[U-Boot] [PATCH] net/eth: fix a bug in on_ethaddr()
The loop should check all ethenet devices, not only the first device, to set each specified ethaddr, or it'll cause failure when we use other devices.
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com
diff --git a/net/eth.c b/net/eth.c index d3ec8d6..e3ef80e 100644 --- a/net/eth.c +++ b/net/eth.c @@ -677,6 +677,7 @@ static int on_ethaddr(const char *name, const char *value, enum env_op op, memset(dev->enetaddr, 0, 6); } } + dev = dev->next; } while (dev != eth_devices);
Hi Gong,
On Sun, Aug 30, 2015 at 10:34 PM, Gong Qianyu Qianyu.Gong@freescale.com wrote:
-----Original Message----- From: Joe Hershberger [mailto:joe.hershberger@gmail.com] Sent: Friday, September 04, 2015 5:46 AM To: Gong Qianyu-B52263 Cc: Joe Hershberger; u-boot; Hu Mingkai-B21284 Subject: Re: [U-Boot] [PATCH] net/eth: fix a bug in on_ethaddr()
Hi Gong,
The problem still exists. Please help to merge this patch. Thanks!
Regards, Qianyu
Hi Joe,
Would you please kindly help to pick up this patch which fixed the issue when using multiple Ethernet ports?
Thanks, Mingkai
-----Original Message----- From: Gong Qianyu-B52263 Sent: Friday, October 16, 2015 7:22 PM To: Joe Hershberger Cc: Joe Hershberger; u-boot; Hu Mingkai-B21284 Subject: RE: [U-Boot] [PATCH] net/eth: fix a bug in on_ethaddr()
Hi Gong,
Regards, Qianyu
On Wed, Oct 21, 2015 at 5:07 AM, Hu Vincent Mingkai.Hu@freescale.com wrote:
Hi Joe,
Yes, now that the merge window is open, I will be pulling in all patches assigned to me in patchwork and testing.
-Joe
Hi Joe,
Do you have any objection about this patch? If yes, then please share your comments then we can refine it. If no, would you please help to pick up the patch?
Thanks in advance. Mingkai
-----Original Message----- From: Hu Mingkai-B21284 Sent: Wednesday, October 21, 2015 6:07 PM To: Gong Qianyu-B52263; Joe Hershberger Cc: Joe Hershberger; u-boot Subject: RE: [U-Boot] [PATCH] net/eth: fix a bug in on_ethaddr()
Hi Joe,
Thanks, Mingkai
Hi Gong,
Regards, Qianyu
Applied to u-boot-net/master, thanks! -Joe
Gong Q.Y.
Gong Qianyu
Hu Vincent
Joe Hershberger
