[U-Boot] [PATCH v2 1/2] rockchip: dts: rk3399: sync with kernel dts
The kernel dts has update a lot since the first time we commit rk3399.dtsi, sync with kernel for further development.
Signed-off-by: Kever Yang kever.yang@rock-chips.com Acked-by: Simon Glass sjg@chromium.org ---
Changes in v2: None
arch/arm/dts/rk3399.dtsi | 1274 +++++++++++++++++++++++++----- include/dt-bindings/pinctrl/rockchip.h | 35 +- include/dt-bindings/power/rk3399-power.h | 53 ++ 3 files changed, 1157 insertions(+), 205 deletions(-) create mode 100644 include/dt-bindings/power/rk3399-power.h
diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi index a51015f..5d37a1e 100644 --- a/arch/arm/dts/rk3399.dtsi +++ b/arch/arm/dts/rk3399.dtsi @@ -1,5 +1,5 @@ /* - * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * Copyright (c) 2016-2017 Fuzhou Rockchip Electronics Co., Ltd. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -9,6 +9,8 @@ #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/pinctrl/rockchip.h> +#include <dt-bindings/power/rk3399-power.h> +#include <dt-bindings/thermal/thermal.h> #define USB_CLASS_HUB 9
/ { @@ -19,6 +21,15 @@ #size-cells = <2>;
aliases { + i2c0 = &i2c0; + i2c1 = &i2c1; + i2c2 = &i2c2; + i2c3 = &i2c3; + i2c4 = &i2c4; + i2c5 = &i2c5; + i2c6 = &i2c6; + i2c7 = &i2c7; + i2c8 = &i2c8; serial0 = &uart0; serial1 = &uart1; serial2 = &uart2; @@ -26,7 +37,6 @@ serial4 = &uart4; mmc0 = &sdhci; mmc1 = &sdmmc; - i2c0 = &i2c0; };
cpus { @@ -110,6 +120,16 @@ }; };
+ pmu_a53 { + compatible = "arm,cortex-a53-pmu"; + interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_LOW &ppi_cluster0>; + }; + + pmu_a72 { + compatible = "arm,cortex-a72-pmu"; + interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_LOW &ppi_cluster1>; + }; + psci { compatible = "arm,psci-1.0"; method = "smc"; @@ -117,10 +137,11 @@
timer { compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>, - <GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>, - <GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>, - <GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>; + interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW 0>, + <GIC_PPI 14 IRQ_TYPE_LEVEL_LOW 0>, + <GIC_PPI 11 IRQ_TYPE_LEVEL_LOW 0>, + <GIC_PPI 10 IRQ_TYPE_LEVEL_LOW 0>; + arm,no-tick-in-suspend; };
xin24m: xin24m { @@ -139,8 +160,8 @@ dmac_bus: dma-controller@ff6d0000 { compatible = "arm,pl330", "arm,primecell"; reg = <0x0 0xff6d0000 0x0 0x4000>; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH 0>; #dma-cells = <1>; clocks = <&cru ACLK_DMAC0_PERILP>; clock-names = "apb_pclk"; @@ -149,24 +170,92 @@ dmac_peri: dma-controller@ff6e0000 { compatible = "arm,pl330", "arm,primecell"; reg = <0x0 0xff6e0000 0x0 0x4000>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH 0>; #dma-cells = <1>; clocks = <&cru ACLK_DMAC1_PERILP>; clock-names = "apb_pclk"; }; };
+ pcie0: pcie@f8000000 { + compatible = "rockchip,rk3399-pcie"; + reg = <0x0 0xf8000000 0x0 0x2000000>, + <0x0 0xfd000000 0x0 0x1000000>; + reg-names = "axi-base", "apb-base"; + #address-cells = <3>; + #size-cells = <2>; + #interrupt-cells = <1>; + aspm-no-l0s; + bus-range = <0x0 0x1>; + clocks = <&cru ACLK_PCIE>, <&cru ACLK_PERF_PCIE>, + <&cru PCLK_PCIE>, <&cru SCLK_PCIE_PM>; + clock-names = "aclk", "aclk-perf", + "hclk", "pm"; + interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH 0>; + interrupt-names = "sys", "legacy", "client"; + interrupt-map-mask = <0 0 0 7>; + interrupt-map = <0 0 0 1 &pcie0_intc 0>, + <0 0 0 2 &pcie0_intc 1>, + <0 0 0 3 &pcie0_intc 2>, + <0 0 0 4 &pcie0_intc 3>; + linux,pci-domain = <0>; + max-link-speed = <1>; + msi-map = <0x0 &its 0x0 0x1000>; + phys = <&pcie_phy>; + phy-names = "pcie-phy"; + ranges = <0x83000000 0x0 0xfa000000 0x0 0xfa000000 0x0 0x600000 + 0x81000000 0x0 0xfa600000 0x0 0xfa600000 0x0 0x100000>; + resets = <&cru SRST_PCIE_CORE>, <&cru SRST_PCIE_MGMT>, + <&cru SRST_PCIE_MGMT_STICKY>, <&cru SRST_PCIE_PIPE>, + <&cru SRST_PCIE_PM>, <&cru SRST_P_PCIE>, + <&cru SRST_A_PCIE>; + reset-names = "core", "mgmt", "mgmt-sticky", "pipe", + "pm", "pclk", "aclk"; + status = "disabled"; + + pcie0_intc: interrupt-controller { + interrupt-controller; + #address-cells = <0>; + #interrupt-cells = <1>; + }; + }; + + gmac: ethernet@fe300000 { + compatible = "rockchip,rk3399-gmac"; + reg = <0x0 0xfe300000 0x0 0x10000>; + interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH 0>; + interrupt-names = "macirq"; + clocks = <&cru SCLK_MAC>, <&cru SCLK_MAC_RX>, + <&cru SCLK_MAC_TX>, <&cru SCLK_MACREF>, + <&cru SCLK_MACREF_OUT>, <&cru ACLK_GMAC>, + <&cru PCLK_GMAC>; + clock-names = "stmmaceth", "mac_clk_rx", + "mac_clk_tx", "clk_mac_ref", + "clk_mac_refout", "aclk_mac", + "pclk_mac"; + power-domains = <&power RK3399_PD_GMAC>; + resets = <&cru SRST_A_GMAC>; + reset-names = "stmmaceth"; + rockchip,grf = <&grf>; + status = "disabled"; + }; + sdio0: dwmmc@fe310000 { compatible = "rockchip,rk3399-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x0 0xfe310000 0x0 0x4000>; - interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>; - clock-freq-min-max = <400000 150000000>; + interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH 0>; + max-frequency = <150000000>; clocks = <&cru HCLK_SDIO>, <&cru SCLK_SDIO>, <&cru SCLK_SDIO_DRV>, <&cru SCLK_SDIO_SAMPLE>; clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; + power-domains = <&power RK3399_PD_SDIOAUDIO>; + resets = <&cru SRST_SDIO0>; + reset-names = "reset"; status = "disabled"; };
@@ -174,14 +263,15 @@ compatible = "rockchip,rk3399-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x0 0xfe320000 0x0 0x4000>; - interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; - clock-freq-min-max = <400000 150000000>; - clocks = <&cru SCLK_SDMMC>, <&cru HCLK_SDMMC>, + interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH 0>; + max-frequency = <150000000>; + clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; - clock-names = "ciu", "biu", "ciu-drive", "ciu-sample"; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk>; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; + power-domains = <&power RK3399_PD_SD>; + resets = <&cru SRST_SDMMC>; + reset-names = "reset"; status = "disabled"; };
@@ -189,50 +279,74 @@ u-boot,dm-pre-reloc; compatible = "rockchip,rk3399-sdhci-5.1", "arasan,sdhci-5.1"; reg = <0x0 0xfe330000 0x0 0x10000>; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH 0>; + arasan,soc-ctl-syscon = <&grf>; assigned-clocks = <&cru SCLK_EMMC>; assigned-clock-rates = <200000000>; max-frequency = <200000000>; clocks = <&cru SCLK_EMMC>, <&cru ACLK_EMMC>; clock-names = "clk_xin", "clk_ahb"; + clock-output-names = "emmc_cardclock"; + #clock-cells = <0>; phys = <&emmc_phy>; phy-names = "phy_arasan"; + power-domains = <&power RK3399_PD_EMMC>; status = "disabled"; };
usb_host0_ehci: usb@fe380000 { compatible = "generic-ehci"; reg = <0x0 0xfe380000 0x0 0x20000>; - interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>; - clock-names = "hclk_host0", "hclk_host0_arb"; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>, + <&u2phy0>; + clock-names = "usbhost", "arbiter", + "utmi"; + phys = <&u2phy0_host>; + phy-names = "usb"; + power-domains = <&power RK3399_PD_PERIHP>; status = "disabled"; };
usb_host0_ohci: usb@fe3a0000 { compatible = "generic-ohci"; reg = <0x0 0xfe3a0000 0x0 0x20000>; - interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>; - clock-names = "hclk_host0", "hclk_host0_arb"; + interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>, + <&u2phy0>; + clock-names = "usbhost", "arbiter", + "utmi"; + phys = <&u2phy0_host>; + phy-names = "usb"; + power-domains = <&power RK3399_PD_PERIHP>; status = "disabled"; };
usb_host1_ehci: usb@fe3c0000 { compatible = "generic-ehci"; reg = <0x0 0xfe3c0000 0x0 0x20000>; - interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>; - clock-names = "hclk_host1", "hclk_host1_arb"; + interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>, + <&u2phy1>; + clock-names = "usbhost", "arbiter", + "utmi"; + phys = <&u2phy1_host>; + phy-names = "usb"; + power-domains = <&power RK3399_PD_PERIHP>; status = "disabled"; };
usb_host1_ohci: usb@fe3e0000 { compatible = "generic-ohci"; reg = <0x0 0xfe3e0000 0x0 0x20000>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>; - clock-names = "hclk_host1", "hclk_host1_arb"; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>, + <&u2phy1>; + clock-names = "usbhost", "arbiter", + "utmi"; + phys = <&u2phy1_host>; + phy-names = "usb"; + power-domains = <&power RK3399_PD_PERIHP>; status = "disabled"; };
@@ -280,7 +394,7 @@
gic: interrupt-controller@fee00000 { compatible = "arm,gic-v3"; - #interrupt-cells = <3>; + #interrupt-cells = <4>; #address-cells = <2>; #size-cells = <2>; ranges; @@ -291,12 +405,124 @@ <0x0 0xfff00000 0 0x10000>, /* GICC */ <0x0 0xfff10000 0 0x10000>, /* GICH */ <0x0 0xfff20000 0 0x10000>; /* GICV */ - interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH 0>; its: interrupt-controller@fee20000 { compatible = "arm,gic-v3-its"; msi-controller; reg = <0x0 0xfee20000 0x0 0x20000>; }; + + ppi-partitions { + ppi_cluster0: interrupt-partition-0 { + affinity = <&cpu_l0 &cpu_l1 &cpu_l2 &cpu_l3>; + }; + + ppi_cluster1: interrupt-partition-1 { + affinity = <&cpu_b0 &cpu_b1>; + }; + }; + }; + + saradc: saradc@ff100000 { + compatible = "rockchip,rk3399-saradc"; + reg = <0x0 0xff100000 0x0 0x100>; + interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH 0>; + #io-channel-cells = <1>; + clocks = <&cru SCLK_SARADC>, <&cru PCLK_SARADC>; + clock-names = "saradc", "apb_pclk"; + resets = <&cru SRST_P_SARADC>; + reset-names = "saradc-apb"; + status = "disabled"; + }; + + i2c1: i2c@ff110000 { + compatible = "rockchip,rk3399-i2c"; + reg = <0x0 0xff110000 0x0 0x1000>; + assigned-clocks = <&cru SCLK_I2C1>; + assigned-clock-rates = <200000000>; + clocks = <&cru SCLK_I2C1>, <&cru PCLK_I2C1>; + clock-names = "i2c", "pclk"; + interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH 0>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_xfer>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c2: i2c@ff120000 { + compatible = "rockchip,rk3399-i2c"; + reg = <0x0 0xff120000 0x0 0x1000>; + assigned-clocks = <&cru SCLK_I2C2>; + assigned-clock-rates = <200000000>; + clocks = <&cru SCLK_I2C2>, <&cru PCLK_I2C2>; + clock-names = "i2c", "pclk"; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH 0>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_xfer>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c3: i2c@ff130000 { + compatible = "rockchip,rk3399-i2c"; + reg = <0x0 0xff130000 0x0 0x1000>; + assigned-clocks = <&cru SCLK_I2C3>; + assigned-clock-rates = <200000000>; + clocks = <&cru SCLK_I2C3>, <&cru PCLK_I2C3>; + clock-names = "i2c", "pclk"; + interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH 0>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c3_xfer>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c5: i2c@ff140000 { + compatible = "rockchip,rk3399-i2c"; + reg = <0x0 0xff140000 0x0 0x1000>; + assigned-clocks = <&cru SCLK_I2C5>; + assigned-clock-rates = <200000000>; + clocks = <&cru SCLK_I2C5>, <&cru PCLK_I2C5>; + clock-names = "i2c", "pclk"; + interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH 0>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c5_xfer>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c6: i2c@ff150000 { + compatible = "rockchip,rk3399-i2c"; + reg = <0x0 0xff150000 0x0 0x1000>; + assigned-clocks = <&cru SCLK_I2C6>; + assigned-clock-rates = <200000000>; + clocks = <&cru SCLK_I2C6>, <&cru PCLK_I2C6>; + clock-names = "i2c", "pclk"; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH 0>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c6_xfer>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c7: i2c@ff160000 { + compatible = "rockchip,rk3399-i2c"; + reg = <0x0 0xff160000 0x0 0x1000>; + assigned-clocks = <&cru SCLK_I2C7>; + assigned-clock-rates = <200000000>; + clocks = <&cru SCLK_I2C7>, <&cru PCLK_I2C7>; + clock-names = "i2c", "pclk"; + interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH 0>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c7_xfer>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; };
uart0: serial@ff180000 { @@ -304,7 +530,7 @@ reg = <0x0 0xff180000 0x0 0x100>; clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; clock-names = "baudclk", "apb_pclk"; - interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH 0>; reg-shift = <2>; reg-io-width = <4>; pinctrl-names = "default"; @@ -317,7 +543,7 @@ reg = <0x0 0xff190000 0x0 0x100>; clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; clock-names = "baudclk", "apb_pclk"; - interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH 0>; reg-shift = <2>; reg-io-width = <4>; pinctrl-names = "default"; @@ -330,7 +556,7 @@ reg = <0x0 0xff1a0000 0x0 0x100>; clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; clock-names = "baudclk", "apb_pclk"; - interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH 0>; clock-frequency = <24000000>; reg-shift = <2>; reg-io-width = <4>; @@ -344,7 +570,7 @@ reg = <0x0 0xff1b0000 0x0 0x100>; clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; clock-names = "baudclk", "apb_pclk"; - interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH 0>; reg-shift = <2>; reg-io-width = <4>; pinctrl-names = "default"; @@ -357,7 +583,7 @@ reg = <0x0 0xff1c0000 0x0 0x1000>; clocks = <&cru SCLK_SPI0>, <&cru PCLK_SPI0>; clock-names = "spiclk", "apb_pclk"; - interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH 0>; pinctrl-names = "default"; pinctrl-0 = <&spi0_clk &spi0_tx &spi0_rx &spi0_cs0>; #address-cells = <1>; @@ -370,7 +596,7 @@ reg = <0x0 0xff1d0000 0x0 0x1000>; clocks = <&cru SCLK_SPI1>, <&cru PCLK_SPI1>; clock-names = "spiclk", "apb_pclk"; - interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH 0>; pinctrl-names = "default"; pinctrl-0 = <&spi1_clk &spi1_tx &spi1_rx &spi1_cs0>; #address-cells = <1>; @@ -383,7 +609,7 @@ reg = <0x0 0xff1e0000 0x0 0x1000>; clocks = <&cru SCLK_SPI2>, <&cru PCLK_SPI2>; clock-names = "spiclk", "apb_pclk"; - interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH 0>; pinctrl-names = "default"; pinctrl-0 = <&spi2_clk &spi2_tx &spi2_rx &spi2_cs0>; #address-cells = <1>; @@ -396,7 +622,7 @@ reg = <0x0 0xff1f0000 0x0 0x1000>; clocks = <&cru SCLK_SPI4>, <&cru PCLK_SPI4>; clock-names = "spiclk", "apb_pclk"; - interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH 0>; pinctrl-names = "default"; pinctrl-0 = <&spi4_clk &spi4_tx &spi4_rx &spi4_cs0>; #address-cells = <1>; @@ -409,7 +635,7 @@ reg = <0x0 0xff200000 0x0 0x1000>; clocks = <&cru SCLK_SPI5>, <&cru PCLK_SPI5>; clock-names = "spiclk", "apb_pclk"; - interrupts = <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH 0>; pinctrl-names = "default"; pinctrl-0 = <&spi5_clk &spi5_tx &spi5_rx &spi5_cs0>; #address-cells = <1>; @@ -417,6 +643,375 @@ status = "disabled"; };
+ thermal_zones: thermal-zones { + cpu_thermal: cpu { + polling-delay-passive = <100>; + polling-delay = <1000>; + + thermal-sensors = <&tsadc 0>; + + trips { + cpu_alert0: cpu_alert0 { + temperature = <70000>; + hysteresis = <2000>; + type = "passive"; + }; + cpu_alert1: cpu_alert1 { + temperature = <75000>; + hysteresis = <2000>; + type = "passive"; + }; + cpu_crit: cpu_crit { + temperature = <95000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu_alert0>; + cooling-device = + <&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + map1 { + trip = <&cpu_alert1>; + cooling-device = + <&cpu_l0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + gpu_thermal: gpu { + polling-delay-passive = <100>; + polling-delay = <1000>; + + thermal-sensors = <&tsadc 1>; + + trips { + gpu_alert0: gpu_alert0 { + temperature = <75000>; + hysteresis = <2000>; + type = "passive"; + }; + gpu_crit: gpu_crit { + temperature = <95000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&gpu_alert0>; + cooling-device = + <&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + }; + + tsadc: tsadc@ff260000 { + compatible = "rockchip,rk3399-tsadc"; + reg = <0x0 0xff260000 0x0 0x100>; + interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH 0>; + assigned-clocks = <&cru SCLK_TSADC>; + assigned-clock-rates = <750000>; + clocks = <&cru SCLK_TSADC>, <&cru PCLK_TSADC>; + clock-names = "tsadc", "apb_pclk"; + resets = <&cru SRST_TSADC>; + reset-names = "tsadc-apb"; + rockchip,grf = <&grf>; + rockchip,hw-tshut-temp = <95000>; + pinctrl-names = "init", "default", "sleep"; + pinctrl-0 = <&otp_gpio>; + pinctrl-1 = <&otp_out>; + pinctrl-2 = <&otp_gpio>; + #thermal-sensor-cells = <1>; + status = "disabled"; + }; + + qos_emmc: qos@ffa58000 { + compatible = "syscon"; + reg = <0x0 0xffa58000 0x0 0x20>; + }; + + qos_gmac: qos@ffa5c000 { + compatible = "syscon"; + reg = <0x0 0xffa5c000 0x0 0x20>; + }; + + qos_pcie: qos@ffa60080 { + compatible = "syscon"; + reg = <0x0 0xffa60080 0x0 0x20>; + }; + + qos_usb_host0: qos@ffa60100 { + compatible = "syscon"; + reg = <0x0 0xffa60100 0x0 0x20>; + }; + + qos_usb_host1: qos@ffa60180 { + compatible = "syscon"; + reg = <0x0 0xffa60180 0x0 0x20>; + }; + + qos_usb_otg0: qos@ffa70000 { + compatible = "syscon"; + reg = <0x0 0xffa70000 0x0 0x20>; + }; + + qos_usb_otg1: qos@ffa70080 { + compatible = "syscon"; + reg = <0x0 0xffa70080 0x0 0x20>; + }; + + qos_sd: qos@ffa74000 { + compatible = "syscon"; + reg = <0x0 0xffa74000 0x0 0x20>; + }; + + qos_sdioaudio: qos@ffa76000 { + compatible = "syscon"; + reg = <0x0 0xffa76000 0x0 0x20>; + }; + + qos_hdcp: qos@ffa90000 { + compatible = "syscon"; + reg = <0x0 0xffa90000 0x0 0x20>; + }; + + qos_iep: qos@ffa98000 { + compatible = "syscon"; + reg = <0x0 0xffa98000 0x0 0x20>; + }; + + qos_isp0_m0: qos@ffaa0000 { + compatible = "syscon"; + reg = <0x0 0xffaa0000 0x0 0x20>; + }; + + qos_isp0_m1: qos@ffaa0080 { + compatible = "syscon"; + reg = <0x0 0xffaa0080 0x0 0x20>; + }; + + qos_isp1_m0: qos@ffaa8000 { + compatible = "syscon"; + reg = <0x0 0xffaa8000 0x0 0x20>; + }; + + qos_isp1_m1: qos@ffaa8080 { + compatible = "syscon"; + reg = <0x0 0xffaa8080 0x0 0x20>; + }; + + qos_rga_r: qos@ffab0000 { + compatible = "syscon"; + reg = <0x0 0xffab0000 0x0 0x20>; + }; + + qos_rga_w: qos@ffab0080 { + compatible = "syscon"; + reg = <0x0 0xffab0080 0x0 0x20>; + }; + + qos_video_m0: qos@ffab8000 { + compatible = "syscon"; + reg = <0x0 0xffab8000 0x0 0x20>; + }; + + qos_video_m1_r: qos@ffac0000 { + compatible = "syscon"; + reg = <0x0 0xffac0000 0x0 0x20>; + }; + + qos_video_m1_w: qos@ffac0080 { + compatible = "syscon"; + reg = <0x0 0xffac0080 0x0 0x20>; + }; + + qos_vop_big_r: qos@ffac8000 { + compatible = "syscon"; + reg = <0x0 0xffac8000 0x0 0x20>; + }; + + qos_vop_big_w: qos@ffac8080 { + compatible = "syscon"; + reg = <0x0 0xffac8080 0x0 0x20>; + }; + + qos_vop_little: qos@ffad0000 { + compatible = "syscon"; + reg = <0x0 0xffad0000 0x0 0x20>; + }; + + qos_perihp: qos@ffad8080 { + compatible = "syscon"; + reg = <0x0 0xffad8080 0x0 0x20>; + }; + + qos_gpu: qos@ffae0000 { + compatible = "syscon"; + reg = <0x0 0xffae0000 0x0 0x20>; + }; + + pmu: power-management@ff310000 { + compatible = "rockchip,rk3399-pmu", "syscon", "simple-mfd"; + reg = <0x0 0xff310000 0x0 0x1000>; + + /* + * Note: RK3399 supports 6 voltage domains including VD_CORE_L, + * VD_CORE_B, VD_CENTER, VD_GPU, VD_LOGIC and VD_PMU. + * Some of the power domains are grouped together for every + * voltage domain. + * The detail contents as below. + */ + power: power-controller { + compatible = "rockchip,rk3399-power-controller"; + #power-domain-cells = <1>; + #address-cells = <1>; + #size-cells = <0>; + + /* These power domains are grouped by VD_CENTER */ + pd_iep@RK3399_PD_IEP { + reg = <RK3399_PD_IEP>; + clocks = <&cru ACLK_IEP>, + <&cru HCLK_IEP>; + pm_qos = <&qos_iep>; + }; + pd_rga@RK3399_PD_RGA { + reg = <RK3399_PD_RGA>; + clocks = <&cru ACLK_RGA>, + <&cru HCLK_RGA>; + pm_qos = <&qos_rga_r>, + <&qos_rga_w>; + }; + pd_vcodec@RK3399_PD_VCODEC { + reg = <RK3399_PD_VCODEC>; + clocks = <&cru ACLK_VCODEC>, + <&cru HCLK_VCODEC>; + pm_qos = <&qos_video_m0>; + }; + pd_vdu@RK3399_PD_VDU { + reg = <RK3399_PD_VDU>; + clocks = <&cru ACLK_VDU>, + <&cru HCLK_VDU>; + pm_qos = <&qos_video_m1_r>, + <&qos_video_m1_w>; + }; + + /* These power domains are grouped by VD_GPU */ + pd_gpu@RK3399_PD_GPU { + reg = <RK3399_PD_GPU>; + clocks = <&cru ACLK_GPU>; + pm_qos = <&qos_gpu>; + }; + + /* These power domains are grouped by VD_LOGIC */ + pd_edp@RK3399_PD_EDP { + reg = <RK3399_PD_EDP>; + clocks = <&cru PCLK_EDP_CTRL>; + }; + pd_emmc@RK3399_PD_EMMC { + reg = <RK3399_PD_EMMC>; + clocks = <&cru ACLK_EMMC>; + pm_qos = <&qos_emmc>; + }; + pd_gmac@RK3399_PD_GMAC { + reg = <RK3399_PD_GMAC>; + clocks = <&cru ACLK_GMAC>, + <&cru PCLK_GMAC>; + pm_qos = <&qos_gmac>; + }; + pd_perihp@RK3399_PD_PERIHP { + reg = <RK3399_PD_PERIHP>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&cru ACLK_PERIHP>; + pm_qos = <&qos_perihp>, + <&qos_pcie>, + <&qos_usb_host0>, + <&qos_usb_host1>; + + pd_sd@RK3399_PD_SD { + reg = <RK3399_PD_SD>; + clocks = <&cru HCLK_SDMMC>, + <&cru SCLK_SDMMC>; + pm_qos = <&qos_sd>; + }; + }; + pd_sdioaudio@RK3399_PD_SDIOAUDIO { + reg = <RK3399_PD_SDIOAUDIO>; + clocks = <&cru HCLK_SDIO>; + pm_qos = <&qos_sdioaudio>; + }; + pd_usb3@RK3399_PD_USB3 { + reg = <RK3399_PD_USB3>; + clocks = <&cru ACLK_USB3>; + pm_qos = <&qos_usb_otg0>, + <&qos_usb_otg1>; + }; + pd_vio@RK3399_PD_VIO { + reg = <RK3399_PD_VIO>; + #address-cells = <1>; + #size-cells = <0>; + + pd_hdcp@RK3399_PD_HDCP { + reg = <RK3399_PD_HDCP>; + clocks = <&cru ACLK_HDCP>, + <&cru HCLK_HDCP>, + <&cru PCLK_HDCP>; + pm_qos = <&qos_hdcp>; + }; + pd_isp0@RK3399_PD_ISP0 { + reg = <RK3399_PD_ISP0>; + clocks = <&cru ACLK_ISP0>, + <&cru HCLK_ISP0>; + pm_qos = <&qos_isp0_m0>, + <&qos_isp0_m1>; + }; + pd_isp1@RK3399_PD_ISP1 { + reg = <RK3399_PD_ISP1>; + clocks = <&cru ACLK_ISP1>, + <&cru HCLK_ISP1>; + pm_qos = <&qos_isp1_m0>, + <&qos_isp1_m1>; + }; + pd_tcpc0@RK3399_PD_TCPC0 { + reg = <RK3399_PD_TCPD0>; + clocks = <&cru SCLK_UPHY0_TCPDCORE>, + <&cru SCLK_UPHY0_TCPDPHY_REF>; + }; + pd_tcpc1@RK3399_PD_TCPC1 { + reg = <RK3399_PD_TCPD1>; + clocks = <&cru SCLK_UPHY1_TCPDCORE>, + <&cru SCLK_UPHY1_TCPDPHY_REF>; + }; + pd_vo@RK3399_PD_VO { + reg = <RK3399_PD_VO>; + #address-cells = <1>; + #size-cells = <0>; + + pd_vopb@RK3399_PD_VOPB { + reg = <RK3399_PD_VOPB>; + clocks = <&cru ACLK_VOP0>, + <&cru HCLK_VOP0>; + pm_qos = <&qos_vop_big_r>, + <&qos_vop_big_w>; + }; + pd_vopl@RK3399_PD_VOPL { + reg = <RK3399_PD_VOPL>; + clocks = <&cru ACLK_VOP1>, + <&cru HCLK_VOP1>; + pm_qos = <&qos_vop_little>; + }; + }; + }; + }; + }; + pmugrf: syscon@ff320000 { u-boot,dm-pre-reloc; compatible = "rockchip,rk3399-pmugrf", "syscon", "simple-mfd"; @@ -441,7 +1036,7 @@ reg = <0x0 0xff350000 0x0 0x1000>; clocks = <&pmucru SCLK_SPI3_PMU>, <&pmucru PCLK_SPI3_PMU>; clock-names = "spiclk", "apb_pclk"; - interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH 0>; pinctrl-names = "default"; pinctrl-0 = <&spi3_clk &spi3_tx &spi3_rx &spi3_cs0>; #address-cells = <1>; @@ -454,7 +1049,7 @@ reg = <0x0 0xff370000 0x0 0x100>; clocks = <&pmucru SCLK_UART4_PMU>, <&pmucru PCLK_UART4_PMU>; clock-names = "baudclk", "apb_pclk"; - interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH 0>; reg-shift = <2>; reg-io-width = <4>; pinctrl-names = "default"; @@ -477,6 +1072,36 @@ status = "disabled"; };
+ i2c4: i2c@ff3d0000 { + compatible = "rockchip,rk3399-i2c"; + reg = <0x0 0xff3d0000 0x0 0x1000>; + assigned-clocks = <&pmucru SCLK_I2C4_PMU>; + assigned-clock-rates = <200000000>; + clocks = <&pmucru SCLK_I2C4_PMU>, <&pmucru PCLK_I2C4_PMU>; + clock-names = "i2c", "pclk"; + interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH 0>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c4_xfer>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c8: i2c@ff3e0000 { + compatible = "rockchip,rk3399-i2c"; + reg = <0x0 0xff3e0000 0x0 0x1000>; + assigned-clocks = <&pmucru SCLK_I2C8_PMU>; + assigned-clock-rates = <200000000>; + clocks = <&pmucru SCLK_I2C8_PMU>, <&pmucru PCLK_I2C8_PMU>; + clock-names = "i2c", "pclk"; + interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH 0>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c8_xfer>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + pwm0: pwm@ff420000 { compatible = "rockchip,rk3399-pwm", "rockchip,rk3288-pwm"; reg = <0x0 0xff420000 0x0 0x10>; @@ -553,10 +1178,43 @@ 0x0 0xffa8c000 0x0 0x1000>; };
+ efuse0: efuse@ff690000 { + compatible = "rockchip,rk3399-efuse"; + reg = <0x0 0xff690000 0x0 0x80>; + #address-cells = <1>; + #size-cells = <1>; + clocks = <&cru PCLK_EFUSE1024NS>; + clock-names = "pclk_efuse"; + + /* Data cells */ + cpu_id: cpu-id@7 { + reg = <0x07 0x10>; + }; + cpub_leakage: cpu-leakage@17 { + reg = <0x17 0x1>; + }; + gpu_leakage: gpu-leakage@18 { + reg = <0x18 0x1>; + }; + center_leakage: center-leakage@19 { + reg = <0x19 0x1>; + }; + cpul_leakage: cpu-leakage@1a { + reg = <0x1a 0x1>; + }; + logic_leakage: logic-leakage@1b { + reg = <0x1b 0x1>; + }; + wafer_info: wafer-info@1c { + reg = <0x1c 0x1>; + }; + }; + pmucru: pmu-clock-controller@ff750000 { u-boot,dm-pre-reloc; compatible = "rockchip,rk3399-pmucru"; reg = <0x0 0xff750000 0x0 0x1000>; + rockchip,grf = <&pmugrf>; #clock-cells = <1>; #reset-cells = <1>; assigned-clocks = <&pmucru PLL_PPLL>; @@ -567,6 +1225,7 @@ u-boot,dm-pre-reloc; compatible = "rockchip,rk3399-cru"; reg = <0x0 0xff760000 0x0 0x1000>; + rockchip,grf = <&grf>; #clock-cells = <1>; #reset-cells = <1>; assigned-clocks = @@ -575,7 +1234,7 @@ <&cru ACLK_PERIHP>, <&cru HCLK_PERIHP>, <&cru PCLK_PERIHP>, <&cru ACLK_PERILP0>, <&cru HCLK_PERILP0>, - <&cru PCLK_PERILP0>, + <&cru PCLK_PERILP0>, <&cru ACLK_CCI>, <&cru HCLK_PERILP1>, <&cru PCLK_PERILP1>; assigned-clock-rates = <594000000>, <800000000>, @@ -583,7 +1242,7 @@ <150000000>, <75000000>, <37500000>, <100000000>, <100000000>, - <50000000>, + <50000000>, <600000000>, <100000000>, <50000000>; };
@@ -599,50 +1258,106 @@ status = "disabled"; };
+ u2phy0: usb2-phy@e450 { + compatible = "rockchip,rk3399-usb2phy"; + reg = <0xe450 0x10>; + clocks = <&cru SCLK_USB2PHY0_REF>; + clock-names = "phyclk"; + #clock-cells = <0>; + clock-output-names = "clk_usbphy0_480m"; + status = "disabled"; + + u2phy0_host: host-port { + #phy-cells = <0>; + interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH 0>; + interrupt-names = "linestate"; + status = "disabled"; + }; + + u2phy0_otg: otg-port { + #phy-cells = <0>; + interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH 0>; + interrupt-names = "otg-bvalid", "otg-id", + "linestate"; + status = "disabled"; + }; + }; + + u2phy1: usb2-phy@e460 { + compatible = "rockchip,rk3399-usb2phy"; + reg = <0xe460 0x10>; + clocks = <&cru SCLK_USB2PHY1_REF>; + clock-names = "phyclk"; + #clock-cells = <0>; + clock-output-names = "clk_usbphy1_480m"; + status = "disabled"; + + u2phy1_host: host-port { + #phy-cells = <0>; + interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH 0>; + interrupt-names = "linestate"; + status = "disabled"; + }; + + u2phy1_otg: otg-port { + #phy-cells = <0>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH 0>; + interrupt-names = "otg-bvalid", "otg-id", + "linestate"; + status = "disabled"; + }; + }; + emmc_phy: phy@f780 { compatible = "rockchip,rk3399-emmc-phy"; reg = <0xf780 0x24>; + clocks = <&sdhci>; + clock-names = "emmcclk"; #phy-cells = <0>; status = "disabled"; }; + + pcie_phy: pcie-phy { + compatible = "rockchip,rk3399-pcie-phy"; + clocks = <&cru SCLK_PCIEPHY_REF>; + clock-names = "refclk"; + #phy-cells = <0>; + resets = <&cru SRST_PCIEPHY>; + reset-names = "phy"; + status = "disabled"; + }; };
- watchdog@ff840000 { + watchdog@ff848000 { compatible = "snps,dw-wdt"; - reg = <0x0 0xff840000 0x0 0x100>; + reg = <0x0 0xff848000 0x0 0x100>; clocks = <&cru PCLK_WDT>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; - }; - - gmac: eth@fe300000 { - compatible = "rockchip,rk3399-gmac"; - reg = <0x0 0xfe300000 0x0 0x10000>; - rockchip,grf = <&grf>; - interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH 0>; - interrupt-names = "macirq"; - clocks = <&cru SCLK_MAC>, <&cru SCLK_MAC_RX>, - <&cru SCLK_MAC_TX>, <&cru SCLK_MACREF>, - <&cru SCLK_MACREF_OUT>, <&cru ACLK_GMAC>, - <&cru PCLK_GMAC>; - clock-names = "stmmaceth", "mac_clk_rx", - "mac_clk_tx", "clk_mac_ref", - "clk_mac_refout", "aclk_mac", - "pclk_mac"; - resets = <&cru SRST_A_GMAC>; - reset-names = "stmmaceth"; - status = "disabled"; - }; + interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH 0>; + }; + + rktimer: rktimer@ff850000 { + compatible = "rockchip,rk3399-timer"; + reg = <0x0 0xff850000 0x0 0x1000>; + interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru PCLK_TIMER0>, <&cru SCLK_TIMER00>; + clock-names = "pclk", "timer"; + };
spdif: spdif@ff870000 { compatible = "rockchip,rk3399-spdif"; reg = <0x0 0xff870000 0x0 0x1000>; - interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH 0>; dmas = <&dmac_bus 7>; dma-names = "tx"; clock-names = "mclk", "hclk"; clocks = <&cru SCLK_SPDIF_8CH>, <&cru HCLK_SPDIF>; pinctrl-names = "default"; pinctrl-0 = <&spdif_bus>; + power-domains = <&power RK3399_PD_SDIOAUDIO>; status = "disabled"; };
@@ -650,37 +1365,40 @@ compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s"; reg = <0x0 0xff880000 0x0 0x1000>; rockchip,grf = <&grf>; - interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH 0>; dmas = <&dmac_bus 0>, <&dmac_bus 1>; dma-names = "tx", "rx"; clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S0_8CH>, <&cru HCLK_I2S0_8CH>; pinctrl-names = "default"; pinctrl-0 = <&i2s0_8ch_bus>; + power-domains = <&power RK3399_PD_SDIOAUDIO>; status = "disabled"; };
i2s1: i2s@ff890000 { compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s"; reg = <0x0 0xff890000 0x0 0x1000>; - interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH 0>; dmas = <&dmac_bus 2>, <&dmac_bus 3>; dma-names = "tx", "rx"; clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S1_8CH>, <&cru HCLK_I2S1_8CH>; pinctrl-names = "default"; pinctrl-0 = <&i2s1_2ch_bus>; + power-domains = <&power RK3399_PD_SDIOAUDIO>; status = "disabled"; };
i2s2: i2s@ff8a0000 { compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s"; reg = <0x0 0xff8a0000 0x0 0x1000>; - interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH 0>; dmas = <&dmac_bus 4>, <&dmac_bus 5>; dma-names = "tx", "rx"; clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S2_8CH>, <&cru HCLK_I2S2_8CH>; + power-domains = <&power RK3399_PD_SDIOAUDIO>; status = "disabled"; };
@@ -697,7 +1415,7 @@ compatible = "rockchip,gpio-bank"; reg = <0x0 0xff720000 0x0 0x100>; clocks = <&pmucru PCLK_GPIO0_PMU>; - interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH 0>;
gpio-controller; #gpio-cells = <0x2>; @@ -710,7 +1428,7 @@ compatible = "rockchip,gpio-bank"; reg = <0x0 0xff730000 0x0 0x100>; clocks = <&pmucru PCLK_GPIO1_PMU>; - interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH 0>;
gpio-controller; #gpio-cells = <0x2>; @@ -723,7 +1441,7 @@ compatible = "rockchip,gpio-bank"; reg = <0x0 0xff780000 0x0 0x100>; clocks = <&cru PCLK_GPIO2>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH 0>;
gpio-controller; #gpio-cells = <0x2>; @@ -736,7 +1454,7 @@ compatible = "rockchip,gpio-bank"; reg = <0x0 0xff788000 0x0 0x100>; clocks = <&cru PCLK_GPIO3>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH 0>;
gpio-controller; #gpio-cells = <0x2>; @@ -749,7 +1467,7 @@ compatible = "rockchip,gpio-bank"; reg = <0x0 0xff790000 0x0 0x100>; clocks = <&cru PCLK_GPIO4>; - interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH 0>;
gpio-controller; #gpio-cells = <0x2>; @@ -800,427 +1518,575 @@ drive-strength = <13>; };
+ clock { + clk_32k: clk-32k { + rockchip,pins = <0 RK_PA0 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + edp { + edp_hpd: edp-hpd { + rockchip,pins = + <4 RK_PC7 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + gmac { + rgmii_pins: rgmii-pins { + rockchip,pins = + /* mac_txclk */ + <3 RK_PC1 RK_FUNC_1 &pcfg_pull_none_13ma>, + /* mac_rxclk */ + <3 RK_PB6 RK_FUNC_1 &pcfg_pull_none>, + /* mac_mdio */ + <3 RK_PB5 RK_FUNC_1 &pcfg_pull_none>, + /* mac_txen */ + <3 RK_PB4 RK_FUNC_1 &pcfg_pull_none_13ma>, + /* mac_clk */ + <3 RK_PB3 RK_FUNC_1 &pcfg_pull_none>, + /* mac_rxdv */ + <3 RK_PB1 RK_FUNC_1 &pcfg_pull_none>, + /* mac_mdc */ + <3 RK_PB0 RK_FUNC_1 &pcfg_pull_none>, + /* mac_rxd1 */ + <3 RK_PA7 RK_FUNC_1 &pcfg_pull_none>, + /* mac_rxd0 */ + <3 RK_PA6 RK_FUNC_1 &pcfg_pull_none>, + /* mac_txd1 */ + <3 RK_PA5 RK_FUNC_1 &pcfg_pull_none_13ma>, + /* mac_txd0 */ + <3 RK_PA4 RK_FUNC_1 &pcfg_pull_none_13ma>, + /* mac_rxd3 */ + <3 RK_PA3 RK_FUNC_1 &pcfg_pull_none>, + /* mac_rxd2 */ + <3 RK_PA2 RK_FUNC_1 &pcfg_pull_none>, + /* mac_txd3 */ + <3 RK_PA1 RK_FUNC_1 &pcfg_pull_none_13ma>, + /* mac_txd2 */ + <3 RK_PA0 RK_FUNC_1 &pcfg_pull_none_13ma>; + }; + + rmii_pins: rmii-pins { + rockchip,pins = + /* mac_mdio */ + <3 RK_PB5 RK_FUNC_1 &pcfg_pull_none>, + /* mac_txen */ + <3 RK_PB4 RK_FUNC_1 &pcfg_pull_none_13ma>, + /* mac_clk */ + <3 RK_PB3 RK_FUNC_1 &pcfg_pull_none>, + /* mac_rxer */ + <3 RK_PB2 RK_FUNC_1 &pcfg_pull_none>, + /* mac_rxdv */ + <3 RK_PB1 RK_FUNC_1 &pcfg_pull_none>, + /* mac_mdc */ + <3 RK_PB0 RK_FUNC_1 &pcfg_pull_none>, + /* mac_rxd1 */ + <3 RK_PA7 RK_FUNC_1 &pcfg_pull_none>, + /* mac_rxd0 */ + <3 RK_PA6 RK_FUNC_1 &pcfg_pull_none>, + /* mac_txd1 */ + <3 RK_PA5 RK_FUNC_1 &pcfg_pull_none_13ma>, + /* mac_txd0 */ + <3 RK_PA4 RK_FUNC_1 &pcfg_pull_none_13ma>; + }; + }; + i2c0 { i2c0_xfer: i2c0-xfer { rockchip,pins = - <1 15 RK_FUNC_2 &pcfg_pull_none>, - <1 16 RK_FUNC_2 &pcfg_pull_none>; + <1 RK_PB7 RK_FUNC_2 &pcfg_pull_none>, + <1 RK_PC0 RK_FUNC_2 &pcfg_pull_none>; }; };
i2c1 { i2c1_xfer: i2c1-xfer { rockchip,pins = - <4 2 RK_FUNC_1 &pcfg_pull_none>, - <4 1 RK_FUNC_1 &pcfg_pull_none>; + <4 RK_PA2 RK_FUNC_1 &pcfg_pull_none>, + <4 RK_PA1 RK_FUNC_1 &pcfg_pull_none>; }; };
i2c2 { i2c2_xfer: i2c2-xfer { rockchip,pins = - <2 1 RK_FUNC_2 &pcfg_pull_none_12ma>, - <2 0 RK_FUNC_2 &pcfg_pull_none_12ma>; + <2 RK_PA1 RK_FUNC_2 &pcfg_pull_none_12ma>, + <2 RK_PA0 RK_FUNC_2 &pcfg_pull_none_12ma>; }; };
i2c3 { i2c3_xfer: i2c3-xfer { rockchip,pins = - <4 17 RK_FUNC_1 &pcfg_pull_none>, - <4 16 RK_FUNC_1 &pcfg_pull_none>; + <4 RK_PC1 RK_FUNC_1 &pcfg_pull_none>, + <4 RK_PC0 RK_FUNC_1 &pcfg_pull_none>; }; };
i2c4 { i2c4_xfer: i2c4-xfer { rockchip,pins = - <1 12 RK_FUNC_1 &pcfg_pull_none>, - <1 11 RK_FUNC_1 &pcfg_pull_none>; + <1 RK_PB4 RK_FUNC_1 &pcfg_pull_none>, + <1 RK_PB3 RK_FUNC_1 &pcfg_pull_none>; }; };
i2c5 { i2c5_xfer: i2c5-xfer { rockchip,pins = - <3 11 RK_FUNC_2 &pcfg_pull_none>, - <3 10 RK_FUNC_2 &pcfg_pull_none>; + <3 RK_PB3 RK_FUNC_2 &pcfg_pull_none>, + <3 RK_PB2 RK_FUNC_2 &pcfg_pull_none>; }; };
i2c6 { i2c6_xfer: i2c6-xfer { rockchip,pins = - <2 10 RK_FUNC_2 &pcfg_pull_none>, - <2 9 RK_FUNC_2 &pcfg_pull_none>; + <2 RK_PB2 RK_FUNC_2 &pcfg_pull_none>, + <2 RK_PB1 RK_FUNC_2 &pcfg_pull_none>; }; };
i2c7 { i2c7_xfer: i2c7-xfer { rockchip,pins = - <2 8 RK_FUNC_2 &pcfg_pull_none>, - <2 7 RK_FUNC_2 &pcfg_pull_none>; + <2 RK_PB0 RK_FUNC_2 &pcfg_pull_none>, + <2 RK_PA7 RK_FUNC_2 &pcfg_pull_none>; }; };
i2c8 { i2c8_xfer: i2c8-xfer { rockchip,pins = - <1 21 RK_FUNC_1 &pcfg_pull_none>, - <1 20 RK_FUNC_1 &pcfg_pull_none>; + <1 RK_PC5 RK_FUNC_1 &pcfg_pull_none>, + <1 RK_PC4 RK_FUNC_1 &pcfg_pull_none>; }; };
i2s0 { i2s0_8ch_bus: i2s0-8ch-bus { rockchip,pins = - <3 24 RK_FUNC_1 &pcfg_pull_none>, - <3 25 RK_FUNC_1 &pcfg_pull_none>, - <3 26 RK_FUNC_1 &pcfg_pull_none>, - <3 27 RK_FUNC_1 &pcfg_pull_none>, - <3 28 RK_FUNC_1 &pcfg_pull_none>, - <3 29 RK_FUNC_1 &pcfg_pull_none>, - <3 30 RK_FUNC_1 &pcfg_pull_none>, - <3 31 RK_FUNC_1 &pcfg_pull_none>, - <4 0 RK_FUNC_1 &pcfg_pull_none>; + <3 RK_PD0 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PD1 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PD2 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PD3 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PD4 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PD5 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PD6 RK_FUNC_1 &pcfg_pull_none>, + <3 RK_PD7 RK_FUNC_1 &pcfg_pull_none>, + <4 RK_PA0 RK_FUNC_1 &pcfg_pull_none>; }; };
i2s1 { i2s1_2ch_bus: i2s1-2ch-bus { rockchip,pins = - <4 3 RK_FUNC_1 &pcfg_pull_none>, - <4 4 RK_FUNC_1 &pcfg_pull_none>, - <4 5 RK_FUNC_1 &pcfg_pull_none>, - <4 6 RK_FUNC_1 &pcfg_pull_none>, - <4 7 RK_FUNC_1 &pcfg_pull_none>; + <4 RK_PA3 RK_FUNC_1 &pcfg_pull_none>, + <4 RK_PA4 RK_FUNC_1 &pcfg_pull_none>, + <4 RK_PA5 RK_FUNC_1 &pcfg_pull_none>, + <4 RK_PA6 RK_FUNC_1 &pcfg_pull_none>, + <4 RK_PA7 RK_FUNC_1 &pcfg_pull_none>; }; };
- gmac { - rgmii_pins: rgmii-pins { + sdio0 { + sdio0_bus1: sdio0-bus1 { rockchip,pins = - /* mac_txclk */ - <3 17 RK_FUNC_1 &pcfg_pull_none_13ma>, - /* mac_rxclk */ - <3 14 RK_FUNC_1 &pcfg_pull_none>, - /* mac_mdio */ - <3 13 RK_FUNC_1 &pcfg_pull_none>, - /* mac_txen */ - <3 12 RK_FUNC_1 &pcfg_pull_none_13ma>, - /* mac_clk */ - <3 11 RK_FUNC_1 &pcfg_pull_none>, - /* mac_rxdv */ - <3 9 RK_FUNC_1 &pcfg_pull_none>, - /* mac_mdc */ - <3 8 RK_FUNC_1 &pcfg_pull_none>, - /* mac_rxd1 */ - <3 7 RK_FUNC_1 &pcfg_pull_none>, - /* mac_rxd0 */ - <3 6 RK_FUNC_1 &pcfg_pull_none>, - /* mac_txd1 */ - <3 5 RK_FUNC_1 &pcfg_pull_none_13ma>, - /* mac_txd0 */ - <3 4 RK_FUNC_1 &pcfg_pull_none_13ma>, - /* mac_rxd3 */ - <3 3 RK_FUNC_1 &pcfg_pull_none>, - /* mac_rxd2 */ - <3 2 RK_FUNC_1 &pcfg_pull_none>, - /* mac_txd3 */ - <3 1 RK_FUNC_1 &pcfg_pull_none_13ma>, - /* mac_txd2 */ - <3 0 RK_FUNC_1 &pcfg_pull_none_13ma>; + <2 RK_PC4 RK_FUNC_1 &pcfg_pull_up>; + }; + + sdio0_bus4: sdio0-bus4 { + rockchip,pins = + <2 RK_PC4 RK_FUNC_1 &pcfg_pull_up>, + <2 RK_PC5 RK_FUNC_1 &pcfg_pull_up>, + <2 RK_PC6 RK_FUNC_1 &pcfg_pull_up>, + <2 RK_PC7 RK_FUNC_1 &pcfg_pull_up>; + }; + + sdio0_cmd: sdio0-cmd { + rockchip,pins = + <2 RK_PD0 RK_FUNC_1 &pcfg_pull_up>; + }; + + sdio0_clk: sdio0-clk { + rockchip,pins = + <2 RK_PD1 RK_FUNC_1 &pcfg_pull_none>; + }; + + sdio0_cd: sdio0-cd { + rockchip,pins = + <2 RK_PD2 RK_FUNC_1 &pcfg_pull_up>; + }; + + sdio0_pwr: sdio0-pwr { + rockchip,pins = + <2 RK_PD3 RK_FUNC_1 &pcfg_pull_up>; + }; + + sdio0_bkpwr: sdio0-bkpwr { + rockchip,pins = + <2 RK_PD4 RK_FUNC_1 &pcfg_pull_up>; + }; + + sdio0_wp: sdio0-wp { + rockchip,pins = + <0 RK_PA3 RK_FUNC_1 &pcfg_pull_up>; + }; + + sdio0_int: sdio0-int { + rockchip,pins = + <0 RK_PA4 RK_FUNC_1 &pcfg_pull_up>; }; };
sdmmc { sdmmc_bus1: sdmmc-bus1 { rockchip,pins = - <4 8 RK_FUNC_1 &pcfg_pull_up>; + <4 RK_PB0 RK_FUNC_1 &pcfg_pull_up>; };
sdmmc_bus4: sdmmc-bus4 { rockchip,pins = - <4 8 RK_FUNC_1 &pcfg_pull_up>, - <4 9 RK_FUNC_1 &pcfg_pull_up>, - <4 10 RK_FUNC_1 &pcfg_pull_up>, - <4 11 RK_FUNC_1 &pcfg_pull_up>; + <4 RK_PB0 RK_FUNC_1 &pcfg_pull_up>, + <4 RK_PB1 RK_FUNC_1 &pcfg_pull_up>, + <4 RK_PB2 RK_FUNC_1 &pcfg_pull_up>, + <4 RK_PB3 RK_FUNC_1 &pcfg_pull_up>; };
sdmmc_clk: sdmmc-clk { rockchip,pins = - <4 12 RK_FUNC_1 &pcfg_pull_none>; + <4 RK_PB4 RK_FUNC_1 &pcfg_pull_none>; };
sdmmc_cmd: sdmmc-cmd { rockchip,pins = - <4 13 RK_FUNC_1 &pcfg_pull_up>; + <4 RK_PB5 RK_FUNC_1 &pcfg_pull_up>; };
sdmmc_cd: sdmcc-cd { rockchip,pins = - <0 7 RK_FUNC_1 &pcfg_pull_up>; + <0 RK_PA7 RK_FUNC_1 &pcfg_pull_up>; };
sdmmc_wp: sdmmc-wp { rockchip,pins = - <0 8 RK_FUNC_1 &pcfg_pull_up>; + <0 RK_PB0 RK_FUNC_1 &pcfg_pull_up>; + }; + }; + + sleep { + ap_pwroff: ap-pwroff { + rockchip,pins = <1 RK_PA5 RK_FUNC_1 &pcfg_pull_none>; + }; + + ddrio_pwroff: ddrio-pwroff { + rockchip,pins = <0 RK_PA1 RK_FUNC_1 &pcfg_pull_none>; }; };
spdif { spdif_bus: spdif-bus { rockchip,pins = - <4 21 RK_FUNC_1 &pcfg_pull_none>; + <4 RK_PC5 RK_FUNC_1 &pcfg_pull_none>; + }; + + spdif_bus_1: spdif-bus-1 { + rockchip,pins = + <3 RK_PC0 RK_FUNC_3 &pcfg_pull_none>; }; };
spi0 { spi0_clk: spi0-clk { rockchip,pins = - <3 6 RK_FUNC_2 &pcfg_pull_up>; + <3 RK_PA6 RK_FUNC_2 &pcfg_pull_up>; }; spi0_cs0: spi0-cs0 { rockchip,pins = - <3 7 RK_FUNC_2 &pcfg_pull_up>; + <3 RK_PA7 RK_FUNC_2 &pcfg_pull_up>; }; spi0_cs1: spi0-cs1 { rockchip,pins = - <3 8 RK_FUNC_2 &pcfg_pull_up>; + <3 RK_PB0 RK_FUNC_2 &pcfg_pull_up>; }; spi0_tx: spi0-tx { rockchip,pins = - <3 5 RK_FUNC_2 &pcfg_pull_up>; + <3 RK_PA5 RK_FUNC_2 &pcfg_pull_up>; }; spi0_rx: spi0-rx { rockchip,pins = - <3 4 RK_FUNC_2 &pcfg_pull_up>; + <3 RK_PA4 RK_FUNC_2 &pcfg_pull_up>; }; };
spi1 { spi1_clk: spi1-clk { rockchip,pins = - <1 9 RK_FUNC_2 &pcfg_pull_up>; + <1 RK_PB1 RK_FUNC_2 &pcfg_pull_up>; }; spi1_cs0: spi1-cs0 { rockchip,pins = - <1 10 RK_FUNC_2 &pcfg_pull_up>; + <1 RK_PB2 RK_FUNC_2 &pcfg_pull_up>; }; spi1_rx: spi1-rx { rockchip,pins = - <1 7 RK_FUNC_2 &pcfg_pull_up>; + <1 RK_PA7 RK_FUNC_2 &pcfg_pull_up>; }; spi1_tx: spi1-tx { rockchip,pins = - <1 8 RK_FUNC_2 &pcfg_pull_up>; + <1 RK_PB0 RK_FUNC_2 &pcfg_pull_up>; }; };
spi2 { spi2_clk: spi2-clk { rockchip,pins = - <2 11 RK_FUNC_1 &pcfg_pull_up>; + <2 RK_PB3 RK_FUNC_1 &pcfg_pull_up>; }; spi2_cs0: spi2-cs0 { rockchip,pins = - <2 12 RK_FUNC_1 &pcfg_pull_up>; + <2 RK_PB4 RK_FUNC_1 &pcfg_pull_up>; }; spi2_rx: spi2-rx { rockchip,pins = - <2 9 RK_FUNC_1 &pcfg_pull_up>; + <2 RK_PB1 RK_FUNC_1 &pcfg_pull_up>; }; spi2_tx: spi2-tx { rockchip,pins = - <2 10 RK_FUNC_1 &pcfg_pull_up>; + <2 RK_PB2 RK_FUNC_1 &pcfg_pull_up>; }; };
spi3 { spi3_clk: spi3-clk { rockchip,pins = - <1 17 RK_FUNC_1 &pcfg_pull_up>; + <1 RK_PC1 RK_FUNC_1 &pcfg_pull_up>; }; spi3_cs0: spi3-cs0 { rockchip,pins = - <1 18 RK_FUNC_1 &pcfg_pull_up>; + <1 RK_PC2 RK_FUNC_1 &pcfg_pull_up>; }; spi3_rx: spi3-rx { rockchip,pins = - <1 15 RK_FUNC_1 &pcfg_pull_up>; + <1 RK_PB7 RK_FUNC_1 &pcfg_pull_up>; }; spi3_tx: spi3-tx { rockchip,pins = - <1 16 RK_FUNC_1 &pcfg_pull_up>; + <1 RK_PC0 RK_FUNC_1 &pcfg_pull_up>; }; };
spi4 { spi4_clk: spi4-clk { rockchip,pins = - <3 2 RK_FUNC_2 &pcfg_pull_up>; + <3 RK_PA2 RK_FUNC_2 &pcfg_pull_up>; }; spi4_cs0: spi4-cs0 { rockchip,pins = - <3 3 RK_FUNC_2 &pcfg_pull_up>; + <3 RK_PA3 RK_FUNC_2 &pcfg_pull_up>; }; spi4_rx: spi4-rx { rockchip,pins = - <3 0 RK_FUNC_2 &pcfg_pull_up>; + <3 RK_PA0 RK_FUNC_2 &pcfg_pull_up>; }; spi4_tx: spi4-tx { rockchip,pins = - <3 1 RK_FUNC_2 &pcfg_pull_up>; + <3 RK_PA1 RK_FUNC_2 &pcfg_pull_up>; }; };
spi5 { spi5_clk: spi5-clk { rockchip,pins = - <2 22 RK_FUNC_2 &pcfg_pull_up>; + <2 RK_PC6 RK_FUNC_2 &pcfg_pull_up>; }; spi5_cs0: spi5-cs0 { rockchip,pins = - <2 23 RK_FUNC_2 &pcfg_pull_up>; + <2 RK_PC7 RK_FUNC_2 &pcfg_pull_up>; }; spi5_rx: spi5-rx { rockchip,pins = - <2 20 RK_FUNC_2 &pcfg_pull_up>; + <2 RK_PC4 RK_FUNC_2 &pcfg_pull_up>; }; spi5_tx: spi5-tx { rockchip,pins = - <2 21 RK_FUNC_2 &pcfg_pull_up>; + <2 RK_PC5 RK_FUNC_2 &pcfg_pull_up>; + }; + }; + + tsadc { + otp_gpio: otp-gpio { + rockchip,pins = <1 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + otp_out: otp-out { + rockchip,pins = <1 RK_PA6 RK_FUNC_1 &pcfg_pull_none>; }; };
uart0 { uart0_xfer: uart0-xfer { rockchip,pins = - <2 16 RK_FUNC_1 &pcfg_pull_up>, - <2 17 RK_FUNC_1 &pcfg_pull_none>; + <2 RK_PC0 RK_FUNC_1 &pcfg_pull_up>, + <2 RK_PC1 RK_FUNC_1 &pcfg_pull_none>; };
uart0_cts: uart0-cts { rockchip,pins = - <2 18 RK_FUNC_1 &pcfg_pull_none>; + <2 RK_PC2 RK_FUNC_1 &pcfg_pull_none>; };
uart0_rts: uart0-rts { rockchip,pins = - <2 19 RK_FUNC_1 &pcfg_pull_none>; + <2 RK_PC3 RK_FUNC_1 &pcfg_pull_none>; }; };
uart1 { uart1_xfer: uart1-xfer { rockchip,pins = - <3 12 RK_FUNC_2 &pcfg_pull_up>, - <3 13 RK_FUNC_2 &pcfg_pull_none>; + <3 RK_PB4 RK_FUNC_2 &pcfg_pull_up>, + <3 RK_PB5 RK_FUNC_2 &pcfg_pull_none>; }; };
uart2a { uart2a_xfer: uart2a-xfer { rockchip,pins = - <4 8 RK_FUNC_2 &pcfg_pull_up>, - <4 9 RK_FUNC_2 &pcfg_pull_none>; + <4 RK_PB0 RK_FUNC_2 &pcfg_pull_up>, + <4 RK_PB1 RK_FUNC_2 &pcfg_pull_none>; }; };
uart2b { uart2b_xfer: uart2b-xfer { rockchip,pins = - <4 16 RK_FUNC_2 &pcfg_pull_up>, - <4 17 RK_FUNC_2 &pcfg_pull_none>; + <4 RK_PC0 RK_FUNC_2 &pcfg_pull_up>, + <4 RK_PC1 RK_FUNC_2 &pcfg_pull_none>; }; };
uart2c { uart2c_xfer: uart2c-xfer { rockchip,pins = - <4 19 RK_FUNC_1 &pcfg_pull_up>, - <4 20 RK_FUNC_1 &pcfg_pull_none>; + <4 RK_PC3 RK_FUNC_1 &pcfg_pull_up>, + <4 RK_PC4 RK_FUNC_1 &pcfg_pull_none>; }; };
uart3 { uart3_xfer: uart3-xfer { rockchip,pins = - <3 14 RK_FUNC_2 &pcfg_pull_up>, - <3 15 RK_FUNC_2 &pcfg_pull_none>; + <3 RK_PB6 RK_FUNC_2 &pcfg_pull_up>, + <3 RK_PB7 RK_FUNC_2 &pcfg_pull_none>; };
uart3_cts: uart3-cts { rockchip,pins = - <3 18 RK_FUNC_2 &pcfg_pull_none>; + <3 RK_PC2 RK_FUNC_2 &pcfg_pull_none>; };
uart3_rts: uart3-rts { rockchip,pins = - <3 19 RK_FUNC_2 &pcfg_pull_none>; + <3 RK_PC3 RK_FUNC_2 &pcfg_pull_none>; }; };
uart4 { uart4_xfer: uart4-xfer { rockchip,pins = - <1 7 RK_FUNC_1 &pcfg_pull_up>, - <1 8 RK_FUNC_1 &pcfg_pull_none>; + <1 RK_PA7 RK_FUNC_1 &pcfg_pull_up>, + <1 RK_PB0 RK_FUNC_1 &pcfg_pull_none>; }; };
uarthdcp { uarthdcp_xfer: uarthdcp-xfer { rockchip,pins = - <4 21 RK_FUNC_2 &pcfg_pull_up>, - <4 22 RK_FUNC_2 &pcfg_pull_none>; + <4 RK_PC5 RK_FUNC_2 &pcfg_pull_up>, + <4 RK_PC6 RK_FUNC_2 &pcfg_pull_none>; }; };
pwm0 { pwm0_pin: pwm0-pin { rockchip,pins = - <4 18 RK_FUNC_1 &pcfg_pull_none>; + <4 RK_PC2 RK_FUNC_1 &pcfg_pull_none>; };
vop0_pwm_pin: vop0-pwm-pin { rockchip,pins = - <4 18 RK_FUNC_2 &pcfg_pull_none>; + <4 RK_PC2 RK_FUNC_2 &pcfg_pull_none>; }; };
pwm1 { pwm1_pin: pwm1-pin { rockchip,pins = - <4 22 RK_FUNC_1 &pcfg_pull_none>; + <4 RK_PC6 RK_FUNC_1 &pcfg_pull_none>; };
vop1_pwm_pin: vop1-pwm-pin { rockchip,pins = - <4 18 RK_FUNC_3 &pcfg_pull_none>; + <4 RK_PC2 RK_FUNC_3 &pcfg_pull_none>; }; };
pwm2 { pwm2_pin: pwm2-pin { rockchip,pins = - <1 19 RK_FUNC_1 &pcfg_pull_none>; + <1 RK_PC3 RK_FUNC_1 &pcfg_pull_none>; }; };
pwm3a { pwm3a_pin: pwm3a-pin { rockchip,pins = - <0 6 RK_FUNC_1 &pcfg_pull_none>; + <0 RK_PA6 RK_FUNC_1 &pcfg_pull_none>; }; };
pwm3b { pwm3b_pin: pwm3b-pin { rockchip,pins = - <1 14 RK_FUNC_1 &pcfg_pull_none>; + <1 RK_PB6 RK_FUNC_1 &pcfg_pull_none>; }; }; + + hdmi { + hdmi_i2c_xfer: hdmi-i2c-xfer { + rockchip,pins = + <4 RK_PC1 RK_FUNC_3 &pcfg_pull_none>, + <4 RK_PC0 RK_FUNC_3 &pcfg_pull_none>; + }; + + hdmi_cec: hdmi-cec { + rockchip,pins = + <4 RK_PC7 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + pcie { + pcie_clkreqn: pci-clkreqn { + rockchip,pins = + <2 RK_PD2 RK_FUNC_2 &pcfg_pull_none>; + }; + + pcie_clkreqnb: pci-clkreqnb { + rockchip,pins = + <4 RK_PD0 RK_FUNC_1 &pcfg_pull_none>; + }; + + pcie_clkreqn_cpm: pci-clkreqn-cpm { + rockchip,pins = + <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + pcie_clkreqnb_cpm: pci-clkreqnb-cpm { + rockchip,pins = + <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + }; }; diff --git a/include/dt-bindings/pinctrl/rockchip.h b/include/dt-bindings/pinctrl/rockchip.h index ecb76c7..0798287 100644 --- a/include/dt-bindings/pinctrl/rockchip.h +++ b/include/dt-bindings/pinctrl/rockchip.h @@ -4,7 +4,7 @@ * Copyright (c) 2013 MundoReader S.L. * Author: Heiko Stuebner heiko@sntech.de * - * SPDX-License-Identifier: GPL-2.0+ + * SPDX-License-Identifier: GPL-2.0+ */
#ifndef __DT_BINDINGS_ROCKCHIP_PINCTRL_H__ @@ -17,6 +17,39 @@ #define RK_GPIO4 4 #define RK_GPIO6 6
+#define RK_PA0 0 +#define RK_PA1 1 +#define RK_PA2 2 +#define RK_PA3 3 +#define RK_PA4 4 +#define RK_PA5 5 +#define RK_PA6 6 +#define RK_PA7 7 +#define RK_PB0 8 +#define RK_PB1 9 +#define RK_PB2 10 +#define RK_PB3 11 +#define RK_PB4 12 +#define RK_PB5 13 +#define RK_PB6 14 +#define RK_PB7 15 +#define RK_PC0 16 +#define RK_PC1 17 +#define RK_PC2 18 +#define RK_PC3 19 +#define RK_PC4 20 +#define RK_PC5 21 +#define RK_PC6 22 +#define RK_PC7 23 +#define RK_PD0 24 +#define RK_PD1 25 +#define RK_PD2 26 +#define RK_PD3 27 +#define RK_PD4 28 +#define RK_PD5 29 +#define RK_PD6 30 +#define RK_PD7 31 + #define RK_FUNC_GPIO 0 #define RK_FUNC_1 1 #define RK_FUNC_2 2 diff --git a/include/dt-bindings/power/rk3399-power.h b/include/dt-bindings/power/rk3399-power.h new file mode 100644 index 0000000..168b3bf --- /dev/null +++ b/include/dt-bindings/power/rk3399-power.h @@ -0,0 +1,53 @@ +#ifndef __DT_BINDINGS_POWER_RK3399_POWER_H__ +#define __DT_BINDINGS_POWER_RK3399_POWER_H__ + +/* VD_CORE_L */ +#define RK3399_PD_A53_L0 0 +#define RK3399_PD_A53_L1 1 +#define RK3399_PD_A53_L2 2 +#define RK3399_PD_A53_L3 3 +#define RK3399_PD_SCU_L 4 + +/* VD_CORE_B */ +#define RK3399_PD_A72_B0 5 +#define RK3399_PD_A72_B1 6 +#define RK3399_PD_SCU_B 7 + +/* VD_LOGIC */ +#define RK3399_PD_TCPD0 8 +#define RK3399_PD_TCPD1 9 +#define RK3399_PD_CCI 10 +#define RK3399_PD_CCI0 11 +#define RK3399_PD_CCI1 12 +#define RK3399_PD_PERILP 13 +#define RK3399_PD_PERIHP 14 +#define RK3399_PD_VIO 15 +#define RK3399_PD_VO 16 +#define RK3399_PD_VOPB 17 +#define RK3399_PD_VOPL 18 +#define RK3399_PD_ISP0 19 +#define RK3399_PD_ISP1 20 +#define RK3399_PD_HDCP 21 +#define RK3399_PD_GMAC 22 +#define RK3399_PD_EMMC 23 +#define RK3399_PD_USB3 24 +#define RK3399_PD_EDP 25 +#define RK3399_PD_GIC 26 +#define RK3399_PD_SD 27 +#define RK3399_PD_SDIOAUDIO 28 +#define RK3399_PD_ALIVE 29 + +/* VD_CENTER */ +#define RK3399_PD_CENTER 30 +#define RK3399_PD_VCODEC 31 +#define RK3399_PD_VDU 32 +#define RK3399_PD_RGA 33 +#define RK3399_PD_IEP 34 + +/* VD_GPU */ +#define RK3399_PD_GPU 35 + +/* VD_PMU */ +#define RK3399_PD_PMU 36 + +#endif
Firefly-rk3399 is a bord from T-Firefly, you can find detail about it here: http://en.t-firefly.com/en/firenow/Firefly_RK3399/
This patch add basic node for the board and make it able to bring up.
Peripheral/interfaces on board: - usb hub which connect to ehci controller; - UART2 debug - eMMC - PCIe - USB 3.0 HOST, type-C port - sdio, sd-card - HDMI - Ethernet - OPTICAL - WiFi/BT - MIPI CSI/DSI - IR - EDP/DP
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
Changes in v2: - dts properity order update
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-firefly.dts | 660 ++++++++++++++++++++++++++++++++++++++++ 2 files changed, 661 insertions(+) create mode 100644 arch/arm/dts/rk3399-firefly.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 7378c88..2dfe85f 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -42,6 +42,7 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3288-veyron-minnie.dtb \ rk3328-evb.dtb \ rk3399-evb.dtb \ + rk3399-firefly.dtb \ rk3399-puma.dtb dtb-$(CONFIG_ARCH_MESON) += \ meson-gxbb-odroidc2.dtb diff --git a/arch/arm/dts/rk3399-firefly.dts b/arch/arm/dts/rk3399-firefly.dts new file mode 100644 index 0000000..edf48fb --- /dev/null +++ b/arch/arm/dts/rk3399-firefly.dts @@ -0,0 +1,660 @@ +/* + * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +#include <dt-bindings/pwm/pwm.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include "rk3399.dtsi" +#include "rk3399-sdram-ddr3-1333.dtsi" + +/ { + model = "Firefly-RK3399 Board"; + compatible = "firefly,firefly-rk3399", "rockchip,rk3399"; + + chosen { + stdout-path = &uart2; + }; + + backlight: backlight { + compatible = "pwm-backlight"; + enable-gpios = <&gpio1 RK_PB5 GPIO_ACTIVE_HIGH>; + pwms = <&pwm0 0 25000 0>; + brightness-levels = < + 0 1 2 3 4 5 6 7 + 8 9 10 11 12 13 14 15 + 16 17 18 19 20 21 22 23 + 24 25 26 27 28 29 30 31 + 32 33 34 35 36 37 38 39 + 40 41 42 43 44 45 46 47 + 48 49 50 51 52 53 54 55 + 56 57 58 59 60 61 62 63 + 64 65 66 67 68 69 70 71 + 72 73 74 75 76 77 78 79 + 80 81 82 83 84 85 86 87 + 88 89 90 91 92 93 94 95 + 96 97 98 99 100 101 102 103 + 104 105 106 107 108 109 110 111 + 112 113 114 115 116 117 118 119 + 120 121 122 123 124 125 126 127 + 128 129 130 131 132 133 134 135 + 136 137 138 139 140 141 142 143 + 144 145 146 147 148 149 150 151 + 152 153 154 155 156 157 158 159 + 160 161 162 163 164 165 166 167 + 168 169 170 171 172 173 174 175 + 176 177 178 179 180 181 182 183 + 184 185 186 187 188 189 190 191 + 192 193 194 195 196 197 198 199 + 200 201 202 203 204 205 206 207 + 208 209 210 211 212 213 214 215 + 216 217 218 219 220 221 222 223 + 224 225 226 227 228 229 230 231 + 232 233 234 235 236 237 238 239 + 240 241 242 243 244 245 246 247 + 248 249 250 251 252 253 254 255>; + default-brightness-level = <200>; + }; + + clkin_gmac: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "clkin_gmac"; + #clock-cells = <0>; + }; + + rt5640-sound { + compatible = "simple-audio-card"; + simple-audio-card,name = "rockchip,rt5640-codec"; + simple-audio-card,format = "i2s"; + simple-audio-card,mclk-fs = <256>; + simple-audio-card,widgets = + "Microphone", "Mic Jack", + "Headphone", "Headphone Jack"; + simple-audio-card,routing = + "Mic Jack", "MICBIAS1", + "IN1P", "Mic Jack", + "Headphone Jack", "HPOL", + "Headphone Jack", "HPOR"; + + simple-audio-card,cpu { + sound-dai = <&i2s1>; + }; + + simple-audio-card,codec { + sound-dai = <&rt5640>; + }; + }; + + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rk808 1>; + clock-names = "ext_clock"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_enable_h>; + + /* + * On the module itself this is one of these (depending + * on the actual card populated): + * - SDIO_RESET_L_WL_REG_ON + * - PDN (power down when low) + */ + reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; + }; + + vcc3v3_pcie: vcc3v3-pcie-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio1 RK_PC1 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_drv>; + regulator-name = "vcc3v3_pcie"; + regulator-always-on; + regulator-boot-on; + }; + + vcc3v3_sys: vcc3v3-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + vcc5v0_host: vcc5v0-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&host_vbus_drv>; + regulator-name = "vcc5v0_host"; + regulator-always-on; + }; + + vcc5v0_sys: vcc5v0-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vcc_phy: vcc-phy-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_phy"; + regulator-always-on; + regulator-boot-on; + }; + + vdd_log: vdd-log { + compatible = "pwm-regulator"; + pwms = <&pwm2 0 25000 1>; + regulator-name = "vdd_log"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + }; + + vccadc_ref: vccadc-ref { + compatible = "regulator-fixed"; + regulator-name = "vcc1v8_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_b>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_b>; +}; + +&emmc_phy { + status = "okay"; +}; + +&gmac { + assigned-clocks = <&cru SCLK_RMII_SRC>; + assigned-clock-parents = <&clkin_gmac>; + clock_in_out = "input"; + phy-supply = <&vcc_phy>; + phy-mode = "rgmii"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; + tx_delay = <0x28>; + rx_delay = <0x11>; + status = "okay"; +}; + +&i2c0 { + clock-frequency = <400000>; + i2c-scl-rising-time-ns = <168>; + i2c-scl-falling-time-ns = <4>; + status = "okay"; + + rk808: pmic@1b { + compatible = "rockchip,rk808"; + reg = <0x1b>; + interrupt-parent = <&gpio1>; + interrupts = <21 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk808-clkout2"; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + + vcc1-supply = <&vcc3v3_sys>; + vcc2-supply = <&vcc3v3_sys>; + vcc3-supply = <&vcc3v3_sys>; + vcc4-supply = <&vcc3v3_sys>; + vcc6-supply = <&vcc3v3_sys>; + vcc7-supply = <&vcc3v3_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc3v3_sys>; + vcc10-supply = <&vcc3v3_sys>; + vcc11-supply = <&vcc3v3_sys>; + vcc12-supply = <&vcc3v3_sys>; + vddio-supply = <&vcc1v8_pmu>; + + regulators { + vdd_center: DCDC_REG1 { + regulator-name = "vdd_center"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_l: DCDC_REG2 { + regulator-name = "vdd_cpu_l"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG4 { + regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc1v8_dvp: LDO_REG1 { + regulator-name = "vcc1v8_dvp"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v0_tp: LDO_REG2 { + regulator-name = "vcc3v0_tp"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc1v8_pmu: LDO_REG3 { + regulator-name = "vcc1v8_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_sd: LDO_REG4 { + regulator-name = "vcc_sd"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcca3v0_codec: LDO_REG5 { + regulator-name = "vcca3v0_codec"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v5: LDO_REG6 { + regulator-name = "vcc_1v5"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1500000>; + }; + }; + + vcca1v8_codec: LDO_REG7 { + regulator-name = "vcca1v8_codec"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v0: LDO_REG8 { + regulator-name = "vcc_3v0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcc3v3_s3: SWITCH_REG1 { + regulator-name = "vcc3v3_s3"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_s0: SWITCH_REG2 { + regulator-name = "vcc3v3_s0"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; + + vdd_cpu_b: regulator@40 { + compatible = "silergy,syr827"; + reg = <0x40>; + fcs,suspend-voltage-selector = <0>; + regulator-name = "vdd_cpu_b"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: regulator@41 { + compatible = "silergy,syr828"; + reg = <0x41>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_gpu"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c1 { + i2c-scl-rising-time-ns = <300>; + i2c-scl-falling-time-ns = <15>; + status = "okay"; + + rt5640: rt5640@1c { + compatible = "realtek,rt5640"; + reg = <0x1c>; + clocks = <&cru SCLK_I2S_8CH_OUT>; + clock-names = "mclk"; + realtek,in1-differential; + #sound-dai-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&rt5640_hpcon>; + }; +}; + +&i2c3 { + i2c-scl-rising-time-ns = <450>; + i2c-scl-falling-time-ns = <15>; + status = "okay"; +}; + +&i2c4 { + i2c-scl-rising-time-ns = <600>; + i2c-scl-falling-time-ns = <20>; + status = "okay"; + + accelerometer@68 { + compatible = "invensense,mpu6500"; + reg = <0x68>; + interrupt-parent = <&gpio1>; + interrupts = <RK_PC6 IRQ_TYPE_EDGE_RISING>; + }; +}; + +&i2s0 { + rockchip,playback-channels = <8>; + rockchip,capture-channels = <8>; + #sound-dai-cells = <0>; + status = "okay"; +}; + +&i2s1 { + rockchip,playback-channels = <2>; + rockchip,capture-channels = <2>; + #sound-dai-cells = <0>; + status = "okay"; +}; + +&i2s2 { + #sound-dai-cells = <0>; + status = "okay"; +}; + +&io_domains { + status = "okay"; + + bt656-supply = <&vcc1v8_dvp>; + audio-supply = <&vcca1v8_codec>; + sdmmc-supply = <&vcc_sd>; + gpio1830-supply = <&vcc_3v0>; +}; + +&pcie_phy { + status = "okay"; +}; + +&pcie0 { + ep-gpios = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>; + num-lanes = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_clkreqn>; + status = "okay"; +}; + +&pmu_io_domains { + pmu1830-supply = <&vcc_3v0>; + status = "okay"; +}; + +&pinctrl { + buttons { + pwrbtn: pwrbtn { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + lcd-panel { + lcd_panel_reset: lcd-panel-reset { + rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + pcie { + pcie_drv: pcie-drv { + rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + pcie_3g_drv: pcie-3g-drv { + rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + pmic { + vsel1_gpio: vsel1-gpio { + rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + vsel2_gpio: vsel2-gpio { + rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; + + sdio-pwrseq { + wifi_enable_h: wifi-enable-h { + rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + rt5640 { + rt5640_hpcon: rt5640-hpcon { + rockchip,pins = <4 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + usb2 { + host_vbus_drv: host-vbus-drv { + rockchip,pins = <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pwm0 { + status = "okay"; +}; + +&pwm2 { + status = "okay"; +}; + +&saradc { + vref-supply = <&vccadc_ref>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + keep-power-in-suspend; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + non-removable; + status = "okay"; +}; + +&tsadc { + /* tshut mode 0:CRU 1:GPIO */ + rockchip,hw-tshut-mode = <1>; + /* tshut polarity 0:LOW 1:HIGH */ + rockchip,hw-tshut-polarity = <1>; + status = "okay"; +}; + +&u2phy0 { + status = "okay"; + + u2phy0_otg: otg-port { + status = "okay"; + }; + + u2phy0_host: host-port { + phy-supply = <&vcc5v0_host>; + status = "okay"; + }; +}; + +&u2phy1 { + status = "okay"; + + u2phy1_otg: otg-port { + status = "okay"; + }; + + u2phy1_host: host-port { + phy-supply = <&vcc5v0_host>; + status = "okay"; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer &uart0_cts>; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +};
- UART2 debug
- eMMC
- PCIe
- sdio, sd-card
- HDMI
- Ethernet
- OPTICAL
- WiFi/BT
- MIPI CSI/DSI
- IR
- EDP/DP
Changes in v2:
property?
Also, what ordering change did you make?
Hi Simon,
- UART2 debug
- eMMC
- PCIe
- sdio, sd-card
- HDMI
- Ethernet
- OPTICAL
- WiFi/BT
- MIPI CSI/DSI
- IR
- EDP/DP
Changes in v2:
property?
Yes, sorry.
The order is make by Heiko by the coding style from kernel, and this version is the one acked and applied by Heiko.
Thanks, - Kever
On 24 April 2017 at 04:34, Kever Yang kever.yang@rock-chips.com wrote:
Hi Simon,
- UART2 debug
- eMMC
- PCIe
- sdio, sd-card
- HDMI
- Ethernet
- OPTICAL
- WiFi/BT
- MIPI CSI/DSI
- IR
- EDP/DP
Changes in v2:
property?
Yes, sorry.
Thanks,
- Kever
Hi Simon,
- UART2 debug
- eMMC
- PCIe
- sdio, sd-card
- HDMI
- Ethernet
- OPTICAL
- WiFi/BT
- MIPI CSI/DSI
- IR
- EDP/DP
Changes in v2:
property?
Yes, sorry.
Thanks,
- Kever
Applied to u-boot-rockchip/next, thanks!
Hi Simon,
Please don't merge this V2 patch, there is a regression on dw-mmc,
a property 'clock-freq-min-max' is missing after sync with kernel driver,
I will send a new version.
Thanks, - Kever On 04/19/2017 06:17 PM, Kever Yang wrote:
The kernel dts has update a lot since the first time we commit rk3399.dtsi, sync with kernel for further development.
Signed-off-by: Kever Yang kever.yang@rock-chips.com Acked-by: Simon Glass sjg@chromium.org
Changes in v2: None
arch/arm/dts/rk3399.dtsi | 1274 +++++++++++++++++++++++++----- include/dt-bindings/pinctrl/rockchip.h | 35 +- include/dt-bindings/power/rk3399-power.h | 53 ++ 3 files changed, 1157 insertions(+), 205 deletions(-) create mode 100644 include/dt-bindings/power/rk3399-power.h
diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi index a51015f..5d37a1e 100644 --- a/arch/arm/dts/rk3399.dtsi +++ b/arch/arm/dts/rk3399.dtsi @@ -1,5 +1,5 @@ /*
- (C) Copyright 2016 Rockchip Electronics Co., Ltd
- Copyright (c) 2016-2017 Fuzhou Rockchip Electronics Co., Ltd.
@@ -9,6 +9,8 @@ #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/pinctrl/rockchip.h> +#include <dt-bindings/power/rk3399-power.h> +#include <dt-bindings/thermal/thermal.h> #define USB_CLASS_HUB 9
/ { @@ -19,6 +21,15 @@ #size-cells = <2>;
aliases {
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
i2c3 = &i2c3;
i2c4 = &i2c4;
i2c5 = &i2c5;
i2c6 = &i2c6;
i2c7 = &i2c7;
serial0 = &uart0; serial1 = &uart1; serial2 = &uart2;i2c8 = &i2c8;
@@ -26,7 +37,6 @@ serial4 = &uart4; mmc0 = &sdhci; mmc1 = &sdmmc;
i2c0 = &i2c0;
cpus {
@@ -110,6 +120,16 @@ }; };
- pmu_a53 {
compatible = "arm,cortex-a53-pmu";
interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_LOW &ppi_cluster0>;
- pmu_a72 {
compatible = "arm,cortex-a72-pmu";
interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_LOW &ppi_cluster1>;
- psci { compatible = "arm,psci-1.0"; method = "smc";
@@ -117,10 +137,11 @@
timer { compatible = "arm,armv8-timer";
interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>,
<GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>,
<GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>,
<GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>;
interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW 0>,
<GIC_PPI 14 IRQ_TYPE_LEVEL_LOW 0>,
<GIC_PPI 11 IRQ_TYPE_LEVEL_LOW 0>,
<GIC_PPI 10 IRQ_TYPE_LEVEL_LOW 0>;
arm,no-tick-in-suspend;
xin24m: xin24m {
@@ -139,8 +160,8 @@ dmac_bus: dma-controller@ff6d0000 { compatible = "arm,pl330", "arm,primecell"; reg = <0x0 0xff6d0000 0x0 0x4000>;
interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>;
interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH 0>; #dma-cells = <1>; clocks = <&cru ACLK_DMAC0_PERILP>; clock-names = "apb_pclk";
@@ -149,24 +170,92 @@ dmac_peri: dma-controller@ff6e0000 { compatible = "arm,pl330", "arm,primecell"; reg = <0x0 0xff6e0000 0x0 0x4000>;
interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>;
interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH 0>; #dma-cells = <1>; clocks = <&cru ACLK_DMAC1_PERILP>; clock-names = "apb_pclk";
pcie0: pcie@f8000000 {
compatible = "rockchip,rk3399-pcie";
reg = <0x0 0xf8000000 0x0 0x2000000>,
<0x0 0xfd000000 0x0 0x1000000>;
reg-names = "axi-base", "apb-base";
#address-cells = <3>;
#size-cells = <2>;
#interrupt-cells = <1>;
aspm-no-l0s;
bus-range = <0x0 0x1>;
clocks = <&cru ACLK_PCIE>, <&cru ACLK_PERF_PCIE>,
<&cru PCLK_PCIE>, <&cru SCLK_PCIE_PM>;
clock-names = "aclk", "aclk-perf",
"hclk", "pm";
interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH 0>;
interrupt-names = "sys", "legacy", "client";
interrupt-map-mask = <0 0 0 7>;
interrupt-map = <0 0 0 1 &pcie0_intc 0>,
<0 0 0 2 &pcie0_intc 1>,
<0 0 0 3 &pcie0_intc 2>,
<0 0 0 4 &pcie0_intc 3>;
linux,pci-domain = <0>;
max-link-speed = <1>;
msi-map = <0x0 &its 0x0 0x1000>;
phys = <&pcie_phy>;
phy-names = "pcie-phy";
ranges = <0x83000000 0x0 0xfa000000 0x0 0xfa000000 0x0 0x600000
0x81000000 0x0 0xfa600000 0x0 0xfa600000 0x0 0x100000>;
resets = <&cru SRST_PCIE_CORE>, <&cru SRST_PCIE_MGMT>,
<&cru SRST_PCIE_MGMT_STICKY>, <&cru SRST_PCIE_PIPE>,
<&cru SRST_PCIE_PM>, <&cru SRST_P_PCIE>,
<&cru SRST_A_PCIE>;
reset-names = "core", "mgmt", "mgmt-sticky", "pipe",
"pm", "pclk", "aclk";
pcie0_intc: interrupt-controller {
interrupt-controller;
#address-cells = <0>;
gmac: ethernet@fe300000 {
<&cru PCLK_GMAC>;
"pclk_mac";
power-domains = <&power RK3399_PD_GMAC>;
sdio0: dwmmc@fe310000 { compatible = "rockchip,rk3399-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x0 0xfe310000 0x0 0x4000>;
interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>;
clock-freq-min-max = <400000 150000000>;
interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru HCLK_SDIO>, <&cru SCLK_SDIO>, <&cru SCLK_SDIO_DRV>, <&cru SCLK_SDIO_SAMPLE>; clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>;max-frequency = <150000000>;
resets = <&cru SRST_SDIO0>;
status = "disabled"; };reset-names = "reset";
@@ -174,14 +263,15 @@ compatible = "rockchip,rk3399-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x0 0xfe320000 0x0 0x4000>;
interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_SDMMC>, <&cru HCLK_SDMMC>,
interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>;
clock-names = "ciu", "biu", "ciu-drive", "ciu-sample";
pinctrl-0 = <&sdmmc_clk>;
fifo-depth = <0x100>;clock-names = "biu", "ciu", "ciu-drive", "ciu-sample";
power-domains = <&power RK3399_PD_SD>;
resets = <&cru SRST_SDMMC>;
@@ -189,50 +279,74 @@ u-boot,dm-pre-reloc; compatible = "rockchip,rk3399-sdhci-5.1", "arasan,sdhci-5.1"; reg = <0x0 0xfe330000 0x0 0x10000>;
interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>;
interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH 0>;
arasan,soc-ctl-syscon = <&grf>;
assigned-clocks = <&cru SCLK_EMMC>; assigned-clock-rates = <200000000>; max-frequency = <200000000>; clocks = <&cru SCLK_EMMC>, <&cru ACLK_EMMC>; clock-names = "clk_xin", "clk_ahb";
clock-output-names = "emmc_cardclock";
#clock-cells = <0>;
phys = <&emmc_phy>; phy-names = "phy_arasan";
power-domains = <&power RK3399_PD_EMMC>;
usb_host0_ehci: usb@fe380000 { compatible = "generic-ehci"; reg = <0x0 0xfe380000 0x0 0x20000>;
interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>;
clock-names = "hclk_host0", "hclk_host0_arb";
interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>,
<&u2phy0>;
clock-names = "usbhost", "arbiter",
"utmi";
phys = <&u2phy0_host>;
phy-names = "usb";
power-domains = <&power RK3399_PD_PERIHP>;
usb_host0_ohci: usb@fe3a0000 { compatible = "generic-ohci"; reg = <0x0 0xfe3a0000 0x0 0x20000>;
interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>;
interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH 0>;
<&u2phy0>;
"utmi";
phy-names = "usb";
usb_host1_ehci: usb@fe3c0000 { compatible = "generic-ehci"; reg = <0x0 0xfe3c0000 0x0 0x20000>;
interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>;
clock-names = "hclk_host1", "hclk_host1_arb";
interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>,
<&u2phy1>;
"utmi";
phys = <&u2phy1_host>;
phy-names = "usb";
usb_host1_ohci: usb@fe3e0000 { compatible = "generic-ohci"; reg = <0x0 0xfe3e0000 0x0 0x20000>;
interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>;
interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH 0>;
<&u2phy1>;
"utmi";
phy-names = "usb";
status = "disabled"; };power-domains = <&power RK3399_PD_PERIHP>;
@@ -280,7 +394,7 @@
gic: interrupt-controller@fee00000 { compatible = "arm,gic-v3";
#interrupt-cells = <3>;
#address-cells = <2>; #size-cells = <2>; ranges;#interrupt-cells = <4>;
@@ -291,12 +405,124 @@ <0x0 0xfff00000 0 0x10000>, /* GICC */ <0x0 0xfff10000 0 0x10000>, /* GICH */ <0x0 0xfff20000 0 0x10000>; /* GICV */
interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>;
interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH 0>;
its: interrupt-controller@fee20000 { compatible = "arm,gic-v3-its"; msi-controller; reg = <0x0 0xfee20000 0x0 0x20000>; };
ppi-partitions {
ppi_cluster0: interrupt-partition-0 {
affinity = <&cpu_l0 &cpu_l1 &cpu_l2 &cpu_l3>;
ppi_cluster1: interrupt-partition-1 {
affinity = <&cpu_b0 &cpu_b1>;
saradc: saradc@ff100000 {
compatible = "rockchip,rk3399-saradc";
reg = <0x0 0xff100000 0x0 0x100>;
interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH 0>;
#io-channel-cells = <1>;
clocks = <&cru SCLK_SARADC>, <&cru PCLK_SARADC>;
clock-names = "saradc", "apb_pclk";
resets = <&cru SRST_P_SARADC>;
reset-names = "saradc-apb";
i2c1: i2c@ff110000 {
reg = <0x0 0xff110000 0x0 0x1000>;
assigned-clocks = <&cru SCLK_I2C1>;
clocks = <&cru SCLK_I2C1>, <&cru PCLK_I2C1>;
interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH 0>;
pinctrl-0 = <&i2c1_xfer>;
#size-cells = <0>;
i2c2: i2c@ff120000 {
reg = <0x0 0xff120000 0x0 0x1000>;
assigned-clocks = <&cru SCLK_I2C2>;
clocks = <&cru SCLK_I2C2>, <&cru PCLK_I2C2>;
interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH 0>;
pinctrl-0 = <&i2c2_xfer>;
#size-cells = <0>;
i2c3: i2c@ff130000 {
reg = <0x0 0xff130000 0x0 0x1000>;
assigned-clocks = <&cru SCLK_I2C3>;
clocks = <&cru SCLK_I2C3>, <&cru PCLK_I2C3>;
interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH 0>;
pinctrl-0 = <&i2c3_xfer>;
#size-cells = <0>;
i2c5: i2c@ff140000 {
reg = <0x0 0xff140000 0x0 0x1000>;
assigned-clocks = <&cru SCLK_I2C5>;
clocks = <&cru SCLK_I2C5>, <&cru PCLK_I2C5>;
interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH 0>;
pinctrl-0 = <&i2c5_xfer>;
#size-cells = <0>;
i2c6: i2c@ff150000 {
reg = <0x0 0xff150000 0x0 0x1000>;
assigned-clocks = <&cru SCLK_I2C6>;
clocks = <&cru SCLK_I2C6>, <&cru PCLK_I2C6>;
interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH 0>;
pinctrl-0 = <&i2c6_xfer>;
#size-cells = <0>;
i2c7: i2c@ff160000 {
reg = <0x0 0xff160000 0x0 0x1000>;
assigned-clocks = <&cru SCLK_I2C7>;
clocks = <&cru SCLK_I2C7>, <&cru PCLK_I2C7>;
interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH 0>;
pinctrl-0 = <&i2c7_xfer>;
#size-cells = <0>;
uart0: serial@ff180000 {
@@ -304,7 +530,7 @@ reg = <0x0 0xff180000 0x0 0x100>; clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; clock-names = "baudclk", "apb_pclk";
interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>;
reg-shift = <2>; reg-io-width = <4>; pinctrl-names = "default";interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH 0>;
@@ -317,7 +543,7 @@ reg = <0x0 0xff190000 0x0 0x100>; clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; clock-names = "baudclk", "apb_pclk";
interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>;
reg-shift = <2>; reg-io-width = <4>; pinctrl-names = "default";interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH 0>;
@@ -330,7 +556,7 @@ reg = <0x0 0xff1a0000 0x0 0x100>; clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; clock-names = "baudclk", "apb_pclk";
interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>;
clock-frequency = <24000000>; reg-shift = <2>; reg-io-width = <4>;interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH 0>;
@@ -344,7 +570,7 @@ reg = <0x0 0xff1b0000 0x0 0x100>; clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; clock-names = "baudclk", "apb_pclk";
interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>;
reg-shift = <2>; reg-io-width = <4>; pinctrl-names = "default";interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH 0>;
@@ -357,7 +583,7 @@ reg = <0x0 0xff1c0000 0x0 0x1000>; clocks = <&cru SCLK_SPI0>, <&cru PCLK_SPI0>; clock-names = "spiclk", "apb_pclk";
interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>;
pinctrl-names = "default"; pinctrl-0 = <&spi0_clk &spi0_tx &spi0_rx &spi0_cs0>; #address-cells = <1>;interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH 0>;
@@ -370,7 +596,7 @@ reg = <0x0 0xff1d0000 0x0 0x1000>; clocks = <&cru SCLK_SPI1>, <&cru PCLK_SPI1>; clock-names = "spiclk", "apb_pclk";
interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>;
pinctrl-names = "default"; pinctrl-0 = <&spi1_clk &spi1_tx &spi1_rx &spi1_cs0>; #address-cells = <1>;interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH 0>;
@@ -383,7 +609,7 @@ reg = <0x0 0xff1e0000 0x0 0x1000>; clocks = <&cru SCLK_SPI2>, <&cru PCLK_SPI2>; clock-names = "spiclk", "apb_pclk";
interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>;
pinctrl-names = "default"; pinctrl-0 = <&spi2_clk &spi2_tx &spi2_rx &spi2_cs0>; #address-cells = <1>;interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH 0>;
@@ -396,7 +622,7 @@ reg = <0x0 0xff1f0000 0x0 0x1000>; clocks = <&cru SCLK_SPI4>, <&cru PCLK_SPI4>; clock-names = "spiclk", "apb_pclk";
interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>;
pinctrl-names = "default"; pinctrl-0 = <&spi4_clk &spi4_tx &spi4_rx &spi4_cs0>; #address-cells = <1>;interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH 0>;
@@ -409,7 +635,7 @@ reg = <0x0 0xff200000 0x0 0x1000>; clocks = <&cru SCLK_SPI5>, <&cru PCLK_SPI5>; clock-names = "spiclk", "apb_pclk";
interrupts = <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>;
pinctrl-names = "default"; pinctrl-0 = <&spi5_clk &spi5_tx &spi5_rx &spi5_cs0>; #address-cells = <1>;interrupts = <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH 0>;
@@ -417,6 +643,375 @@ status = "disabled"; };
- thermal_zones: thermal-zones {
cpu_thermal: cpu {
polling-delay-passive = <100>;
polling-delay = <1000>;
thermal-sensors = <&tsadc 0>;
trips {
cpu_alert0: cpu_alert0 {
temperature = <70000>;
hysteresis = <2000>;
type = "passive";
cpu_alert1: cpu_alert1 {
temperature = <75000>;
type = "passive";
cpu_crit: cpu_crit {
temperature = <95000>;
type = "critical";
cooling-maps {
map0 {
trip = <&cpu_alert0>;
cooling-device =
<&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
map1 {
trip = <&cpu_alert1>;
cooling-device =
<&cpu_l0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
gpu_thermal: gpu {
thermal-sensors = <&tsadc 1>;
trips {
gpu_alert0: gpu_alert0 {
type = "passive";
gpu_crit: gpu_crit {
type = "critical";
cooling-maps {
map0 {
trip = <&gpu_alert0>;
cooling-device =
- tsadc: tsadc@ff260000 {
compatible = "rockchip,rk3399-tsadc";
reg = <0x0 0xff260000 0x0 0x100>;
interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH 0>;
assigned-clocks = <&cru SCLK_TSADC>;
assigned-clock-rates = <750000>;
clocks = <&cru SCLK_TSADC>, <&cru PCLK_TSADC>;
clock-names = "tsadc", "apb_pclk";
resets = <&cru SRST_TSADC>;
reset-names = "tsadc-apb";
rockchip,hw-tshut-temp = <95000>;
pinctrl-names = "init", "default", "sleep";
pinctrl-0 = <&otp_gpio>;
pinctrl-1 = <&otp_out>;
pinctrl-2 = <&otp_gpio>;
#thermal-sensor-cells = <1>;
- qos_emmc: qos@ffa58000 {
compatible = "syscon";
reg = <0x0 0xffa58000 0x0 0x20>;
- qos_gmac: qos@ffa5c000 {
reg = <0x0 0xffa5c000 0x0 0x20>;
- qos_pcie: qos@ffa60080 {
reg = <0x0 0xffa60080 0x0 0x20>;
- qos_usb_host0: qos@ffa60100 {
reg = <0x0 0xffa60100 0x0 0x20>;
- qos_usb_host1: qos@ffa60180 {
reg = <0x0 0xffa60180 0x0 0x20>;
- qos_usb_otg0: qos@ffa70000 {
reg = <0x0 0xffa70000 0x0 0x20>;
- qos_usb_otg1: qos@ffa70080 {
reg = <0x0 0xffa70080 0x0 0x20>;
- qos_sd: qos@ffa74000 {
reg = <0x0 0xffa74000 0x0 0x20>;
- qos_sdioaudio: qos@ffa76000 {
reg = <0x0 0xffa76000 0x0 0x20>;
- qos_hdcp: qos@ffa90000 {
reg = <0x0 0xffa90000 0x0 0x20>;
- qos_iep: qos@ffa98000 {
reg = <0x0 0xffa98000 0x0 0x20>;
- qos_isp0_m0: qos@ffaa0000 {
reg = <0x0 0xffaa0000 0x0 0x20>;
- qos_isp0_m1: qos@ffaa0080 {
reg = <0x0 0xffaa0080 0x0 0x20>;
- qos_isp1_m0: qos@ffaa8000 {
reg = <0x0 0xffaa8000 0x0 0x20>;
- qos_isp1_m1: qos@ffaa8080 {
reg = <0x0 0xffaa8080 0x0 0x20>;
- qos_rga_r: qos@ffab0000 {
reg = <0x0 0xffab0000 0x0 0x20>;
- qos_rga_w: qos@ffab0080 {
reg = <0x0 0xffab0080 0x0 0x20>;
- qos_video_m0: qos@ffab8000 {
reg = <0x0 0xffab8000 0x0 0x20>;
- qos_video_m1_r: qos@ffac0000 {
reg = <0x0 0xffac0000 0x0 0x20>;
- qos_video_m1_w: qos@ffac0080 {
reg = <0x0 0xffac0080 0x0 0x20>;
- qos_vop_big_r: qos@ffac8000 {
reg = <0x0 0xffac8000 0x0 0x20>;
- qos_vop_big_w: qos@ffac8080 {
reg = <0x0 0xffac8080 0x0 0x20>;
- qos_vop_little: qos@ffad0000 {
reg = <0x0 0xffad0000 0x0 0x20>;
- qos_perihp: qos@ffad8080 {
reg = <0x0 0xffad8080 0x0 0x20>;
- qos_gpu: qos@ffae0000 {
reg = <0x0 0xffae0000 0x0 0x20>;
- pmu: power-management@ff310000 {
compatible = "rockchip,rk3399-pmu", "syscon", "simple-mfd";
reg = <0x0 0xff310000 0x0 0x1000>;
* Note: RK3399 supports 6 voltage domains including VD_CORE_L,
* VD_CORE_B, VD_CENTER, VD_GPU, VD_LOGIC and VD_PMU.
* Some of the power domains are grouped together for every
* voltage domain.
* The detail contents as below.
power: power-controller {
compatible = "rockchip,rk3399-power-controller";
#power-domain-cells = <1>;
#size-cells = <0>;
/* These power domains are grouped by VD_CENTER */
pd_iep@RK3399_PD_IEP {
reg = <RK3399_PD_IEP>;
clocks = <&cru ACLK_IEP>,
<&cru HCLK_IEP>;
pm_qos = <&qos_iep>;
pd_rga@RK3399_PD_RGA {
reg = <RK3399_PD_RGA>;
clocks = <&cru ACLK_RGA>,
<&cru HCLK_RGA>;
pm_qos = <&qos_rga_r>,
<&qos_rga_w>;
pd_vcodec@RK3399_PD_VCODEC {
reg = <RK3399_PD_VCODEC>;
clocks = <&cru ACLK_VCODEC>,
<&cru HCLK_VCODEC>;
pm_qos = <&qos_video_m0>;
pd_vdu@RK3399_PD_VDU {
reg = <RK3399_PD_VDU>;
clocks = <&cru ACLK_VDU>,
<&cru HCLK_VDU>;
pm_qos = <&qos_video_m1_r>,
<&qos_video_m1_w>;
/* These power domains are grouped by VD_GPU */
pd_gpu@RK3399_PD_GPU {
reg = <RK3399_PD_GPU>;
clocks = <&cru ACLK_GPU>;
pm_qos = <&qos_gpu>;
/* These power domains are grouped by VD_LOGIC */
pd_edp@RK3399_PD_EDP {
reg = <RK3399_PD_EDP>;
clocks = <&cru PCLK_EDP_CTRL>;
pd_emmc@RK3399_PD_EMMC {
reg = <RK3399_PD_EMMC>;
clocks = <&cru ACLK_EMMC>;
pm_qos = <&qos_emmc>;
pd_gmac@RK3399_PD_GMAC {
reg = <RK3399_PD_GMAC>;
clocks = <&cru ACLK_GMAC>,
<&cru PCLK_GMAC>;
pm_qos = <&qos_gmac>;
pd_perihp@RK3399_PD_PERIHP {
reg = <RK3399_PD_PERIHP>;
#size-cells = <0>;
clocks = <&cru ACLK_PERIHP>;
pm_qos = <&qos_perihp>,
<&qos_pcie>,
<&qos_usb_host0>,
<&qos_usb_host1>;
pd_sd@RK3399_PD_SD {
reg = <RK3399_PD_SD>;
<&cru SCLK_SDMMC>;
pm_qos = <&qos_sd>;
pd_sdioaudio@RK3399_PD_SDIOAUDIO {
reg = <RK3399_PD_SDIOAUDIO>;
clocks = <&cru HCLK_SDIO>;
pm_qos = <&qos_sdioaudio>;
pd_usb3@RK3399_PD_USB3 {
reg = <RK3399_PD_USB3>;
clocks = <&cru ACLK_USB3>;
pm_qos = <&qos_usb_otg0>,
<&qos_usb_otg1>;
pd_vio@RK3399_PD_VIO {
reg = <RK3399_PD_VIO>;
#size-cells = <0>;
pd_hdcp@RK3399_PD_HDCP {
reg = <RK3399_PD_HDCP>;
clocks = <&cru ACLK_HDCP>,
<&cru HCLK_HDCP>,
<&cru PCLK_HDCP>;
pm_qos = <&qos_hdcp>;
pd_isp0@RK3399_PD_ISP0 {
reg = <RK3399_PD_ISP0>;
clocks = <&cru ACLK_ISP0>,
<&cru HCLK_ISP0>;
pm_qos = <&qos_isp0_m0>,
<&qos_isp0_m1>;
pd_isp1@RK3399_PD_ISP1 {
reg = <RK3399_PD_ISP1>;
clocks = <&cru ACLK_ISP1>,
<&cru HCLK_ISP1>;
pm_qos = <&qos_isp1_m0>,
<&qos_isp1_m1>;
pd_tcpc0@RK3399_PD_TCPC0 {
reg = <RK3399_PD_TCPD0>;
clocks = <&cru SCLK_UPHY0_TCPDCORE>,
<&cru SCLK_UPHY0_TCPDPHY_REF>;
pd_tcpc1@RK3399_PD_TCPC1 {
reg = <RK3399_PD_TCPD1>;
clocks = <&cru SCLK_UPHY1_TCPDCORE>,
<&cru SCLK_UPHY1_TCPDPHY_REF>;
pd_vo@RK3399_PD_VO {
reg = <RK3399_PD_VO>;
#size-cells = <0>;
pd_vopb@RK3399_PD_VOPB {
reg = <RK3399_PD_VOPB>;
clocks = <&cru ACLK_VOP0>,
<&cru HCLK_VOP0>;
pm_qos = <&qos_vop_big_r>,
<&qos_vop_big_w>;
pd_vopl@RK3399_PD_VOPL {
reg = <RK3399_PD_VOPL>;
clocks = <&cru ACLK_VOP1>,
<&cru HCLK_VOP1>;
pm_qos = <&qos_vop_little>;
- pmugrf: syscon@ff320000 { u-boot,dm-pre-reloc; compatible = "rockchip,rk3399-pmugrf", "syscon", "simple-mfd";
@@ -441,7 +1036,7 @@ reg = <0x0 0xff350000 0x0 0x1000>; clocks = <&pmucru SCLK_SPI3_PMU>, <&pmucru PCLK_SPI3_PMU>; clock-names = "spiclk", "apb_pclk";
interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>;
pinctrl-names = "default"; pinctrl-0 = <&spi3_clk &spi3_tx &spi3_rx &spi3_cs0>; #address-cells = <1>;interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH 0>;
@@ -454,7 +1049,7 @@ reg = <0x0 0xff370000 0x0 0x100>; clocks = <&pmucru SCLK_UART4_PMU>, <&pmucru PCLK_UART4_PMU>; clock-names = "baudclk", "apb_pclk";
interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>;
reg-shift = <2>; reg-io-width = <4>; pinctrl-names = "default";interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH 0>;
@@ -477,6 +1072,36 @@ status = "disabled"; };
- i2c4: i2c@ff3d0000 {
compatible = "rockchip,rk3399-i2c";
reg = <0x0 0xff3d0000 0x0 0x1000>;
assigned-clocks = <&pmucru SCLK_I2C4_PMU>;
clocks = <&pmucru SCLK_I2C4_PMU>, <&pmucru PCLK_I2C4_PMU>;
clock-names = "i2c", "pclk";
interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH 0>;
pinctrl-0 = <&i2c4_xfer>;
#size-cells = <0>;
- i2c8: i2c@ff3e0000 {
reg = <0x0 0xff3e0000 0x0 0x1000>;
assigned-clocks = <&pmucru SCLK_I2C8_PMU>;
clocks = <&pmucru SCLK_I2C8_PMU>, <&pmucru PCLK_I2C8_PMU>;
interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH 0>;
pinctrl-0 = <&i2c8_xfer>;
#size-cells = <0>;
- pwm0: pwm@ff420000 { compatible = "rockchip,rk3399-pwm", "rockchip,rk3288-pwm"; reg = <0x0 0xff420000 0x0 0x10>;
@@ -553,10 +1178,43 @@ 0x0 0xffa8c000 0x0 0x1000>; };
- efuse0: efuse@ff690000 {
compatible = "rockchip,rk3399-efuse";
reg = <0x0 0xff690000 0x0 0x80>;
#size-cells = <1>;
clocks = <&cru PCLK_EFUSE1024NS>;
clock-names = "pclk_efuse";
/* Data cells */
cpu_id: cpu-id@7 {
reg = <0x07 0x10>;
cpub_leakage: cpu-leakage@17 {
reg = <0x17 0x1>;
gpu_leakage: gpu-leakage@18 {
reg = <0x18 0x1>;
center_leakage: center-leakage@19 {
reg = <0x19 0x1>;
cpul_leakage: cpu-leakage@1a {
reg = <0x1a 0x1>;
logic_leakage: logic-leakage@1b {
reg = <0x1b 0x1>;
wafer_info: wafer-info@1c {
reg = <0x1c 0x1>;
- pmucru: pmu-clock-controller@ff750000 { u-boot,dm-pre-reloc; compatible = "rockchip,rk3399-pmucru"; reg = <0x0 0xff750000 0x0 0x1000>;
#clock-cells = <1>; #reset-cells = <1>; assigned-clocks = <&pmucru PLL_PPLL>;rockchip,grf = <&pmugrf>;
@@ -567,6 +1225,7 @@ u-boot,dm-pre-reloc; compatible = "rockchip,rk3399-cru"; reg = <0x0 0xff760000 0x0 0x1000>;
#clock-cells = <1>; #reset-cells = <1>; assigned-clocks =rockchip,grf = <&grf>;
@@ -575,7 +1234,7 @@ <&cru ACLK_PERIHP>, <&cru HCLK_PERIHP>, <&cru PCLK_PERIHP>, <&cru ACLK_PERILP0>, <&cru HCLK_PERILP0>,
<&cru PCLK_PERILP0>,
assigned-clock-rates = <594000000>, <800000000>,<&cru PCLK_PERILP0>, <&cru ACLK_CCI>, <&cru HCLK_PERILP1>, <&cru PCLK_PERILP1>;
@@ -583,7 +1242,7 @@ <150000000>, <75000000>, <37500000>, <100000000>, <100000000>,
<50000000>,
};<50000000>, <600000000>, <100000000>, <50000000>;
@@ -599,50 +1258,106 @@ status = "disabled"; };
u2phy0: usb2-phy@e450 {
compatible = "rockchip,rk3399-usb2phy";
reg = <0xe450 0x10>;
clocks = <&cru SCLK_USB2PHY0_REF>;
clock-names = "phyclk";
#clock-cells = <0>;
clock-output-names = "clk_usbphy0_480m";
#phy-cells = <0>;
interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH 0>;
interrupt-names = "linestate";
#phy-cells = <0>;
interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH 0>;
interrupt-names = "otg-bvalid", "otg-id",
"linestate";
u2phy1: usb2-phy@e460 {
reg = <0xe460 0x10>;
clocks = <&cru SCLK_USB2PHY1_REF>;
#clock-cells = <0>;
clock-output-names = "clk_usbphy1_480m";
#phy-cells = <0>;
interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH 0>;
#phy-cells = <0>;
interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH 0>;
"linestate";
- emmc_phy: phy@f780 { compatible = "rockchip,rk3399-emmc-phy"; reg = <0xf780 0x24>;
clocks = <&sdhci>;
};clock-names = "emmcclk"; #phy-cells = <0>; status = "disabled";
pcie_phy: pcie-phy {
compatible = "rockchip,rk3399-pcie-phy";
clocks = <&cru SCLK_PCIEPHY_REF>;
clock-names = "refclk";
#phy-cells = <0>;
resets = <&cru SRST_PCIEPHY>;
reset-names = "phy";
- watchdog@ff840000 {
- watchdog@ff848000 { compatible = "snps,dw-wdt";
reg = <0x0 0xff840000 0x0 0x100>;
clocks = <&cru PCLK_WDT>;reg = <0x0 0xff848000 0x0 0x100>;
interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>;
gmac: eth@fe300000 {
compatible = "rockchip,rk3399-gmac";
reg = <0x0 0xfe300000 0x0 0x10000>;
interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH 0>;
interrupt-names = "macirq";
clocks = <&cru SCLK_MAC>, <&cru SCLK_MAC_RX>,
<&cru SCLK_MAC_TX>, <&cru SCLK_MACREF>,
<&cru SCLK_MACREF_OUT>, <&cru ACLK_GMAC>,
<&cru PCLK_GMAC>;
clock-names = "stmmaceth", "mac_clk_rx",
"mac_clk_tx", "clk_mac_ref",
"clk_mac_refout", "aclk_mac",
"pclk_mac";
resets = <&cru SRST_A_GMAC>;
reset-names = "stmmaceth";
interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH 0>;
rktimer: rktimer@ff850000 {
compatible = "rockchip,rk3399-timer";
reg = <0x0 0xff850000 0x0 0x1000>;
interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru PCLK_TIMER0>, <&cru SCLK_TIMER00>;
clock-names = "pclk", "timer";
spdif: spdif@ff870000 { compatible = "rockchip,rk3399-spdif"; reg = <0x0 0xff870000 0x0 0x1000>;
interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&dmac_bus 7>; dma-names = "tx"; clock-names = "mclk", "hclk"; clocks = <&cru SCLK_SPDIF_8CH>, <&cru HCLK_SPDIF>; pinctrl-names = "default"; pinctrl-0 = <&spdif_bus>;interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH 0>;
status = "disabled"; };power-domains = <&power RK3399_PD_SDIOAUDIO>;
@@ -650,37 +1365,40 @@ compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s"; reg = <0x0 0xff880000 0x0 0x1000>; rockchip,grf = <&grf>;
interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>;
interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH 0>;
dmas = <&dmac_bus 0>, <&dmac_bus 1>; dma-names = "tx", "rx"; clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S0_8CH>, <&cru HCLK_I2S0_8CH>; pinctrl-names = "default"; pinctrl-0 = <&i2s0_8ch_bus>;
i2s1: i2s@ff890000 { compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s"; reg = <0x0 0xff890000 0x0 0x1000>;
interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>;
interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH 0>;
dmas = <&dmac_bus 2>, <&dmac_bus 3>; dma-names = "tx", "rx"; clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S1_8CH>, <&cru HCLK_I2S1_8CH>; pinctrl-names = "default"; pinctrl-0 = <&i2s1_2ch_bus>;
i2s2: i2s@ff8a0000 { compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s"; reg = <0x0 0xff8a0000 0x0 0x1000>;
interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&dmac_bus 4>, <&dmac_bus 5>; dma-names = "tx", "rx"; clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S2_8CH>, <&cru HCLK_I2S2_8CH>;interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH 0>;
@@ -697,7 +1415,7 @@ compatible = "rockchip,gpio-bank"; reg = <0x0 0xff720000 0x0 0x100>; clocks = <&pmucru PCLK_GPIO0_PMU>;
interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>;
interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH 0>; gpio-controller; #gpio-cells = <0x2>;
@@ -710,7 +1428,7 @@ compatible = "rockchip,gpio-bank"; reg = <0x0 0xff730000 0x0 0x100>; clocks = <&pmucru PCLK_GPIO1_PMU>;
interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>;
interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH 0>; gpio-controller; #gpio-cells = <0x2>;
@@ -723,7 +1441,7 @@ compatible = "rockchip,gpio-bank"; reg = <0x0 0xff780000 0x0 0x100>; clocks = <&cru PCLK_GPIO2>;
interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>;
interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH 0>; gpio-controller; #gpio-cells = <0x2>;
@@ -736,7 +1454,7 @@ compatible = "rockchip,gpio-bank"; reg = <0x0 0xff788000 0x0 0x100>; clocks = <&cru PCLK_GPIO3>;
interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>;
interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH 0>; gpio-controller; #gpio-cells = <0x2>;
@@ -749,7 +1467,7 @@ compatible = "rockchip,gpio-bank"; reg = <0x0 0xff790000 0x0 0x100>; clocks = <&cru PCLK_GPIO4>;
interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>;
interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH 0>; gpio-controller; #gpio-cells = <0x2>;
@@ -800,427 +1518,575 @@ drive-strength = <13>; };
clock {
clk_32k: clk-32k {
rockchip,pins = <0 RK_PA0 RK_FUNC_2 &pcfg_pull_none>;
edp {
edp_hpd: edp-hpd {
rockchip,pins =
<4 RK_PC7 RK_FUNC_2 &pcfg_pull_none>;
gmac {
rockchip,pins =
/* mac_txclk */
<3 RK_PC1 RK_FUNC_1 &pcfg_pull_none_13ma>,
/* mac_rxclk */
<3 RK_PB6 RK_FUNC_1 &pcfg_pull_none>,
/* mac_mdio */
/* mac_txen */
/* mac_clk */
/* mac_rxdv */
/* mac_mdc */
/* mac_rxd1 */
/* mac_rxd0 */
/* mac_txd1 */
/* mac_txd0 */
/* mac_rxd3 */
/* mac_rxd2 */
/* mac_txd3 */
/* mac_txd2 */
rockchip,pins =
/* mac_mdio */
/* mac_txen */
/* mac_clk */
/* mac_rxer */
/* mac_rxdv */
/* mac_mdc */
/* mac_rxd1 */
/* mac_rxd0 */
/* mac_txd1 */
/* mac_txd0 */
- i2c0 { i2c0_xfer: i2c0-xfer { rockchip,pins =
};<4 RK_PA7 RK_FUNC_1 &pcfg_pull_none>; };
gmac {
sdio0 {
/* mac_txclk */
/* mac_rxclk */
/* mac_mdio */
/* mac_txen */
/* mac_clk */
/* mac_rxdv */
/* mac_mdc */
/* mac_rxd1 */
/* mac_rxd0 */
/* mac_txd1 */
/* mac_txd0 */
/* mac_rxd3 */
/* mac_rxd2 */
/* mac_txd3 */
/* mac_txd2 */
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
<4 RK_PB0 RK_FUNC_1 &pcfg_pull_up>; }; sdmmc_bus4: sdmmc-bus4 { rockchip,pins =
<4 RK_PB3 RK_FUNC_1 &pcfg_pull_up>; }; sdmmc_clk: sdmmc-clk { rockchip,pins =
<4 RK_PB4 RK_FUNC_1 &pcfg_pull_none>; }; sdmmc_cmd: sdmmc-cmd { rockchip,pins =
<4 RK_PB5 RK_FUNC_1 &pcfg_pull_up>; }; sdmmc_cd: sdmcc-cd { rockchip,pins =
<0 RK_PA7 RK_FUNC_1 &pcfg_pull_up>; }; sdmmc_wp: sdmmc-wp { rockchip,pins =
sleep {
rockchip,pins =
tsadc {
otp_out: otp-out {
<2 RK_PC1 RK_FUNC_1 &pcfg_pull_none>; }; uart0_cts: uart0-cts { rockchip,pins =
<2 RK_PC2 RK_FUNC_1 &pcfg_pull_none>; }; uart0_rts: uart0-rts { rockchip,pins =
<3 RK_PB7 RK_FUNC_2 &pcfg_pull_none>; }; uart3_cts: uart3-cts { rockchip,pins =
<3 RK_PC2 RK_FUNC_2 &pcfg_pull_none>; }; uart3_rts: uart3-rts { rockchip,pins =
<4 RK_PC2 RK_FUNC_1 &pcfg_pull_none>; }; vop0_pwm_pin: vop0-pwm-pin { rockchip,pins =
<4 RK_PC6 RK_FUNC_1 &pcfg_pull_none>; }; vop1_pwm_pin: vop1-pwm-pin { rockchip,pins =
};<1 RK_PB6 RK_FUNC_1 &pcfg_pull_none>; };
hdmi {
rockchip,pins =
rockchip,pins =
pcie {
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
- Copyright (c) 2013 MundoReader S.L.
- Author: Heiko Stuebner heiko@sntech.de
- #define RK_FUNC_GPIO 0 #define RK_FUNC_1 1 #define RK_FUNC_2 2
Kever & Simon,
I’d prefer if we can remove ‘clock-freq-min-max’, as it’s deprecated upstream. A patch to adapt the rockchip_dw_mmc driver glue is already on patchworks: https://patchwork.ozlabs.org/patch/754607/ https://patchwork.ozlabs.org/patch/754607/
I.e. I’d prefer v2 of the patch to be merged and v3 to be ignored.
Regards, Philipp.
On 26 Apr 2017, at 12:23, Kever Yang kever.yang@rock-chips.com wrote:
Hi Simon,
Thanks,
- Kever
Changes in v2: None
@@ -9,6 +9,8 @@ #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/pinctrl/rockchip.h> +#include <dt-bindings/power/rk3399-power.h> +#include <dt-bindings/thermal/thermal.h> #define USB_CLASS_HUB 9 / { @@ -19,6 +21,15 @@ #size-cells = <2>; aliases {
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
i2c3 = &i2c3;
i2c4 = &i2c4;
i2c5 = &i2c5;
i2c6 = &i2c6;
i2c7 = &i2c7;
}; cpus {i2c0 = &i2c0;
- pmu_a53 {
- pmu_a72 {
@@ -117,10 +137,11 @@ timer { compatible = "arm,armv8-timer";
}; xin24m: xin24m {arm,no-tick-in-suspend;
}; };<GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH 0>; #dma-cells = <1>; clocks = <&cru ACLK_DMAC1_PERILP>; clock-names = "apb_pclk";
- pcie0: pcie@f8000000 {
#size-cells = <2>;
aspm-no-l0s;
"hclk", "pm";
phys = <&pcie_phy>;
<&cru SRST_A_PCIE>;
- gmac: ethernet@fe300000 {
<&cru PCLK_GMAC>;
"pclk_mac";
- sdio0: dwmmc@fe310000 { compatible = "rockchip,rk3399-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x0 0xfe310000 0x0 0x4000>;
assigned-clocks = <&cru SCLK_EMMC>; assigned-clock-rates = <200000000>; max-frequency = <200000000>; clocks = <&cru SCLK_EMMC>, <&cru ACLK_EMMC>; clock-names = "clk_xin", "clk_ahb";arasan,soc-ctl-syscon = <&grf>;
phys = <&emmc_phy>; phy-names = "phy_arasan";#clock-cells = <0>;
status = "disabled"; }; usb_host0_ehci: usb@fe380000 { compatible = "generic-ehci"; reg = <0x0 0xfe380000 0x0 0x20000>;power-domains = <&power RK3399_PD_EMMC>;
<&u2phy0>;
"utmi";
phy-names = "usb";
status = "disabled"; }; usb_host0_ohci: usb@fe3a0000 { compatible = "generic-ohci"; reg = <0x0 0xfe3a0000 0x0 0x20000>;power-domains = <&power RK3399_PD_PERIHP>;
<&u2phy0>;
"utmi";
phy-names = "usb";
status = "disabled"; }; usb_host1_ehci: usb@fe3c0000 { compatible = "generic-ehci"; reg = <0x0 0xfe3c0000 0x0 0x20000>;power-domains = <&power RK3399_PD_PERIHP>;
<&u2phy1>;
"utmi";
phy-names = "usb";
status = "disabled"; }; usb_host1_ohci: usb@fe3e0000 { compatible = "generic-ohci"; reg = <0x0 0xfe3e0000 0x0 0x20000>;power-domains = <&power RK3399_PD_PERIHP>;
<&u2phy1>;
"utmi";
phy-names = "usb";
@@ -280,7 +394,7 @@ gic: interrupt-controller@fee00000 { compatible = "arm,gic-v3";
its: interrupt-controller@fee20000 { compatible = "arm,gic-v3-its"; msi-controller; reg = <0x0 0xfee20000 0x0 0x20000>; };interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH 0>;
ppi-partitions {
- saradc: saradc@ff100000 {
- i2c1: i2c@ff110000 {
#size-cells = <0>;
- i2c2: i2c@ff120000 {
#size-cells = <0>;
- i2c3: i2c@ff130000 {
#size-cells = <0>;
- i2c5: i2c@ff140000 {
#size-cells = <0>;
- i2c6: i2c@ff150000 {
#size-cells = <0>;
- i2c7: i2c@ff160000 {
#size-cells = <0>;
}; uart0: serial@ff180000 {status = "disabled";
cpu_thermal: cpu {
trips {
type = "passive";
type = "passive";
type = "critical";
cooling-maps {
map0 {
cooling-device =
map1 {
cooling-device =
gpu_thermal: gpu {
trips {
type = "passive";
type = "critical";
cooling-maps {
map0 {
cooling-device =
* voltage domain.
#size-cells = <0>;
<&cru HCLK_IEP>;
<&cru HCLK_RGA>;
<&qos_rga_w>;
<&cru HCLK_VCODEC>;
<&cru HCLK_VDU>;
<&qos_video_m1_w>;
<&cru PCLK_GMAC>;
#size-cells = <0>;
<&qos_pcie>,
<&qos_usb_host0>,
<&qos_usb_host1>;
<&cru SCLK_SDMMC>;
pm_qos = <&qos_sd>;
<&qos_usb_otg1>;
#size-cells = <0>;
<&cru HCLK_HDCP>,
<&cru PCLK_HDCP>;
<&cru HCLK_ISP0>;
<&qos_isp0_m1>;
<&cru HCLK_ISP1>;
<&qos_isp1_m1>;
#size-cells = <0>;
<&cru HCLK_VOP0>;
<&qos_vop_big_w>;
<&cru HCLK_VOP1>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <1>;
/* Data cells */
cpu_id: cpu-id@7 {
reg = <0x07 0x10>;
reg = <0x17 0x1>;
reg = <0x18 0x1>;
reg = <0x19 0x1>;
reg = <0x1a 0x1>;
reg = <0x1b 0x1>;
reg = <0x1c 0x1>;
<50000000>,
#clock-cells = <0>;
#phy-cells = <0>;
#phy-cells = <0>;
"linestate";
#clock-cells = <0>;
#phy-cells = <0>;
#phy-cells = <0>;
"linestate";
clocks = <&sdhci>;
#phy-cells = <0>;
<&cru PCLK_GMAC>;
"pclk_mac";
- rktimer: rktimer@ff850000 {
- }; spdif: spdif@ff870000 { compatible = "rockchip,rk3399-spdif"; reg = <0x0 0xff870000 0x0 0x1000>;
dmas = <&dmac_bus 0>, <&dmac_bus 1>; dma-names = "tx", "rx"; clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S0_8CH>, <&cru HCLK_I2S0_8CH>; pinctrl-names = "default"; pinctrl-0 = <&i2s0_8ch_bus>;interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH 0>;
status = "disabled"; }; i2s1: i2s@ff890000 { compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s"; reg = <0x0 0xff890000 0x0 0x1000>;power-domains = <&power RK3399_PD_SDIOAUDIO>;
dmas = <&dmac_bus 2>, <&dmac_bus 3>; dma-names = "tx", "rx"; clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S1_8CH>, <&cru HCLK_I2S1_8CH>; pinctrl-names = "default"; pinctrl-0 = <&i2s1_2ch_bus>;interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH 0>;
status = "disabled"; }; i2s2: i2s@ff8a0000 { compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s"; reg = <0x0 0xff8a0000 0x0 0x1000>;power-domains = <&power RK3399_PD_SDIOAUDIO>;
clock {
clk_32k: clk-32k {
edp {
edp_hpd: edp-hpd {
rockchip,pins =
gmac {
rgmii_pins: rgmii-pins {
rockchip,pins =
/* mac_txclk */
/* mac_rxclk */
/* mac_mdio */
<3 RK_PB5 RK_FUNC_1 &pcfg_pull_none>,
/* mac_txen */
<3 RK_PB4 RK_FUNC_1 &pcfg_pull_none_13ma>,
/* mac_clk */
<3 RK_PB3 RK_FUNC_1 &pcfg_pull_none>,
/* mac_rxdv */
<3 RK_PB1 RK_FUNC_1 &pcfg_pull_none>,
/* mac_mdc */
<3 RK_PB0 RK_FUNC_1 &pcfg_pull_none>,
/* mac_rxd1 */
<3 RK_PA7 RK_FUNC_1 &pcfg_pull_none>,
/* mac_rxd0 */
<3 RK_PA6 RK_FUNC_1 &pcfg_pull_none>,
/* mac_txd1 */
<3 RK_PA5 RK_FUNC_1 &pcfg_pull_none_13ma>,
/* mac_txd0 */
<3 RK_PA4 RK_FUNC_1 &pcfg_pull_none_13ma>,
/* mac_rxd3 */
<3 RK_PA3 RK_FUNC_1 &pcfg_pull_none>,
/* mac_rxd2 */
<3 RK_PA2 RK_FUNC_1 &pcfg_pull_none>,
/* mac_txd3 */
<3 RK_PA1 RK_FUNC_1 &pcfg_pull_none_13ma>,
/* mac_txd2 */
<3 RK_PA0 RK_FUNC_1 &pcfg_pull_none_13ma>;
rmii_pins: rmii-pins {
rockchip,pins =
/* mac_mdio */
/* mac_txen */
/* mac_clk */
/* mac_rxer */
<3 RK_PB2 RK_FUNC_1 &pcfg_pull_none>,
/* mac_rxdv */
/* mac_mdc */
/* mac_rxd1 */
/* mac_rxd0 */
/* mac_txd1 */
/* mac_txd0 */
<3 RK_PA4 RK_FUNC_1 &pcfg_pull_none_13ma>;
<1 15 RK_FUNC_2 &pcfg_pull_none>,
<1 16 RK_FUNC_2 &pcfg_pull_none>;
<1 RK_PB7 RK_FUNC_2 &pcfg_pull_none>,
}; i2c1 { i2c1_xfer: i2c1-xfer { rockchip,pins =<1 RK_PC0 RK_FUNC_2 &pcfg_pull_none>; };
<4 2 RK_FUNC_1 &pcfg_pull_none>,
<4 1 RK_FUNC_1 &pcfg_pull_none>;
<4 RK_PA2 RK_FUNC_1 &pcfg_pull_none>,
}; i2c2 { i2c2_xfer: i2c2-xfer { rockchip,pins =<4 RK_PA1 RK_FUNC_1 &pcfg_pull_none>; };
<2 1 RK_FUNC_2 &pcfg_pull_none_12ma>,
<2 0 RK_FUNC_2 &pcfg_pull_none_12ma>;
<2 RK_PA1 RK_FUNC_2 &pcfg_pull_none_12ma>,
}; i2c3 { i2c3_xfer: i2c3-xfer { rockchip,pins =<2 RK_PA0 RK_FUNC_2 &pcfg_pull_none_12ma>; };
<4 17 RK_FUNC_1 &pcfg_pull_none>,
<4 16 RK_FUNC_1 &pcfg_pull_none>;
<4 RK_PC1 RK_FUNC_1 &pcfg_pull_none>,
}; i2c4 { i2c4_xfer: i2c4-xfer { rockchip,pins =<4 RK_PC0 RK_FUNC_1 &pcfg_pull_none>; };
<1 12 RK_FUNC_1 &pcfg_pull_none>,
<1 11 RK_FUNC_1 &pcfg_pull_none>;
<1 RK_PB4 RK_FUNC_1 &pcfg_pull_none>,
}; i2c5 { i2c5_xfer: i2c5-xfer { rockchip,pins =<1 RK_PB3 RK_FUNC_1 &pcfg_pull_none>; };
<3 11 RK_FUNC_2 &pcfg_pull_none>,
<3 10 RK_FUNC_2 &pcfg_pull_none>;
<3 RK_PB3 RK_FUNC_2 &pcfg_pull_none>,
}; i2c6 { i2c6_xfer: i2c6-xfer { rockchip,pins =<3 RK_PB2 RK_FUNC_2 &pcfg_pull_none>; };
<2 10 RK_FUNC_2 &pcfg_pull_none>,
<2 9 RK_FUNC_2 &pcfg_pull_none>;
<2 RK_PB2 RK_FUNC_2 &pcfg_pull_none>,
}; i2c7 { i2c7_xfer: i2c7-xfer { rockchip,pins =<2 RK_PB1 RK_FUNC_2 &pcfg_pull_none>; };
<2 8 RK_FUNC_2 &pcfg_pull_none>,
<2 7 RK_FUNC_2 &pcfg_pull_none>;
<2 RK_PB0 RK_FUNC_2 &pcfg_pull_none>,
}; i2c8 { i2c8_xfer: i2c8-xfer { rockchip,pins =<2 RK_PA7 RK_FUNC_2 &pcfg_pull_none>; };
<1 21 RK_FUNC_1 &pcfg_pull_none>,
<1 20 RK_FUNC_1 &pcfg_pull_none>;
<1 RK_PC5 RK_FUNC_1 &pcfg_pull_none>,
}; i2s0 { i2s0_8ch_bus: i2s0-8ch-bus { rockchip,pins =<1 RK_PC4 RK_FUNC_1 &pcfg_pull_none>; };
<3 24 RK_FUNC_1 &pcfg_pull_none>,
<3 25 RK_FUNC_1 &pcfg_pull_none>,
<3 26 RK_FUNC_1 &pcfg_pull_none>,
<3 27 RK_FUNC_1 &pcfg_pull_none>,
<3 28 RK_FUNC_1 &pcfg_pull_none>,
<3 29 RK_FUNC_1 &pcfg_pull_none>,
<3 30 RK_FUNC_1 &pcfg_pull_none>,
<3 31 RK_FUNC_1 &pcfg_pull_none>,
<4 0 RK_FUNC_1 &pcfg_pull_none>;
<3 RK_PD0 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PD1 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PD2 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PD3 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PD4 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PD5 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PD6 RK_FUNC_1 &pcfg_pull_none>,
<3 RK_PD7 RK_FUNC_1 &pcfg_pull_none>,
}; i2s1 { i2s1_2ch_bus: i2s1-2ch-bus { rockchip,pins =<4 RK_PA0 RK_FUNC_1 &pcfg_pull_none>; };
<4 3 RK_FUNC_1 &pcfg_pull_none>,
<4 4 RK_FUNC_1 &pcfg_pull_none>,
<4 5 RK_FUNC_1 &pcfg_pull_none>,
<4 6 RK_FUNC_1 &pcfg_pull_none>,
<4 7 RK_FUNC_1 &pcfg_pull_none>;
<4 RK_PA3 RK_FUNC_1 &pcfg_pull_none>,
<4 RK_PA4 RK_FUNC_1 &pcfg_pull_none>,
<4 RK_PA5 RK_FUNC_1 &pcfg_pull_none>,
<4 RK_PA6 RK_FUNC_1 &pcfg_pull_none>,
gmac {
sdio0 {
sdio0_bus1: sdio0-bus1 { rockchip,pins =
/* mac_txclk */
<3 17 RK_FUNC_1 &pcfg_pull_none_13ma>,
/* mac_rxclk */
<3 14 RK_FUNC_1 &pcfg_pull_none>,
/* mac_mdio */
<3 13 RK_FUNC_1 &pcfg_pull_none>,
/* mac_txen */
<3 12 RK_FUNC_1 &pcfg_pull_none_13ma>,
/* mac_clk */
<3 11 RK_FUNC_1 &pcfg_pull_none>,
/* mac_rxdv */
<3 9 RK_FUNC_1 &pcfg_pull_none>,
/* mac_mdc */
<3 8 RK_FUNC_1 &pcfg_pull_none>,
/* mac_rxd1 */
<3 7 RK_FUNC_1 &pcfg_pull_none>,
/* mac_rxd0 */
<3 6 RK_FUNC_1 &pcfg_pull_none>,
/* mac_txd1 */
<3 5 RK_FUNC_1 &pcfg_pull_none_13ma>,
/* mac_txd0 */
<3 4 RK_FUNC_1 &pcfg_pull_none_13ma>,
/* mac_rxd3 */
<3 3 RK_FUNC_1 &pcfg_pull_none>,
/* mac_rxd2 */
<3 2 RK_FUNC_1 &pcfg_pull_none>,
/* mac_txd3 */
<3 1 RK_FUNC_1 &pcfg_pull_none_13ma>,
/* mac_txd2 */
<3 0 RK_FUNC_1 &pcfg_pull_none_13ma>;
<2 RK_PC4 RK_FUNC_1 &pcfg_pull_up>;
sdio0_bus4: sdio0-bus4 {
rockchip,pins =
<2 RK_PC4 RK_FUNC_1 &pcfg_pull_up>,
<2 RK_PC5 RK_FUNC_1 &pcfg_pull_up>,
<2 RK_PC6 RK_FUNC_1 &pcfg_pull_up>,
<2 RK_PC7 RK_FUNC_1 &pcfg_pull_up>;
sdio0_cmd: sdio0-cmd {
rockchip,pins =
<2 RK_PD0 RK_FUNC_1 &pcfg_pull_up>;
sdio0_clk: sdio0-clk {
rockchip,pins =
<2 RK_PD1 RK_FUNC_1 &pcfg_pull_none>;
sdio0_cd: sdio0-cd {
rockchip,pins =
<2 RK_PD2 RK_FUNC_1 &pcfg_pull_up>;
sdio0_pwr: sdio0-pwr {
rockchip,pins =
<2 RK_PD3 RK_FUNC_1 &pcfg_pull_up>;
sdio0_bkpwr: sdio0-bkpwr {
rockchip,pins =
<2 RK_PD4 RK_FUNC_1 &pcfg_pull_up>;
sdio0_wp: sdio0-wp {
rockchip,pins =
<0 RK_PA3 RK_FUNC_1 &pcfg_pull_up>;
sdio0_int: sdio0-int {
rockchip,pins =
}; sdmmc { sdmmc_bus1: sdmmc-bus1 { rockchip,pins =<0 RK_PA4 RK_FUNC_1 &pcfg_pull_up>; };
<4 8 RK_FUNC_1 &pcfg_pull_up>;
<4 8 RK_FUNC_1 &pcfg_pull_up>,
<4 9 RK_FUNC_1 &pcfg_pull_up>,
<4 10 RK_FUNC_1 &pcfg_pull_up>,
<4 11 RK_FUNC_1 &pcfg_pull_up>;
<4 RK_PB0 RK_FUNC_1 &pcfg_pull_up>,
<4 RK_PB1 RK_FUNC_1 &pcfg_pull_up>,
<4 RK_PB2 RK_FUNC_1 &pcfg_pull_up>,
<4 12 RK_FUNC_1 &pcfg_pull_none>;
<4 13 RK_FUNC_1 &pcfg_pull_up>;
<0 7 RK_FUNC_1 &pcfg_pull_up>;
<0 8 RK_FUNC_1 &pcfg_pull_up>;
<0 RK_PB0 RK_FUNC_1 &pcfg_pull_up>;
sleep {
ap_pwroff: ap-pwroff {
rockchip,pins = <1 RK_PA5 RK_FUNC_1 &pcfg_pull_none>;
ddrio_pwroff: ddrio-pwroff {
}; spdif { spdif_bus: spdif-bus { rockchip,pins =rockchip,pins = <0 RK_PA1 RK_FUNC_1 &pcfg_pull_none>; };
<4 21 RK_FUNC_1 &pcfg_pull_none>;
<4 RK_PC5 RK_FUNC_1 &pcfg_pull_none>;
spdif_bus_1: spdif-bus-1 {
rockchip,pins =
}; spi0 { spi0_clk: spi0-clk { rockchip,pins =<3 RK_PC0 RK_FUNC_3 &pcfg_pull_none>; };
<3 6 RK_FUNC_2 &pcfg_pull_up>;
<3 RK_PA6 RK_FUNC_2 &pcfg_pull_up>; }; spi0_cs0: spi0-cs0 { rockchip,pins =
<3 7 RK_FUNC_2 &pcfg_pull_up>;
<3 RK_PA7 RK_FUNC_2 &pcfg_pull_up>; }; spi0_cs1: spi0-cs1 { rockchip,pins =
<3 8 RK_FUNC_2 &pcfg_pull_up>;
<3 RK_PB0 RK_FUNC_2 &pcfg_pull_up>; }; spi0_tx: spi0-tx { rockchip,pins =
<3 5 RK_FUNC_2 &pcfg_pull_up>;
<3 RK_PA5 RK_FUNC_2 &pcfg_pull_up>; }; spi0_rx: spi0-rx { rockchip,pins =
<3 4 RK_FUNC_2 &pcfg_pull_up>;
}; spi1 { spi1_clk: spi1-clk { rockchip,pins =<3 RK_PA4 RK_FUNC_2 &pcfg_pull_up>; };
<1 9 RK_FUNC_2 &pcfg_pull_up>;
<1 RK_PB1 RK_FUNC_2 &pcfg_pull_up>; }; spi1_cs0: spi1-cs0 { rockchip,pins =
<1 10 RK_FUNC_2 &pcfg_pull_up>;
<1 RK_PB2 RK_FUNC_2 &pcfg_pull_up>; }; spi1_rx: spi1-rx { rockchip,pins =
<1 7 RK_FUNC_2 &pcfg_pull_up>;
<1 RK_PA7 RK_FUNC_2 &pcfg_pull_up>; }; spi1_tx: spi1-tx { rockchip,pins =
<1 8 RK_FUNC_2 &pcfg_pull_up>;
}; spi2 { spi2_clk: spi2-clk { rockchip,pins =<1 RK_PB0 RK_FUNC_2 &pcfg_pull_up>; };
<2 11 RK_FUNC_1 &pcfg_pull_up>;
<2 RK_PB3 RK_FUNC_1 &pcfg_pull_up>; }; spi2_cs0: spi2-cs0 { rockchip,pins =
<2 12 RK_FUNC_1 &pcfg_pull_up>;
<2 RK_PB4 RK_FUNC_1 &pcfg_pull_up>; }; spi2_rx: spi2-rx { rockchip,pins =
<2 9 RK_FUNC_1 &pcfg_pull_up>;
<2 RK_PB1 RK_FUNC_1 &pcfg_pull_up>; }; spi2_tx: spi2-tx { rockchip,pins =
<2 10 RK_FUNC_1 &pcfg_pull_up>;
}; spi3 { spi3_clk: spi3-clk { rockchip,pins =<2 RK_PB2 RK_FUNC_1 &pcfg_pull_up>; };
<1 17 RK_FUNC_1 &pcfg_pull_up>;
<1 RK_PC1 RK_FUNC_1 &pcfg_pull_up>; }; spi3_cs0: spi3-cs0 { rockchip,pins =
<1 18 RK_FUNC_1 &pcfg_pull_up>;
<1 RK_PC2 RK_FUNC_1 &pcfg_pull_up>; }; spi3_rx: spi3-rx { rockchip,pins =
<1 15 RK_FUNC_1 &pcfg_pull_up>;
<1 RK_PB7 RK_FUNC_1 &pcfg_pull_up>; }; spi3_tx: spi3-tx { rockchip,pins =
<1 16 RK_FUNC_1 &pcfg_pull_up>;
}; spi4 { spi4_clk: spi4-clk { rockchip,pins =<1 RK_PC0 RK_FUNC_1 &pcfg_pull_up>; };
<3 2 RK_FUNC_2 &pcfg_pull_up>;
<3 RK_PA2 RK_FUNC_2 &pcfg_pull_up>; }; spi4_cs0: spi4-cs0 { rockchip,pins =
<3 3 RK_FUNC_2 &pcfg_pull_up>;
<3 RK_PA3 RK_FUNC_2 &pcfg_pull_up>; }; spi4_rx: spi4-rx { rockchip,pins =
<3 0 RK_FUNC_2 &pcfg_pull_up>;
<3 RK_PA0 RK_FUNC_2 &pcfg_pull_up>; }; spi4_tx: spi4-tx { rockchip,pins =
<3 1 RK_FUNC_2 &pcfg_pull_up>;
}; spi5 { spi5_clk: spi5-clk { rockchip,pins =<3 RK_PA1 RK_FUNC_2 &pcfg_pull_up>; };
<2 22 RK_FUNC_2 &pcfg_pull_up>;
<2 RK_PC6 RK_FUNC_2 &pcfg_pull_up>; }; spi5_cs0: spi5-cs0 { rockchip,pins =
<2 23 RK_FUNC_2 &pcfg_pull_up>;
<2 RK_PC7 RK_FUNC_2 &pcfg_pull_up>; }; spi5_rx: spi5-rx { rockchip,pins =
<2 20 RK_FUNC_2 &pcfg_pull_up>;
<2 RK_PC4 RK_FUNC_2 &pcfg_pull_up>; }; spi5_tx: spi5-tx { rockchip,pins =
<2 21 RK_FUNC_2 &pcfg_pull_up>;
<2 RK_PC5 RK_FUNC_2 &pcfg_pull_up>;
tsadc {
otp_gpio: otp-gpio {
rockchip,pins = <1 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>;
otp_out: otp-out {
}; uart0 { uart0_xfer: uart0-xfer { rockchip,pins =rockchip,pins = <1 RK_PA6 RK_FUNC_1 &pcfg_pull_none>; };
<2 16 RK_FUNC_1 &pcfg_pull_up>,
<2 17 RK_FUNC_1 &pcfg_pull_none>;
<2 RK_PC0 RK_FUNC_1 &pcfg_pull_up>,
<2 18 RK_FUNC_1 &pcfg_pull_none>;
<2 19 RK_FUNC_1 &pcfg_pull_none>;
}; uart1 { uart1_xfer: uart1-xfer { rockchip,pins =<2 RK_PC3 RK_FUNC_1 &pcfg_pull_none>; };
<3 12 RK_FUNC_2 &pcfg_pull_up>,
<3 13 RK_FUNC_2 &pcfg_pull_none>;
<3 RK_PB4 RK_FUNC_2 &pcfg_pull_up>,
}; uart2a { uart2a_xfer: uart2a-xfer { rockchip,pins =<3 RK_PB5 RK_FUNC_2 &pcfg_pull_none>; };
<4 8 RK_FUNC_2 &pcfg_pull_up>,
<4 9 RK_FUNC_2 &pcfg_pull_none>;
<4 RK_PB0 RK_FUNC_2 &pcfg_pull_up>,
}; uart2b { uart2b_xfer: uart2b-xfer { rockchip,pins =<4 RK_PB1 RK_FUNC_2 &pcfg_pull_none>; };
<4 16 RK_FUNC_2 &pcfg_pull_up>,
<4 17 RK_FUNC_2 &pcfg_pull_none>;
<4 RK_PC0 RK_FUNC_2 &pcfg_pull_up>,
}; uart2c { uart2c_xfer: uart2c-xfer { rockchip,pins =<4 RK_PC1 RK_FUNC_2 &pcfg_pull_none>; };
<4 19 RK_FUNC_1 &pcfg_pull_up>,
<4 20 RK_FUNC_1 &pcfg_pull_none>;
<4 RK_PC3 RK_FUNC_1 &pcfg_pull_up>,
}; uart3 { uart3_xfer: uart3-xfer { rockchip,pins =<4 RK_PC4 RK_FUNC_1 &pcfg_pull_none>; };
<3 14 RK_FUNC_2 &pcfg_pull_up>,
<3 15 RK_FUNC_2 &pcfg_pull_none>;
<3 RK_PB6 RK_FUNC_2 &pcfg_pull_up>,
<3 18 RK_FUNC_2 &pcfg_pull_none>;
<3 19 RK_FUNC_2 &pcfg_pull_none>;
}; uart4 { uart4_xfer: uart4-xfer { rockchip,pins =<3 RK_PC3 RK_FUNC_2 &pcfg_pull_none>; };
<1 7 RK_FUNC_1 &pcfg_pull_up>,
<1 8 RK_FUNC_1 &pcfg_pull_none>;
<1 RK_PA7 RK_FUNC_1 &pcfg_pull_up>,
}; uarthdcp { uarthdcp_xfer: uarthdcp-xfer { rockchip,pins =<1 RK_PB0 RK_FUNC_1 &pcfg_pull_none>; };
<4 21 RK_FUNC_2 &pcfg_pull_up>,
<4 22 RK_FUNC_2 &pcfg_pull_none>;
<4 RK_PC5 RK_FUNC_2 &pcfg_pull_up>,
}; pwm0 { pwm0_pin: pwm0-pin { rockchip,pins =<4 RK_PC6 RK_FUNC_2 &pcfg_pull_none>; };
<4 18 RK_FUNC_1 &pcfg_pull_none>;
<4 18 RK_FUNC_2 &pcfg_pull_none>;
}; pwm1 { pwm1_pin: pwm1-pin { rockchip,pins =<4 RK_PC2 RK_FUNC_2 &pcfg_pull_none>; };
<4 22 RK_FUNC_1 &pcfg_pull_none>;
<4 18 RK_FUNC_3 &pcfg_pull_none>;
}; pwm2 { pwm2_pin: pwm2-pin { rockchip,pins =<4 RK_PC2 RK_FUNC_3 &pcfg_pull_none>; };
<1 19 RK_FUNC_1 &pcfg_pull_none>;
}; pwm3a { pwm3a_pin: pwm3a-pin { rockchip,pins =<1 RK_PC3 RK_FUNC_1 &pcfg_pull_none>; };
<0 6 RK_FUNC_1 &pcfg_pull_none>;
}; pwm3b { pwm3b_pin: pwm3b-pin { rockchip,pins =<0 RK_PA6 RK_FUNC_1 &pcfg_pull_none>; };
<1 14 RK_FUNC_1 &pcfg_pull_none>;
hdmi {
hdmi_i2c_xfer: hdmi-i2c-xfer {
rockchip,pins =
<4 RK_PC1 RK_FUNC_3 &pcfg_pull_none>,
<4 RK_PC0 RK_FUNC_3 &pcfg_pull_none>;
hdmi_cec: hdmi-cec {
rockchip,pins =
<4 RK_PC7 RK_FUNC_1 &pcfg_pull_none>;
pcie {
pcie_clkreqn: pci-clkreqn {
rockchip,pins =
<2 RK_PD2 RK_FUNC_2 &pcfg_pull_none>;
pcie_clkreqnb: pci-clkreqnb {
rockchip,pins =
<4 RK_PD0 RK_FUNC_1 &pcfg_pull_none>;
pcie_clkreqn_cpm: pci-clkreqn-cpm {
rockchip,pins =
<2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>;
pcie_clkreqnb_cpm: pci-clkreqnb-cpm {
rockchip,pins =
<4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>;
}; diff --git a/include/dt-bindings/pinctrl/rockchip.h b/include/dt-bindings/pinctrl/rockchip.h index ecb76c7..0798287 100644 --- a/include/dt-bindings/pinctrl/rockchip.h +++ b/include/dt-bindings/pinctrl/rockchip.h @@ -4,7 +4,7 @@
*/ #ifndef __DT_BINDINGS_ROCKCHIP_PINCTRL_H__
@@ -17,6 +17,39 @@ #define RK_GPIO4 4 #define RK_GPIO6 6 +#define RK_PA0 0 +#define RK_PA1 1 +#define RK_PA2 2 +#define RK_PA3 3 +#define RK_PA4 4 +#define RK_PA5 5 +#define RK_PA6 6 +#define RK_PA7 7 +#define RK_PB0 8 +#define RK_PB1 9 +#define RK_PB2 10 +#define RK_PB3 11 +#define RK_PB4 12 +#define RK_PB5 13 +#define RK_PB6 14 +#define RK_PB7 15 +#define RK_PC0 16 +#define RK_PC1 17 +#define RK_PC2 18 +#define RK_PC3 19 +#define RK_PC4 20 +#define RK_PC5 21 +#define RK_PC6 22 +#define RK_PC7 23 +#define RK_PD0 24 +#define RK_PD1 25 +#define RK_PD2 26 +#define RK_PD3 27 +#define RK_PD4 28 +#define RK_PD5 29 +#define RK_PD6 30 +#define RK_PD7 31
#define RK_FUNC_GPIO 0 #define RK_FUNC_1 1 #define RK_FUNC_2 2 diff --git a/include/dt-bindings/power/rk3399-power.h b/include/dt-bindings/power/rk3399-power.h new file mode 100644 index 0000000..168b3bf --- /dev/null +++ b/include/dt-bindings/power/rk3399-power.h @@ -0,0 +1,53 @@ +#ifndef __DT_BINDINGS_POWER_RK3399_POWER_H__ +#define __DT_BINDINGS_POWER_RK3399_POWER_H__
+/* VD_CORE_L */ +#define RK3399_PD_A53_L0 0 +#define RK3399_PD_A53_L1 1 +#define RK3399_PD_A53_L2 2 +#define RK3399_PD_A53_L3 3 +#define RK3399_PD_SCU_L 4
+/* VD_CORE_B */ +#define RK3399_PD_A72_B0 5 +#define RK3399_PD_A72_B1 6 +#define RK3399_PD_SCU_B 7
+/* VD_LOGIC */ +#define RK3399_PD_TCPD0 8 +#define RK3399_PD_TCPD1 9 +#define RK3399_PD_CCI 10 +#define RK3399_PD_CCI0 11 +#define RK3399_PD_CCI1 12 +#define RK3399_PD_PERILP 13 +#define RK3399_PD_PERIHP 14 +#define RK3399_PD_VIO 15 +#define RK3399_PD_VO 16 +#define RK3399_PD_VOPB 17 +#define RK3399_PD_VOPL 18 +#define RK3399_PD_ISP0 19 +#define RK3399_PD_ISP1 20 +#define RK3399_PD_HDCP 21 +#define RK3399_PD_GMAC 22 +#define RK3399_PD_EMMC 23 +#define RK3399_PD_USB3 24 +#define RK3399_PD_EDP 25 +#define RK3399_PD_GIC 26 +#define RK3399_PD_SD 27 +#define RK3399_PD_SDIOAUDIO 28 +#define RK3399_PD_ALIVE 29
+/* VD_CENTER */ +#define RK3399_PD_CENTER 30 +#define RK3399_PD_VCODEC 31 +#define RK3399_PD_VDU 32 +#define RK3399_PD_RGA 33 +#define RK3399_PD_IEP 34
+/* VD_GPU */ +#define RK3399_PD_GPU 35
+/* VD_PMU */ +#define RK3399_PD_PMU 36
Hi Philipp,
I didn't search the history of kernel about the "clock-freq-min-max"
when I find the regression.
You patch for rockchip_dw_mmc would be better if it can apply.
Hi Simon,
You can decide which version to use. If using V2, should pull with Philipp's
patch for remove 'clock-freq-min-max'.
Thanks, - Kever On 04/26/2017 06:30 PM, Dr. Philipp Tomsich wrote:
Kever & Simon,
Regards, Philipp.
On 26 Apr 2017, at 12:23, Kever Yang <kever.yang@rock-chips.com mailto:kever.yang@rock-chips.com> wrote:
Hi Simon,
Thanks,
- Kever
Signed-off-by: Kever Yang <kever.yang@rock-chips.com mailto:kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org mailto:sjg@chromium.org>
Changes in v2: None
- SPDX-License-Identifier:GPL-2.0+
@@ -9,6 +9,8 @@ #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/pinctrl/rockchip.h> +#include <dt-bindings/power/rk3399-power.h> +#include <dt-bindings/thermal/thermal.h> #define USB_CLASS_HUB9 / { @@ -19,6 +21,15 @@ #size-cells = <2>; aliases { +i2c0 = &i2c0; +i2c1 = &i2c1; +i2c2 = &i2c2; +i2c3 = &i2c3; +i2c4 = &i2c4; +i2c5 = &i2c5; +i2c6 = &i2c6; +i2c7 = &i2c7; +i2c8 = &i2c8; serial0 = &uart0; serial1 = &uart1; serial2 = &uart2; @@ -26,7 +37,6 @@ serial4 = &uart4; mmc0 = &sdhci; mmc1 = &sdmmc; -i2c0 = &i2c0; }; cpus { @@ -110,6 +120,16 @@ }; }; +pmu_a53 { +compatible = "arm,cortex-a53-pmu"; +interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_LOW &ppi_cluster0>; +};
+pmu_a72 { +compatible = "arm,cortex-a72-pmu"; +interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_LOW &ppi_cluster1>; +};
psci { compatible = "arm,psci-1.0"; method = "smc"; @@ -117,10 +137,11 @@ timer { compatible = "arm,armv8-timer"; -interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>,
- <GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>,
- <GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>,
- <GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>;
+interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW 0>,
- <GIC_PPI 14 IRQ_TYPE_LEVEL_LOW 0>,
- <GIC_PPI 11 IRQ_TYPE_LEVEL_LOW 0>,
- <GIC_PPI 10 IRQ_TYPE_LEVEL_LOW 0>;
+arm,no-tick-in-suspend; }; xin24m: xin24m { @@ -139,8 +160,8 @@ dmac_bus: dma-controller@ff6d0000 { compatible = "arm,pl330", "arm,primecell"; reg = <0x0 0xff6d0000 0x0 0x4000>; -interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>,
- <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>;
+interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH 0>,
- <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH 0>;
#dma-cells = <1>; clocks = <&cru ACLK_DMAC0_PERILP>; clock-names = "apb_pclk"; @@ -149,24 +170,92 @@ dmac_peri: dma-controller@ff6e0000 { compatible = "arm,pl330", "arm,primecell"; reg = <0x0 0xff6e0000 0x0 0x4000>; -interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>,
- <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>;
+interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH 0>,
- <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH 0>;
#dma-cells = <1>; clocks = <&cru ACLK_DMAC1_PERILP>; clock-names = "apb_pclk"; }; }; +pcie0: pcie@f8000000 { +compatible = "rockchip,rk3399-pcie"; +reg = <0x0 0xf8000000 0x0 0x2000000>,
+reg-names = "axi-base", "apb-base"; +#address-cells = <3>; +#size-cells = <2>; +#interrupt-cells = <1>; +aspm-no-l0s; +bus-range = <0x0 0x1>; +clocks = <&cru ACLK_PCIE>, <&cru ACLK_PERF_PCIE>, +<&cru PCLK_PCIE>, <&cru SCLK_PCIE_PM>; +clock-names = "aclk", "aclk-perf",
"hclk", "pm";
+interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH 0>,
- <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH 0>,
- <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH 0>;
+interrupt-names = "sys", "legacy", "client"; +interrupt-map-mask = <0 0 0 7>; +interrupt-map = <0 0 0 1 &pcie0_intc 0>, +<0 0 0 2 &pcie0_intc 1>, +<0 0 0 3 &pcie0_intc 2>, +<0 0 0 4 &pcie0_intc 3>; +linux,pci-domain = <0>; +max-link-speed = <1>; +msi-map = <0x0 &its 0x0 0x1000>; +phys = <&pcie_phy>; +phy-names = "pcie-phy"; +ranges = <0x83000000 0x0 0xfa000000 0x0 0xfa000000 0x0 0x600000
- 0x81000000 0x0 0xfa600000 0x0 0xfa600000 0x0 0x100000>;
+resets = <&cru SRST_PCIE_CORE>, <&cru SRST_PCIE_MGMT>, +<&cru SRST_PCIE_MGMT_STICKY>, <&cru SRST_PCIE_PIPE>, +<&cru SRST_PCIE_PM>, <&cru SRST_P_PCIE>, +<&cru SRST_A_PCIE>; +reset-names = "core", "mgmt", "mgmt-sticky", "pipe",
+status = "disabled";
+pcie0_intc: interrupt-controller { +interrupt-controller; +#address-cells = <0>; +#interrupt-cells = <1>; +}; +};
+gmac: ethernet@fe300000 { +compatible = "rockchip,rk3399-gmac"; +reg = <0x0 0xfe300000 0x0 0x10000>; +interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH 0>; +interrupt-names = "macirq"; +clocks = <&cru SCLK_MAC>, <&cru SCLK_MAC_RX>, +<&cru SCLK_MAC_TX>, <&cru SCLK_MACREF>, +<&cru SCLK_MACREF_OUT>, <&cru ACLK_GMAC>, +<&cru PCLK_GMAC>; +clock-names = "stmmaceth", "mac_clk_rx",
"pclk_mac";
+power-domains = <&power RK3399_PD_GMAC>; +resets = <&cru SRST_A_GMAC>; +reset-names = "stmmaceth"; +rockchip,grf = <&grf>; +status = "disabled"; +};
sdio0: dwmmc@fe310000 { compatible = "rockchip,rk3399-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x0 0xfe310000 0x0 0x4000>; -interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>; -clock-freq-min-max = <400000 150000000>; +interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH 0>; +max-frequency = <150000000>; clocks = <&cru HCLK_SDIO>, <&cru SCLK_SDIO>, <&cru SCLK_SDIO_DRV>, <&cru SCLK_SDIO_SAMPLE>; clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; +power-domains = <&power RK3399_PD_SDIOAUDIO>; +resets = <&cru SRST_SDIO0>; +reset-names = "reset"; status = "disabled"; }; @@ -174,14 +263,15 @@ compatible = "rockchip,rk3399-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x0 0xfe320000 0x0 0x4000>; -interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; -clock-freq-min-max = <400000 150000000>; -clocks = <&cru SCLK_SDMMC>, <&cru HCLK_SDMMC>, +interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH 0>; +max-frequency = <150000000>; +clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; -clock-names = "ciu", "biu", "ciu-drive", "ciu-sample"; -pinctrl-names = "default"; -pinctrl-0 = <&sdmmc_clk>; +clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; +power-domains = <&power RK3399_PD_SD>; +resets = <&cru SRST_SDMMC>; +reset-names = "reset"; status = "disabled"; }; @@ -189,50 +279,74 @@ u-boot,dm-pre-reloc; compatible = "rockchip,rk3399-sdhci-5.1", "arasan,sdhci-5.1"; reg = <0x0 0xfe330000 0x0 0x10000>; -interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH 0>; +arasan,soc-ctl-syscon = <&grf>; assigned-clocks = <&cru SCLK_EMMC>; assigned-clock-rates = <200000000>; max-frequency = <200000000>; clocks = <&cru SCLK_EMMC>, <&cru ACLK_EMMC>; clock-names = "clk_xin", "clk_ahb"; +clock-output-names = "emmc_cardclock"; +#clock-cells = <0>; phys = <&emmc_phy>; phy-names = "phy_arasan"; +power-domains = <&power RK3399_PD_EMMC>; status = "disabled"; }; usb_host0_ehci: usb@fe380000 { compatible = "generic-ehci"; reg = <0x0 0xfe380000 0x0 0x20000>; -interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; -clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>; -clock-names = "hclk_host0", "hclk_host0_arb"; +interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH 0>; +clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>, +<&u2phy0>; +clock-names = "usbhost", "arbiter",
"utmi";
+phys = <&u2phy0_host>; +phy-names = "usb"; +power-domains = <&power RK3399_PD_PERIHP>; status = "disabled"; }; usb_host0_ohci: usb@fe3a0000 { compatible = "generic-ohci"; reg = <0x0 0xfe3a0000 0x0 0x20000>; -interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; -clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>; -clock-names = "hclk_host0", "hclk_host0_arb"; +interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH 0>; +clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>, +<&u2phy0>; +clock-names = "usbhost", "arbiter",
"utmi";
+phys = <&u2phy0_host>; +phy-names = "usb"; +power-domains = <&power RK3399_PD_PERIHP>; status = "disabled"; }; usb_host1_ehci: usb@fe3c0000 { compatible = "generic-ehci"; reg = <0x0 0xfe3c0000 0x0 0x20000>; -interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; -clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>; -clock-names = "hclk_host1", "hclk_host1_arb"; +interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH 0>; +clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>, +<&u2phy1>; +clock-names = "usbhost", "arbiter",
"utmi";
+phys = <&u2phy1_host>; +phy-names = "usb"; +power-domains = <&power RK3399_PD_PERIHP>; status = "disabled"; }; usb_host1_ohci: usb@fe3e0000 { compatible = "generic-ohci"; reg = <0x0 0xfe3e0000 0x0 0x20000>; -interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; -clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>; -clock-names = "hclk_host1", "hclk_host1_arb"; +interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH 0>; +clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>, +<&u2phy1>; +clock-names = "usbhost", "arbiter",
"utmi";
+phys = <&u2phy1_host>; +phy-names = "usb"; +power-domains = <&power RK3399_PD_PERIHP>; status = "disabled"; }; @@ -280,7 +394,7 @@ gic: interrupt-controller@fee00000 { compatible = "arm,gic-v3"; -#interrupt-cells = <3>; +#interrupt-cells = <4>; #address-cells = <2>; #size-cells = <2>; ranges; @@ -291,12 +405,124 @@ <0x0 0xfff00000 0 0x10000>, /* GICC */ <0x0 0xfff10000 0 0x10000>, /* GICH */ <0x0 0xfff20000 0 0x10000>; /* GICV */ -interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH 0>; its: interrupt-controller@fee20000 { compatible = "arm,gic-v3-its"; msi-controller; reg = <0x0 0xfee20000 0x0 0x20000>; };
+ppi-partitions { +ppi_cluster0: interrupt-partition-0 { +affinity = <&cpu_l0 &cpu_l1 &cpu_l2 &cpu_l3>; +};
+ppi_cluster1: interrupt-partition-1 { +affinity = <&cpu_b0 &cpu_b1>; +}; +}; +};
+saradc: saradc@ff100000 { +compatible = "rockchip,rk3399-saradc"; +reg = <0x0 0xff100000 0x0 0x100>; +interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH 0>; +#io-channel-cells = <1>; +clocks = <&cru SCLK_SARADC>, <&cru PCLK_SARADC>; +clock-names = "saradc", "apb_pclk"; +resets = <&cru SRST_P_SARADC>; +reset-names = "saradc-apb"; +status = "disabled"; +};
+i2c1: i2c@ff110000 { +compatible = "rockchip,rk3399-i2c"; +reg = <0x0 0xff110000 0x0 0x1000>; +assigned-clocks = <&cru SCLK_I2C1>; +assigned-clock-rates = <200000000>; +clocks = <&cru SCLK_I2C1>, <&cru PCLK_I2C1>; +clock-names = "i2c", "pclk"; +interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH 0>; +pinctrl-names = "default"; +pinctrl-0 = <&i2c1_xfer>; +#address-cells = <1>; +#size-cells = <0>; +status = "disabled"; +};
+i2c2: i2c@ff120000 { +compatible = "rockchip,rk3399-i2c"; +reg = <0x0 0xff120000 0x0 0x1000>; +assigned-clocks = <&cru SCLK_I2C2>; +assigned-clock-rates = <200000000>; +clocks = <&cru SCLK_I2C2>, <&cru PCLK_I2C2>; +clock-names = "i2c", "pclk"; +interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH 0>; +pinctrl-names = "default"; +pinctrl-0 = <&i2c2_xfer>; +#address-cells = <1>; +#size-cells = <0>; +status = "disabled"; +};
+i2c3: i2c@ff130000 { +compatible = "rockchip,rk3399-i2c"; +reg = <0x0 0xff130000 0x0 0x1000>; +assigned-clocks = <&cru SCLK_I2C3>; +assigned-clock-rates = <200000000>; +clocks = <&cru SCLK_I2C3>, <&cru PCLK_I2C3>; +clock-names = "i2c", "pclk"; +interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH 0>; +pinctrl-names = "default"; +pinctrl-0 = <&i2c3_xfer>; +#address-cells = <1>; +#size-cells = <0>; +status = "disabled"; +};
+i2c5: i2c@ff140000 { +compatible = "rockchip,rk3399-i2c"; +reg = <0x0 0xff140000 0x0 0x1000>; +assigned-clocks = <&cru SCLK_I2C5>; +assigned-clock-rates = <200000000>; +clocks = <&cru SCLK_I2C5>, <&cru PCLK_I2C5>; +clock-names = "i2c", "pclk"; +interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH 0>; +pinctrl-names = "default"; +pinctrl-0 = <&i2c5_xfer>; +#address-cells = <1>; +#size-cells = <0>; +status = "disabled"; +};
+i2c6: i2c@ff150000 { +compatible = "rockchip,rk3399-i2c"; +reg = <0x0 0xff150000 0x0 0x1000>; +assigned-clocks = <&cru SCLK_I2C6>; +assigned-clock-rates = <200000000>; +clocks = <&cru SCLK_I2C6>, <&cru PCLK_I2C6>; +clock-names = "i2c", "pclk"; +interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH 0>; +pinctrl-names = "default"; +pinctrl-0 = <&i2c6_xfer>; +#address-cells = <1>; +#size-cells = <0>; +status = "disabled"; +};
+i2c7: i2c@ff160000 { +compatible = "rockchip,rk3399-i2c"; +reg = <0x0 0xff160000 0x0 0x1000>; +assigned-clocks = <&cru SCLK_I2C7>; +assigned-clock-rates = <200000000>; +clocks = <&cru SCLK_I2C7>, <&cru PCLK_I2C7>; +clock-names = "i2c", "pclk"; +interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH 0>; +pinctrl-names = "default"; +pinctrl-0 = <&i2c7_xfer>; +#address-cells = <1>; +#size-cells = <0>; +status = "disabled"; }; uart0: serial@ff180000 { @@ -304,7 +530,7 @@ reg = <0x0 0xff180000 0x0 0x100>; clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; clock-names = "baudclk", "apb_pclk"; -interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH 0>; reg-shift = <2>; reg-io-width = <4>; pinctrl-names = "default"; @@ -317,7 +543,7 @@ reg = <0x0 0xff190000 0x0 0x100>; clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; clock-names = "baudclk", "apb_pclk"; -interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH 0>; reg-shift = <2>; reg-io-width = <4>; pinctrl-names = "default"; @@ -330,7 +556,7 @@ reg = <0x0 0xff1a0000 0x0 0x100>; clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; clock-names = "baudclk", "apb_pclk"; -interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH 0>; clock-frequency = <24000000>; reg-shift = <2>; reg-io-width = <4>; @@ -344,7 +570,7 @@ reg = <0x0 0xff1b0000 0x0 0x100>; clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; clock-names = "baudclk", "apb_pclk"; -interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH 0>; reg-shift = <2>; reg-io-width = <4>; pinctrl-names = "default"; @@ -357,7 +583,7 @@ reg = <0x0 0xff1c0000 0x0 0x1000>; clocks = <&cru SCLK_SPI0>, <&cru PCLK_SPI0>; clock-names = "spiclk", "apb_pclk"; -interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH 0>; pinctrl-names = "default"; pinctrl-0 = <&spi0_clk &spi0_tx &spi0_rx &spi0_cs0>; #address-cells = <1>; @@ -370,7 +596,7 @@ reg = <0x0 0xff1d0000 0x0 0x1000>; clocks = <&cru SCLK_SPI1>, <&cru PCLK_SPI1>; clock-names = "spiclk", "apb_pclk"; -interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH 0>; pinctrl-names = "default"; pinctrl-0 = <&spi1_clk &spi1_tx &spi1_rx &spi1_cs0>; #address-cells = <1>; @@ -383,7 +609,7 @@ reg = <0x0 0xff1e0000 0x0 0x1000>; clocks = <&cru SCLK_SPI2>, <&cru PCLK_SPI2>; clock-names = "spiclk", "apb_pclk"; -interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH 0>; pinctrl-names = "default"; pinctrl-0 = <&spi2_clk &spi2_tx &spi2_rx &spi2_cs0>; #address-cells = <1>; @@ -396,7 +622,7 @@ reg = <0x0 0xff1f0000 0x0 0x1000>; clocks = <&cru SCLK_SPI4>, <&cru PCLK_SPI4>; clock-names = "spiclk", "apb_pclk"; -interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH 0>; pinctrl-names = "default"; pinctrl-0 = <&spi4_clk &spi4_tx &spi4_rx &spi4_cs0>; #address-cells = <1>; @@ -409,7 +635,7 @@ reg = <0x0 0xff200000 0x0 0x1000>; clocks = <&cru SCLK_SPI5>, <&cru PCLK_SPI5>; clock-names = "spiclk", "apb_pclk"; -interrupts = <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH 0>; pinctrl-names = "default"; pinctrl-0 = <&spi5_clk &spi5_tx &spi5_rx &spi5_cs0>; #address-cells = <1>; @@ -417,6 +643,375 @@ status = "disabled"; }; +thermal_zones: thermal-zones { +cpu_thermal: cpu { +polling-delay-passive = <100>; +polling-delay = <1000>;
+thermal-sensors = <&tsadc 0>;
+trips { +cpu_alert0: cpu_alert0 { +temperature = <70000>; +hysteresis = <2000>; +type = "passive"; +}; +cpu_alert1: cpu_alert1 { +temperature = <75000>; +hysteresis = <2000>; +type = "passive"; +}; +cpu_crit: cpu_crit { +temperature = <95000>; +hysteresis = <2000>; +type = "critical"; +}; +};
+cooling-maps { +map0 { +trip = <&cpu_alert0>; +cooling-device = +<&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; +}; +map1 { +trip = <&cpu_alert1>; +cooling-device = +<&cpu_l0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, +<&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; +}; +}; +};
+gpu_thermal: gpu { +polling-delay-passive = <100>; +polling-delay = <1000>;
+thermal-sensors = <&tsadc 1>;
+trips { +gpu_alert0: gpu_alert0 { +temperature = <75000>; +hysteresis = <2000>; +type = "passive"; +}; +gpu_crit: gpu_crit { +temperature = <95000>; +hysteresis = <2000>; +type = "critical"; +}; +};
+cooling-maps { +map0 { +trip = <&gpu_alert0>; +cooling-device = +<&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; +}; +}; +}; +};
+tsadc: tsadc@ff260000 { +compatible = "rockchip,rk3399-tsadc"; +reg = <0x0 0xff260000 0x0 0x100>; +interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH 0>; +assigned-clocks = <&cru SCLK_TSADC>; +assigned-clock-rates = <750000>; +clocks = <&cru SCLK_TSADC>, <&cru PCLK_TSADC>; +clock-names = "tsadc", "apb_pclk"; +resets = <&cru SRST_TSADC>; +reset-names = "tsadc-apb"; +rockchip,grf = <&grf>; +rockchip,hw-tshut-temp = <95000>; +pinctrl-names = "init", "default", "sleep"; +pinctrl-0 = <&otp_gpio>; +pinctrl-1 = <&otp_out>; +pinctrl-2 = <&otp_gpio>; +#thermal-sensor-cells = <1>; +status = "disabled"; +};
+qos_emmc: qos@ffa58000 { +compatible = "syscon"; +reg = <0x0 0xffa58000 0x0 0x20>; +};
+qos_gmac: qos@ffa5c000 { +compatible = "syscon"; +reg = <0x0 0xffa5c000 0x0 0x20>; +};
+qos_pcie: qos@ffa60080 { +compatible = "syscon"; +reg = <0x0 0xffa60080 0x0 0x20>; +};
+qos_usb_host0: qos@ffa60100 { +compatible = "syscon"; +reg = <0x0 0xffa60100 0x0 0x20>; +};
+qos_usb_host1: qos@ffa60180 { +compatible = "syscon"; +reg = <0x0 0xffa60180 0x0 0x20>; +};
+qos_usb_otg0: qos@ffa70000 { +compatible = "syscon"; +reg = <0x0 0xffa70000 0x0 0x20>; +};
+qos_usb_otg1: qos@ffa70080 { +compatible = "syscon"; +reg = <0x0 0xffa70080 0x0 0x20>; +};
+qos_sd: qos@ffa74000 { +compatible = "syscon"; +reg = <0x0 0xffa74000 0x0 0x20>; +};
+qos_sdioaudio: qos@ffa76000 { +compatible = "syscon"; +reg = <0x0 0xffa76000 0x0 0x20>; +};
+qos_hdcp: qos@ffa90000 { +compatible = "syscon"; +reg = <0x0 0xffa90000 0x0 0x20>; +};
+qos_iep: qos@ffa98000 { +compatible = "syscon"; +reg = <0x0 0xffa98000 0x0 0x20>; +};
+qos_isp0_m0: qos@ffaa0000 { +compatible = "syscon"; +reg = <0x0 0xffaa0000 0x0 0x20>; +};
+qos_isp0_m1: qos@ffaa0080 { +compatible = "syscon"; +reg = <0x0 0xffaa0080 0x0 0x20>; +};
+qos_isp1_m0: qos@ffaa8000 { +compatible = "syscon"; +reg = <0x0 0xffaa8000 0x0 0x20>; +};
+qos_isp1_m1: qos@ffaa8080 { +compatible = "syscon"; +reg = <0x0 0xffaa8080 0x0 0x20>; +};
+qos_rga_r: qos@ffab0000 { +compatible = "syscon"; +reg = <0x0 0xffab0000 0x0 0x20>; +};
+qos_rga_w: qos@ffab0080 { +compatible = "syscon"; +reg = <0x0 0xffab0080 0x0 0x20>; +};
+qos_video_m0: qos@ffab8000 { +compatible = "syscon"; +reg = <0x0 0xffab8000 0x0 0x20>; +};
+qos_video_m1_r: qos@ffac0000 { +compatible = "syscon"; +reg = <0x0 0xffac0000 0x0 0x20>; +};
+qos_video_m1_w: qos@ffac0080 { +compatible = "syscon"; +reg = <0x0 0xffac0080 0x0 0x20>; +};
+qos_vop_big_r: qos@ffac8000 { +compatible = "syscon"; +reg = <0x0 0xffac8000 0x0 0x20>; +};
+qos_vop_big_w: qos@ffac8080 { +compatible = "syscon"; +reg = <0x0 0xffac8080 0x0 0x20>; +};
+qos_vop_little: qos@ffad0000 { +compatible = "syscon"; +reg = <0x0 0xffad0000 0x0 0x20>; +};
+qos_perihp: qos@ffad8080 { +compatible = "syscon"; +reg = <0x0 0xffad8080 0x0 0x20>; +};
+qos_gpu: qos@ffae0000 { +compatible = "syscon"; +reg = <0x0 0xffae0000 0x0 0x20>; +};
+pmu: power-management@ff310000 { +compatible = "rockchip,rk3399-pmu", "syscon", "simple-mfd"; +reg = <0x0 0xff310000 0x0 0x1000>;
+/* +* Note: RK3399 supports 6 voltage domains including VD_CORE_L, +* VD_CORE_B, VD_CENTER, VD_GPU, VD_LOGIC and VD_PMU. +* Some of the power domains are grouped together for every +* voltage domain. +* The detail contents as below. +*/ +power: power-controller { +compatible = "rockchip,rk3399-power-controller"; +#power-domain-cells = <1>; +#address-cells = <1>; +#size-cells = <0>;
+/* These power domains are grouped by VD_CENTER */ +pd_iep@RK3399_PD_IEP { +reg = <RK3399_PD_IEP>; +clocks = <&cru ACLK_IEP>, +<&cru HCLK_IEP>; +pm_qos = <&qos_iep>; +}; +pd_rga@RK3399_PD_RGA { +reg = <RK3399_PD_RGA>; +clocks = <&cru ACLK_RGA>, +<&cru HCLK_RGA>; +pm_qos = <&qos_rga_r>, +<&qos_rga_w>; +}; +pd_vcodec@RK3399_PD_VCODEC { +reg = <RK3399_PD_VCODEC>; +clocks = <&cru ACLK_VCODEC>, +<&cru HCLK_VCODEC>; +pm_qos = <&qos_video_m0>; +}; +pd_vdu@RK3399_PD_VDU { +reg = <RK3399_PD_VDU>; +clocks = <&cru ACLK_VDU>, +<&cru HCLK_VDU>; +pm_qos = <&qos_video_m1_r>, +<&qos_video_m1_w>; +};
+/* These power domains are grouped by VD_GPU */ +pd_gpu@RK3399_PD_GPU { +reg = <RK3399_PD_GPU>; +clocks = <&cru ACLK_GPU>; +pm_qos = <&qos_gpu>; +};
+/* These power domains are grouped by VD_LOGIC */ +pd_edp@RK3399_PD_EDP { +reg = <RK3399_PD_EDP>; +clocks = <&cru PCLK_EDP_CTRL>; +}; +pd_emmc@RK3399_PD_EMMC { +reg = <RK3399_PD_EMMC>; +clocks = <&cru ACLK_EMMC>; +pm_qos = <&qos_emmc>; +}; +pd_gmac@RK3399_PD_GMAC { +reg = <RK3399_PD_GMAC>; +clocks = <&cru ACLK_GMAC>, +<&cru PCLK_GMAC>; +pm_qos = <&qos_gmac>; +}; +pd_perihp@RK3399_PD_PERIHP { +reg = <RK3399_PD_PERIHP>; +#address-cells = <1>; +#size-cells = <0>; +clocks = <&cru ACLK_PERIHP>; +pm_qos = <&qos_perihp>, +<&qos_pcie>, +<&qos_usb_host0>, +<&qos_usb_host1>;
+pd_sd@RK3399_PD_SD { +reg = <RK3399_PD_SD>; +clocks = <&cru HCLK_SDMMC>, +<&cru SCLK_SDMMC>; +pm_qos = <&qos_sd>; +}; +}; +pd_sdioaudio@RK3399_PD_SDIOAUDIO { +reg = <RK3399_PD_SDIOAUDIO>; +clocks = <&cru HCLK_SDIO>; +pm_qos = <&qos_sdioaudio>; +}; +pd_usb3@RK3399_PD_USB3 { +reg = <RK3399_PD_USB3>; +clocks = <&cru ACLK_USB3>; +pm_qos = <&qos_usb_otg0>, +<&qos_usb_otg1>; +}; +pd_vio@RK3399_PD_VIO { +reg = <RK3399_PD_VIO>; +#address-cells = <1>; +#size-cells = <0>;
+pd_hdcp@RK3399_PD_HDCP { +reg = <RK3399_PD_HDCP>; +clocks = <&cru ACLK_HDCP>, +<&cru HCLK_HDCP>, +<&cru PCLK_HDCP>; +pm_qos = <&qos_hdcp>; +}; +pd_isp0@RK3399_PD_ISP0 { +reg = <RK3399_PD_ISP0>; +clocks = <&cru ACLK_ISP0>, +<&cru HCLK_ISP0>; +pm_qos = <&qos_isp0_m0>, +<&qos_isp0_m1>; +}; +pd_isp1@RK3399_PD_ISP1 { +reg = <RK3399_PD_ISP1>; +clocks = <&cru ACLK_ISP1>, +<&cru HCLK_ISP1>; +pm_qos = <&qos_isp1_m0>, +<&qos_isp1_m1>; +}; +pd_tcpc0@RK3399_PD_TCPC0 { +reg = <RK3399_PD_TCPD0>; +clocks = <&cru SCLK_UPHY0_TCPDCORE>, +<&cru SCLK_UPHY0_TCPDPHY_REF>; +}; +pd_tcpc1@RK3399_PD_TCPC1 { +reg = <RK3399_PD_TCPD1>; +clocks = <&cru SCLK_UPHY1_TCPDCORE>, +<&cru SCLK_UPHY1_TCPDPHY_REF>; +}; +pd_vo@RK3399_PD_VO { +reg = <RK3399_PD_VO>; +#address-cells = <1>; +#size-cells = <0>;
+pd_vopb@RK3399_PD_VOPB { +reg = <RK3399_PD_VOPB>; +clocks = <&cru ACLK_VOP0>, +<&cru HCLK_VOP0>; +pm_qos = <&qos_vop_big_r>, +<&qos_vop_big_w>; +}; +pd_vopl@RK3399_PD_VOPL { +reg = <RK3399_PD_VOPL>; +clocks = <&cru ACLK_VOP1>, +<&cru HCLK_VOP1>; +pm_qos = <&qos_vop_little>; +}; +}; +}; +}; +};
pmugrf: syscon@ff320000 { u-boot,dm-pre-reloc; compatible = "rockchip,rk3399-pmugrf", "syscon", "simple-mfd"; @@ -441,7 +1036,7 @@ reg = <0x0 0xff350000 0x0 0x1000>; clocks = <&pmucru SCLK_SPI3_PMU>, <&pmucru PCLK_SPI3_PMU>; clock-names = "spiclk", "apb_pclk"; -interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH 0>; pinctrl-names = "default"; pinctrl-0 = <&spi3_clk &spi3_tx &spi3_rx &spi3_cs0>; #address-cells = <1>; @@ -454,7 +1049,7 @@ reg = <0x0 0xff370000 0x0 0x100>; clocks = <&pmucru SCLK_UART4_PMU>, <&pmucru PCLK_UART4_PMU>; clock-names = "baudclk", "apb_pclk"; -interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH 0>; reg-shift = <2>; reg-io-width = <4>; pinctrl-names = "default"; @@ -477,6 +1072,36 @@ status = "disabled"; }; +i2c4: i2c@ff3d0000 { +compatible = "rockchip,rk3399-i2c"; +reg = <0x0 0xff3d0000 0x0 0x1000>; +assigned-clocks = <&pmucru SCLK_I2C4_PMU>; +assigned-clock-rates = <200000000>; +clocks = <&pmucru SCLK_I2C4_PMU>, <&pmucru PCLK_I2C4_PMU>; +clock-names = "i2c", "pclk"; +interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH 0>; +pinctrl-names = "default"; +pinctrl-0 = <&i2c4_xfer>; +#address-cells = <1>; +#size-cells = <0>; +status = "disabled"; +};
+i2c8: i2c@ff3e0000 { +compatible = "rockchip,rk3399-i2c"; +reg = <0x0 0xff3e0000 0x0 0x1000>; +assigned-clocks = <&pmucru SCLK_I2C8_PMU>; +assigned-clock-rates = <200000000>; +clocks = <&pmucru SCLK_I2C8_PMU>, <&pmucru PCLK_I2C8_PMU>; +clock-names = "i2c", "pclk"; +interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH 0>; +pinctrl-names = "default"; +pinctrl-0 = <&i2c8_xfer>; +#address-cells = <1>; +#size-cells = <0>; +status = "disabled"; +};
pwm0: pwm@ff420000 { compatible = "rockchip,rk3399-pwm", "rockchip,rk3288-pwm"; reg = <0x0 0xff420000 0x0 0x10>; @@ -553,10 +1178,43 @@ 0x0 0xffa8c000 0x0 0x1000>; }; +efuse0: efuse@ff690000 { +compatible = "rockchip,rk3399-efuse"; +reg = <0x0 0xff690000 0x0 0x80>; +#address-cells = <1>; +#size-cells = <1>; +clocks = <&cru PCLK_EFUSE1024NS>; +clock-names = "pclk_efuse";
+/* Data cells */ +cpu_id: cpu-id@7 { +reg = <0x07 0x10>; +}; +cpub_leakage: cpu-leakage@17 { +reg = <0x17 0x1>; +}; +gpu_leakage: gpu-leakage@18 { +reg = <0x18 0x1>; +}; +center_leakage: center-leakage@19 { +reg = <0x19 0x1>; +}; +cpul_leakage: cpu-leakage@1a { +reg = <0x1a 0x1>; +}; +logic_leakage: logic-leakage@1b { +reg = <0x1b 0x1>; +}; +wafer_info: wafer-info@1c { +reg = <0x1c 0x1>; +}; +};
pmucru: pmu-clock-controller@ff750000 { u-boot,dm-pre-reloc; compatible = "rockchip,rk3399-pmucru"; reg = <0x0 0xff750000 0x0 0x1000>; +rockchip,grf = <&pmugrf>; #clock-cells = <1>; #reset-cells = <1>; assigned-clocks = <&pmucru PLL_PPLL>; @@ -567,6 +1225,7 @@ u-boot,dm-pre-reloc; compatible = "rockchip,rk3399-cru"; reg = <0x0 0xff760000 0x0 0x1000>; +rockchip,grf = <&grf>; #clock-cells = <1>; #reset-cells = <1>; assigned-clocks = @@ -575,7 +1234,7 @@ <&cru ACLK_PERIHP>, <&cru HCLK_PERIHP>, <&cru PCLK_PERIHP>, <&cru ACLK_PERILP0>, <&cru HCLK_PERILP0>, -<&cru PCLK_PERILP0>, +<&cru PCLK_PERILP0>, <&cru ACLK_CCI>, <&cru HCLK_PERILP1>, <&cru PCLK_PERILP1>; assigned-clock-rates = <594000000>, <800000000>, @@ -583,7 +1242,7 @@ <150000000>, <75000000>, <37500000>, <100000000>, <100000000>,
- <50000000>,
- <50000000>, <600000000>,
<100000000>, <50000000>; }; @@ -599,50 +1258,106 @@ status = "disabled"; }; +u2phy0: usb2-phy@e450 { +compatible = "rockchip,rk3399-usb2phy"; +reg = <0xe450 0x10>; +clocks = <&cru SCLK_USB2PHY0_REF>; +clock-names = "phyclk"; +#clock-cells = <0>; +clock-output-names = "clk_usbphy0_480m"; +status = "disabled";
+u2phy0_host: host-port { +#phy-cells = <0>; +interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH 0>; +interrupt-names = "linestate"; +status = "disabled"; +};
+u2phy0_otg: otg-port { +#phy-cells = <0>; +interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH 0>,
- <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH 0>,
- <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH 0>;
+interrupt-names = "otg-bvalid", "otg-id",
- "linestate";
+status = "disabled"; +}; +};
+u2phy1: usb2-phy@e460 { +compatible = "rockchip,rk3399-usb2phy"; +reg = <0xe460 0x10>; +clocks = <&cru SCLK_USB2PHY1_REF>; +clock-names = "phyclk"; +#clock-cells = <0>; +clock-output-names = "clk_usbphy1_480m"; +status = "disabled";
+u2phy1_host: host-port { +#phy-cells = <0>; +interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH 0>; +interrupt-names = "linestate"; +status = "disabled"; +};
+u2phy1_otg: otg-port { +#phy-cells = <0>; +interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH 0>,
- <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH 0>,
- <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH 0>;
- "linestate";
emmc_phy: phy@f780 { compatible = "rockchip,rk3399-emmc-phy"; reg = <0xf780 0x24>; +clocks = <&sdhci>; +clock-names = "emmcclk"; #phy-cells = <0>; status = "disabled"; };
+pcie_phy: pcie-phy { +compatible = "rockchip,rk3399-pcie-phy"; +clocks = <&cru SCLK_PCIEPHY_REF>; +clock-names = "refclk"; +#phy-cells = <0>; +resets = <&cru SRST_PCIEPHY>; +reset-names = "phy"; +status = "disabled"; +}; }; -watchdog@ff840000 { +watchdog@ff848000 { compatible = "snps,dw-wdt"; -reg = <0x0 0xff840000 0x0 0x100>; +reg = <0x0 0xff848000 0x0 0x100>; clocks = <&cru PCLK_WDT>; -interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; -};
<&cru PCLK_GMAC>;
"pclk_mac";
+interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH 0>; +};
+rktimer: rktimer@ff850000 { +compatible = "rockchip,rk3399-timer"; +reg = <0x0 0xff850000 0x0 0x1000>; +interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH 0>; +clocks = <&cru PCLK_TIMER0>, <&cru SCLK_TIMER00>; +clock-names = "pclk", "timer"; +}; spdif: spdif@ff870000 { compatible = "rockchip,rk3399-spdif"; reg = <0x0 0xff870000 0x0 0x1000>; -interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH 0>; dmas = <&dmac_bus 7>; dma-names = "tx"; clock-names = "mclk", "hclk"; clocks = <&cru SCLK_SPDIF_8CH>, <&cru HCLK_SPDIF>; pinctrl-names = "default"; pinctrl-0 = <&spdif_bus>; +power-domains = <&power RK3399_PD_SDIOAUDIO>; status = "disabled"; }; @@ -650,37 +1365,40 @@ compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s"; reg = <0x0 0xff880000 0x0 0x1000>; rockchip,grf = <&grf>; -interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH 0>; dmas = <&dmac_bus 0>, <&dmac_bus 1>; dma-names = "tx", "rx"; clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S0_8CH>, <&cru HCLK_I2S0_8CH>; pinctrl-names = "default"; pinctrl-0 = <&i2s0_8ch_bus>; +power-domains = <&power RK3399_PD_SDIOAUDIO>; status = "disabled"; }; i2s1: i2s@ff890000 { compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s"; reg = <0x0 0xff890000 0x0 0x1000>; -interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH 0>; dmas = <&dmac_bus 2>, <&dmac_bus 3>; dma-names = "tx", "rx"; clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S1_8CH>, <&cru HCLK_I2S1_8CH>; pinctrl-names = "default"; pinctrl-0 = <&i2s1_2ch_bus>; +power-domains = <&power RK3399_PD_SDIOAUDIO>; status = "disabled"; }; i2s2: i2s@ff8a0000 { compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s"; reg = <0x0 0xff8a0000 0x0 0x1000>; -interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH 0>; dmas = <&dmac_bus 4>, <&dmac_bus 5>; dma-names = "tx", "rx"; clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S2_8CH>, <&cru HCLK_I2S2_8CH>; +power-domains = <&power RK3399_PD_SDIOAUDIO>; status = "disabled"; }; @@ -697,7 +1415,7 @@ compatible = "rockchip,gpio-bank"; reg = <0x0 0xff720000 0x0 0x100>; clocks = <&pmucru PCLK_GPIO0_PMU>; -interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH 0>; gpio-controller; #gpio-cells = <0x2>; @@ -710,7 +1428,7 @@ compatible = "rockchip,gpio-bank"; reg = <0x0 0xff730000 0x0 0x100>; clocks = <&pmucru PCLK_GPIO1_PMU>; -interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH 0>; gpio-controller; #gpio-cells = <0x2>; @@ -723,7 +1441,7 @@ compatible = "rockchip,gpio-bank"; reg = <0x0 0xff780000 0x0 0x100>; clocks = <&cru PCLK_GPIO2>; -interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH 0>; gpio-controller; #gpio-cells = <0x2>; @@ -736,7 +1454,7 @@ compatible = "rockchip,gpio-bank"; reg = <0x0 0xff788000 0x0 0x100>; clocks = <&cru PCLK_GPIO3>; -interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH 0>; gpio-controller; #gpio-cells = <0x2>; @@ -749,7 +1467,7 @@ compatible = "rockchip,gpio-bank"; reg = <0x0 0xff790000 0x0 0x100>; clocks = <&cru PCLK_GPIO4>; -interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>; +interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH 0>; gpio-controller; #gpio-cells = <0x2>; @@ -800,427 +1518,575 @@ drive-strength = <13>; }; +clock { +clk_32k: clk-32k { +rockchip,pins = <0 RK_PA0 RK_FUNC_2 &pcfg_pull_none>; +}; +};
+edp { +edp_hpd: edp-hpd { +rockchip,pins = +<4 RK_PC7 RK_FUNC_2 &pcfg_pull_none>; +}; +};
+gmac { +rgmii_pins: rgmii-pins { +rockchip,pins = +/* mac_txclk */ +<3 RK_PC1 RK_FUNC_1 &pcfg_pull_none_13ma>, +/* mac_rxclk */ +<3 RK_PB6 RK_FUNC_1 &pcfg_pull_none>, +/* mac_mdio */ +<3 RK_PB5 RK_FUNC_1 &pcfg_pull_none>, +/* mac_txen */ +<3 RK_PB4 RK_FUNC_1 &pcfg_pull_none_13ma>, +/* mac_clk */ +<3 RK_PB3 RK_FUNC_1 &pcfg_pull_none>, +/* mac_rxdv */ +<3 RK_PB1 RK_FUNC_1 &pcfg_pull_none>, +/* mac_mdc */ +<3 RK_PB0 RK_FUNC_1 &pcfg_pull_none>, +/* mac_rxd1 */ +<3 RK_PA7 RK_FUNC_1 &pcfg_pull_none>, +/* mac_rxd0 */ +<3 RK_PA6 RK_FUNC_1 &pcfg_pull_none>, +/* mac_txd1 */ +<3 RK_PA5 RK_FUNC_1 &pcfg_pull_none_13ma>, +/* mac_txd0 */ +<3 RK_PA4 RK_FUNC_1 &pcfg_pull_none_13ma>, +/* mac_rxd3 */ +<3 RK_PA3 RK_FUNC_1 &pcfg_pull_none>, +/* mac_rxd2 */ +<3 RK_PA2 RK_FUNC_1 &pcfg_pull_none>, +/* mac_txd3 */ +<3 RK_PA1 RK_FUNC_1 &pcfg_pull_none_13ma>, +/* mac_txd2 */ +<3 RK_PA0 RK_FUNC_1 &pcfg_pull_none_13ma>; +};
+rmii_pins: rmii-pins { +rockchip,pins = +/* mac_mdio */ +<3 RK_PB5 RK_FUNC_1 &pcfg_pull_none>, +/* mac_txen */ +<3 RK_PB4 RK_FUNC_1 &pcfg_pull_none_13ma>, +/* mac_clk */ +<3 RK_PB3 RK_FUNC_1 &pcfg_pull_none>, +/* mac_rxer */ +<3 RK_PB2 RK_FUNC_1 &pcfg_pull_none>, +/* mac_rxdv */ +<3 RK_PB1 RK_FUNC_1 &pcfg_pull_none>, +/* mac_mdc */ +<3 RK_PB0 RK_FUNC_1 &pcfg_pull_none>, +/* mac_rxd1 */ +<3 RK_PA7 RK_FUNC_1 &pcfg_pull_none>, +/* mac_rxd0 */ +<3 RK_PA6 RK_FUNC_1 &pcfg_pull_none>, +/* mac_txd1 */ +<3 RK_PA5 RK_FUNC_1 &pcfg_pull_none_13ma>, +/* mac_txd0 */ +<3 RK_PA4 RK_FUNC_1 &pcfg_pull_none_13ma>; +}; +};
i2c0 { i2c0_xfer: i2c0-xfer { rockchip,pins = -<1 15 RK_FUNC_2 &pcfg_pull_none>, -<1 16 RK_FUNC_2 &pcfg_pull_none>; +<1 RK_PB7 RK_FUNC_2 &pcfg_pull_none>, +<1 RK_PC0 RK_FUNC_2 &pcfg_pull_none>; }; }; i2c1 { i2c1_xfer: i2c1-xfer { rockchip,pins = -<4 2 RK_FUNC_1 &pcfg_pull_none>, -<4 1 RK_FUNC_1 &pcfg_pull_none>; +<4 RK_PA2 RK_FUNC_1 &pcfg_pull_none>, +<4 RK_PA1 RK_FUNC_1 &pcfg_pull_none>; }; }; i2c2 { i2c2_xfer: i2c2-xfer { rockchip,pins = -<2 1 RK_FUNC_2 &pcfg_pull_none_12ma>, -<2 0 RK_FUNC_2 &pcfg_pull_none_12ma>; +<2 RK_PA1 RK_FUNC_2 &pcfg_pull_none_12ma>, +<2 RK_PA0 RK_FUNC_2 &pcfg_pull_none_12ma>; }; }; i2c3 { i2c3_xfer: i2c3-xfer { rockchip,pins = -<4 17 RK_FUNC_1 &pcfg_pull_none>, -<4 16 RK_FUNC_1 &pcfg_pull_none>; +<4 RK_PC1 RK_FUNC_1 &pcfg_pull_none>, +<4 RK_PC0 RK_FUNC_1 &pcfg_pull_none>; }; }; i2c4 { i2c4_xfer: i2c4-xfer { rockchip,pins = -<1 12 RK_FUNC_1 &pcfg_pull_none>, -<1 11 RK_FUNC_1 &pcfg_pull_none>; +<1 RK_PB4 RK_FUNC_1 &pcfg_pull_none>, +<1 RK_PB3 RK_FUNC_1 &pcfg_pull_none>; }; }; i2c5 { i2c5_xfer: i2c5-xfer { rockchip,pins = -<3 11 RK_FUNC_2 &pcfg_pull_none>, -<3 10 RK_FUNC_2 &pcfg_pull_none>; +<3 RK_PB3 RK_FUNC_2 &pcfg_pull_none>, +<3 RK_PB2 RK_FUNC_2 &pcfg_pull_none>; }; }; i2c6 { i2c6_xfer: i2c6-xfer { rockchip,pins = -<2 10 RK_FUNC_2 &pcfg_pull_none>, -<2 9 RK_FUNC_2 &pcfg_pull_none>; +<2 RK_PB2 RK_FUNC_2 &pcfg_pull_none>, +<2 RK_PB1 RK_FUNC_2 &pcfg_pull_none>; }; }; i2c7 { i2c7_xfer: i2c7-xfer { rockchip,pins = -<2 8 RK_FUNC_2 &pcfg_pull_none>, -<2 7 RK_FUNC_2 &pcfg_pull_none>; +<2 RK_PB0 RK_FUNC_2 &pcfg_pull_none>, +<2 RK_PA7 RK_FUNC_2 &pcfg_pull_none>; }; }; i2c8 { i2c8_xfer: i2c8-xfer { rockchip,pins = -<1 21 RK_FUNC_1 &pcfg_pull_none>, -<1 20 RK_FUNC_1 &pcfg_pull_none>; +<1 RK_PC5 RK_FUNC_1 &pcfg_pull_none>, +<1 RK_PC4 RK_FUNC_1 &pcfg_pull_none>; }; }; i2s0 { i2s0_8ch_bus: i2s0-8ch-bus { rockchip,pins = -<3 24 RK_FUNC_1 &pcfg_pull_none>, -<3 25 RK_FUNC_1 &pcfg_pull_none>, -<3 26 RK_FUNC_1 &pcfg_pull_none>, -<3 27 RK_FUNC_1 &pcfg_pull_none>, -<3 28 RK_FUNC_1 &pcfg_pull_none>, -<3 29 RK_FUNC_1 &pcfg_pull_none>, -<3 30 RK_FUNC_1 &pcfg_pull_none>, -<3 31 RK_FUNC_1 &pcfg_pull_none>, -<4 0 RK_FUNC_1 &pcfg_pull_none>; +<3 RK_PD0 RK_FUNC_1 &pcfg_pull_none>, +<3 RK_PD1 RK_FUNC_1 &pcfg_pull_none>, +<3 RK_PD2 RK_FUNC_1 &pcfg_pull_none>, +<3 RK_PD3 RK_FUNC_1 &pcfg_pull_none>, +<3 RK_PD4 RK_FUNC_1 &pcfg_pull_none>, +<3 RK_PD5 RK_FUNC_1 &pcfg_pull_none>, +<3 RK_PD6 RK_FUNC_1 &pcfg_pull_none>, +<3 RK_PD7 RK_FUNC_1 &pcfg_pull_none>, +<4 RK_PA0 RK_FUNC_1 &pcfg_pull_none>; }; }; i2s1 { i2s1_2ch_bus: i2s1-2ch-bus { rockchip,pins = -<4 3 RK_FUNC_1 &pcfg_pull_none>, -<4 4 RK_FUNC_1 &pcfg_pull_none>, -<4 5 RK_FUNC_1 &pcfg_pull_none>, -<4 6 RK_FUNC_1 &pcfg_pull_none>, -<4 7 RK_FUNC_1 &pcfg_pull_none>; +<4 RK_PA3 RK_FUNC_1 &pcfg_pull_none>, +<4 RK_PA4 RK_FUNC_1 &pcfg_pull_none>, +<4 RK_PA5 RK_FUNC_1 &pcfg_pull_none>, +<4 RK_PA6 RK_FUNC_1 &pcfg_pull_none>, +<4 RK_PA7 RK_FUNC_1 &pcfg_pull_none>; }; }; -gmac { -rgmii_pins: rgmii-pins { +sdio0 { +sdio0_bus1: sdio0-bus1 { rockchip,pins = -/* mac_txclk */ -<3 17 RK_FUNC_1 &pcfg_pull_none_13ma>, -/* mac_rxclk */ -<3 14 RK_FUNC_1 &pcfg_pull_none>, -/* mac_mdio */ -<3 13 RK_FUNC_1 &pcfg_pull_none>, -/* mac_txen */ -<3 12 RK_FUNC_1 &pcfg_pull_none_13ma>, -/* mac_clk */ -<3 11 RK_FUNC_1 &pcfg_pull_none>, -/* mac_rxdv */ -<3 9 RK_FUNC_1 &pcfg_pull_none>, -/* mac_mdc */ -<3 8 RK_FUNC_1 &pcfg_pull_none>, -/* mac_rxd1 */ -<3 7 RK_FUNC_1 &pcfg_pull_none>, -/* mac_rxd0 */ -<3 6 RK_FUNC_1 &pcfg_pull_none>, -/* mac_txd1 */ -<3 5 RK_FUNC_1 &pcfg_pull_none_13ma>, -/* mac_txd0 */ -<3 4 RK_FUNC_1 &pcfg_pull_none_13ma>, -/* mac_rxd3 */ -<3 3 RK_FUNC_1 &pcfg_pull_none>, -/* mac_rxd2 */ -<3 2 RK_FUNC_1 &pcfg_pull_none>, -/* mac_txd3 */ -<3 1 RK_FUNC_1 &pcfg_pull_none_13ma>, -/* mac_txd2 */ -<3 0 RK_FUNC_1 &pcfg_pull_none_13ma>; +<2 RK_PC4 RK_FUNC_1 &pcfg_pull_up>; +};
+sdio0_bus4: sdio0-bus4 { +rockchip,pins = +<2 RK_PC4 RK_FUNC_1 &pcfg_pull_up>, +<2 RK_PC5 RK_FUNC_1 &pcfg_pull_up>, +<2 RK_PC6 RK_FUNC_1 &pcfg_pull_up>, +<2 RK_PC7 RK_FUNC_1 &pcfg_pull_up>; +};
+sdio0_cmd: sdio0-cmd { +rockchip,pins = +<2 RK_PD0 RK_FUNC_1 &pcfg_pull_up>; +};
+sdio0_clk: sdio0-clk { +rockchip,pins = +<2 RK_PD1 RK_FUNC_1 &pcfg_pull_none>; +};
+sdio0_cd: sdio0-cd { +rockchip,pins = +<2 RK_PD2 RK_FUNC_1 &pcfg_pull_up>; +};
+sdio0_pwr: sdio0-pwr { +rockchip,pins = +<2 RK_PD3 RK_FUNC_1 &pcfg_pull_up>; +};
+sdio0_bkpwr: sdio0-bkpwr { +rockchip,pins = +<2 RK_PD4 RK_FUNC_1 &pcfg_pull_up>; +};
+sdio0_wp: sdio0-wp { +rockchip,pins = +<0 RK_PA3 RK_FUNC_1 &pcfg_pull_up>; +};
+sdio0_int: sdio0-int { +rockchip,pins = +<0 RK_PA4 RK_FUNC_1 &pcfg_pull_up>; }; }; sdmmc { sdmmc_bus1: sdmmc-bus1 { rockchip,pins = -<4 8 RK_FUNC_1 &pcfg_pull_up>; +<4 RK_PB0 RK_FUNC_1 &pcfg_pull_up>; }; sdmmc_bus4: sdmmc-bus4 { rockchip,pins = -<4 8 RK_FUNC_1 &pcfg_pull_up>, -<4 9 RK_FUNC_1 &pcfg_pull_up>, -<4 10 RK_FUNC_1 &pcfg_pull_up>, -<4 11 RK_FUNC_1 &pcfg_pull_up>; +<4 RK_PB0 RK_FUNC_1 &pcfg_pull_up>, +<4 RK_PB1 RK_FUNC_1 &pcfg_pull_up>, +<4 RK_PB2 RK_FUNC_1 &pcfg_pull_up>, +<4 RK_PB3 RK_FUNC_1 &pcfg_pull_up>; }; sdmmc_clk: sdmmc-clk { rockchip,pins = -<4 12 RK_FUNC_1 &pcfg_pull_none>; +<4 RK_PB4 RK_FUNC_1 &pcfg_pull_none>; }; sdmmc_cmd: sdmmc-cmd { rockchip,pins = -<4 13 RK_FUNC_1 &pcfg_pull_up>; +<4 RK_PB5 RK_FUNC_1 &pcfg_pull_up>; }; sdmmc_cd: sdmcc-cd { rockchip,pins = -<0 7 RK_FUNC_1 &pcfg_pull_up>; +<0 RK_PA7 RK_FUNC_1 &pcfg_pull_up>; }; sdmmc_wp: sdmmc-wp { rockchip,pins = -<0 8 RK_FUNC_1 &pcfg_pull_up>; +<0 RK_PB0 RK_FUNC_1 &pcfg_pull_up>; +}; +};
+sleep { +ap_pwroff: ap-pwroff { +rockchip,pins = <1 RK_PA5 RK_FUNC_1 &pcfg_pull_none>; +};
+ddrio_pwroff: ddrio-pwroff { +rockchip,pins = <0 RK_PA1 RK_FUNC_1 &pcfg_pull_none>; }; }; spdif { spdif_bus: spdif-bus { rockchip,pins = -<4 21 RK_FUNC_1 &pcfg_pull_none>; +<4 RK_PC5 RK_FUNC_1 &pcfg_pull_none>; +};
+spdif_bus_1: spdif-bus-1 { +rockchip,pins = +<3 RK_PC0 RK_FUNC_3 &pcfg_pull_none>; }; }; spi0 { spi0_clk: spi0-clk { rockchip,pins = -<3 6 RK_FUNC_2 &pcfg_pull_up>; +<3 RK_PA6 RK_FUNC_2 &pcfg_pull_up>; }; spi0_cs0: spi0-cs0 { rockchip,pins = -<3 7 RK_FUNC_2 &pcfg_pull_up>; +<3 RK_PA7 RK_FUNC_2 &pcfg_pull_up>; }; spi0_cs1: spi0-cs1 { rockchip,pins = -<3 8 RK_FUNC_2 &pcfg_pull_up>; +<3 RK_PB0 RK_FUNC_2 &pcfg_pull_up>; }; spi0_tx: spi0-tx { rockchip,pins = -<3 5 RK_FUNC_2 &pcfg_pull_up>; +<3 RK_PA5 RK_FUNC_2 &pcfg_pull_up>; }; spi0_rx: spi0-rx { rockchip,pins = -<3 4 RK_FUNC_2 &pcfg_pull_up>; +<3 RK_PA4 RK_FUNC_2 &pcfg_pull_up>; }; }; spi1 { spi1_clk: spi1-clk { rockchip,pins = -<1 9 RK_FUNC_2 &pcfg_pull_up>; +<1 RK_PB1 RK_FUNC_2 &pcfg_pull_up>; }; spi1_cs0: spi1-cs0 { rockchip,pins = -<1 10 RK_FUNC_2 &pcfg_pull_up>; +<1 RK_PB2 RK_FUNC_2 &pcfg_pull_up>; }; spi1_rx: spi1-rx { rockchip,pins = -<1 7 RK_FUNC_2 &pcfg_pull_up>; +<1 RK_PA7 RK_FUNC_2 &pcfg_pull_up>; }; spi1_tx: spi1-tx { rockchip,pins = -<1 8 RK_FUNC_2 &pcfg_pull_up>; +<1 RK_PB0 RK_FUNC_2 &pcfg_pull_up>; }; }; spi2 { spi2_clk: spi2-clk { rockchip,pins = -<2 11 RK_FUNC_1 &pcfg_pull_up>; +<2 RK_PB3 RK_FUNC_1 &pcfg_pull_up>; }; spi2_cs0: spi2-cs0 { rockchip,pins = -<2 12 RK_FUNC_1 &pcfg_pull_up>; +<2 RK_PB4 RK_FUNC_1 &pcfg_pull_up>; }; spi2_rx: spi2-rx { rockchip,pins = -<2 9 RK_FUNC_1 &pcfg_pull_up>; +<2 RK_PB1 RK_FUNC_1 &pcfg_pull_up>; }; spi2_tx: spi2-tx { rockchip,pins = -<2 10 RK_FUNC_1 &pcfg_pull_up>; +<2 RK_PB2 RK_FUNC_1 &pcfg_pull_up>; }; }; spi3 { spi3_clk: spi3-clk { rockchip,pins = -<1 17 RK_FUNC_1 &pcfg_pull_up>; +<1 RK_PC1 RK_FUNC_1 &pcfg_pull_up>; }; spi3_cs0: spi3-cs0 { rockchip,pins = -<1 18 RK_FUNC_1 &pcfg_pull_up>; +<1 RK_PC2 RK_FUNC_1 &pcfg_pull_up>; }; spi3_rx: spi3-rx { rockchip,pins = -<1 15 RK_FUNC_1 &pcfg_pull_up>; +<1 RK_PB7 RK_FUNC_1 &pcfg_pull_up>; }; spi3_tx: spi3-tx { rockchip,pins = -<1 16 RK_FUNC_1 &pcfg_pull_up>; +<1 RK_PC0 RK_FUNC_1 &pcfg_pull_up>; }; }; spi4 { spi4_clk: spi4-clk { rockchip,pins = -<3 2 RK_FUNC_2 &pcfg_pull_up>; +<3 RK_PA2 RK_FUNC_2 &pcfg_pull_up>; }; spi4_cs0: spi4-cs0 { rockchip,pins = -<3 3 RK_FUNC_2 &pcfg_pull_up>; +<3 RK_PA3 RK_FUNC_2 &pcfg_pull_up>; }; spi4_rx: spi4-rx { rockchip,pins = -<3 0 RK_FUNC_2 &pcfg_pull_up>; +<3 RK_PA0 RK_FUNC_2 &pcfg_pull_up>; }; spi4_tx: spi4-tx { rockchip,pins = -<3 1 RK_FUNC_2 &pcfg_pull_up>; +<3 RK_PA1 RK_FUNC_2 &pcfg_pull_up>; }; }; spi5 { spi5_clk: spi5-clk { rockchip,pins = -<2 22 RK_FUNC_2 &pcfg_pull_up>; +<2 RK_PC6 RK_FUNC_2 &pcfg_pull_up>; }; spi5_cs0: spi5-cs0 { rockchip,pins = -<2 23 RK_FUNC_2 &pcfg_pull_up>; +<2 RK_PC7 RK_FUNC_2 &pcfg_pull_up>; }; spi5_rx: spi5-rx { rockchip,pins = -<2 20 RK_FUNC_2 &pcfg_pull_up>; +<2 RK_PC4 RK_FUNC_2 &pcfg_pull_up>; }; spi5_tx: spi5-tx { rockchip,pins = -<2 21 RK_FUNC_2 &pcfg_pull_up>; +<2 RK_PC5 RK_FUNC_2 &pcfg_pull_up>; +}; +};
+tsadc { +otp_gpio: otp-gpio { +rockchip,pins = <1 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; +};
+otp_out: otp-out { +rockchip,pins = <1 RK_PA6 RK_FUNC_1 &pcfg_pull_none>; }; }; uart0 { uart0_xfer: uart0-xfer { rockchip,pins = -<2 16 RK_FUNC_1 &pcfg_pull_up>, -<2 17 RK_FUNC_1 &pcfg_pull_none>; +<2 RK_PC0 RK_FUNC_1 &pcfg_pull_up>, +<2 RK_PC1 RK_FUNC_1 &pcfg_pull_none>; }; uart0_cts: uart0-cts { rockchip,pins = -<2 18 RK_FUNC_1 &pcfg_pull_none>; +<2 RK_PC2 RK_FUNC_1 &pcfg_pull_none>; }; uart0_rts: uart0-rts { rockchip,pins = -<2 19 RK_FUNC_1 &pcfg_pull_none>; +<2 RK_PC3 RK_FUNC_1 &pcfg_pull_none>; }; }; uart1 { uart1_xfer: uart1-xfer { rockchip,pins = -<3 12 RK_FUNC_2 &pcfg_pull_up>, -<3 13 RK_FUNC_2 &pcfg_pull_none>; +<3 RK_PB4 RK_FUNC_2 &pcfg_pull_up>, +<3 RK_PB5 RK_FUNC_2 &pcfg_pull_none>; }; }; uart2a { uart2a_xfer: uart2a-xfer { rockchip,pins = -<4 8 RK_FUNC_2 &pcfg_pull_up>, -<4 9 RK_FUNC_2 &pcfg_pull_none>; +<4 RK_PB0 RK_FUNC_2 &pcfg_pull_up>, +<4 RK_PB1 RK_FUNC_2 &pcfg_pull_none>; }; }; uart2b { uart2b_xfer: uart2b-xfer { rockchip,pins = -<4 16 RK_FUNC_2 &pcfg_pull_up>, -<4 17 RK_FUNC_2 &pcfg_pull_none>; +<4 RK_PC0 RK_FUNC_2 &pcfg_pull_up>, +<4 RK_PC1 RK_FUNC_2 &pcfg_pull_none>; }; }; uart2c { uart2c_xfer: uart2c-xfer { rockchip,pins = -<4 19 RK_FUNC_1 &pcfg_pull_up>, -<4 20 RK_FUNC_1 &pcfg_pull_none>; +<4 RK_PC3 RK_FUNC_1 &pcfg_pull_up>, +<4 RK_PC4 RK_FUNC_1 &pcfg_pull_none>; }; }; uart3 { uart3_xfer: uart3-xfer { rockchip,pins = -<3 14 RK_FUNC_2 &pcfg_pull_up>, -<3 15 RK_FUNC_2 &pcfg_pull_none>; +<3 RK_PB6 RK_FUNC_2 &pcfg_pull_up>, +<3 RK_PB7 RK_FUNC_2 &pcfg_pull_none>; }; uart3_cts: uart3-cts { rockchip,pins = -<3 18 RK_FUNC_2 &pcfg_pull_none>; +<3 RK_PC2 RK_FUNC_2 &pcfg_pull_none>; }; uart3_rts: uart3-rts { rockchip,pins = -<3 19 RK_FUNC_2 &pcfg_pull_none>; +<3 RK_PC3 RK_FUNC_2 &pcfg_pull_none>; }; }; uart4 { uart4_xfer: uart4-xfer { rockchip,pins = -<1 7 RK_FUNC_1 &pcfg_pull_up>, -<1 8 RK_FUNC_1 &pcfg_pull_none>; +<1 RK_PA7 RK_FUNC_1 &pcfg_pull_up>, +<1 RK_PB0 RK_FUNC_1 &pcfg_pull_none>; }; }; uarthdcp { uarthdcp_xfer: uarthdcp-xfer { rockchip,pins = -<4 21 RK_FUNC_2 &pcfg_pull_up>, -<4 22 RK_FUNC_2 &pcfg_pull_none>; +<4 RK_PC5 RK_FUNC_2 &pcfg_pull_up>, +<4 RK_PC6 RK_FUNC_2 &pcfg_pull_none>; }; }; pwm0 { pwm0_pin: pwm0-pin { rockchip,pins = -<4 18 RK_FUNC_1 &pcfg_pull_none>; +<4 RK_PC2 RK_FUNC_1 &pcfg_pull_none>; }; vop0_pwm_pin: vop0-pwm-pin { rockchip,pins = -<4 18 RK_FUNC_2 &pcfg_pull_none>; +<4 RK_PC2 RK_FUNC_2 &pcfg_pull_none>; }; }; pwm1 { pwm1_pin: pwm1-pin { rockchip,pins = -<4 22 RK_FUNC_1 &pcfg_pull_none>; +<4 RK_PC6 RK_FUNC_1 &pcfg_pull_none>; }; vop1_pwm_pin: vop1-pwm-pin { rockchip,pins = -<4 18 RK_FUNC_3 &pcfg_pull_none>; +<4 RK_PC2 RK_FUNC_3 &pcfg_pull_none>; }; }; pwm2 { pwm2_pin: pwm2-pin { rockchip,pins = -<1 19 RK_FUNC_1 &pcfg_pull_none>; +<1 RK_PC3 RK_FUNC_1 &pcfg_pull_none>; }; }; pwm3a { pwm3a_pin: pwm3a-pin { rockchip,pins = -<0 6 RK_FUNC_1 &pcfg_pull_none>; +<0 RK_PA6 RK_FUNC_1 &pcfg_pull_none>; }; }; pwm3b { pwm3b_pin: pwm3b-pin { rockchip,pins = -<1 14 RK_FUNC_1 &pcfg_pull_none>; +<1 RK_PB6 RK_FUNC_1 &pcfg_pull_none>; }; };
+hdmi { +hdmi_i2c_xfer: hdmi-i2c-xfer { +rockchip,pins = +<4 RK_PC1 RK_FUNC_3 &pcfg_pull_none>, +<4 RK_PC0 RK_FUNC_3 &pcfg_pull_none>; +};
+hdmi_cec: hdmi-cec { +rockchip,pins = +<4 RK_PC7 RK_FUNC_1 &pcfg_pull_none>; +}; +};
+pcie { +pcie_clkreqn: pci-clkreqn { +rockchip,pins = +<2 RK_PD2 RK_FUNC_2 &pcfg_pull_none>; +};
+pcie_clkreqnb: pci-clkreqnb { +rockchip,pins = +<4 RK_PD0 RK_FUNC_1 &pcfg_pull_none>; +};
+pcie_clkreqn_cpm: pci-clkreqn-cpm { +rockchip,pins = +<2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; +};
+pcie_clkreqnb_cpm: pci-clkreqnb-cpm { +rockchip,pins = +<4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; +}; +};
}; }; diff --git a/include/dt-bindings/pinctrl/rockchip.h b/include/dt-bindings/pinctrl/rockchip.h index ecb76c7..0798287 100644 --- a/include/dt-bindings/pinctrl/rockchip.h +++ b/include/dt-bindings/pinctrl/rockchip.h @@ -4,7 +4,7 @@
- Copyright (c) 2013 MundoReader S.L.
- Author: Heiko Stuebner <heiko@sntech.de mailto:heiko@sntech.de>
@@ -17,6 +17,39 @@ #define RK_GPIO44 #define RK_GPIO66 +#define RK_PA00 +#define RK_PA11 +#define RK_PA22 +#define RK_PA33 +#define RK_PA44 +#define RK_PA55 +#define RK_PA66 +#define RK_PA77 +#define RK_PB08 +#define RK_PB19 +#define RK_PB210 +#define RK_PB311 +#define RK_PB412 +#define RK_PB513 +#define RK_PB614 +#define RK_PB715 +#define RK_PC016 +#define RK_PC117 +#define RK_PC218 +#define RK_PC319 +#define RK_PC420 +#define RK_PC521 +#define RK_PC622 +#define RK_PC723 +#define RK_PD024 +#define RK_PD125 +#define RK_PD226 +#define RK_PD327 +#define RK_PD428 +#define RK_PD529 +#define RK_PD630 +#define RK_PD731
#define RK_FUNC_GPIO0 #define RK_FUNC_11 #define RK_FUNC_22 diff --git a/include/dt-bindings/power/rk3399-power.h b/include/dt-bindings/power/rk3399-power.h new file mode 100644 index 0000000..168b3bf --- /dev/null +++ b/include/dt-bindings/power/rk3399-power.h @@ -0,0 +1,53 @@ +#ifndef __DT_BINDINGS_POWER_RK3399_POWER_H__ +#define __DT_BINDINGS_POWER_RK3399_POWER_H__
+/* VD_CORE_L */ +#define RK3399_PD_A53_L00 +#define RK3399_PD_A53_L11 +#define RK3399_PD_A53_L22 +#define RK3399_PD_A53_L33 +#define RK3399_PD_SCU_L4
+/* VD_CORE_B */ +#define RK3399_PD_A72_B05 +#define RK3399_PD_A72_B16 +#define RK3399_PD_SCU_B7
+/* VD_LOGIC */ +#define RK3399_PD_TCPD08 +#define RK3399_PD_TCPD19 +#define RK3399_PD_CCI10 +#define RK3399_PD_CCI011 +#define RK3399_PD_CCI112 +#define RK3399_PD_PERILP13 +#define RK3399_PD_PERIHP14 +#define RK3399_PD_VIO15 +#define RK3399_PD_VO16 +#define RK3399_PD_VOPB17 +#define RK3399_PD_VOPL18 +#define RK3399_PD_ISP019 +#define RK3399_PD_ISP120 +#define RK3399_PD_HDCP21 +#define RK3399_PD_GMAC22 +#define RK3399_PD_EMMC23 +#define RK3399_PD_USB324 +#define RK3399_PD_EDP25 +#define RK3399_PD_GIC26 +#define RK3399_PD_SD27 +#define RK3399_PD_SDIOAUDIO28 +#define RK3399_PD_ALIVE29
+/* VD_CENTER */ +#define RK3399_PD_CENTER30 +#define RK3399_PD_VCODEC31 +#define RK3399_PD_VDU32 +#define RK3399_PD_RGA33 +#define RK3399_PD_IEP34
+/* VD_GPU */ +#define RK3399_PD_GPU35
+/* VD_PMU */ +#define RK3399_PD_PMU36
Hi Philipp,
Hi Simon,
Kever & Simon,
I’d prefer if we can remove ‘clock-freq-min-max’, as it’s deprecated upstream. A patch to adapt the rockchip_dw_mmc driver glue is already on patchworks: https://patchwork.ozlabs.org/patch/754607/
I.e. I’d prefer v2 of the patch to be merged and v3 to be ignored.
Regards, Philipp.
Hi Simon,
Please don't merge this V2 patch, there is a regression on dw-mmc,
a property 'clock-freq-min-max' is missing after sync with kernel driver,
I will send a new version.
Thanks,
- Kever
On 04/19/2017 06:17 PM, Kever Yang wrote:
The kernel dts has update a lot since the first time we commit rk3399.dtsi, sync with kernel for further development.
Changes in v2: None
arch/arm/dts/rk3399.dtsi | 1274 +++++++++++++++++++++++++----- include/dt-bindings/pinctrl/rockchip.h | 35 +- include/dt-bindings/power/rk3399-power.h | 53 ++ 3 files changed, 1157 insertions(+), 205 deletions(-) create mode 100644 include/dt-bindings/power/rk3399-power.h
Applied to u-boot-rockchip/next, thanks!
Dr. Philipp Tomsich
Kever Yang
sjg@google.com
