[U-Boot] Please pull u-boot-marvell master
Hi Tom,
can you please pull the collected work from Dirk, Kevin, Quentin, Stefan and me on the mvebu and kirkwood SoC? Thank you!
The following changes since commit 3d4825446e4258192e1f2302d691a8c0c82a0975:
Prepare v2016.01-rc1 (2015-11-16 20:29:51 -0500)
git://git.denx.de/u-boot-marvell.git
for you to fetch changes up to 6a26748c5e5558073b72ff55de4dc3ea245d3726:
arm: kirkwood: ib62x0: drop duplicate defines from CONFIG_SYS_MVFS (2015-11-17 23:41:41 +0100)
---------------------------------------------------------------- Dirk Eibach (1): arm: mvebu: Fix SAR1_CPU_CORE_MASK
Kevin Smith (3): arm: mvebu: a38x: Remove unsupported topologies arm: mvebu: a38x: Add const to some function calls arm: mvebu: a38x: serdes specification cleanup
Luka Perkov (6): arm: kirkwood: ib62x0: drop CONFIG_MACH_TYPE arm: kirkwood: ib62x0: build u-boot.kwb arm: kirkwood: ib62x0: drop CONFIG_CMD_ENV define arm: kirkwood: ib62x0: make use of defconfig arm: kirkwood: ib62x0: drop dev CONFIG_OF_LIBFDT arm: kirkwood: ib62x0: drop duplicate defines from CONFIG_SYS_MVFS
Quentin Armitage (7): arm: kirkwood: standardise the configuration arm: kirkwood: Remove duplicate definition of CONFIG_CMD_FAT arm: kirkwood: Move configuration of some commands to _defconfig files arm: kirkwood: Use common definition for filesystems arm: kirkwood: Align configuration files arm: kirkwood: Remove duplicate definition from dreamplug.h arm: kirkwood: Move common definitions into common file
Stefan Roese (1): tools/kwbimage.c: Fix generation of binary header
arch/arm/mach-mvebu/serdes/a38x/Makefile | 1 - arch/arm/mach-mvebu/serdes/a38x/ctrl_pex.c | 13 +- arch/arm/mach-mvebu/serdes/a38x/ctrl_pex.h | 2 +- .../serdes/a38x/high_speed_env_spec-38x.c | 1 - .../mach-mvebu/serdes/a38x/high_speed_env_spec.c | 103 +- .../mach-mvebu/serdes/a38x/high_speed_env_spec.h | 8 +- .../serdes/a38x/high_speed_topology_spec-38x.c | 1009 -------------------- .../serdes/a38x/high_speed_topology_spec.h | 124 --- arch/arm/mach-mvebu/serdes/a38x/seq_exec.c | 1 - arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.c | 151 --- arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.h | 2 - board/Marvell/db-88f6820-gp/db-88f6820-gp.c | 17 + configs/dreamplug_defconfig | 5 + configs/guruplug_defconfig | 5 + configs/ib62x0_defconfig | 5 + configs/sheevaplug_defconfig | 5 + drivers/ddr/marvell/a38x/ddr3_a38x.h | 5 - .../ddr/marvell/a38x/ddr3_hws_hw_training_def.h | 7 +- drivers/ddr/marvell/a38x/ddr3_init.c | 72 -- include/configs/dreamplug.h | 34 +- include/configs/guruplug.h | 52 +- include/configs/ib62x0.h | 30 +- include/configs/mv-plug-common.h | 64 ++ include/configs/sheevaplug.h | 49 +- tools/kwbimage.c | 12 +- 25 files changed, 175 insertions(+), 1602 deletions(-) delete mode 100644 arch/arm/mach-mvebu/serdes/a38x/high_speed_topology_spec-38x.c delete mode 100644 arch/arm/mach-mvebu/serdes/a38x/high_speed_topology_spec.h create mode 100644 include/configs/mv-plug-common.h
Regards, Luka
On Tue, Nov 17, 2015 at 10:46:31PM +0000, Luka Perkov wrote:
Hi Tom,
Luka Perkov
