[PATCH] sunxi: board: Fix UART PortF pinmux setup
When CONFIG_UART0_PORT_F is defined, we try to configure two PortF pins (usually used for the SD card) as UART0. Some SoCs use the mux value of 3 for this, while others use 4.
The combination of Kconfig symbols we currently use was not quite right: we mis-configure the A31, A64, H6 and H616.
Going through the list in the pinctrl driver, there are only a few older SoCs that use a value of 4, so revert the #ifdef clause, and name those explicitly, instead of the other way around.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/mach-sunxi/board.c | 13 +++++++------ 1 file changed, 7 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 173e946465d..8f7c894286d 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -87,15 +87,16 @@ static int gpio_init(void) sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUNXI_GPIO_INPUT); sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUNXI_GPIO_INPUT); #endif -#if (defined(CONFIG_MACH_SUN8I) && !defined(CONFIG_MACH_SUN8I_R40)) || \ - defined(CONFIG_MACH_SUNIV) - sunxi_gpio_set_cfgpin(SUNXI_GPF(2), SUN8I_GPF_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUN8I_GPF_UART0); -#else +#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN5I) || \ + defined(CONFIG_MACH_SUN7I) || defined(CONFIG_MACH_SUN8I_R40) || \ + defined(CONFIG_MACH_SUN9I) sunxi_gpio_set_cfgpin(SUNXI_GPF(2), SUNXI_GPF_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUNXI_GPF_UART0); +#else + sunxi_gpio_set_cfgpin(SUNXI_GPF(2), SUN8I_GPF_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUN8I_GPF_UART0); #endif - sunxi_gpio_set_pull(SUNXI_GPF(4), 1); + sunxi_gpio_set_pull(SUNXI_GPF(4), SUNXI_GPIO_PULL_UP); #elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUNIV) sunxi_gpio_set_cfgpin(SUNXI_GPE(0), SUNIV_GPE_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPE(1), SUNIV_GPE_UART0);
Reviewed-by: Samuel Holland samuel@sholland.org
On Fri, 6 May 2022 01:37:03 +0100 Andre Przywara andre.przywara@arm.com wrote:
Applied to sunxi/master.
Thanks, Andre
- defined(CONFIG_MACH_SUN7I) || defined(CONFIG_MACH_SUN8I_R40) || \
- defined(CONFIG_MACH_SUN9I) sunxi_gpio_set_cfgpin(SUNXI_GPF(2), SUNXI_GPF_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUNXI_GPF_UART0);
+#else
#endif
- sunxi_gpio_set_pull(SUNXI_GPF(4), SUNXI_GPIO_PULL_UP);
Andre Przywara
Samuel Holland
