[PATCH v3 1/7] dt-bindings: rockchip: Sync rockchip, vop2.h from Linux
Sync rockchip,vop2.h from linux-next, and the last commit is
commit <604be85547ce> ("drm/rockchip: Add VOP2 driver")
Reviewed-by: Kever Yang kever.yang@rock-chips.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v3: - none Changes for v2: - collect Kever RB
include/dt-bindings/soc/rockchip,vop2.h | 14 ++++++++++++++ 1 file changed, 14 insertions(+) create mode 100644 include/dt-bindings/soc/rockchip,vop2.h
diff --git a/include/dt-bindings/soc/rockchip,vop2.h b/include/dt-bindings/soc/rockchip,vop2.h new file mode 100644 index 0000000000..6e66a802b9 --- /dev/null +++ b/include/dt-bindings/soc/rockchip,vop2.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0 OR BSD-2-Clause */ + +#ifndef __DT_BINDINGS_ROCKCHIP_VOP2_H +#define __DT_BINDINGS_ROCKCHIP_VOP2_H + +#define ROCKCHIP_VOP2_EP_RGB0 1 +#define ROCKCHIP_VOP2_EP_HDMI0 2 +#define ROCKCHIP_VOP2_EP_EDP0 3 +#define ROCKCHIP_VOP2_EP_MIPI0 4 +#define ROCKCHIP_VOP2_EP_LVDS0 5 +#define ROCKCHIP_VOP2_EP_MIPI1 6 +#define ROCKCHIP_VOP2_EP_LVDS1 7 + +#endif /* __DT_BINDINGS_ROCKCHIP_VOP2_H */
Radxa Compute Module 3(CM3) is one of the modules from a series System On Module based on the Radxa ROCK 3 series and is compatible with Raspberry Pi CM4 pinout and form factor.
Specification: - Rockchip RK3566 - up to 8GB LPDDR4 - up to 128GB high performance eMMC - Optional wireless LAN, 2.4GHz and 5.0GHz IEEE 802.11b/g/n/ac wireless, BT 5.0, BLE with onboard and external antenna. - Gigabit Ethernet PHY
Radxa CM3 needs to mount on top of this IO board in order to create complete Radxa CM3 IO board platform.
Since Radxa CM3 is compatible with Raspberry Pi CM4 pinout so it is possible to mount Radxa CM3 on top of the Rasberry Pi CM4 IO board.
linux-next commit for the same,
commit <8f19828844f2> ("arm64: dts: rockchip: Fix compatible for Radxa CM3")
Add support for Radxa CM3.
Reviewed-by: Kever Yang kever.yang@rock-chips.com Co-developed-by: FUKAUMI Naoki naoki@radxa.com Signed-off-by: FUKAUMI Naoki naoki@radxa.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v3: - updated linux-next commit Changes for v2: - collect Kever RB - add linux-next commit
arch/arm/dts/rk3566-radxa-cm3.dtsi | 425 +++++++++++++++++++++++++++++ 1 file changed, 425 insertions(+) create mode 100644 arch/arm/dts/rk3566-radxa-cm3.dtsi
diff --git a/arch/arm/dts/rk3566-radxa-cm3.dtsi b/arch/arm/dts/rk3566-radxa-cm3.dtsi new file mode 100644 index 0000000000..45de2630bb --- /dev/null +++ b/arch/arm/dts/rk3566-radxa-cm3.dtsi @@ -0,0 +1,425 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2022 Radxa Limited + * Copyright (c) 2022 Amarula Solutions(India) + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/leds/common.h> + +/ { + compatible = "radxa,cm3", "rockchip,rk3566"; + + aliases { + mmc0 = &sdhci; + }; + + leds { + compatible = "gpio-leds"; + + led-0 { + gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_STATUS; + linux,default-trigger = "timer"; + default-state = "on"; + pinctrl-names = "default"; + pinctrl-0 = <&user_led2>; + }; + }; + + vcc_sys: vcc-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vcc_1v8: vcc-1v8-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_1v8_p>; + }; + + vcc_3v3: vcc-3v3-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_3v3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc3v3_sys>; + }; + + vcca_1v8: vcca-1v8-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcca_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_1v8_p>; + }; + + sdio_pwrseq: pwrseq-sdio { + compatible = "mmc-pwrseq-simple"; + clocks = <&rk817 1>; + clock-names = "ext_clock"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_reg_on_h>; + reset-gpios = <&gpio2 RK_PB7 GPIO_ACTIVE_LOW>; + }; +}; + +&cpu0 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu1 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu2 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu3 { + cpu-supply = <&vdd_cpu>; +}; + +&gpu { + mali-supply = <&vdd_gpu_npu>; + status = "okay"; +}; + +&i2c0 { + status = "okay"; + + vdd_cpu: regulator@1c { + compatible = "tcs,tcs4525"; + reg = <0x1c>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1390000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + rk817: pmic@20 { + compatible = "rockchip,rk817"; + reg = <0x20>; + #clock-cells = <1>; + clock-output-names = "rk817-clkout1", "rk817-clkout2"; + interrupt-parent = <&gpio0>; + interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + + vcc1-supply = <&vcc_sys>; + vcc2-supply = <&vcc_sys>; + vcc3-supply = <&vcc_sys>; + vcc4-supply = <&vcc_sys>; + vcc5-supply = <&vcc_sys>; + vcc6-supply = <&vcc_sys>; + vcc7-supply = <&vcc_sys>; + + regulators { + vdd_logic: DCDC_REG1 { + regulator-name = "vdd_logic"; + regulator-always-on; + regulator-boot-on; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <900000>; + }; + }; + + vdd_gpu_npu: DCDC_REG2 { + regulator-name = "vdd_gpu_npu"; + regulator-always-on; + regulator-boot-on; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-initial-mode = <0x2>; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc3v3_sys: DCDC_REG4 { + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcca1v8_pmu: LDO_REG1 { + regulator-name = "vcca1v8_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdda_0v9: LDO_REG2 { + regulator-name = "vdda_0v9"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda0v9_pmu: LDO_REG3 { + regulator-name = "vdda0v9_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <900000>; + }; + }; + + vccio_acodec: LDO_REG4 { + regulator-name = "vccio_acodec"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vccio_sd: LDO_REG5 { + regulator-name = "vccio_sd"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_pmu: LDO_REG6 { + regulator-name = "vcc3v3_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcc_1v8_p: LDO_REG7 { + regulator-name = "vcc_1v8_p"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc1v8_dvp: LDO_REG8 { + regulator-name = "vcc1v8_dvp"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc2v8_dvp: LDO_REG9 { + regulator-name = "vcc2v8_dvp"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + }; + }; +}; + +&pinctrl { + bluetooth { + bt_host_wake_h: bt-host-wake-h { + rockchip,pins = <2 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_reg_on_h: bt-reg-on-h { + rockchip,pins = <2 RK_PC0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + bt_wake_host_h: bt-wake-host-h { + rockchip,pins = <2 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + leds { + user_led2: user-led2 { + rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + wifi { + wifi_reg_on_h: wifi-reg-on-h { + rockchip,pins = <2 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + wifi_host_wake_h: wifi-host-wake-h { + rockchip,pins = <2 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pmu_io_domains { + pmuio1-supply = <&vcc3v3_pmu>; + pmuio2-supply = <&vcc_3v3>; + vccio1-supply = <&vccio_acodec>; + vccio2-supply = <&vcc_1v8>; + vccio3-supply = <&vccio_sd>; + vccio4-supply = <&vcc_1v8>; + vccio5-supply = <&vcc_3v3>; + vccio6-supply = <&vcc_3v3>; + vccio7-supply = <&vcc_3v3>; + status = "okay"; +}; + +&saradc { + vref-supply = <&vcca_1v8>; + status = "okay"; +}; + +&sdmmc1 { + #address-cells = <1>; + #size-cells = <0>; + bus-width = <4>; + disable-wp; + cap-sd-highspeed; + cap-sdio-irq; + keep-power-in-suspend; + mmc-pwrseq = <&sdio_pwrseq>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc1_bus4 &sdmmc1_clk &sdmmc1_cmd>; + sd-uhs-sdr104; + vmmc-supply = <&vcc_3v3>; + vqmmc-supply = <&vcc_1v8>; + status = "okay"; + + wifi@1 { + compatible = "brcm,bcm43455-fmac"; + reg = <1>; + interrupt-parent = <&gpio2>; + interrupts = <RK_PC1 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "host-wake"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_host_wake_h>; + }; +}; + +&sdhci { + bus-width = <8>; + max-frequency = <200000000>; + mmc-hs200-1_8v; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe>; + vmmc-supply = <&vcc_3v3>; + vqmmc-supply = <&vcc_1v8>; + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1m0_ctsn &uart1m0_rtsn &uart1m0_xfer>; + status = "okay"; + + bluetooth { + compatible = "brcm,bcm4345c5"; + clocks = <&rk817 1>; + clock-names = "lpo"; + device-wakeup-gpios = <&gpio2 RK_PB2 GPIO_ACTIVE_HIGH>; + host-wakeup-gpios = <&gpio2 RK_PB1 GPIO_ACTIVE_HIGH>; + reset-gpios = <&gpio2 RK_PC0 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&bt_host_wake_h &bt_reg_on_h &bt_wake_host_h>; + vbat-supply = <&vcc_3v3>; + vddio-supply = <&vcc_1v8>; + }; +}; + +&usb2phy0 { + status = "okay"; +}; + +&usb2phy1 { + status = "okay"; +}; + +&tsadc { + rockchip,hw-tshut-mode = <1>; + rockchip,hw-tshut-polarity = <0>; + status = "okay"; +};
Radxa Compute Module 3(CM3) IO board an application board from Radxa and is compatible with Raspberry Pi CM4 IO form factor.
Specification: - 1x HDMI, - 2x MIPI DSI - 2x MIPI CSI2 - 1x eDP - 1x PCIe card - 2x SATA - 2x USB 2.0 Host - 1x USB 3.0 - 1x USB 2.0 OTG - Phone jack - microSD slot - 40-pin GPIO expansion header - 12V DC
Add support for Radxa CM3 IO Board.
Co-developed-by: FUKAUMI Naoki naoki@radxa.com Signed-off-by: FUKAUMI Naoki naoki@radxa.com Co-developed-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v3: - updated linux-next commit Changes for v2: - collect Kever RB - add linux-next commit
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3566-radxa-cm3-io.dts | 272 +++++++++++++++++++++++++++ 2 files changed, 273 insertions(+) create mode 100644 arch/arm/dts/rk3566-radxa-cm3-io.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d9b719f85d..8d45050c2a 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -165,6 +165,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3399) += \ rk3399pro-rock-pi-n10.dtb
dtb-$(CONFIG_ROCKCHIP_RK3568) += \ + rk3566-radxa-cm3-io.dtb \ rk3568-evb.dtb
dtb-$(CONFIG_ROCKCHIP_RV1108) += \ diff --git a/arch/arm/dts/rk3566-radxa-cm3-io.dts b/arch/arm/dts/rk3566-radxa-cm3-io.dts new file mode 100644 index 0000000000..d89d5263cb --- /dev/null +++ b/arch/arm/dts/rk3566-radxa-cm3-io.dts @@ -0,0 +1,272 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2022 Radxa Limited + * Copyright (c) 2022 Amarula Solutions(India) + */ + +/dts-v1/; +#include <dt-bindings/soc/rockchip,vop2.h> +#include "rk3566.dtsi" +#include "rk3566-radxa-cm3.dtsi" + +/ { + model = "Radxa Compute Module 3(CM3) IO Board"; + compatible = "radxa,cm3-io", "radxa,cm3", "rockchip,rk3566"; + + aliases { + mmc1 = &sdmmc0; + }; + + chosen: chosen { + stdout-path = "serial2:1500000n8"; + }; + + gmac1_clkin: external-gmac1-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "gmac1_clkin"; + #clock-cells = <0>; + }; + + hdmi-con { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + led-1 { + gpios = <&gpio4 RK_PA4 GPIO_ACTIVE_LOW>; + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_ACTIVITY; + linux,default-trigger = "heartbeat"; + pinctrl-names = "default"; + pinctrl-0 = <&pi_nled_activity>; + }; + }; + + vcc5v0_usb30: vcc5v0-usb30-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usb30"; + enable-active-high; + gpio = <&gpio3 RK_PC2 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_usb30_en_h>; + regulator-always-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc_sys>; + }; + + vcca1v8_image: vcca1v8-image-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcca1v8_image"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_1v8_p>; + }; + + vdda0v9_image: vdda0v9-image-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcca0v9_image"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + vin-supply = <&vdda_0v9>; + }; +}; + +&combphy1 { + status = "okay"; +}; + +&gmac1 { + assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1>; + assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&gmac1_clkin>; + assigned-clock-rates = <0>, <125000000>; + clock_in_out = "input"; + phy-handle = <&rgmii_phy1>; + phy-mode = "rgmii"; + pinctrl-names = "default"; + pinctrl-0 = <&gmac1m0_miim + &gmac1m0_tx_bus2 + &gmac1m0_rx_bus2 + &gmac1m0_rgmii_clk + &gmac1m0_rgmii_bus + &gmac1m0_clkinout>; + snps,reset-gpio = <&gpio4 RK_PC2 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + /* Reset time is 20ms, 100ms for rtl8211f */ + snps,reset-delays-us = <0 20000 100000>; + tx_delay = <0x46>; + rx_delay = <0x2e>; + status = "okay"; +}; + +&hdmi { + avdd-0v9-supply = <&vdda0v9_image>; + avdd-1v8-supply = <&vcca1v8_image>; + status = "okay"; +}; + +&hdmi_in { + hdmi_in_vp0: endpoint { + remote-endpoint = <&vp0_out_hdmi>; + }; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + +&hdmi_sound { + status = "okay"; +}; + +&mdio1 { + rgmii_phy1: ethernet-phy@0 { + compatible="ethernet-phy-ieee802.3-c22"; + reg= <0x0>; + }; +}; + +&pinctrl { + gmac1 { + gmac1m0_miim: gmac1m0-miim { + rockchip,pins = + /* gmac1_mdcm0 */ + <3 RK_PC4 3 &pcfg_pull_none_drv_level_15>, + /* gmac1_mdiom0 */ + <3 RK_PC5 3 &pcfg_pull_none_drv_level_15>; + }; + + gmac1m0_rx_bus2: gmac1m0-rx-bus2 { + rockchip,pins = + /* gmac1_rxd0m0 */ + <3 RK_PB1 3 &pcfg_pull_none_drv_level_15>, + /* gmac1_rxd1m0 */ + <3 RK_PB2 3 &pcfg_pull_none_drv_level_15>, + /* gmac1_rxdvcrsm0 */ + <3 RK_PB3 3 &pcfg_pull_none_drv_level_15>; + }; + + gmac1m0_tx_bus2: gmac1m0-tx-bus2 { + rockchip,pins = + /* gmac1_txd0m0 */ + <3 RK_PB5 3 &pcfg_pull_none_drv_level_15>, + /* gmac1_txd1m0 */ + <3 RK_PB6 3 &pcfg_pull_none_drv_level_15>, + /* gmac1_txenm0 */ + <3 RK_PB7 3 &pcfg_pull_none_drv_level_15>; + }; + + gmac1m0_rgmii_clk: gmac1m0-rgmii-clk { + rockchip,pins = + /* gmac1_rxclkm0 */ + <3 RK_PA7 3 &pcfg_pull_none_drv_level_15>, + /* gmac1_txclkm0 */ + <3 RK_PA6 3 &pcfg_pull_none_drv_level_15>; + }; + + gmac1m0_rgmii_bus: gmac1m0-rgmii-bus { + rockchip,pins = + /* gmac1_rxd2m0 */ + <3 RK_PA4 3 &pcfg_pull_none_drv_level_15>, + /* gmac1_rxd3m0 */ + <3 RK_PA5 3 &pcfg_pull_none_drv_level_15>, + /* gmac1_txd2m0 */ + <3 RK_PA2 3 &pcfg_pull_none_drv_level_15>, + /* gmac1_txd3m0 */ + <3 RK_PA3 3 &pcfg_pull_none_drv_level_15>; + }; + + gmac1m0_clkinout: gmac1m0-clkinout { + rockchip,pins = + /* gmac1_mclkinoutm0 */ + <3 RK_PC0 3 &pcfg_pull_none_drv_level_15>; + }; + }; + + leds { + pi_nled_activity: pi-nled-activity { + rockchip,pins = <4 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + sdcard { + sdmmc_pwren: sdmmc-pwren { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb { + vcc5v0_usb30_en_h: vcc5v0-host-en-h { + rockchip,pins = <3 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&sdmmc0 { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + disable-wp; + vqmmc-supply = <&vccio_sd>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det &sdmmc0_pwren>; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&usb2phy0_host { + phy-supply = <&vcc5v0_usb30>; + status = "okay"; +}; + +&usb2phy1_host { + status = "okay"; +}; + +&usb2phy1_otg { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host1_xhci { + status = "okay"; +}; + +&vop { + assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>; + assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>; + status = "okay"; +}; + +&vop_mmu { + status = "okay"; +}; + +&vp0 { + vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 { + reg = <ROCKCHIP_VOP2_EP_HDMI0>; + remote-endpoint = <&hdmi_in_vp0>; + }; +};
Add support for Radxa CM3 IO Board defconfig and -u-boot.dtsi
arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi | 18 ++++++ board/rockchip/evb_rk3568/MAINTAINERS | 5 ++ configs/radxa-cm3-io-rk3566_defconfig | 68 ++++++++++++++++++++ 3 files changed, 91 insertions(+) create mode 100644 arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi create mode 100644 configs/radxa-cm3-io-rk3566_defconfig
diff --git a/arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi b/arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi new file mode 100644 index 0000000000..3c925161d4 --- /dev/null +++ b/arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi @@ -0,0 +1,18 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2021 Rockchip Electronics Co., Ltd + */ + +#include "rk356x-u-boot.dtsi" + +/ { + chosen { + stdout-path = &uart2; + }; +}; + +&uart2 { + clock-frequency = <24000000>; + u-boot,dm-spl; + status = "okay"; +}; diff --git a/board/rockchip/evb_rk3568/MAINTAINERS b/board/rockchip/evb_rk3568/MAINTAINERS index b6ea498d2b..88d11f05c2 100644 --- a/board/rockchip/evb_rk3568/MAINTAINERS +++ b/board/rockchip/evb_rk3568/MAINTAINERS @@ -4,3 +4,8 @@ S: Maintained F: board/rockchip/evb_rk3568 F: include/configs/evb_rk3568.h F: configs/evb-rk3568_defconfig + +RADXA-CM3 +M: Jagan Teki jagan@amarulasolutions.com +S: Maintained +F: configs/radxa-cm3-io-rk3566_defconfig diff --git a/configs/radxa-cm3-io-rk3566_defconfig b/configs/radxa-cm3-io-rk3566_defconfig new file mode 100644 index 0000000000..10b81e0c6d --- /dev/null +++ b/configs/radxa-cm3-io-rk3566_defconfig @@ -0,0 +1,68 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00a00000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 +CONFIG_DEFAULT_DEVICE_TREE="rk3566-radxa-cm3-io" +CONFIG_DM_RESET=y +CONFIG_ROCKCHIP_RK3568=y +CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y +CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_TARGET_EVB_RK3568=y +CONFIG_SPL_STACK=0x400000 +CONFIG_DEBUG_UART_BASE=0xFE660000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3566-radxa-cm3-io.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x4000000 +CONFIG_SPL_BSS_MAX_SIZE=0x4000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_ATF=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_REGULATOR_PWM=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +# CONFIG_BINMAN_FDT is not set +CONFIG_ERRNO_STR=y
New Rockchip devices have the usb phy nodes as standalone devices. These nodes have register nodes with #address_cells = 2, but only use 32 bit addresses.
Adjust the driver to check if the returned address is "0", and adjust the index in that case.
Derived and adjusted the similar change from linux-next with below commit <9c19c531dc98> ("phy: phy-rockchip-inno-usb2: support #address_cells = 2")
Co-developed-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v3: - new patch
drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 11 ++++++++++- 1 file changed, 10 insertions(+), 1 deletion(-)
diff --git a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c index b32a498ea7..a01148db22 100644 --- a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c +++ b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c @@ -179,12 +179,21 @@ static int rockchip_usb2phy_probe(struct udevice *dev) if (IS_ERR(priv->reg_base)) return PTR_ERR(priv->reg_base);
- ret = ofnode_read_u32(dev_ofnode(dev), "reg", ®); + ret = ofnode_read_u32_index(dev_ofnode(dev), "reg", 0, ®); if (ret) { dev_err(dev, "failed to read reg property (ret = %d)\n", ret); return ret; }
+ /* support address_cells=2 */ + if (reg == 0) { + if (ofnode_read_u32_index(dev_ofnode(dev), "reg", 1, ®)) { + dev_err(dev, "%s must have reg[1]\n", + ofnode_get_name(dev_ofnode(dev))); + return -EINVAL; + } + } + phy_cfgs = (const struct rockchip_usb2phy_cfg *) dev_get_driver_data(dev); if (!phy_cfgs)
From: Manoj Sai abbaraju.manojsai@amarulasolutions.com
RK3568 has two USB 2.0 PHYs, and each PHY has two ports, the OTG port of PHY0 support OTG mode with charging detection function, they are similar to previous Rockchip SoCs.
However, there are three different designs for RK3568 USB 2.0 PHY. 1. RK3568 uses independent USB GRF module for each USB 2.0 PHY. 2. RK3568 accesses the registers of USB 2.0 PHY IP directly by APB. 3. The two ports of USB 2.0 PHY share one interrupt.
This patch only PHY1 with necessary attributes required to function USBPHY1 on U-Boot.
Co-developed-by: Ren Jianing jianing.ren@rock-chips.com Signed-off-by: Ren Jianing jianing.ren@rock-chips.com Co-developed-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com --- Changes for v3: - new patch
drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 29 +++++++++++++++++++ 1 file changed, 29 insertions(+)
diff --git a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c index a01148db22..38cd0f0f33 100644 --- a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c +++ b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c @@ -298,11 +298,40 @@ static const struct rockchip_usb2phy_cfg rk3399_usb2phy_cfgs[] = { { /* sentinel */ } };
+static const struct rockchip_usb2phy_cfg rk3568_phy_cfgs[] = { + { + .reg = 0xfe8b0000, + .port_cfgs = { + [USB2PHY_PORT_OTG] = { + .phy_sus = { 0x0000, 8, 0, 0x1d2, 0x1d1 }, + .ls_det_en = { 0x0080, 0, 0, 0, 1 }, + .ls_det_st = { 0x0084, 0, 0, 0, 1 }, + .ls_det_clr = { 0x0088, 0, 0, 0, 1 }, + .utmi_ls = { 0x00c0, 5, 4, 0, 1 }, + .utmi_hstdet = { 0x00c0, 7, 7, 0, 1 } + }, + [USB2PHY_PORT_HOST] = { + .phy_sus = { 0x0004, 8, 0, 0x1d2, 0x1d1 }, + .ls_det_en = { 0x0080, 1, 1, 0, 1 }, + .ls_det_st = { 0x0084, 1, 1, 0, 1 }, + .ls_det_clr = { 0x0088, 1, 1, 0, 1 }, + .utmi_ls = { 0x00c0, 17, 16, 0, 1 }, + .utmi_hstdet = { 0x00c0, 19, 19, 0, 1 } + } + }, + }, + { /* sentinel */ } +}; + static const struct udevice_id rockchip_usb2phy_ids[] = { { .compatible = "rockchip,rk3399-usb2phy", .data = (ulong)&rk3399_usb2phy_cfgs, }, + { + .compatible = "rockchip,rk3568-usb2phy", + .data = (ulong)&rk3568_phy_cfgs, + }, { /* sentinel */ } };
=> usb start starting USB... Bus usb@fd800000: USB EHCI 1.00 scanning bus usb@fd800000 for devices... 4 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found => usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) | u-boot EHCI Host Controller | +-2 Hub (480 Mb/s, 100mA) | USB 2.0 Hub | +-3 Mass Storage (480 Mb/s, 224mA) | SanDisk Dual Drive 04019c9b2e1a58f24ee318c3c123aa5 | +-4 Human Interface (12 Mb/s, 100mA) CX 2.4G Receiver
configs/radxa-cm3-io-rk3566_defconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/configs/radxa-cm3-io-rk3566_defconfig b/configs/radxa-cm3-io-rk3566_defconfig index 10b81e0c6d..404ada3323 100644 --- a/configs/radxa-cm3-io-rk3566_defconfig +++ b/configs/radxa-cm3-io-rk3566_defconfig @@ -39,6 +39,7 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_ATF=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set # CONFIG_SPL_DOS_PARTITION is not set CONFIG_SPL_OF_CONTROL=y @@ -58,11 +59,15 @@ CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y CONFIG_REGULATOR_PWM=y CONFIG_PWM_ROCKCHIP=y CONFIG_SPL_RAM=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y # CONFIG_BINMAN_FDT is not set CONFIG_ERRNO_STR=y
Hi Kever,
Changes for v3:
- none
Changes for v2:
- collect Kever RB
Any comments on this series?
Jagan.
Jagan Teki
