW_LINK_SPEED_1G (0x00) +#define FW_LINK_SPEED_100M (0x01) +#define FW_LINK_SPEED_10M (0x02) +#define FW_LINK_SPEED_HD (0x80) + +#define PRUETH_PKT_TYPE_CMD 0x10 +#define PRUETH_NAV_PS_DATA_SIZE 16 /* Protocol specific data size */ +#define PRUETH_NAV_SW_DATA_SIZE 16 /* SW related data size */ +#define PRUETH_MAX_RX_FLOWS 1 /* excluding default flow */ +#define PRUETH_RX_FLOW_DATA 0 /* FIXME: f/w bug to change to highest priority flow */ + +#define PRUETH_EMAC_BUF_POOL_SIZE SZ_8K +#define PRUETH_EMAC_POOLS_PER_SLICE 24 +#define PRUETH_EMAC_BUF_POOL_START 8 +#define PRUETH_NUM_BUF_POOLS 8 +#define PRUETH_EMAC_RX_CTX_BUF_SIZE SZ_16K /* per slice */ +#define MSMC_RAM_SIZE (2 * (PRUETH_EMAC_BUF_POOL_SIZE * PRUETH_NUM_BUF_POOLS + \ + PRUETH_EMAC_RX_CTX_BUF_SIZE)) + +struct icssg_rxq_ctx { + __le32 start[3]; + __le32 end; +} __packed; + +/* Load time Fiwmware Configuration */ + +#define ICSSG_FW_MGMT_CMD_HEADER 0x81 +#define ICSSG_FW_MGMT_FDB_CMD_TYPE 0x03 +#define ICSSG_FW_MGMT_CMD_TYPE 0x04 +#define ICSSG_FW_MGMT_PKT 0x80000000 + +struct icssg_r30_cmd { + u32 cmd[4]; +} __packed; + +enum icssg_port_state_cmd { + ICSSG_EMAC_PORT_DISABLE = 0, + ICSSG_EMAC_PORT_BLOCK, + ICSSG_EMAC_PORT_FORWARD, + ICSSG_EMAC_PORT_FORWARD_WO_LEARNING, + ICSSG_EMAC_PORT_ACCEPT_ALL, + ICSSG_EMAC_PORT_ACCEPT_TAGGED, + ICSSG_EMAC_PORT_ACCEPT_UNTAGGED_N_PRIO, + ICSSG_EMAC_PORT_TAS_TRIGGER, + ICSSG_EMAC_PORT_TAS_ENABLE, + ICSSG_EMAC_PORT_TAS_RESET, + ICSSG_EMAC_PORT_TAS_DISABLE, + ICSSG_EMAC_PORT_UC_FLOODING_ENABLE, + ICSSG_EMAC_PORT_UC_FLOODING_DISABLE, + ICSSG_EMAC_PORT_MC_FLOODING_ENABLE, + ICSSG_EMAC_PORT_MC_FLOODING_DISABLE, + ICSSG_EMAC_PORT_PREMPT_TX_ENABLE, + ICSSG_EMAC_PORT_PREMPT_TX_DISABLE, + ICSSG_EMAC_PORT_MAX_COMMANDS +}; + +#define EMAC_NONE 0xffff0000 +#define EMAC_PRU0_P_DI 0xffff0004 +#define EMAC_PRU1_P_DI 0xffff0040 +#define EMAC_TX_P_DI 0xffff0100 + +#define EMAC_PRU0_P_EN 0xfffb0000 +#define EMAC_PRU1_P_EN 0xffbf0000 +#define EMAC_TX_P_EN 0xfeff0000 + +#define EMAC_P_BLOCK 0xffff0040 +#define EMAC_TX_P_BLOCK 0xffff0200 +#define EMAC_P_UNBLOCK 0xffbf0000 +#define EMAC_TX_P_UNBLOCK 0xfdff0000 +#define EMAC_LEAN_EN 0xfff70000 +#define EMAC_LEAN_DI 0xffff0008 + +#define EMAC_ACCEPT_ALL 0xffff0001 +#define EMAC_ACCEPT_TAG 0xfffe0002 +#define EMAC_ACCEPT_PRIOR 0xfffc0000 + +/* Config area lies in DRAM */ +#define ICSSG_CONFIG_OFFSET 0x0 + +#define ICSSG_NUM_NORMAL_PDS 64 +#define ICSSG_NUM_SPECIAL_PDS 16 + +#define ICSSG_NORMAL_PD_SIZE 8 +#define ICSSG_SPECIAL_PD_SIZE 20 + +#define ICSSG_FLAG_MASK 0xff00ffff + +struct icssg_setclock_desc { + u8 request; + u8 restore; + u8 acknowledgment; + u8 cmp_status; + u32 margin; + u32 cyclecounter0_set; + u32 cyclecounter1_set; + u32 iepcount_set; + u32 rsvd1; + u32 rsvd2; + u32 CMP0_current; + u32 iepcount_current; + u32 difference; + u32 cyclecounter0_new; + u32 cyclecounter1_new; + u32 CMP0_new; +} __packed; + +#define ICSSG_CMD_POP_SLICE0 56 +#define ICSSG_CMD_POP_SLICE1 60 + +#define ICSSG_CMD_PUSH_SLICE0 57 +#define ICSSG_CMD_PUSH_SLICE1 61 + +#define ICSSG_RSP_POP_SLICE0 58 +#define ICSSG_RSP_POP_SLICE1 62 + +#define ICSSG_RSP_PUSH_SLICE0 56 +#define ICSSG_RSP_PUSH_SLICE1 60 + +#define ICSSG_TS_POP_SLICE0 59 +#define ICSSG_TS_POP_SLICE1 63 + +#define ICSSG_TS_PUSH_SLICE0 40 +#define ICSSG_TS_PUSH_SLICE1 41 + +#endif /* __NET_TI_ICSSG_CONFIG_H */ diff --git a/drivers/net/ti/icssg_prueth.h b/drivers/net/ti/icssg_prueth.h new file mode 100644 index 0000000000..26b77dd8f3 --- /dev/null +++ b/drivers/net/ti/icssg_prueth.h @@ -0,0 +1,78 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Texas Instruments K3 AM65 Ethernet Switch SubSystem Driver + * + * Copyright (C) 2019, Texas Instruments, Incorporated + * + */ + +#ifndef __NET_TI_ICSSG_PRUETH_H +#define __NET_TI_ICSSG_PRUETH_H + +#include <asm/io.h> +#include <clk.h> +#include <dm/lists.h> +#include <dm/ofnode.h> +#include <dm/device.h> +#include <dma-uclass.h> +#include <regmap.h> +#include <linux/sizes.h> +#include <linux/pruss_driver.h> +#include "icssg_config.h" +#include "icssg_switch_map.h" + +void icssg_class_set_mac_addr(struct regmap *miig_rt, int slice, u8 *mac); +void icssg_class_set_host_mac_addr(struct regmap *miig_rt, u8 *mac); +void icssg_class_disable(struct regmap *miig_rt, int slice); +void icssg_class_default(struct regmap *miig_rt, int slice, bool allmulti); +void icssg_ft1_set_mac_addr(struct regmap *miig_rt, int slice, u8 *mac_addr); + +enum prueth_mac { + PRUETH_MAC0 = 0, + PRUETH_MAC1, + PRUETH_NUM_MACS, +}; + +enum prueth_port { + PRUETH_PORT_HOST = 0, /* host side port */ + PRUETH_PORT_MII0, /* physical port MII 0 */ + PRUETH_PORT_MII1, /* physical port MII 1 */ +}; + +struct prueth { + struct udevice *dev; + struct udevice *pruss; + struct regmap *miig_rt; + struct regmap *mii_rt; + fdt_addr_t mdio_base; + struct pruss_mem_region shram; + struct pruss_mem_region dram; + phys_addr_t tmaddr; + struct mii_dev *bus; + u32 port_id; + u32 sram_pa; + struct phy_device *phydev; + bool has_phy; + ofnode phy_node; + u32 phy_addr; + ofnode eth_node[PRUETH_NUM_MACS]; + u32 mdio_freq; + int phy_interface; + struct clk mdiofck; + struct dma dma_tx; + struct dma dma_rx; + struct dma dma_rx_mgm; + u32 rx_next; + u32 rx_pend; + int slice; + bool mdio_manual_mode; + int speed; + int duplex; +}; + +/* config helpers */ +void icssg_config_ipg(struct prueth *prueth, int speed, int mii); +int icssg_config(struct prueth *prueth); +int emac_set_port_state(struct prueth *prueth, enum icssg_port_state_cmd cmd); + +#endif /* __NET_TI_ICSSG_PRUETH_H */
Add icssg_queue.c file. This file introduces macros and APIs related to ICSSG queues. These will be used by ICSSG Ethernet driver.
Signed-off-by: MD Danish Anwar danishanwar@ti.com --- drivers/net/ti/icssg_prueth.h | 5 ++++ drivers/net/ti/icssg_queues.c | 51 +++++++++++++++++++++++++++++++++++ 2 files changed, 56 insertions(+) create mode 100644 drivers/net/ti/icssg_queues.c
diff --git a/drivers/net/ti/icssg_prueth.h b/drivers/net/ti/icssg_prueth.h index 26b77dd8f3..f34ab5d6d4 100644 --- a/drivers/net/ti/icssg_prueth.h +++ b/drivers/net/ti/icssg_prueth.h @@ -75,4 +75,9 @@ void icssg_config_ipg(struct prueth *prueth, int speed, int mii); int icssg_config(struct prueth *prueth); int emac_set_port_state(struct prueth *prueth, enum icssg_port_state_cmd cmd);
+/* Buffer queue helpers */ +int icssg_queue_pop(struct prueth *prueth, u8 queue); +void icssg_queue_push(struct prueth *prueth, int queue, u16 addr); +u32 icssg_queue_level(struct prueth *prueth, int queue); + #endif /* __NET_TI_ICSSG_PRUETH_H */ diff --git a/drivers/net/ti/icssg_queues.c b/drivers/net/ti/icssg_queues.c new file mode 100644 index 0000000000..6a95ef5d58 --- /dev/null +++ b/drivers/net/ti/icssg_queues.c @@ -0,0 +1,51 @@ +// SPDX-License-Identifier: GPL-2.0 +/* ICSSG Buffer queue helpers + * + * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com + */ + +#include <dm/ofnode.h> +#include <regmap.h> +#include "icssg_prueth.h" + +#define ICSSG_QUEUES_MAX 64 +#define ICSSG_QUEUE_OFFSET 0xd00 +#define ICSSG_QUEUE_PEEK_OFFSET 0xe00 +#define ICSSG_QUEUE_CNT_OFFSET 0xe40 +#define ICSSG_QUEUE_RESET_OFFSET 0xf40 + +int icssg_queue_pop(struct prueth *prueth, u8 queue) +{ + u32 val, cnt; + + if (queue >= ICSSG_QUEUES_MAX) + return -EINVAL; + + regmap_read(prueth->miig_rt, ICSSG_QUEUE_CNT_OFFSET + 4 * queue, &cnt); + if (!cnt) + return -EINVAL; + + regmap_read(prueth->miig_rt, ICSSG_QUEUE_OFFSET + 4 * queue, &val); + + return val; +} + +void icssg_queue_push(struct prueth *prueth, int queue, u16 addr) +{ + if (queue >= ICSSG_QUEUES_MAX) + return; + + regmap_write(prueth->miig_rt, ICSSG_QUEUE_OFFSET + 4 * queue, addr); +} + +u32 icssg_queue_level(struct prueth *prueth, int queue) +{ + u32 reg; + + if (queue >= ICSSG_QUEUES_MAX) + return 0; + + regmap_read(prueth->miig_rt, ICSSG_QUEUE_CNT_OFFSET + 4 * queue, ®); + + return reg; +}
This is the PURSS Ethernet driver for TI AM654 Sr2.0 and laterSoCs with the ICSSG PRU Sub-system running EMAC firmware. This driver caters to either of the slices of the icssg subsystem.
One and exactly one of the slices is supported as the u-boot ethernet supports probing one interface at a time.
Signed-off-by: MD Danish Anwar danishanwar@ti.com --- drivers/net/ti/Kconfig | 8 + drivers/net/ti/Makefile | 1 + drivers/net/ti/icssg_prueth.c | 697 ++++++++++++++++++++++++++++++++++ drivers/net/ti/icssg_prueth.h | 3 + 4 files changed, 709 insertions(+) create mode 100644 drivers/net/ti/icssg_prueth.c
diff --git a/drivers/net/ti/Kconfig b/drivers/net/ti/Kconfig index c75f418628..9fead2c7ce 100644 --- a/drivers/net/ti/Kconfig +++ b/drivers/net/ti/Kconfig @@ -49,3 +49,11 @@ config TI_AM65_CPSW_NUSS help This driver supports TI K3 MCU CPSW Nuss Ethernet controller in Texas Instruments K3 AM65x SoCs. + +config TI_ICSSG_PRUETH + bool "TI Gigabit PRU Ethernet driver" + depends on ARCH_K3 + select PHYLIB + help + Support Gigabit Ethernet ports over the ICSSG PRU Subsystem + This subsystem is available starting with the AM65 platform. diff --git a/drivers/net/ti/Makefile b/drivers/net/ti/Makefile index 0ce0cf2828..5af760572f 100644 --- a/drivers/net/ti/Makefile +++ b/drivers/net/ti/Makefile @@ -6,3 +6,4 @@ obj-$(CONFIG_DRIVER_TI_CPSW) += cpsw.o cpsw-common.o cpsw_mdio.o obj-$(CONFIG_DRIVER_TI_EMAC) += davinci_emac.o obj-$(CONFIG_DRIVER_TI_KEYSTONE_NET) += keystone_net.o cpsw_mdio.o obj-$(CONFIG_TI_AM65_CPSW_NUSS) += am65-cpsw-nuss.o cpsw_mdio.o +obj-$(CONFIG_TI_ICSSG_PRUETH) += icssg_prueth.o cpsw_mdio.o icssg_classifier.o icssg_config.o icssg_queues.o diff --git a/drivers/net/ti/icssg_prueth.c b/drivers/net/ti/icssg_prueth.c new file mode 100644 index 0000000000..cd6ff1a7fe --- /dev/null +++ b/drivers/net/ti/icssg_prueth.c @@ -0,0 +1,697 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Texas Instruments K3 AM65 PRU Ethernet Driver + * + * Copyright (C) 2019-2021, Texas Instruments, Incorporated + * + */ + +#include <asm/io.h> +#include <asm/processor.h> +#include <clk.h> +#include <dm/lists.h> +#include <dm/device.h> +#include <dma-uclass.h> +#include <dm/of_access.h> +#include <fs_loader.h> +#include <miiphy.h> +#include <net.h> +#include <phy.h> +#include <power-domain.h> +#include <linux/soc/ti/ti-udma.h> +#include <regmap.h> +#include <remoteproc.h> +#include <syscon.h> +#include <soc.h> +#include <linux/pruss_driver.h> +#include <dm/device_compat.h> + +#include "cpsw_mdio.h" +#include "icssg_prueth.h" +#include "icss_mii_rt.h" + +#define ICSS_SLICE0 0 +#define ICSS_SLICE1 1 + +#ifdef PKTSIZE_ALIGN +#define UDMA_RX_BUF_SIZE PKTSIZE_ALIGN +#else +#define UDMA_RX_BUF_SIZE ALIGN(1522, ARCH_DMA_MINALIGN) +#endif + +#ifdef PKTBUFSRX +#define UDMA_RX_DESC_NUM PKTBUFSRX +#else +#define UDMA_RX_DESC_NUM 4 +#endif + +/* Config region lies in shared RAM */ +#define ICSS_CONFIG_OFFSET_SLICE0 0 +#define ICSS_CONFIG_OFFSET_SLICE1 0x8000 + +/* Firmware flags */ +#define ICSS_SET_RUN_FLAG_VLAN_ENABLE BIT(0) /* switch only */ +#define ICSS_SET_RUN_FLAG_FLOOD_UNICAST BIT(1) /* switch only */ +#define ICSS_SET_RUN_FLAG_PROMISC BIT(2) /* MAC only */ +#define ICSS_SET_RUN_FLAG_MULTICAST_PROMISC BIT(3) /* MAC only */ + +/* CTRLMMR_ICSSG_RGMII_CTRL register bits */ +#define ICSSG_CTRL_RGMII_ID_MODE BIT(24) + +/* Management packet type */ +#define PRUETH_PKT_TYPE_CMD 0x10 + +/* Number of PRU Cores per Slice */ +#define ICSSG_NUM_PRU_CORES 3 + +static int icssg_phy_init(struct udevice *dev) +{ + struct prueth *priv = dev_get_priv(dev); + struct phy_device *phydev; + u32 supported = PHY_GBIT_FEATURES; + int ret; + + phydev = phy_connect(priv->bus, + priv->phy_addr, + priv->dev, + priv->phy_interface); + + if (!phydev) { + dev_err(dev, "phy_connect() failed\n"); + return -ENODEV; + } + + /* disable unsupported features */ + supported &= ~(PHY_10BT_FEATURES | + SUPPORTED_100baseT_Half | + SUPPORTED_1000baseT_Half | + SUPPORTED_Pause | + SUPPORTED_Asym_Pause); + + phydev->supported &= supported; + phydev->advertising = phydev->supported; + + if (IS_ENABLED(CONFIG_DM_ETH)) + if (ofnode_valid(priv->phy_node)) + phydev->node = priv->phy_node; + + priv->phydev = phydev; + ret = phy_config(phydev); + if (ret < 0) + pr_err("phy_config() failed: %d", ret); + + return ret; +} + +static int icssg_mdio_init(struct udevice *dev) +{ + struct prueth *prueth = dev_get_priv(dev); + + prueth->bus = cpsw_mdio_init(dev->name, prueth->mdio_base, + prueth->mdio_freq, + clk_get_rate(&prueth->mdiofck), + prueth->mdio_manual_mode); + if (!prueth->bus) + return -EFAULT; + + return 0; +} + +static void icssg_config_set_speed(struct prueth *priv, int speed) +{ + u8 fw_speed; + + switch (speed) { + case SPEED_1000: + fw_speed = FW_LINK_SPEED_1G; + break; + case SPEED_100: + fw_speed = FW_LINK_SPEED_100M; + break; + case SPEED_10: + fw_speed = FW_LINK_SPEED_10M; + break; + default: + /* Other links speeds not supported */ + dev_err(priv->dev, "Unsupported link speed\n"); + return; + } + + writeb(fw_speed, priv->dram.pa + PORT_LINK_SPEED_OFFSET); +} + +static int icssg_update_link(struct prueth *priv) +{ + struct phy_device *phy = priv->phydev; + bool gig_en = false, full_duplex = false; + + if (phy->link) { /* link up */ + if (phy->speed == SPEED_1000) + gig_en = true; + if (phy->duplex == DUPLEX_FULL) + full_duplex = true; + /* Set the RGMII cfg for gig en and full duplex */ + icssg_update_rgmii_cfg(priv->miig_rt, phy->speed, full_duplex, + priv->slice, priv); + /* update the Tx IPG based on 100M/1G speed */ + icssg_config_ipg(priv, phy->speed, priv->slice); + + /* Send command to firmware to update Speed setting */ + icssg_config_set_speed(priv, phy->speed); + + /* Enable PORT FORWARDING */ + emac_set_port_state(priv, ICSSG_EMAC_PORT_FORWARD); + + printf("link up on port %d, speed %d, %s duplex\n", + priv->slice, phy->speed, + (phy->duplex == DUPLEX_FULL) ? "full" : "half"); + } else { + emac_set_port_state(priv, ICSSG_EMAC_PORT_DISABLE); + printf("link down on port %d\n", priv->slice); + } + + return phy->link; +} + +struct icssg_firmwares { + char *pru; + char *rtu; + char *txpru; +}; + +static struct icssg_firmwares icssg_emac_firmwares[] = { + { + .pru = "/lib/firmware/ti-pruss/am65x-sr2-pru0-prueth-fw.elf", + .rtu = "/lib/firmware/ti-pruss/am65x-sr2-rtu0-prueth-fw.elf", + .txpru = "/lib/firmware/ti-pruss/am65x-sr2-txpru0-prueth-fw.elf", + }, + { + .pru = "/lib/firmware/ti-pruss/am65x-sr2-pru1-prueth-fw.elf", + .rtu = "/lib/firmware/ti-pruss/am65x-sr2-rtu1-prueth-fw.elf", + .txpru = "/lib/firmware/ti-pruss/am65x-sr2-txpru1-prueth-fw.elf", + } +}; + +static int icssg_start_pru_cores(struct udevice *dev) +{ + struct prueth *prueth = dev_get_priv(dev); + struct icssg_firmwares *firmwares; + struct udevice *rproc_dev = NULL; + int ret, slice; + u32 phandle; + u8 index; + + slice = prueth->slice; + index = slice * ICSSG_NUM_PRU_CORES; + firmwares = icssg_emac_firmwares; + + ofnode_read_u32_index(dev_ofnode(dev), "ti,prus", index, &phandle); + ret = uclass_get_device_by_phandle_id(UCLASS_REMOTEPROC, phandle, &rproc_dev); + if (ret) { + dev_err(dev, "Unknown remote processor with phandle '0x%x' requested(%d)\n", + phandle, ret); + return ret; + } + + prueth->pru_core_id = dev_seq(rproc_dev); + ret = rproc_set_firmware(rproc_dev, firmwares[slice].pru); + if (ret) + return ret; + + ret = rproc_boot(rproc_dev, SZ_64K); + if (ret) { + dev_err(dev, "failed to boot PRU%d: %d\n", slice, ret); + return -EINVAL; + } + + ofnode_read_u32_index(dev_ofnode(dev), "ti,prus", index + 1, &phandle); + ret = uclass_get_device_by_phandle_id(UCLASS_REMOTEPROC, phandle, &rproc_dev); + if (ret) { + dev_err(dev, "Unknown remote processor with phandle '0x%x' requested(%d)\n", + phandle, ret); + goto halt_pru; + } + + prueth->rtu_core_id = dev_seq(rproc_dev); + ret = rproc_set_firmware(rproc_dev, firmwares[slice].rtu); + if (ret) + goto halt_pru; + + ret = rproc_boot(rproc_dev, SZ_64K); + if (ret) { + dev_err(dev, "failed to boot RTU%d: %d\n", slice, ret); + goto halt_pru; + } + + ofnode_read_u32_index(dev_ofnode(dev), "ti,prus", index + 2, &phandle); + ret = uclass_get_device_by_phandle_id(UCLASS_REMOTEPROC, phandle, &rproc_dev); + if (ret) { + dev_err(dev, "Unknown remote processor with phandle '0x%x' requested(%d)\n", + phandle, ret); + goto halt_rtu; + } + + prueth->txpru_core_id = dev_seq(rproc_dev); + ret = rproc_set_firmware(rproc_dev, firmwares[slice].txpru); + if (ret) + goto halt_rtu; + + ret = rproc_boot(rproc_dev, SZ_64K); + if (ret) { + dev_err(dev, "failed to boot TXPRU%d: %d\n", slice, ret); + goto halt_rtu; + } + + return 0; + +halt_rtu: + rproc_stop(prueth->rtu_core_id); + +halt_pru: + rproc_stop(prueth->pru_core_id); + return ret; +} + +static int icssg_stop_pru_cores(struct udevice *dev) +{ + struct prueth *prueth = dev_get_priv(dev); + + rproc_stop(prueth->pru_core_id); + rproc_stop(prueth->rtu_core_id); + rproc_stop(prueth->txpru_core_id); + + return 0; +} + +static int prueth_start(struct udevice *dev) +{ + struct ti_udma_drv_chan_cfg_data *dma_rx_cfg_data; + struct eth_pdata *pdata = dev_get_plat(dev); + struct prueth *priv = dev_get_priv(dev); + struct icssg_flow_cfg *flow_cfg; + u8 *hwaddr = pdata->enetaddr; + char chn_name[16]; + void *config; + int ret, i; + + icssg_class_set_mac_addr(priv->miig_rt, priv->slice, hwaddr); + icssg_ft1_set_mac_addr(priv->miig_rt, priv->slice, hwaddr); + icssg_class_default(priv->miig_rt, priv->slice, 0); + + /* Set Load time configuration */ + icssg_config(priv); + + ret = icssg_start_pru_cores(dev); + if (ret) + return ret; + + /* To differentiate channels for SLICE0 vs SLICE1 */ + snprintf(chn_name, sizeof(chn_name), "tx%d-0", priv->slice); + + ret = dma_get_by_name(dev, chn_name, &priv->dma_tx); + if (ret) + dev_err(dev, "TX dma get failed %d\n", ret); + + snprintf(chn_name, sizeof(chn_name), "rx%d", priv->slice); + ret = dma_get_by_name(dev, chn_name, &priv->dma_rx); + if (ret) + dev_err(dev, "RX dma get failed %d\n", ret); + + for (i = 0; i < UDMA_RX_DESC_NUM; i++) { + ret = dma_prepare_rcv_buf(&priv->dma_rx, + net_rx_packets[i], + UDMA_RX_BUF_SIZE); + if (ret) + dev_err(dev, "RX dma add buf failed %d\n", ret); + } + + ret = dma_enable(&priv->dma_tx); + if (ret) { + dev_err(dev, "TX dma_enable failed %d\n", ret); + goto tx_fail; + } + + ret = dma_enable(&priv->dma_rx); + if (ret) { + dev_err(dev, "RX dma_enable failed %d\n", ret); + goto rx_fail; + } + + /* check if the rx_flow_id of dma_rx is as expected since + * driver hardcode that value in config struct to firmware + * in probe. Just add this sanity check to catch any change + * to rx channel assignment in the future. + */ + dma_get_cfg(&priv->dma_rx, 0, (void **)&dma_rx_cfg_data); + config = (void *)(priv->dram.pa + ICSSG_CONFIG_OFFSET); + flow_cfg = config + PSI_L_REGULAR_FLOW_ID_BASE_OFFSET; + writew(dma_rx_cfg_data->flow_id_base, &flow_cfg->rx_base_flow); + writew(0, &flow_cfg->mgm_base_flow); + + dev_info(dev, "K3 ICSSG: rflow_id_base: %u, chn_name = %s\n", + dma_rx_cfg_data->flow_id_base, chn_name); + + ret = phy_startup(priv->phydev); + if (ret) { + dev_err(dev, "phy_startup failed\n"); + goto phy_fail; + } + + ret = icssg_update_link(priv); + if (!ret) { + ret = -ENODEV; + goto phy_shut; + } + + return 0; + +phy_shut: + phy_shutdown(priv->phydev); +phy_fail: + dma_disable(&priv->dma_rx); + dma_free(&priv->dma_rx); +rx_fail: + dma_disable(&priv->dma_tx); + dma_free(&priv->dma_tx); + +tx_fail: + icssg_class_disable(priv->miig_rt, priv->slice); + + return ret; +} + +static int prueth_send(struct udevice *dev, void *packet, int length) +{ + struct prueth *priv = dev_get_priv(dev); + int ret; + + ret = dma_send(&priv->dma_tx, packet, length, NULL); + + return ret; +} + +static int prueth_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct prueth *priv = dev_get_priv(dev); + int ret; + + /* try to receive a new packet */ + ret = dma_receive(&priv->dma_rx, (void **)packetp, NULL); + + return ret; +} + +static int prueth_free_pkt(struct udevice *dev, uchar *packet, int length) +{ + struct prueth *priv = dev_get_priv(dev); + int ret = 0; + + if (length > 0) { + u32 pkt = priv->rx_next % UDMA_RX_DESC_NUM; + + dev_dbg(dev, "%s length:%d pkt:%u\n", __func__, length, pkt); + + ret = dma_prepare_rcv_buf(&priv->dma_rx, + net_rx_packets[pkt], + UDMA_RX_BUF_SIZE); + priv->rx_next++; + } + + return ret; +} + +static void prueth_stop(struct udevice *dev) +{ + struct prueth *priv = dev_get_priv(dev); + + phy_shutdown(priv->phydev); + + dma_disable(&priv->dma_tx); + dma_disable(&priv->dma_rx); + + icssg_stop_pru_cores(dev); + + dma_free(&priv->dma_tx); + dma_free(&priv->dma_rx); +} + +static const struct eth_ops prueth_ops = { + .start = prueth_start, + .send = prueth_send, + .recv = prueth_recv, + .free_pkt = prueth_free_pkt, + .stop = prueth_stop, +}; + +static int icssg_ofdata_parse_phy(struct udevice *dev, ofnode port_np) +{ + struct prueth *priv = dev_get_priv(dev); + struct ofnode_phandle_args out_args; + int ret = 0; + + priv->phy_interface = ofnode_read_phy_mode(port_np); + + if (priv->phy_interface == PHY_INTERFACE_MODE_NA) { + dev_err(dev, "Invalid PHY mode '%s'\n", + phy_string_for_interface(priv->phy_interface)); + ret = -EINVAL; + goto out; + } + + ret = ofnode_parse_phandle_with_args(port_np, "phy-handle", + NULL, 0, 0, &out_args); + if (ret) { + dev_err(dev, "can't parse phy-handle port (%d)\n", ret); + ret = 0; + } + + priv->phy_node = out_args.node; + ret = ofnode_read_u32(priv->phy_node, "reg", &priv->phy_addr); + if (ret) + dev_err(dev, "failed to get phy_addr port (%d)\n", ret); + +out: + return ret; +} + +static const struct soc_attr k3_mdio_soc_data[] = { + { .family = "AM62X", .revision = "SR1.0" }, + { .family = "AM64X", .revision = "SR1.0" }, + { .family = "AM64X", .revision = "SR2.0" }, + { .family = "AM65X", .revision = "SR1.0" }, + { .family = "AM65X", .revision = "SR2.0" }, + { .family = "J7200", .revision = "SR1.0" }, + { .family = "J7200", .revision = "SR2.0" }, + { .family = "J721E", .revision = "SR1.0" }, + { .family = "J721E", .revision = "SR1.1" }, + { .family = "J721S2", .revision = "SR1.0" }, + { /* sentinel */ }, +}; + +static int prueth_probe(struct udevice *dev) +{ + ofnode eth_ports_node, eth0_node, eth1_node, eth_node; + ofnode node, pruss_node, mdio_node, sram_node; + struct prueth *prueth = dev_get_priv(dev); + struct udevice **prussdev = NULL; + u32 phandle, err, sp; + int ret = 0; + + prueth = dev_get_priv(dev); + prueth->dev = dev; + err = ofnode_read_u32(dev_ofnode(dev), "ti,prus", &phandle); + if (err) + return err; + + node = ofnode_get_by_phandle(phandle); + if (!ofnode_valid(node)) + return -EINVAL; + + pruss_node = ofnode_get_parent(node); + ret = device_get_global_by_ofnode(pruss_node, prussdev); + if (ret) + dev_err(dev, "error getting the pruss dev\n"); + prueth->pruss = *prussdev; + + ret = pruss_request_mem_region(*prussdev, PRUSS_MEM_SHRD_RAM2, + &prueth->shram); + if (ret) + return ret; + + ret = pruss_request_tm_region(*prussdev, &prueth->tmaddr); + if (ret) + return ret; + + eth_ports_node = dev_read_subnode(dev, "ethernet-ports"); + if (!ofnode_valid(eth_ports_node)) + return -ENOENT; + + ofnode_for_each_subnode(eth_node, eth_ports_node) { + const char *node_name; + u32 reg; + + node_name = ofnode_get_name(eth_node); + ret = ofnode_read_u32(eth_node, "reg", ®); + if (ret) + dev_err(dev, "%s: error reading port_id (%d)\n", node_name, ret); + + if (reg >= PRUETH_NUM_MACS) { + dev_err(dev, "%s: invalid port_id (%d)\n", node_name, reg); + return -EINVAL; + } + + if (reg == 0) + eth0_node = eth_node; + else if (reg == 1) + eth1_node = eth_node; + else + dev_err(dev, "port reg should be 0 or 1\n"); + } + + /* one node must be present and available else we fail */ + if (!ofnode_is_enabled(eth0_node) && !ofnode_is_enabled(eth1_node)) { + dev_err(dev, "neither port@0 nor port@1 node available\n"); + return -ENODEV; + } + + /* + * Uboot ethernet framework does not support two interfaces in a single + * probe. If the eth0_node is enabled in DT, we'll only probe eth0_node. + * If the eth0_node is not enabled in DT, we'll check for eth1_node and + * probe the eth1_node if enabled. + */ + if (ofnode_is_enabled(eth0_node)) { + if (ofnode_valid(eth0_node) && ofnode_is_enabled(eth0_node)) { + prueth->slice = 0; + icssg_ofdata_parse_phy(dev, eth0_node); + prueth->eth_node[PRUETH_MAC0] = eth0_node; + dev_dbg(dev, "Using port0\n"); + } + } else if (ofnode_is_enabled(eth1_node)) { + if (ofnode_valid(eth1_node) && ofnode_is_enabled(eth1_node)) { + prueth->slice = 1; + icssg_ofdata_parse_phy(dev, eth1_node); + prueth->eth_node[PRUETH_MAC0] = eth1_node; + dev_dbg(dev, "Using port1\n"); + } + } + + ret = pruss_request_mem_region(*prussdev, + prueth->slice ? PRUSS_MEM_DRAM1 : PRUSS_MEM_DRAM0, + &prueth->dram); + if (ret) { + dev_err(dev, "could not request DRAM%d region\n", prueth->slice); + return ret; + } + + prueth->miig_rt = syscon_regmap_lookup_by_phandle(dev, "ti,mii-g-rt"); + if (!prueth->miig_rt) { + dev_err(dev, "couldn't get mii-g-rt syscon regmap\n"); + return -ENODEV; + } + + prueth->mii_rt = syscon_regmap_lookup_by_phandle(dev, "ti,mii-rt"); + if (!prueth->mii_rt) { + dev_err(dev, "couldn't get mii-rt syscon regmap\n"); + return -ENODEV; + } + + ret = ofnode_read_u32(dev_ofnode(dev), "sram", &sp); + if (ret) { + dev_err(dev, "sram node fetch failed %d\n", ret); + return ret; + } + + sram_node = ofnode_get_by_phandle(sp); + if (!ofnode_valid(sram_node)) + return -EINVAL; + + prueth->sram_pa = ofnode_get_addr(sram_node); + if (prueth->sram_pa % SZ_64K != 0) { + /* This is constraint for SR2.0 firmware */ + dev_err(dev, "sram address needs to be 64KB aligned\n"); + return -EINVAL; + } + + if (prueth->phy_interface != PHY_INTERFACE_MODE_MII && + prueth->phy_interface < PHY_INTERFACE_MODE_RGMII && + prueth->phy_interface > PHY_INTERFACE_MODE_RGMII_TXID) { + dev_err(prueth->dev, "PHY mode unsupported %s\n", + phy_string_for_interface(prueth->phy_interface)); + return -EINVAL; + } + + /* AM65 SR2.0 has TX Internal delay always enabled by hardware + * and it is not possible to disable TX Internal delay. The below + * switch case block describes how we handle different phy modes + * based on hardware restriction. + */ + switch (prueth->phy_interface) { + case PHY_INTERFACE_MODE_RGMII_ID: + prueth->phy_interface = PHY_INTERFACE_MODE_RGMII_RXID; + break; + case PHY_INTERFACE_MODE_RGMII_TXID: + prueth->phy_interface = PHY_INTERFACE_MODE_RGMII; + break; + case PHY_INTERFACE_MODE_RGMII: + case PHY_INTERFACE_MODE_RGMII_RXID: + dev_err(prueth->dev, "RGMII mode without TX delay is not supported"); + return -EINVAL; + default: + break; + } + + mdio_node = ofnode_find_subnode(pruss_node, "mdio"); + prueth->mdio_base = ofnode_get_addr(mdio_node); + ofnode_read_u32(mdio_node, "bus_freq", &prueth->mdio_freq); + + ret = clk_get_by_name_nodev(mdio_node, "fck", &prueth->mdiofck); + if (ret) { + dev_err(dev, "failed to get clock %d\n", ret); + return ret; + } + + ret = clk_enable(&prueth->mdiofck); + if (ret) { + dev_err(dev, "clk_enable failed %d\n", ret); + return ret; + } + + prueth->mdio_manual_mode = false; + if (soc_device_match(k3_mdio_soc_data)) + prueth->mdio_manual_mode = true; + + ret = icssg_mdio_init(dev); + if (ret) + return ret; + + ret = icssg_phy_init(dev); + if (ret) { + dev_err(dev, "phy_init failed\n"); + goto out; + } + + return 0; +out: + cpsw_mdio_free(prueth->bus); + clk_disable(&prueth->mdiofck); + + return ret; +} + +static const struct udevice_id prueth_ids[] = { + { .compatible = "ti,am654-icssg-prueth" }, + { .compatible = "ti,am642-icssg-prueth" }, + { } +}; + +U_BOOT_DRIVER(prueth) = { + .name = "prueth", + .id = UCLASS_ETH, + .of_match = prueth_ids, + .probe = prueth_probe, + .ops = &prueth_ops, + .priv_auto = sizeof(struct prueth), + .plat_auto = sizeof(struct eth_pdata), + .flags = DM_FLAG_ALLOC_PRIV_DMA, +}; diff --git a/drivers/net/ti/icssg_prueth.h b/drivers/net/ti/icssg_prueth.h index f34ab5d6d4..fb76668f90 100644 --- a/drivers/net/ti/icssg_prueth.h +++ b/drivers/net/ti/icssg_prueth.h @@ -68,6 +68,9 @@ struct prueth { bool mdio_manual_mode; int speed; int duplex; + u8 pru_core_id; + u8 rtu_core_id; + u8 txpru_core_id; };
ICSSG firmware supports FDB commands. Add support to send FDB commands from driver. Once rx_flow_id is obtained from dma, let firmware know that we are using this rx_flow_id by sending a FDB command.
Signed-off-by: MD Danish Anwar danishanwar@ti.com --- drivers/net/ti/icssg_config.c | 66 +++++++++++++++++++++++++++++++++++ drivers/net/ti/icssg_config.h | 18 ++++++++++ drivers/net/ti/icssg_prueth.c | 6 ++++ drivers/net/ti/icssg_prueth.h | 6 ++++ 4 files changed, 96 insertions(+)
diff --git a/drivers/net/ti/icssg_config.c b/drivers/net/ti/icssg_config.c index 0dc2c0fa3a..630698add4 100644 --- a/drivers/net/ti/icssg_config.c +++ b/drivers/net/ti/icssg_config.c @@ -9,6 +9,7 @@ #include "icssg_switch_map.h" #include "icss_mii_rt.h" #include <dm/device_compat.h> +#include <linux/iopoll.h>
/* TX IPG Values to be set for 100M and 1G link speeds. These values are * in ocp_clk cycles. So need change if ocp_clk is changed for a specific @@ -395,3 +396,68 @@ int emac_set_port_state(struct prueth *prueth,
return ret; } + +int icssg_send_fdb_msg(struct prueth *prueth, struct mgmt_cmd *cmd, + struct mgmt_cmd_rsp *rsp) +{ + int slice = prueth->slice; + int ret, addr; + + addr = icssg_queue_pop(prueth, slice == 0 ? + ICSSG_CMD_POP_SLICE0 : ICSSG_CMD_POP_SLICE1); + if (addr < 0) + return addr; + + /* First 4 bytes have FW owned buffer linking info which should + * not be touched + */ + memcpy_toio((void __iomem *)prueth->shram.pa + addr + 4, cmd, sizeof(*cmd)); + icssg_queue_push(prueth, slice == 0 ? + ICSSG_CMD_PUSH_SLICE0 : ICSSG_CMD_PUSH_SLICE1, addr); + ret = read_poll_timeout(icssg_queue_pop, addr, addr >= 0, + 2000, 20000000, prueth, slice == 0 ? + ICSSG_RSP_POP_SLICE0 : ICSSG_RSP_POP_SLICE1); + + if (ret) { + dev_err(prueth->dev, "Timedout sending HWQ message\n"); + return ret; + } + + memcpy_fromio(rsp, (void __iomem *)prueth->shram.pa + addr, sizeof(*rsp)); + /* Return buffer back for to pool */ + icssg_queue_push(prueth, slice == 0 ? + ICSSG_RSP_PUSH_SLICE0 : ICSSG_RSP_PUSH_SLICE1, addr); + + return 0; +} + +int emac_fdb_flow_id_updated(struct prueth *prueth) +{ + struct mgmt_cmd_rsp fdb_cmd_rsp = { 0 }; + int slice = prueth->slice; + struct mgmt_cmd fdb_cmd = { 0 }; + int ret = 0; + + fdb_cmd.header = ICSSG_FW_MGMT_CMD_HEADER; + fdb_cmd.type = ICSSG_FW_MGMT_FDB_CMD_TYPE_RX_FLOW; + fdb_cmd.seqnum = ++(prueth->icssg_hwcmdseq); + fdb_cmd.param = 0; + + fdb_cmd.param |= (slice << 4); + fdb_cmd.cmd_args[0] = 0; + + ret = icssg_send_fdb_msg(prueth, &fdb_cmd, &fdb_cmd_rsp); + if (ret) + return ret; + + if (fdb_cmd.seqnum != fdb_cmd_rsp.seqnum) { + dev_err(prueth->dev, "seqnum doesn't match, cmd.seqnum %d != rsp.seqnum %d\n", + fdb_cmd.seqnum, fdb_cmd_rsp.seqnum); + return -EINVAL; + } + + if (fdb_cmd_rsp.status == 1) + return 0; + + return -EINVAL; +} diff --git a/drivers/net/ti/icssg_config.h b/drivers/net/ti/icssg_config.h index fc6eae0426..156127bd3d 100644 --- a/drivers/net/ti/icssg_config.h +++ b/drivers/net/ti/icssg_config.h @@ -80,6 +80,7 @@ struct icssg_rxq_ctx { #define ICSSG_FW_MGMT_FDB_CMD_TYPE 0x03 #define ICSSG_FW_MGMT_CMD_TYPE 0x04 #define ICSSG_FW_MGMT_PKT 0x80000000 +#define ICSSG_FW_MGMT_FDB_CMD_TYPE_RX_FLOW 0x05
struct icssg_r30_cmd { u32 cmd[4]; @@ -156,6 +157,23 @@ struct icssg_setclock_desc { u32 CMP0_new; } __packed;
+struct mgmt_cmd { + u8 param; + u8 seqnum; + u8 type; + u8 header; + u32 cmd_args[3]; +} __packed; + +struct mgmt_cmd_rsp { + u32 reserved; + u8 status; + u8 seqnum; + u8 type; + u8 header; + u32 cmd_args[3]; +} __packed; + #define ICSSG_CMD_POP_SLICE0 56 #define ICSSG_CMD_POP_SLICE1 60
diff --git a/drivers/net/ti/icssg_prueth.c b/drivers/net/ti/icssg_prueth.c index cd6ff1a7fe..50af9a2bc6 100644 --- a/drivers/net/ti/icssg_prueth.c +++ b/drivers/net/ti/icssg_prueth.c @@ -351,6 +351,12 @@ static int prueth_start(struct udevice *dev) dev_info(dev, "K3 ICSSG: rflow_id_base: %u, chn_name = %s\n", dma_rx_cfg_data->flow_id_base, chn_name);
+ ret = emac_fdb_flow_id_updated(priv); + if (ret) { + dev_err(dev, "Failed to update Rx Flow ID %d", ret); + goto phy_fail; + } + ret = phy_startup(priv->phydev); if (ret) { dev_err(dev, "phy_startup failed\n"); diff --git a/drivers/net/ti/icssg_prueth.h b/drivers/net/ti/icssg_prueth.h index fb76668f90..24dda1fee8 100644 --- a/drivers/net/ti/icssg_prueth.h +++ b/drivers/net/ti/icssg_prueth.h @@ -71,6 +71,7 @@ struct prueth { u8 pru_core_id; u8 rtu_core_id; u8 txpru_core_id; + u8 icssg_hwcmdseq; };
/* config helpers */ @@ -83,4 +84,9 @@ int icssg_queue_pop(struct prueth *prueth, u8 queue); void icssg_queue_push(struct prueth *prueth, int queue, u16 addr); u32 icssg_queue_level(struct prueth *prueth, int queue);
+/* FDB helpers */ +int icssg_send_fdb_msg(struct prueth *prueth, struct mgmt_cmd *cmd, + struct mgmt_cmd_rsp *rsp); +int emac_fdb_flow_id_updated(struct prueth *prueth); + #endif /* __NET_TI_ICSSG_PRUETH_H */
The binding represents the MDIO controller as a child device tree node of the MAC device tree node.
The U-Boot driver mostly ignores that child device tree node and just hardcodes the resources it uses to support both the MAC and MDIO in a single driver.
However, some resources like pinctrl muxing states are thus ignored. This has been a problem with some device trees that will put some pinctrl states on the MDIO device tree node.
Let's rework the driver a bit to create a dummy MDIO driver that we will then get during our initialization to force the core to select the right muxing.
Signed-off-by: MD Danish Anwar danishanwar@ti.com --- drivers/net/ti/Kconfig | 1 + drivers/net/ti/icssg_prueth.c | 59 +++++++++++++++++++++++++++++++++++ 2 files changed, 60 insertions(+)
diff --git a/drivers/net/ti/Kconfig b/drivers/net/ti/Kconfig index 9fead2c7ce..6935b70e12 100644 --- a/drivers/net/ti/Kconfig +++ b/drivers/net/ti/Kconfig @@ -53,6 +53,7 @@ config TI_AM65_CPSW_NUSS config TI_ICSSG_PRUETH bool "TI Gigabit PRU Ethernet driver" depends on ARCH_K3 + imply DM_MDIO select PHYLIB help Support Gigabit Ethernet ports over the ICSSG PRU Subsystem diff --git a/drivers/net/ti/icssg_prueth.c b/drivers/net/ti/icssg_prueth.c index 50af9a2bc6..225928e477 100644 --- a/drivers/net/ti/icssg_prueth.c +++ b/drivers/net/ti/icssg_prueth.c @@ -13,6 +13,7 @@ #include <dm/device.h> #include <dma-uclass.h> #include <dm/of_access.h> +#include <dm/pinctrl.h> #include <fs_loader.h> #include <miiphy.h> #include <net.h> @@ -103,9 +104,56 @@ static int icssg_phy_init(struct udevice *dev) return ret; }
+static ofnode prueth_find_mdio(ofnode parent) +{ + ofnode node; + + ofnode_for_each_subnode(node, parent) + if (ofnode_device_is_compatible(node, "ti,davinci_mdio")) + return node; + + return ofnode_null(); +} + +static int prueth_mdio_setup(struct udevice *dev) +{ + struct prueth *priv = dev_get_priv(dev); + struct udevice *mdio_dev; + ofnode mdio; + int ret; + + mdio = prueth_find_mdio(dev_ofnode(priv->pruss)); + if (!ofnode_valid(mdio)) + return 0; + + /* + * The MDIO controller is represented in the DT binding by a + * subnode of the MAC controller. + * + * We don't have a DM driver for the MDIO device yet, and thus any + * pinctrl setting on its node will be ignored. + * + * However, we do need to make sure the pins states tied to the + * MDIO node are configured properly. Fortunately, the core DM + * does that for use when we get a device, so we can work around + * that whole issue by just requesting a dummy MDIO driver to + * probe, and our pins will get muxed. + */ + ret = uclass_get_device_by_ofnode(UCLASS_MDIO, mdio, &mdio_dev); + if (ret) + return ret; + + return 0; +} + static int icssg_mdio_init(struct udevice *dev) { struct prueth *prueth = dev_get_priv(dev); + int ret; + + ret = prueth_mdio_setup(dev); + if (ret) + return ret;
prueth->bus = cpsw_mdio_init(dev->name, prueth->mdio_base, prueth->mdio_freq, @@ -701,3 +749,14 @@ U_BOOT_DRIVER(prueth) = { .plat_auto = sizeof(struct eth_pdata), .flags = DM_FLAG_ALLOC_PRIV_DMA, }; + +static const struct udevice_id prueth_mdio_ids[] = { + { .compatible = "ti,davinci_mdio" }, + { } +}; + +U_BOOT_DRIVER(prueth_mdio) = { + .name = "prueth_mdio", + .id = UCLASS_MDIO, + .of_match = prueth_mdio_ids, +};
ICSSG2 provides dual Gigabit Ethernet support. Add ICSSG2 ethernet node to an overlay k3-am654-icssg2.dtso
Signed-off-by: MD Danish Anwar danishanwar@ti.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/k3-am654-icssg2.dtso | 145 ++++++++++++++++++++++++++++++ 2 files changed, 147 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/k3-am654-icssg2.dtso
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index e9e58c5478..2bc53fba89 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1396,7 +1396,8 @@ dtb-$(CONFIG_SOC_K3_AM654) += \ k3-am6548-iot2050-advanced-pg2.dtb \ k3-am6548-iot2050-advanced-m2.dtb \ k3-am6548-iot2050-advanced-m2-bkey-usb3-overlay.dtbo \ - k3-am6548-iot2050-advanced-m2-bkey-ekey-pcie-overlay.dtbo + k3-am6548-iot2050-advanced-m2-bkey-ekey-pcie-overlay.dtbo \ + k3-am654-icssg2.dtbo dtb-$(CONFIG_SOC_K3_J721E) += k3-j721e-common-proc-board.dtb \ k3-j721e-r5-common-proc-board.dtb \ k3-j7200-common-proc-board.dtb \ diff --git a/arch/arm/dts/k3-am654-icssg2.dtso b/arch/arm/dts/k3-am654-icssg2.dtso new file mode 100644 index 0000000000..faefa2febc --- /dev/null +++ b/arch/arm/dts/k3-am654-icssg2.dtso @@ -0,0 +1,145 @@ +// SPDX-License-Identifier: GPL-2.0 +/** + * DT overlay for enabling ICSSG2 on AM654 EVM + * + * Copyright (C) 2018-2023 Texas Instruments Incorporated - https://www.ti.com/ + */ + +/dts-v1/; +/plugin/; + +#include <dt-bindings/net/ti-dp83867.h> +#include "k3-pinctrl.h" + +&{/} { + aliases { + ethernet1 = "/icssg2-eth/ethernet-ports/port@0"; + ethernet2 = "/icssg2-eth/ethernet-ports/port@1"; + }; + + /* Ethernet node on PRU-ICSSG2 */ + icssg2_eth: icssg2-eth { + compatible = "ti,am654-icssg-prueth"; + pinctrl-names = "default"; + pinctrl-0 = <&icssg2_rgmii_pins_default>; + sram = <&msmc_ram>; + ti,prus = <&pru2_0>, <&rtu2_0>, <&tx_pru2_0>, + <&pru2_1>, <&rtu2_1>, <&tx_pru2_1>; + firmware-name = "ti-pruss/am65x-sr2-pru0-prueth-fw.elf", + "ti-pruss/am65x-sr2-rtu0-prueth-fw.elf", + "ti-pruss/am65x-sr2-txpru0-prueth-fw.elf", + "ti-pruss/am65x-sr2-pru1-prueth-fw.elf", + "ti-pruss/am65x-sr2-rtu1-prueth-fw.elf", + "ti-pruss/am65x-sr2-txpru1-prueth-fw.elf"; + + ti,pruss-gp-mux-sel = <2>, /* MII mode */ + <2>, + <2>, + <2>, /* MII mode */ + <2>, + <2>; + + ti,mii-g-rt = <&icssg2_mii_g_rt>; + ti,mii-rt = <&icssg2_mii_rt>; + ti,iep = <&icssg2_iep0>, <&icssg2_iep1>; + + interrupt-parent = <&icssg2_intc>; + interrupts = <24 0 2>, <25 1 3>; + interrupt-names = "tx_ts0", "tx_ts1"; + + dmas = <&main_udmap 0xc300>, /* egress slice 0 */ + <&main_udmap 0xc301>, /* egress slice 0 */ + <&main_udmap 0xc302>, /* egress slice 0 */ + <&main_udmap 0xc303>, /* egress slice 0 */ + <&main_udmap 0xc304>, /* egress slice 1 */ + <&main_udmap 0xc305>, /* egress slice 1 */ + <&main_udmap 0xc306>, /* egress slice 1 */ + <&main_udmap 0xc307>, /* egress slice 1 */ + <&main_udmap 0x4300>, /* ingress slice 0 */ + <&main_udmap 0x4301>; /* ingress slice 1 */ + + dma-names = "tx0-0", "tx0-1", "tx0-2", "tx0-3", + "tx1-0", "tx1-1", "tx1-2", "tx1-3", + "rx0", "rx1"; + ethernet-ports { + #address-cells = <1>; + #size-cells = <0>; + icssg2_emac0: port@0 { + reg = <0>; + phy-handle = <&icssg2_phy0>; + phy-mode = "rgmii-id"; + ti,syscon-rgmii-delay = <&scm_conf 0x4120>; + /* Filled in by bootloader */ + local-mac-address = [00 00 00 00 00 00]; + }; + icssg2_emac1: port@1 { + reg = <1>; + phy-handle = <&icssg2_phy1>; + phy-mode = "rgmii-id"; + ti,syscon-rgmii-delay = <&scm_conf 0x4124>; + /* Filled in by bootloader */ + local-mac-address = [00 00 00 00 00 00]; + }; + }; + }; +}; + +&main_pmx0 { + + icssg2_mdio_pins_default: icssg2-mdio-default-pins { + pinctrl-single,pins = < + AM65X_IOPAD(0x0094, PIN_INPUT, 2) /* (AC19) PRG2_PRU0_GPO7.PRG2_MDIO0_MDIO */ + AM65X_IOPAD(0x00c8, PIN_OUTPUT, 2) /* (AE15) PRG2_PRU1_GPO7.PRG2_MDIO0_MDC */ + >; + }; + + icssg2_rgmii_pins_default: icssg2-rgmii-default-pins { + pinctrl-single,pins = < + AM65X_IOPAD(0x00ac, PIN_INPUT, 2) /* (AH15) PRG2_PRU1_GPO0.PRG2_RGMII2_RD0 */ + AM65X_IOPAD(0x00b0, PIN_INPUT, 2) /* (AC16) PRG2_PRU1_GPO1.PRG2_RGMII2_RD1 */ + AM65X_IOPAD(0x00b4, PIN_INPUT, 2) /* (AD17) PRG2_PRU1_GPO2.PRG2_RGMII2_RD2 */ + AM65X_IOPAD(0x00b8, PIN_INPUT, 2) /* (AH14) PRG2_PRU1_GPO3.PRG2_RGMII2_RD3 */ + AM65X_IOPAD(0x00cc, PIN_OUTPUT, 2) /* (AD15) PRG2_PRU1_GPO8.PRG2_RGMII2_TD0 */ + AM65X_IOPAD(0x00d0, PIN_OUTPUT, 2) /* (AF14) PRG2_PRU1_GPO9.PRG2_RGMII2_TD1 */ + AM65X_IOPAD(0x00d4, PIN_OUTPUT, 2) /* (AC15) PRG2_PRU1_GPO10.PRG2_RGMII2_TD2 */ + AM65X_IOPAD(0x00d8, PIN_OUTPUT, 2) /* (AD14) PRG2_PRU1_GPO11.PRG2_RGMII2_TD3 */ + AM65X_IOPAD(0x00dc, PIN_INPUT, 2) /* (AE14) PRG2_PRU1_GPO16.PRG2_RGMII2_TXC */ + AM65X_IOPAD(0x00c4, PIN_OUTPUT, 2) /* (AC17) PRG2_PRU1_GPO6.PRG2_RGMII2_TX_CTL */ + AM65X_IOPAD(0x00c0, PIN_INPUT, 2) /* (AG15) PRG2_PRU1_GPO5.PRG2_RGMII2_RXC */ + AM65X_IOPAD(0x00bc, PIN_INPUT, 2) /* (AG14) PRG2_PRU1_GPO4.PRG2_RGMII2_RX_CTL */ + + AM65X_IOPAD(0x0078, PIN_INPUT, 2) /* (AF18) PRG2_PRU0_GPO0.PRG2_RGMII1_RD0 */ + AM65X_IOPAD(0x007c, PIN_INPUT, 2) /* (AE18) PRG2_PRU0_GPO1.PRG2_RGMII1_RD1 */ + AM65X_IOPAD(0x0080, PIN_INPUT, 2) /* (AH17) PRG2_PRU0_GPO2.PRG2_RGMII1_RD2 */ + AM65X_IOPAD(0x0084, PIN_INPUT, 2) /* (AG18) PRG2_PRU0_GPO3.PRG2_RGMII1_RD3 */ + AM65X_IOPAD(0x0098, PIN_OUTPUT, 2) /* (AH16) PRG2_PRU0_GPO8.PRG2_RGMII1_TD0 */ + AM65X_IOPAD(0x009c, PIN_OUTPUT, 2) /* (AG16) PRG2_PRU0_GPO9.PRG2_RGMII1_TD1 */ + AM65X_IOPAD(0x00a0, PIN_OUTPUT, 2) /* (AF16) PRG2_PRU0_GPO10.PRG2_RGMII1_TD2 */ + AM65X_IOPAD(0x00a4, PIN_OUTPUT, 2) /* (AE16) PRG2_PRU0_GPO11.PRG2_RGMII1_TD3 */ + AM65X_IOPAD(0x00a8, PIN_INPUT, 2) /* (AD16) PRG2_PRU0_GPO16.PRG2_RGMII1_TXC */ + AM65X_IOPAD(0x0090, PIN_OUTPUT, 2) /* (AE17) PRG2_PRU0_GPO6.PRG2_RGMII1_TX_CTL */ + AM65X_IOPAD(0x008c, PIN_INPUT, 2) /* (AF17) PRG2_PRU0_GPO5.PRG2_RGMII1_RXC */ + AM65X_IOPAD(0x0088, PIN_INPUT, 2) /* (AG17) PRG2_PRU0_GPO4.PRG2_RGMII1_RX_CTL */ + >; + }; +}; + +&icssg2_mdio { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&icssg2_mdio_pins_default>; + #address-cells = <1>; + #size-cells = <0>; + + icssg2_phy0: ethernet-phy@0 { + reg = <0>; + ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; + ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; + }; + + icssg2_phy1: ethernet-phy@3 { + reg = <3>; + ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; + ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; + }; +};
Add ICSSG2 overlay and configuration to tispl and u-boot images.
Signed-off-by: MD Danish Anwar danishanwar@ti.com --- arch/arm/dts/k3-am65x-binman.dtsi | 65 +++++++++++++++++++++++++++++-- 1 file changed, 61 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/k3-am65x-binman.dtsi b/arch/arm/dts/k3-am65x-binman.dtsi index 8cc24da1f3..d0cd4889cd 100644 --- a/arch/arm/dts/k3-am65x-binman.dtsi +++ b/arch/arm/dts/k3-am65x-binman.dtsi @@ -98,6 +98,8 @@ #define SPL_AM654_EVM_DTB "spl/dts/k3-am654-base-board.dtb" #define AM654_EVM_DTB "u-boot.dtb"
+#define AM654_EVM_ICSSG2_DTBO "arch/arm/dts/k3-am654-icssg2.dtbo" + &binman { ti-spl { insert-template = <&ti_spl_template>; @@ -124,6 +126,20 @@ filename = SPL_AM654_EVM_DTB; }; }; + + fdt-1 { + description = "k3-am654-icssg2 overlay"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_am65x_evm_icssg2_dtb>; + keyfile = "custMpk.pem"; + }; + spl_am65x_evm_icssg2_dtb: blob-ext { + filename = AM654_EVM_ICSSG2_DTBO; + }; + }; };
configurations { @@ -133,7 +149,7 @@ description = "k3-am654-base-board"; firmware = "atf"; loadables = "tee", "dm", "spl"; - fdt = "fdt-0"; + fdt = "fdt-0", "fdt-1"; }; }; }; @@ -168,6 +184,24 @@ }; };
+ fdt-1 { + description = "k3-am654-icssg2 overlay"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&am65x_evm_icssg2_dtb>; + keyfile = "custMpk.pem"; + + }; + am65x_evm_icssg2_dtb: blob-ext { + filename = AM654_EVM_ICSSG2_DTBO; + }; + hash { + algo = "crc32"; + }; + }; + };
configurations { @@ -177,7 +211,7 @@ description = "k3-am654-base-board"; firmware = "uboot"; loadables = "uboot"; - fdt = "fdt-0"; + fdt = "fdt-0", "fdt-1"; }; }; }; @@ -205,6 +239,16 @@ filename = SPL_AM654_EVM_DTB; }; }; + + fdt-1 { + description = "k3-am654-icssg2 overlay"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = AM654_EVM_ICSSG2_DTBO; + }; + }; };
configurations { @@ -214,7 +258,7 @@ description = "k3-am654-base-board"; firmware = "atf"; loadables = "tee", "dm", "spl"; - fdt = "fdt-0"; + fdt = "fdt-0", "fdt-1"; }; }; }; @@ -243,6 +287,19 @@ algo = "crc32"; }; }; + + fdt-1 { + description = "k3-am654-icssg2"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = AM654_EVM_ICSSG2_DTBO; + }; + hash { + algo = "crc32"; + }; + }; };
configurations { @@ -252,7 +309,7 @@ description = "k3-am654-base-board"; firmware = "uboot"; loadables = "uboot"; - fdt = "fdt-0"; + fdt = "fdt-0", "fdt-1"; }; }; };
Enable ICSSG driver in am65x_evm_a53_defconfig
Signed-off-by: MD Danish Anwar danishanwar@ti.com --- configs/am65x_evm_a53_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index 529bda283d..aeea24d773 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -129,6 +129,7 @@ CONFIG_PHY_FIXED=y CONFIG_E1000=y CONFIG_CMD_E1000=y CONFIG_TI_AM65_CPSW_NUSS=y +CONFIG_TI_ICSSG_PRUETH=y CONFIG_PCI_KEYSTONE=y CONFIG_PHY=y CONFIG_SPL_PHY=y
We want SPL to apply DTB overlays (e.g. ICSSG2 overlay) so enable SPL_LOAD_FIT_APPLY_OVERLAY.
diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index aeea24d773..329973de68 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -69,6 +69,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_REMOTEPROC=y +CONFIG_SPL_LOAD_FIT_APPLY_OVERLAY=y CONFIG_CMD_USB=y CONFIG_CMD_TIME=y CONFIG_MTDIDS_DEFAULT="nor0=47040000.spi.0"
When CONFIG_TI_ICSSG_PRUETH is enabled, add config name check for the icssg2 overlay in board_fit_config_match() API.
Signed-off-by: MD Danish Anwar danishanwar@ti.com --- board/ti/am65x/evm.c | 11 +++++++---- 1 file changed, 7 insertions(+), 4 deletions(-)
diff --git a/board/ti/am65x/evm.c b/board/ti/am65x/evm.c index df209021c1..0b661f0084 100644 --- a/board/ti/am65x/evm.c +++ b/board/ti/am65x/evm.c @@ -90,10 +90,13 @@ int dram_init_banksize(void) #ifdef CONFIG_SPL_LOAD_FIT int board_fit_config_name_match(const char *name) { -#ifdef CONFIG_TARGET_AM654_A53_EVM - if (!strcmp(name, "k3-am654-base-board")) - return 0; -#endif + if (IS_ENABLED(CONFIG_TI_ICSSG_PRUETH)) { + if (!strcmp(name, "k3-am654-icssg2")) + return 0; + } else { + if (!strcmp(name, "k3-am654-base-board")) + return 0; + }
return -1; }
When ICSSG driver is enabled (CONFIG_TI_ICSSG_PRUETH=y) set fw_storage_interface and fw_dev_part env variables.
These variables need be set appropriately in order to load differnet ICSSG firmwares needed for ICSSG driver. By default the storage interface is mmc and the partition is 1:2. User can modify this based on their needs.
Signed-off-by: MD Danish Anwar danishanwar@ti.com --- board/ti/am65x/am65x.env | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/ti/am65x/am65x.env b/board/ti/am65x/am65x.env index 286b9c300c..5d6b98b87c 100644 --- a/board/ti/am65x/am65x.env +++ b/board/ti/am65x/am65x.env @@ -30,3 +30,7 @@ get_fdt_ubi=ubifsload ${fdtaddr} ${bootdir}/${name_fdt} args_ubi=setenv bootargs console=${console} ${optargs} rootfstype=ubifs root=ubi0:rootfs rw ubi.mtd=ospi.rootfs
+#if CONFIG_TI_ICSSG_PRUETH +fw_storage_interface=mmc +fw_dev_part=1:2 +#endif
MD Danish Anwar
