[PATCH 0/4] Adding support to load secure firmware for HS devices
Some use case needs rproc firmware to be loaded at u-boot stage, using following commands at u-boot shell, firmware could be loaded
=> setenv dorprocboot 1 => run boot_rprocs
For Secure devices, secure version of rproc firmware should be loaded, which is appended by sec keyword[0]. but currently non-secure firmware is loaded even for secure devices. So adding support for loading secure firmware on Secured devices.
[0]: https://gist.github.com/uditkumarti/cd8bf6a448079b59145d17a0e8bf13b7
Bootlogs: GP : https://gist.github.com/uditkumarti/23a00c313e1c28b62537aab733a585df#file-gp... line 65 onwards HS : https://gist.github.com/uditkumarti/23a00c313e1c28b62537aab733a585df#file-hs... line 60 onwards
Manorit Chawdhry (3): include: mach-k3: move k3 security functions to security.h drivers: remoteproc: ti_k3 : enable secure booting with firmware images mach-k3: common.c: add a flag for booting authenticated rproc binaries
Udit Kumar (1): include: env: ti: Add support for secure firmwares
arch/arm/mach-k3/common.c | 4 +++- arch/arm/mach-k3/common.h | 4 ++-- arch/arm/mach-k3/include/mach/security.h | 11 +++++++++++ drivers/remoteproc/ti_k3_dsp_rproc.c | 4 ++++ drivers/remoteproc/ti_k3_r5f_rproc.c | 4 ++++ include/env/ti/k3_rproc.env | 6 +++++- include/env/ti/ti_common.env | 1 + 7 files changed, 30 insertions(+), 4 deletions(-) create mode 100644 arch/arm/mach-k3/include/mach/security.h
ti_secure_image_post_process and ti_secure_image_check_binary is used for the authentication purposes in the current boot flow. Authentication of remoteproc firmware images require ti_secure_image_post_process to be available outside mach-k3.
Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com Signed-off-by: Udit Kumar u-kumar1@ti.com --- arch/arm/mach-k3/common.h | 4 ++-- arch/arm/mach-k3/include/mach/security.h | 11 +++++++++++ 2 files changed, 13 insertions(+), 2 deletions(-) create mode 100644 arch/arm/mach-k3/include/mach/security.h
diff --git a/arch/arm/mach-k3/common.h b/arch/arm/mach-k3/common.h index 53aa186b31..7bd72da1de 100644 --- a/arch/arm/mach-k3/common.h +++ b/arch/arm/mach-k3/common.h @@ -2,12 +2,13 @@ /* * K3: Architecture common definitions * - * Copyright (C) 2018 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2018-2024 Texas Instruments Incorporated - https://www.ti.com/ * Lokesh Vutla lokeshvutla@ti.com */
#include <asm/armv7_mpu.h> #include <asm/hardware.h> +#include <mach/security.h>
#define K3_FIREWALL_BACKGROUND_BIT (8)
@@ -41,7 +42,6 @@ void spl_enable_cache(void); void mmr_unlock(uintptr_t base, u32 partition); bool is_rom_loaded_sysfw(struct rom_extended_boot_data *data); enum k3_device_type get_device_type(void); -void ti_secure_image_post_process(void **p_image, size_t *p_size); struct ti_sci_handle *get_ti_sci_handle(void); void do_board_detect(void); void ti_secure_image_check_binary(void **p_image, size_t *p_size); diff --git a/arch/arm/mach-k3/include/mach/security.h b/arch/arm/mach-k3/include/mach/security.h new file mode 100644 index 0000000000..8502b57bd8 --- /dev/null +++ b/arch/arm/mach-k3/include/mach/security.h @@ -0,0 +1,11 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * K3: Security related definitions + * + * Copyright (C) 2024 Texas Instruments Incorporated - https://www.ti.com/ + * Manorit Chawdhry m-chawdhry@ti.com + */ + +#include <linux/types.h> + +void ti_secure_image_post_process(void **p_image, size_t *p_size);
Remoteproc firmware images aren't authenticated in the current boot flow. Authenticates remoteproc firmware images to complete the root of trust in secure booting.
Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- drivers/remoteproc/ti_k3_dsp_rproc.c | 4 ++++ drivers/remoteproc/ti_k3_r5f_rproc.c | 4 ++++ 2 files changed, 8 insertions(+)
diff --git a/drivers/remoteproc/ti_k3_dsp_rproc.c b/drivers/remoteproc/ti_k3_dsp_rproc.c index 57fe1037da..7617bbb986 100644 --- a/drivers/remoteproc/ti_k3_dsp_rproc.c +++ b/drivers/remoteproc/ti_k3_dsp_rproc.c @@ -21,6 +21,7 @@ #include <linux/sizes.h> #include <linux/soc/ti/ti_sci_protocol.h> #include "ti_sci_proc.h" +#include <mach/security.h>
#define KEYSTONE_RPROC_LOCAL_ADDRESS_MASK (SZ_16M - 1)
@@ -127,6 +128,7 @@ static int k3_dsp_load(struct udevice *dev, ulong addr, ulong size) struct k3_dsp_privdata *dsp = dev_get_priv(dev); struct k3_dsp_boot_data *data = dsp->data; u32 boot_vector; + void *image_addr = (void *)addr; int ret;
if (dsp->in_use) { @@ -148,6 +150,8 @@ static int k3_dsp_load(struct udevice *dev, ulong addr, ulong size) goto proc_release; }
+ ti_secure_image_post_process(&image_addr, &size); + ret = rproc_elf_load_image(dev, addr, size); if (ret < 0) { dev_err(dev, "Loading elf failed %d\n", ret); diff --git a/drivers/remoteproc/ti_k3_r5f_rproc.c b/drivers/remoteproc/ti_k3_r5f_rproc.c index b55b1dc10d..b9c6549e18 100644 --- a/drivers/remoteproc/ti_k3_r5f_rproc.c +++ b/drivers/remoteproc/ti_k3_r5f_rproc.c @@ -20,6 +20,7 @@ #include <linux/kernel.h> #include <linux/soc/ti/ti_sci_protocol.h> #include "ti_sci_proc.h" +#include <mach/security.h>
/* * R5F's view of this address can either be for ATCM or BTCM with the other @@ -301,6 +302,7 @@ static int k3_r5f_load(struct udevice *dev, ulong addr, ulong size) u64 boot_vector; u32 ctrl, sts, cfg = 0; bool mem_auto_init; + void *image_addr = (void *)addr; int ret;
dev_dbg(dev, "%s addr = 0x%lx, size = 0x%lx\n", __func__, addr, size); @@ -328,6 +330,8 @@ static int k3_r5f_load(struct udevice *dev, ulong addr, ulong size)
k3_r5f_init_tcm_memories(core, mem_auto_init);
+ ti_secure_image_post_process(&image_addr, &size); + ret = rproc_elf_load_image(dev, addr, size); if (ret < 0) { dev_err(dev, "Loading elf failedi %d\n", ret);
Secure firmwares must be loaded if SOC is secure, currently rproc framework chooses non-secure firmware always.
So adding support to load secure firmware, when SOC is secure
Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com Signed-off-by: Udit Kumar u-kumar1@ti.com --- include/env/ti/k3_rproc.env | 6 +++++- include/env/ti/ti_common.env | 1 + 2 files changed, 6 insertions(+), 1 deletion(-)
diff --git a/include/env/ti/k3_rproc.env b/include/env/ti/k3_rproc.env index 87d9d76eba..d4f0f1708c 100644 --- a/include/env/ti/k3_rproc.env +++ b/include/env/ti/k3_rproc.env @@ -13,11 +13,15 @@ rproc_load_and_boot_one= boot_rprocs_mmc= env set rproc_id; env set rproc_fw; + env set secure_suffix; + if test ${secure_rprocs} -eq 1; then + env set secure_suffix -sec; + fi; for i in ${rproc_fw_binaries} ; do if test -z "${rproc_id}" ; then env set rproc_id $i; else - env set rproc_fw $i; + env set rproc_fw $i${secure_suffix}; run rproc_load_and_boot_one; env set rproc_id; env set rproc_fw; diff --git a/include/env/ti/ti_common.env b/include/env/ti/ti_common.env index 02b410c3ad..c5c3642177 100644 --- a/include/env/ti/ti_common.env +++ b/include/env/ti/ti_common.env @@ -12,6 +12,7 @@ bootm_size=0x10000000 boot_fdt=try
boot_fit=0 +secure_rprocs=0 addr_fit=0x90000000 name_fit=fitImage update_to_fit=setenv loadaddr ${addr_fit}; setenv bootfile ${name_fit}
The flag will be used for booting authenticated remote procs from hs-se devices which can optionally be used in hs-fs devices also.
Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com Signed-off-by: Udit Kumar u-kumar1@ti.com --- arch/arm/mach-k3/common.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-k3/common.c b/arch/arm/mach-k3/common.c index 1a269d6934..eaa7d36176 100644 --- a/arch/arm/mach-k3/common.c +++ b/arch/arm/mach-k3/common.c @@ -283,8 +283,10 @@ int misc_init_r(void) }
/* Default FIT boot on HS-SE devices */ - if (get_device_type() == K3_DEVICE_TYPE_HS_SE) + if (get_device_type() == K3_DEVICE_TYPE_HS_SE) { env_set("boot_fit", "1"); + env_set("secure_rprocs", "1"); + }
return 0; }
Are you Cc'ing random people with this? Please don't do it.
I used names names popped up while running get_maintainer.pl script of u-boot
your email id was there for patch-3 of this series
./scripts/get_maintainer.pl 0003-include-env-ti-Add-support-for-secure-firmwares.patch Joe Hershberger joe.hershberger@ni.com (maintainer:ENVIRONMENT) Tom Rini trini@konsulko.com (maintainer:THE REST) Udit Kumar u-kumar1@ti.com (commit_signer:1/2=50%,authored:1/2=50%,commit_signer:1/7=14%,authored:1/7=14%) Simon Glass sjg@chromium.org (commit_signer:1/2=50%,authored:1/2=50%,authored:1/7=14%) Andy Shevchenko andriy.shevchenko@linux.intel.com (commit_signer:1/2=50%) Bin Meng bmeng.cn@gmail.com (commit_signer:1/2=50%) Manorit Chawdhry m-chawdhry@ti.com (commit_signer:1/2=50%,commit_signer:5/7=71%,authored:4/7=57%) Mattijs Korpershoek mkorpershoek@baylibre.com (commit_signer:4/7=57%) Nishanth Menon nm@ti.com (commit_signer:1/7=14%,authored:1/7=14%) Siddharth Vadapalli s-vadapalli@ti.com (commit_signer:1/7=14%) u-boot@lists.denx.de (open list)
Nice, the tool is broken. Please, work with the respective people to fix a tool or to tune it to avoid such mistakes in the future.
(Hint: I would first disable Git fallback completely)
So you were cc'd thanks to: commit 5e541a05f70296dbad07fc1f4e8678ad207bb476 Author: Simon Glass sjg@chromium.org Date: Sun Jul 30 21:01:45 2023 -0600
env: Use include/env for text-environment includes
The 'environment' word is too long. We mostly use 'env' in U-Boot, so use that as the name of the include directory too.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Andy Shevchenko andriy.shevchenko@linux.intel.com # Intel Edison Reviewed-by: Bin Meng bmeng.cn@gmail.com
And, I'm sorry because there are other contributors who get upset when git fallback doesn't find them (because it also ages out after a year). In this case there's not even a "tweak the threshold" option since there's only a single commit to the file so you're in 100% of them.
env: Use include/env for text-environment includes The 'environment' word is too long. We mostly use 'env' in U-Boot, so use that as the name of the include directory too. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> # Intel Edison
Yeah, and it even explicitly stated what I reviewed from that code...
Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
Just an example of false positive by get_maintainer.pl :-( And a confirmation of what I said — tool is broken.
It's an imperfect tool, yes. A quick check shows that if you never want to be cc'd from a git tag, you can add yourself to .get_maintainer.ignore and you will still be matched for things you have an explicit MAINTAINER entry for.
But this will kill me being a maintainer of U-Boot parts (regarding to a certain platform) which is not what I want.
On 5/21/2024 7:59 PM, Andy Shevchenko wrote: > On Tue, May 21, 2024 at 04:26:44PM +0530, Udit Kumar wrote:
> Are you Cc'ing random people with this? > Please don't do it.
With a quick local test, no, it still reported you for edison stuff since that's not where the ignore list comes in.
On Tue, May 21, 2024 at 08:59:17PM +0530, Kumar, Udit wrote: > On 5/21/2024 7:59 PM, Andy Shevchenko wrote: > > On Tue, May 21, 2024 at 04:26:44PM +0530, Udit Kumar wrote:
> > Are you Cc'ing random people with this? > > Please don't do it. > > I used names names popped up while running get_maintainer.pl script of > u-boot > > your email id was there for patch-3 of this series
I see. Still looking at the rate of false positives so far from U-Boot project I don't see that a big hammer, like the proposed one, should be used. Better to teach people on how to use/tune the tool, it will be helpful in a long-term.
On Tue, May 21, 2024 at 07:12:09PM +0300, Andy Shevchenko wrote: > On Tue, May 21, 2024 at 08:59:17PM +0530, Kumar, Udit wrote: > > On 5/21/2024 7:59 PM, Andy Shevchenko wrote: > > > On Tue, May 21, 2024 at 04:26:44PM +0530, Udit Kumar wrote:
> > > Are you Cc'ing random people with this? > > > Please don't do it. > > > > I used names names popped up while running get_maintainer.pl script of > > u-boot > > > > your email id was there for patch-3 of this series > > Nice, the tool is broken. Please, work with the respective people to fix a tool > or to tune it to avoid such mistakes in the future. > > (Hint: I would first disable Git fallback completely)
Long term, it would be best if nearly everything had a real MAINTAINERS entry. Short term, I don't know how to reconcile "I don't want to be found via git history" with "Why wasn't I cc'd on a patch? Oh, because I touched it more than a year ago? I don't like that!" in a way other than: - Encouraging people to add themselves to / expand existing MAINTAINERS entries. - Add themselves to the ignore list if they don't want to be found for other contributions they made.
Andy Shevchenko
Kumar, Udit
Udit Kumar
